[U-Boot] TI OMAP3 Fixing i2c initialization.
This patch is against u-boot-ti/master
This fixes a problem I am seeing with an early i2c access on Beagle.
From reviewing the code, it looks like the problem is general so
I included the other omap3 boards in the fix.
Tom
This changes fixes an early i2c error.
It appears that I2C is working because once a read or write error is detected, the omap24xx_i2c driver calls i2c_init inside its error handling check.
While it is ok to attempt error handling this way, the boards must not depend on this side effect to initialize it's i2c.
Instead of explicitly calling i2c_init for every board, use the generic arm initialization in lib_arm/board.c. By defining the config variable CONFIG_HARD_I2C, the omap3 i2c initialization is included in the init_sequence table.
Run tested on Beagle. Compile tested on the omap3's
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- include/configs/devkit8000.h | 1 + include/configs/omap3_beagle.h | 1 + include/configs/omap3_evm.h | 1 + include/configs/omap3_overo.h | 1 + include/configs/omap3_pandora.h | 1 + include/configs/omap3_zoom1.h | 1 + include/configs/omap3_zoom2.h | 1 + 7 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index cd40da6..a8ac786 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -98,6 +98,7 @@ #define CONFIG_DOS_PARTITION 1
/* I2C */ +#define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 #define CONFIG_SYS_I2C_BUS 0 diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 61629f8..55eeb94 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -123,6 +123,7 @@ #undef CONFIG_CMD_NFS /* NFS support */
#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 #define CONFIG_SYS_I2C_BUS 0 diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 9f0f34b..72e9626 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -121,6 +121,7 @@ #undef CONFIG_CMD_IMLS /* List all found images */
#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 #define CONFIG_SYS_I2C_BUS 0 diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 6616b55..c4fd696 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -114,6 +114,7 @@
#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 #define CONFIG_SYS_I2C_BUS 0 diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 1cfd7e9..064c0bc 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -112,6 +112,7 @@ #undef CONFIG_CMD_NFS /* NFS support */
#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 #define CONFIG_SYS_I2C_BUS 0 diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 61a41e7..b55b8f0 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -119,6 +119,7 @@ #undef CONFIG_CMD_NFS /* NFS support */
#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 1 #define CONFIG_SYS_I2C_BUS 0 diff --git a/include/configs/omap3_zoom2.h b/include/configs/omap3_zoom2.h index 03f92f5..75ab980 100644 --- a/include/configs/omap3_zoom2.h +++ b/include/configs/omap3_zoom2.h @@ -140,6 +140,7 @@ #undef CONFIG_CMD_NFS /* NFS support */
Acked-by: Dirk Behme dirk.behme@googlemail.com
Hello Tom,
Patch does not apply:
$ git am --whitespace=strip ../patches/20090928/[U-Boot]\ [PATCH\ 1_1]\ TI\ OMAP3\ Use\ arm\ init\ sequence\ to\ initialize\ i2c.eml Applying: TI OMAP3 Use arm init sequence to initialize i2c error: patch failed: include/configs/omap3_overo.h:114 error: include/configs/omap3_overo.h: patch does not apply Patch failed at 0001. When you have resolved this problem run "git am --resolved". If you would prefer to skip this patch, instead run "git am --skip". To restore the original branch and stop patching run "git am --abort". $
please fix
thanks
bye Heiko
Hi Heiko,
Heiko Schocher wrote:
Hello Tom,
It seems that it applies to u-boot-ti. Is it ok to move it through u-boot-ti into mainline?
Best regards
Dirk
Hello Dirk,
Hello Tom,
This is okay for me, so I just make:
Acked-by: Heiko Schocherhs@denx.de
bye Heiko
Tom,
Do you like to update this against recent u-boot-ti?
It applies fine using quilt
-- cut --
quilt push
Applying patch patches/i2c_fix.txt patching file include/configs/devkit8000.h patching file include/configs/omap3_beagle.h patching file include/configs/omap3_evm.h patching file include/configs/omap3_overo.h Hunk #1 succeeded at 109 with fuzz 1 (offset -5 lines). patching file include/configs/omap3_pandora.h patching file include/configs/omap3_zoom1.h patching file include/configs/omap3_zoom2.h
Now at patch patches/i2c_fix.txt -- cut --
but 'git am' fails
-- cut --
git am patches/i2c_fix.txt
Patch failed at 0001. -- cut --
Something like 'quilt refresh' and then 'git am' helps :)
Strange, not sure why quilt can resolve this, but git not. I haven't found any option for git am to behave like quilt :(
Best regards
Dirk
Dirk Behme wrote:
Tom,
Yes. I developed against the u-boot-ti branch. I will rebase the patches. Tom
Dirk Behme
Heiko Schocher
Tom
Tom Rix
