[U-Boot] [PATCH 1/3] fs-test: Add FAT16 support
Currently we can only test FAT32 which is the default FAT version that mkfs.vfat creates by default. Instead make it explicitly create either a FAT16 or a FAT32 volume. This allows us to exercise more code, for instance the root directory handling is done differently in FAT32 than the older FATs.
Adding FAT12 support is a much bigger job since the test creates a 2.5GB file and the FAT12 maximum partition size is way smaller than that.
Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi --- test/fs/fs-test.sh | 41 +++++++++++++++++++++++++++-------------- 1 file changed, 27 insertions(+), 14 deletions(-)
diff --git a/test/fs/fs-test.sh b/test/fs/fs-test.sh index b19486419e..2ddac50f90 100755 --- a/test/fs/fs-test.sh +++ b/test/fs/fs-test.sh @@ -41,7 +41,7 @@ SMALL_FILE="1MB.file" BIG_FILE="2.5GB.file"
# $MD5_FILE will have the expected md5s when we do the test -# They shall have a suffix which represents their file system (ext4/fat) +# They shall have a suffix which represents their file system (ext4/fat16/...) MD5_FILE="${OUT_DIR}/md5s.list"
# $OUT shall be the prefix of the test output. Their suffix will be .out @@ -104,15 +104,25 @@ function prepare_env() { }
# 1st parameter is the name of the image file to be created -# 2nd parameter is the filesystem - fat ext4 etc +# 2nd parameter is the filesystem - fat16 ext4 etc # -F cant be used with fat as it means something else. function create_image() { # Create image if not already present - saves time, while debugging - if [ "$2" = "ext4" ]; then + case "$2" in + fat16) + MKFS_OPTION="-F 16" + FS_TYPE="fat" + ;; + fat32) + MKFS_OPTION="-F 32" + FS_TYPE="fat" + ;; + ext4) MKFS_OPTION="-F" - else - MKFS_OPTION="" - fi + FS_TYPE="ext4" + ;; + esac + if [ ! -f "$1" ]; then fallocate -l 3G "$1" &> /dev/null if [ $? -ne 0 ]; then @@ -123,8 +133,8 @@ function create_image() { exit $? fi fi - mkfs -t "$2" $MKFS_OPTION "$1" &> /dev/null - if [ $? -ne 0 -a "$2" = "fat" ]; then + mkfs -t "$FS_TYPE" $MKFS_OPTION "$1" &> /dev/null + if [ $? -ne 0 -a "$FS_TYPE" = "fat" ]; then # If we fail and we did fat, try vfat. mkfs -t vfat $MKFS_OPTION "$1" &> /dev/null fi @@ -136,7 +146,7 @@ function create_image() { }
# 1st parameter is image file -# 2nd parameter is file system type - fat/ext4 +# 2nd parameter is file system type - fat16/ext4/... # 3rd parameter is name of small file # 4th parameter is name of big file # 5th parameter is fs/nonfs/sb - to dictate generic fs commands or @@ -149,7 +159,7 @@ function test_image() { length="0x00100000"
case "$2" in - fat) + fat*) FPATH="" PREFIX="fat" WRITE="write" @@ -550,7 +560,7 @@ TOTAL_PASS=0 # In each loop, for a given file system image, we test both the # fs command, like load/size/write, the file system specific command # like: ext4load/ext4size/ext4write and the sb load/ls/save commands. -for fs in ext4 fat; do +for fs in ext4 fat16 fat32; do
echo "Creating $fs image if not already present." IMAGE=${IMG}.${fs}.img @@ -563,11 +573,14 @@ for fs in ext4 fat; do
# Lets mount the image and test sb hostfs commands mkdir -p "$MOUNT_DIR" - if [ "$fs" = "fat" ]; then + case "$fs" in + fat*) uid="uid=`id -u`" - else + ;; + *) uid="" - fi + ;; + esac sudo mount -o loop,rw,$uid "$IMAGE" "$MOUNT_DIR" sudo chmod 777 "$MOUNT_DIR"
If we end up back in the root directory via a '..' directory entry, set itr->is_root accordingly. Failing to do that gives spews like "Invalid FAT entry" and being unable to access directory entries located past the first cluster of the root directory on FAT12/FAT16.
Fixes: 8eafae209c35 ("fat/fs: convert to directory iterators") Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi --- fs/fat/fat.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/fs/fat/fat.c b/fs/fat/fat.c index 36a309c73c..3d3e17e8fa 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -710,13 +710,14 @@ static void fat_itr_child(fat_itr *itr, fat_itr *parent) itr->fsdata = parent->fsdata; if (clustnum > 0) { itr->clust = clustnum; + itr->is_root = 0; } else { itr->clust = parent->fsdata->root_cluster; + itr->is_root = 1; } itr->dent = NULL; itr->remaining = 0; itr->last_cluster = 0; - itr->is_root = 0; }
static void *next_cluster(fat_itr *itr)
The previous commit fixed a problem in FAT code where going back to the root directory using '..' wouldn't work correctly on FAT12 or FAT16. Add a test to exercise this case (which was once fixed in commit 18a10d46f26 "fat: handle paths that include ../" but reintroduced due to the directory iterator refactoring).
This test only very barely catches the problem - without the fix the size command still gives valid output but the additional spurious "Invalid FAT entry" error message makes it not get caught in the 'egrep -A3 ' output. I tried to make a proper test that grows the root directory to two clusters lots of with dummy files but that causes the write tests to crash the sandbox totally...
Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi --- test/fs/fs-test.sh | 14 ++++++++++++-- 1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/test/fs/fs-test.sh b/test/fs/fs-test.sh index 2ddac50f90..a8a55e41fc 100755 --- a/test/fs/fs-test.sh +++ b/test/fs/fs-test.sh @@ -225,10 +225,14 @@ ${PREFIX}ls host${SUFFIX} $6 # We want ${PREFIX}size host 0:0 $3 for host commands and # sb size hostfs - $3 for hostfs commands. # 1MB is 0x0010 0000 -# Test Case 2 - size of small file +# Test Case 2a - size of small file ${PREFIX}size host${SUFFIX} ${FPATH}$FILE_SMALL printenv filesize setenv filesize +# Test Case 2b - size of small file via a path using '..' +${PREFIX}size host${SUFFIX} ${FPATH}SUBDIR/../$FILE_SMALL +printenv filesize +setenv filesize
# 2.5GB (1024*1024*2500) is 0x9C40 0000 # Test Case 3 - size of big file @@ -343,6 +347,9 @@ function create_files() { mkdir -p "$MOUNT_DIR" sudo mount -o loop,rw "$1" "$MOUNT_DIR"
+ # Create a subdirectory. + sudo mkdir -p "$MOUNT_DIR/SUBDIR" + # Create big file in this image. # Note that we work only on the start 1MB, couple MBs in the 2GB range # and the last 1 MB of the huge 2.5GB file. @@ -457,8 +464,11 @@ function check_results() { pass_fail "TC1: ls of $3"
# Check size command on 1MB.file - egrep -A3 "Test Case 2 " "$1" | grep -q "filesize=100000" + egrep -A3 "Test Case 2a " "$1" | grep -q "filesize=100000" pass_fail "TC2: size of $3" + # Check size command on 1MB.file via a path using '..' + egrep -A3 "Test Case 2b " "$1" | grep -q "filesize=100000" + pass_fail "TC2: size of $3 via a path using '..'"
# Check size command on 2.5GB.file egrep -A3 "Test Case 3 " "$1" | grep -q "filesize=9c400000"
Can you post, unrelated, the code that totally crashed sandbox? Maybe that's a problem we need to fix too :)
Otherwise fine, but we need to update the expected results.
jfwiw, I've started looking at the fat_write code, so even a failing/crashing test is useful.
BR, -R
-- Tom
On top of these three (also attached to avoid whitespace damage):
diff --git a/test/fs/fs-test.sh b/test/fs/fs-test.sh index a8a55e41fc..eccc03a513 100755 --- a/test/fs/fs-test.sh +++ b/test/fs/fs-test.sh @@ -110,7 +110,7 @@ function create_image() { # Create image if not already present - saves time, while debugging case "$2" in fat16) - MKFS_OPTION="-F 16" + MKFS_OPTION="-F 16 -r 8192" FS_TYPE="fat" ;; fat32) @@ -363,6 +363,10 @@ function create_files() { &> /dev/null fi
+ for i in $(seq 1 256); do + sudo touch "$MOUNT_DIR/LONGNAME$(head -c 240 /dev/zero | tr '\0' 'X').$i" + done + # Create a small file in this image. if [ ! -f "${MB1}" ]; then sudo dd if=/dev/urandom of="${MB1}" bs=1M count=1 \ @@ -570,7 +574,7 @@ TOTAL_PASS=0 # In each loop, for a given file system image, we test both the # fs command, like load/size/write, the file system specific command # like: ext4load/ext4size/ext4write and the sb load/ls/save commands. -for fs in ext4 fat16 fat32; do +for fs in fat16; do
Basically the problem is that curclust for the root directory is not <= 1 but rather some large positive value (0x01fffffe) in the following snippet in fat_write.c:
867 /* 868 * In FAT16/12, the root dir is locate before data area, shows 869 * in following: 870 * ------------------------------------------------------------- 871 * | Boot | FAT1 & 2 | Root dir | Data (start from cluster #2) | 872 * ------------------------------------------------------------- 873 * 874 * As a result if curclust is in Root dir, it is a negative 875 * number or 0, 1. 876 * 877 */ 878 if (mydata->fatsize != 32 && (int)curclust <= 1) { 879 /* Current clust is in root dir, set to next clust */ 880 curclust++;
With fsdata->data_begin = 896, fsdata->rootdir_sect = 640, fsdata->clust_size = 128, indeed sect_to_clust(rootdir_sect) doesn't underflow enough to be negative but ends up 0x01fffffe. That hack really needs excising from the tree...
Another fun thing that needs handling is that the root directory need not be a multiple of cluster size, being a multiple of sector size is enough according to fatgen103.pdf...
Ah, cool. Please update the top of the script to note the expected PASS/FAIL numbers now that we're testing even more. Everything else looks good tho.
On Sun, Sep 24, 2017 at 5:07 PM, Tuomas Tynkkynen tuomas.tynkkynen@iki.fi wrote:
Thanks
Note that fat12 and fat16 work more similar to each other (other than file allocation table size) compared to fat32. (fat12 and fat16 have a single contiguous root directory, whereas fat32 has a root directory constructed from a chain of clusters, more like how subdirectories work on earlier fat versions).
That said, I think we could probably increase test coverage w/ much smaller filesys image sizes.. my current wishlist:
+ bunch of small files w/ long vfat names, enough that the directory spans multiple clusters.. depends a bit on sector/cluster size but
128 should do the trick.. there might end up being a lower limit on
root directory in fat12/fat16 so this could be a subdir
+ we don't need huge files, but something bigger than cluster size.. 1MB should be sufficient
BR, -R
case "$2" in
fat16)
MKFS_OPTION="-F 16"
FS_TYPE="fat"
fat32)
MKFS_OPTION="-F 32"
FS_TYPE="fat"
else
MKFS_OPTION=""
fi
FS_TYPE="ext4"
esac
case "$2" in
fat)
case "$fs" in
else
*) uid=""
fi
-- 2.13.0
Rob Clark
Tuomas Tynkkynen
