[PATCH] U-Boot ENV in EXT4 support for Espressobin
Hi
I was attemting to boot from SATA on an Espressobin. As such I wanted to store the Environment in a SATA partition and not in the SPI flash. In order to get this running I had to make a few changes, as the original code assumes the Environment is always in SPI flash. Additionally I also had to force scsci_scan to ensure the AHCI disk / partitions could be found.
Hope it will be considered to merge
Regards
Rogier Stam
Hello! See inline comments below.
On Monday 07 February 2022 09:11:06 Rogier Stam wrote:
Hi
Regards
Rogier Stam
From 460eb1fc6d5189750d2ce791e45c89792c476167 Mon Sep 17 00:00:00 2001 From: Rogier Stam rogier@unrailed.org Date: Mon, 31 Jan 2022 23:06:19 +0100 Subject: [PATCH] Fix Espressobin build for configs where ENV is not in SPI
When storing the UBoot Environment in for example EXT4, the U-Boot build is broken for several reasons:
- armada-385-turris-omnia-u-boot.dtsi will not allow CONFIG_ENV_OFFSET and CONFIG_ENV_SIZE to be undefined
- armada-37xx/board.c ft_board_setup function does not exist if CONFIG_ENV_IS_IN_SPI_FLASH is not defined
- When defining CONFIG_ENV_IS_IN_EXT4 and using AHCI SCSI scan is not performed and hence the partition on AHCI is not available when the environment is loaded.
This change fixes these 3 points so that the UBoot config can be on a AHCI (SATA) drive partition instead of enforced in SPI flash.
Signed-off-by: Rogier Stam rogier@unrailed.org
arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 2 ++ board/Marvell/mvebu_armada-37xx/board.c | 4 ++-- env/ext4.c | 4 ++++ 3 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi index 3ff76c9..7921298 100644 --- a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi +++ b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi @@ -41,6 +41,7 @@ &spi0 { u-boot,dm-pre-reloc;
+#ifdef CONFIG_ENV_IS_IN_SPI_FLASH
In my opinion this #ifdef should be put above "&spi0 {" line.
But I will let this change to Marek for review (CCed).
spi-nor@0 { u-boot,dm-pre-reloc;
@@ -55,6 +56,7 @@ }; }; }; +#endif };
&uart0 { diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index d7b6eca..33b772a 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -328,7 +328,6 @@ int board_network_enable(struct mii_dev *bus) return 0; }
-#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) int ft_board_setup(void *blob, struct bd_info *bd) { int ret; @@ -340,6 +339,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) if (!of_machine_is_compatible("globalscale,espressobin")) return 0;
+#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_ENV_IS_IN_SPI_FLASH)
Even this change is not logically correct. Function ft_board_setup() should be defined only when CONFIG_OF_BOARD_SETUP is enabled.
So correct change should look like:
#ifdef CONFIG_OF_BOARD_SETUP int ft_board_setup(void *blob, struct bd_info *bd) { #ifdef CONFIG_ENV_IS_IN_SPI_FLASH int ret; int spi_off; ... #endif return 0; } #endif
spi_off = fdt_node_offset_by_compatible(blob, -1, "jedec,spi-nor"); if (spi_off < 0) return 0; @@ -424,6 +424,6 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; }
+#endif return 0; } -#endif diff --git a/env/ext4.c b/env/ext4.c index 9f65afb..88214b9 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -146,6 +146,10 @@ static int env_ext4_load(void) if (!strcmp(ifname, "mmc")) mmc_initialize(NULL); #endif +#ifdef CONFIG_AHCI
- if (!strcmp(ifname, "scsi"))
scsi_scan(true);
I guess that same change is required also for env/fat.c driver.
part = blk_get_device_part_str(ifname, dev_and_part, &dev_desc, &info, 1); -- 2.7.4
Hi
Per Pali's comments adapted the patch. This one also includes the changes necessary for storing ENV in FAT. I also added CONFIG_SCSI for both ext4 and fat should anyone want to use SCSI instead of AHCI.
Regards
Rogier
On 07-02-2022 09:11, Rogier Stam wrote:
Hi
Regards
Rogier Stam
On Monday 07 February 2022 23:56:25 Rogier Stam wrote:
Hi
Regards
Rogier
Hi
Regards
Rogier Stam
+ Marek
From e2c1b825700b6356b8b0758dcbe8c3c64bd79805 Mon Sep 17 00:00:00 2001 From: Rogier Stam rogier@unrailed.org Date: Mon, 31 Jan 2022 23:06:19 +0100 Subject: [PATCH] Fix Espressobin build for configs where ENV is not in SPI
- Same for CONFIG_ENV_IS_IN_FAT and using AHCI. SCSI scan is not performed.
This change fixes these 4 points so that the UBoot config can be on a AHCI (SATA) drive partition instead of enforced in SPI flash.
Reviewed-by: Pali Rohár pali@kernel.org
arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 2 ++ board/Marvell/mvebu_armada-37xx/board.c | 4 +++- env/ext4.c | 5 +++++ env/fat.c | 5 +++++ 4 files changed, 15 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi index 3ff76c9..008787e 100644 --- a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi +++ b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi @@ -38,6 +38,7 @@ }; };
+#ifdef CONFIG_ENV_IS_IN_SPI_FLASH &spi0 { u-boot,dm-pre-reloc;
@@ -56,6 +57,7 @@ }; }; }; +#endif
&uart0 { u-boot,dm-pre-reloc; diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index d7b6eca..5bace0c 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -328,9 +328,10 @@ int board_network_enable(struct mii_dev *bus) return 0; }
-#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#ifdef CONFIG_OF_BOARD_SETUP int ft_board_setup(void *blob, struct bd_info *bd) { +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH int ret; int spi_off; int parts_off; @@ -424,6 +425,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; }
+#endif return 0; } #endif diff --git a/env/ext4.c b/env/ext4.c index 9f65afb..47e05a4 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -31,6 +31,7 @@ #include <errno.h> #include <ext4fs.h> #include <mmc.h> +#include <scsi.h> #include <asm/global_data.h>
DECLARE_GLOBAL_DATA_PTR; @@ -146,6 +147,10 @@ static int env_ext4_load(void) if (!strcmp(ifname, "mmc")) mmc_initialize(NULL); #endif +#if defined(CONFIG_AHCI) || defined(CONFIG_SCSI)
scsi_scan(true);
part = blk_get_device_part_str(ifname, dev_and_part, &dev_desc, &info, 1); diff --git a/env/fat.c b/env/fat.c index fdccd6c..dbd6a13 100644 --- a/env/fat.c +++ b/env/fat.c @@ -17,6 +17,7 @@ #include <errno.h> #include <fat.h> #include <mmc.h> +#include <scsi.h> #include <asm/cache.h> #include <asm/global_data.h> #include <linux/stddef.h> @@ -122,6 +123,10 @@ static int env_fat_load(void) if (!strcmp(CONFIG_ENV_FAT_INTERFACE, "mmc")) mmc_initialize(NULL); #endif +#if defined(CONFIG_AHCI) || defined(CONFIG_SCSI)
- if (!strcmp(CONFIG_ENV_FAT_INTERFACE, "scsi"))
scsi_scan(true);
part = blk_get_device_part_str(CONFIG_ENV_FAT_INTERFACE, env_fat_device_and_part(), -- 2.7.4
Hi Rogier
On 2/7/22 23:56, Rogier Stam wrote:
Hi
I have 2 comments, more related to formal patch submission.
a) Could you please send patches in-lined, best formatted via "git format-patch" and sent via "git send-email". Otherwise its harder to review and comment the patches.
b) Split you patch into 2 logically separated patches. One handling the common "env" files and one handling the Espressobin related files.
Thanks, Stefan
Regards
Rogier
Hi
Regards
Rogier Stam
Viele Grüße, Stefan Roese
Pali Rohár
Rogier Stam
Stefan Roese
