[U-Boot] why so little use of ft_system_setup()?
still crawling through the code related to FDTs, and while i see a pile of boards that define CONFIG_OF_SYSTEM_SETUP, i see very few that define the corresponding(?) ft_system_setup() routine.
$ grep -r CONFIG_OF_SYSTEM_SETUP * cmd/fdt.c:#ifdef CONFIG_OF_SYSTEM_SETUP cmd/fdt.c:#ifdef CONFIG_OF_SYSTEM_SETUP configs/apalis_t30_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/paz00_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/plutux_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/venice2_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/p2571_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/beaver_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/ventana_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/p2371-0000_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/tec-ng_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/seaboard_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/dalmore_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/harmony_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/cardhu_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/p2371-2180_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/trimslice_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/colibri_t30_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/colibri_t20_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/whistler_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/tec_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/jetson-tk1_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/e2220-1170_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/medcom-wide_defconfig:CONFIG_OF_SYSTEM_SETUP=y configs/nyan-big_defconfig:CONFIG_OF_SYSTEM_SETUP=y include/image.h:#ifdef CONFIG_OF_SYSTEM_SETUP include/fdt_support.h: * This function is called if CONFIG_OF_SYSTEM_SETUP is defined README: CONFIG_OF_SYSTEM_SETUP $
and yet ...
$ grep -rw ft_system_setup * arch/arm/mach-tegra/board2.c:int ft_system_setup(void *blob, bd_t *bd) cmd/fdt.c: int err = ft_system_setup(working_fdt, gd->bd); common/image-fdt.c: fdt_ret = ft_system_setup(blob, gd->bd); include/fdt_support.h:int ft_system_setup(void *blob, bd_t *bd); Kconfig: This causes U-Boot to call ft_system_setup() before booting into README: This causes ft_system_setup() to be called before booting $
am i missing something? what is the point of a board defining that setting but not defining the associated(?) ft_system_setup() function? what else is that CONFIG setting being used for? thanks.
rday
All of those are Tegra boards.
and yet ...
... which link in that file.
and yet ...
ah, quite so, sorry for not noticing that.
rday
Robert P. J. Day
Stephen Warren
