[U-Boot] Please pull u-boot-cfi-flash/master
Hi Tom,
please pull the following patches which have been queued for some time (sorry for the delay):
The following changes since commit 5644369450635fa5c2967bee55b1ac41f6e988d0:
Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-staging (2013-03-31 08:43:12 -0400)
git://www.denx.de/git/u-boot-cfi-flash.git master
for you to fetch changes up to c502321c4a1bc8d859ecf19b22f9d0ce03954fd6:
mtd: cfi_flash: Write buffer size adjustment for M29EW Numonyx devices (2013-04-02 14:27:54 +0200)
---------------------------------------------------------------- Jagannadha Sutradharudu Teki (1): mtd: cfi_flash: Write buffer size adjustment for M29EW Numonyx devices
aaron.williams@caviumnetworks.com (1): mtd: cfi_flash: Fix CFI flash driver for 8-bit bus support
drivers/mtd/cfi_flash.c | 101 +++++++++++++++++++++++++++++++++++++----------- include/mtd/cfi_flash.h | 41 ++++++++++---------- 2 files changed, 99 insertions(+), 43 deletions(-)
On Tue, Apr 02, 2013 at 04:41:24PM +0200, Stefan Roese wrote:
Hi Tom,
Configuring for qemu_mips64 - Board: qemu-mips64, Options: SYS_BIG_ENDIAN text data bss dec hex filename 215344 13082 218720 447146 6d2aa qemu_mips64/u-boot cfi_flash.c: In function 'flash_map': cfi_flash.c:217:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
A patch on top to fix this warning is fine (and the ELDK MIPS toolchain is also fine for qemu_mips64).
Stefan Roese
