[PATCH v5 0/7] rockchip: Add Binman support
This is v5 set for Binman support in rockchip, [1] here is previous patchset.
This series add single boot image with binman for arm32 and pad_cat for arm64 rockchip platforms both TPL + SPL and SPL-alone targets.
Changes for v5: - collect kever review tag - drop idbloader.img from clean target Changes for v4: - support all rockchip platforms - add new patches for dtsi changes - update documentation - format proper commit message - rebase on master Changes for v3: - rebase on master - add binman for rk3288, rk3328, rk3368, rk3399 - added rst documentation for rockchip Changes for v2: - Add few clean target patches - update bl31.elf env handling code, with logging - support puma itb, via BL31 and PMUM0 env - enable BUILD_TARGET for ROCKCHIP_RK3399
[1] https://patchwork.ozlabs.org/cover/1182449/
Any inputs? Jagan.
Jagan Teki (7): Makefile: Add rockchip image type Makefile: rockchip: Suffix platform type with tpl name Makefile: rockchip: Support SPL-alone mkimage Makefile: rockchip: Use u-boot preferred spl name arm: dts: rk3036: Add rk3036-u-boot.dtsi rockchip: Add Single boot image (with binman, pad_cat) doc: boards: Add rockchip documentation
Makefile | 39 +++++++-- arch/arm/Kconfig | 1 + arch/arm/dts/rk3036-sdk-u-boot.dtsi | 2 + arch/arm/dts/rk3036-u-boot.dtsi | 6 ++ arch/arm/dts/rk3288-u-boot.dtsi | 2 + arch/arm/dts/rockchip-u-boot.dtsi | 21 +++++ doc/board/rockchip/index.rst | 10 +++ doc/board/rockchip/rockchip.rst | 128 ++++++++++++++++++++++++++++ include/configs/rockchip-common.h | 2 + 9 files changed, 204 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/rk3036-u-boot.dtsi create mode 100644 arch/arm/dts/rockchip-u-boot.dtsi create mode 100644 doc/board/rockchip/index.rst create mode 100644 doc/board/rockchip/rockchip.rst
Add rockchip image type support. right now the image type marked with rksd, So create image type variable with required image type like rksd or rkspi.
Cc: Kever Yang kever.yang@rock-chips.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Makefile | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index e20a206239..9998d238f3 100644 --- a/Makefile +++ b/Makefile @@ -1374,7 +1374,15 @@ u-boot-with-spl.bin: $(SPL_IMAGE) $(SPL_PAYLOAD) FORCE $(call if_changed,pad_cat)
ifeq ($(CONFIG_ARCH_ROCKCHIP),y) -MKIMAGEFLAGS_u-boot-tpl.img = -n $(CONFIG_SYS_SOC) -T rksd + +# rockchip image type +ifeq ($(CONFIG_SPI_FLASH_SUPPORT),y) +ROCKCHIP_IMG_TYPE := rkspi +else +ROCKCHIP_IMG_TYPE := rksd +endif + +MKIMAGEFLAGS_u-boot-tpl.img = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) tpl/u-boot-tpl.img: tpl/u-boot-tpl.bin FORCE $(call if_changed,mkimage) idbloader.img: tpl/u-boot-tpl.img spl/u-boot-spl.bin FORCE
Most of the platforms uses the platform type on their boot stage image naming conventions in makefile like,
u-boot-x86-start16-tpl.bin - x86 start16 TPL bin u-boot-spl-mtk.bin - Mediatek SPL bin
This would help to understand the users to what that particular image belongs to? and less confused.
On that note, suffix platform type rockchip for existing u-boot-tpl.img so now it become u-boot-tpl-rockchip.bin
Also, bin is more conventional way to include it on tools like binman, pad_cat etc in future patches.
Note: usage of platform type doesn't follow consistent order as of now.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Makefile | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index 9998d238f3..e519103be4 100644 --- a/Makefile +++ b/Makefile @@ -1382,10 +1382,10 @@ else ROCKCHIP_IMG_TYPE := rksd endif
-MKIMAGEFLAGS_u-boot-tpl.img = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) -tpl/u-boot-tpl.img: tpl/u-boot-tpl.bin FORCE +MKIMAGEFLAGS_u-boot-tpl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) +tpl/u-boot-tpl-rockchip.bin: tpl/u-boot-tpl.bin FORCE $(call if_changed,mkimage) -idbloader.img: tpl/u-boot-tpl.img spl/u-boot-spl.bin FORCE +idbloader.img: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE $(call if_changed,cat) endif
Add SPL-alone mkimage tooling support via Makefile for few platforms or boards used in rockchip family.
With this users would get rid of explicitly creating mkimage tool for rockchip rksd or rkspi boot modes.
diff --git a/Makefile b/Makefile index e519103be4..d8a0f68883 100644 --- a/Makefile +++ b/Makefile @@ -908,7 +908,7 @@ ifeq ($(CONFIG_MPC85xx)$(CONFIG_OF_SEPARATE),yy) ALL-y += u-boot-with-dtb.bin endif
-ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL)$(CONFIG_TPL),yyy) +ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL),yy) ALL-y += idbloader.img endif
@@ -1382,11 +1382,19 @@ else ROCKCHIP_IMG_TYPE := rksd endif
+# TPL + SPL +ifeq ($(CONFIG_SPL)$(CONFIG_TPL),yy) MKIMAGEFLAGS_u-boot-tpl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) tpl/u-boot-tpl-rockchip.bin: tpl/u-boot-tpl.bin FORCE $(call if_changed,mkimage) idbloader.img: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE $(call if_changed,cat) +else +MKIMAGEFLAGS_idbloader.img = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) +idbloader.img: spl/u-boot-spl.bin FORCE + $(call if_changed,mkimage) +endif + endif
ifeq ($(CONFIG_ARCH_LPC32XX)$(CONFIG_SPL),yy)
Most of the platforms uses the platform type and particular boot stage on their image naming conventions in makefile like,
u-boot-sunxi-with-spl.bin - Allwinner U-Boot with SPL u-boot-spl-mtk.bin - Mediatek SPL bin
On that note, use u-boot-spl-rockchip.bin instead of idbloader.img. idbloader.img is still a proper naming for rockchip external documentation but u-boot preferred spl name would always good choice in upstream tree.
Note: usage of platform type, boot stage doesn't follow consistent oder as of now.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Makefile | 11 +++++------ 1 file changed, 5 insertions(+), 6 deletions(-)
diff --git a/Makefile b/Makefile index d8a0f68883..b48693e560 100644 --- a/Makefile +++ b/Makefile @@ -909,7 +909,7 @@ ALL-y += u-boot-with-dtb.bin endif
ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL),yy) -ALL-y += idbloader.img +ALL-y += u-boot-spl-rockchip.bin endif
LDFLAGS_u-boot += $(LDFLAGS_FINAL) @@ -1387,11 +1387,11 @@ ifeq ($(CONFIG_SPL)$(CONFIG_TPL),yy) MKIMAGEFLAGS_u-boot-tpl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) tpl/u-boot-tpl-rockchip.bin: tpl/u-boot-tpl.bin FORCE $(call if_changed,mkimage) -idbloader.img: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE +u-boot-spl-rockchip.bin: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE $(call if_changed,cat) else -MKIMAGEFLAGS_idbloader.img = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) -idbloader.img: spl/u-boot-spl.bin FORCE +MKIMAGEFLAGS_u-boot-spl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) +u-boot-spl-rockchip.bin: spl/u-boot-spl.bin FORCE $(call if_changed,mkimage) endif
@@ -1943,8 +1943,7 @@ CLEAN_DIRS += $(MODVERDIR) \ CLEAN_FILES += include/bmp_logo.h include/bmp_logo_data.h tools/version.h \ boot* u-boot* MLO* SPL System.map fit-dtb.blob* \ u-boot-ivt.img.log u-boot-dtb.imx.log SPL.log u-boot.imx.log \ - lpc32xx-* bl31.c bl31.elf bl31_*.bin image.map tispl.bin* \ - idbloader.img + lpc32xx-* bl31.c bl31.elf bl31_*.bin image.map tispl.bin*
# Directories & files removed with 'make mrproper' MRPROPER_DIRS += include/config include/generated spl tpl \
Add U-Boot specific dtsi file for rk3036 SoC. This would help to add U-Boot specific dts nodes, properties which are common across rk3036.
Right now, the file is empty, will add required changes in future patches.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- arch/arm/dts/rk3036-sdk-u-boot.dtsi | 2 ++ arch/arm/dts/rk3036-u-boot.dtsi | 4 ++++ 2 files changed, 6 insertions(+) create mode 100644 arch/arm/dts/rk3036-u-boot.dtsi
diff --git a/arch/arm/dts/rk3036-sdk-u-boot.dtsi b/arch/arm/dts/rk3036-sdk-u-boot.dtsi index 6f15f4a8ec..754800c6e6 100644 --- a/arch/arm/dts/rk3036-sdk-u-boot.dtsi +++ b/arch/arm/dts/rk3036-sdk-u-boot.dtsi @@ -1,3 +1,5 @@ +#include "rk3036-u-boot.dtsi" + &uart2 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3036-u-boot.dtsi b/arch/arm/dts/rk3036-u-boot.dtsi new file mode 100644 index 0000000000..1e7d079315 --- /dev/null +++ b/arch/arm/dts/rk3036-u-boot.dtsi @@ -0,0 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */
All rockchip platforms support TPL or SPL-based bootloader in mainline with U-Boot proper as final stage. For each stage we need to burn the image on to flash with respective offsets.
This patch creates a single boot image component using - binman, for arm32 rockchip platforms - pad_cat, for arm64 rockchip platforms.
This would help users to get rid of burning different boot stage images.
The new image called 'u-boot-rockchip.bin' which can burn into flash like:
₹ sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64
This would support all rockchip platforms, except rk3128 since it doesn't support for SPL yet.
Cc: Kever Yang kever.yang@rock-chips.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Makefile | 18 ++++++++++++++---- arch/arm/Kconfig | 1 + arch/arm/dts/rk3036-u-boot.dtsi | 2 ++ arch/arm/dts/rk3288-u-boot.dtsi | 2 ++ arch/arm/dts/rockchip-u-boot.dtsi | 21 +++++++++++++++++++++ include/configs/rockchip-common.h | 2 ++ 6 files changed, 42 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/rockchip-u-boot.dtsi
diff --git a/Makefile b/Makefile index b48693e560..d5b6c45c89 100644 --- a/Makefile +++ b/Makefile @@ -909,7 +909,7 @@ ALL-y += u-boot-with-dtb.bin endif
ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL),yy) -ALL-y += u-boot-spl-rockchip.bin +ALL-y += u-boot-rockchip.bin endif
LDFLAGS_u-boot += $(LDFLAGS_FINAL) @@ -1387,15 +1387,25 @@ ifeq ($(CONFIG_SPL)$(CONFIG_TPL),yy) MKIMAGEFLAGS_u-boot-tpl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) tpl/u-boot-tpl-rockchip.bin: tpl/u-boot-tpl.bin FORCE $(call if_changed,mkimage) -u-boot-spl-rockchip.bin: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE +spl/u-boot-spl-rockchip.bin: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE $(call if_changed,cat) else MKIMAGEFLAGS_u-boot-spl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T $(ROCKCHIP_IMG_TYPE) -u-boot-spl-rockchip.bin: spl/u-boot-spl.bin FORCE +spl/u-boot-spl-rockchip.bin: spl/u-boot-spl.bin FORCE $(call if_changed,mkimage) endif
-endif +ifeq ($(CONFIG_ARM64),) +u-boot-rockchip.bin: spl/u-boot-spl-rockchip.bin u-boot.img FORCE + $(call if_changed,binman) +else +OBJCOPYFLAGS_u-boot-rockchip.bin = -I binary -O binary \ + --pad-to=$(CONFIG_SPL_PAD_TO) --gap-fill=0xff +u-boot-rockchip.bin: spl/u-boot-spl-rockchip.bin u-boot.itb FORCE + $(call if_changed,pad_cat) +endif # CONFIG_ARM64 + +endif # CONFIG_ARCH_ROCKCHIP
ifeq ($(CONFIG_ARCH_LPC32XX)$(CONFIG_SPL),yy) MKIMAGEFLAGS_lpc32xx-spl.img = -T lpc32xximage -a $(CONFIG_SPL_TEXT_BASE) diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f9dab073ea..7bd99ba3bb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1590,6 +1590,7 @@ config ARCH_STM32MP config ARCH_ROCKCHIP bool "Support Rockchip SoCs" select BLK + select BINMAN if !ARM64 select DM select DM_GPIO select DM_I2C diff --git a/arch/arm/dts/rk3036-u-boot.dtsi b/arch/arm/dts/rk3036-u-boot.dtsi index 1e7d079315..41ac054b81 100644 --- a/arch/arm/dts/rk3036-u-boot.dtsi +++ b/arch/arm/dts/rk3036-u-boot.dtsi @@ -2,3 +2,5 @@ /* * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */ + +#include "rockchip-u-boot.dtsi" diff --git a/arch/arm/dts/rk3288-u-boot.dtsi b/arch/arm/dts/rk3288-u-boot.dtsi index 3f00a3b6d3..6d31735362 100644 --- a/arch/arm/dts/rk3288-u-boot.dtsi +++ b/arch/arm/dts/rk3288-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2019 Rockchip Electronics Co., Ltd */
+#include "rockchip-u-boot.dtsi" + / { chosen { u-boot,spl-boot-order = \ diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi new file mode 100644 index 0000000000..bc0b1412a2 --- /dev/null +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include <config.h> + +/ { + binman { + filename = "u-boot-rockchip.bin"; + pad-byte = <0xff>; + + blob { + filename = "spl/u-boot-spl-rockchip.bin"; + }; + + u-boot-img { + offset = <CONFIG_SPL_PAD_TO>; + }; + }; +}; diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 68e1105a4b..d7f5ca9fa4 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -9,6 +9,8 @@
#define CONFIG_SYS_NS16550_MEM32
+#define CONFIG_SPL_PAD_TO 8355840 + #ifndef CONFIG_SPL_BUILD
/* First try to boot from SD (index 0), then eMMC (index 1) */
пн, 30 дек. 2019 г. в 11:28, Jagan Teki jagan@amarulasolutions.com:
- Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com
- Copyright (C) 2019 Rockchip Electronics Co., Ltd
binman {
pad-byte = <0xff>;
blob {
u-boot-img {
I may be wrong, but shouldn't CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR be used here?
2.18.0.321.gffc6fa0e3
вт, 31 дек. 2019 г. в 10:54, Matwey V. Kornilov matwey.kornilov@gmail.com:
binman {
pad-byte = <0xff>;
blob {
u-boot-img {
I.e.
#define CONFIG_SPL_PAD_TO ((CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR - 64) * 512)
-- With best regards, Matwey V. Kornilov
On Tue, Dec 31, 2019 at 1:34 PM Matwey V. Kornilov matwey.kornilov@gmail.com wrote:
binman {
pad-byte = <0xff>;
blob {
u-boot-img {
I.e.
Yes, I did try this logic. but arm64 compiler throwing warning during build for this. (I'm using gcc 6.3.1)
CAT u-boot-rockchip.bin aarch64-linux-gnu-objcopy: --pad-to: bad number: ((CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR - 64) * 512)
Rockchip has documentation file, doc/README.rockchip but which is not so readable to add or understand the existing contents. Even the format that support is legacy readme in U-Boot.
Add rockchip specific documentation file using new rst format, which describes the information about Rockchip supported boards and it's usage steps.
Added minimal information about rk3288, rk3328, rk3368 and rk3399 boards and usage. This would indeed updated further based on the requirements and updates.
Cc: Kever Yang kever.yang@rock-chips.com Cc: Matwey V. Kornilov matwey.kornilov@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- doc/board/rockchip/index.rst | 10 +++ doc/board/rockchip/rockchip.rst | 128 ++++++++++++++++++++++++++++++++ 2 files changed, 138 insertions(+) create mode 100644 doc/board/rockchip/index.rst create mode 100644 doc/board/rockchip/rockchip.rst
diff --git a/doc/board/rockchip/index.rst b/doc/board/rockchip/index.rst new file mode 100644 index 0000000000..0c377e9bbb --- /dev/null +++ b/doc/board/rockchip/index.rst @@ -0,0 +1,10 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + +Rockchip +======== + +.. toctree:: + :maxdepth: 2 + + rockchip diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst new file mode 100644 index 0000000000..625155e432 --- /dev/null +++ b/doc/board/rockchip/rockchip.rst @@ -0,0 +1,128 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + +ROCKCHIP +======== + +About this +---------- + +This document describes the information about Rockchip supported boards +and it's usage steps. + +Rockchip boards +--------------- + +Rockchip is SoC solutions provider for tablets & PCs, streaming media +TV boxes, AI audio & vision, IoT hardware. + +A wide range of Rockchip SoCs with associated boardsare supported in +mainline U-Boot. + +List of mainline supported rockchip boards: + +* rk3288 + - Evb-RK3288 + - Firefly-RK3288 + - mqmaker MiQi + - Phytec RK3288 PCM-947 + - PopMetal-RK3288 + - Radxa Rock 2 Square + - Tinker-RK3288 + - Google Jerry + - Google Mickey + - Google Minnie + - Google Speedy + - Amarula Vyasa-RK3288 +* rk3328 + - Rockchip RK3328 EVB + - Pine64 Rock64 +* rk3368 + - GeekBox + - PX5 EVB + - Rockchip sheep board + - Theobroma Systems RK3368-uQ7 SoM +* rk3399 + - 96boards RK3399 Ficus + - 96boards Rock960 + - Firefly-RK3399 Board + - Firefly ROC-RK3399-PC Board + - FriendlyElec NanoPC-T4 + - FriendlyElec NanoPi M4 + - FriendlyARM NanoPi NEO4 + - Google Bob + - Khadas Edge + - Khadas Edge-Captain + - Khadas Edge-V + - Orange Pi RK3399 Board + - Pine64 RockPro64 + - Radxa ROCK Pi 4 + - Rockchip RK3399 Evaluation Board + - Theobroma Systems RK3399-Q7 SoM + +Building +-------- + +TF-A +^^^^ + +TF-A would require to build for ARM64 Rockchip SoCs platforms. + +To build TF-A:: + + git clone https://github.com/ARM-software/arm-trusted-firmware.git + cd arm-trusted-firmware + make realclean + make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 + +Specify the PLAT= with desired rockchip platform to build TF-A for. + +U-Boot +^^^^^^ + +To build rk3328 boards:: + + export BL31=/path/to/arm-trusted-firmware/to/bl31.elf + make evb-rk3328_defconfig + make + +To build rk3288 boards:: + + make evb-rk3288_defconfig + make + +To build rk3368 boards:: + + export BL31=/path/to/arm-trusted-firmware/to/bl31.elf + make evb-px5_defconfig + make + +To build rk3399 boards:: + + export BL31=/path/to/arm-trusted-firmware/to/bl31.elf + make evb-rk3399_defconfig + make + +Flashing +-------- + +SD Card +^^^^^^^ + +All rockchip platforms, except rk3128 (which doesn't use SPL) are now +supporting single boot image using binman and pad_cat. + +To write an image that boots from an SD card (assumed to be /dev/sda):: + + sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64 + sync + +TODO +---- + +- Add rockchip idbloader image building +- Describe steps for eMMC flashing +- Add missing SoC's with it boards list + +.. Jagan Teki jagan@amarulasolutions.com +.. Thu Oct 17 22:36:14 IST 2019
Hello,
Thank you for the patch set. Currently, I have the following concern about documentation and overall proposed u-boot deploy procedure.
There is a use case, when I have to use Rockchip proprietary TPL binary and deploy it instead of u-boot's one together with u-boot SPL and ITB images. It is required for debugging purposes because unfortunately u-boot TPL is usually less stable that proprietary one. And switching the TPL binary is basically the first step when I see random strange crashes. It is a good way to locate an issue origin.
Could we somehow ensure that this backup deployment plan is still possible and documented in the text here? It would be great if the user could learn the procedure from the text, not from the source code, recovering correct offsets.
+Rockchip +========
+.. toctree::
- :maxdepth: 2
- rockchip
+ROCKCHIP +========
+* rk3288
- Evb-RK3288
- Firefly-RK3288
- mqmaker MiQi
- PopMetal-RK3288
- Tinker-RK3288
- Google Jerry
- Google Mickey
- Google Minnie
- Google Speedy
+* rk3328
- Pine64 Rock64
+* rk3368
- GeekBox
- PX5 EVB
+* rk3399
- 96boards Rock960
- Google Bob
- Khadas Edge
- Khadas Edge-V
- Pine64 RockPro64
- Radxa ROCK Pi 4
+Building +--------
+TF-A +^^^^
+To build TF-A::
make realclean
+U-Boot +^^^^^^
make
make
make
make
+Flashing +--------
+SD Card +^^^^^^^
sync
+TODO +----
On Mon, Dec 30, 2019 at 2:11 PM Matwey V. Kornilov matwey.kornilov@gmail.com wrote:
Hello,
You mean to say rkbin => SPL => U-Boot proper ? if yes, I do agree with this point and it is worth to document it as well. Kever, will that be okay for you?
Jagan.
пн, 30 дек. 2019 г. в 11:59, Jagan Teki jagan@amarulasolutions.com:
Hello,
Yes, I mean so. I think it would be great to have something like the section describing where do the things came from and the layout which is under the hood.
Jagan.
Jagan Teki
Matwey V. Kornilov
