[U-Boot] [PATCH] Allow CONFIG_BOARD_SIZE_LIMIT to be specified in hex
Use the printf command to convert the number in any valid format into the expected decimal format. The resulting errors should be printed to stderr.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- Makefile | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/Makefile b/Makefile index 2fe1490..41e3e43 100644 --- a/Makefile +++ b/Makefile @@ -386,12 +386,12 @@ __LIBS := $(subst $(obj),,$(LIBS)) $(subst $(obj),,$(LIBBOARD)) ifneq ($(CONFIG_BOARD_SIZE_LIMIT),) BOARD_SIZE_CHECK = \ @actual=`wc -c $@ | awk '{print $$1}'`; \ - limit=$(CONFIG_BOARD_SIZE_LIMIT); \ + limit=`printf "%d" $(CONFIG_BOARD_SIZE_LIMIT)`; \ if test $$actual -gt $$limit; then \ - echo "$@ exceeds file size limit:"; \ - echo " limit: $$limit bytes"; \ - echo " actual: $$actual bytes"; \ - echo " excess: $$((actual - limit)) bytes"; \ + echo "$@ exceeds file size limit:" >&2 ; \ + echo " limit: $$limit bytes" >&2 ; \ + echo " actual: $$actual bytes" >&2 ; \ + echo " excess: $$((actual - limit)) bytes" >&2; \ exit 1; \ fi else
Joe Hershberger
