[U-Boot] [PATCH] i.MX6: arm2: Add AXI cache and Qos setting
Do the same AXI cache and Qos settings done already in the SabreLite imximage.cfg for the ARM2 board, too.
It fixes a display flash issue caused by low priority of the display IDMA channel.
Signed-off-by: Dirk Behme dirk.behme@de.bosch.com CC: Jason Chen b02280@freescale.com CC: Jason Liu r64343@freescale.com CC: Stefano Babic sbabic@denx.de CC: Fabio Estevam festevam@gmail.com --- board/freescale/mx6qarm2/imximage.cfg | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mx6qarm2/imximage.cfg b/board/freescale/mx6qarm2/imximage.cfg index 5f0ee0d..ceecbf9 100644 --- a/board/freescale/mx6qarm2/imximage.cfg +++ b/board/freescale/mx6qarm2/imximage.cfg @@ -165,3 +165,9 @@ DATA 4 0x020c4074 0x3FF00000 DATA 4 0x020c4078 0x00FFF300 DATA 4 0x020c407c 0x0F0000C3 DATA 4 0x020c4080 0x000003FF + +# enable AXI cache for VDOA/VPU/IPU +DATA 4 0x020e0010 0xF00000FF +# set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 +DATA 4 0x020e0018 0x007F007F +DATA 4 0x020e001c 0x007F007F
-----Original Message----- From: Dirk Behme [mailto:dirk.behme@de.bosch.com] Sent: Friday, April 13, 2012 2:46 PM To: u-boot@lists.denx.de Cc: Dirk Behme; Jason Chen; Liu Hui-R64343; Stefano Babic; Fabio Estevam Subject: [PATCH] i.MX6: arm2: Add AXI cache and Qos setting
+# enable AXI cache for VDOA/VPU/IPU +DATA 4 0x020e0010 0xF00000FF +# set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 DATA 4 0x020e0018 +0x007F007F DATA 4 0x020e001c 0x007F007F
Acked-by: Jason Liu r64343@freescale.com
-- 1.7.0.4
Thanks all - this is a fix, I will try to push it for the release.
Best regards, Stefano Babic
Applied to u-boot-imx (fix), thanks.
Dirk Behme
Liu Hui-R64343
Stefano Babic
