[U-Boot] [PATCH 1/3] wandboard: Add card detection for SOM MicroSD card
This add support to identify if the card is connected or not; so it does not try to communicate with the controller if no card is available.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 1 + board/wandboard/wandboard.c | 19 +++++++++++++++++++ 2 files changed, 20 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 9846f1b..b8e6bf0 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -93,6 +93,7 @@ enum { MX6_PAD_EIM_D28__I2C1_SDA = IOMUX_PAD(0x0544, 0x0174, 1 | IOMUX_CONFIG_SION, 0x086C, 1, 0), MX6_PAD_EIM_D28__GPIO_3_28 = IOMUX_PAD(0x0544, 0x0174, 5, 0x0000, 0, 0), MX6_PAD_EIM_D29__GPIO_3_29 = IOMUX_PAD(0x0548, 0x0178, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__GPIO_3_9 = IOMUX_PAD(0x0590, 0x01C0, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x05B8, 0x01E8, 1, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x05BC, 0x01EC, 1, 0x0810, 0, 0), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x05C0, 0x01F0, 1, 0x0000, 0, 0), diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index ac7b89a..a8f6ba2 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -52,6 +52,8 @@ static iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_CSI0_DAT11__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), };
+#define USDHC3_CD_GPIO IMX_GPIO_NR(3, 9) + static iomux_v3_cfg_t const usdhc3_pads[] = { MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -59,6 +61,8 @@ static iomux_v3_cfg_t const usdhc3_pads[] = { MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + /* SOM MicroSD Card Detect */ + MX6_PAD_EIM_DA9__GPIO_3_9 | MUX_PAD_CTRL(NO_PAD_CTRL), };
static iomux_v3_cfg_t const enet_pads[] = { @@ -100,12 +104,27 @@ static struct fsl_esdhc_cfg usdhc_cfg[1] = { {USDHC3_BASE_ADDR}, };
+int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC3_BASE_ADDR: + ret = !gpio_get_value(USDHC3_CD_GPIO); + break; + } + + return ret; +} + int board_mmc_init(bd_t *bis) { imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads));
usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); usdhc_cfg[0].max_bus_width = 4; + gpio_direction_input(USDHC3_CD_GPIO);
return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); }
Allow use of the carrier board MicroSD card available in the Wandboard; this allow for loading alternative system from the other card for testing or upgrade proposes.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 7 ++++ board/wandboard/wandboard.c | 58 ++++++++++++++++++++++++++---- include/configs/wandboard.h | 1 + 3 files changed, 59 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index b8e6bf0..8cedbdc 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -103,6 +103,7 @@ enum { MX6_PAD_GPIO_17__GPIO_7_12 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), MX6_PAD_GPIO_18__GPIO_7_13 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), MX6_PAD_GPIO_19__GPIO_4_5 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_2__GPIO_1_2 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), MX6_PAD_GPIO_5__GPIO_1_5 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), MX6_PAD_GPIO_5__I2C3_SCL = IOMUX_PAD(0x0600, 0x0230, 6 | IOMUX_CONFIG_SION, 0x0878, 2, 0), MX6_PAD_KEY_COL3__I2C2_SCL = IOMUX_PAD(0x0638, 0x0250, 4 | IOMUX_CONFIG_SION, 0x0870, 1, 0), @@ -135,8 +136,14 @@ enum { MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__ENET_RGMII_TXC = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__USDHC1_CLK = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0928, 1, 0), + MX6_PAD_SD1_CMD__USDHC1_CMD = IOMUX_PAD(0x06C8, 0x02E0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_SD1_CMD__GPIO_1_18 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__GPIO_1_21 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__USDHC1_DAT0 = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__USDHC1_DAT1 = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__USDHC1_DAT2 = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__USDHC1_DAT3 = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), MX6_PAD_SD3_CLK__USDHC3_CLK = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0934, 1, 0), MX6_PAD_SD3_CMD__USDHC3_CMD = IOMUX_PAD(0x06F8, 0x0310, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__USDHC3_DAT0 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index a8f6ba2..5d98244 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -52,6 +52,18 @@ static iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_CSI0_DAT11__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), };
+iomux_v3_cfg_t const usdhc1_pads[] = { + MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT0__USDHC1_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT1__USDHC1_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT2__USDHC1_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT3__USDHC1_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + /* Carrier MicroSD Card Detect */ + MX6_PAD_GPIO_2__GPIO_1_2 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 2) #define USDHC3_CD_GPIO IMX_GPIO_NR(3, 9)
static iomux_v3_cfg_t const usdhc3_pads[] = { @@ -100,8 +112,9 @@ static void setup_iomux_enet(void) gpio_set_value(ETH_PHY_RESET, 1); }
-static struct fsl_esdhc_cfg usdhc_cfg[1] = { +static struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC3_BASE_ADDR}, + {USDHC1_BASE_ADDR}, };
int board_mmc_getcd(struct mmc *mmc) @@ -110,6 +123,9 @@ int board_mmc_getcd(struct mmc *mmc) int ret = 0;
switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; case USDHC3_BASE_ADDR: ret = !gpio_get_value(USDHC3_CD_GPIO); break; @@ -120,13 +136,41 @@ int board_mmc_getcd(struct mmc *mmc)
int board_mmc_init(bd_t *bis) { - imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); - - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - usdhc_cfg[0].max_bus_width = 4; - gpio_direction_input(USDHC3_CD_GPIO); + int i; + + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 SOM MicroSD + * mmc1 Carrier board MicroSD + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg[0].max_bus_width = 4; + gpio_direction_input(USDHC3_CD_GPIO); + break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + usdhc_cfg[1].max_bus_width = 4; + gpio_direction_input(USDHC1_CD_GPIO); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return 0; + } + + if (fsl_esdhc_initialize(bis, &usdhc_cfg[i])) + printf("Warning: failed to initialize mmc dev %d\n", i); + }
- return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); + return 0; }
static int mx6_rgmii_rework(struct phy_device *phydev) diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 120e3f6..161b400 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -57,6 +57,7 @@ /* MMC Configuration */ #define CONFIG_FSL_ESDHC #define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0
#define CONFIG_MMC
On Mon, Apr 15, 2013 at 10:35 AM, Otavio Salvador otavio@ossystems.com.br wrote:
int i;
* mmc0 SOM MicroSD
switch (i) {
case 0:
break;
case 1:
break;
default:
This should be an error. What about return -EINVAL ?
With this change, you never return an error.
int i;
* mmc0 SOM MicroSD
switch (i) {
case 0:
break;
case 1:
break;
default:
Agreed, fixed locally.
Should we fail if *any* fail?
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
On Mon, Apr 15, 2013 at 11:06 AM, Otavio Salvador otavio@ossystems.com.br wrote:
Yes, I think so.
Yes, I think so.
--- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -162,13 +162,15 @@ int board_mmc_init(bd_t *bis) gpio_direction_input(USDHC1_CD_GPIO); break; default: - printf("Warning: you configured more USDHC controllers" + printf("ERROR: you configured more USDHC controllers" "(%d) than supported by the board\n", i + 1); return -EINVAL; }
- if (fsl_esdhc_initialize(bis, &usdhc_cfg[i])) - printf("Warning: failed to initialize mmc dev %d\n", i); + if (fsl_esdhc_initialize(bis, &usdhc_cfg[i])) { + printf("ERROR: failed to initialize mmc dev %d\n", i); + return 1; + } }
Like this?
On Mon, Apr 15, 2013 at 1:18 PM, Otavio Salvador otavio@ossystems.com.br wrote:
return 1;
1 is not an appropriate return value for an error.
What about doing like sabrelite? status |= fsl_esdhc_initialize(bis, &usdhc_cfg[i]);
and then you return status?
return 1;
int board_mmc_init(bd_t *bis) { - imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + int i; + int ret;
- usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - usdhc_cfg[0].max_bus_width = 4; - gpio_direction_input(USDHC3_CD_GPIO); + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 SOM MicroSD + * mmc1 Carrier board MicroSD + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg[0].max_bus_width = 4; + gpio_direction_input(USDHC3_CD_GPIO); + break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + usdhc_cfg[1].max_bus_width = 4; + gpio_direction_input(USDHC1_CD_GPIO); + break; + default: + printf("ERROR: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret |= fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + } + + if (ret) + printf("ERROR: failed to initialize mmc dev %d\n", i);
- return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); + return ret; }
This would be the final patch than...
Dear Otavio Salvador,
In message CAP9ODKqO8V1-WYZQ4_GXRZ5DJbD2xiXw59xKOzGY0ZjsUJJjXQ@mail.gmail.com you wrote:
default:
return -EINVAL;
Can you please make this a compile time test and error?
Thanks.
default:
return -EINVAL;
I will check how to do that.
On Wed, Apr 17, 2013 at 7:21 PM, Otavio Salvador otavio@ossystems.com.br wrote:
default:
return -EINVAL;
I checked and it will be a much bigger change as it should be done in all boards using this so I will look at it but won't hold the patches for now.
I will send a new revision without this change and work on this.
In message CAP9ODKqFSMHot7tCTuxV+c14385GGd4v0onsocd4wDGcghDzKw@mail.gmail.com you wrote:
To make it more clear: this should be a compile-time error, not detected at runtime.
Yes, this is the good old rule of defensive programming: as soon as you detect any kind of (critical) error, you print an error message and bail out.
Adds support for 'bmode' command which let user to choose where to boot from; this allows U-Boot to load system from another storage without messing with jumpers.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- board/wandboard/wandboard.c | 19 +++++++++++++++++++ include/configs/wandboard.h | 3 +++ 2 files changed, 22 insertions(+)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 5d98244..e7cf4a1 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -16,6 +16,7 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/boot_mode.h> #include <asm/io.h> #include <asm/sizes.h> #include <common.h> @@ -225,6 +226,24 @@ int board_early_init_f(void) return 0; }
+#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"mmc0", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)}, + {"mmc1", MAKE_CFGVAL(0x40, 0x20, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +int board_late_init(void) +{ +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + + return 0; +} + int board_init(void) { /* address of boot parameters */ diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 161b400..4cb9f8d 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -32,6 +32,7 @@ #define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M)
#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT #define CONFIG_MXC_GPIO
#define CONFIG_MXC_UART @@ -47,6 +48,8 @@
#undef CONFIG_CMD_IMLS
+#define CONFIG_CMD_BMODE + #define CONFIG_BOOTDELAY 5
#define CONFIG_SYS_MEMTEST_START 0x10000000
Fabio Estevam
Otavio Salvador
