[RFC] Start using guestfish for U-Boot fs tests
Hey all,
I started taking a look at moving to guestfish to see if this resolves the latest problem I've run in to: https://source.denx.de/u-boot/u-boot/-/jobs/284763#L307 which I think is due to guestmount not being done in time for the test. So I started converting things to use guestfish directly:
diff --git a/test/py/tests/test_fs/conftest.py b/test/py/tests/test_fs/conftest.py index 7325486cdb1a..e8899cfdd118 100644 --- a/test/py/tests/test_fs/conftest.py +++ b/test/py/tests/test_fs/conftest.py @@ -265,10 +265,10 @@ def fs_obj_basic(request, u_boot_config): fs_ubtype = fstype_to_ubname(fs_type) check_ubconfig(u_boot_config, fs_ubtype)
- mount_dir = u_boot_config.persistent_data_dir + '/mnt' + data_dir = u_boot_config.persistent_data_dir + '/data'
- small_file = mount_dir + '/' + SMALL_FILE - big_file = mount_dir + '/' + BIG_FILE + small_file = data_dir + '/' + SMALL_FILE + big_file = data_dir + '/' + BIG_FILE
try:
@@ -279,26 +279,14 @@ def fs_obj_basic(request, u_boot_config): return
try: - check_call('mkdir -p %s' % mount_dir, shell=True) + check_call('mkdir -p %s' % data_dir, shell=True) except CalledProcessError as err: pytest.skip('Preparing mount folder failed for filesystem: ' + fs_type + '. {}'.format(err)) call('rm -f %s' % fs_img, shell=True) return
try: - # Mount the image so we can populate it. - mount_fs(fs_type, fs_img, mount_dir) - except CalledProcessError as err: - pytest.skip('Mounting to folder failed for filesystem: ' + fs_type + '. {}'.format(err)) - call('rmdir %s' % mount_dir, shell=True) - call('rm -f %s' % fs_img, shell=True) - return - - try: - # Create a subdirectory. - check_call('mkdir %s/SUBDIR' % mount_dir, shell=True) - - # Create big file in this image. + # Create big file to copy in to the image. # Note that we work only on the start 1MB, couple MBs in the 2GB range # and the last 1 MB of the huge 2.5GB file. # So, just put random values only in those areas. @@ -309,10 +297,14 @@ def fs_obj_basic(request, u_boot_config): check_call('dd if=/dev/urandom of=%s bs=1M count=1 seek=2499' % big_file, shell=True)
- # Create a small file in this image. + # Create a small file to copy in to the image. check_call('dd if=/dev/urandom of=%s bs=1M count=1' % small_file, shell=True)
+ # Copy the files in to the image and add a subdirectory. + # Create a subdirectory. + check_call('guestfish add %s : run : mount /dev/sda / : mkdir /SUBDIR : copy-in %s %s /' + % (fs_img, big_file, small_file), shell=True) # Delete the small file copies which possibly are written as part of a # previous test. # check_call('rm -f "%s.w"' % MB1, shell=True) @@ -357,13 +349,11 @@ def fs_obj_basic(request, u_boot_config):
except CalledProcessError as err: pytest.skip('Setup failed for filesystem: ' + fs_type + '. {}'.format(err)) - umount_fs(mount_dir) return else: - umount_fs(mount_dir) yield [fs_ubtype, fs_img, md5val] finally: - call('rmdir %s' % mount_dir, shell=True) + call('rmdir %s' % data_dir, shell=True) call('rm -f %s' % fs_img, shell=True)
The problem here is that a test run went from taking about 5 minutes to taking about 17 minutes. I can reduce this to closer to 15 minutes with LIBGUESTFS_BACKEND=direct and using libguestfs-make-fixed-appliance to make an appliance we reuse. But that's still too long to be usable. I'm hoping someone has some ideas here on how to improve things.
Hi Tom,
On Fri, 2 Jul 2021 at 13:01, Tom Rini trini@konsulko.com wrote:
Hey all,
- data_dir = u_boot_config.persistent_data_dir + '/data'
try:
try:
try:
return
- try:
else:umount_fs(mount_dir) return
finally:umount_fs(mount_dir) yield [fs_ubtype, fs_img, md5val]
Well even 5 minutes is too long. Could we make the filesystems and files very small? It does not seem useful to make 2GB things.
Also we could try harder to get the tests running in parallel. It is not that far away.
On Fri, Jul 02, 2021 at 01:06:23PM -0600, Simon Glass wrote:
Hi Tom,
Hey all,
try:
try:
try:
return
- try:
Adding "not fs" brings me down to 2 minutes. Doing "not fs and not efi" (because I can see the efi secboot stuff taking visible time) brings me to 1 minute. Adding in "and not vboot" is 36 seconds.
That said, there's only a subset of the tests that we could turn in to "use these static images" as we've also got tests to generate new signed content and verify the signatures, and that's got to test both the sign and verify paths.
This, along with easier / clearer documentation on how to run tests directly so that you can pass "not fs and not ..." might help too. I yanked this out of .gitlab-ci.yml today to make iterating on this under docker easier, and have a slightly more robust one in my bin dir:
export TEST_PY_BD=sandbox;export UBOOT_TRAVIS_BUILD_DIR=/tmp/${TEST_PY_BD} tools/buildman/buildman -o ${UBOOT_TRAVIS_BUILD_DIR} -w -E -W -e --board ${TEST_PY_BD} virtualenv -p /usr/bin/python3 /tmp/venv . /tmp/venv/bin/activate pip install -r test/py/requirements.txt export PATH=/opt/qemu/bin:/tmp/uboot-test-hooks/bin:${PATH} export PYTHONPATH=/tmp/uboot-test-hooks/py/travis-ci time ./test/py/test.py -ra --bd ${TEST_PY_BD} --build-dir "$UBOOT_TRAVIS_BUILD_DIR"
On 7/2/21 3:01 PM, Tom Rini wrote:
Hey all,
try:
try:
check_call('mkdir -p %s' % data_dir, shell=True) except CalledProcessError as err: pytest.skip('Preparing mount folder failed for filesystem: ' + fs_type + '. {}'.format(err)) call('rm -f %s' % fs_img, shell=True) return try:
return
- try:
Have we tried using fuse? I've had good results with fuse2fs (although it does not support the journal), and there is a fusefat package as well. Example usage:
mkdir -p root truncate -s 1G root.img mkfs.ext4 -q $@ fuse2fs -o fakeroot root.img root fakeroot tar -C root -xf rootfs.tar fusermount -u root
If you don't need correct permissions, you can skip the fakeroot stuff.
If you want to go one step further, you can also try lklfuse [1], though I have not used it.
[1] https://github.com/lkl/linux
--Sean
Hey all,
try:
try:
return
- try:
I think fuse directly (guestfs stuff uses fuse under the hood) is probably out as we wouldn't be able to convert squashfs for example.
Hey all,
try:
try:
return
- try:
Why not squashfuse?
--Sean
On 02/07/2021 22:01, Tom Rini wrote:
Hey all,
That failing test's setup uses virt-make-fs, different from what you're changing below. I locally only see that failure for the clang build, and it still fails after adding time.sleep(300) after its virt-make-fs calls. I don't think it's an issue in the test setup.
So I started converting things to use guestfish directly: diff --git a/test/py/tests/test_fs/conftest.py b/test/py/tests/test_fs/conftest.py index 7325486cdb1a..e8899cfdd118 100644 --- a/test/py/tests/test_fs/conftest.py +++ b/test/py/tests/test_fs/conftest.py @@ -265,10 +265,10 @@ def fs_obj_basic(request, u_boot_config): fs_ubtype = fstype_to_ubname(fs_type) check_ubconfig(u_boot_config, fs_ubtype)
try:
try:
try:
return
- try:
It could be faster to do things within guestfish as much as possible, instead of preparing the files outside and copying them in.
Also it looks like python bindings are available as python3-guestfs on Debian and Ubuntu, just not on pypi.org.
If libguestfs is falling back to slow emulation because /dev/kvm isn't available, maybe it's appropriate to check for that and skip the fs tests...
Hey all,
try:
try:
try:
return
- try:
Also the User-Mode Linux backend might be worth exploring.
Hey all,
try:
try:
try:
return
- try:
Trying to use user-mode-linux under Docker and I'm running in to another round of failures and annoyances. This might be easier with a Debian rather than Ubuntu based container, so I'm not giving up yet, but it's not a trivial switch anyhow.
Hey all,
Ah good, I need to go catch up on that thread again, thanks for looking.
try:
try:
try:
return
- try:
This is, I believe, as much as possible. You can't run arbitrary commands via guestfish, or at least I didn't see how. "dd" isn't really dd, for example.
I saw there's some reason why you can't pip install them, and wasn't sure it would be any faster, based on doing these commands outside of pytest first.
This is, I think, part of the problem. We're jumping through a huge number of hoops to avoid "sudo mount ..." in the tests directly. I thought I was getting kvm used locally, but nope, it's not. I'm going to take another break and see if I can figure out what I'm doing wrong since: sudo docker run --privileged --cap-add SYS_ADMIN --security-opt apparmor=unconfined --rm -v /dev/fuse:/dev/fuse -v /dev/kvm:/dev/kvm isn't doing it.
Hey all,
try:
try:
try:
return
- try:
Well, whether 'sudo mount' works also depends on CI config.
It should be --device instead of -v (--volume) for /dev/{fuse,kvm}; but just --privileged should be enough (no --cap-add, --securtiy-opt, or --devices necessary) for Docker itself. Something like:
sudo docker run --privileged -v $(pwd):/home/uboot/u-boot --rm \ trini/u-boot-gitlab-ci-runner:focal-20210609-01Jul2021 \ bash /home/uboot/u-boot/test.sh
where test.sh should be the things in .gitlab-ci.yml or .azure-pipelines.yml.
I got gitlab-runner working instead and use e.g.:
gitlab-runner exec docker --docker-privileged "sandbox test.py"
Hey all,
try:
try:
try:
return
- try:
Yes. But it's also how the tests can be run outside of CI, and some level of CI nodes are things we do control. I do want to get this working in the most friendly and non-privileged way possible, I just lament a little that this was all working for the case of "just use sudo", at one point, and was also relatively fast.
Ah right. I'll give that another whirl and see if things look reasonably quick again.
Right, and one of the things that's done for the gitlab runners we control (rather than the free community ones) is to run like that.
Hey all,
try:
try:
try:
return
- try:
JFYI, I managed to, fairly easily, swap the "focal" Dockerfile over instead to Debian Bullseye or Buster "slim" based containers, but in both cases, just doing some simple guestfish commands like: dd if=/dev/zero of=/tmp/test.img bs=1M count=4096 mkfs.vfat /tmp/test.img export LIBGUESTFS_DEBUG=1 LIBGUESTFS_TRACE=1 export LIBGUESTFS_BACKEND=uml export LIBGUESTFS_HV=/usr/bin/linux guestfish add /tmp/test.img : run : mount /dev/sda / : mkdir /SUBDIR
results in UML blowing up in generic looking failures on each. I'm setting UML aside for now.
Hey all,
try:
try:
try:
return
- try:
I guess something like:
dd if=/dev/urandom of="rand1.bin" bs=1M count=1 dd if=/dev/urandom of="rand2.bin" bs=1M count=2 dd if=/dev/urandom of="rand3.bin" bs=1M count=1 dd if=/dev/urandom of="rand4.bin" bs=1M count=1
fallocate -l 3GiB disk.img mkfs.vfat disk.img
guestfish <<EOF add disk.img run mount /dev/sda /
upload rand1.bin /1M.file
fallocate64 /2.5GB.file 0xA0000000 upload-offset rand2.bin /2.5GB.file 0 upload-offset rand3.bin /2.5GB.file 0x7FF00000 upload-offset rand4.bin /2.5GB.file 0x9C300000
download-offset /2.5GB.file read.bin 0x7FF80000 1M EOF
but haven't tried it in the test setup yet. It works faster for me than using copy-in with LIBGUESTFS_BACKEND_SETTINGS=force_tcg (about 1m 30s vs 4m 30s) but slower than guestmount (about 30s). Using force_kvm instead prevents falling back to slower emulation.
I couldn't get the UML backend to work either, e.g. anything trying to write to a guestmount-ed directory becomes unresponsive.
Alper Nebi Yasak
Sean Anderson
