[PATCH] Fix fastboot handling of partitions when no slots are, supported
The fastboot module has a bug that prevents some command to work properly on devices that haven't an Android-like partition scheme, that is, just one spl and one kernel partition, instead of the redundant scheme with _a and _b slots.
This is the schema of our NAND storage (board is based on an AllWinner A33 sunxi chip):
=> mtdparts
device nand0 <1c03000.nand>, # parts = 4 #: name size net size offset mask_flags 0: spl 0x00020000 0x00020000 0x00000000 0 1: uboot 0x00100000 0x00100000 0x00020000 0 2: kernel 0x00400000 0x00400000 0x00120000 0 3: ubi 0x07ae0000 0x079e0000 (!) 0x00520000 0
active partition: nand0,0 - (spl) 0x00020000 @ 0x00000000
This happens when we try to erase the spl partition using fastboot:
$ fastboot erase spl Erasing 'spl_a' FAILED (remote: 'invalid NAND device') fastboot: error: Command failed
The error occurs because getvars fails to handle the error returned by nand layer when a partition cannot be found.
Indeed, getvar_get_part_info returns what is returned by fastboot_nand_get_part_info (0 on success, 1 on failure) but it should return -ENODEV or -EINVAL instead. Since the cause of failure is not returned by the nand function, I decided to return -EINVAL to make it simple.
Signed-off-by: Federico Fuga fuga@studiofuga.com --- drivers/fastboot/fb_getvar.c | 5 ++++- drivers/fastboot/fb_nand.c | 2 +- 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/fastboot/fb_getvar.c b/drivers/fastboot/fb_getvar.c index 93cbd598e0..f5d8b03301 100644 --- a/drivers/fastboot/fb_getvar.c +++ b/drivers/fastboot/fb_getvar.c @@ -121,8 +121,11 @@ static int getvar_get_part_info(const char *part_name, char *response, *size = disk_part.size * disk_part.blksz; } else if (IS_ENABLED(CONFIG_FASTBOOT_FLASH_NAND)) { r = fastboot_nand_get_part_info(part_name, &part_info, response); - if (r >= 0 && size) + if (r == 0 && size) { *size = part_info->size; + } else { + r = -EINVAL; + } } else { fastboot_fail("this storage is not supported in bootloader", response); r = -ENODEV; diff --git a/drivers/fastboot/fb_nand.c b/drivers/fastboot/fb_nand.c index 5a55144479..3ee0f40ea8 100644 --- a/drivers/fastboot/fb_nand.c +++ b/drivers/fastboot/fb_nand.c @@ -141,7 +141,7 @@ static lbaint_t fb_nand_sparse_reserve(struct sparse_storage *info, * * @part_name: Named device to lookup * @part_info: Pointer to returned part_info pointer - * @response: Pointer to fastboot response buffer + * @response: 0 on success, 1 otherwise */ int fastboot_nand_get_part_info(const char *part_name, struct part_info **part_info, char *response)
=> mtdparts
Hi Federico,
Thank you for the patch.
=> mtdparts
Unfortunately, I'm unable to apply this. I've tried using b4 and via git am.
$ b4 shazam -s -l --check a70b19e6-4436-4fcf-bebd-b6877b66779e@studiofuga.com
Grabbing thread from lore.kernel.org/all/a70b19e6-4436-4fcf-bebd-b6877b66779e@studiofuga.com/t.mbox.gz Checking for newer revisions Grabbing search results from lore.kernel.org Analyzing 2 messages in the thread Assuming new revision: v2 ([PATCH] Fix fastboot handling of partitions when no slots are, supported) Analyzing 0 code-review messages Will use the latest revision: v2 You can pick other revisions using the -vN flag Checking attestation on all messages, may take a moment... --- [PATCH] Fix fastboot handling of partitions when no slots are, supported + Link: https://lore.kernel.org/r/add4f6ac-3dd5-4707-a40c-a41191e62912@studiofuga.co... + Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com Traceback (most recent call last): File "/mnt/work/upstream/b4/src/b4/command.py", line 435, in <module> cmd() ~~~^^ File "/mnt/work/upstream/b4/src/b4/command.py", line 417, in cmd cmdargs.func(cmdargs)
Downloading the thread from this patchwork link (clicking on "mbox"): https://patchwork.ozlabs.org/project/uboot/patch/a70b19e6-4436-4fcf-bebd-b68...
$ git am Fix-fastboot-handling-of-partitions-when-no-slots-are-supported.patch Applying: Fix fastboot handling of partitions when no slots are, supported error: corrupt patch at line 13 error: could not build fake ancestor Patch failed at 0001 Fix fastboot handling of partitions when no slots are, supported hint: Use 'git am --show-current-patch=diff' to see the failed patch hint: When you have resolved this problem, run "git am --continue". hint: If you prefer to skip this patch, run "git am --skip" instead. hint: To restore the original branch and stop patching, run "git am --abort". hint: Disable this message with "git config advice.mergeConflict false"
Can you please confirm that you are able to apply it yourself? Maybe the email client is misconfigured somehow?
I've also tried to apply the one that has been send yesterday (https://patchwork.ozlabs.org/project/uboot/patch/add4f6ac-3dd5-4707-a40c-a41...) but I'm encountering the same problem.
- @response: Pointer to fastboot response buffer
- @response: 0 on success, 1 otherwise
*/ int fastboot_nand_get_part_info(const char *part_name, struct part_info **part_info, char *response) -- 2.48.1
Hi Mattijs, sorry, my bad: I exported from the wrong branch, as I was working on the latest release, not from main.
Resending it. Sorry for the mistake.
Federico
On 28/01/25 09:44, Mattijs Korpershoek wrote:
Hi Federico,
=> mtdparts
-- 2.48.1
Federico Fuga
Mattijs Korpershoek
