[PATCH v2 0/2] splash: add more options/support
This patch series add several options/support for splashscreen feature: - support raw image from MMC - get devpart from environment variable
With these changes the user has now more options and can change default configurations through environment variables.
Example: image located in splashscreen partition (MMC as raw) ``` splashsource=mmc_raw splashdevpart=0#splashscreen ```
Changes in v2: - splash_mmc_read_raw: return -EIO in case of errors - splash_mmc_read_raw: use IS_ENABLED(CONFIG_CMD_MMC) instead of #ifdef - rename local var env_splashdevpart_value to devpart
Julien Masson (2): splash: support raw image from MMC splash: get devpart from environment variable
common/splash.c | 6 ++++++ common/splash_source.c | 31 +++++++++++++++++++++++++++++++ 2 files changed, 37 insertions(+)
The user has now the choice to specify the splash location in the MMC as a raw storage.
Signed-off-by: Julien Masson jmasson@baylibre.com ---
common/splash.c | 6 ++++++ common/splash_source.c | 26 ++++++++++++++++++++++++++ 2 files changed, 32 insertions(+)
diff --git a/common/splash.c b/common/splash.c index 0e520cc103..5206e35f74 100644 --- a/common/splash.c +++ b/common/splash.c @@ -39,6 +39,12 @@ static struct splash_location default_splash_locations[] = { .flags = SPLASH_STORAGE_FS, .devpart = "0:1", }, + { + .name = "mmc_raw", + .storage = SPLASH_STORAGE_MMC, + .flags = SPLASH_STORAGE_RAW, + .devpart = "0:1", + }, { .name = "usb_fs", .storage = SPLASH_STORAGE_USB, diff --git a/common/splash_source.c b/common/splash_source.c index 87e55a54f8..68c9fa371b 100644 --- a/common/splash_source.c +++ b/common/splash_source.c @@ -65,6 +65,30 @@ static int splash_nand_read_raw(u32 bmp_load_addr, int offset, size_t read_size) } #endif
+static int splash_mmc_read_raw(u32 bmp_load_addr, struct splash_location *location, + size_t read_size) +{ + struct disk_partition partition; + struct blk_desc *desc; + lbaint_t blkcnt; + int ret, n; + + if (!IS_ENABLED(CONFIG_CMD_MMC)) { + debug("%s: mmc support not available\n", __func__); + return -ENOSYS; + } + + ret = part_get_info_by_dev_and_name_or_num("mmc", location->devpart, &desc, + &partition, 1); + if (ret < 0) + return ret; + + blkcnt = DIV_ROUND_UP(read_size, partition.blksz); + n = blk_dread(desc, partition.start, blkcnt, (void *)(uintptr_t)bmp_load_addr); + + return (n == blkcnt) ? 0 : -EIO; +} + static int splash_storage_read_raw(struct splash_location *location, u32 bmp_load_addr, size_t read_size) { @@ -75,6 +99,8 @@ static int splash_storage_read_raw(struct splash_location *location,
offset = location->offset; switch (location->storage) { + case SPLASH_STORAGE_MMC: + return splash_mmc_read_raw(bmp_load_addr, location, read_size); case SPLASH_STORAGE_NAND: return splash_nand_read_raw(bmp_load_addr, offset, read_size); case SPLASH_STORAGE_SF:
Changes in v2:
By default several types of splash locations are supported and the user can select one of them through environment var (splashsource).
However the devpart is still hardcoded and we cannot change it from the environment.
This patch add the support of "splashdevpart" which allow the user to set the devpart though this environment variable.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Julien Masson jmasson@baylibre.com ---
Changes in v2: - rename local var env_splashdevpart_value to devpart
common/splash_source.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/common/splash_source.c b/common/splash_source.c index 68c9fa371b..a260137619 100644 --- a/common/splash_source.c +++ b/common/splash_source.c @@ -448,6 +448,7 @@ int splash_source_load(struct splash_location *locations, uint size) { struct splash_location *splash_location; char *env_splashimage_value; + char *devpart; u32 bmp_load_addr;
env_splashimage_value = env_get("splashimage"); @@ -464,6 +465,10 @@ int splash_source_load(struct splash_location *locations, uint size) if (!splash_location) return -EINVAL;
+ devpart = env_get("splashdevpart"); + if (devpart) + splash_location->devpart = devpart; + if (splash_location->flags == SPLASH_STORAGE_RAW) return splash_load_raw(splash_location, bmp_load_addr); else if (splash_location->flags == SPLASH_STORAGE_FS)
Changes in v2:
On Mon, 17 Oct 2022 10:33:18 +0200 Julien Masson jmasson@baylibre.com wrote: ...
Changes in v2:
Applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Julien Masson
