[U-Boot] Reading data from SPI flash before relocation - what is the best way to do this?
Hello,
I want to chose the best aproach to achive something like this: There is a u-boot without SPL and it is copied by bootrom to SDRAM. In first phase (while running *_f functions) I need to read some configuration data from SPI NOR, and it must be done before DDR config. I have SPI NOR with enabled MTD support on SPI. Problem is that MTD uses bss wich is not avalaible yet. My solutions: * Change linker script to divide bss and rel.dyn sections and clean bss by myself. Disadventage is that it will enlarge my binary, but it migh be acceptable. * Write code that do not use SPI/MTD frameworks to read configuration data (data will be on raw so MTD is not needed). For sure - at least at the moment - I wan't to avoid using SPL and config compiled into binary. Maybe there is another way that I can achive that?
Regards, Marcin
On 22 October 2015 at 17:05, Krzeminski, Marcin (Nokia - PL/Wroclaw) marcin.krzeminski@nokia.com wrote:
Hello,
Why can't you use SPL? any specific reason?
Just to be clear are going write the data from spi-nor to SRAM because *_f doesn't have DDR access.
-----Original Message----- From: EXT Jagan Teki [mailto:jteki@openedev.com] Sent: Thursday, October 22, 2015 2:55 PM To: Krzeminski, Marcin (Nokia - PL/Wroclaw) marcin.krzeminski@nokia.com Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] Reading data from SPI flash before relocation - what is the best way to do this?
Hello,
Since we are already in small SDRAM, so assumption was tha SPL is not needed - which was apparently wrong. Strong argument is that dividing u-boot to u-boot and SPL will consume more flash space, complicate flash layout and already complicated boot process.
Yes.
My solutions:
-- Jagan | openedev.
Regards, Marcin
Dear Marcin,
In message CA0E6F9BA6AED7458C23277BD87075E50F731841@DEMUMBX014.nsn-intra.net you wrote:
OK, the question why you don't use SPL has already been asked.
Why do you need to read it separately? Can you not "attach" it to the U-Boot image, so the boot ROM will read that combined image (U-Boot plus your config data) ?
-----Original Message----- From: EXT Wolfgang Denk [mailto:wd@denx.de] Sent: Thursday, October 22, 2015 7:16 PM To: Krzeminski, Marcin (Nokia - PL/Wroclaw) marcin.krzeminski@nokia.com Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] Reading data from SPI flash before relocation - what is the best way to do this?
Dear Marcin,
In message <CA0E6F9BA6AED7458C23277BD87075E50F731841@DEMUMBX014.nsn- intra.net> you wrote:
Because many configuration are expected, so avoiding many u-boot binaries is the target.
Generally it seems that I want to do something that is against u-boot design, so my question should be, how to do it harmless?
I changed linker script, cleared bss and it seem that this is working fine, so probably I'll try this way.
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Until you walk a mile in another man's moccasins, you can't imagine the smell.
Best regards, Marcin KrzemiĆski
Jagan Teki
