[U-Boot] [PATCH v13 0/4] efi_loader: Code refactoring and improvement
This collects the patches previously sent to break up the very large functions in efi_loader into smaller pieces. Now that the other sandbox stuff is applied, perhaps it is time to apply these patches.
This also adds a few new patches to fix more recent breakages. Unfortunately we still cannot enable the efi loader tests since one of the tests fails. Thus we should expect additional failures to appear until that is resolved.
Changes in v13: - Drop 'efi_loader: Drop setup_ok' as we have an existing patch for that - Drop patches previously applied - Update code to deal with the struct_table_address member
Changes in v12: - Rename image to image_prot
Changes in v11: - Drop patches previously applied - Fix the EFI code that has since been added and relies on broken behaviour
Changes in v9: - Add comments to bootefi_test_prepare() about the memset()s
Changes in v7: - Drop patch "efi: Init the 'rows' and 'cols' variables" - Drop patches previous applied
Changes in v5: - Drop call to efi_init_obj_list() which is now done in do_bootefi() - Introduce load_options_path to specifyc U-Boot env var for load_options_path - Rebase to master
Changes in v4: - Rebase to master
Changes in v3: - Add new patch to rename bootefi_test_finish() to bootefi_run_finish() - Add new patch to split out test init/uninit into functions - Add patch to create a function to set up for running EFI code - Drop incorrect map_sysmem() in write_smbios_table()
Simon Glass (4): sandbox: smbios: Update to support sandbox efi: Split out test init/uninit into functions efi: Create a function to set up for running EFI code efi: Rename bootefi_test_finish() to bootefi_run_finish()
cmd/bootefi.c | 136 +++++++++++++++++++++++++----------- lib/efi_loader/efi_smbios.c | 20 ++++-- lib/smbios.c | 52 +++++++++++--- 3 files changed, 152 insertions(+), 56 deletions(-)
At present this code casts addresses to pointers so cannot be used with sandbox. Update it to use mapmem instead.
Changes in v13: - Update code to deal with the struct_table_address member
Changes in v12: None Changes in v11: - Fix the EFI code that has since been added and relies on broken behaviour
Changes in v9: None Changes in v7: None Changes in v5: None Changes in v4: None Changes in v3: - Drop incorrect map_sysmem() in write_smbios_table()
lib/efi_loader/efi_smbios.c | 20 +++++++++----- lib/smbios.c | 52 ++++++++++++++++++++++++++++++------- 2 files changed, 56 insertions(+), 16 deletions(-)
diff --git a/lib/efi_loader/efi_smbios.c b/lib/efi_loader/efi_smbios.c index 38e42fa2432..a81488495e2 100644 --- a/lib/efi_loader/efi_smbios.c +++ b/lib/efi_loader/efi_smbios.c @@ -7,6 +7,7 @@
#include <common.h> #include <efi_loader.h> +#include <mapmem.h> #include <smbios.h>
static const efi_guid_t smbios_guid = SMBIOS_TABLE_GUID; @@ -19,17 +20,19 @@ static const efi_guid_t smbios_guid = SMBIOS_TABLE_GUID; efi_status_t efi_smbios_register(void) { /* Map within the low 32 bits, to allow for 32bit SMBIOS tables */ - u64 dmi = U32_MAX; + u64 dmi_addr = U32_MAX; efi_status_t ret; + void *dmi;
/* Reserve 4kiB page for SMBIOS */ ret = efi_allocate_pages(EFI_ALLOCATE_MAX_ADDRESS, - EFI_RUNTIME_SERVICES_DATA, 1, &dmi); + EFI_RUNTIME_SERVICES_DATA, 1, &dmi_addr);
if (ret != EFI_SUCCESS) { /* Could not find space in lowmem, use highmem instead */ ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, - EFI_RUNTIME_SERVICES_DATA, 1, &dmi); + EFI_RUNTIME_SERVICES_DATA, 1, + &dmi_addr);
if (ret != EFI_SUCCESS) return ret; @@ -39,11 +42,14 @@ efi_status_t efi_smbios_register(void) * Generate SMBIOS tables - we know that efi_allocate_pages() returns * a 4k-aligned address, so it is safe to assume that * write_smbios_table() will write the table at that address. + * + * Note that on sandbox, efi_allocate_pages() unfortunately returns a + * pointer even though it uses a uint64_t type. Convert it. */ - assert(!(dmi & 0xf)); - write_smbios_table(dmi); + assert(!(dmi_addr & 0xf)); + dmi = (void *)(uintptr_t)dmi_addr; + write_smbios_table(map_to_sysmem(dmi));
/* And expose them to our EFI payload */ - return efi_install_configuration_table(&smbios_guid, - (void *)(uintptr_t)dmi); + return efi_install_configuration_table(&smbios_guid, dmi); } diff --git a/lib/smbios.c b/lib/smbios.c index 326eb00230d..2cd08b5e16f 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <mapmem.h> #include <smbios.h> #include <tables_csum.h> #include <version.h> @@ -72,9 +73,10 @@ static int smbios_string_table_len(char *start)
static int smbios_write_type0(ulong *current, int handle) { - struct smbios_type0 *t = (struct smbios_type0 *)*current; + struct smbios_type0 *t; int len = sizeof(struct smbios_type0);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type0)); fill_smbios_header(t, SMBIOS_BIOS_INFORMATION, len, handle); t->vendor = smbios_add_string(t->eos, "U-Boot"); @@ -101,16 +103,18 @@ static int smbios_write_type0(ulong *current, int handle)
len = t->length + smbios_string_table_len(t->eos); *current += len; + unmap_sysmem(t);
return len; }
static int smbios_write_type1(ulong *current, int handle) { - struct smbios_type1 *t = (struct smbios_type1 *)*current; + struct smbios_type1 *t; int len = sizeof(struct smbios_type1); char *serial_str = env_get("serial#");
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type1)); fill_smbios_header(t, SMBIOS_SYSTEM_INFORMATION, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -122,15 +126,17 @@ static int smbios_write_type1(ulong *current, int handle)
return len; }
static int smbios_write_type2(ulong *current, int handle) { - struct smbios_type2 *t = (struct smbios_type2 *)*current; + struct smbios_type2 *t; int len = sizeof(struct smbios_type2);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type2)); fill_smbios_header(t, SMBIOS_BOARD_INFORMATION, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -140,15 +146,17 @@ static int smbios_write_type2(ulong *current, int handle)
return len; }
static int smbios_write_type3(ulong *current, int handle) { - struct smbios_type3 *t = (struct smbios_type3 *)*current; + struct smbios_type3 *t; int len = sizeof(struct smbios_type3);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type3)); fill_smbios_header(t, SMBIOS_SYSTEM_ENCLOSURE, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -160,6 +168,7 @@ static int smbios_write_type3(ulong *current, int handle)
return len; } @@ -198,9 +207,10 @@ static void smbios_write_type4_dm(struct smbios_type4 *t)
static int smbios_write_type4(ulong *current, int handle) { - struct smbios_type4 *t = (struct smbios_type4 *)*current; + struct smbios_type4 *t; int len = sizeof(struct smbios_type4);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type4)); fill_smbios_header(t, SMBIOS_PROCESSOR_INFORMATION, len, handle); t->processor_type = SMBIOS_PROCESSOR_TYPE_CENTRAL; @@ -214,32 +224,37 @@ static int smbios_write_type4(ulong *current, int handle)
return len; }
static int smbios_write_type32(ulong *current, int handle) { - struct smbios_type32 *t = (struct smbios_type32 *)*current; + struct smbios_type32 *t; int len = sizeof(struct smbios_type32);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type32)); fill_smbios_header(t, SMBIOS_SYSTEM_BOOT_INFORMATION, len, handle);
return len; }
static int smbios_write_type127(ulong *current, int handle) { - struct smbios_type127 *t = (struct smbios_type127 *)*current; + struct smbios_type127 *t; int len = sizeof(struct smbios_type127);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type127)); fill_smbios_header(t, SMBIOS_END_OF_TABLE, len, handle);
return len; } @@ -257,6 +272,7 @@ static smbios_write_type smbios_write_funcs[] = { ulong write_smbios_table(ulong addr) { struct smbios_entry *se; + ulong table_addr; ulong tables; int len = 0; int max_struct_size = 0; @@ -268,7 +284,7 @@ ulong write_smbios_table(ulong addr) /* 16 byte align the table address */ addr = ALIGN(addr, 16);
- se = (struct smbios_entry *)(uintptr_t)addr; + se = map_sysmem(addr, sizeof(struct smbios_entry)); memset(se, 0, sizeof(struct smbios_entry));
addr += sizeof(struct smbios_entry); @@ -290,7 +306,24 @@ ulong write_smbios_table(ulong addr) se->max_struct_size = max_struct_size; memcpy(se->intermediate_anchor, "_DMI_", 5); se->struct_table_length = len; - se->struct_table_address = tables; + + /* + * We must use a pointer here so things work correctly on sandbox. The + * user of this table is not aware of the mapping of addresses to + * sandbox's DRAM buffer. + */ + table_addr = (ulong)map_sysmem(tables, 0); + if (sizeof(table_addr) >= sizeof(u32) && table_addr >= (1ULL << 32)) { + /* + * We need to put this >32-bit pointer into the table but the + * field is only 32 bits wide. + */ + printf("WARNING: SMBIOS table_address overflow %llx\n", + (unsigned long long)table_addr); + table_addr = 0; + } + se->struct_table_address = table_addr; + se->struct_count = handle;
/* calculate checksums */ @@ -298,6 +331,7 @@ ulong write_smbios_table(ulong addr) isize = sizeof(struct smbios_entry) - SMBIOS_INTERMEDIATE_OFFSET; se->intermediate_checksum = table_compute_checksum(istart, isize); se->checksum = table_compute_checksum(se, sizeof(struct smbios_entry)); + unmap_sysmem(se);
return addr; }
Changes in v13:
void *dmi;
&dmi_addr);
*/* pointer even though it uses a uint64_t type. Convert it.
- return efi_install_configuration_table(&smbios_guid, dmi); }
unmap_sysmem(t);
return len; }
unmap_sysmem(t);
return len; }
unmap_sysmem(t);
return len; }
unmap_sysmem(t);
return len; }
unmap_sysmem(t);
return len; }
*current += len;
unmap_sysmem(t);
return len; }
*current += len;
unmap_sysmem(t);
return len; }
- ulong table_addr; ulong tables; int len = 0; int max_struct_size = 0;
- table_addr = (ulong)map_sysmem(tables, 0);
- if (sizeof(table_addr) >= sizeof(u32) && table_addr >= (1ULL << 32)) {
sizeof(long) >= sizeof(u32) will always be true on any platform U-Boot supports, no?
How about
if (sizeof(table_addr) > sizeof(u32) && table_addr > (ulong)UINT_MAX)
table_addr = 0;
I'm also not sure what to do about the error case. IMHO ideally we should propagate the error to the upper layers, but consider it non-fatal.
unmap_sysmem(se);
return addr; }
Hi Alex,
Changes in v13:
How about
Yes that seems right, thanks.
table_addr = 0;
Yes agreed, but it involves changing the function signature of this and everything else in table_write_funcs[] so I decided to leave it alone for now, since the effect is the same.
The functions in bootefi are very long because they mix high-level code and control with the low-level implementation. To help with this, create functions which handle preparing for running the test and cleaning up afterwards.
Also shorten the awfully long variable names here.
Changes in v13: None Changes in v12: - Rename image to image_prot
Changes in v11: None Changes in v9: - Add comments to bootefi_test_prepare() about the memset()s
Changes in v7: None Changes in v5: - Drop call to efi_init_obj_list() which is now done in do_bootefi()
Changes in v4: None Changes in v3: - Add new patch to split out test init/uninit into functions
cmd/bootefi.c | 85 +++++++++++++++++++++++++++++++++++++++------------ 1 file changed, 65 insertions(+), 20 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 3e37805ea13..91e6046cf5f 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -453,6 +453,64 @@ exit: return ret; }
+#ifdef CONFIG_CMD_BOOTEFI_SELFTEST +/** + * bootefi_test_prepare() - prepare to run an EFI test + * + * This sets things up so we can call EFI functions. This involves preparing + * the 'gd' pointer and setting up the load ed image data structures. + * + * @image: Pointer to a struct which will hold the loaded image info. + * This struct will be inited by this function before use. + * @obj: Pointer to a struct which will hold the loaded image object + * This struct will be inited by this function before use. + * @path: File path to the test being run (often just the test name with a + * backslash before it + * @test_func: Address of the test function that is being run + * @return 0 if OK, -ve on error + */ +static efi_status_t bootefi_test_prepare(struct efi_loaded_image **imagep, + struct efi_loaded_image_obj **objp, + const char *path, ulong test_func) +{ + efi_status_t r; + + /* Construct a dummy device path */ + bootefi_device_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, + (uintptr_t)test_func, + (uintptr_t)test_func); + bootefi_image_path = efi_dp_from_file(NULL, 0, path); + r = efi_setup_loaded_image(bootefi_device_path, bootefi_image_path, + objp, imagep); + if (r) + return r; + /* + * gd lives in a fixed register which may get clobbered while we execute + * the payload. So save it here and restore it on every callback entry + */ + efi_save_gd(); + + /* Transfer environment variable efi_selftest as load options */ + set_load_options(*imagep, "efi_selftest"); + + return 0; +} + +/** + * bootefi_test_finish() - finish up after running an EFI test + * + * @image_prot: Pointer to a struct which holds the loaded image info + * @obj: Pointer to a struct which holds the loaded image object + */ +static void bootefi_test_finish(struct efi_loaded_image *image_prot, + struct efi_loaded_image_obj *obj) +{ + efi_restore_gd(); + free(image_prot->load_options); + efi_delete_handle(&obj->header); +} +#endif /* CONFIG_CMD_BOOTEFI_SELFTEST */ + static int do_bootefi_bootmgr_exec(void) { struct efi_device_path *device_path, *file_path; @@ -525,29 +583,16 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #endif #ifdef CONFIG_CMD_BOOTEFI_SELFTEST if (!strcmp(argv[1], "selftest")) { - struct efi_loaded_image_obj *image_obj; - struct efi_loaded_image *loaded_image_info; - - /* Construct a dummy device path. */ - bootefi_device_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, - (uintptr_t)&efi_selftest, - (uintptr_t)&efi_selftest); - bootefi_image_path = efi_dp_from_file(NULL, 0, "\selftest"); - - r = efi_setup_loaded_image(bootefi_device_path, - bootefi_image_path, &image_obj, - &loaded_image_info); - if (r != EFI_SUCCESS) + struct efi_loaded_image *image_prot; + struct efi_loaded_image_obj *obj; + + if (bootefi_test_prepare(&image_prot, &obj, "\selftest", + (uintptr_t)&efi_selftest)) return CMD_RET_FAILURE;
- efi_save_gd(); - /* Transfer environment variable efi_selftest as load options */ - set_load_options(loaded_image_info, "efi_selftest"); /* Execute the test */ - r = efi_selftest(&image_obj->header, &systab); - efi_restore_gd(); - free(loaded_image_info->load_options); - efi_delete_handle(&image_obj->header); + r = efi_selftest(&obj->header, &systab); + bootefi_test_finish(image_prot, obj); return r != EFI_SUCCESS; } else #endif
- bootefi_test_prepare() - prepare to run an EFI test
- This sets things up so we can call EFI functions. This involves preparing
- the 'gd' pointer and setting up the load ed image data structures.
- @image: Pointer to a struct which will hold the loaded image info.
- This struct will be inited by this function before use.
- @obj: Pointer to a struct which will hold the loaded image object
- @path: File path to the test being run (often just the test name with a
- backslash before it
- @test_func: Address of the test function that is being run
- @return 0 if OK, -ve on error
- efi_status_t r;
- /* Construct a dummy device path */
- bootefi_image_path = efi_dp_from_file(NULL, 0, path);
- r = efi_setup_loaded_image(bootefi_device_path, bootefi_image_path,
objp, imagep);
- if (r)
return r;
- efi_save_gd();
- set_load_options(*imagep, "efi_selftest");
- bootefi_test_finish() - finish up after running an EFI test
- @image_prot: Pointer to a struct which holds the loaded image info
- @obj: Pointer to a struct which holds the loaded image object
- efi_restore_gd();
- free(image_prot->load_options);
- efi_delete_handle(&obj->header);
- static int do_bootefi_bootmgr_exec(void) { struct efi_device_path *device_path, *file_path;
bootefi_image_path = efi_dp_from_file(NULL, 0, "\\selftest");
This is still renaming the UEFI spec defined variables. Please don't do that.
Alex
if (bootefi_test_prepare(&image_prot, &obj, "\\selftest",
efi_save_gd();
/* Execute the test */set_load_options(loaded_image_info, "efi_selftest");
efi_restore_gd();
return r != EFI_SUCCESS; } else #endifbootefi_test_finish(image_prot, obj);
There is still duplicated code in efi_loader for tests and normal operation.
Add a new bootefi_run_prepare() function which holds common code used to set up U-Boot to run EFI code. Make use of this from the existing bootefi_test_prepare() function, as well as do_bootefi_exec().
Also shorten a few variable names.
Changes in v13: None Changes in v12: None Changes in v11: None Changes in v9: None Changes in v7: None Changes in v5: - Drop call to efi_init_obj_list() which is now done in do_bootefi() - Introduce load_options_path to specifyc U-Boot env var for load_options_path
Changes in v3: - Add patch to create a function to set up for running EFI code
cmd/bootefi.c | 85 +++++++++++++++++++++++++++++---------------------- 1 file changed, 48 insertions(+), 37 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 91e6046cf5f..492052d827a 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -325,6 +325,30 @@ static efi_status_t efi_install_fdt(ulong fdt_addr) return ret; }
+static efi_status_t bootefi_run_prepare(const char *load_options_path, + struct efi_device_path *device_path, + struct efi_device_path *image_path, + struct efi_loaded_image **imagep, + struct efi_loaded_image_obj **objp) +{ + efi_status_t ret; + + ret = efi_setup_loaded_image(device_path, image_path, objp, imagep); + if (ret != EFI_SUCCESS) + return ret; + + /* + * gd lives in a fixed register which may get clobbered while we execute + * the payload. So save it here and restore it on every callback entry + */ + efi_save_gd(); + + /* Transfer environment variable as load options */ + set_load_options(*imagep, load_options_path); + + return 0; +} + /** * do_bootefi_exec() - execute EFI binary * @@ -343,8 +367,8 @@ static efi_status_t do_bootefi_exec(void *efi, efi_handle_t mem_handle = NULL; struct efi_device_path *memdp = NULL; efi_status_t ret; - struct efi_loaded_image_obj *image_obj = NULL; - struct efi_loaded_image *loaded_image_info = NULL; + struct efi_loaded_image_obj *obj = NULL; + struct efi_loaded_image *image_prot = NULL;
EFIAPI efi_status_t (*entry)(efi_handle_t image_handle, struct efi_system_table *st); @@ -374,15 +398,13 @@ static efi_status_t do_bootefi_exec(void *efi, assert(device_path && image_path); }
- ret = efi_setup_loaded_image(device_path, image_path, &image_obj, - &loaded_image_info); - if (ret != EFI_SUCCESS) - goto exit; + ret = bootefi_run_prepare("bootargs", device_path, image_path, + &image_prot, &obj); + if (ret) + return ret;
- /* Transfer environment variable bootargs as load options */ - set_load_options(loaded_image_info, "bootargs"); /* Load the EFI payload */ - entry = efi_load_pe(image_obj, efi, loaded_image_info); + entry = efi_load_pe(obj, efi, image_prot); if (!entry) { ret = EFI_LOAD_ERROR; goto exit; @@ -390,10 +412,9 @@ static efi_status_t do_bootefi_exec(void *efi,
if (memdp) { struct efi_device_path_memory *mdp = (void *)memdp; - mdp->memory_type = loaded_image_info->image_code_type; - mdp->start_address = (uintptr_t)loaded_image_info->image_base; - mdp->end_address = mdp->start_address + - loaded_image_info->image_size; + mdp->memory_type = image_prot->image_code_type; + mdp->start_address = (uintptr_t)image_prot->image_base; + mdp->end_address = mdp->start_address + image_prot->image_size; }
/* we don't support much: */ @@ -403,8 +424,8 @@ static efi_status_t do_bootefi_exec(void *efi, /* Call our payload! */ debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry);
- if (setjmp(&image_obj->exit_jmp)) { - ret = image_obj->exit_status; + if (setjmp(&obj->exit_jmp)) { + ret = obj->exit_status; goto exit; }
@@ -416,7 +437,7 @@ static efi_status_t do_bootefi_exec(void *efi,
/* Move into EL2 and keep running there */ armv8_switch_to_el2((ulong)entry, - (ulong)&image_obj->header, + (ulong)&obj->header, (ulong)&systab, 0, (ulong)efi_run_in_el2, ES_TO_AARCH64);
@@ -433,7 +454,7 @@ static efi_status_t do_bootefi_exec(void *efi, secure_ram_addr(_do_nonsec_entry)( efi_run_in_hyp, (uintptr_t)entry, - (uintptr_t)&image_obj->header, + (uintptr_t)&obj->header, (uintptr_t)&systab);
/* Should never reach here, efi exits with longjmp */ @@ -441,12 +462,12 @@ static efi_status_t do_bootefi_exec(void *efi, } #endif
- ret = efi_do_enter(&image_obj->header, &systab, entry); + ret = efi_do_enter(&obj->header, &systab, entry);
exit: /* image has returned, loaded-image obj goes *poof*: */ - if (image_obj) - efi_delete_handle(&image_obj->header); + if (obj) + efi_delete_handle(&obj->header); if (mem_handle) efi_delete_handle(mem_handle);
@@ -467,33 +488,22 @@ exit: * @path: File path to the test being run (often just the test name with a * backslash before it * @test_func: Address of the test function that is being run + * @load_options_path: U-Boot environment variable to use as load options * @return 0 if OK, -ve on error */ static efi_status_t bootefi_test_prepare(struct efi_loaded_image **imagep, struct efi_loaded_image_obj **objp, - const char *path, ulong test_func) + const char *path, ulong test_func, + const char *load_options_path) { - efi_status_t r; - /* Construct a dummy device path */ bootefi_device_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, (uintptr_t)test_func, (uintptr_t)test_func); bootefi_image_path = efi_dp_from_file(NULL, 0, path); - r = efi_setup_loaded_image(bootefi_device_path, bootefi_image_path, - objp, imagep); - if (r) - return r; - /* - * gd lives in a fixed register which may get clobbered while we execute - * the payload. So save it here and restore it on every callback entry - */ - efi_save_gd(); - - /* Transfer environment variable efi_selftest as load options */ - set_load_options(*imagep, "efi_selftest");
- return 0; + return bootefi_run_prepare(load_options_path, bootefi_device_path, + bootefi_image_path, imagep, objp); }
/** @@ -587,7 +597,8 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) struct efi_loaded_image_obj *obj;
if (bootefi_test_prepare(&image_prot, &obj, "\selftest", - (uintptr_t)&efi_selftest)) + (uintptr_t)&efi_selftest, + "efi_selftest")) return CMD_RET_FAILURE;
Changes in v4:
- Rebase to master
Changes in v3:
- efi_status_t ret;
- ret = efi_setup_loaded_image(device_path, image_path, objp, imagep);
return ret;
- efi_save_gd();
- /* Transfer environment variable as load options */
- set_load_options(*imagep, load_options_path);
- do_bootefi_exec() - execute EFI binary
- struct efi_loaded_image_obj *obj = NULL;
- struct efi_loaded_image *image_prot = NULL;
Same here.
Alex
This function can be used from do_bootefi_exec() so that we use mostly the same code for a normal EFI application and an EFI test.
Rename the function and use it in both places.
Changes in v12: None Changes in v11: - Drop patches previously applied
Changes in v9: None Changes in v7: - Drop patch "efi: Init the 'rows' and 'cols' variables" - Drop patches previous applied
Changes in v5: - Rebase to master
cmd/bootefi.c | 32 ++++++++++++++++---------------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 492052d827a..317c7feb0a5 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -349,6 +349,20 @@ static efi_status_t bootefi_run_prepare(const char *load_options_path, return 0; }
+/** + * bootefi_run_finish() - finish up after running an EFI test + * + * @image: Pointer to a struct which holds the loaded image info + * @obj: Pointer to a struct which holds the loaded image object + */ +static void bootefi_run_finish(struct efi_loaded_image *image, + struct efi_loaded_image_obj *obj) +{ + efi_restore_gd(); + free(image->load_options); + efi_delete_handle(&obj->header); +} + /** * do_bootefi_exec() - execute EFI binary * @@ -466,8 +480,7 @@ static efi_status_t do_bootefi_exec(void *efi,
exit: /* image has returned, loaded-image obj goes *poof*: */ - if (obj) - efi_delete_handle(&obj->header); + bootefi_run_finish(image_prot, obj); if (mem_handle) efi_delete_handle(mem_handle);
@@ -506,19 +519,6 @@ static efi_status_t bootefi_test_prepare(struct efi_loaded_image **imagep, bootefi_image_path, imagep, objp); }
-/** - * bootefi_test_finish() - finish up after running an EFI test - * - * @image_prot: Pointer to a struct which holds the loaded image info - * @obj: Pointer to a struct which holds the loaded image object - */ -static void bootefi_test_finish(struct efi_loaded_image *image_prot, - struct efi_loaded_image_obj *obj) -{ - efi_restore_gd(); - free(image_prot->load_options); - efi_delete_handle(&obj->header); -} #endif /* CONFIG_CMD_BOOTEFI_SELFTEST */
static int do_bootefi_bootmgr_exec(void) @@ -603,7 +603,7 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* Execute the test */ r = efi_selftest(&obj->header, &systab); - bootefi_test_finish(image_prot, obj); + bootefi_run_finish(image_prot, obj); return r != EFI_SUCCESS; } else #endif
Changes in v13:
Changes in v5:
- Rebase to master
Changes in v4:
- Rebase to master
Changes in v3:
- bootefi_run_finish() - finish up after running an EFI test
- @image: Pointer to a struct which holds the loaded image info
- efi_restore_gd();
- free(image->load_options);
- if (obj)
What about the conditional dereference? The new bootefi_run_finish() function is dropping that.
Alex
- bootefi_run_finish(image_prot, obj); if (mem_handle) efi_delete_handle(mem_handle);
- efi_restore_gd();
return r != EFI_SUCCESS; } else #endifbootefi_run_finish(image_prot, obj);
Hi Alex,
Changes in v13:
Changes in v5:
- Rebase to master
Changes in v4:
- Rebase to master
Changes in v3:
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 492052d827a..317c7feb0a5 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -349,6 +349,20 @@ static efi_status_t bootefi_run_prepare(const char *load_options_path, return 0; } +/**
efi_restore_gd();
@@ -466,8 +480,7 @@ static efi_status_t do_bootefi_exec(void *efi, exit: /* image has returned, loaded-image obj goes *poof*: */
if (obj)
Hmm yes. Actually it looks like the error handling in this function is a bit broken. I'll rework it, hopefully without breaking it further.
Alexander Graf
