[U-Boot] [PATCH 2/2] ARM: DTS: Resync Logic PD SOM-LV 37xx devkit with Linux 4.18-RC4
There have been some significant changes to the DM37 SOM-LV device tree. This patch re-syncs it with Linux.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/logicpd-som-lv-37xx-devkit.dts b/arch/arm/dts/logicpd-som-lv-37xx-devkit.dts index 1702b9e3db..2428373952 100644 --- a/arch/arm/dts/logicpd-som-lv-37xx-devkit.dts +++ b/arch/arm/dts/logicpd-som-lv-37xx-devkit.dts @@ -8,262 +8,10 @@
#include "omap36xx.dtsi" #include "logicpd-som-lv.dtsi" +#include "logicpd-som-lv-baseboard.dtsi" #include "omap-gpmc-smsc9221.dtsi"
/ { model = "LogicPD Zoom DM3730 SOM-LV Development Kit"; compatible = "logicpd,dm3730-som-lv-devkit", "ti,omap3630", "ti,omap3"; - - chosen { - stdout-path = &uart1; - }; - - gpio_keys { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&gpio_key_pins>; - - sysboot2 { - label = "gpio3"; - gpios = <&gpio4 15 GPIO_ACTIVE_LOW>; /* gpio_111 / uP_GPIO_3 */ - linux,code = <BTN_0>; - wakeup-source; - }; - }; - - sound { - compatible = "ti,omap-twl4030"; - ti,model = "omap3logic"; - ti,mcbsp = <&mcbsp2>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins &led_pins_wkup>; - - led1 { - label = "led1"; - gpios = <&gpio5 5 GPIO_ACTIVE_LOW>; /* gpio133 */ - linux,default-trigger = "cpu0"; - }; - - led2 { - label = "led2"; - gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; /* gpio11 */ - linux,default-trigger = "none"; - }; - }; -}; - -&vaux1 { - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; -}; - -&vaux4 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; -}; - -&mcbsp2 { - status = "okay"; -}; - -&charger { - ti,bb-uvolt = <3200000>; - ti,bb-uamp = <150>; -}; - -&gpmc { - ranges = <1 0 0x08000000 0x1000000>; /* CS1: 16MB for LAN9221 */ - - ethernet@gpmc { - pinctrl-names = "default"; - pinctrl-0 = <&lan9221_pins>; - interrupt-parent = <&gpio5>; - interrupts = <24 IRQ_TYPE_LEVEL_LOW>; /* gpio_152 */ - reg = <1 0 0xff>; - }; -}; - -&vpll2 { - regulator-always-on; -}; - -&dss { - status = "ok"; - vdds_dsi-supply = <&vpll2>; - vdda_video-supply = <&video_reg>; - pinctrl-names = "default"; - pinctrl-0 = <&dss_dpi_pins1>; - port { - dpi_out: endpoint { - remote-endpoint = <&lcd_in>; - data-lines = <16>; - }; - }; -}; - -/ { - aliases { - display0 = &lcd0; - }; - - video_reg: video_reg { - compatible = "regulator-fixed"; - regulator-name = "fixed-supply"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - lcd0: display@0 { - compatible = "panel-dpi"; - label = "28"; - status = "okay"; - /* default-on; */ - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_pin>; - enable-gpios = <&gpio5 27 GPIO_ACTIVE_HIGH>; /* gpio155, lcd INI */ - port { - lcd_in: endpoint { - remote-endpoint = <&dpi_out>; - }; - }; - - panel-timing { - clock-frequency = <9000000>; - hactive = <480>; - vactive = <272>; - hfront-porch = <3>; - hback-porch = <2>; - hsync-len = <42>; - vback-porch = <3>; - vfront-porch = <2>; - vsync-len = <11>; - hsync-active = <1>; - vsync-active = <1>; - de-active = <1>; - pixelclk-active = <0>; - }; - }; - - bl: backlight { - compatible = "pwm-backlight"; - pinctrl-names = "default"; - pinctrl-0 = <&backlight_pins>; - pwms = <&twl_pwm 0 5000000>; - brightness-levels = <0 10 20 30 40 50 60 70 80 90 100>; - default-brightness-level = <7>; - enable-gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; /* gpio_8 */ - }; -}; - -&mmc1 { - interrupts-extended = <&intc 83 &omap3_pmx_core 0x11a>; - pinctrl-names = "default"; - pinctrl-0 = <&mmc1_pins>; - vmmc-supply = <&vmmc1>; - bus-width = <4>; - cap-power-off-card; -}; - -&mmc2 { - status = "disabled"; -}; - -&omap3_pmx_core { - gpio_key_pins: pinmux_gpio_key_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x212e, PIN_INPUT_PULLUP | MUX_MODE4) /* cam_xclkb.gpio_111 / uP_GPIO_3*/ - >; - }; - - led_pins: pinmux_led_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x215e, PIN_OUTPUT_PULLUP | MUX_MODE4) /* sdmmc2_dat1.gpio_133 / uP_GPIO_0 */ - >; - }; - - lan9221_pins: pinmux_lan9221_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2184, PIN_INPUT_PULLUP | MUX_MODE4) /* mcbsp4_clkx.gpio_152 */ - >; - }; - - mmc1_pins: pinmux_mmc1_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2144, PIN_OUTPUT | MUX_MODE0) /* sdmmc1_clk.sdmmc1_clk */ - OMAP3_CORE1_IOPAD(0x2146, PIN_INPUT | MUX_MODE0) /* sdmmc1_cmd.sdmmc1_cmd */ - OMAP3_CORE1_IOPAD(0x2148, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat0.sdmmc1_dat0 */ - OMAP3_CORE1_IOPAD(0x214a, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat1.sdmmc1_dat1 */ - OMAP3_CORE1_IOPAD(0x214c, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat2.sdmmc1_dat2 */ - OMAP3_CORE1_IOPAD(0x214e, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat3.sdmmc1_dat3 */ - OMAP3_CORE1_IOPAD(0x2132, PIN_INPUT_PULLUP | MUX_MODE4) /* cam_strobe.gpio_126 */ - OMAP3_CORE1_IOPAD(0x212c, PIN_INPUT_PULLUP | MUX_MODE4) /* cam_d11.gpio_110 */ - >; - }; - - lcd_enable_pin: pinmux_lcd_enable_pin { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x218a, PIN_OUTPUT | PIN_OFF_OUTPUT_LOW | MUX_MODE4) /* mcbsp4_fs.gpio_155 */ - >; - }; - - dss_dpi_pins1: pinmux_dss_dpi_pins1 { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x20d4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_pclk.dss_pclk */ - OMAP3_CORE1_IOPAD(0x20d6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_hsync.dss_hsync */ - OMAP3_CORE1_IOPAD(0x20d8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_vsync.dss_vsync */ - OMAP3_CORE1_IOPAD(0x20da, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_acbias.dss_acbias */ - - OMAP3_CORE1_IOPAD(0x20dc, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data0.dss_data0 */ - OMAP3_CORE1_IOPAD(0x20de, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data1.dss_data1 */ - OMAP3_CORE1_IOPAD(0x20e0, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data2.dss_data2 */ - OMAP3_CORE1_IOPAD(0x20e2, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data3.dss_data3 */ - OMAP3_CORE1_IOPAD(0x20e4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data4.dss_data4 */ - OMAP3_CORE1_IOPAD(0x20e6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data5.dss_data5 */ - OMAP3_CORE1_IOPAD(0x20e8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data6.dss_data6 */ - OMAP3_CORE1_IOPAD(0x20ea, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data7.dss_data7 */ - OMAP3_CORE1_IOPAD(0x20ec, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data8.dss_data8 */ - OMAP3_CORE1_IOPAD(0x20ee, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data9.dss_data9 */ - OMAP3_CORE1_IOPAD(0x20f0, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data10.dss_data10 */ - OMAP3_CORE1_IOPAD(0x20f2, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data11.dss_data11 */ - OMAP3_CORE1_IOPAD(0x20f4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data12.dss_data12 */ - OMAP3_CORE1_IOPAD(0x20f6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data13.dss_data13 */ - OMAP3_CORE1_IOPAD(0x20f8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data14.dss_data14 */ - OMAP3_CORE1_IOPAD(0x20fa, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data15.dss_data15 */ - >; - }; -}; - -&omap3_pmx_wkup { - led_pins_wkup: pinmux_led_pins_wkup { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a24, PIN_OUTPUT_PULLUP | MUX_MODE4) /* jtag_emu0.gpio_11 / uP_GPIO_1 */ - >; - }; - - backlight_pins: pinmux_backlight_pins { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a16, PIN_OUTPUT | PIN_OFF_OUTPUT_LOW | MUX_MODE4) /* sys_boot6.gpio_8 */ - >; - }; -}; - - -&uart1 { - interrupts-extended = <&intc 72 &omap3_pmx_core OMAP3_UART1_RX>; -}; - -/* Wired to the tps65950 on the SOM, only the USB connector is on the devkit */ -&usb_otg_hs { - pinctrl-names = "default"; - pinctrl-0 = <&hsusb_otg_pins>; - interface-type = <0>; - usb-phy = <&usb2_phy>; - phys = <&usb2_phy>; - phy-names = "usb2-phy"; - mode = <3>; - power = <50>; }; diff --git a/arch/arm/dts/logicpd-som-lv-baseboard.dtsi b/arch/arm/dts/logicpd-som-lv-baseboard.dtsi new file mode 100644 index 0000000000..4990ed90dc --- /dev/null +++ b/arch/arm/dts/logicpd-som-lv-baseboard.dtsi @@ -0,0 +1,256 @@ +/* + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +/ { + gpio_keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&gpio_key_pins>; + + sysboot2 { + label = "gpio3"; + gpios = <&gpio4 15 GPIO_ACTIVE_LOW>; /* gpio_111 / uP_GPIO_3 */ + linux,code = <BTN_0>; + wakeup-source; + }; + }; + + sound { + compatible = "ti,omap-twl4030"; + ti,model = "omap3logic"; + ti,mcbsp = <&mcbsp2>; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins &led_pins_wkup>; + + led1 { + label = "led1"; + gpios = <&gpio5 5 GPIO_ACTIVE_LOW>; /* gpio133 */ + linux,default-trigger = "cpu0"; + }; + + led2 { + label = "led2"; + gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; /* gpio11 */ + linux,default-trigger = "none"; + }; + }; +}; + +&vaux1 { + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; +}; + +&vaux4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; +}; + +&mcbsp2 { + status = "okay"; +}; + +&charger { + ti,bb-uvolt = <3200000>; + ti,bb-uamp = <150>; +}; + +&gpmc { + ranges = <0 0 0x30000000 0x1000000 /* CS0: 16MB for NAND */ + 1 0 0x2c000000 0x1000000 /* CS1: 16MB for LAN9221 */ + 2 0 0x10000000 0x2000000>; /* CS2: 32MB for NOR */ + + ethernet@gpmc { + pinctrl-names = "default"; + pinctrl-0 = <&lan9221_pins>; + interrupt-parent = <&gpio5>; + interrupts = <24 IRQ_TYPE_LEVEL_LOW>; /* gpio_152 */ + reg = <1 0 0xff>; + }; +}; + +&vpll2 { + regulator-always-on; +}; + +&dss { + status = "ok"; + vdds_dsi-supply = <&vpll2>; + vdda_video-supply = <&video_reg>; + pinctrl-names = "default"; + pinctrl-0 = <&dss_dpi_pins1>; + port { + dpi_out: endpoint { + remote-endpoint = <&lcd_in>; + data-lines = <16>; + }; + }; +}; + +/ { + aliases { + display0 = &lcd0; + }; + + video_reg: video_reg { + compatible = "regulator-fixed"; + regulator-name = "fixed-supply"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + lcd0: display@0 { + compatible = "panel-dpi"; + label = "28"; + status = "okay"; + /* default-on; */ + pinctrl-names = "default"; + pinctrl-0 = <&lcd_enable_pin>; + enable-gpios = <&gpio5 27 GPIO_ACTIVE_HIGH>; /* gpio155, lcd INI */ + port { + lcd_in: endpoint { + remote-endpoint = <&dpi_out>; + }; + }; + + panel-timing { + clock-frequency = <9000000>; + hactive = <480>; + vactive = <272>; + hfront-porch = <3>; + hback-porch = <2>; + hsync-len = <42>; + vback-porch = <3>; + vfront-porch = <2>; + vsync-len = <11>; + hsync-active = <1>; + vsync-active = <1>; + de-active = <1>; + pixelclk-active = <0>; + }; + }; + + bl: backlight { + compatible = "pwm-backlight"; + pinctrl-names = "default"; + pinctrl-0 = <&backlight_pins>; + pwms = <&twl_pwm 0 5000000>; + brightness-levels = <0 10 20 30 40 50 60 70 80 90 100>; + default-brightness-level = <7>; + enable-gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; /* gpio_8 */ + }; +}; + +&mmc1 { + interrupts-extended = <&intc 83 &omap3_pmx_core 0x11a>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + wp-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>; /* gpio_126 */ + cd-gpios = <&gpio4 14 IRQ_TYPE_LEVEL_LOW>; /* gpio_110 */ + vmmc-supply = <&vmmc1>; + bus-width = <4>; + cap-power-off-card; +}; + +&omap3_pmx_core { + gpio_key_pins: pinmux_gpio_key_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x212e, PIN_INPUT_PULLUP | MUX_MODE4) /* cam_xclkb.gpio_111 / uP_GPIO_3*/ + >; + }; + + led_pins: pinmux_led_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x215e, PIN_OUTPUT_PULLUP | MUX_MODE4) /* sdmmc2_dat1.gpio_133 / uP_GPIO_0 */ + >; + }; + + lan9221_pins: pinmux_lan9221_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x2184, PIN_INPUT_PULLUP | MUX_MODE4) /* mcbsp4_clkx.gpio_152 */ + >; + }; + + mmc1_pins: pinmux_mmc1_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x2144, PIN_OUTPUT | MUX_MODE0) /* sdmmc1_clk.sdmmc1_clk */ + OMAP3_CORE1_IOPAD(0x2146, PIN_INPUT | MUX_MODE0) /* sdmmc1_cmd.sdmmc1_cmd */ + OMAP3_CORE1_IOPAD(0x2148, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat0.sdmmc1_dat0 */ + OMAP3_CORE1_IOPAD(0x214a, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat1.sdmmc1_dat1 */ + OMAP3_CORE1_IOPAD(0x214c, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat2.sdmmc1_dat2 */ + OMAP3_CORE1_IOPAD(0x214e, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat3.sdmmc1_dat3 */ + OMAP3_CORE1_IOPAD(0x2132, PIN_INPUT_PULLUP | MUX_MODE4) /* cam_strobe.gpio_126 */ + OMAP3_CORE1_IOPAD(0x212c, PIN_INPUT_PULLUP | MUX_MODE4) /* cam_d11.gpio_110 */ + >; + }; + + lcd_enable_pin: pinmux_lcd_enable_pin { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x218a, PIN_OUTPUT | PIN_OFF_OUTPUT_LOW | MUX_MODE4) /* mcbsp4_fs.gpio_155 */ + >; + }; + + dss_dpi_pins1: pinmux_dss_dpi_pins1 { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x20d4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_pclk.dss_pclk */ + OMAP3_CORE1_IOPAD(0x20d6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_hsync.dss_hsync */ + OMAP3_CORE1_IOPAD(0x20d8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_vsync.dss_vsync */ + OMAP3_CORE1_IOPAD(0x20da, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_acbias.dss_acbias */ + + OMAP3_CORE1_IOPAD(0x20dc, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data0.dss_data0 */ + OMAP3_CORE1_IOPAD(0x20de, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data1.dss_data1 */ + OMAP3_CORE1_IOPAD(0x20e0, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data2.dss_data2 */ + OMAP3_CORE1_IOPAD(0x20e2, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data3.dss_data3 */ + OMAP3_CORE1_IOPAD(0x20e4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data4.dss_data4 */ + OMAP3_CORE1_IOPAD(0x20e6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data5.dss_data5 */ + OMAP3_CORE1_IOPAD(0x20e8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data6.dss_data6 */ + OMAP3_CORE1_IOPAD(0x20ea, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data7.dss_data7 */ + OMAP3_CORE1_IOPAD(0x20ec, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data8.dss_data8 */ + OMAP3_CORE1_IOPAD(0x20ee, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data9.dss_data9 */ + OMAP3_CORE1_IOPAD(0x20f0, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data10.dss_data10 */ + OMAP3_CORE1_IOPAD(0x20f2, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data11.dss_data11 */ + OMAP3_CORE1_IOPAD(0x20f4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data12.dss_data12 */ + OMAP3_CORE1_IOPAD(0x20f6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data13.dss_data13 */ + OMAP3_CORE1_IOPAD(0x20f8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data14.dss_data14 */ + OMAP3_CORE1_IOPAD(0x20fa, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data15.dss_data15 */ + >; + }; +}; + +&omap3_pmx_wkup { + led_pins_wkup: pinmux_led_pins_wkup { + pinctrl-single,pins = < + OMAP3_WKUP_IOPAD(0x2a24, PIN_OUTPUT_PULLUP | MUX_MODE4) /* jtag_emu0.gpio_11 / uP_GPIO_1 */ + >; + }; + + backlight_pins: pinmux_backlight_pins { + pinctrl-single,pins = < + OMAP3_WKUP_IOPAD(0x2a16, PIN_OUTPUT | PIN_OFF_OUTPUT_LOW | MUX_MODE4) /* sys_boot6.gpio_8 */ + >; + }; +}; + + +&uart1 { + interrupts-extended = <&intc 72 &omap3_pmx_core OMAP3_UART1_RX>; +}; + +/* Wired to the tps65950 on the SOM, only the USB connector is on the devkit */ +&usb_otg_hs { + pinctrl-names = "default"; + pinctrl-0 = <&hsusb_otg_pins>; + interface-type = <0>; + usb-phy = <&usb2_phy>; + phys = <&usb2_phy>; + phy-names = "usb2-phy"; + mode = <3>; + power = <50>; +}; diff --git a/arch/arm/dts/logicpd-som-lv.dtsi b/arch/arm/dts/logicpd-som-lv.dtsi index c1aa7a4518..3bb28c03ca 100644 --- a/arch/arm/dts/logicpd-som-lv.dtsi +++ b/arch/arm/dts/logicpd-som-lv.dtsi @@ -26,7 +26,7 @@ gpio = <&gpio1 3 0>; /* gpio_3 */ startup-delay-us = <70000>; enable-active-high; - vin-supply = <&vmmc2>; + vin-supply = <&vaux3>; };
/* HS USB Host PHY on PORT 1 */ @@ -35,6 +35,13 @@ reset-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; /* gpio_4 */ #phy-cells = <0>; }; + + /* fixed 26MHz oscillator */ + hfclk_26m: oscillator { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <26000000>; + }; };
&gpmc { @@ -71,26 +78,54 @@ };
&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; clock-frequency = <2600000>;
twl: twl@48 { reg = <0x48>; interrupts = <7>; /* SYS_NIRQ cascaded to intc */ interrupt-parent = <&intc>; + clocks = <&hfclk_26m>; + clock-names = "fck"; twl_audio: audio { compatible = "ti,twl4030-audio"; codec { + ti,hs_extmute_gpio = <&gpio2 25 GPIO_ACTIVE_HIGH>; }; }; }; };
&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins>; clock-frequency = <400000>; };
&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c3_pins>; clock-frequency = <400000>; + + touchscreen: tsc2004@48 { + compatible = "ti,tsc2004"; + reg = <0x48>; + vio-supply = <&vaux1>; + pinctrl-names = "default"; + pinctrl-0 = <&tsc2004_pins>; + interrupts-extended = <&gpio5 25 IRQ_TYPE_EDGE_RISING>; /* gpio 153 */ + + touchscreen-fuzz-x = <4>; + touchscreen-fuzz-y = <7>; + touchscreen-fuzz-pressure = <2>; + touchscreen-size-x = <4096>; + touchscreen-size-y = <4096>; + touchscreen-max-pressure = <2048>; + + ti,x-plate-ohms = <280>; + ti,esd-recovery-timeout-ms = <8000>; + }; };
&mmc3 { @@ -189,7 +224,19 @@ >; };
+ i2c1_pins: pinmux_i2c1_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x21ba, PIN_INPUT | MUX_MODE0) /* i2c1_scl.i2c1_scl */ + OMAP3_CORE1_IOPAD(0x21bc, PIN_INPUT | MUX_MODE0) /* i2c1_sda.i2c1_sda */ + OMAP3_CORE1_IOPAD(0x20ba, PIN_OUTPUT | MUX_MODE4) /* gpmc_ncs6.gpio_57 */ + >; + };
+ tsc2004_pins: pinmux_tsc2004_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x2186, PIN_INPUT | MUX_MODE4) /* mcbsp4_dr.gpio_153 */ + >; + }; };
&omap3_pmx_wkup { @@ -202,10 +249,22 @@ }; wl127x_gpio: pinmux_wl127x_gpio_pin { pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a0c, PIN_INPUT | MUX_MODE4) /* sys_boot0.gpio_2 */ + OMAP3_WKUP_IOPAD(0x2a0a, PIN_INPUT | MUX_MODE4) /* sys_boot0.gpio_2 */ OMAP3_WKUP_IOPAD(0x2a0c, PIN_OUTPUT | MUX_MODE4) /* sys_boot1.gpio_3 */ >; }; + i2c2_pins: pinmux_i2c2_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x21be, PIN_INPUT | MUX_MODE0) /* i2c2_scl */ + OMAP3_CORE1_IOPAD(0x21c0, PIN_INPUT | MUX_MODE0) /* i2c2_sda */ + >; + }; + i2c3_pins: pinmux_i2c3_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x21c2, PIN_INPUT | MUX_MODE0) /* i2c3_scl */ + OMAP3_CORE1_IOPAD(0x21c4, PIN_INPUT | MUX_MODE0) /* i2c3_sda */ + >; + }; };
&omap3_pmx_core2 { @@ -237,6 +296,11 @@ #include "twl4030.dtsi" #include "twl4030_omap3.dtsi"
+&vaux3 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; +}; + &twl { twl_power: power { compatible = "ti,twl4030-power-idle-osc-off", "ti,twl4030-power-idle";
Adam Ford
