U-Boot Fails w/ Memory Test
Hello all,
I am trying to enable memory POST test for my ARM-based processor. I have reached the point where the U-Boot runs the test and it passes. However, U-Boot later hangs after the following lines:
DDR 31.9 GiB (DDR4, 64-bit, CL=22, ECC on) DDR Controller Interleaving Mode: 256B DDR Chip-Select Interleaving Mode: CS0+CS1
My guess is that the memory test is somehow messing something up, even though it passes, but I don't know how. My attempts to debug and figure out the issue have led me to discover that the issue occurs in the relocate_code function. Other than that, I have not been able to figure anything out. If I build and run U-Boot without the memory test, it works fine, so I know the issue has something to do with the test. (The test is called from the board_init_f function.)
Does anyone have any ideas what may be wrong and/or what I could do to find the issue?
Thank you -Lewis
On 07.08.20 00:50, Brownlie, Lewis wrote:
Hello all,
Thank you -Lewis
Have a look at arch_memory_test_prepare(). The function blindly asks to test and thereby overwrite up to 256 MiB from CONFIG_SYS_SDRAM_BASE to gd->bd.
The test must run *after* relocation. Otherwise we will overwrite U-Boot.
The end of the memory range tested should be ((uintptr_t)map_sysmem(gd->start_addr_sp, 0) - CONFIG_STACK_SIZE.
All memory areas marked as reserved in the device tree have to be excluded.
Best regards
Heinrich
Brownlie, Lewis
