[U-Boot] [PATCH v3 0/4] introduce nand write.trimffs
This series adds a nand write variant which implements the procedure reccomended in the UBI FAQ [1] of dropping trailing pages of eraseblocks containing entirely 0xff's.
[1] http://www.linux-mtd.infradead.org/doc/ubi.html#L_flasher_algo
Changes since v2: * dropped WITH_DEFAULTS in favour of '0' * moved copyright header to nand_util patch * added write.trimffs variant to README.nand
Changes since v1: * renamed to 'trimffs' from 'ubi' * wrapped the new feature in #ifdefs * don't make it default for jffs -- patch dropped * attribution of the drop_ffs() function from mtd-utils to Artem
Ben Gardiner (4): [v3] nand_base: trivial: fix comment read/write comment [v3] nand_util: convert nand_write_skip_bad() to flags [v3] nand_util: drop trailing all-0xff pages if requested [v3] cmd_nand: add nand write.trimffs command
common/cmd_nand.c | 19 +++++++++++++++++- doc/README.nand | 10 +++++++++ drivers/mtd/nand/nand_base.c | 2 +- drivers/mtd/nand/nand_util.c | 43 +++++++++++++++++++++++++++++++++++------ include/nand.h | 6 ++++- 5 files changed, 70 insertions(+), 10 deletions(-)
Replace an incorrect 'read' with 'write' in a comment.
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca Acked-by: Detlev Zundel dzu@denx.de
--- Changes since v2: * added Detlev's Acked-by Changes since v1: * rebased to HEAD of git://git.denx.de/u-boot-nand-flash.git : ff7b4a0 ("env_nand: zero-initialize variable nand_erase_options") --- drivers/mtd/nand/nand_base.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 52f8575..1a95a91 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -1950,7 +1950,7 @@ static int nand_write(struct mtd_info *mtd, loff_t to, size_t len, struct nand_chip *chip = mtd->priv; int ret;
- /* Do not allow reads past end of device */ + /* Do not allow writes past end of device */ if ((to + len) > mtd->size) return -EINVAL; if (!len)
Changes since v2:
- added Detlev's Acked-by
Changes since v1:
- rebased to HEAD of git://git.denx.de/u-boot-nand-flash.git : ff7b4a0 ("env_nand: zero-initialize variable nand_erase_options")
Applied to u-boot-nand-flash next
-Scott
In a future commit the behaviour of nand_write_skip_bad() will be further extended.
Convert the only flag currently passed to the nand_write_ skip_bad() function to a bitfield of only one allocated member. This should avoid an explosion of int's at the end of the parameter list or the ambiguous calls like
nand_write_skip_bad(info, offset, len, buf, 0, 1, 1); nand_write_skip_bad(info, offset, len, buf, 0, 1, 0);
Instead there will be:
nand_write_skip_bad(info, offset, len, buf, WITH_YAFFS_OOB | WITH_OTHER);
--- Changes since v2: * Added Detlev's Acked-by * removed the WITH_DEFAULTS flag -- zero is fine (Detlev Zundel) * fixed typo 'mmofying' to 'modifying' in comment Changes since v1: * rebased to HEAD of git://git.denx.de/u-boot-nand-flash.git : ff7b4a0 ("env_nand: zero-initialize variable nand_erase_options") * renamed the flag from WITH_OOB to WITH_YAFFS_OOB (Detlev Zundel) * introduce 'WITH_DEFAULTS' flag defined as 0 so as to convert also the remaining nand_write_skip_bad() call (Detlev Zundel) --- common/cmd_nand.c | 3 ++- drivers/mtd/nand/nand_util.c | 8 ++++---- include/nand.h | 5 ++++- 3 files changed, 10 insertions(+), 6 deletions(-)
diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 7bd37de..e7db4c9 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -581,7 +581,8 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) printf("Unknown nand command suffix '%s'.\n", s); return 1; } - ret = nand_write_skip_bad(nand, off, &rwsize, (u_char *)addr, 1); + ret = nand_write_skip_bad(nand, off, &rwsize, + (u_char *)addr, WITH_YAFFS_OOB); #endif } else if (!strcmp(s, ".oob")) { /* out-of-band data */ diff --git a/drivers/mtd/nand/nand_util.c b/drivers/mtd/nand/nand_util.c index 5a6f7ae..762ac53 100644 --- a/drivers/mtd/nand/nand_util.c +++ b/drivers/mtd/nand/nand_util.c @@ -448,11 +448,11 @@ static int check_skip_len(nand_info_t *nand, loff_t offset, size_t length) * @param offset offset in flash * @param length buffer length * @param buffer buffer to read from - * @param withoob whether write with yaffs format + * @param flags flags modifying the behaviour of the write to NAND * @return 0 in case of success */ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, - u_char *buffer, int withoob) + u_char *buffer, int flags) { int rval = 0, blocksize; size_t left_to_write = *length; @@ -460,7 +460,7 @@ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, int need_skip;
#ifdef CONFIG_CMD_NAND_YAFFS - if (withoob) { + if (flags & WITH_YAFFS_OOB) { int pages; pages = nand->erasesize / nand->writesize; blocksize = (pages * nand->oobsize) + nand->erasesize; @@ -529,7 +529,7 @@ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, write_size = blocksize - block_offset;
#ifdef CONFIG_CMD_NAND_YAFFS - if (withoob) { + if (flags & WITH_YAFFS_OOB) { int page, pages; size_t pagesize = nand->writesize; size_t pagesize_oob = pagesize + nand->oobsize; diff --git a/include/nand.h b/include/nand.h index 7459bd0..b0a31b8 100644 --- a/include/nand.h +++ b/include/nand.h @@ -114,8 +114,11 @@ typedef struct nand_erase_options nand_erase_options_t;
int nand_read_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, u_char *buffer); + +#define WITH_YAFFS_OOB (1 << 0) /* whether write with yaffs format */ + int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, - u_char *buffer, int withoob); + u_char *buffer, int flags); int nand_erase_opts(nand_info_t *meminfo, const nand_erase_options_t *opts);
#define NAND_LOCK_STATUS_TIGHT 0x01
Changes since v2:
- Added Detlev's Acked-by
- removed the WITH_DEFAULTS flag -- zero is fine (Detlev Zundel)
- fixed typo 'mmofying' to 'modifying' in comment
Changes since v1:
- renamed the flag from WITH_OOB to WITH_YAFFS_OOB (Detlev Zundel)
- introduce 'WITH_DEFAULTS' flag defined as 0 so as to convert also the remaining nand_write_skip_bad() call (Detlev Zundel)
-Scott
Add a flag to nand_read_skip_bad() such that if true, any trailing pages in an eraseblock whose contents are entirely 0xff will be dropped.
The implementation is via a new drop_ffs() function which is based on the function of the same name from the ubiformat utility by Artem Bityutskiy.
This is as-per the reccomendations of the UBI FAQ [1]
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Artem Bityutskiy dedekind1@gmail.com CC: Detlev Zundel dzu@denx.de
This behaviour was found to fix both UBI and JFFS2 images written to cleanly erased NAND partitions on da850evm.
Changes since v2: * moved the copyright header addition of nand_util to this patch from patch 'cmd_nand: add nand write.trimffs command' * Did not add Detlev's Acked-by because of movement of copyright header Changes since v1: * rebased to HEAD of git://git.denx.de/u-boot-nand-flash.git : ff7b4a0 ("env_nand: zero-initialize variable nand_erase_options") * wrap the new functionality in a CONFIG_CMD_NAND_TRIMFFS ifdef to reduce size impact of new feature --- drivers/mtd/nand/nand_util.c | 35 ++++++++++++++++++++++++++++++++--- include/nand.h | 1 + 2 files changed, 33 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/nand_util.c b/drivers/mtd/nand/nand_util.c index 762ac53..82b41a0 100644 --- a/drivers/mtd/nand/nand_util.c +++ b/drivers/mtd/nand/nand_util.c @@ -11,6 +11,9 @@ * nandwrite.c by Steven J. Hill (sjhill@realitydiluted.com) * and Thomas Gleixner (tglx@linutronix.de) * + * Copyright (C) 2008 Nokia Corporation: drop_ffs() function by + * Artem Bityutskiy dedekind1@gmail.com from mtd-utils + * * See file CREDITS for list of people who contributed to this * project. * @@ -436,6 +439,24 @@ static int check_skip_len(nand_info_t *nand, loff_t offset, size_t length) return ret; }
+#ifdef CONFIG_CMD_NAND_TRIMFFS +static size_t drop_ffs(const nand_info_t *nand, const u_char *buf, + const size_t *len) +{ + size_t i, l = *len; + + for (i = l - 1; i >= 0; i--) + if (((const uint8_t *)buf)[i] != 0xFF) + break; + + /* The resulting length must be aligned to the minimum flash I/O size */ + l = i + 1; + l = (l + nand->writesize - 1) / nand->writesize; + l *= nand->writesize; + return l; +} +#endif + /** * nand_write_skip_bad: * @@ -499,7 +520,7 @@ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, return -EINVAL; }
- if (!need_skip) { + if (!need_skip && !(flags & WITH_DROP_FFS)) { rval = nand_write (nand, offset, length, buffer); if (rval == 0) return 0; @@ -512,7 +533,7 @@ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length,
while (left_to_write > 0) { size_t block_offset = offset & (nand->erasesize - 1); - size_t write_size; + size_t write_size, truncated_write_size;
WATCHDOG_RESET ();
@@ -558,7 +579,15 @@ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, else #endif { - rval = nand_write (nand, offset, &write_size, p_buffer); + truncated_write_size = write_size; +#ifdef CONFIG_CMD_NAND_TRIMFFS + if (flags & WITH_DROP_FFS) + truncated_write_size = drop_ffs(nand, p_buffer, + &write_size); +#endif + + rval = nand_write(nand, offset, &truncated_write_size, + p_buffer); offset += write_size; p_buffer += write_size; } diff --git a/include/nand.h b/include/nand.h index b0a31b8..5c8a189 100644 --- a/include/nand.h +++ b/include/nand.h @@ -116,6 +116,7 @@ int nand_read_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, u_char *buffer);
#define WITH_YAFFS_OOB (1 << 0) /* whether write with yaffs format */ +#define WITH_DROP_FFS (1 << 1) /* drop trailing all-0xff pages */
int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, u_char *buffer, int flags);
Hi Ben,
Looks good -
Cheers Detlev
const size_t *len)
- size_t i, l = *len;
- for (i = l - 1; i >= 0; i--)
break;
This cast looks unnecessary.
- /* The resulting length must be aligned to the minimum flash I/O size */
- l = i + 1;
- l = (l + nand->writesize - 1) / nand->writesize;
- l *= nand->writesize;
- return l;
We allow unaligned lengths (the rest of the page gets padded with 0xff, see nand_do_page_write-ops). The input length might be unaligned -- this adjustment could cause you to read beyond the end of the supplied buffer.
+} +#endif
- nand_write_skip_bad:
- if (!need_skip) {
- if (!need_skip && !(flags & WITH_DROP_FFS)) { rval = nand_write (nand, offset, length, buffer); if (rval == 0) return 0;
Why not call drop_ffs before this point?
size_t write_size;
WATCHDOG_RESET ();
&write_size);
What if both WITH_DROP_FFS and WITH_YAFFS_OOB are specified?
-Scott
Hi Scott,
Thanks for the review.
- const size_t *len)
- if (((const uint8_t *)buf)[i] != 0xFF)
- break;
You're absolutely right. It will be gone in v4.
- l = i + 1;
- return l;
Right. Sorry I missed that. In v4 I will drop also any trailling 0xff which do not make-up a full page since they would be padded out to trailing 0xff.
+} +#endif
- if (!need_skip) {
To achieve the desired effect, drop_ffs must be called on each eraseblock sized chunk being written; so it seemed the simplest way was to force a block-by-block pass with the !WITH_DROP_FFS to enter
I'll leave this as-is in v4.
- size_t write_size, truncated_write_size;
WATCHDOG_RESET ();
- truncated_write_size = write_size;
- if (flags & WITH_DROP_FFS)
- truncated_write_size = drop_ffs(nand, p_buffer,
- &write_size);
I didn't plan for that or intend for it to be supported.
Previous to my introduction of WITH_DROP_FFS; using the YAFFS oob mode was mutually exclusive with the 'usual' way of writing. The introduction of WITH_DROP_FFs respects this precedent.
If both flags were set 1) cmd_nand.c would need to be changed ( :) ) and 2) the WITH_YAFFS_OOB behaviour would override.
In v4 I will add a -EINVAL if WITH_YAFFS_OOB flag is used with any other flag.
Best Regards, Ben Gardiner
--- Nanometrics Inc. http://www.nanometrics.ca
On Tue, 7 Jun 2011 09:09:07 -0400 Ben Gardiner bengardiner@nanometrics.ca wrote:
Ah, I missed that it was within each erase block.
OK, I just didn't want it silently ignored, with no documentation of the limitation.
-Scott
Changes since v3: * rebased to nand-flash/next where patches 1/4 and 2/4 [v3] were already applied * added patch 1/3 [v4] to treat WITH_YAFFS_OOB as a mode * renumbered 3/4 and 4/4 [v3] to 1/3 and 3/3 [v4], respectively * remove uneccessary cast * wrapped README at 80 columns * prevent access past input buffer end
Ben Gardiner (3): [v4] nand_util: treat WITH_YAFFS_OOB as a mode [v4] nand_util: drop trailing all-0xff pages if requested [v4] cmd_nand: add nand write.trimffs command
common/cmd_nand.c | 16 +++++++++++++++ doc/README.nand | 10 +++++++++ drivers/mtd/nand/nand_util.c | 43 +++++++++++++++++++++++++++++++++++++++-- include/nand.h | 5 +++- 4 files changed, 70 insertions(+), 4 deletions(-)
When specified in the flags argument of nand_write, WITH_YAFFS_OOB causes an operation which is mutually exclusive with the 'usual' way of writing.
Add a check that client code does not specify WITH_YAFFS_OOB along with any other flags and add a comment indicating that the WITH_YAFFS_OOB flag should not be mixed with other flags.
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Scott Wood scottwood@freescale.com
Changes since v3: * none. This patch was introduced in v4 to adress Scott Wood's v3 review comments.
--- drivers/mtd/nand/nand_util.c | 3 +++ include/nand.h | 4 +++- 2 files changed, 6 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/nand/nand_util.c b/drivers/mtd/nand/nand_util.c index 762ac53..e4ef858 100644 --- a/drivers/mtd/nand/nand_util.c +++ b/drivers/mtd/nand/nand_util.c @@ -461,6 +461,9 @@ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length,
#ifdef CONFIG_CMD_NAND_YAFFS if (flags & WITH_YAFFS_OOB) { + if (flags & ~WITH_YAFFS_OOB) + return -EINVAL; + int pages; pages = nand->erasesize / nand->writesize; blocksize = (pages * nand->oobsize) + nand->erasesize; diff --git a/include/nand.h b/include/nand.h index b0a31b8..c5818f1 100644 --- a/include/nand.h +++ b/include/nand.h @@ -115,7 +115,9 @@ typedef struct nand_erase_options nand_erase_options_t; int nand_read_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, u_char *buffer);
-#define WITH_YAFFS_OOB (1 << 0) /* whether write with yaffs format */ +#define WITH_YAFFS_OOB (1 << 0) /* whether write with yaffs format. This flag + * is a 'mode' meaning it cannot be mixed with + * other flags */
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Artem Bityutskiy dedekind1@gmail.com Acked-by: Detlev Zundel dzu@denx.de CC: Scott Wood scottwood@freescale.com
Scott,
I did not add your Acked-by because to handle the possible unaligned input length I opted to return min() instead of dropping the alignment fixup entire as had been agreed upon in correspondence. I found in testing that removing the alignment resulted in corruption of the NAND.
Changes since v3: * rebased onto nand-flash/next * remove uneccessary cast (Scott Wood) * added Detlev's Acked-by * prevent access past end of buffer using min() (Scott Wood) Changes since v2: * moved the copyright header addition of nand_util to this patch from patch 'cmd_nand: add nand write.trimffs command' * Did not add Detlev's Acked-by because of movement of copyright header Changes since v1: * rebased to HEAD of git://git.denx.de/u-boot-nand-flash.git : ff7b4a0 ("env_nand: zero-initialize variable nand_erase_options") * wrap the new functionality in a CONFIG_CMD_NAND_TRIMFFS ifdef to reduce size impact of new feature
--- drivers/mtd/nand/nand_util.c | 40 +++++++++++++++++++++++++++++++++++++--- include/nand.h | 1 + 2 files changed, 38 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/nand_util.c b/drivers/mtd/nand/nand_util.c index e4ef858..81bf366 100644 --- a/drivers/mtd/nand/nand_util.c +++ b/drivers/mtd/nand/nand_util.c @@ -11,6 +11,9 @@ * nandwrite.c by Steven J. Hill (sjhill@realitydiluted.com) * and Thomas Gleixner (tglx@linutronix.de) * + * Copyright (C) 2008 Nokia Corporation: drop_ffs() function by + * Artem Bityutskiy dedekind1@gmail.com from mtd-utils + * * See file CREDITS for list of people who contributed to this * project. * @@ -436,6 +439,29 @@ static int check_skip_len(nand_info_t *nand, loff_t offset, size_t length) return ret; }
+#ifdef CONFIG_CMD_NAND_TRIMFFS +static size_t drop_ffs(const nand_info_t *nand, const u_char *buf, + const size_t *len) +{ + size_t i, l = *len; + + for (i = l - 1; i >= 0; i--) + if (buf[i] != 0xFF) + break; + + /* The resulting length must be aligned to the minimum flash I/O size */ + l = i + 1; + l = (l + nand->writesize - 1) / nand->writesize; + l *= nand->writesize; + + /* + * since the input length may be unaligned, prevent access past the end + * of the buffer + */ + return min(l, *len); +} +#endif + /** * nand_write_skip_bad: * @@ -502,7 +528,7 @@ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, return -EINVAL; }
- if (!need_skip) { + if (!need_skip && !(flags & WITH_DROP_FFS)) { rval = nand_write (nand, offset, length, buffer); if (rval == 0) return 0; @@ -515,7 +541,7 @@ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length,
WATCHDOG_RESET ();
@@ -561,7 +587,15 @@ int nand_write_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, else #endif { - rval = nand_write (nand, offset, &write_size, p_buffer); + truncated_write_size = write_size; +#ifdef CONFIG_CMD_NAND_TRIMFFS + if (flags & WITH_DROP_FFS) + truncated_write_size = drop_ffs(nand, p_buffer, + &write_size); +#endif + + rval = nand_write(nand, offset, &truncated_write_size, + p_buffer); offset += write_size; p_buffer += write_size; } diff --git a/include/nand.h b/include/nand.h index c5818f1..8d94b5c 100644 --- a/include/nand.h +++ b/include/nand.h @@ -118,6 +118,7 @@ int nand_read_skip_bad(nand_info_t *nand, loff_t offset, size_t *length, #define WITH_YAFFS_OOB (1 << 0) /* whether write with yaffs format. This flag * is a 'mode' meaning it cannot be mixed with * other flags */ +#define WITH_DROP_FFS (1 << 1) /* drop trailing all-0xff pages */
Add another nand write. variant, trimffs. This command will request of nand_write_skip_bad() that all trailing all-0xff pages will be dropped from eraseblocks when they are written to flash as-per the reccommended behaviour of the UBI FAQ [1].
The function that implements this timming is the drop_ffs() function by Artem Bityutskiy, ported from the mtd-utils tree.
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Artem Bityutskiy dedekind1@gmail.com CC: Detlev Zundel dzu@denx.de Acked-by: Scott Wood scottwood@freescale.com
Changes since v3: * rebased to nand-flash/next * wrap README at 80 columns including EOL (Scott Wood) Changes since v2: * added nand write.trimffs to the README.nand file * moved the nand_util copyright header addition to patch 'nand_util: drop trailing all-0xff pages if requested' Changes since v1: * rebased to HEAD of git://git.denx.de/u-boot-nand-flash.git : ff7b4a0 ("env_nand: zero-initialize variable nand_erase_options") * renamed the command variant to '.trimffs' from '.ubi' (Detlev Zundel) * added attribution to mtd-utils and Artem Bityutskiy in both the source comments and commit message * wrapped the new command in a new ifdef, CONFIG_CMD_NAND_TRIMFFS, to reduce the size impact of this new feature
--- common/cmd_nand.c | 16 ++++++++++++++++ doc/README.nand | 10 ++++++++++ 2 files changed, 26 insertions(+), 0 deletions(-)
diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 27a8879..b767cd2 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -575,6 +575,16 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) else ret = nand_write_skip_bad(nand, off, &rwsize, (u_char *)addr, 0); +#ifdef CONFIG_CMD_NAND_TRIMFFS + } else if (!strcmp(s, ".trimffs")) { + if (read) { + printf("Unknown nand command suffix '%s'\n", s); + return 1; + } + ret = nand_write_skip_bad(nand, off, &rwsize, + (u_char *)addr, + WITH_DROP_FFS); +#endif #ifdef CONFIG_CMD_NAND_YAFFS } else if (!strcmp(s, ".yaffs")) { if (read) { @@ -689,6 +699,12 @@ U_BOOT_CMD( "nand write - addr off|partition size\n" " read/write 'size' bytes starting at offset 'off'\n" " to/from memory address 'addr', skipping bad blocks.\n" +#ifdef CONFIG_CMD_NAND_TRIMFFS + "nand write.trimffs - addr off|partition size\n" + " write 'size' bytes starting at offset 'off' from memory address\n" + " 'addr', skipping bad blocks and dropping any pages at the end\n" + " of eraseblocks that contain only 0xFF\n" +#endif #ifdef CONFIG_CMD_NAND_YAFFS "nand write.yaffs - addr off|partition size\n" " write 'size' bytes starting at offset 'off' with yaffs format\n" diff --git a/doc/README.nand b/doc/README.nand index 8eedb6c..751b693 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -78,6 +78,16 @@ Commands: should work well, but loading an image copied from another flash is going to be trouble if there are any bad blocks.
+ nand write.trimffs addr ofs|partition size + Enabled by the CONFIG_CMD_NAND_TRIMFFS macro. This command will write to + the NAND flash in a manner identical to the 'nand write' command + described above -- with the additional check that all pages at the end + of eraseblocks which contain only 0xff data will not be written to the + NAND flash. This behaviour is required when flashing UBI images + containing UBIFS volumes as per the UBI FAQ[1]. + + [1] http://www.linux-mtd.infradead.org/doc/ubi.html#L_flasher_algo + nand write.oob addr ofs|partition size Write `size' bytes from `addr' to the out-of-band data area corresponding to `ofs' in NAND flash. This is limited to the 16 bytes
Changes since v3:
- rebased to nand-flash/next where patches 1/4 and 2/4 [v3] were already applied
- added patch 1/3 [v4] to treat WITH_YAFFS_OOB as a mode
- renumbered 3/4 and 4/4 [v3] to 1/3 and 3/3 [v4], respectively
- remove uneccessary cast
- wrapped README at 80 columns
- prevent access past input buffer end
-Scott
Changes since v2: * added nand write.trimffs to the README.nand file * moved the nand_util copyright header addition to patch 'nand_util: drop trailing all-0xff pages if requested' Changes since v1: * rebased to HEAD of git://git.denx.de/u-boot-nand-flash.git : ff7b4a0 ("env_nand: zero-initialize variable nand_erase_options") * renamed the command variant to '.trimffs' from '.ubi' (Detlev Zundel) * added attribution to mtd-utils and Artem Bityutskiy in both the source comments and commit message * wrapped the new command in a new ifdef, CONFIG_CMD_NAND_TRIMFFS, to reduce the size impact of this new feature --- common/cmd_nand.c | 16 ++++++++++++++++ doc/README.nand | 10 ++++++++++ 2 files changed, 26 insertions(+), 0 deletions(-)
diff --git a/common/cmd_nand.c b/common/cmd_nand.c index e7db4c9..786f179 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -575,6 +575,16 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) else ret = nand_write_skip_bad(nand, off, &rwsize, (u_char *)addr, 0); +#ifdef CONFIG_CMD_NAND_TRIMFFS + } else if (!strcmp(s, ".trimffs")) { + if (read) { + printf("Unknown nand command suffix '%s'\n", s); + return 1; + } + ret = nand_write_skip_bad(nand, off, &rwsize, + (u_char *)addr, + WITH_DROP_FFS); +#endif #ifdef CONFIG_CMD_NAND_YAFFS } else if (!strcmp(s, ".yaffs")) { if (read) { @@ -689,6 +699,12 @@ U_BOOT_CMD( "nand write - addr off|partition size\n" " read/write 'size' bytes starting at offset 'off'\n" " to/from memory address 'addr', skipping bad blocks.\n" +#ifdef CONFIG_CMD_NAND_TRIMFFS + "nand write.trimffs - addr off|partition size\n" + " write 'size' bytes starting at offset 'off' from memory address\n" + " 'addr', skipping bad blocks and dropping any pages at the end\n" + " of eraseblocks that contain only 0xFF\n" +#endif #ifdef CONFIG_CMD_NAND_YAFFS "nand write.yaffs - addr off|partition size\n" " write 'size' bytes starting at offset 'off' with yaffs format\n" diff --git a/doc/README.nand b/doc/README.nand index 8eedb6c..ca62f00 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -78,6 +78,16 @@ Commands: should work well, but loading an image copied from another flash is going to be trouble if there are any bad blocks.
+ nand write.trimffs addr ofs|partition size + Enabled by the CONFIG_CMD_NAND_TRIMFFS macro. This command will write to + the NAND flash in a manner identical to the 'nand write' command described + above -- with the additional check that all pages at the end of + eraseblocks which contain only 0xff data will not be written to the NAND + flash. This behaviour is required when flashing UBI images containing + UBIFS volumes as per the UBI FAQ[1]. + + [1] http://www.linux-mtd.infradead.org/doc/ubi.html#L_flasher_algo + nand write.oob addr ofs|partition size Write `size' bytes from `addr' to the out-of-band data area corresponding to `ofs' in NAND flash. This is limited to the 16 bytes
Hi Ben,
Thanks - looks good now.
Cheers Detlev
if (read) {
return 1;
(u_char *)addr,
WITH_DROP_FFS);
Should these really be modes rather than flags?
- nand write.trimffs addr ofs|partition size
Please wrap at 80 columns.
-Scott
Hi Scott,
Thanks for the reviews.
- } else if (!strcmp(s, ".trimffs")) {
- if (read) {
- printf("Unknown nand command suffix '%s'\n", s);
- return 1;
- (u_char *)addr,
- WITH_DROP_FFS);
For the two currently possible values of 'int flags' -- yes. But that's because the WITH_YAFFS_OOB causes a specific exuction path which is mutually exclusive to the usual path; whereas the WITH_DROP_FFS option does an operation in addition to the usual execution. So the latter is (to me at least) a flag whereas the former is a mode.
I see you have already applied the patches which convert to a flag -- so I will leave as is in v4. I will, as noted in the previous email -- add a return -EINVAL if WITH_YAFFS_OOB is used with any other flags.
- Enabled by the CONFIG_CMD_NAND_TRIMFFS macro. This command will write to
- the NAND flash in a manner identical to the 'nand write' command described
- above -- with the additional check that all pages at the end of
- eraseblocks which contain only 0xff data will not be written to the NAND
- flash. This behaviour is required when flashing UBI images containing
- UBIFS volumes as per the UBI FAQ[1].
Ok. Will do in v4.
checkpatch.pl did not complain about " the NAND flash in a manner identical to the 'nand write' command described" -- which is 81 characters including the \n but it did not complain about a line over 85 characters in that README either so I guess READMEs aren't enforced by that script.
Ben Gardiner
Detlev Zundel
Scott Wood
