[U-Boot] [PATCH 0/1] arm/mach-types: sync with 2.6.28 and add generating tools support
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
diff --git a/Makefile b/Makefile index d533564..a5af22f 100644 --- a/Makefile +++ b/Makefile @@ -194,6 +194,10 @@ include $(TOPDIR)/config.mk ######################################################################### # U-Boot objects....order is important (i.e. start must be first)
+ifeq ($(ARCH),arm) +MACH_H = $(obj)include/asm-arm/mach-types.h +endif + OBJS = cpu/$(CPU)/start.o ifeq ($(CPU),i386) OBJS += cpu/$(CPU)/start16.o @@ -360,13 +364,13 @@ $(SUBDIRS): depend $(obj)include/autoconf.mk $(LDSCRIPT): depend $(obj)include/autoconf.mk $(MAKE) -C $(dir $@) $(notdir $@)
-$(NAND_SPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk +$(NAND_SPL): $(MACH_H) $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk $(MAKE) -C nand_spl/board/$(BOARDDIR) all
$(U_BOOT_NAND): $(NAND_SPL) $(obj)u-boot.bin $(obj)include/autoconf.mk cat $(obj)nand_spl/u-boot-spl-16k.bin $(obj)u-boot.bin > $(obj)u-boot-nand.bin
-$(ONENAND_IPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk +$(ONENAND_IPL): $(MACH_H) $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk $(MAKE) -C onenand_ipl/board/$(BOARDDIR) all
$(U_BOOT_ONENAND): $(ONENAND_IPL) $(obj)u-boot.bin $(obj)include/autoconf.mk @@ -382,6 +386,9 @@ $(TIMESTAMP_FILE): @date +'#define U_BOOT_DATE "%b %d %C%y"' > $@ @date +'#define U_BOOT_TIME "%T"' >> $@
+$(obj)include/asm-arm/mach-types.h: + $(MAKE) -C tools/arm $@ + gdbtools: $(MAKE) -C tools/gdb all || exit 1
@@ -391,7 +398,7 @@ updater: env: $(MAKE) -C tools/env all MTD_VERSION=${MTD_VERSION} || exit 1
-depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) +depend dep: $(MACH_H) $(TIMESTAMP_FILE) $(VERSION_FILE) for dir in $(SUBDIRS) ; do $(MAKE) -C $$dir _depend ; done
TAG_SUBDIRS += include @@ -453,14 +460,14 @@ $(obj)System.map: $(obj)u-boot # This target actually generates 2 files; autoconf.mk and autoconf.mk.dep. # the dep file is only include in this top level makefile to determine when # to regenerate the autoconf.mk file. -$(obj)include/autoconf.mk.dep: $(obj)include/config.h include/common.h +$(obj)include/autoconf.mk.dep: $(obj)include/config.h $(MACH_H) include/common.h @$(XECHO) Generating $@ ; \ set -e ; \ : Generate the dependancies ; \ $(CC) -x c -DDO_DEPS_ONLY -M $(HOST_CFLAGS) $(CPPFLAGS) \ -MQ $(obj)include/autoconf.mk include/common.h > $@
-$(obj)include/autoconf.mk: $(obj)include/config.h +$(obj)include/autoconf.mk: $(obj)include/config.h $(MACH_H) @$(XECHO) Generating $@ ; \ set -e ; \ : Extract the config macros ; \ @@ -3335,7 +3342,8 @@ clean: $(obj)examples/mem_to_mem_idma2intr \ $(obj)examples/sched $(obj)examples/smc91111_eeprom \ $(obj)examples/test_burst $(obj)examples/timer - @rm -f $(obj)tools/bmp_logo $(obj)tools/easylogo/easylogo \ + @rm -f $(obj)include/asm-arm/mach-types.h \ + $(obj)tools/bmp_logo $(obj)tools/easylogo/easylogo \ $(obj)tools/env/{fw_printenv,fw_setenv} \ $(obj)tools/envcrc \ $(obj)tools/gdb/{astest,gdbcont,gdbsend} \ diff --git a/config.mk b/config.mk index b1254e9..76e8844 100644 --- a/config.mk +++ b/config.mk @@ -76,6 +76,7 @@ STRIP = $(CROSS_COMPILE)strip OBJCOPY = $(CROSS_COMPILE)objcopy OBJDUMP = $(CROSS_COMPILE)objdump RANLIB = $(CROSS_COMPILE)RANLIB +AWK = awk
diff --git a/include/asm-arm/.gitignore b/include/asm-arm/.gitignore new file mode 100644 index 0000000..9cc4155 --- /dev/null +++ b/include/asm-arm/.gitignore @@ -0,0 +1 @@ +/mach-types.h diff --git a/include/asm-arm/mach-types.h b/include/asm-arm/mach-types.h deleted file mode 100644 index ce6d25f..0000000 --- a/include/asm-arm/mach-types.h +++ /dev/null @@ -1,24009 +0,0 @@ -/* - * This was automagically generated from arch/arm/tools/mach-types! -# define machine_is_at91sam9260ek_cn() (0) -#endif - -# define machine_is_em104v1() (machine_arch_type == MACH_TYPE_EM104V1) -#else -# define machine_is_em104v1() (0) -#endif -
-# endif -# define machine_is_geneva() (machine_arch_type == MACH_TYPE_GENEVA) -#else -# define machine_is_geneva() (0) -#endif - -/* - * These have not yet been registered - */ - -#ifndef machine_arch_type -#define machine_arch_type __machine_arch_type -#endif - -#endif diff --git a/tools/arm/Makefile b/tools/arm/Makefile new file mode 100644 index 0000000..dacf533 --- /dev/null +++ b/tools/arm/Makefile @@ -0,0 +1,40 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +all: $(obj).depend + +$(OBJTREE)/include/asm-arm/mach-types.h: gen-mach-types mach-types + @echo ' Generating $@' + @mkdir -p $(dir $@) + @$(AWK) -f $^ > $@ || { rm -f $@; /bin/false; } + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/tools/arm/gen-mach-types b/tools/arm/gen-mach-types new file mode 100644 index 0000000..ce319ef --- /dev/null +++ b/tools/arm/gen-mach-types @@ -0,0 +1,72 @@ +#!/bin/awk +# +# Awk script to generate include/asm-arm/mach-types.h +# +BEGIN { nr = 0 } +/^#/ { next } +/^[ ]*$/ { next } + +NF == 4 { + machine_is[nr] = "machine_is_"$1; + config[nr] = "CONFIG_"$2; + mach_type[nr] = "MACH_TYPE_"$3; + num[nr] = $4; nr++ + } + +NF == 3 { + machine_is[nr] = "machine_is_"$1; + config[nr] = "CONFIG_"$2; + mach_type[nr] = "MACH_TYPE_"$3; + num[nr] = ""; nr++ + } + + +END { + printf("/*\n"); + printf(" * This was automagically generated from %s!\n", FILENAME); + printf(" * Do NOT edit\n"); + printf(" */\n\n"); + printf("#ifndef __ASM_ARM_MACH_TYPE_H\n"); + printf("#define __ASM_ARM_MACH_TYPE_H\n\n"); + printf("#ifndef __ASSEMBLY__\n"); + printf("/* The type of machine we're running on */\n"); + printf("extern unsigned int __machine_arch_type;\n"); + printf("#endif\n\n"); + + printf("/* see arch/arm/kernel/arch.c for a description of these */\n"); + for (i = 0; i < nr; i++) + if (num[i] ~ /..*/) + printf("#define %-30s %d\n", mach_type[i], num[i]); + + printf("\n"); + + for (i = 0; i < nr; i++) + if (num[i] ~ /..*/) { + printf("#ifdef %s\n", config[i]); + printf("# ifdef machine_arch_type\n"); + printf("# undef machine_arch_type\n"); + printf("# define machine_arch_type\t__machine_arch_type\n"); + printf("# else\n"); + printf("# define machine_arch_type\t%s\n", mach_type[i]); + printf("# endif\n"); + printf("# define %s()\t(machine_arch_type == %s)\n", machine_is[i], mach_type[i]); + printf("#else\n"); + printf("# define %s()\t(0)\n", machine_is[i]); + printf("#endif\n\n"); + } + + printf("/*\n * These have not yet been registered\n */\n"); + for (i = 0; i < nr; i++) + if (num[i] !~ /..*/) + printf("/* #define %-30s <<not registered>> */\n", mach_type[i]); + + for (i = 0; i < nr; i++) + if (num[i] !~ /..*/) { + printf("#define %s()\t(0)\n", machine_is[i]); + } + + printf("\n#ifndef machine_arch_type\n"); + printf("#define machine_arch_type\t__machine_arch_type\n"); + printf("#endif\n\n"); + printf("#endif\n"); + } diff --git a/tools/arm/mach-types b/tools/arm/mach-types new file mode 100644 index 0000000..43aa202 --- /dev/null +++ b/tools/arm/mach-types @@ -0,0 +1,1901 @@ +# Database of machine macros and numbers +# +# This file is linux/arch/arm/tools/mach-types +# +# Up to date versions of this file can be obtained from: +# +# http://www.arm.linux.org.uk/developer/machines/download.php +# +# Please do not send patches to this file; it is automatically generated! +# To add an entry into this database, please see Documentation/arm/README, +# or visit: +# +# http://www.arm.linux.org.uk/developer/machines/?action=new +# +# Last update: Thu Sep 25 10:10:50 2008 +# +# machine_is_xxx CONFIG_xxxx MACH_TYPE_xxx number +# +ebsa110 ARCH_EBSA110 EBSA110 0 +riscpc ARCH_RPC RISCPC 1 +nexuspci ARCH_NEXUSPCI NEXUSPCI 3 +ebsa285 ARCH_EBSA285 EBSA285 4 +netwinder ARCH_NETWINDER NETWINDER 5 +cats ARCH_CATS CATS 6 +tbox ARCH_TBOX TBOX 7 +co285 ARCH_CO285 CO285 8 +clps7110 ARCH_CLPS7110 CLPS7110 9 +archimedes ARCH_ARC ARCHIMEDES 10 +a5k ARCH_A5K A5K 11 +etoile ARCH_ETOILE ETOILE 12 +lacie_nas ARCH_LACIE_NAS LACIE_NAS 13 +clps7500 ARCH_CLPS7500 CLPS7500 14 +shark ARCH_SHARK SHARK 15 +brutus SA1100_BRUTUS BRUTUS 16 +personal_server ARCH_PERSONAL_SERVER PERSONAL_SERVER 17 +itsy SA1100_ITSY ITSY 18 +l7200 ARCH_L7200 L7200 19 +pleb SA1100_PLEB PLEB 20 +integrator ARCH_INTEGRATOR INTEGRATOR 21 +h3600 SA1100_H3600 H3600 22 +ixp1200 ARCH_IXP1200 IXP1200 23 +p720t ARCH_P720T P720T 24 +assabet SA1100_ASSABET ASSABET 25 +victor SA1100_VICTOR VICTOR 26 +lart SA1100_LART LART 27 +ranger SA1100_RANGER RANGER 28 +graphicsclient SA1100_GRAPHICSCLIENT GRAPHICSCLIENT 29 +xp860 SA1100_XP860 XP860 30 +cerf SA1100_CERF CERF 31 +nanoengine SA1100_NANOENGINE NANOENGINE 32 +fpic SA1100_FPIC FPIC 33 +extenex1 SA1100_EXTENEX1 EXTENEX1 34 +sherman SA1100_SHERMAN SHERMAN 35 +accelent_sa SA1100_ACCELENT ACCELENT_SA 36 +accelent_l7200 ARCH_L7200_ACCELENT ACCELENT_L7200 37 +netport SA1100_NETPORT NETPORT 38 +pangolin SA1100_PANGOLIN PANGOLIN 39 +yopy SA1100_YOPY YOPY 40 +coolidge SA1100_COOLIDGE COOLIDGE 41 +huw_webpanel SA1100_HUW_WEBPANEL HUW_WEBPANEL 42 +spotme ARCH_SPOTME SPOTME 43 +freebird ARCH_FREEBIRD FREEBIRD 44 +ti925 ARCH_TI925 TI925 45 +riscstation ARCH_RISCSTATION RISCSTATION 46 +cavy SA1100_CAVY CAVY 47 +jornada720 SA1100_JORNADA720 JORNADA720 48 +omnimeter SA1100_OMNIMETER OMNIMETER 49 +edb7211 ARCH_EDB7211 EDB7211 50 +citygo SA1100_CITYGO CITYGO 51 +pfs168 SA1100_PFS168 PFS168 52 +spot SA1100_SPOT SPOT 53 +flexanet SA1100_FLEXANET FLEXANET 54 +webpal ARCH_WEBPAL WEBPAL 55 +linpda SA1100_LINPDA LINPDA 56 +anakin ARCH_ANAKIN ANAKIN 57 +mvi SA1100_MVI MVI 58 +jupiter SA1100_JUPITER JUPITER 59 +psionw ARCH_PSIONW PSIONW 60 +aln SA1100_ALN ALN 61 +epxa ARCH_CAMELOT CAMELOT 62 +gds2200 SA1100_GDS2200 GDS2200 63 +netbook SA1100_PSION_SERIES7 PSION_SERIES7 64 +xfile SA1100_XFILE XFILE 65 +accelent_ep9312 ARCH_ACCELENT_EP9312 ACCELENT_EP9312 66 +ic200 ARCH_IC200 IC200 67 +creditlart SA1100_CREDITLART CREDITLART 68 +htm SA1100_HTM HTM 69 +iq80310 ARCH_IQ80310 IQ80310 70 +freebot SA1100_FREEBOT FREEBOT 71 +entel ARCH_ENTEL ENTEL 72 +enp3510 ARCH_ENP3510 ENP3510 73 +trizeps SA1100_TRIZEPS TRIZEPS 74 +nesa SA1100_NESA NESA 75 +venus ARCH_VENUS VENUS 76 +tardis ARCH_TARDIS TARDIS 77 +mercury ARCH_MERCURY MERCURY 78 +empeg SA1100_EMPEG EMPEG 79 +adi_evb ARCH_I80200FCC I80200FCC 80 +itt_cpb SA1100_ITT_CPB ITT_CPB 81 +svc SA1100_SVC SVC 82 +alpha2 SA1100_ALPHA2 ALPHA2 84 +alpha1 SA1100_ALPHA1 ALPHA1 85 +netarm ARCH_NETARM NETARM 86 +simpad SA1100_SIMPAD SIMPAD 87 +pda1 ARCH_PDA1 PDA1 88 +lubbock ARCH_LUBBOCK LUBBOCK 89 +aniko ARCH_ANIKO ANIKO 90 +clep7212 ARCH_CLEP7212 CLEP7212 91 +cs89712 ARCH_CS89712 CS89712 92 +weararm SA1100_WEARARM WEARARM 93 +possio_px SA1100_POSSIO_PX POSSIO_PX 94 +sidearm SA1100_SIDEARM SIDEARM 95 +stork SA1100_STORK STORK 96 +shannon SA1100_SHANNON SHANNON 97 +ace ARCH_ACE ACE 98 +ballyarm SA1100_BALLYARM BALLYARM 99 +simputer SA1100_SIMPUTER SIMPUTER 100 +nexterm SA1100_NEXTERM NEXTERM 101 +sa1100_elf SA1100_SA1100_ELF SA1100_ELF 102 +gator SA1100_GATOR GATOR 103 +granite ARCH_GRANITE GRANITE 104 +consus SA1100_CONSUS CONSUS 105 +aaed2000 ARCH_AAED2000 AAED2000 106 +cdb89712 ARCH_CDB89712 CDB89712 107 +graphicsmaster SA1100_GRAPHICSMASTER GRAPHICSMASTER 108 +adsbitsy SA1100_ADSBITSY ADSBITSY 109 +pxa_idp ARCH_PXA_IDP PXA_IDP 110 +plce ARCH_PLCE PLCE 111 +pt_system3 SA1100_PT_SYSTEM3 PT_SYSTEM3 112 +murphy ARCH_MEDALB MEDALB 113 +eagle ARCH_EAGLE EAGLE 114 +dsc21 ARCH_DSC21 DSC21 115 +dsc24 ARCH_DSC24 DSC24 116 +ti5472 ARCH_TI5472 TI5472 117 +autcpu12 ARCH_AUTCPU12 AUTCPU12 118 +uengine ARCH_UENGINE UENGINE 119 +bluestem SA1100_BLUESTEM BLUESTEM 120 +xingu8 ARCH_XINGU8 XINGU8 121 +bushstb ARCH_BUSHSTB BUSHSTB 122 +epsilon1 SA1100_EPSILON1 EPSILON1 123 +balloon SA1100_BALLOON BALLOON 124 +puppy ARCH_PUPPY PUPPY 125 +elroy SA1100_ELROY ELROY 126 +gms720 ARCH_GMS720 GMS720 127 +s24x ARCH_S24X S24X 128 +jtel_clep7312 ARCH_JTEL_CLEP7312 JTEL_CLEP7312 129 +cx821xx ARCH_CX821XX CX821XX 130 +edb7312 ARCH_EDB7312 EDB7312 131 +bsa1110 SA1100_BSA1110 BSA1110 132 +powerpin ARCH_POWERPIN POWERPIN 133 +openarm ARCH_OPENARM OPENARM 134 +whitechapel SA1100_WHITECHAPEL WHITECHAPEL 135 +h3100 SA1100_H3100 H3100 136 +h3800 SA1100_H3800 H3800 137 +blue_v1 ARCH_BLUE_V1 BLUE_V1 138 +pxa_cerf ARCH_PXA_CERF PXA_CERF 139 +arm7tevb ARCH_ARM7TEVB ARM7TEVB 140 +d7400 SA1100_D7400 D7400 141 +piranha ARCH_PIRANHA PIRANHA 142 +sbcamelot SA1100_SBCAMELOT SBCAMELOT 143 +kings SA1100_KINGS KINGS 144 +smdk2400 ARCH_SMDK2400 SMDK2400 145 +collie SA1100_COLLIE COLLIE 146 +idr ARCH_IDR IDR 147 +badge4 SA1100_BADGE4 BADGE4 148 +webnet ARCH_WEBNET WEBNET 149 +d7300 SA1100_D7300 D7300 150 +cep SA1100_CEP CEP 151 +fortunet ARCH_FORTUNET FORTUNET 152 +vc547x ARCH_VC547X VC547X 153 +filewalker SA1100_FILEWALKER FILEWALKER 154 +netgateway SA1100_NETGATEWAY NETGATEWAY 155 +symbol2800 SA1100_SYMBOL2800 SYMBOL2800 156 +suns SA1100_SUNS SUNS 157 +frodo SA1100_FRODO FRODO 158 +ms301 SA1100_MACH_TYTE_MS301 MACH_TYTE_MS301 159 +mx1ads ARCH_MX1ADS MX1ADS 160 +h7201 ARCH_H7201 H7201 161 +h7202 ARCH_H7202 H7202 162 +amico ARCH_AMICO AMICO 163 +iam SA1100_IAM IAM 164 +tt530 SA1100_TT530 TT530 165 +sam2400 ARCH_SAM2400 SAM2400 166 +jornada56x SA1100_JORNADA56X JORNADA56X 167 +active SA1100_ACTIVE ACTIVE 168 +iq80321 ARCH_IQ80321 IQ80321 169 +wid SA1100_WID WID 170 +sabinal ARCH_SABINAL SABINAL 171 +ixp425_matacumbe ARCH_IXP425_MATACUMBE IXP425_MATACUMBE 172 +miniprint SA1100_MINIPRINT MINIPRINT 173 +adm510x ARCH_ADM510X ADM510X 174 +svs200 SA1100_SVS200 SVS200 175 +atg_tcu ARCH_ATG_TCU ATG_TCU 176 +jornada820 SA1100_JORNADA820 JORNADA820 177 +s3c44b0 ARCH_S3C44B0 S3C44B0 178 +margis2 ARCH_MARGIS2 MARGIS2 179 +ks8695 ARCH_KS8695 KS8695 180 +brh ARCH_BRH BRH 181 +s3c2410 ARCH_S3C2410 S3C2410 182 +possio_px30 ARCH_POSSIO_PX30 POSSIO_PX30 183 +s3c2800 ARCH_S3C2800 S3C2800 184 +fleetwood SA1100_FLEETWOOD FLEETWOOD 185 +omaha ARCH_OMAHA OMAHA 186 +ta7 ARCH_TA7 TA7 187 +nova SA1100_NOVA NOVA 188 +hmk ARCH_HMK HMK 189 +karo ARCH_KARO KARO 190 +fester SA1100_FESTER FESTER 191 +gpi ARCH_GPI GPI 192 +smdk2410 ARCH_SMDK2410 SMDK2410 193 +i519 ARCH_I519 I519 194 +nexio SA1100_NEXIO NEXIO 195 +bitbox SA1100_BITBOX BITBOX 196 +g200 SA1100_G200 G200 197 +gill SA1100_GILL GILL 198 +pxa_mercury ARCH_PXA_MERCURY PXA_MERCURY 199 +ceiva ARCH_CEIVA CEIVA 200 +fret SA1100_FRET FRET 201 +emailphone SA1100_EMAILPHONE EMAILPHONE 202 +h3900 ARCH_H3900 H3900 203 +pxa1 ARCH_PXA1 PXA1 204 +koan369 SA1100_KOAN369 KOAN369 205 +cogent ARCH_COGENT COGENT 206 +esl_simputer ARCH_ESL_SIMPUTER ESL_SIMPUTER 207 +esl_simputer_clr ARCH_ESL_SIMPUTER_CLR ESL_SIMPUTER_CLR 208 +esl_simputer_bw ARCH_ESL_SIMPUTER_BW ESL_SIMPUTER_BW 209 +hhp_cradle ARCH_HHP_CRADLE HHP_CRADLE 210 +he500 ARCH_HE500 HE500 211 +inhandelf2 SA1100_INHANDELF2 INHANDELF2 212 +inhandftip SA1100_INHANDFTIP INHANDFTIP 213 +dnp1110 SA1100_DNP1110 DNP1110 214 +pnp1110 SA1100_PNP1110 PNP1110 215 +csb226 ARCH_CSB226 CSB226 216 +arnold SA1100_ARNOLD ARNOLD 217 +voiceblue MACH_VOICEBLUE VOICEBLUE 218 +jz8028 ARCH_JZ8028 JZ8028 219 +h5400 ARCH_H5400 H5400 220 +forte SA1100_FORTE FORTE 221 +acam SA1100_ACAM ACAM 222 +abox SA1100_ABOX ABOX 223 +atmel ARCH_ATMEL ATMEL 224 +sitsang ARCH_SITSANG SITSANG 225 +cpu1110lcdnet SA1100_CPU1110LCDNET CPU1110LCDNET 226 +mpl_vcma9 ARCH_MPL_VCMA9 MPL_VCMA9 227 +opus_a1 ARCH_OPUS_A1 OPUS_A1 228 +daytona ARCH_DAYTONA DAYTONA 229 +killbear SA1100_KILLBEAR KILLBEAR 230 +yoho ARCH_YOHO YOHO 231 +jasper ARCH_JASPER JASPER 232 +dsc25 ARCH_DSC25 DSC25 233 +omap_innovator MACH_OMAP_INNOVATOR OMAP_INNOVATOR 234 +mnci ARCH_RAMSES RAMSES 235 +s28x ARCH_S28X S28X 236 +mport3 ARCH_MPORT3 MPORT3 237 +pxa_eagle250 ARCH_PXA_EAGLE250 PXA_EAGLE250 238 +pdb ARCH_PDB PDB 239 +blue_2g SA1100_BLUE_2G BLUE_2G 240 +bluearch SA1100_BLUEARCH BLUEARCH 241 +ixdp2400 ARCH_IXDP2400 IXDP2400 242 +ixdp2800 ARCH_IXDP2800 IXDP2800 243 +explorer SA1100_EXPLORER EXPLORER 244 +ixdp425 ARCH_IXDP425 IXDP425 245 +chimp ARCH_CHIMP CHIMP 246 +stork_nest ARCH_STORK_NEST STORK_NEST 247 +stork_egg ARCH_STORK_EGG STORK_EGG 248 +wismo SA1100_WISMO WISMO 249 +ezlinx ARCH_EZLINX EZLINX 250 +at91rm9200 ARCH_AT91RM9200 AT91RM9200 251 +adtech_orion ARCH_ADTECH_ORION ADTECH_ORION 252 +neptune ARCH_NEPTUNE NEPTUNE 253 +hackkit SA1100_HACKKIT HACKKIT 254 +pxa_wins30 ARCH_PXA_WINS30 PXA_WINS30 255 +lavinna SA1100_LAVINNA LAVINNA 256 +pxa_uengine ARCH_PXA_UENGINE PXA_UENGINE 257 +innokom ARCH_INNOKOM INNOKOM 258 +bms ARCH_BMS BMS 259 +ixcdp1100 ARCH_IXCDP1100 IXCDP1100 260 +prpmc1100 ARCH_PRPMC1100 PRPMC1100 261 +at91rm9200dk ARCH_AT91RM9200DK AT91RM9200DK 262 +armstick ARCH_ARMSTICK ARMSTICK 263 +armonie ARCH_ARMONIE ARMONIE 264 +mport1 ARCH_MPORT1 MPORT1 265 +s3c5410 ARCH_S3C5410 S3C5410 266 +zcp320a ARCH_ZCP320A ZCP320A 267 +i_box ARCH_I_BOX I_BOX 268 +stlc1502 ARCH_STLC1502 STLC1502 269 +siren ARCH_SIREN SIREN 270 +greenlake ARCH_GREENLAKE GREENLAKE 271 +argus ARCH_ARGUS ARGUS 272 +combadge SA1100_COMBADGE COMBADGE 273 +rokepxa ARCH_ROKEPXA ROKEPXA 274 +cintegrator ARCH_CINTEGRATOR CINTEGRATOR 275 +guidea07 ARCH_GUIDEA07 GUIDEA07 276 +tat257 ARCH_TAT257 TAT257 277 +igp2425 ARCH_IGP2425 IGP2425 278 +bluegrama ARCH_BLUEGRAMMA BLUEGRAMMA 279 +ipod ARCH_IPOD IPOD 280 +adsbitsyx ARCH_ADSBITSYX ADSBITSYX 281 +trizeps2 ARCH_TRIZEPS2 TRIZEPS2 282 +viper ARCH_VIPER VIPER 283 +adsbitsyplus SA1100_ADSBITSYPLUS ADSBITSYPLUS 284 +adsagc SA1100_ADSAGC ADSAGC 285 +stp7312 ARCH_STP7312 STP7312 286 +nx_phnx MACH_NX_PHNX NX_PHNX 287 +wep_ep250 ARCH_WEP_EP250 WEP_EP250 288 +inhandelf3 ARCH_INHANDELF3 INHANDELF3 289 +adi_coyote ARCH_ADI_COYOTE ADI_COYOTE 290 +iyonix ARCH_IYONIX IYONIX 291 +damicam1 ARCH_DAMICAM_SA1110 DAMICAM_SA1110 292 +meg03 ARCH_MEG03 MEG03 293 +pxa_whitechapel ARCH_PXA_WHITECHAPEL PXA_WHITECHAPEL 294 +nwsc ARCH_NWSC NWSC 295 +nwlarm ARCH_NWLARM NWLARM 296 +ixp425_mguard ARCH_IXP425_MGUARD IXP425_MGUARD 297 +pxa_netdcu4 ARCH_PXA_NETDCU4 PXA_NETDCU4 298 +ixdp2401 ARCH_IXDP2401 IXDP2401 299 +ixdp2801 ARCH_IXDP2801 IXDP2801 300 +zodiac ARCH_ZODIAC ZODIAC 301 +armmodul ARCH_ARMMODUL ARMMODUL 302 +ketop SA1100_KETOP KETOP 303 +av7200 ARCH_AV7200 AV7200 304 +arch_ti925 ARCH_ARCH_TI925 ARCH_TI925 305 +acq200 ARCH_ACQ200 ACQ200 306 +pt_dafit SA1100_PT_DAFIT PT_DAFIT 307 +ihba ARCH_IHBA IHBA 308 +quinque ARCH_QUINQUE QUINQUE 309 +nimbraone ARCH_NIMBRAONE NIMBRAONE 310 +nimbra29x ARCH_NIMBRA29X NIMBRA29X 311 +nimbra210 ARCH_NIMBRA210 NIMBRA210 312 +hhp_d95xx ARCH_HHP_D95XX HHP_D95XX 313 +labarm ARCH_LABARM LABARM 314 +m825xx ARCH_M825XX M825XX 315 +m7100 SA1100_M7100 M7100 316 +nipc2 ARCH_NIPC2 NIPC2 317 +fu7202 ARCH_FU7202 FU7202 318 +adsagx ARCH_ADSAGX ADSAGX 319 +pxa_pooh ARCH_PXA_POOH PXA_POOH 320 +bandon ARCH_BANDON BANDON 321 +pcm7210 ARCH_PCM7210 PCM7210 322 +nms9200 ARCH_NMS9200 NMS9200 323 +logodl ARCH_LOGODL LOGODL 324 +m7140 SA1100_M7140 M7140 325 +korebot ARCH_KOREBOT KOREBOT 326 +iq31244 ARCH_IQ31244 IQ31244 327 +koan393 SA1100_KOAN393 KOAN393 328 +inhandftip3 ARCH_INHANDFTIP3 INHANDFTIP3 329 +gonzo ARCH_GONZO GONZO 330 +bast ARCH_BAST BAST 331 +scanpass ARCH_SCANPASS SCANPASS 332 +ep7312_pooh ARCH_EP7312_POOH EP7312_POOH 333 +ta7s ARCH_TA7S TA7S 334 +ta7v ARCH_TA7V TA7V 335 +icarus SA1100_ICARUS ICARUS 336 +h1900 ARCH_H1900 H1900 337 +gemini SA1100_GEMINI GEMINI 338 +axim ARCH_AXIM AXIM 339 +audiotron ARCH_AUDIOTRON AUDIOTRON 340 +h2200 ARCH_H2200 H2200 341 +loox600 ARCH_LOOX600 LOOX600 342 +niop ARCH_NIOP NIOP 343 +dm310 ARCH_DM310 DM310 344 +seedpxa_c2 ARCH_SEEDPXA_C2 SEEDPXA_C2 345 +ixp4xx_mguardpci ARCH_IXP4XX_MGUARD_PCI IXP4XX_MGUARD_PCI 346 +h1940 ARCH_H1940 H1940 347 +scorpio ARCH_SCORPIO SCORPIO 348 +viva ARCH_VIVA VIVA 349 +pxa_xcard ARCH_PXA_XCARD PXA_XCARD 350 +csb335 ARCH_CSB335 CSB335 351 +ixrd425 ARCH_IXRD425 IXRD425 352 +iq80315 ARCH_IQ80315 IQ80315 353 +nmp7312 ARCH_NMP7312 NMP7312 354 +cx861xx ARCH_CX861XX CX861XX 355 +enp2611 ARCH_ENP2611 ENP2611 356 +xda SA1100_XDA XDA 357 +csir_ims ARCH_CSIR_IMS CSIR_IMS 358 +ixp421_dnaeeth ARCH_IXP421_DNAEETH IXP421_DNAEETH 359 +pocketserv9200 ARCH_POCKETSERV9200 POCKETSERV9200 360 +toto ARCH_TOTO TOTO 361 +s3c2440 ARCH_S3C2440 S3C2440 362 +ks8695p ARCH_KS8695P KS8695P 363 +se4000 ARCH_SE4000 SE4000 364 +quadriceps ARCH_QUADRICEPS QUADRICEPS 365 +bronco ARCH_BRONCO BRONCO 366 +esl_wireless_tab ARCH_ESL_WIRELESS_TAB ESL_WIRELESS_TAB 367 +esl_sofcomp ARCH_ESL_SOFCOMP ESL_SOFCOMP 368 +s5c7375 ARCH_S5C7375 S5C7375 369 +spearhead ARCH_SPEARHEAD SPEARHEAD 370 +pantera ARCH_PANTERA PANTERA 371 +prayoglite ARCH_PRAYOGLITE PRAYOGLITE 372 +gumstix ARCH_GUMSTIX GUMSTIX 373 +rcube ARCH_RCUBE RCUBE 374 +rea_olv ARCH_REA_OLV REA_OLV 375 +pxa_iphone ARCH_PXA_IPHONE PXA_IPHONE 376 +s3c3410 ARCH_S3C3410 S3C3410 377 +espd_4510b ARCH_ESPD_4510B ESPD_4510B 378 +mp1x ARCH_MP1X MP1X 379 +at91rm9200tb ARCH_AT91RM9200TB AT91RM9200TB 380 +adsvgx ARCH_ADSVGX ADSVGX 381 +omap_h2 MACH_OMAP_H2 OMAP_H2 382 +pelee ARCH_PELEE PELEE 383 +e740 MACH_E740 E740 384 +iq80331 ARCH_IQ80331 IQ80331 385 +versatile_pb ARCH_VERSATILE_PB VERSATILE_PB 387 +kev7a400 MACH_KEV7A400 KEV7A400 388 +lpd7a400 MACH_LPD7A400 LPD7A400 389 +lpd7a404 MACH_LPD7A404 LPD7A404 390 +fujitsu_camelot ARCH_FUJITSU_CAMELOT FUJITSU_CAMELOT 391 +janus2m ARCH_JANUS2M JANUS2M 392 +embtf MACH_EMBTF EMBTF 393 +hpm MACH_HPM HPM 394 +smdk2410tk MACH_SMDK2410TK SMDK2410TK 395 +smdk2410aj MACH_SMDK2410AJ SMDK2410AJ 396 +streetracer MACH_STREETRACER STREETRACER 397 +eframe MACH_EFRAME EFRAME 398 +csb337 MACH_CSB337 CSB337 399 +pxa_lark MACH_PXA_LARK PXA_LARK 400 +pxa_pnp2110 MACH_PNP2110 PNP2110 401 +tcc72x MACH_TCC72X TCC72X 402 +altair MACH_ALTAIR ALTAIR 403 +kc3 MACH_KC3 KC3 404 +sinteftd MACH_SINTEFTD SINTEFTD 405 +mainstone MACH_MAINSTONE MAINSTONE 406 +aday4x MACH_ADAY4X ADAY4X 407 +lite300 MACH_LITE300 LITE300 408 +s5c7376 MACH_S5C7376 S5C7376 409 +mt02 MACH_MT02 MT02 410 +mport3s MACH_MPORT3S MPORT3S 411 +ra_alpha MACH_RA_ALPHA RA_ALPHA 412 +xcep MACH_XCEP XCEP 413 +arcom_vulcan MACH_ARCOM_VULCAN ARCOM_VULCAN 414 +stargate MACH_STARGATE STARGATE 415 +armadilloj MACH_ARMADILLOJ ARMADILLOJ 416 +elroy_jack MACH_ELROY_JACK ELROY_JACK 417 +backend MACH_BACKEND BACKEND 418 +s5linbox MACH_S5LINBOX S5LINBOX 419 +nomadik MACH_NOMADIK NOMADIK 420 +ia_cpu_9200 MACH_IA_CPU_9200 IA_CPU_9200 421 +at91_bja1 MACH_AT91_BJA1 AT91_BJA1 422 +corgi MACH_CORGI CORGI 423 +poodle MACH_POODLE POODLE 424 +ten MACH_TEN TEN 425 +roverp5p MACH_ROVERP5P ROVERP5P 426 +sc2700 MACH_SC2700 SC2700 427 +ex_eagle MACH_EX_EAGLE EX_EAGLE 428 +nx_pxa12 MACH_NX_PXA12 NX_PXA12 429 +nx_pxa5 MACH_NX_PXA5 NX_PXA5 430 +blackboard2 MACH_BLACKBOARD2 BLACKBOARD2 431 +i819 MACH_I819 I819 432 +ixmb995e MACH_IXMB995E IXMB995E 433 +skyrider MACH_SKYRIDER SKYRIDER 434 +skyhawk MACH_SKYHAWK SKYHAWK 435 +enterprise MACH_ENTERPRISE ENTERPRISE 436 +dep2410 MACH_DEP2410 DEP2410 437 +armcore MACH_ARMCORE ARMCORE 438 +hobbit MACH_HOBBIT HOBBIT 439 +h7210 MACH_H7210 H7210 440 +pxa_netdcu5 MACH_PXA_NETDCU5 PXA_NETDCU5 441 +acc MACH_ACC ACC 442 +esl_sarva MACH_ESL_SARVA ESL_SARVA 443 +xm250 MACH_XM250 XM250 444 +t6tc1xb MACH_T6TC1XB T6TC1XB 445 +ess710 MACH_ESS710 ESS710 446 +mx31ads MACH_MX31ADS MX31ADS 447 +himalaya MACH_HIMALAYA HIMALAYA 448 +bolfenk MACH_BOLFENK BOLFENK 449 +at91rm9200kr MACH_AT91RM9200KR AT91RM9200KR 450 +edb9312 MACH_EDB9312 EDB9312 451 +omap_generic MACH_OMAP_GENERIC OMAP_GENERIC 452 +aximx3 MACH_AXIMX3 AXIMX3 453 +eb67xdip MACH_EB67XDIP EB67XDIP 454 +webtxs MACH_WEBTXS WEBTXS 455 +hawk MACH_HAWK HAWK 456 +ccat91sbc001 MACH_CCAT91SBC001 CCAT91SBC001 457 +expresso MACH_EXPRESSO EXPRESSO 458 +h4000 MACH_H4000 H4000 459 +dino MACH_DINO DINO 460 +ml675k MACH_ML675K ML675K 461 +edb9301 MACH_EDB9301 EDB9301 462 +edb9315 MACH_EDB9315 EDB9315 463 +reciva_tt MACH_RECIVA_TT RECIVA_TT 464 +cstcb01 MACH_CSTCB01 CSTCB01 465 +cstcb1 MACH_CSTCB1 CSTCB1 466 +shadwell MACH_SHADWELL SHADWELL 467 +goepel263 MACH_GOEPEL263 GOEPEL263 468 +acq100 MACH_ACQ100 ACQ100 469 +mx1fs2 MACH_MX1FS2 MX1FS2 470 +hiptop_g1 MACH_HIPTOP_G1 HIPTOP_G1 471 +sparky MACH_SPARKY SPARKY 472 +ns9750 MACH_NS9750 NS9750 473 +phoenix MACH_PHOENIX PHOENIX 474 +vr1000 MACH_VR1000 VR1000 475 +deisterpxa MACH_DEISTERPXA DEISTERPXA 476 +bcm1160 MACH_BCM1160 BCM1160 477 +pcm022 MACH_PCM022 PCM022 478 +adsgcx MACH_ADSGCX ADSGCX 479 +dreadnaught MACH_DREADNAUGHT DREADNAUGHT 480 +dm320 MACH_DM320 DM320 481 +markov MACH_MARKOV MARKOV 482 +cos7a400 MACH_COS7A400 COS7A400 483 +milano MACH_MILANO MILANO 484 +ue9328 MACH_UE9328 UE9328 485 +uex255 MACH_UEX255 UEX255 486 +ue2410 MACH_UE2410 UE2410 487 +a620 MACH_A620 A620 488 +ocelot MACH_OCELOT OCELOT 489 +cheetah MACH_CHEETAH CHEETAH 490 +omap_perseus2 MACH_OMAP_PERSEUS2 OMAP_PERSEUS2 491 +zvue MACH_ZVUE ZVUE 492 +roverp1 MACH_ROVERP1 ROVERP1 493 +asidial2 MACH_ASIDIAL2 ASIDIAL2 494 +s3c24a0 MACH_S3C24A0 S3C24A0 495 +e800 MACH_E800 E800 496 +e750 MACH_E750 E750 497 +s3c5500 MACH_S3C5500 S3C5500 498 +smdk5500 MACH_SMDK5500 SMDK5500 499 +signalsync MACH_SIGNALSYNC SIGNALSYNC 500 +nbc MACH_NBC NBC 501 +kodiak MACH_KODIAK KODIAK 502 +netbookpro MACH_NETBOOKPRO NETBOOKPRO 503 +hw90200 MACH_HW90200 HW90200 504 +condor MACH_CONDOR CONDOR 505 +cup MACH_CUP CUP 506 +kite MACH_KITE KITE 507 +scb9328 MACH_SCB9328 SCB9328 508 +omap_h3 MACH_OMAP_H3 OMAP_H3 509 +omap_h4 MACH_OMAP_H4 OMAP_H4 510 +n10 MACH_N10 N10 511 +montejade MACH_MONTAJADE MONTAJADE 512 +sg560 MACH_SG560 SG560 513 +dp1000 MACH_DP1000 DP1000 514 +omap_osk MACH_OMAP_OSK OMAP_OSK 515 +rg100v3 MACH_RG100V3 RG100V3 516 +mx2ads MACH_MX2ADS MX2ADS 517 +pxa_kilo MACH_PXA_KILO PXA_KILO 518 +ixp4xx_eagle MACH_IXP4XX_EAGLE IXP4XX_EAGLE 519 +tosa MACH_TOSA TOSA 520 +mb2520f MACH_MB2520F MB2520F 521 +emc1000 MACH_EMC1000 EMC1000 522 +tidsc25 MACH_TIDSC25 TIDSC25 523 +akcpmxl MACH_AKCPMXL AKCPMXL 524 +av3xx MACH_AV3XX AV3XX 525 +avila MACH_AVILA AVILA 526 +pxa_mpm10 MACH_PXA_MPM10 PXA_MPM10 527 +pxa_kyanite MACH_PXA_KYANITE PXA_KYANITE 528 +sgold MACH_SGOLD SGOLD 529 +oscar MACH_OSCAR OSCAR 530 +epxa4usb2 MACH_EPXA4USB2 EPXA4USB2 531 +xsengine MACH_XSENGINE XSENGINE 532 +ip600 MACH_IP600 IP600 533 +mcan2 MACH_MCAN2 MCAN2 534 +ddi_blueridge MACH_DDI_BLUERIDGE DDI_BLUERIDGE 535 +skyminder MACH_SKYMINDER SKYMINDER 536 +lpd79520 MACH_LPD79520 LPD79520 537 +edb9302 MACH_EDB9302 EDB9302 538 +hw90340 MACH_HW90340 HW90340 539 +cip_box MACH_CIP_BOX CIP_BOX 540 +ivpn MACH_IVPN IVPN 541 +rsoc2 MACH_RSOC2 RSOC2 542 +husky MACH_HUSKY HUSKY 543 +boxer MACH_BOXER BOXER 544 +shepherd MACH_SHEPHERD SHEPHERD 545 +aml42800aa MACH_AML42800AA AML42800AA 546 +lpc2294 MACH_LPC2294 LPC2294 548 +switchgrass MACH_SWITCHGRASS SWITCHGRASS 549 +ens_cmu MACH_ENS_CMU ENS_CMU 550 +mm6_sdb MACH_MM6_SDB MM6_SDB 551 +saturn MACH_SATURN SATURN 552 +i30030evb MACH_I30030EVB I30030EVB 553 +mxc27530evb MACH_MXC27530EVB MXC27530EVB 554 +smdk2800 MACH_SMDK2800 SMDK2800 555 +mtwilson MACH_MTWILSON MTWILSON 556 +ziti MACH_ZITI ZITI 557 +grandfather MACH_GRANDFATHER GRANDFATHER 558 +tengine MACH_TENGINE TENGINE 559 +s3c2460 MACH_S3C2460 S3C2460 560 +pdm MACH_PDM PDM 561 +h4700 MACH_H4700 H4700 562 +h6300 MACH_H6300 H6300 563 +rz1700 MACH_RZ1700 RZ1700 564 +a716 MACH_A716 A716 565 +estk2440a MACH_ESTK2440A ESTK2440A 566 +atwixp425 MACH_ATWIXP425 ATWIXP425 567 +csb336 MACH_CSB336 CSB336 568 +rirm2 MACH_RIRM2 RIRM2 569 +cx23518 MACH_CX23518 CX23518 570 +cx2351x MACH_CX2351X CX2351X 571 +computime MACH_COMPUTIME COMPUTIME 572 +izarus MACH_IZARUS IZARUS 573 +pxa_rts MACH_RTS RTS 574 +se5100 MACH_SE5100 SE5100 575 +s3c2510 MACH_S3C2510 S3C2510 576 +csb437tl MACH_CSB437TL CSB437TL 577 +slauson MACH_SLAUSON SLAUSON 578 +pearlriver MACH_PEARLRIVER PEARLRIVER 579 +tdc_p210 MACH_TDC_P210 TDC_P210 580 +sg580 MACH_SG580 SG580 581 +wrsbcarm7 MACH_WRSBCARM7 WRSBCARM7 582 +ipd MACH_IPD IPD 583 +pxa_dnp2110 MACH_PXA_DNP2110 PXA_DNP2110 584 +xaeniax MACH_XAENIAX XAENIAX 585 +somn4250 MACH_SOMN4250 SOMN4250 586 +pleb2 MACH_PLEB2 PLEB2 587 +cornwallis MACH_CORNWALLIS CORNWALLIS 588 +gurney_drv MACH_GURNEY_DRV GURNEY_DRV 589 +chaffee MACH_CHAFFEE CHAFFEE 590 +rms101 MACH_RMS101 RMS101 591 +rx3715 MACH_RX3715 RX3715 592 +swift MACH_SWIFT SWIFT 593 +roverp7 MACH_ROVERP7 ROVERP7 594 +pr818s MACH_PR818S PR818S 595 +trxpro MACH_TRXPRO TRXPRO 596 +nslu2 MACH_NSLU2 NSLU2 597 +e400 MACH_E400 E400 598 +trab MACH_TRAB TRAB 599 +cmc_pu2 MACH_CMC_PU2 CMC_PU2 600 +fulcrum MACH_FULCRUM FULCRUM 601 +netgate42x MACH_NETGATE42X NETGATE42X 602 +str710 MACH_STR710 STR710 603 +ixdpg425 MACH_IXDPG425 IXDPG425 604 +tomtomgo MACH_TOMTOMGO TOMTOMGO 605 +versatile_ab MACH_VERSATILE_AB VERSATILE_AB 606 +edb9307 MACH_EDB9307 EDB9307 607 +sg565 MACH_SG565 SG565 608 +lpd79524 MACH_LPD79524 LPD79524 609 +lpd79525 MACH_LPD79525 LPD79525 610 +rms100 MACH_RMS100 RMS100 611 +kb9200 MACH_KB9200 KB9200 612 +sx1 MACH_SX1 SX1 613 +hms39c7092 MACH_HMS39C7092 HMS39C7092 614 +armadillo MACH_ARMADILLO ARMADILLO 615 +ipcu MACH_IPCU IPCU 616 +loox720 MACH_LOOX720 LOOX720 617 +ixdp465 MACH_IXDP465 IXDP465 618 +ixdp2351 MACH_IXDP2351 IXDP2351 619 +adsvix MACH_ADSVIX ADSVIX 620 +dm270 MACH_DM270 DM270 621 +socltplus MACH_SOCLTPLUS SOCLTPLUS 622 +ecia MACH_ECIA ECIA 623 +cm4008 MACH_CM4008 CM4008 624 +p2001 MACH_P2001 P2001 625 +twister MACH_TWISTER TWISTER 626 +mudshark MACH_MUDSHARK MUDSHARK 627 +hb2 MACH_HB2 HB2 628 +iq80332 MACH_IQ80332 IQ80332 629 +sendt MACH_SENDT SENDT 630 +mx2jazz MACH_MX2JAZZ MX2JAZZ 631 +multiio MACH_MULTIIO MULTIIO 632 +hrdisplay MACH_HRDISPLAY HRDISPLAY 633 +mxc27530ads MACH_MXC27530ADS MXC27530ADS 634 +trizeps3 MACH_TRIZEPS3 TRIZEPS3 635 +zefeerdza MACH_ZEFEERDZA ZEFEERDZA 636 +zefeerdzb MACH_ZEFEERDZB ZEFEERDZB 637 +zefeerdzg MACH_ZEFEERDZG ZEFEERDZG 638 +zefeerdzn MACH_ZEFEERDZN ZEFEERDZN 639 +zefeerdzq MACH_ZEFEERDZQ ZEFEERDZQ 640 +gtwx5715 MACH_GTWX5715 GTWX5715 641 +astro_jack MACH_ASTRO_JACK ASTRO_JACK 643 +tip03 MACH_TIP03 TIP03 644 +a9200ec MACH_A9200EC A9200EC 645 +pnx0105 MACH_PNX0105 PNX0105 646 +adcpoecpu MACH_ADCPOECPU ADCPOECPU 647 +csb637 MACH_CSB637 CSB637 648 +mb9200 MACH_MB9200 MB9200 650 +kulun MACH_KULUN KULUN 651 +snapper MACH_SNAPPER SNAPPER 652 +optima MACH_OPTIMA OPTIMA 653 +dlhsbc MACH_DLHSBC DLHSBC 654 +x30 MACH_X30 X30 655 +n30 MACH_N30 N30 656 +manga_ks8695 MACH_MANGA_KS8695 MANGA_KS8695 657 +ajax MACH_AJAX AJAX 658 +nec_mp900 MACH_NEC_MP900 NEC_MP900 659 +vvtk1000 MACH_VVTK1000 VVTK1000 661 +kafa MACH_KAFA KAFA 662 +vvtk3000 MACH_VVTK3000 VVTK3000 663 +pimx1 MACH_PIMX1 PIMX1 664 +ollie MACH_OLLIE OLLIE 665 +skymax MACH_SKYMAX SKYMAX 666 +jazz MACH_JAZZ JAZZ 667 +tel_t3 MACH_TEL_T3 TEL_T3 668 +aisino_fcr255 MACH_AISINO_FCR255 AISINO_FCR255 669 +btweb MACH_BTWEB BTWEB 670 +dbg_lh79520 MACH_DBG_LH79520 DBG_LH79520 671 +cm41xx MACH_CM41XX CM41XX 672 +ts72xx MACH_TS72XX TS72XX 673 +nggpxa MACH_NGGPXA NGGPXA 674 +csb535 MACH_CSB535 CSB535 675 +csb536 MACH_CSB536 CSB536 676 +pxa_trakpod MACH_PXA_TRAKPOD PXA_TRAKPOD 677 +praxis MACH_PRAXIS PRAXIS 678 +lh75411 MACH_LH75411 LH75411 679 +otom MACH_OTOM OTOM 680 +nexcoder_2440 MACH_NEXCODER_2440 NEXCODER_2440 681 +loox410 MACH_LOOX410 LOOX410 682 +westlake MACH_WESTLAKE WESTLAKE 683 +nsb MACH_NSB NSB 684 +esl_sarva_stn MACH_ESL_SARVA_STN ESL_SARVA_STN 685 +esl_sarva_tft MACH_ESL_SARVA_TFT ESL_SARVA_TFT 686 +esl_sarva_iad MACH_ESL_SARVA_IAD ESL_SARVA_IAD 687 +esl_sarva_acc MACH_ESL_SARVA_ACC ESL_SARVA_ACC 688 +typhoon MACH_TYPHOON TYPHOON 689 +cnav MACH_CNAV CNAV 690 +a730 MACH_A730 A730 691 +netstar MACH_NETSTAR NETSTAR 692 +supercon MACH_PHASEFALE_SUPERCON PHASEFALE_SUPERCON 693 +shiva1100 MACH_SHIVA1100 SHIVA1100 694 +etexsc MACH_ETEXSC ETEXSC 695 +ixdpg465 MACH_IXDPG465 IXDPG465 696 +a9m2410 MACH_A9M2410 A9M2410 697 +a9m2440 MACH_A9M2440 A9M2440 698 +a9m9750 MACH_A9M9750 A9M9750 699 +a9m9360 MACH_A9M9360 A9M9360 700 +unc90 MACH_UNC90 UNC90 701 +eco920 MACH_ECO920 ECO920 702 +satview MACH_SATVIEW SATVIEW 703 +roadrunner MACH_ROADRUNNER ROADRUNNER 704 +at91rm9200ek MACH_AT91RM9200EK AT91RM9200EK 705 +gp32 MACH_GP32 GP32 706 +gem MACH_GEM GEM 707 +i858 MACH_I858 I858 708 +hx2750 MACH_HX2750 HX2750 709 +mxc91131evb MACH_MXC91131EVB MXC91131EVB 710 +p700 MACH_P700 P700 711 +cpe MACH_CPE CPE 712 +spitz MACH_SPITZ SPITZ 713 +nimbra340 MACH_NIMBRA340 NIMBRA340 714 +lpc22xx MACH_LPC22XX LPC22XX 715 +omap_comet3 MACH_COMET3 COMET3 716 +omap_comet4 MACH_COMET4 COMET4 717 +csb625 MACH_CSB625 CSB625 718 +fortunet2 MACH_FORTUNET2 FORTUNET2 719 +s5h2200 MACH_S5H2200 S5H2200 720 +optorm920 MACH_OPTORM920 OPTORM920 721 +adsbitsyxb MACH_ADSBITSYXB ADSBITSYXB 722 +adssphere MACH_ADSSPHERE ADSSPHERE 723 +adsportal MACH_ADSPORTAL ADSPORTAL 724 +ln2410sbc MACH_LN2410SBC LN2410SBC 725 +cb3rufc MACH_CB3RUFC CB3RUFC 726 +mp2usb MACH_MP2USB MP2USB 727 +ntnp425c MACH_NTNP425C NTNP425C 728 +colibri MACH_COLIBRI COLIBRI 729 +pcm7220 MACH_PCM7220 PCM7220 730 +gateway7001 MACH_GATEWAY7001 GATEWAY7001 731 +pcm027 MACH_PCM027 PCM027 732 +cmpxa MACH_CMPXA CMPXA 733 +anubis MACH_ANUBIS ANUBIS 734 +ite8152 MACH_ITE8152 ITE8152 735 +lpc3xxx MACH_LPC3XXX LPC3XXX 736 +puppeteer MACH_PUPPETEER PUPPETEER 737 +e570 MACH_E570 E570 739 +x50 MACH_X50 X50 740 +recon MACH_RECON RECON 741 +xboardgp8 MACH_XBOARDGP8 XBOARDGP8 742 +fpic2 MACH_FPIC2 FPIC2 743 +akita MACH_AKITA AKITA 744 +a81 MACH_A81 A81 745 +svm_sc25x MACH_SVM_SC25X SVM_SC25X 746 +vt020 MACH_VADATECH020 VADATECH020 747 +tli MACH_TLI TLI 748 +edb9315lc MACH_EDB9315LC EDB9315LC 749 +passec MACH_PASSEC PASSEC 750 +ds_tiger MACH_DS_TIGER DS_TIGER 751 +e310 MACH_E310 E310 752 +e330 MACH_E330 E330 753 +rt3000 MACH_RT3000 RT3000 754 +nokia770 MACH_NOKIA770 NOKIA770 755 +pnx0106 MACH_PNX0106 PNX0106 756 +hx21xx MACH_HX21XX HX21XX 757 +faraday MACH_FARADAY FARADAY 758 +sbc9312 MACH_SBC9312 SBC9312 759 +batman MACH_BATMAN BATMAN 760 +jpd201 MACH_JPD201 JPD201 761 +mipsa MACH_MIPSA MIPSA 762 +kacom MACH_KACOM KACOM 763 +swarcocpu MACH_SWARCOCPU SWARCOCPU 764 +swarcodsl MACH_SWARCODSL SWARCODSL 765 +blueangel MACH_BLUEANGEL BLUEANGEL 766 +hairygrama MACH_HAIRYGRAMA HAIRYGRAMA 767 +banff MACH_BANFF BANFF 768 +carmeva MACH_CARMEVA CARMEVA 769 +sam255 MACH_SAM255 SAM255 770 +ppm10 MACH_PPM10 PPM10 771 +edb9315a MACH_EDB9315A EDB9315A 772 +sunset MACH_SUNSET SUNSET 773 +stargate2 MACH_STARGATE2 STARGATE2 774 +intelmote2 MACH_INTELMOTE2 INTELMOTE2 775 +trizeps4 MACH_TRIZEPS4 TRIZEPS4 776 +mainstone2 MACH_MAINSTONE2 MAINSTONE2 777 +ez_ixp42x MACH_EZ_IXP42X EZ_IXP42X 778 +tapwave_zodiac MACH_TAPWAVE_ZODIAC TAPWAVE_ZODIAC 779 +universalmeter MACH_UNIVERSALMETER UNIVERSALMETER 780 +hicoarm9 MACH_HICOARM9 HICOARM9 781 +pnx4008 MACH_PNX4008 PNX4008 782 +kws6000 MACH_KWS6000 KWS6000 783 +portux920t MACH_PORTUX920T PORTUX920T 784 +ez_x5 MACH_EZ_X5 EZ_X5 785 +omap_rudolph MACH_OMAP_RUDOLPH OMAP_RUDOLPH 786 +cpuat91 MACH_CPUAT91 CPUAT91 787 +rea9200 MACH_REA9200 REA9200 788 +acts_pune_sa1110 MACH_ACTS_PUNE_SA1110 ACTS_PUNE_SA1110 789 +ixp425 MACH_IXP425 IXP425 790 +i30030ads MACH_I30030ADS I30030ADS 791 +perch MACH_PERCH PERCH 792 +eis05r1 MACH_EIS05R1 EIS05R1 793 +pepperpad MACH_PEPPERPAD PEPPERPAD 794 +sb3010 MACH_SB3010 SB3010 795 +rm9200 MACH_RM9200 RM9200 796 +dma03 MACH_DMA03 DMA03 797 +road_s101 MACH_ROAD_S101 ROAD_S101 798 +iq81340sc MACH_IQ81340SC IQ81340SC 799 +iq_nextgen_b MACH_IQ_NEXTGEN_B IQ_NEXTGEN_B 800 +iq81340mc MACH_IQ81340MC IQ81340MC 801 +iq_nextgen_d MACH_IQ_NEXTGEN_D IQ_NEXTGEN_D 802 +iq_nextgen_e MACH_IQ_NEXTGEN_E IQ_NEXTGEN_E 803 +mallow_at91 MACH_MALLOW_AT91 MALLOW_AT91 804 +cybertracker_i MACH_CYBERTRACKER_I CYBERTRACKER_I 805 +gesbc931x MACH_GESBC931X GESBC931X 806 +centipad MACH_CENTIPAD CENTIPAD 807 +armsoc MACH_ARMSOC ARMSOC 808 +se4200 MACH_SE4200 SE4200 809 +ems197a MACH_EMS197A EMS197A 810 +micro9 MACH_MICRO9 MICRO9 811 +micro9l MACH_MICRO9L MICRO9L 812 +uc5471dsp MACH_UC5471DSP UC5471DSP 813 +sj5471eng MACH_SJ5471ENG SJ5471ENG 814 +none MACH_CMPXA26X CMPXA26X 815 +nc1 MACH_NC NC 816 +omap_palmte MACH_OMAP_PALMTE OMAP_PALMTE 817 +ajax52x MACH_AJAX52X AJAX52X 818 +siriustar MACH_SIRIUSTAR SIRIUSTAR 819 +iodata_hdlg MACH_IODATA_HDLG IODATA_HDLG 820 +at91rm9200utl MACH_AT91RM9200UTL AT91RM9200UTL 821 +biosafe MACH_BIOSAFE BIOSAFE 822 +mp1000 MACH_MP1000 MP1000 823 +parsy MACH_PARSY PARSY 824 +ccxp270 MACH_CCXP CCXP 825 +omap_gsample MACH_OMAP_GSAMPLE OMAP_GSAMPLE 826 +realview_eb MACH_REALVIEW_EB REALVIEW_EB 827 +samoa MACH_SAMOA SAMOA 828 +palmt3 MACH_PALMT3 PALMT3 829 +i878 MACH_I878 I878 830 +borzoi MACH_BORZOI BORZOI 831 +gecko MACH_GECKO GECKO 832 +ds101 MACH_DS101 DS101 833 +omap_palmtt2 MACH_OMAP_PALMTT2 OMAP_PALMTT2 834 +palmld MACH_PALMLD PALMLD 835 +cc9c MACH_CC9C CC9C 836 +sbc1670 MACH_SBC1670 SBC1670 837 +ixdp28x5 MACH_IXDP28X5 IXDP28X5 838 +omap_palmtt MACH_OMAP_PALMTT OMAP_PALMTT 839 +ml696k MACH_ML696K ML696K 840 +arcom_zeus MACH_ARCOM_ZEUS ARCOM_ZEUS 841 +osiris MACH_OSIRIS OSIRIS 842 +maestro MACH_MAESTRO MAESTRO 843 +palmte2 MACH_PALMTE2 PALMTE2 844 +ixbbm MACH_IXBBM IXBBM 845 +mx27ads MACH_MX27ADS MX27ADS 846 +ax8004 MACH_AX8004 AX8004 847 +at91sam9261ek MACH_AT91SAM9261EK AT91SAM9261EK 848 +loft MACH_LOFT LOFT 849 +magpie MACH_MAGPIE MAGPIE 850 +mx21ads MACH_MX21ADS MX21ADS 851 +mb87m3400 MACH_MB87M3400 MB87M3400 852 +mguard_delta MACH_MGUARD_DELTA MGUARD_DELTA 853 +davinci_dvdp MACH_DAVINCI_DVDP DAVINCI_DVDP 854 +htcuniversal MACH_HTCUNIVERSAL HTCUNIVERSAL 855 +tpad MACH_TPAD TPAD 856 +roverp3 MACH_ROVERP3 ROVERP3 857 +jornada928 MACH_JORNADA928 JORNADA928 858 +mv88fxx81 MACH_MV88FXX81 MV88FXX81 859 +stmp36xx MACH_STMP36XX STMP36XX 860 +sxni79524 MACH_SXNI79524 SXNI79524 861 +ams_delta MACH_AMS_DELTA AMS_DELTA 862 +uranium MACH_URANIUM URANIUM 863 +ucon MACH_UCON UCON 864 +nas100d MACH_NAS100D NAS100D 865 +l083 MACH_L083_1000 L083_1000 866 +ezx MACH_EZX EZX 867 +pnx5220 MACH_PNX5220 PNX5220 868 +butte MACH_BUTTE BUTTE 869 +srm2 MACH_SRM2 SRM2 870 +dsbr MACH_DSBR DSBR 871 +crystalball MACH_CRYSTALBALL CRYSTALBALL 872 +tinypxa27x MACH_TINYPXA27X TINYPXA27X 873 +herbie MACH_HERBIE HERBIE 874 +magician MACH_MAGICIAN MAGICIAN 875 +cm4002 MACH_CM4002 CM4002 876 +b4 MACH_B4 B4 877 +maui MACH_MAUI MAUI 878 +cybertracker_g MACH_CYBERTRACKER_G CYBERTRACKER_G 879 +nxdkn MACH_NXDKN NXDKN 880 +mio8390 MACH_MIO8390 MIO8390 881 +omi_board MACH_OMI_BOARD OMI_BOARD 882 +mx21civ MACH_MX21CIV MX21CIV 883 +mahi_cdac MACH_MAHI_CDAC MAHI_CDAC 884 +palmtx MACH_PALMTX PALMTX 885 +s3c2413 MACH_S3C2413 S3C2413 887 +samsys_ep0 MACH_SAMSYS_EP0 SAMSYS_EP0 888 +wg302v1 MACH_WG302V1 WG302V1 889 +wg302v2 MACH_WG302V2 WG302V2 890 +eb42x MACH_EB42X EB42X 891 +iq331es MACH_IQ331ES IQ331ES 892 +cosydsp MACH_COSYDSP COSYDSP 893 +uplat7d_proto MACH_UPLAT7D UPLAT7D 894 +ptdavinci MACH_PTDAVINCI PTDAVINCI 895 +mbus MACH_MBUS MBUS 896 +nadia2vb MACH_NADIA2VB NADIA2VB 897 +r1000 MACH_R1000 R1000 898 +hw90250 MACH_HW90250 HW90250 899 +omap_2430sdp MACH_OMAP_2430SDP OMAP_2430SDP 900 +davinci_evm MACH_DAVINCI_EVM DAVINCI_EVM 901 +omap_tornado MACH_OMAP_TORNADO OMAP_TORNADO 902 +olocreek MACH_OLOCREEK OLOCREEK 903 +palmz72 MACH_PALMZ72 PALMZ72 904 +nxdb500 MACH_NXDB500 NXDB500 905 +apf9328 MACH_APF9328 APF9328 906 +omap_wipoq MACH_OMAP_WIPOQ OMAP_WIPOQ 907 +omap_twip MACH_OMAP_TWIP OMAP_TWIP 908 +palmt650 MACH_PALMT650 PALMT650 909 +acumen MACH_ACUMEN ACUMEN 910 +xp100 MACH_XP100 XP100 911 +fs2410 MACH_FS2410 FS2410 912 +pxa270_cerf MACH_PXA270_CERF PXA270_CERF 913 +sq2ftlpalm MACH_SQ2FTLPALM SQ2FTLPALM 914 +bsemserver MACH_BSEMSERVER BSEMSERVER 915 +netclient MACH_NETCLIENT NETCLIENT 916 +palmt5 MACH_PALMT5 PALMT5 917 +palmtc MACH_PALMTC PALMTC 918 +omap_apollon MACH_OMAP_APOLLON OMAP_APOLLON 919 +mxc30030evb MACH_MXC30030EVB MXC30030EVB 920 +rea_2d MACH_REA_2D REA_2D 921 +eti3e524 MACH_TI3E524 TI3E524 922 +ateb9200 MACH_ATEB9200 ATEB9200 923 +auckland MACH_AUCKLAND AUCKLAND 924 +ak3220m MACH_AK3320M AK3320M 925 +duramax MACH_DURAMAX DURAMAX 926 +n35 MACH_N35 N35 927 +pronghorn MACH_PRONGHORN PRONGHORN 928 +fundy MACH_FUNDY FUNDY 929 +logicpd_pxa270 MACH_LOGICPD_PXA270 LOGICPD_PXA270 930 +cpu777 MACH_CPU777 CPU777 931 +simicon9201 MACH_SIMICON9201 SIMICON9201 932 +leap2_hpm MACH_LEAP2_HPM LEAP2_HPM 933 +cm922txa10 MACH_CM922TXA10 CM922TXA10 934 +sandgate MACH_PXA PXA 935 +sandgate2 MACH_SANDGATE2 SANDGATE2 936 +sandgate2g MACH_SANDGATE2G SANDGATE2G 937 +sandgate2p MACH_SANDGATE2P SANDGATE2P 938 +fred_jack MACH_FRED_JACK FRED_JACK 939 +ttg_color1 MACH_TTG_COLOR1 TTG_COLOR1 940 +nxeb500hmi MACH_NXEB500HMI NXEB500HMI 941 +netdcu8 MACH_NETDCU8 NETDCU8 942 +ng_fvx538 MACH_NG_FVX538 NG_FVX538 944 +ng_fvs338 MACH_NG_FVS338 NG_FVS338 945 +pnx4103 MACH_PNX4103 PNX4103 946 +hesdb MACH_HESDB HESDB 947 +xsilo MACH_XSILO XSILO 948 +espresso MACH_ESPRESSO ESPRESSO 949 +emlc MACH_EMLC EMLC 950 +sisteron MACH_SISTERON SISTERON 951 +rx1950 MACH_RX1950 RX1950 952 +tsc_venus MACH_TSC_VENUS TSC_VENUS 953 +ds101j MACH_DS101J DS101J 954 +mxc30030ads MACH_MXC30030ADS MXC30030ADS 955 +fujitsu_wimaxsoc MACH_FUJITSU_WIMAXSOC FUJITSU_WIMAXSOC 956 +dualpcmodem MACH_DUALPCMODEM DUALPCMODEM 957 +gesbc9312 MACH_GESBC9312 GESBC9312 958 +htcapache MACH_HTCAPACHE HTCAPACHE 959 +ixdp435 MACH_IXDP435 IXDP435 960 +catprovt100 MACH_CATPROVT100 CATPROVT100 961 +picotux1xx MACH_PICOTUX1XX PICOTUX1XX 962 +picotux2xx MACH_PICOTUX2XX PICOTUX2XX 963 +dsmg600 MACH_DSMG600 DSMG600 964 +empc2 MACH_EMPC2 EMPC2 965 +ventura MACH_VENTURA VENTURA 966 +phidget_sbc MACH_PHIDGET_SBC PHIDGET_SBC 967 +ij3k MACH_IJ3K IJ3K 968 +pisgah MACH_PISGAH PISGAH 969 +omap_fsample MACH_OMAP_FSAMPLE OMAP_FSAMPLE 970 +sg720 MACH_SG720 SG720 971 +redfox MACH_REDFOX REDFOX 972 +mysh_ep9315_1 MACH_MYSH_EP9315_1 MYSH_EP9315_1 973 +tpf106 MACH_TPF106 TPF106 974 +at91rm9200kg MACH_AT91RM9200KG AT91RM9200KG 975 +rcmt2 MACH_SLEDB SLEDB 976 +ontrack MACH_ONTRACK ONTRACK 977 +pm1200 MACH_PM1200 PM1200 978 +ess24562 MACH_ESS24XXX ESS24XXX 979 +coremp7 MACH_COREMP7 COREMP7 980 +nexcoder_6446 MACH_NEXCODER_6446 NEXCODER_6446 981 +stvc8380 MACH_STVC8380 STVC8380 982 +teklynx MACH_TEKLYNX TEKLYNX 983 +carbonado MACH_CARBONADO CARBONADO 984 +sysmos_mp730 MACH_SYSMOS_MP730 SYSMOS_MP730 985 +snapper_cl15 MACH_SNAPPER_CL15 SNAPPER_CL15 986 +pgigim MACH_PGIGIM PGIGIM 987 +ptx9160p2 MACH_PTX9160P2 PTX9160P2 988 +dcore1 MACH_DCORE1 DCORE1 989 +victorpxa MACH_VICTORPXA VICTORPXA 990 +mx2dtb MACH_MX2DTB MX2DTB 991 +pxa_irex_er0100 MACH_PXA_IREX_ER0100 PXA_IREX_ER0100 992 +omap_palmz71 MACH_OMAP_PALMZ71 OMAP_PALMZ71 993 +bartec_deg MACH_BARTEC_DEG BARTEC_DEG 994 +hw50251 MACH_HW50251 HW50251 995 +ibox MACH_IBOX IBOX 996 +atlaslh7a404 MACH_ATLASLH7A404 ATLASLH7A404 997 +pt2026 MACH_PT2026 PT2026 998 +htcalpine MACH_HTCALPINE HTCALPINE 999 +bartec_vtu MACH_BARTEC_VTU BARTEC_VTU 1000 +vcoreii MACH_VCOREII VCOREII 1001 +pdnb3 MACH_PDNB3 PDNB3 1002 +htcbeetles MACH_HTCBEETLES HTCBEETLES 1003 +s3c6400 MACH_S3C6400 S3C6400 1004 +s3c2443 MACH_S3C2443 S3C2443 1005 +omap_ldk MACH_OMAP_LDK OMAP_LDK 1006 +smdk2460 MACH_SMDK2460 SMDK2460 1007 +smdk2440 MACH_SMDK2440 SMDK2440 1008 +smdk2412 MACH_SMDK2412 SMDK2412 1009 +webbox MACH_WEBBOX WEBBOX 1010 +cwwndp MACH_CWWNDP CWWNDP 1011 +i839 MACH_DRAGON DRAGON 1012 +opendo_cpu_board MACH_OPENDO_CPU_BOARD OPENDO_CPU_BOARD 1013 +ccm2200 MACH_CCM2200 CCM2200 1014 +etwarm MACH_ETWARM ETWARM 1015 +m93030 MACH_M93030 M93030 1016 +cc7u MACH_CC7U CC7U 1017 +mtt_ranger MACH_MTT_RANGER MTT_RANGER 1018 +nexus MACH_NEXUS NEXUS 1019 +desman MACH_DESMAN DESMAN 1020 +bkde303 MACH_BKDE303 BKDE303 1021 +smdk2413 MACH_SMDK2413 SMDK2413 1022 +aml_m7200 MACH_AML_M7200 AML_M7200 1023 +aml_m5900 MACH_AML_M5900 AML_M5900 1024 +sg640 MACH_SG640 SG640 1025 +edg79524 MACH_EDG79524 EDG79524 1026 +ai2410 MACH_AI2410 AI2410 1027 +ixp465 MACH_IXP465 IXP465 1028 +balloon3 MACH_BALLOON3 BALLOON3 1029 +heins MACH_HEINS HEINS 1030 +mpluseva MACH_MPLUSEVA MPLUSEVA 1031 +rt042 MACH_RT042 RT042 1032 +cwiem MACH_CWIEM CWIEM 1033 +cm_x270 MACH_CM_X270 CM_X270 1034 +cm_x255 MACH_CM_X255 CM_X255 1035 +esh_at91 MACH_ESH_AT91 ESH_AT91 1036 +sandgate3 MACH_SANDGATE3 SANDGATE3 1037 +primo MACH_PRIMO PRIMO 1038 +gemstone MACH_GEMSTONE GEMSTONE 1039 +pronghorn_metro MACH_PRONGHORNMETRO PRONGHORNMETRO 1040 +sidewinder MACH_SIDEWINDER SIDEWINDER 1041 +picomod1 MACH_PICOMOD1 PICOMOD1 1042 +sg590 MACH_SG590 SG590 1043 +akai9307 MACH_AKAI9307 AKAI9307 1044 +fontaine MACH_FONTAINE FONTAINE 1045 +wombat MACH_WOMBAT WOMBAT 1046 +acq300 MACH_ACQ300 ACQ300 1047 +mod272 MACH_MOD_270 MOD_270 1048 +vmc_vc0820 MACH_VC0820 VC0820 1049 +ani_aim MACH_ANI_AIM ANI_AIM 1050 +jellyfish MACH_JELLYFISH JELLYFISH 1051 +amanita MACH_AMANITA AMANITA 1052 +vlink MACH_VLINK VLINK 1053 +dexflex MACH_DEXFLEX DEXFLEX 1054 +eigen_ttq MACH_EIGEN_TTQ EIGEN_TTQ 1055 +arcom_titan MACH_ARCOM_TITAN ARCOM_TITAN 1056 +tabla MACH_TABLA TABLA 1057 +mdirac3 MACH_MDIRAC3 MDIRAC3 1058 +mrhfbp2 MACH_MRHFBP2 MRHFBP2 1059 +at91rm9200rb MACH_AT91RM9200RB AT91RM9200RB 1060 +ani_apm MACH_ANI_APM ANI_APM 1061 +ella1 MACH_ELLA1 ELLA1 1062 +inhand_pxa27x MACH_INHAND_PXA27X INHAND_PXA27X 1063 +inhand_pxa25x MACH_INHAND_PXA25X INHAND_PXA25X 1064 +empos_xm MACH_EMPOS_XM EMPOS_XM 1065 +empos MACH_EMPOS EMPOS 1066 +empos_tiny MACH_EMPOS_TINY EMPOS_TINY 1067 +empos_sm MACH_EMPOS_SM EMPOS_SM 1068 +egret MACH_EGRET EGRET 1069 +ostrich MACH_OSTRICH OSTRICH 1070 +n50 MACH_N50 N50 1071 +ecbat91 MACH_ECBAT91 ECBAT91 1072 +stareast MACH_STAREAST STAREAST 1073 +dspg_dw MACH_DSPG_DW DSPG_DW 1074 +onearm MACH_ONEARM ONEARM 1075 +mrg110_6 MACH_MRG110_6 MRG110_6 1076 +wrt300nv2 MACH_WRT300NV2 WRT300NV2 1077 +xm_bulverde MACH_XM_BULVERDE XM_BULVERDE 1078 +msm6100 MACH_MSM6100 MSM6100 1079 +eti_b1 MACH_ETI_B1 ETI_B1 1080 +za9l_series MACH_ZILOG_ZA9L ZILOG_ZA9L 1081 +bit2440 MACH_BIT2440 BIT2440 1082 +nbi MACH_NBI NBI 1083 +smdk2443 MACH_SMDK2443 SMDK2443 1084 +vdavinci MACH_VDAVINCI VDAVINCI 1085 +atc6 MACH_ATC6 ATC6 1086 +multmdw MACH_MULTMDW MULTMDW 1087 +mba2440 MACH_MBA2440 MBA2440 1088 +ecsd MACH_ECSD ECSD 1089 +palmz31 MACH_PALMZ31 PALMZ31 1090 +fsg MACH_FSG FSG 1091 +razor101 MACH_RAZOR101 RAZOR101 1092 +opera_tdm MACH_OPERA_TDM OPERA_TDM 1093 +comcerto MACH_COMCERTO COMCERTO 1094 +tb0319 MACH_TB0319 TB0319 1095 +kws8000 MACH_KWS8000 KWS8000 1096 +b2 MACH_B2 B2 1097 +lcl54 MACH_LCL54 LCL54 1098 +at91sam9260ek MACH_AT91SAM9260EK AT91SAM9260EK 1099 +glantank MACH_GLANTANK GLANTANK 1100 +n2100 MACH_N2100 N2100 1101 +n4100 MACH_N4100 N4100 1102 +rsc4 MACH_VERTICAL_RSC4 VERTICAL_RSC4 1103 +sg8100 MACH_SG8100 SG8100 1104 +im42xx MACH_IM42XX IM42XX 1105 +ftxx MACH_FTXX FTXX 1106 +lwfusion MACH_LWFUSION LWFUSION 1107 +qt2410 MACH_QT2410 QT2410 1108 +kixrp435 MACH_KIXRP435 KIXRP435 1109 +ccw9c MACH_CCW9C CCW9C 1110 +dabhs MACH_DABHS DABHS 1111 +gzmx MACH_GZMX GZMX 1112 +ipnw100ap MACH_IPNW100AP IPNW100AP 1113 +cc9p9360dev MACH_CC9P9360DEV CC9P9360DEV 1114 +cc9p9750dev MACH_CC9P9750DEV CC9P9750DEV 1115 +cc9p9360val MACH_CC9P9360VAL CC9P9360VAL 1116 +cc9p9750val MACH_CC9P9750VAL CC9P9750VAL 1117 +nx70v MACH_NX70V NX70V 1118 +at91rm9200df MACH_AT91RM9200DF AT91RM9200DF 1119 +se_pilot2 MACH_SE_PILOT2 SE_PILOT2 1120 +mtcn_t800 MACH_MTCN_T800 MTCN_T800 1121 +vcmx212 MACH_VCMX212 VCMX212 1122 +lynx MACH_LYNX LYNX 1123 +at91sam9260id MACH_AT91SAM9260ID AT91SAM9260ID 1124 +hw86052 MACH_HW86052 HW86052 1125 +pilz_pmi3 MACH_PILZ_PMI3 PILZ_PMI3 1126 +edb9302a MACH_EDB9302A EDB9302A 1127 +edb9307a MACH_EDB9307A EDB9307A 1128 +ct_dfs MACH_CT_DFS CT_DFS 1129 +pilz_pmi4 MACH_PILZ_PMI4 PILZ_PMI4 1130 +xceednp_ixp MACH_XCEEDNP_IXP XCEEDNP_IXP 1131 +smdk2442b MACH_SMDK2442B SMDK2442B 1132 +xnode MACH_XNODE XNODE 1133 +aidx270 MACH_AIDX270 AIDX270 1134 +rema MACH_REMA REMA 1135 +bps1000 MACH_BPS1000 BPS1000 1136 +hw90350 MACH_HW90350 HW90350 1137 +omap_3430sdp MACH_OMAP_3430SDP OMAP_3430SDP 1138 +bluetouch MACH_BLUETOUCH BLUETOUCH 1139 +vstms MACH_VSTMS VSTMS 1140 +xsbase270 MACH_XSBASE270 XSBASE270 1141 +at91sam9260ek_cn MACH_AT91SAM9260EK_CN AT91SAM9260EK_CN 1142 +adsturboxb MACH_ADSTURBOXB ADSTURBOXB 1143 +oti4110 MACH_OTI4110 OTI4110 1144 +hme_pxa MACH_HME_PXA HME_PXA 1145 +deisterdca MACH_DEISTERDCA DEISTERDCA 1146 +ces_ssem2 MACH_CES_SSEM2 CES_SSEM2 1147 +ces_mtr MACH_CES_MTR CES_MTR 1148 +tds_avng_sbc MACH_TDS_AVNG_SBC TDS_AVNG_SBC 1149 +everest MACH_EVEREST EVEREST 1150 +pnx4010 MACH_PNX4010 PNX4010 1151 +oxnas MACH_OXNAS OXNAS 1152 +fiori MACH_FIORI FIORI 1153 +ml1200 MACH_ML1200 ML1200 1154 +pecos MACH_PECOS PECOS 1155 +nb2xxx MACH_NB2XXX NB2XXX 1156 +hw6900 MACH_HW6900 HW6900 1157 +cdcs_quoll MACH_CDCS_QUOLL CDCS_QUOLL 1158 +quicksilver MACH_QUICKSILVER QUICKSILVER 1159 +uplat926 MACH_UPLAT926 UPLAT926 1160 +dep2410_dep2410 MACH_DEP2410_THOMAS DEP2410_THOMAS 1161 +dtk2410 MACH_DTK2410 DTK2410 1162 +chili MACH_CHILI CHILI 1163 +demeter MACH_DEMETER DEMETER 1164 +dionysus MACH_DIONYSUS DIONYSUS 1165 +as352x MACH_AS352X AS352X 1166 +service MACH_SERVICE SERVICE 1167 +cs_e9301 MACH_CS_E9301 CS_E9301 1168 +micro9m MACH_MICRO9M MICRO9M 1169 +ia_mospck MACH_IA_MOSPCK IA_MOSPCK 1170 +ql201b MACH_QL201B QL201B 1171 +bbm MACH_BBM BBM 1174 +exxx MACH_EXXX EXXX 1175 +wma11b MACH_WMA11B WMA11B 1176 +pelco_atlas MACH_PELCO_ATLAS PELCO_ATLAS 1177 +g500 MACH_G500 G500 1178 +bug MACH_BUG BUG 1179 +mx33ads MACH_MX33ADS MX33ADS 1180 +chub MACH_CHUB CHUB 1181 +neo1973_gta01 MACH_NEO1973_GTA01 NEO1973_GTA01 1182 +w90n740 MACH_W90N740 W90N740 1183 +medallion_sa2410 MACH_MEDALLION_SA2410 MEDALLION_SA2410 1184 +ia_cpu_9200_2 MACH_IA_CPU_9200_2 IA_CPU_9200_2 1185 +dimmrm9200 MACH_DIMMRM9200 DIMMRM9200 1186 +pm9261 MACH_PM9261 PM9261 1187 +ml7304 MACH_ML7304 ML7304 1189 +ucp250 MACH_UCP250 UCP250 1190 +intboard MACH_INTBOARD INTBOARD 1191 +gulfstream MACH_GULFSTREAM GULFSTREAM 1192 +labquest MACH_LABQUEST LABQUEST 1193 +vcmx313 MACH_VCMX313 VCMX313 1194 +urg200 MACH_URG200 URG200 1195 +cpux255lcdnet MACH_CPUX255LCDNET CPUX255LCDNET 1196 +netdcu9 MACH_NETDCU9 NETDCU9 1197 +netdcu10 MACH_NETDCU10 NETDCU10 1198 +dspg_dga MACH_DSPG_DGA DSPG_DGA 1199 +dspg_dvw MACH_DSPG_DVW DSPG_DVW 1200 +solos MACH_SOLOS SOLOS 1201 +at91sam9263ek MACH_AT91SAM9263EK AT91SAM9263EK 1202 +osstbox MACH_OSSTBOX OSSTBOX 1203 +kbat9261 MACH_KBAT9261 KBAT9261 1204 +ct1100 MACH_CT1100 CT1100 1205 +akcppxa MACH_AKCPPXA AKCPPXA 1206 +ochaya1020 MACH_OCHAYA1020 OCHAYA1020 1207 +hitrack MACH_HITRACK HITRACK 1208 +syme1 MACH_SYME1 SYME1 1209 +syhl1 MACH_SYHL1 SYHL1 1210 +empca400 MACH_EMPCA400 EMPCA400 1211 +em7210 MACH_EM7210 EM7210 1212 +htchermes MACH_HTCHERMES HTCHERMES 1213 +eti_c1 MACH_ETI_C1 ETI_C1 1214 +ac100 MACH_AC100 AC100 1216 +sneetch MACH_SNEETCH SNEETCH 1217 +studentmate MACH_STUDENTMATE STUDENTMATE 1218 +zir2410 MACH_ZIR2410 ZIR2410 1219 +zir2413 MACH_ZIR2413 ZIR2413 1220 +dlonip3 MACH_DLONIP3 DLONIP3 1221 +instream MACH_INSTREAM INSTREAM 1222 +ambarella MACH_AMBARELLA AMBARELLA 1223 +nevis MACH_NEVIS NEVIS 1224 +htc_trinity MACH_HTC_TRINITY HTC_TRINITY 1225 +ql202b MACH_QL202B QL202B 1226 +vpac270 MACH_VPAC270 VPAC270 1227 +rd129 MACH_RD129 RD129 1228 +htcwizard MACH_HTCWIZARD HTCWIZARD 1229 +xscale_treo680 MACH_XSCALE_TREO680 XSCALE_TREO680 1230 +tecon_tmezon MACH_TECON_TMEZON TECON_TMEZON 1231 +zylonite MACH_ZYLONITE ZYLONITE 1233 +gene1270 MACH_GENE1270 GENE1270 1234 +zir2412 MACH_ZIR2412 ZIR2412 1235 +mx31lite MACH_MX31LITE MX31LITE 1236 +t700wx MACH_T700WX T700WX 1237 +vf100 MACH_VF100 VF100 1238 +nsb2 MACH_NSB2 NSB2 1239 +nxhmi_bb MACH_NXHMI_BB NXHMI_BB 1240 +nxhmi_re MACH_NXHMI_RE NXHMI_RE 1241 +n4100pro MACH_N4100PRO N4100PRO 1242 +sam9260 MACH_SAM9260 SAM9260 1243 +omap_treo600 MACH_OMAP_TREO600 OMAP_TREO600 1244 +indy2410 MACH_INDY2410 INDY2410 1245 +nelt_a MACH_NELT_A NELT_A 1246 +n311 MACH_N311 N311 1248 +at91sam9260vgk MACH_AT91SAM9260VGK AT91SAM9260VGK 1249 +at91leppe MACH_AT91LEPPE AT91LEPPE 1250 +at91lepccn MACH_AT91LEPCCN AT91LEPCCN 1251 +apc7100 MACH_APC7100 APC7100 1252 +stargazer MACH_STARGAZER STARGAZER 1253 +sonata MACH_SONATA SONATA 1254 +schmoogie MACH_SCHMOOGIE SCHMOOGIE 1255 +aztool MACH_AZTOOL AZTOOL 1256 +mioa701 MACH_MIOA701 MIOA701 1257 +sxni9260 MACH_SXNI9260 SXNI9260 1258 +mxc27520evb MACH_MXC27520EVB MXC27520EVB 1259 +armadillo5x0 MACH_ARMADILLO5X0 ARMADILLO5X0 1260 +mb9260 MACH_MB9260 MB9260 1261 +mb9263 MACH_MB9263 MB9263 1262 +ipac9302 MACH_IPAC9302 IPAC9302 1263 +cc9p9360js MACH_CC9P9360JS CC9P9360JS 1264 +gallium MACH_GALLIUM GALLIUM 1265 +msc2410 MACH_MSC2410 MSC2410 1266 +ghi270 MACH_GHI270 GHI270 1267 +davinci_leonardo MACH_DAVINCI_LEONARDO DAVINCI_LEONARDO 1268 +oiab MACH_OIAB OIAB 1269 +smdk6400 MACH_SMDK6400 SMDK6400 1270 +nokia_n800 MACH_NOKIA_N800 NOKIA_N800 1271 +greenphone MACH_GREENPHONE GREENPHONE 1272 +compex42x MACH_COMPEXWP18 COMPEXWP18 1273 +xmate MACH_XMATE XMATE 1274 +energizer MACH_ENERGIZER ENERGIZER 1275 +ime1 MACH_IME1 IME1 1276 +sweda_tms MACH_SWEDATMS SWEDATMS 1277 +ntnp435c MACH_NTNP435C NTNP435C 1278 +spectro2 MACH_SPECTRO2 SPECTRO2 1279 +h6039 MACH_H6039 H6039 1280 +ep80219 MACH_EP80219 EP80219 1281 +samoa_ii MACH_SAMOA_II SAMOA_II 1282 +cwmxl MACH_CWMXL CWMXL 1283 +as9200 MACH_AS9200 AS9200 1284 +sfx1149 MACH_SFX1149 SFX1149 1285 +navi010 MACH_NAVI010 NAVI010 1286 +multmdp MACH_MULTMDP MULTMDP 1287 +scb9520 MACH_SCB9520 SCB9520 1288 +htcathena MACH_HTCATHENA HTCATHENA 1289 +xp179 MACH_XP179 XP179 1290 +h4300 MACH_H4300 H4300 1291 +goramo_mlr MACH_GORAMO_MLR GORAMO_MLR 1292 +mxc30020evb MACH_MXC30020EVB MXC30020EVB 1293 +adsbitsyg5 MACH_ADSBITSYG5 ADSBITSYG5 1294 +adsportalplus MACH_ADSPORTALPLUS ADSPORTALPLUS 1295 +mmsp2plus MACH_MMSP2PLUS MMSP2PLUS 1296 +em_x270 MACH_EM_X270 EM_X270 1297 +tpp302 MACH_TPP302 TPP302 1298 +tpp104 MACH_TPM104 TPM104 1299 +tpm102 MACH_TPM102 TPM102 1300 +tpm109 MACH_TPM109 TPM109 1301 +fbxo1 MACH_FBXO1 FBXO1 1302 +hxd8 MACH_HXD8 HXD8 1303 +neo1973_gta02 MACH_NEO1973_GTA02 NEO1973_GTA02 1304 +emtest MACH_EMTEST EMTEST 1305 +ad6900 MACH_AD6900 AD6900 1306 +europa MACH_EUROPA EUROPA 1307 +metroconnect MACH_METROCONNECT METROCONNECT 1308 +ez_s2410 MACH_EZ_S2410 EZ_S2410 1309 +ez_s2440 MACH_EZ_S2440 EZ_S2440 1310 +ez_ep9312 MACH_EZ_EP9312 EZ_EP9312 1311 +ez_ep9315 MACH_EZ_EP9315 EZ_EP9315 1312 +ez_x7 MACH_EZ_X7 EZ_X7 1313 +godotdb MACH_GODOTDB GODOTDB 1314 +mistral MACH_MISTRAL MISTRAL 1315 +msm MACH_MSM MSM 1316 +ct5910 MACH_CT5910 CT5910 1317 +ct5912 MACH_CT5912 CT5912 1318 +hynet_ine MACH_HYNET_INE HYNET_INE 1319 +hynet_app MACH_HYNET_APP HYNET_APP 1320 +msm7200 MACH_MSM7200 MSM7200 1321 +msm7600 MACH_MSM7600 MSM7600 1322 +ceb255 MACH_CEB255 CEB255 1323 +ciel MACH_CIEL CIEL 1324 +slm5650 MACH_SLM5650 SLM5650 1325 +at91sam9rlek MACH_AT91SAM9RLEK AT91SAM9RLEK 1326 +comtech_router MACH_COMTECH_ROUTER COMTECH_ROUTER 1327 +sbc2410x MACH_SBC2410X SBC2410X 1328 +at4x0bd MACH_AT4X0BD AT4X0BD 1329 +cbifr MACH_CBIFR CBIFR 1330 +arcom_quantum MACH_ARCOM_QUANTUM ARCOM_QUANTUM 1331 +matrix520 MACH_MATRIX520 MATRIX520 1332 +matrix510 MACH_MATRIX510 MATRIX510 1333 +matrix500 MACH_MATRIX500 MATRIX500 1334 +m501 MACH_M501 M501 1335 +aaeon1270 MACH_AAEON1270 AAEON1270 1336 +matrix500ev MACH_MATRIX500EV MATRIX500EV 1337 +pac500 MACH_PAC500 PAC500 1338 +pnx8181 MACH_PNX8181 PNX8181 1339 +colibri320 MACH_COLIBRI320 COLIBRI320 1340 +aztoolbb MACH_AZTOOLBB AZTOOLBB 1341 +aztoolg2 MACH_AZTOOLG2 AZTOOLG2 1342 +dvlhost MACH_DVLHOST DVLHOST 1343 +zir9200 MACH_ZIR9200 ZIR9200 1344 +zir9260 MACH_ZIR9260 ZIR9260 1345 +cocopah MACH_COCOPAH COCOPAH 1346 +nds MACH_NDS NDS 1347 +rosencrantz MACH_ROSENCRANTZ ROSENCRANTZ 1348 +fttx_odsc MACH_FTTX_ODSC FTTX_ODSC 1349 +classe_r6904 MACH_CLASSE_R6904 CLASSE_R6904 1350 +cam60 MACH_CAM60 CAM60 1351 +mxc30031ads MACH_MXC30031ADS MXC30031ADS 1352 +datacall MACH_DATACALL DATACALL 1353 +at91eb01 MACH_AT91EB01 AT91EB01 1354 +rty MACH_RTY RTY 1355 +dwl2100 MACH_DWL2100 DWL2100 1356 +vinsi MACH_VINSI VINSI 1357 +db88f5281 MACH_DB88F5281 DB88F5281 1358 +csb726 MACH_CSB726 CSB726 1359 +tik27 MACH_TIK27 TIK27 1360 +mx_uc7420 MACH_MX_UC7420 MX_UC7420 1361 +rirm3 MACH_RIRM3 RIRM3 1362 +pelco_odyssey MACH_PELCO_ODYSSEY PELCO_ODYSSEY 1363 +adx_abox MACH_ADX_ABOX ADX_ABOX 1365 +adx_tpid MACH_ADX_TPID ADX_TPID 1366 +minicheck MACH_MINICHECK MINICHECK 1367 +idam MACH_IDAM IDAM 1368 +mario_mx MACH_MARIO_MX MARIO_MX 1369 +vi1888 MACH_VI1888 VI1888 1370 +zr4230 MACH_ZR4230 ZR4230 1371 +t1_ix_blue MACH_T1_IX_BLUE T1_IX_BLUE 1372 +syhq2 MACH_SYHQ2 SYHQ2 1373 +computime_r3 MACH_COMPUTIME_R3 COMPUTIME_R3 1374 +oratis MACH_ORATIS ORATIS 1375 +mikko MACH_MIKKO MIKKO 1376 +holon MACH_HOLON HOLON 1377 +olip8 MACH_OLIP8 OLIP8 1378 +ghi270hg MACH_GHI270HG GHI270HG 1379 +davinci_dm6467_evm MACH_DAVINCI_DM6467_EVM DAVINCI_DM6467_EVM 1380 +davinci_dm355_evm MACH_DAVINCI_DM350_EVM DAVINCI_DM350_EVM 1381 +blackriver MACH_BLACKRIVER BLACKRIVER 1383 +sandgate_wp MACH_SANDGATEWP SANDGATEWP 1384 +cdotbwsg MACH_CDOTBWSG CDOTBWSG 1385 +quark963 MACH_QUARK963 QUARK963 1386 +csb735 MACH_CSB735 CSB735 1387 +littleton MACH_LITTLETON LITTLETON 1388 +mio_p550 MACH_MIO_P550 MIO_P550 1389 +motion2440 MACH_MOTION2440 MOTION2440 1390 +imm500 MACH_IMM500 IMM500 1391 +homematic MACH_HOMEMATIC HOMEMATIC 1392 +ermine MACH_ERMINE ERMINE 1393 +kb9202b MACH_KB9202B KB9202B 1394 +hs1xx MACH_HS1XX HS1XX 1395 +studentmate2440 MACH_STUDENTMATE2440 STUDENTMATE2440 1396 +arvoo_l1_z1 MACH_ARVOO_L1_Z1 ARVOO_L1_Z1 1397 +dep2410k MACH_DEP2410K DEP2410K 1398 +xxsvideo MACH_XXSVIDEO XXSVIDEO 1399 +im4004 MACH_IM4004 IM4004 1400 +ochaya1050 MACH_OCHAYA1050 OCHAYA1050 1401 +lep9261 MACH_LEP9261 LEP9261 1402 +svenmeb MACH_SVENMEB SVENMEB 1403 +fortunet2ne MACH_FORTUNET2NE FORTUNET2NE 1404 +nxhx MACH_NXHX NXHX 1406 +realview_pb11mp MACH_REALVIEW_PB11MP REALVIEW_PB11MP 1407 +ids500 MACH_IDS500 IDS500 1408 +ors_n725 MACH_ORS_N725 ORS_N725 1409 +hsdarm MACH_HSDARM HSDARM 1410 +sha_pon003 MACH_SHA_PON003 SHA_PON003 1411 +sha_pon004 MACH_SHA_PON004 SHA_PON004 1412 +sha_pon007 MACH_SHA_PON007 SHA_PON007 1413 +sha_pon011 MACH_SHA_PON011 SHA_PON011 1414 +h6042 MACH_H6042 H6042 1415 +h6043 MACH_H6043 H6043 1416 +looxc550 MACH_LOOXC550 LOOXC550 1417 +cnty_titan MACH_CNTY_TITAN CNTY_TITAN 1418 +app3xx MACH_APP3XX APP3XX 1419 +sideoatsgrama MACH_SIDEOATSGRAMA SIDEOATSGRAMA 1420 +palmtreo700p MACH_PALMTREO700P PALMTREO700P 1421 +palmtreo700w MACH_PALMTREO700W PALMTREO700W 1422 +palmtreo750 MACH_PALMTREO750 PALMTREO750 1423 +palmtreo755p MACH_PALMTREO755P PALMTREO755P 1424 +ezreganut9200 MACH_EZREGANUT9200 EZREGANUT9200 1425 +sarge MACH_SARGE SARGE 1426 +a696 MACH_A696 A696 1427 +turtle1916 MACH_TURTLE TURTLE 1428 +mx27_3ds MACH_MX27_3DS MX27_3DS 1430 +bishop MACH_BISHOP BISHOP 1431 +pxx MACH_PXX PXX 1432 +redwood MACH_REDWOOD REDWOOD 1433 +omap_2430dlp MACH_OMAP_2430DLP OMAP_2430DLP 1436 +omap_2430osk MACH_OMAP_2430OSK OMAP_2430OSK 1437 +sardine MACH_SARDINE SARDINE 1438 +halibut MACH_HALIBUT HALIBUT 1439 +trout MACH_TROUT TROUT 1440 +goldfish MACH_GOLDFISH GOLDFISH 1441 +gesbc2440 MACH_GESBC2440 GESBC2440 1442 +nomad MACH_NOMAD NOMAD 1443 +rosalind MACH_ROSALIND ROSALIND 1444 +cc9p9215 MACH_CC9P9215 CC9P9215 1445 +cc9p9210 MACH_CC9P9210 CC9P9210 1446 +cc9p9215js MACH_CC9P9215JS CC9P9215JS 1447 +cc9p9210js MACH_CC9P9210JS CC9P9210JS 1448 +nasffe MACH_NASFFE NASFFE 1449 +tn2x0bd MACH_TN2X0BD TN2X0BD 1450 +gwmpxa MACH_GWMPXA GWMPXA 1451 +exyplus MACH_EXYPLUS EXYPLUS 1452 +jadoo21 MACH_JADOO21 JADOO21 1453 +looxn560 MACH_LOOXN560 LOOXN560 1454 +bonsai MACH_BONSAI BONSAI 1455 +adsmilgato MACH_ADSMILGATO ADSMILGATO 1456 +gba MACH_GBA GBA 1457 +h6044 MACH_H6044 H6044 1458 +app MACH_APP APP 1459 +tct_hammer MACH_TCT_HAMMER TCT_HAMMER 1460 +herald MACH_HERMES HERMES 1461 +artemis MACH_ARTEMIS ARTEMIS 1462 +htctitan MACH_HTCTITAN HTCTITAN 1463 +qranium MACH_QRANIUM QRANIUM 1464 +adx_wsc2 MACH_ADX_WSC2 ADX_WSC2 1465 +adx_medcom MACH_ADX_MEDCOM ADX_MEDCOM 1466 +bboard MACH_BBOARD BBOARD 1467 +cambria MACH_CAMBRIA CAMBRIA 1468 +mt7xxx MACH_MT7XXX MT7XXX 1469 +matrix512 MACH_MATRIX512 MATRIX512 1470 +matrix522 MACH_MATRIX522 MATRIX522 1471 +ipac5010 MACH_IPAC5010 IPAC5010 1472 +sakura MACH_SAKURA SAKURA 1473 +grocx MACH_GROCX GROCX 1474 +pm9263 MACH_PM9263 PM9263 1475 +sim_one MACH_SIM_ONE SIM_ONE 1476 +acq132 MACH_ACQ132 ACQ132 1477 +datr MACH_DATR DATR 1478 +actux1 MACH_ACTUX1 ACTUX1 1479 +actux2 MACH_ACTUX2 ACTUX2 1480 +actux3 MACH_ACTUX3 ACTUX3 1481 +flexit MACH_FLEXIT FLEXIT 1482 +bh2x0bd MACH_BH2X0BD BH2X0BD 1483 +atb2002 MACH_ATB2002 ATB2002 1484 +xenon MACH_XENON XENON 1485 +fm607 MACH_FM607 FM607 1486 +matrix514 MACH_MATRIX514 MATRIX514 1487 +matrix524 MACH_MATRIX524 MATRIX524 1488 +inpod MACH_INPOD INPOD 1489 +jive MACH_JIVE JIVE 1490 +tll_mx21 MACH_TLL_MX21 TLL_MX21 1491 +sbc2800 MACH_SBC2800 SBC2800 1492 +cc7ucamry MACH_CC7UCAMRY CC7UCAMRY 1493 +ubisys_p9_sc15 MACH_UBISYS_P9_SC15 UBISYS_P9_SC15 1494 +ubisys_p9_ssc2d10 MACH_UBISYS_P9_SSC2D10 UBISYS_P9_SSC2D10 1495 +ubisys_p9_rcu3 MACH_UBISYS_P9_RCU3 UBISYS_P9_RCU3 1496 +aml_m8000 MACH_AML_M8000 AML_M8000 1497 +snapper_270 MACH_SNAPPER_270 SNAPPER_270 1498 +omap_bbx MACH_OMAP_BBX OMAP_BBX 1499 +ucn2410 MACH_UCN2410 UCN2410 1500 +sam9_l9260 MACH_SAM9_L9260 SAM9_L9260 1501 +eti_c2 MACH_ETI_C2 ETI_C2 1502 +avalanche MACH_AVALANCHE AVALANCHE 1503 +realview_pb1176 MACH_REALVIEW_PB1176 REALVIEW_PB1176 1504 +dp1500 MACH_DP1500 DP1500 1505 +apple_iphone MACH_APPLE_IPHONE APPLE_IPHONE 1506 +yl9200 MACH_YL9200 YL9200 1507 +rd88f5182 MACH_RD88F5182 RD88F5182 1508 +kurobox_pro MACH_KUROBOX_PRO KUROBOX_PRO 1509 +se_poet MACH_SE_POET SE_POET 1510 +mx31_3ds MACH_MX31_3DS MX31_3DS 1511 +r270 MACH_R270 R270 1512 +armour21 MACH_ARMOUR21 ARMOUR21 1513 +dt2 MACH_DT2 DT2 1514 +vt4 MACH_VT4 VT4 1515 +tyco320 MACH_TYCO320 TYCO320 1516 +adma MACH_ADMA ADMA 1517 +wp188 MACH_WP188 WP188 1518 +corsica MACH_CORSICA CORSICA 1519 +bigeye MACH_BIGEYE BIGEYE 1520 +tll5000 MACH_TLL5000 TLL5000 1522 +bebot MACH_BEBOT BEBOT 1523 +qong MACH_QONG QONG 1524 +tcompact MACH_TCOMPACT TCOMPACT 1525 +puma5 MACH_PUMA5 PUMA5 1526 +elara MACH_ELARA ELARA 1527 +ellington MACH_ELLINGTON ELLINGTON 1528 +xda_atom MACH_XDA_ATOM XDA_ATOM 1529 +energizer2 MACH_ENERGIZER2 ENERGIZER2 1530 +odin MACH_ODIN ODIN 1531 +actux4 MACH_ACTUX4 ACTUX4 1532 +esl_omap MACH_ESL_OMAP ESL_OMAP 1533 +omap2evm MACH_OMAP2EVM OMAP2EVM 1534 +omap3evm MACH_OMAP3EVM OMAP3EVM 1535 +adx_pcu57 MACH_ADX_PCU57 ADX_PCU57 1536 +monaco MACH_MONACO MONACO 1537 +levante MACH_LEVANTE LEVANTE 1538 +tmxipx425 MACH_TMXIPX425 TMXIPX425 1539 +leep MACH_LEEP LEEP 1540 +raad MACH_RAAD RAAD 1541 +dns323 MACH_DNS323 DNS323 1542 +ap1000 MACH_AP1000 AP1000 1543 +a9sam6432 MACH_A9SAM6432 A9SAM6432 1544 +shiny MACH_SHINY SHINY 1545 +omap3_beagle MACH_OMAP3_BEAGLE OMAP3_BEAGLE 1546 +csr_bdb2 MACH_CSR_BDB2 CSR_BDB2 1547 +nokia_n810 MACH_NOKIA_N810 NOKIA_N810 1548 +c270 MACH_C270 C270 1549 +sentry MACH_SENTRY SENTRY 1550 +pcm038 MACH_PCM038 PCM038 1551 +anc300 MACH_ANC300 ANC300 1552 +htckaiser MACH_HTCKAISER HTCKAISER 1553 +sbat100 MACH_SBAT100 SBAT100 1554 +modunorm MACH_MODUNORM MODUNORM 1555 +pelos_twarm MACH_PELOS_TWARM PELOS_TWARM 1556 +flank MACH_FLANK FLANK 1557 +sirloin MACH_SIRLOIN SIRLOIN 1558 +brisket MACH_BRISKET BRISKET 1559 +chuck MACH_CHUCK CHUCK 1560 +otter MACH_OTTER OTTER 1561 +davinci_ldk MACH_DAVINCI_LDK DAVINCI_LDK 1562 +phreedom MACH_PHREEDOM PHREEDOM 1563 +sg310 MACH_SG310 SG310 1564 +ts_x09 MACH_TS209 TS209 1565 +at91cap9adk MACH_AT91CAP9ADK AT91CAP9ADK 1566 +tion9315 MACH_TION9315 TION9315 1567 +mast MACH_MAST MAST 1568 +pfw MACH_PFW PFW 1569 +yl_p2440 MACH_YL_P2440 YL_P2440 1570 +zsbc32 MACH_ZSBC32 ZSBC32 1571 +omap_pace2 MACH_OMAP_PACE2 OMAP_PACE2 1572 +imx_pace2 MACH_IMX_PACE2 IMX_PACE2 1573 +mx31moboard MACH_MX31MOBOARD MX31MOBOARD 1574 +mx37_3ds MACH_MX37_3DS MX37_3DS 1575 +rcc MACH_RCC RCC 1576 +dmp MACH_ARM9 ARM9 1577 +vision_ep9307 MACH_VISION_EP9307 VISION_EP9307 1578 +scly1000 MACH_SCLY1000 SCLY1000 1579 +fontel_ep MACH_FONTEL_EP FONTEL_EP 1580 +voiceblue3g MACH_VOICEBLUE3G VOICEBLUE3G 1581 +tt9200 MACH_TT9200 TT9200 1582 +digi2410 MACH_DIGI2410 DIGI2410 1583 +terastation_pro2 MACH_TERASTATION_PRO2 TERASTATION_PRO2 1584 +linkstation_pro MACH_LINKSTATION_PRO LINKSTATION_PRO 1585 +motorola_a780 MACH_MOTOROLA_A780 MOTOROLA_A780 1587 +motorola_e6 MACH_MOTOROLA_E6 MOTOROLA_E6 1588 +motorola_e2 MACH_MOTOROLA_E2 MOTOROLA_E2 1589 +motorola_e680 MACH_MOTOROLA_E680 MOTOROLA_E680 1590 +ur2410 MACH_UR2410 UR2410 1591 +tas9261 MACH_TAS9261 TAS9261 1592 +davinci_hermes_hd MACH_HERMES_HD HERMES_HD 1593 +davinci_perseo_hd MACH_PERSEO_HD PERSEO_HD 1594 +stargazer2 MACH_STARGAZER2 STARGAZER2 1595 +e350 MACH_E350 E350 1596 +wpcm450 MACH_WPCM450 WPCM450 1597 +cartesio MACH_CARTESIO CARTESIO 1598 +toybox MACH_TOYBOX TOYBOX 1599 +tx27 MACH_TX27 TX27 1600 +ts409 MACH_TS409 TS409 1601 +p300 MACH_P300 P300 1602 +xdacomet MACH_XDACOMET XDACOMET 1603 +dexflex2 MACH_DEXFLEX2 DEXFLEX2 1604 +ow MACH_OW OW 1605 +armebs3 MACH_ARMEBS3 ARMEBS3 1606 +u3 MACH_U3 U3 1607 +smdk2450 MACH_SMDK2450 SMDK2450 1608 +rsi_ews MACH_RSI_EWS RSI_EWS 1609 +tnb MACH_TNB TNB 1610 +toepath MACH_TOEPATH TOEPATH 1611 +kb9263 MACH_KB9263 KB9263 1612 +mt7108 MACH_MT7108 MT7108 1613 +smtr2440 MACH_SMTR2440 SMTR2440 1614 +manao MACH_MANAO MANAO 1615 +cm_x300 MACH_CM_X300 CM_X300 1616 +gulfstream_kp MACH_GULFSTREAM_KP GULFSTREAM_KP 1617 +lanreadyfn522 MACH_LANREADYFN522 LANREADYFN522 1618 +arma37 MACH_ARMA37 ARMA37 1619 +mendel MACH_MENDEL MENDEL 1620 +pelco_iliad MACH_PELCO_ILIAD PELCO_ILIAD 1621 +unit2p MACH_UNIT2P UNIT2P 1622 +inc20otter MACH_INC20OTTER INC20OTTER 1623 +at91sam9g20ek MACH_AT91SAM9G20EK AT91SAM9G20EK 1624 +sc_ge2 MACH_STORCENTER STORCENTER 1625 +smdk6410 MACH_SMDK6410 SMDK6410 1626 +u300 MACH_U300 U300 1627 +u500 MACH_U500 U500 1628 +ds9260 MACH_DS9260 DS9260 1629 +riverrock MACH_RIVERROCK RIVERROCK 1630 +scibath MACH_SCIBATH SCIBATH 1631 +at91sam7se MACH_AT91SAM7SE512EK AT91SAM7SE512EK 1632 +wrt350n_v2 MACH_WRT350N_V2 WRT350N_V2 1633 +multimedia MACH_MULTIMEDIA MULTIMEDIA 1634 +marvin MACH_MARVIN MARVIN 1635 +x500 MACH_X500 X500 1636 +awlug4lcu MACH_AWLUG4LCU AWLUG4LCU 1637 +palermoc MACH_PALERMOC PALERMOC 1638 +omap_ldp MACH_OMAP_LDP OMAP_LDP 1639 +ip500 MACH_IP500 IP500 1640 +ase2 MACH_ASE2 ASE2 1642 +mx35evb MACH_MX35EVB MX35EVB 1643 +aml_m8050 MACH_AML_M8050 AML_M8050 1644 +mx35_3ds MACH_MX35_3DS MX35_3DS 1645 +mars MACH_MARS MARS 1646 +ntosd_644xa MACH_NTOSD_644XA NTOSD_644XA 1647 +badger MACH_BADGER BADGER 1648 +trizeps4wl MACH_TRIZEPS4WL TRIZEPS4WL 1649 +trizeps5 MACH_TRIZEPS5 TRIZEPS5 1650 +marlin MACH_MARLIN MARLIN 1651 +ts78xx MACH_TS78XX TS78XX 1652 +hpipaq214 MACH_HPIPAQ214 HPIPAQ214 1653 +at572d940dcm MACH_AT572D940DCM AT572D940DCM 1654 +ne1board MACH_NE1BOARD NE1BOARD 1655 +zante MACH_ZANTE ZANTE 1656 +sffsdr MACH_SFFSDR SFFSDR 1657 +tw2662 MACH_TW2662 TW2662 1658 +vf10xx MACH_VF10XX VF10XX 1659 +zoran43xx MACH_ZORAN43XX ZORAN43XX 1660 +sonix926 MACH_SONIX926 SONIX926 1661 +celestialsemi MACH_CELESTIALSEMI CELESTIALSEMI 1662 +cc9m2443 MACH_CC9M2443 CC9M2443 1663 +tw5334 MACH_TW5334 TW5334 1664 +omap_htcartemis MACH_HTCARTEMIS HTCARTEMIS 1665 +nal_hlite MACH_NAL_HLITE NAL_HLITE 1666 +htcvogue MACH_HTCVOGUE HTCVOGUE 1667 +smartweb MACH_SMARTWEB SMARTWEB 1668 +mv86xx MACH_MV86XX MV86XX 1669 +mv87xx MACH_MV87XX MV87XX 1670 +songyoungho MACH_SONGYOUNGHO SONGYOUNGHO 1671 +younghotema MACH_YOUNGHOTEMA YOUNGHOTEMA 1672 +pcm037 MACH_PCM037 PCM037 1673 +mmvp MACH_MMVP MMVP 1674 +mmap MACH_MMAP MMAP 1675 +ptid2410 MACH_PTID2410 PTID2410 1676 +james_926 MACH_JAMES_926 JAMES_926 1677 +fm6000 MACH_FM6000 FM6000 1678 +db88f6281_bp MACH_DB88F6281_BP DB88F6281_BP 1680 +rd88f6192_nas MACH_RD88F6192_NAS RD88F6192_NAS 1681 +rd88f6281 MACH_RD88F6281 RD88F6281 1682 +db78x00_bp MACH_DB78X00_BP DB78X00_BP 1683 +smdk2416 MACH_SMDK2416 SMDK2416 1685 +oce_spider_si MACH_OCE_SPIDER_SI OCE_SPIDER_SI 1686 +oce_spider_sk MACH_OCE_SPIDER_SK OCE_SPIDER_SK 1687 +rovern6 MACH_ROVERN6 ROVERN6 1688 +pelco_evolution MACH_PELCO_EVOLUTION PELCO_EVOLUTION 1689 +wbd111 MACH_WBD111 WBD111 1690 +elaracpe MACH_ELARACPE ELARACPE 1691 +mabv3 MACH_MABV3 MABV3 1692 +mv2120 MACH_MV2120 MV2120 1693 +csb737 MACH_CSB737 CSB737 1695 +mx51_3ds MACH_MX51_3DS MX51_3DS 1696 +g900 MACH_G900 G900 1697 +apf27 MACH_APF27 APF27 1698 +ggus2000 MACH_GGUS2000 GGUS2000 1699 +omap_2430_mimic MACH_OMAP_2430_MIMIC OMAP_2430_MIMIC 1700 +imx27lite MACH_IMX27LITE IMX27LITE 1701 +almex MACH_ALMEX ALMEX 1702 +control MACH_CONTROL CONTROL 1703 +mba2410 MACH_MBA2410 MBA2410 1704 +volcano MACH_VOLCANO VOLCANO 1705 +zenith MACH_ZENITH ZENITH 1706 +muchip MACH_MUCHIP MUCHIP 1707 +magellan MACH_MAGELLAN MAGELLAN 1708 +usb_a9260 MACH_USB_A9260 USB_A9260 1709 +usb_a9263 MACH_USB_A9263 USB_A9263 1710 +qil_a9260 MACH_QIL_A9260 QIL_A9260 1711 +cme9210 MACH_CME9210 CME9210 1712 +hczh4 MACH_HCZH4 HCZH4 1713 +spearbasic MACH_SPEARBASIC SPEARBASIC 1714 +dep2440 MACH_DEP2440 DEP2440 1715 +hdl_gxr MACH_HDL_GXR HDL_GXR 1716 +hdl_gt MACH_HDL_GT HDL_GT 1717 +hdl_4g MACH_HDL_4G HDL_4G 1718 +s3c6000 MACH_S3C6000 S3C6000 1719 +mmsp2_mdk MACH_MMSP2_MDK MMSP2_MDK 1720 +mpx220 MACH_MPX220 MPX220 1721 +kzm_arm11_01 MACH_KZM_ARM11_01 KZM_ARM11_01 1722 +htc_polaris MACH_HTC_POLARIS HTC_POLARIS 1723 +htc_kaiser MACH_HTC_KAISER HTC_KAISER 1724 +lg_ks20 MACH_LG_KS20 LG_KS20 1725 +hhgps MACH_HHGPS HHGPS 1726 +nokia_n810_wimax MACH_NOKIA_N810_WIMAX NOKIA_N810_WIMAX 1727 +insight MACH_INSIGHT INSIGHT 1728 +sapphire MACH_SAPPHIRE SAPPHIRE 1729 +csb637xo MACH_CSB637XO CSB637XO 1730 +evisiong MACH_EVISIONG EVISIONG 1731 +stmp37xx MACH_STMP37XX STMP37XX 1732 +stmp378x MACH_STMP38XX STMP38XX 1733 +tnt MACH_TNT TNT 1734 +tbxt MACH_TBXT TBXT 1735 +playmate MACH_PLAYMATE PLAYMATE 1736 +pns10 MACH_PNS10 PNS10 1737 +eznavi MACH_EZNAVI EZNAVI 1738 +ps4000 MACH_PS4000 PS4000 1739 +ezx_a780 MACH_EZX_A780 EZX_A780 1740 +ezx_e680 MACH_EZX_E680 EZX_E680 1741 +ezx_a1200 MACH_EZX_A1200 EZX_A1200 1742 +ezx_e6 MACH_EZX_E6 EZX_E6 1743 +ezx_e2 MACH_EZX_E2 EZX_E2 1744 +ezx_a910 MACH_EZX_A910 EZX_A910 1745 +cwmx31 MACH_CWMX31 CWMX31 1746 +sl2312 MACH_SL2312 SL2312 1747 +blenny MACH_BLENNY BLENNY 1748 +ds107 MACH_DS107 DS107 1749 +dsx07 MACH_DSX07 DSX07 1750 +picocom1 MACH_PICOCOM1 PICOCOM1 1751 +lynx_wolverine MACH_LYNX_WOLVERINE LYNX_WOLVERINE 1752 +ubisys_p9_sc19 MACH_UBISYS_P9_SC19 UBISYS_P9_SC19 1753 +kratos_low MACH_KRATOS_LOW KRATOS_LOW 1754 +m700 MACH_M700 M700 1755 +edmini_v2 MACH_EDMINI_V2 EDMINI_V2 1756 +zipit2 MACH_ZIPIT2 ZIPIT2 1757 +hslfemtocell MACH_HSLFEMTOCELL HSLFEMTOCELL 1758 +daintree_at91 MACH_DAINTREE_AT91 DAINTREE_AT91 1759 +sg560usb MACH_SG560USB SG560USB 1760 +omap3_pandora MACH_OMAP3_PANDORA OMAP3_PANDORA 1761 +usr8200 MACH_USR8200 USR8200 1762 +s1s65k MACH_S1S65K S1S65K 1763 +s2s65a MACH_S2S65A S2S65A 1764 +icore MACH_ICORE ICORE 1765 +mss2 MACH_MSS2 MSS2 1766 +belmont MACH_BELMONT BELMONT 1767 +asusp525 MACH_ASUSP525 ASUSP525 1768 +lb88rc8480 MACH_LB88RC8480 LB88RC8480 1769 +hipxa MACH_HIPXA HIPXA 1770 +mx25_3ds MACH_MX25_3DS MX25_3DS 1771 +m800 MACH_M800 M800 1772 +omap3530_lv_som MACH_OMAP3530_LV_SOM OMAP3530_LV_SOM 1773 +prima_evb MACH_PRIMA_EVB PRIMA_EVB 1774 +mx31bt1 MACH_MX31BT1 MX31BT1 1775 +atlas4_evb MACH_ATLAS4_EVB ATLAS4_EVB 1776 +mx31cicada MACH_MX31CICADA MX31CICADA 1777 +mi424wr MACH_MI424WR MI424WR 1778 +axs_ultrax MACH_AXS_ULTRAX AXS_ULTRAX 1779 +at572d940deb MACH_AT572D940DEB AT572D940DEB 1780 +davinci_da8xx_evm MACH_DAVINCI_DA8XX_EVM DAVINCI_DA8XX_EVM 1781 +ep9302 MACH_EP9302 EP9302 1782 +at572d940hfeb MACH_AT572D940HFEB AT572D940HFEB 1783 +cybook3 MACH_CYBOOK3 CYBOOK3 1784 +wdg002 MACH_WDG002 WDG002 1785 +sg560adsl MACH_SG560ADSL SG560ADSL 1786 +nextio_n2800_ica MACH_NEXTIO_N2800_ICA NEXTIO_N2800_ICA 1787 +marvell_newdb MACH_MARVELL_NEWDB MARVELL_NEWDB 1789 +vandihud MACH_VANDIHUD VANDIHUD 1790 +magx_e8 MACH_MAGX_E8 MAGX_E8 1791 +magx_z6 MACH_MAGX_Z6 MAGX_Z6 1792 +magx_v8 MACH_MAGX_V8 MAGX_V8 1793 +magx_u9 MACH_MAGX_U9 MAGX_U9 1794 +toughcf08 MACH_TOUGHCF08 TOUGHCF08 1795 +zw4400 MACH_ZW4400 ZW4400 1796 +marat91 MACH_MARAT91 MARAT91 1797 +overo MACH_OVERO OVERO 1798 +at2440evb MACH_AT2440EVB AT2440EVB 1799 +neocore926 MACH_NEOCORE926 NEOCORE926 1800 +wnr854t MACH_WNR854T WNR854T 1801 +imx27 MACH_IMX27 IMX27 1802 +moose_db MACH_MOOSE_DB MOOSE_DB 1803 +fab4 MACH_FAB4 FAB4 1804 +htcdiamond MACH_HTCDIAMOND HTCDIAMOND 1805 +fiona MACH_FIONA FIONA 1806 +mxc30030_x MACH_MXC30030_X MXC30030_X 1807 +bmp1000 MACH_BMP1000 BMP1000 1808 +logi9200 MACH_LOGI9200 LOGI9200 1809 +tqma31 MACH_TQMA31 TQMA31 1810 +ccw9p9215js MACH_CCW9P9215JS CCW9P9215JS 1811 +rd88f5181l_ge MACH_RD88F5181L_GE RD88F5181L_GE 1812 +sifmain MACH_SIFMAIN SIFMAIN 1813 +sam9_l9261 MACH_SAM9_L9261 SAM9_L9261 1814 +cc9m2443js MACH_CC9M2443JS CC9M2443JS 1815 +xaria300 MACH_XARIA300 XARIA300 1816 +it9200 MACH_IT9200 IT9200 1817 +rd88f5181l_fxo MACH_RD88F5181L_FXO RD88F5181L_FXO 1818 +kriss_sensor MACH_KRISS_SENSOR KRISS_SENSOR 1819 +pilz_pmi5 MACH_PILZ_PMI5 PILZ_PMI5 1820 +jade MACH_JADE JADE 1821 +ks8695_softplc MACH_KS8695_SOFTPLC KS8695_SOFTPLC 1822 +gprisc3 MACH_GPRISC3 GPRISC3 1823 +stamp9260 MACH_STAMP9260 STAMP9260 1824 +smdk6430 MACH_SMDK6430 SMDK6430 1825 +smdkc100 MACH_SMDKC100 SMDKC100 1826 +tavorevb MACH_TAVOREVB TAVOREVB 1827 +saar MACH_SAAR SAAR 1828 +deister_eyecam MACH_DEISTER_EYECAM DEISTER_EYECAM 1829 +at91sam9m10ek MACH_AT91SAM9M10EK AT91SAM9M10EK 1830 +linkstation_produo MACH_LINKSTATION_PRODUO LINKSTATION_PRODUO 1831 +hit_b0 MACH_HIT_B0 HIT_B0 1832 +adx_rmu MACH_ADX_RMU ADX_RMU 1833 +xg_cpe_main MACH_XG_CPE_MAIN XG_CPE_MAIN 1834 +edb9407a MACH_EDB9407A EDB9407A 1835 +dtb9608 MACH_DTB9608 DTB9608 1836 +em104v1 MACH_EM104V1 EM104V1 1837 +demo MACH_DEMO DEMO 1838 +logi9260 MACH_LOGI9260 LOGI9260 1839 +mx31_exm32 MACH_MX31_EXM32 MX31_EXM32 1840 +usb_a9g20 MACH_USB_A9G20 USB_A9G20 1841 +picproje2008 MACH_PICPROJE2008 PICPROJE2008 1842 +cs_e9315 MACH_CS_E9315 CS_E9315 1843 +qil_a9g20 MACH_QIL_A9G20 QIL_A9G20 1844 +sha_pon020 MACH_SHA_PON020 SHA_PON020 1845 +nad MACH_NAD NAD 1846 +sbc35_a9260 MACH_SBC35_A9260 SBC35_A9260 1847 +sbc35_a9g20 MACH_SBC35_A9G20 SBC35_A9G20 1848 +davinci_beginning MACH_DAVINCI_BEGINNING DAVINCI_BEGINNING 1849 +uwc MACH_UWC UWC 1850 +mxlads MACH_MXLADS MXLADS 1851 +htcnike MACH_HTCNIKE HTCNIKE 1852 +deister_pxa270 MACH_DEISTER_PXA270 DEISTER_PXA270 1853 +cme9210js MACH_CME9210JS CME9210JS 1854 +cc9p9360 MACH_CC9P9360 CC9P9360 1855 +mocha MACH_MOCHA MOCHA 1856 +wapd170ag MACH_WAPD170AG WAPD170AG 1857 +linkstation_mini MACH_LINKSTATION_MINI LINKSTATION_MINI 1858 +afeb9260 MACH_AFEB9260 AFEB9260 1859 +w90x900 MACH_W90X900 W90X900 1860 +w90x700 MACH_W90X700 W90X700 1861 +kt300ip MACH_KT300IP KT300IP 1862 +kt300ip_g20 MACH_KT300IP_G20 KT300IP_G20 1863 +srcm MACH_SRCM SRCM 1864 +wlnx_9260 MACH_WLNX_9260 WLNX_9260 1865 +openmoko_gta03 MACH_OPENMOKO_GTA03 OPENMOKO_GTA03 1866 +osprey2 MACH_OSPREY2 OSPREY2 1867 +kbio9260 MACH_KBIO9260 KBIO9260 1868 +ginza MACH_GINZA GINZA 1869 +a636n MACH_A636N A636N 1870 +imx27ipcam MACH_IMX27IPCAM IMX27IPCAM 1871 +nemoc MACH_NEMOC NEMOC 1872 +geneva MACH_GENEVA GENEVA 1873 +htcpharos MACH_HTCPHAROS HTCPHAROS 1874 +neonc MACH_NEONC NEONC 1875 +nas7100 MACH_NAS7100 NAS7100 1876 +teuphone MACH_TEUPHONE TEUPHONE 1877 +annax_eth2 MACH_ANNAX_ETH2 ANNAX_ETH2 1878 +csb733 MACH_CSB733 CSB733 1879 +bk3 MACH_BK3 BK3 1880 +omap_em32 MACH_OMAP_EM32 OMAP_EM32 1881 +et9261cp MACH_ET9261CP ET9261CP 1882 +jasperc MACH_JASPERC JASPERC 1883 +issi_arm9 MACH_ISSI_ARM9 ISSI_ARM9 1884 +ued MACH_UED UED 1885 +esiblade MACH_ESIBLADE ESIBLADE 1886 +eye02 MACH_EYE02 EYE02 1887 +imx27kbd MACH_IMX27KBD IMX27KBD 1888 +sst61vc010_fpga MACH_SST61VC010_FPGA SST61VC010_FPGA 1889 +kixvp435 MACH_KIXVP435 KIXVP435 1890 +kixnp435 MACH_KIXNP435 KIXNP435 1891 +africa MACH_AFRICA AFRICA 1892 +nh233 MACH_NH233 NH233 1893 +rd88f6183ap_ge MACH_RD88F6183AP_GE RD88F6183AP_GE 1894 +bcm4760 MACH_BCM4760 BCM4760 1895 +eddy_v2 MACH_EDDY_V2 EDDY_V2 1896 +realview_pba8 MACH_REALVIEW_PBA8 REALVIEW_PBA8 1897 +hid_a7 MACH_HID_A7 HID_A7 1898 +hero MACH_HERO HERO 1899 +omap_poseidon MACH_OMAP_POSEIDON OMAP_POSEIDON 1900 +realview_pbx MACH_REALVIEW_PBX REALVIEW_PBX 1901 +micro9s MACH_MICRO9S MICRO9S 1902 +mako MACH_MAKO MAKO 1903 +xdaflame MACH_XDAFLAME XDAFLAME 1904 +phidget_sbc2 MACH_PHIDGET_SBC2 PHIDGET_SBC2 1905 +limestone MACH_LIMESTONE LIMESTONE 1906 +iprobe_c32 MACH_IPROBE_C32 IPROBE_C32 1907 +rut100 MACH_RUT100 RUT100 1908 +asusp535 MACH_ASUSP535 ASUSP535 1909 +htcraphael MACH_HTCRAPHAEL HTCRAPHAEL 1910 +sygdg1 MACH_SYGDG1 SYGDG1 1911
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
diff --git a/board/apollon/apollon.c b/board/apollon/apollon.c index 8964eba..47df84a 100644 --- a/board/apollon/apollon.c +++ b/board/apollon/apollon.c @@ -66,7 +66,7 @@ int board_init(void) { gpmc_init(); /* in SRAM or SDRM, finish GPMC */
- gd->bd->bi_arch_number = 919; + gd->bd->bi_arch_number = MACH_TYPE_OMAP_APOLLON; /* adress of boot parameters */ gd->bd->bi_boot_params = (OMAP2420_SDRC_CS0 + 0x100);
diff --git a/board/armadillo/armadillo.c b/board/armadillo/armadillo.c index ca5bd1d..e9be758 100644 --- a/board/armadillo/armadillo.c +++ b/board/armadillo/armadillo.c @@ -42,8 +42,7 @@ int board_init (void) /* Activate LED flasher */ IO_LEDFLSH = 0x40;
- /* arch number MACH_TYPE_ARMADILLO - not official*/ - gd->bd->bi_arch_number = 83; + gd->bd->bi_arch_number = MACH_TYPE_ARMADILLO;
/* location of boot parameters */ gd->bd->bi_boot_params = 0xc0000100; diff --git a/board/cm4008/cm4008.c b/board/cm4008/cm4008.c index d34737c..0744905 100644 --- a/board/cm4008/cm4008.c +++ b/board/cm4008/cm4008.c @@ -78,7 +78,7 @@ int board_late_init (void) int board_init (void) { /* arch number of CM4008 */ - gd->bd->bi_arch_number = 624; + gd->bd->bi_arch_number = MACH_TYPE_CM4008;
/* adress of boot parameters */ gd->bd->bi_boot_params = 0x00000100; diff --git a/board/cm41xx/cm41xx.c b/board/cm41xx/cm41xx.c index 02d05af..c4136f8 100644 --- a/board/cm41xx/cm41xx.c +++ b/board/cm41xx/cm41xx.c @@ -78,7 +78,7 @@ int board_late_init (void) int board_init (void) { /* arch number of CM41xx */ - gd->bd->bi_arch_number = 672; + gd->bd->bi_arch_number = MACH_TYPE_CM41XX;
/* adress of boot parameters */ gd->bd->bi_boot_params = 0x00000100; diff --git a/board/cmc_pu2/cmc_pu2.c b/board/cmc_pu2/cmc_pu2.c index 3ad756d..205bd3a 100644 --- a/board/cmc_pu2/cmc_pu2.c +++ b/board/cmc_pu2/cmc_pu2.c @@ -96,12 +96,7 @@ int board_init (void) piob->PIO_PER = AT91C_PIO_PB3 | AT91C_PIO_PB4 | AT91C_PIO_PB5 | AT91C_PIO_PB6;
- /* - * arch number of CMC_PU2-Board. MACH_TYPE_CMC_PU2 is not supported in - * the linuxarm kernel, yet. - */ - /* gd->bd->bi_arch_number = MACH_TYPE_CMC_PU2; */ - gd->bd->bi_arch_number = 251; + gd->bd->bi_arch_number = MACH_TYPE_CMC_PU2; /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
diff --git a/board/imx31_phycore/imx31_phycore.c b/board/imx31_phycore/imx31_phycore.c index ae93444..4b72d57 100644 --- a/board/imx31_phycore/imx31_phycore.c +++ b/board/imx31_phycore/imx31_phycore.c @@ -60,7 +60,7 @@ int board_init (void) mx31_gpio_mux(MUX_CSPI2_MOSI__I2C2_SCL); mx31_gpio_mux(MUX_CSPI2_MISO__I2C2_SDA);
- gd->bd->bi_arch_number = 447; /* board id for linux */ + gd->bd->bi_arch_number = MACH_TYPE_MX31ADS; /* board id for linux */ gd->bd->bi_boot_params = (0x80000100); /* adress of boot parameters */
return 0; diff --git a/board/ns9750dev/ns9750dev.c b/board/ns9750dev/ns9750dev.c index fc46244..b8f377b 100644 --- a/board/ns9750dev/ns9750dev.c +++ b/board/ns9750dev/ns9750dev.c @@ -68,7 +68,7 @@ int board_init( void ) #warning Please register your machine at http://www.arm.linux.org.uk/developer/machines/?action=new /* arch number of OMAP 1510-Board */ /* to be changed for OMAP 1610 Board */ - gd->bd->bi_arch_number = 234; + gd->bd->bi_arch_number = MACH_TYPE_NS9750;
/* adress of boot parameters */ gd->bd->bi_boot_params = 0x10000100; diff --git a/board/samsung/smdk6400/smdk6400.c b/board/samsung/smdk6400/smdk6400.c index bd2e45a..f24d70f 100644 --- a/board/samsung/smdk6400/smdk6400.c +++ b/board/samsung/smdk6400/smdk6400.c @@ -71,7 +71,7 @@ int board_init(void) /* Enable WAIT */ SROM_BW_REG |= 4 | 8 | 1;
- gd->bd->bi_arch_number = MACH_TYPE; + gd->bd->bi_arch_number = MACH_TYPE_SMDK6400; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
return 0; diff --git a/board/trizepsiv/conxs.c b/board/trizepsiv/conxs.c index 7c6c855..e118f63 100644 --- a/board/trizepsiv/conxs.c +++ b/board/trizepsiv/conxs.c @@ -98,7 +98,7 @@ int board_init (void) /* so we do _nothing_ here */
/* arch number of ConXS Board */ - gd->bd->bi_arch_number = 776; + gd->bd->bi_arch_number = MACH_TYPE_TRIZEPS4;
/* adress of boot parameters */ gd->bd->bi_boot_params = 0xa000003c; diff --git a/board/xaeniax/xaeniax.c b/board/xaeniax/xaeniax.c index 9baa457..03721a2 100644 --- a/board/xaeniax/xaeniax.c +++ b/board/xaeniax/xaeniax.c @@ -42,7 +42,7 @@ int board_init (void) /* so we do _nothing_ here */
/* arch number of xaeniax */ - gd->bd->bi_arch_number = 585; + gd->bd->bi_arch_number = MACH_TYPE_XAENIAX;
/* adress of boot parameters */ gd->bd->bi_boot_params = 0xa0000100; diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h index 1784cc6..22cdf94 100644 --- a/include/configs/smdk6400.h +++ b/include/configs/smdk6400.h @@ -55,11 +55,6 @@ #define CONFIG_CMDLINE_TAG #define CONFIG_INITRD_TAG
-/* - * Architecture magic and machine type - */ -#define MACH_TYPE 1270 - #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
- gd->bd->bi_arch_number = MACH_TYPE_MX31ADS; /* board id for linux */
Why ADS board ID for the Phycore?
Kind regards, Jens
the 447 is the MX31ADS
if you need your own id please register one here http://www.arm.linux.org.uk/developer/machines/
Best Regards, J.
Sorry for a late reply, but it seems not to be upstream yet, so
There is a number already, could you please use
MACH_TYPE_PCM037
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 1232603494-14583-2-git-send-email-plagnioj@jcrosoft.com you wrote:
You actually CHANGE the arch_number here; you need the board maintainer's ACK for such a patch.
Note that there are other places where this is used - these must be changed, too - for example:
"board/lpc2292sodimm/lpc2292sodimm.c":
42 /* arch number MACH_TYPE_ARMADILLO - not official*/ 43 gd->bd->bi_arch_number = 83;
"board/siemens/SMN42/smn42.c":
I recommend you got through this again, more thoroughly.
- gd->bd->bi_arch_number = MACH_TYPE_CMC_PU2; /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- gd->bd->bi_arch_number = MACH_TYPE_MX31ADS; /* board id for linux */ gd->bd->bi_boot_params = (0x80000100); /* adress of boot parameters */
MX31ADS ??
- gd->bd->bi_arch_number = MACH_TYPE_NS9750;
NAK as is. This needs to be reworked.
the ARMADILLO was changed in the current kernel it's not any more 83 but 615
83 is used for board that does not have any valid MACHINE ID
I've not find it in the official list so I've let as 83 (non registered board)
ditto
as precedently it's the current MACHINE ID 251 is used for AT91RM9200
MX31ADS ?
234 is use for OMAP_INNOVATOR not the ns9750 so I've correct it
I any board maintainer have a problem with it I'm open
Best Regards, J.
- gd->bd->bi_arch_number = MACH_TYPE_ARMADILLO;
I am aware of this. But anybody using some Linux kernel runnin on this board will have a nasty surprise when hisl old kernels don;t boot any more with recent versions of U-Boot.
This is why I request that you ask for an ACK from the board maintainer - he needs to be at least aware of such a change.
You canged the old "MACH_TYPE_ARMADILLO" / 83 setting in one place but not in others? This will cause inconsistent behaviour.
You must not do that. Either leave ALL of these as they are, or fix ALL of them in the SAME way.
See above. You must talk to the board maintainers first.
the other board are not a ARMODILLO correct if I wrong
Best Regards, J.
I don't know, and frankly, I don't care.
If you implement such a change, you must at least implement it consistently.
If you don't know how to do that for a specific board, then you need to talk with the board maintainers.
Fixing the problm in one place but leaving it unfixed in some other places (knowingly) is not acceptable.
Hi Jean-Christophe,
Why not correct the wrong comment? I think this is the consistent thing to do, as there certainly is no definition for "83" in the kernel and 83 has nothing to do with ARMADILLO.
Cheers Detlev
PS: You have an interesting Mail-Followup-To on this posting. Maybe I should do this also to cut down on my incoming mails ;)
Dear Detlev,
Don't dare to attempt this. I might start doing the same...
On 13:02 Tue 27 Jan , Detlev Zundel wrote:
Hi Jean-Christophe,
This make sense anyway normaly no new arm board will not have a valid machine id now
Best Regards, J.
Hi, all affected board maintainers I've found in the current u-boot code some errors on the machine id could take a look on your board
nb: e-mail forwaded following
Best Regards, J.
In message 1232603494-14583-1-git-send-email-plagnioj@jcrosoft.com you wrote:
please, *PLEASE* get used to a somewhat reasonable style of numbering your patches.
If you submit patches tagged as "[PATCH 0/1]" and "[PATCH 1/1]" everybody expects *ONE* patche, with "0/1" being introductory comments only.
If you want to post TWO patches then please tell so, and write ".../2"
I told you this before. PLEASE stick to the rules.
You make working with your patches unnecessarily hard.
participants (5)
Detlev Zundel
Jens Gehrlein
