[U-Boot] [PATCH 1/6] net: gem: Add support for reading MAC from I2C EEPROM
Add support for reading MAC address from I2C EEPROM.
Signed-off-by: Michal Simek monstr@monstr.eu ---
drivers/net/zynq_gem.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index b3821c31a91d..ace60c901cb5 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -627,6 +627,21 @@ static int zynq_gem_remove(struct udevice *dev) return 0; }
+static int zynq_gem_read_rom_hwaddr(struct udevice *dev) +{ +#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ + defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) + struct eth_pdata *pdata = dev_get_platdata(dev); + + if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, + CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, + pdata->enetaddr, ARRAY_SIZE(pdata->enetaddr))) + printf("EEPROM MAC address read failed\n"); +#endif + return 0; +} + + static const struct eth_ops zynq_gem_ops = { .start = zynq_gem_init, .send = zynq_gem_send, @@ -634,6 +649,7 @@ static const struct eth_ops zynq_gem_ops = { .free_pkt = zynq_gem_free_pkt, .stop = zynq_gem_halt, .write_hwaddr = zynq_gem_setup_mac, + .read_rom_hwaddr = zynq_gem_read_rom_hwaddr, };
static int zynq_gem_ofdata_to_platdata(struct udevice *dev)
Zybo has on board I2C EEPROM which contains preprogrammed MAC address.
include/configs/zynq_zybo.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/configs/zynq_zybo.h b/include/configs/zynq_zybo.h index c53ba79d48b0..644d462c01c9 100644 --- a/include/configs/zynq_zybo.h +++ b/include/configs/zynq_zybo.h @@ -18,6 +18,12 @@ #define CONFIG_ZYNQ_USB #define CONFIG_ZYNQ_SDHCI0 #define CONFIG_ZYNQ_BOOT_FREEBSD +#define CONFIG_ZYNQ_I2C0 +#define CONFIG_ZYNQ_I2C1 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_CMD_EEPROM +#define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x50 +#define CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET 0xFA
/* Define ZYBO PS Clock Frequency to 50MHz */ #define CONFIG_ZYNQ_PS_CLK_FREQ 50000000UL
The problem with current implementation is that SPDDONE bit is 1 but link bit is zero. That's why phydev->link is setup to 0 which ending up in driver failure that link is not up.
Log: Zynq> dhcp ethernet@e000b000 Waiting for PHY auto negotiation to complete....... done ethernet@e000b000: No link.
There is at least 1ms delay between spddone bit and link up.
Use genphy_read_status() instead of realtek implemenation which is working with page 11. Linux driver is also using generic implementation.
drivers/net/phy/realtek.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/realtek.c b/drivers/net/phy/realtek.c index bba48da4099f..259a87fcc59e 100644 --- a/drivers/net/phy/realtek.c +++ b/drivers/net/phy/realtek.c @@ -203,6 +203,14 @@ static int rtl8211x_startup(struct phy_device *phydev) return 0; }
+static int rtl8211e_startup(struct phy_device *phydev) +{ + genphy_update_link(phydev); + genphy_parse_link(phydev); + + return 0; +} + static int rtl8211f_startup(struct phy_device *phydev) { /* Read the Status (2x to make sure link is right) */ @@ -230,7 +238,7 @@ static struct phy_driver RTL8211E_driver = { .mask = 0xffffff, .features = PHY_GBIT_FEATURES, .config = &rtl8211x_config, - .startup = &rtl8211x_startup, + .startup = &rtl8211e_startup, .shutdown = &genphy_shutdown, };
- genphy_update_link(phydev);
- genphy_parse_link(phydev);
- .startup = &rtl8211e_startup, .shutdown = &genphy_shutdown,
Applied to zynq repo.
Thanks, Michal
This phy is available at Zybo board.
include/configs/zynq-common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index e8c3ef0c3872..7b42a00b9e75 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -50,6 +50,7 @@ # define CONFIG_MII # define CONFIG_SYS_FAULT_ECHO_LINK_DOWN # define CONFIG_PHY_MARVELL +# define CONFIG_PHY_REALTEK # define CONFIG_BOOTP_SERVERIP # define CONFIG_BOOTP_BOOTPATH # define CONFIG_BOOTP_GATEWAY
Thanks, Michal
DTS syncup with Linux kernel. Add missing reset-gpio property.
This patch is in queue to next kernel version
--- arch/arm/dts/zynq-zybo.dts | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynq-zybo.dts b/arch/arm/dts/zynq-zybo.dts index fbbb8911910b..d04e9625d29e 100644 --- a/arch/arm/dts/zynq-zybo.dts +++ b/arch/arm/dts/zynq-zybo.dts @@ -31,8 +31,9 @@ };
usb_phy0: phy0 { - compatible = "usb-nop-xceiv"; #phy-cells = <0>; + compatible = "usb-nop-xceiv"; + reset-gpios = <&gpio0 46 1>; }; };
usb_phy0: phy0 {
#phy-cells = <0>;compatible = "usb-nop-xceiv";
};reset-gpios = <&gpio0 46 1>;
Thanks, Michal
Zybo contains on board HDMI that's why enable EDID. Doing it via config because zynq i2c driver hasn't been moved to DM yet and enabling via Kconfig requires DM_I2C. This will be moved that driver is moved to DM.
Currently the biggest problem is EEPROM support with DM together.
Log for zybo: Zynq> i2c dev 1 Setting bus to 1 Zynq> i2c probe Valid chip addresses: 50 Zynq> i2c edid 50 EDID version: 1.3 Product ID code: 05cd Manufacturer: SAM Serial number: 30303033 Manufactured in week: 42 year: 2010 Video input definition: digital signal, voltage level 0 Monitor is non-RGB Maximum visible display size: 16 cm x 9 cm Power management features: active off, no suspend, no standby Estabilished timings: 640x480 60 Hz (VGA) 800x600 56 Hz (VESA) 800x600 60 Hz (VESA) 1024x768 60 Hz (VESA) Standard timings: 1600x1200 60 Hz 1280x1024 60 Hz 1280x960 60 Hz 1280x800 60 Hz 1440x900 60 Hz 1680x1050 60 Hz 1920x1080 60 Hz (detailed) 1280x720 60 Hz (detailed) Monitor range limits, horizontal sync: 30-81 kHz, vertical refresh: 50-60 Hz, max pixel clock: 170 MHz Monitor name: SyncMaster
--- include/configs/zynq_zybo.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/zynq_zybo.h b/include/configs/zynq_zybo.h index 644d462c01c9..3db3c13e8a3e 100644 --- a/include/configs/zynq_zybo.h +++ b/include/configs/zynq_zybo.h @@ -24,6 +24,8 @@ #define CONFIG_CMD_EEPROM #define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x50 #define CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET 0xFA +#define CONFIG_DISPLAY +#define CONFIG_I2C_EDID
Thanks, Michal
Hi Michal,
Is this a feature provided by the GEM MAC IP?
- defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET)
This call to eeprom_read() looks to me a board-specific feature, that an on-board eeprom is used to store the MAC address for the GEM?
Regards, Bin
Hi Bin,
2016-02-14 3:25 GMT+01:00 Bin Meng bmeng.cn@gmail.com:
Hi Michal,
Right. it is board specific feature I can The question is if this should really go to board specific file or to be the part of DT binding. I didn't look at the kernel if someone has some sort of eeprom binding for this case but I expect local mac addresses via DT are used. Or passing via command line does it.
Anyway there is mac_read_from_eeprom() but it is ancient one. Do you any preference for the name of function?
Thanks, Michal
Hi Michal,
On Sun, Feb 14, 2016 at 6:03 PM, Michal Simek monstr@monstr.eu wrote:
Hi Bin,
Hi Michal,
I think the intention of the read_rom_hwaddr op is to read the MAC address via the ethernet controller defined mechanism (eg: e1000 can read its MAC address from either an EEPROM or an SPI flash), or via SoC defined mechanism (eg: the ethernet IP is only seen on a specific SoC, and reading the MAC address only makes sense on that specific SoC). If this is a board-specific mechanism, I don't think we should put the codes into driver's read_rom_hwaddr(). Again, if it is board-specific, we may not come up with a standard DT binding for such stuff, unless we can enumerate all possible ways for storing MAC address on a board (EEPROM, SPI flash, eMMC, SD)?
Regards, Bin
Hi Bin,
On 14.2.2016 13:00, Bin Meng wrote:
Hi Michal,
Hi Bin,
Hi Michal,
It is interesting that there is no standard binding for it. Maybe in future. Anyway is this better way (look below)? (I will send it as regular patch)
Thanks, Michal
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 01bae5d67e3f..ae115245b7ea 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -72,6 +72,18 @@ int board_init(void)
int board_late_init(void) { +#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ + defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) + unsigned char enetaddr[6]; + + if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, + CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, + enetaddr, ARRAY_SIZE(enetaddr))) + printf("I2C EEPROM MAC address read failed\n"); + else + eth_setenv_enetaddr("ethaddr", enetaddr); +#endif + switch ((zynq_slcr_get_boot_mode()) & ZYNQ_BM_MASK) { case ZYNQ_BM_NOR: setenv("modeboot", "norboot");
Hi Michal,
On Mon, Feb 15, 2016 at 3:16 PM, Michal Simek monstr@monstr.eu wrote:
Hi Bin,
Hi Michal,
Hi Bin,
Hi Michal,
Thanks, Michal
else
Looks good, but one comment regarding to the naming: CONFIG_ZYNQ_GEM_EEPROM_ADDR & CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET.
Should we include _ZYNQ_GEM_ in the macro name since it may mislead it has something to do with the GEM controller? Is the on-board EEPROM only used to store the MAC address? If not, maybe think about some another generic naming?
Regards, Bin
On 15.2.2016 12:10, Bin Meng wrote:
Hi Michal,
Hi Bin,
Hi Michal,
Hi Bin,
Hi Michal,
Thanks, Michal
else
Fair enough will fix it and send the patch.
Thanks, Michal
Hi Bin,
On Sun, Feb 14, 2016 at 6:00 AM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Michal,
Hi Bin,
Hi Michal,
Did you see this: https://patchwork.ozlabs.org/patch/573373/
This is the concept I had in mind for handling this sort of thing.
Thanks, -Joe
Hi Joe,
2016-02-15 17:01 GMT+01:00 Joe Hershberger joe.hershberger@gmail.com:
Hi Bin,
Hi Michal,
Hi Bin,
Hi Michal,
pdata->enetaddr,
has
This also works for me. I have no problem with both ways. It means this one or setting up variable in board init file. Also is there any hook that mac address will be updated in DTS file (local-mac-address) to be the same in u-boot and in Linux.
Thanks, Michal
Hi Michal,
On Mon, Feb 15, 2016 at 11:41 AM, Michal Simek monstr@monstr.eu wrote:
Hi Joe,
Hi Bin,
Hi Michal,
Hi Bin,
Hi Michal,
pdata->enetaddr,
I'm not aware of a common way.
-Joe
2016-02-15 18:53 GMT+01:00 Joe Hershberger joe.hershberger@gmail.com:
Hi Michal,
Hi Joe,
Hi Bin,
Hi Michal,
wrote:
Hi Bin,
Hi Michal,
On Sat, Feb 13, 2016 at 6:39 PM, Michal Simek monstr@monstr.eu wrote: > Add support for reading MAC address from I2C EEPROM. >
> Signed-off-by: Michal Simek monstr@monstr.eu > --- > > drivers/net/zynq_gem.c | 16 ++++++++++++++++ > 1 file changed, 16 insertions(+) > > diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c > index b3821c31a91d..ace60c901cb5 100644 > --- a/drivers/net/zynq_gem.c > +++ b/drivers/net/zynq_gem.c > @@ -627,6 +627,21 @@ static int zynq_gem_remove(struct udevice
*dev)
> return 0; > } > > +static int zynq_gem_read_rom_hwaddr(struct udevice *dev) > +{ > +#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ > + defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) > + struct eth_pdata *pdata = dev_get_platdata(dev); > + > + if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, > + CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, > + pdata->enetaddr, > ARRAY_SIZE(pdata->enetaddr)))
that
someone
one
Anyway you are network custodian and I believe you will tell me which way to go to implement this mac address reading from eeprom. :-)
Thanks, Michal
Hi Michal,
Hi Michal,
Hi Joe,
Hi Bin,
Hi Michal,
Hi Bin,
2016-02-14 3:25 GMT+01:00 Bin Meng bmeng.cn@gmail.com: > > Hi Michal, > > On Sat, Feb 13, 2016 at 6:39 PM, Michal Simek monstr@monstr.eu > wrote: > > Add support for reading MAC address from I2C EEPROM. > > > > Is this a feature provided by the GEM MAC IP? > > > Signed-off-by: Michal Simek monstr@monstr.eu > > --- > > > > drivers/net/zynq_gem.c | 16 ++++++++++++++++ > > 1 file changed, 16 insertions(+) > > > > diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c > > index b3821c31a91d..ace60c901cb5 100644 > > --- a/drivers/net/zynq_gem.c > > +++ b/drivers/net/zynq_gem.c > > @@ -627,6 +627,21 @@ static int zynq_gem_remove(struct udevice > > *dev) > > return 0; > > } > > > > +static int zynq_gem_read_rom_hwaddr(struct udevice *dev) > > +{ > > +#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ > > + defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) > > + struct eth_pdata *pdata = dev_get_platdata(dev); > > + > > + if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, > > + CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, > > + pdata->enetaddr, > > ARRAY_SIZE(pdata->enetaddr))) > > This call to eeprom_read() looks to me a board-specific feature, > that > an on-board eeprom is used to store the MAC address for the GEM? >
Unless someone can compel me otherwise, I think the reference that I sent should be the way for now.
+Simon,
Hi Joe,
On Tue, Feb 16, 2016 at 12:01 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Bin,
Hi Michal,
Hi Bin,
Hi Michal,
I haven't noticed this before.
Your patch looks good to me, but I added Simon, who is not a big fan of using weak in driver model :-)
Regards, Bin
On 15 February 2016 at 18:06, Bin Meng bmeng.cn@gmail.com wrote:
+Simon,
Hi Joe,
Hi Bin,
Hi Michal,
Hi Bin,
Hi Michal,
My main concern with 'weak' is using it in place of what I see as a proper API. The drivers should really stand alone and not call into board code, and vice versa. If the driver needs some settings, then perhaps we can provide it via device tree / platform data?
What will the other zynq boards do to read this information? How different will each implementation be?
That said, since this is confined to zynq it's not a big concern.
Hi Simon,
+Simon,
Hi Joe,
Hi Bin,
Hi Michal,
Hi Bin,
Hi Michal,
> Signed-off-by: Michal Simek monstr@monstr.eu > --- > > drivers/net/zynq_gem.c | 16 ++++++++++++++++ > 1 file changed, 16 insertions(+) > > diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c > index b3821c31a91d..ace60c901cb5 100644 > --- a/drivers/net/zynq_gem.c > +++ b/drivers/net/zynq_gem.c > @@ -627,6 +627,21 @@ static int zynq_gem_remove(struct udevice *dev) > return 0; > } > > +static int zynq_gem_read_rom_hwaddr(struct udevice *dev) > +{ > +#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ > + defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) > + struct eth_pdata *pdata = dev_get_platdata(dev); > + > + if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, > + CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, > + pdata->enetaddr, ARRAY_SIZE(pdata->enetaddr)))
The problem with using the device tree is we want to share with Linux. Linux DTs will not describe this sort of thing. Platform data, maybe... but it is not something that is defined. That means it will be very difficult to make standard.
On a side note, the same thing troubles me wrt MDIO and phy descriptions in DTs. It seems each MAC device tree has a different way to describe the relationships.
That's part of the problem. It's hard to make a good API when it's only the first or second board that wants to do this. The next one will have a different requirement.
It seems like it's worth cleaning up after there is a clear need to have an API. Until there are a number of boards that need something like this, I think an informal API (like this weak stuff) is simpler.
-Joe
Hi Joe,
On 16 February 2016 at 09:06, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
+Simon,
Hi Joe,
Hi Bin,
Hi Michal,
Hi Bin,
2016-02-14 3:25 GMT+01:00 Bin Meng bmeng.cn@gmail.com: > > Hi Michal, > > On Sat, Feb 13, 2016 at 6:39 PM, Michal Simek monstr@monstr.eu wrote: > > Add support for reading MAC address from I2C EEPROM. > > > > Is this a feature provided by the GEM MAC IP? > > > Signed-off-by: Michal Simek monstr@monstr.eu > > --- > > > > drivers/net/zynq_gem.c | 16 ++++++++++++++++ > > 1 file changed, 16 insertions(+) > > > > diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c > > index b3821c31a91d..ace60c901cb5 100644 > > --- a/drivers/net/zynq_gem.c > > +++ b/drivers/net/zynq_gem.c > > @@ -627,6 +627,21 @@ static int zynq_gem_remove(struct udevice *dev) > > return 0; > > } > > > > +static int zynq_gem_read_rom_hwaddr(struct udevice *dev) > > +{ > > +#if defined(CONFIG_ZYNQ_GEM_EEPROM_ADDR) && \ > > + defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) > > + struct eth_pdata *pdata = dev_get_platdata(dev); > > + > > + if (eeprom_read(CONFIG_ZYNQ_GEM_EEPROM_ADDR, > > + CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET, > > + pdata->enetaddr, ARRAY_SIZE(pdata->enetaddr))) > > This call to eeprom_read() looks to me a board-specific feature, that > an on-board eeprom is used to store the MAC address for the GEM? >
Sounds reasonable to me.
Bin Meng
Joe Hershberger
Michal Simek
