[U-Boot] [PATCH 01/14] PXA: pxafb: Fix indent problems
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxafb.c | 200 +++++++++++++++++++++++----------------------- 1 files changed, 100 insertions(+), 100 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 0ee6a75..09ee5c6 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -56,26 +56,26 @@
/* 640x480x16 @ 61 Hz */ vidinfo_t panel_info = { - vl_col: 640, - vl_row: 480, - vl_width: 640, - vl_height: 480, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_HIGH, - vl_hsp: CONFIG_SYS_HIGH, - vl_vsp: CONFIG_SYS_HIGH, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 0, - vl_splt: 0, - vl_clor: 0, - vl_tft: 1, - vl_hpw: 40, - vl_blw: 56, - vl_elw: 56, - vl_vpw: 20, - vl_bfw: 8, - vl_efw: 8, + .vl_col = 640, + .vl_row = 480, + .vl_width = 640, + .vl_height = 480, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_HIGH, + .vl_hsp = CONFIG_SYS_HIGH, + .vl_vsp = CONFIG_SYS_HIGH, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 0, + .vl_clor = 0, + .vl_tft = 1, + .vl_hpw = 40, + .vl_blw = 56, + .vl_elw = 56, + .vl_vpw = 20, + .vl_bfw = 8, + .vl_efw = 8, }; #endif /* CONFIG_PXA_VIDEO */
@@ -90,26 +90,26 @@ vidinfo_t panel_info = { # define REG_LCCR3 0x0340FF08
vidinfo_t panel_info = { - vl_col: 640, - vl_row: 480, - vl_width: 157, - vl_height: 118, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_HIGH, - vl_hsp: CONFIG_SYS_HIGH, - vl_vsp: CONFIG_SYS_HIGH, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 0, - vl_splt: 1, - vl_clor: 1, - vl_tft: 0, - vl_hpw: 1, - vl_blw: 3, - vl_elw: 3, - vl_vpw: 1, - vl_bfw: 0, - vl_efw: 0, + .vl_col = 640, + .vl_row = 480, + .vl_width = 157, + .vl_height = 118, + .vl_clk = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_HIGH, + .vl_hsp = CONFIG_SYS_HIGH, + .vl_vsp = CONFIG_SYS_HIGH, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 0, + .vl_hpw = 1, + .vl_blw = 3, + .vl_elw = 3, + .vl_vpw = 1, + .vl_bfw = 0, + .vl_efw = 0, }; #endif /* CONFIG_SHARP_LM8V31 */ /*----------------------------------------------------------------------*/ @@ -123,26 +123,26 @@ vidinfo_t panel_info = { # define REG_LCCR3 0x0340FF08
vidinfo_t panel_info = { - vl_col: 640, - vl_row: 480, - vl_width: 157, - vl_height: 118, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_HIGH, - vl_hsp: CONFIG_SYS_HIGH, - vl_vsp: CONFIG_SYS_HIGH, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 0, - vl_splt: 1, - vl_clor: 1, - vl_tft: 1, - vl_hpw: 32, - vl_blw: 144, - vl_elw: 32, - vl_vpw: 2, - vl_bfw: 13, - vl_efw: 30, + .vl_col = 640, + .vl_row = 480, + .vl_width = 157, + .vl_height = 118, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_HIGH, + .vl_hsp = CONFIG_SYS_HIGH, + .vl_vsp = CONFIG_SYS_HIGH, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 1, + .vl_hpw = 32, + .vl_blw = 144, + .vl_elw = 32, + .vl_vpw = 2, + .vl_bfw = 13, + .vl_efw = 30, }; #endif /* CONFIG_VOIPAC_LCD */
@@ -156,26 +156,26 @@ vidinfo_t panel_info = { #define REG_LCCR3 0x0340FF20
vidinfo_t panel_info = { - vl_col: 320, - vl_row: 240, - vl_width: 167, - vl_height: 109, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_HIGH, - vl_hsp: CONFIG_SYS_HIGH, - vl_vsp: CONFIG_SYS_HIGH, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 1, - vl_splt: 0, - vl_clor: 1, - vl_tft: 0, - vl_hpw: 1, - vl_blw: 1, - vl_elw: 1, - vl_vpw: 7, - vl_bfw: 0, - vl_efw: 0, + .vl_col = 320, + .vl_row = 240, + .vl_width = 167, + .vl_height = 109, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_HIGH, + .vl_hsp = CONFIG_SYS_HIGH, + .vl_vsp = CONFIG_SYS_HIGH, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 1, + .vl_splt = 0, + .vl_clor = 1, + .vl_tft = 0, + .vl_hpw = 1, + .vl_blw = 1, + .vl_elw = 1, + .vl_vpw = 7, + .vl_bfw = 0, + .vl_efw = 0, }; #endif /* CONFIG_HITACHI_SX14 */
@@ -190,26 +190,26 @@ vidinfo_t panel_info = { # define REG_LCCR3 0x03b00009
vidinfo_t panel_info = { - vl_col: 240, - vl_row: 320, - vl_width: 240, - vl_height: 320, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_LOW, - vl_hsp: CONFIG_SYS_LOW, - vl_vsp: CONFIG_SYS_LOW, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 0, - vl_splt: 1, - vl_clor: 1, - vl_tft: 1, - vl_hpw: 4, - vl_blw: 4, - vl_elw: 8, - vl_vpw: 4, - vl_bfw: 4, - vl_efw: 8, + .vl_col = 240, + .vl_row = 320, + .vl_width = 240, + .vl_height = 320, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_LOW, + .vl_hsp = CONFIG_SYS_LOW, + .vl_vsp = CONFIG_SYS_LOW, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 1, + .vl_hpw = 4, + .vl_blw = 4, + .vl_elw = 8, + .vl_vpw = 4, + .vl_bfw = 4, + .vl_efw = 8, }; #endif /* CONFIG_LMS283GF05 */
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/cpu.c | 28 +- arch/arm/cpu/pxa/i2c.c | 69 +- arch/arm/cpu/pxa/pxafb.c | 64 +- arch/arm/cpu/pxa/timer.c | 7 +- arch/arm/cpu/pxa/usb.c | 61 +- arch/arm/include/asm/arch-pxa/hardware.h | 61 +- arch/arm/include/asm/arch-pxa/pxa-regs.h | 2674 ++++++++++++++++-------------- board/colibri_pxa270/colibri_pxa270.c | 33 +- board/cradle/cradle.c | 5 +- board/cradle/lowlevel_init.S | 4 +- board/csb226/csb226.c | 13 +- board/delta/delta.c | 37 +- board/delta/nand.c | 110 +- board/innokom/innokom.c | 14 +- board/pxa255_idp/pxa_idp.c | 27 +- board/trizepsiv/conxs.c | 33 +- board/vpac270/vpac270.c | 37 +- board/wepep250/wepep250.c | 11 +- board/zipitz2/zipitz2.c | 33 +- board/zylonite/nand.c | 110 +- drivers/mmc/pxa_mmc.c | 98 +- drivers/serial/serial_pxa.c | 94 +- include/configs/cradle.h | 2 - include/configs/delta.h | 1 + include/configs/zylonite.h | 1 + 25 files changed, 1909 insertions(+), 1718 deletions(-)
diff --git a/arch/arm/cpu/pxa/cpu.c b/arch/arm/cpu/pxa/cpu.c index 800d120..330d013 100644 --- a/arch/arm/cpu/pxa/cpu.c +++ b/arch/arm/cpu/pxa/cpu.c @@ -30,10 +30,11 @@ * CPU specific code */
-#include <common.h> -#include <command.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h> #include <asm/system.h> +#include <command.h> +#include <common.h>
static void cache_flush(void);
@@ -71,17 +72,22 @@ void set_GPIO_mode(int gpio_mode) { int gpio = gpio_mode & GPIO_MD_MASK_NR; int fn = (gpio_mode & GPIO_MD_MASK_FN) >> 8; - int gafr; + int val; + + /* This below changes direction setting of GPIO "gpio" */ + val = readl(GPDR(gpio));
if (gpio_mode & GPIO_MD_MASK_DIR) - { - GPDR(gpio) |= GPIO_bit(gpio); - } + val |= GPIO_bit(gpio); else - { - GPDR(gpio) &= ~GPIO_bit(gpio); - } - gafr = GAFR(gpio) & ~(0x3 << (((gpio) & 0xf)*2)); - GAFR(gpio) = gafr | (fn << (((gpio) & 0xf)*2)); + val &= ~GPIO_bit(gpio); + + writel(val, GPDR(gpio)); + + /* This below updates only AF of GPIO "gpio" */ + val = readl(GAFR(gpio)); + val &= ~(0x3 << (((gpio) & 0xf) * 2)); + val |= fn << (((gpio) & 0xf) * 2); + writel(val, GAFR(gpio)); } #endif /* CONFIG_CPU_MONAHANS */ diff --git a/arch/arm/cpu/pxa/i2c.c b/arch/arm/cpu/pxa/i2c.c index 6b72ba1..7aa49ae 100644 --- a/arch/arm/cpu/pxa/i2c.c +++ b/arch/arm/cpu/pxa/i2c.c @@ -33,6 +33,7 @@ /* FIXME: this file is PXA255 specific! What about other XScales? */
#include <common.h> +#include <asm/io.h>
#ifdef CONFIG_HARD_I2C
@@ -93,19 +94,21 @@ struct i2c_msg {
static void i2c_reset( void ) { - ICR &= ~ICR_IUE; /* disable unit */ - ICR |= ICR_UR; /* reset the unit */ + writel(readl(ICR) & ~ICR_IUE, ICR); /* disable unit */ + writel(readl(ICR) | ICR_UR, ICR); /* reset the unit */ udelay(100); - ICR &= ~ICR_IUE; /* disable unit */ + writel(readl(ICR) & ~ICR_IUE, ICR); /* disable unit */ #ifdef CONFIG_CPU_MONAHANS - CKENB |= (CKENB_4_I2C); /* | CKENB_1_PWM1 | CKENB_0_PWM0); */ + /* | CKENB_1_PWM1 | CKENB_0_PWM0); */ + writel(readl(CKENB) | (CKENB_4_I2C), CKENB); #else /* CONFIG_CPU_MONAHANS */ - CKEN |= CKEN14_I2C; /* set the global I2C clock on */ + /* set the global I2C clock on */ + writel(readl(CKEN) | CKEN14_I2C, CKEN); #endif - ISAR = I2C_PXA_SLAVE_ADDR; /* set our slave address */ - ICR = I2C_ICR_INIT; /* set control register values */ - ISR = I2C_ISR_INIT; /* set clear interrupt bits */ - ICR |= ICR_IUE; /* enable unit */ + writel(I2C_PXA_SLAVE_ADDR, ISAR); /* set our slave address */ + writel(I2C_ICR_INIT, ICR); /* set control reg values */ + writel(I2C_ISR_INIT, ISR); /* set clear interrupt bits */ + writel(readl(ICR) | ICR_IUE, ICR); /* enable unit */ udelay(100); }
@@ -159,22 +162,26 @@ int i2c_transfer(struct i2c_msg *msg) goto transfer_error_bus_busy;
/* start transmission */ - ICR &= ~ICR_START; - ICR &= ~ICR_STOP; - IDBR = msg->data; - if (msg->condition == I2C_COND_START) ICR |= ICR_START; - if (msg->condition == I2C_COND_STOP) ICR |= ICR_STOP; - if (msg->acknack == I2C_ACKNAK_SENDNAK) ICR |= ICR_ACKNAK; - if (msg->acknack == I2C_ACKNAK_SENDACK) ICR &= ~ICR_ACKNAK; - ICR &= ~ICR_ALDIE; - ICR |= ICR_TB; + writel(readl(ICR) & ~ICR_START, ICR); + writel(readl(ICR) & ~ICR_STOP, ICR); + writel(msg->data, IDBR); + if (msg->condition == I2C_COND_START) + writel(readl(ICR) | ICR_START, ICR); + if (msg->condition == I2C_COND_STOP) + writel(readl(ICR) | ICR_STOP, ICR); + if (msg->acknack == I2C_ACKNAK_SENDNAK) + writel(readl(ICR) | ICR_ACKNAK, ICR); + if (msg->acknack == I2C_ACKNAK_SENDACK) + writel(readl(ICR) & ~ICR_ACKNAK, ICR); + writel(readl(ICR) & ~ICR_ALDIE, ICR); + writel(readl(ICR) | ICR_TB, ICR);
/* transmit register empty? */ if (!i2c_isr_set_cleared(ISR_ITE,0)) goto transfer_error_transmit_timeout;
/* clear 'transmit empty' state */ - ISR |= ISR_ITE; + writel(readl(ISR) | ISR_ITE, ISR);
/* wait for ACK from slave */ if (msg->acknack == I2C_ACKNAK_WAITACK) @@ -189,23 +196,27 @@ int i2c_transfer(struct i2c_msg *msg) goto transfer_error_bus_busy;
/* start receive */ - ICR &= ~ICR_START; - ICR &= ~ICR_STOP; - if (msg->condition == I2C_COND_START) ICR |= ICR_START; - if (msg->condition == I2C_COND_STOP) ICR |= ICR_STOP; - if (msg->acknack == I2C_ACKNAK_SENDNAK) ICR |= ICR_ACKNAK; - if (msg->acknack == I2C_ACKNAK_SENDACK) ICR &= ~ICR_ACKNAK; - ICR &= ~ICR_ALDIE; - ICR |= ICR_TB; + writel(readl(ICR) & ~ICR_START, ICR); + writel(readl(ICR) & ~ICR_STOP, ICR); + if (msg->condition == I2C_COND_START) + writel(readl(ICR) | ICR_START, ICR); + if (msg->condition == I2C_COND_STOP) + writel(readl(ICR) | ICR_STOP, ICR); + if (msg->acknack == I2C_ACKNAK_SENDNAK) + writel(readl(ICR) | ICR_ACKNAK, ICR); + if (msg->acknack == I2C_ACKNAK_SENDACK) + writel(readl(ICR) & ~ICR_ACKNAK, ICR); + writel(readl(ICR) & ~ICR_ALDIE, ICR); + writel(readl(ICR) | ICR_TB, ICR);
/* receive register full? */ if (!i2c_isr_set_cleared(ISR_IRF,0)) goto transfer_error_receive_timeout;
- msg->data = IDBR; + msg->data = readl(IDBR);
/* clear 'receive empty' state */ - ISR |= ISR_IRF; + writel(readl(ISR) | ISR_IRF, ISR);
break;
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 09ee5c6..d73f765 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -35,6 +35,7 @@ #include <stdio_dev.h> #include <lcd.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
/* #define DEBUG */
@@ -377,12 +378,14 @@ static void pxafb_setup_gpio (vidinfo_t *vid) { debug("Setting GPIO for 4 bit data\n"); /* bits 58-61 */ - GPDR1 |= (0xf << 26); - GAFR1_U = (GAFR1_U & ~(0xff << 20)) | (0xaa << 20); + writel(readl(GPDR1) | (0xf << 26), GPDR1); + writel((readl(GAFR1_U) & ~(0xff << 20)) | (0xaa << 20), + GAFR1_U);
/* bits 74-77 */ - GPDR2 |= (0xf << 10); - GAFR2_L = (GAFR2_L & ~(0xff << 20)) | (0xaa << 20); + writel(readl(GPDR2) | (0xf << 10), GPDR2); + writel((readl(GAFR2_L) & ~(0xff << 20)) | (0xaa << 20), + GAFR2_L); }
/* 8 bit interface */ @@ -391,15 +394,17 @@ static void pxafb_setup_gpio (vidinfo_t *vid) { debug("Setting GPIO for 8 bit data\n"); /* bits 58-65 */ - GPDR1 |= (0x3f << 26); - GPDR2 |= (0x3); + writel(readl(GPDR1) | (0x3f << 26), GPDR1); + writel(readl(GPDR2) | (0x3), GPDR2);
- GAFR1_U = (GAFR1_U & ~(0xfff << 20)) | (0xaaa << 20); - GAFR2_L = (GAFR2_L & ~0xf) | (0xa); + writel((readl(GAFR1_U) & ~(0xfff << 20)) | (0xaaa << 20), + GAFR1_U); + writel((readl(GAFR2_L) & ~0xf) | (0xa), GAFR2_L);
/* 16 bit interface */ @@ -407,11 +412,12 @@ static void pxafb_setup_gpio (vidinfo_t *vid) { debug("Setting GPIO for 16 bit data\n"); /* bits 58-77 */ - GPDR1 |= (0x3f << 26); - GPDR2 |= 0x00003fff; + writel(readl(GPDR1) | (0x3f << 26), GPDR1); + writel(readl(GPDR2) | 0x00003fff, GPDR2);
- GAFR1_U = (GAFR1_U & ~(0xfff << 20)) | (0xaaa << 20); - GAFR2_L = (GAFR2_L & 0xf0000000) | 0x0aaaaaaa; + writel((readl(GAFR1_U) & ~(0xfff << 20)) | (0xaaa << 20), + GAFR1_U); + writel((readl(GAFR2_L) & 0xf0000000) | 0x0aaaaaaa, GAFR2_L); } else { @@ -425,26 +431,26 @@ static void pxafb_enable_controller (vidinfo_t *vid) debug("Enabling LCD controller\n");
/* Sequence from 11.7.10 */ - LCCR3 = vid->pxa.reg_lccr3; - LCCR2 = vid->pxa.reg_lccr2; - LCCR1 = vid->pxa.reg_lccr1; - LCCR0 = vid->pxa.reg_lccr0 & ~LCCR0_ENB; - FDADR0 = vid->pxa.fdadr0; - FDADR1 = vid->pxa.fdadr1; - LCCR0 |= LCCR0_ENB; + writel(vid->pxa.reg_lccr3, LCCR3); + writel(vid->pxa.reg_lccr2, LCCR2); + writel(vid->pxa.reg_lccr1, LCCR1); + writel(vid->pxa.reg_lccr0 & ~LCCR0_ENB, LCCR0); + writel(vid->pxa.fdadr0, FDADR0); + writel(vid->pxa.fdadr1, FDADR1); + writel(readl(LCCR0) | LCCR0_ENB, LCCR0);
#ifdef CONFIG_CPU_MONAHANS - CKENA |= CKENA_1_LCD; + writel(readl(CKENA) | CKENA_1_LCD, CKENA); #else - CKEN |= CKEN16_LCD; + writel(readl(CKEN) | CKEN16_LCD, CKEN); #endif
- debug("FDADR0 = 0x%08x\n", (unsigned int)FDADR0); - debug("FDADR1 = 0x%08x\n", (unsigned int)FDADR1); - debug("LCCR0 = 0x%08x\n", (unsigned int)LCCR0); - debug("LCCR1 = 0x%08x\n", (unsigned int)LCCR1); - debug("LCCR2 = 0x%08x\n", (unsigned int)LCCR2); - debug("LCCR3 = 0x%08x\n", (unsigned int)LCCR3); + debug("FDADR0 = 0x%08x\n", (unsigned int)readl(FDADR0)); + debug("FDADR1 = 0x%08x\n", (unsigned int)readl(FDADR1)); + debug("LCCR0 = 0x%08x\n", (unsigned int)readl(LCCR0)); + debug("LCCR1 = 0x%08x\n", (unsigned int)readl(LCCR1)); + debug("LCCR2 = 0x%08x\n", (unsigned int)readl(LCCR2)); + debug("LCCR3 = 0x%08x\n", (unsigned int)readl(LCCR3)); }
static int pxafb_init (vidinfo_t *vid) diff --git a/arch/arm/cpu/pxa/timer.c b/arch/arm/cpu/pxa/timer.c index 8d0f826..ec950c7 100644 --- a/arch/arm/cpu/pxa/timer.c +++ b/arch/arm/cpu/pxa/timer.c @@ -26,8 +26,9 @@ * MA 02111-1307 USA */
-#include <common.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h> +#include <common.h> #include <div64.h>
#ifdef CONFIG_USE_IRQ @@ -86,7 +87,7 @@ void __udelay (unsigned long usec)
void reset_timer_masked (void) { - OSCR = 0; + writel(0, OSCR); }
ulong get_timer_masked (void) @@ -113,7 +114,7 @@ void udelay_masked (unsigned long usec) */ unsigned long long get_ticks(void) { - return OSCR; + return readl(OSCR); }
/* diff --git a/arch/arm/cpu/pxa/usb.c b/arch/arm/cpu/pxa/usb.c index bd718a6..0311d5e 100644 --- a/arch/arm/cpu/pxa/usb.c +++ b/arch/arm/cpu/pxa/usb.c @@ -27,86 +27,79 @@ # if defined(CONFIG_CPU_MONAHANS) || defined(CONFIG_PXA27X)
#include <asm/arch/pxa-regs.h> +#include <asm/io.h> #include <usb.h>
int usb_cpu_init(void) { #if defined(CONFIG_CPU_MONAHANS) /* Enable USB host clock. */ - CKENA |= (CKENA_2_USBHOST | CKENA_20_UDC); + writel(readl(CKENA) | CKENA_2_USBHOST | CKENA_20_UDC, CKENA); udelay(100); #endif #if defined(CONFIG_PXA27X) /* Enable USB host clock. */ - CKEN |= CKEN10_USBHOST; + writel(readl(CKEN) | CKEN10_USBHOST, CKEN); #endif
#if defined(CONFIG_CPU_MONAHANS) /* Configure Port 2 for Host (USB Client Registers) */ - UP2OCR = 0x3000c; + writel(0x3000c, UP2OCR); #endif
- UHCHR |= UHCHR_FHR; + writel(readl(UHCHR) | UHCHR_FHR, UHCHR); wait_ms(11); - UHCHR &= ~UHCHR_FHR; + writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR);
- UHCHR |= UHCHR_FSBIR; - while (UHCHR & UHCHR_FSBIR) + writel(readl(UHCHR) | UHCHR_FSBIR, UHCHR); + while (readl(UHCHR) & UHCHR_FSBIR) udelay(1);
#if defined(CONFIG_CPU_MONAHANS) - UHCHR &= ~UHCHR_SSEP0; + writel(readl(UHCHR) & ~UHCHR_SSEP0, UHCHR); #endif #if defined(CONFIG_PXA27X) - UHCHR &= ~UHCHR_SSEP2; + writel(readl(UHCHR) & ~UHCHR_SSEP2, UHCHR); #endif - UHCHR &= ~UHCHR_SSEP1; - UHCHR &= ~UHCHR_SSE; + writel(readl(UHCHR) & ~(UHCHR_SSEP1 | UHCHR_SSE), UHCHR);
return 0; }
int usb_cpu_stop(void) { - UHCHR |= UHCHR_FHR; + writel(readl(UHCHR) | UHCHR_FHR, UHCHR); udelay(11); - UHCHR &= ~UHCHR_FHR; + writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR);
- UHCCOMS |= 1; + writel(readl(UHCCOMS) | UHCHR_FHR, UHCCOMS); udelay(10);
#if defined(CONFIG_CPU_MONAHANS) - UHCHR |= UHCHR_SSEP0; + writel(readl(UHCHR) | UHCHR_SSEP0, UHCHR); #endif #if defined(CONFIG_PXA27X) - UHCHR |= UHCHR_SSEP2; + writel(readl(UHCHR) | UHCHR_SSEP2, UHCHR); #endif - UHCHR |= UHCHR_SSEP1; - UHCHR |= UHCHR_SSE; - - return 0; -} - -int usb_cpu_init_fail(void) -{ - UHCHR |= UHCHR_FHR; - udelay(11); - UHCHR &= ~UHCHR_FHR; - - UHCCOMS |= 1; - udelay(10); + writel(readl(UHCHR) | UHCHR_SSEP1 | UHCHR_SSE, UHCHR);
#if defined(CONFIG_CPU_MONAHANS) - UHCHR |= UHCHR_SSEP0; + /* Disable USB host clock. */ + writel(readl(CKENA) & ~(CKENA_2_USBHOST | CKENA_20_UDC), CKENA); + udelay(100); #endif #if defined(CONFIG_PXA27X) - UHCHR |= UHCHR_SSEP2; + /* Disable USB host clock. */ + writel(readl(CKEN) & ~CKEN10_USBHOST, CKEN); #endif - UHCHR |= UHCHR_SSEP1; - UHCHR |= UHCHR_SSE;
return 0; }
+int usb_cpu_init_fail(void) +{ + return usb_cpu_stop(); +} + # endif /* defined(CONFIG_CPU_MONAHANS) || defined(CONFIG_PXA27X) */ #endif /* defined(CONFIG_USB_OHCI) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) */ diff --git a/arch/arm/include/asm/arch-pxa/hardware.h b/arch/arm/include/asm/arch-pxa/hardware.h index c8c479a..44b800f 100644 --- a/arch/arm/include/asm/arch-pxa/hardware.h +++ b/arch/arm/include/asm/arch-pxa/hardware.h @@ -21,6 +21,19 @@ #include <linux/config.h> #include <asm/mach-types.h>
+/* + * Define CONFIG_CPU_MONAHANS in case some CPU of the PXA3xx family is selected. + * PXA300/310/320 all have distinct register mappings in some cases, that's why + * the exact CPU has to be selected. CONFIG_CPU_MONAHANS is a helper for common + * drivers and compatibility glue with old source then. + */ +#ifndef CONFIG_CPU_MONAHANS +#if defined(CONFIG_CPU_PXA300) || \ + defined(CONFIG_CPU_PXA310) || \ + defined(CONFIG_CPU_PXA320) +#define CONFIG_CPU_MONAHANS +#endif +#endif
/* * These are statically mapped PCMCIA IO space for designs using it as a @@ -51,54 +64,6 @@ * 0x48000000 - 0x49ffffff <--> 0xfc000000 - 0xfdffffff */
-/* FIXME: Only this does work for u-boot... find out why... [RS] */ -#define UBOOT_REG_FIX 1 - -#ifndef UBOOT_REG_FIX -#ifndef __ASSEMBLY__ - -#define io_p2v(x) ( ((x) | 0xbe000000) ^ (~((x) >> 1) & 0x06000000) ) -#define io_v2p( x ) ( ((x) & 0x41ffffff) ^ ( ((x) & 0x06000000) << 1) ) - -/* - * This __REG() version gives the same results as the one above, except - * that we are fooling gcc somehow so it generates far better and smaller - * assembly code for access to contigous registers. It's a shame that gcc - * doesn't guess this by itself. - */ -#include <asm/types.h> -typedef struct { volatile u32 offset[4096]; } __regbase; -# define __REGP(x) ((__regbase *)((x)&~4095))->offset[((x)&4095)>>2] -# define __REG(x) __REGP(io_p2v(x)) -#endif - -/* Let's kick gcc's ass again... */ -# define __REG2(x,y) \ - ( __builtin_constant_p(y) ? (__REG((x) + (y))) \ - : (*(volatile u32 *)((u32)&__REG(x) + (y))) ) - -# define __PREG(x) (io_v2p((u32)&(x))) - -#else - -# define __REG(x) io_p2v(x) -# define __PREG(x) io_v2p(x) - -# undef io_p2v -# undef __REG -# ifndef __ASSEMBLY__ -# define io_p2v(PhAdd) (PhAdd) -# define __REG(x) (*((volatile u32 *)io_p2v(x))) -# define __REG2(x,y) (*(volatile u32 *)((u32)&__REG(x) + (y))) -# else -# define __REG(x) (x) -# ifdef CONFIG_CPU_MONAHANS /* Hack to make this work with mona's pxa-regs.h */ -# define __REG_2(x) (x) -# define __REG_3(x) (x) -# endif -# endif -#endif /* UBOOT_REG_FIX */ - #include "pxa-regs.h"
#ifndef __ASSEMBLY__ diff --git a/arch/arm/include/asm/arch-pxa/pxa-regs.h b/arch/arm/include/asm/arch-pxa/pxa-regs.h index d442fb0..4eefff2 100644 --- a/arch/arm/include/asm/arch-pxa/pxa-regs.h +++ b/arch/arm/include/asm/arch-pxa/pxa-regs.h @@ -93,42 +93,42 @@ typedef void (*ExcpHndlr) (void) ; /* * DMA Controller */ -#define DCSR0 __REG(0x40000000) /* DMA Control / Status Register for Channel 0 */ -#define DCSR1 __REG(0x40000004) /* DMA Control / Status Register for Channel 1 */ -#define DCSR2 __REG(0x40000008) /* DMA Control / Status Register for Channel 2 */ -#define DCSR3 __REG(0x4000000c) /* DMA Control / Status Register for Channel 3 */ -#define DCSR4 __REG(0x40000010) /* DMA Control / Status Register for Channel 4 */ -#define DCSR5 __REG(0x40000014) /* DMA Control / Status Register for Channel 5 */ -#define DCSR6 __REG(0x40000018) /* DMA Control / Status Register for Channel 6 */ -#define DCSR7 __REG(0x4000001c) /* DMA Control / Status Register for Channel 7 */ -#define DCSR8 __REG(0x40000020) /* DMA Control / Status Register for Channel 8 */ -#define DCSR9 __REG(0x40000024) /* DMA Control / Status Register for Channel 9 */ -#define DCSR10 __REG(0x40000028) /* DMA Control / Status Register for Channel 10 */ -#define DCSR11 __REG(0x4000002c) /* DMA Control / Status Register for Channel 11 */ -#define DCSR12 __REG(0x40000030) /* DMA Control / Status Register for Channel 12 */ -#define DCSR13 __REG(0x40000034) /* DMA Control / Status Register for Channel 13 */ -#define DCSR14 __REG(0x40000038) /* DMA Control / Status Register for Channel 14 */ -#define DCSR15 __REG(0x4000003c) /* DMA Control / Status Register for Channel 15 */ -#ifdef CONFIG_CPU_MONAHANS -#define DCSR16 __REG(0x40000040) /* DMA Control / Status Register for Channel 16 */ -#define DCSR17 __REG(0x40000044) /* DMA Control / Status Register for Channel 17 */ -#define DCSR18 __REG(0x40000048) /* DMA Control / Status Register for Channel 18 */ -#define DCSR19 __REG(0x4000004c) /* DMA Control / Status Register for Channel 19 */ -#define DCSR20 __REG(0x40000050) /* DMA Control / Status Register for Channel 20 */ -#define DCSR21 __REG(0x40000054) /* DMA Control / Status Register for Channel 21 */ -#define DCSR22 __REG(0x40000058) /* DMA Control / Status Register for Channel 22 */ -#define DCSR23 __REG(0x4000005c) /* DMA Control / Status Register for Channel 23 */ -#define DCSR24 __REG(0x40000060) /* DMA Control / Status Register for Channel 24 */ -#define DCSR25 __REG(0x40000064) /* DMA Control / Status Register for Channel 25 */ -#define DCSR26 __REG(0x40000068) /* DMA Control / Status Register for Channel 26 */ -#define DCSR27 __REG(0x4000006c) /* DMA Control / Status Register for Channel 27 */ -#define DCSR28 __REG(0x40000070) /* DMA Control / Status Register for Channel 28 */ -#define DCSR29 __REG(0x40000074) /* DMA Control / Status Register for Channel 29 */ -#define DCSR30 __REG(0x40000078) /* DMA Control / Status Register for Channel 30 */ -#define DCSR31 __REG(0x4000007c) /* DMA Control / Status Register for Channel 31 */ -#endif /* CONFIG_CPU_MONAHANS */ - -#define DCSR(x) __REG2(0x40000000, (x) << 2) +#define DCSR0 (0x40000000) /* DMA Control / Status Register for Channel 0 */ +#define DCSR1 (0x40000004) /* DMA Control / Status Register for Channel 1 */ +#define DCSR2 (0x40000008) /* DMA Control / Status Register for Channel 2 */ +#define DCSR3 (0x4000000c) /* DMA Control / Status Register for Channel 3 */ +#define DCSR4 (0x40000010) /* DMA Control / Status Register for Channel 4 */ +#define DCSR5 (0x40000014) /* DMA Control / Status Register for Channel 5 */ +#define DCSR6 (0x40000018) /* DMA Control / Status Register for Channel 6 */ +#define DCSR7 (0x4000001c) /* DMA Control / Status Register for Channel 7 */ +#define DCSR8 (0x40000020) /* DMA Control / Status Register for Channel 8 */ +#define DCSR9 (0x40000024) /* DMA Control / Status Register for Channel 9 */ +#define DCSR10 (0x40000028) /* DMA Control / Status Register for Channel 10 */ +#define DCSR11 (0x4000002c) /* DMA Control / Status Register for Channel 11 */ +#define DCSR12 (0x40000030) /* DMA Control / Status Register for Channel 12 */ +#define DCSR13 (0x40000034) /* DMA Control / Status Register for Channel 13 */ +#define DCSR14 (0x40000038) /* DMA Control / Status Register for Channel 14 */ +#define DCSR15 (0x4000003c) /* DMA Control / Status Register for Channel 15 */ +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define DCSR16 (0x40000040) /* DMA Control / Status Register for Channel 16 */ +#define DCSR17 (0x40000044) /* DMA Control / Status Register for Channel 17 */ +#define DCSR18 (0x40000048) /* DMA Control / Status Register for Channel 18 */ +#define DCSR19 (0x4000004c) /* DMA Control / Status Register for Channel 19 */ +#define DCSR20 (0x40000050) /* DMA Control / Status Register for Channel 20 */ +#define DCSR21 (0x40000054) /* DMA Control / Status Register for Channel 21 */ +#define DCSR22 (0x40000058) /* DMA Control / Status Register for Channel 22 */ +#define DCSR23 (0x4000005c) /* DMA Control / Status Register for Channel 23 */ +#define DCSR24 (0x40000060) /* DMA Control / Status Register for Channel 24 */ +#define DCSR25 (0x40000064) /* DMA Control / Status Register for Channel 25 */ +#define DCSR26 (0x40000068) /* DMA Control / Status Register for Channel 26 */ +#define DCSR27 (0x4000006c) /* DMA Control / Status Register for Channel 27 */ +#define DCSR28 (0x40000070) /* DMA Control / Status Register for Channel 28 */ +#define DCSR29 (0x40000074) /* DMA Control / Status Register for Channel 29 */ +#define DCSR30 (0x40000078) /* DMA Control / Status Register for Channel 30 */ +#define DCSR31 (0x4000007c) /* DMA Control / Status Register for Channel 31 */ +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */ + +#define DCSR(x) (0x40000000 | ((x) << 2))
#define DCSR_RUN (1 << 31) /* Run Bit (read / write) */ #define DCSR_NODESC (1 << 30) /* No-Descriptor Fetch (read / write) */ @@ -150,52 +150,52 @@ typedef void (*ExcpHndlr) (void) ; #define DCSR_STARTINTR (1 << 1) /* Start Interrupt (read / write) */ #define DCSR_BUSERR (1 << 0) /* Bus Error Interrupt (read / write) */
-#define DINT __REG(0x400000f0) /* DMA Interrupt Register */ - -#define DRCMR0 __REG(0x40000100) /* Request to Channel Map Register for DREQ 0 */ -#define DRCMR1 __REG(0x40000104) /* Request to Channel Map Register for DREQ 1 */ -#define DRCMR2 __REG(0x40000108) /* Request to Channel Map Register for I2S receive Request */ -#define DRCMR3 __REG(0x4000010c) /* Request to Channel Map Register for I2S transmit Request */ -#define DRCMR4 __REG(0x40000110) /* Request to Channel Map Register for BTUART receive Request */ -#define DRCMR5 __REG(0x40000114) /* Request to Channel Map Register for BTUART transmit Request. */ -#define DRCMR6 __REG(0x40000118) /* Request to Channel Map Register for FFUART receive Request */ -#define DRCMR7 __REG(0x4000011c) /* Request to Channel Map Register for FFUART transmit Request */ -#define DRCMR8 __REG(0x40000120) /* Request to Channel Map Register for AC97 microphone Request */ -#define DRCMR9 __REG(0x40000124) /* Request to Channel Map Register for AC97 modem receive Request */ -#define DRCMR10 __REG(0x40000128) /* Request to Channel Map Register for AC97 modem transmit Request */ -#define DRCMR11 __REG(0x4000012c) /* Request to Channel Map Register for AC97 audio receive Request */ -#define DRCMR12 __REG(0x40000130) /* Request to Channel Map Register for AC97 audio transmit Request */ -#define DRCMR13 __REG(0x40000134) /* Request to Channel Map Register for SSP receive Request */ -#define DRCMR14 __REG(0x40000138) /* Request to Channel Map Register for SSP transmit Request */ -#define DRCMR15 __REG(0x4000013c) /* Reserved */ -#define DRCMR16 __REG(0x40000140) /* Reserved */ -#define DRCMR17 __REG(0x40000144) /* Request to Channel Map Register for ICP receive Request */ -#define DRCMR18 __REG(0x40000148) /* Request to Channel Map Register for ICP transmit Request */ -#define DRCMR19 __REG(0x4000014c) /* Request to Channel Map Register for STUART receive Request */ -#define DRCMR20 __REG(0x40000150) /* Request to Channel Map Register for STUART transmit Request */ -#define DRCMR21 __REG(0x40000154) /* Request to Channel Map Register for MMC receive Request */ -#define DRCMR22 __REG(0x40000158) /* Request to Channel Map Register for MMC transmit Request */ -#define DRCMR23 __REG(0x4000015c) /* Reserved */ -#define DRCMR24 __REG(0x40000160) /* Reserved */ -#define DRCMR25 __REG(0x40000164) /* Request to Channel Map Register for USB endpoint 1 Request */ -#define DRCMR26 __REG(0x40000168) /* Request to Channel Map Register for USB endpoint 2 Request */ -#define DRCMR27 __REG(0x4000016C) /* Request to Channel Map Register for USB endpoint 3 Request */ -#define DRCMR28 __REG(0x40000170) /* Request to Channel Map Register for USB endpoint 4 Request */ -#define DRCMR29 __REG(0x40000174) /* Reserved */ -#define DRCMR30 __REG(0x40000178) /* Request to Channel Map Register for USB endpoint 6 Request */ -#define DRCMR31 __REG(0x4000017C) /* Request to Channel Map Register for USB endpoint 7 Request */ -#define DRCMR32 __REG(0x40000180) /* Request to Channel Map Register for USB endpoint 8 Request */ -#define DRCMR33 __REG(0x40000184) /* Request to Channel Map Register for USB endpoint 9 Request */ -#define DRCMR34 __REG(0x40000188) /* Reserved */ -#define DRCMR35 __REG(0x4000018C) /* Request to Channel Map Register for USB endpoint 11 Request */ -#define DRCMR36 __REG(0x40000190) /* Request to Channel Map Register for USB endpoint 12 Request */ -#define DRCMR37 __REG(0x40000194) /* Request to Channel Map Register for USB endpoint 13 Request */ -#define DRCMR38 __REG(0x40000198) /* Request to Channel Map Register for USB endpoint 14 Request */ -#define DRCMR39 __REG(0x4000019C) /* Reserved */ - -#define DRCMR68 __REG(0x40001110) /* Request to Channel Map Register for Camera FIFO 0 Request */ -#define DRCMR69 __REG(0x40001114) /* Request to Channel Map Register for Camera FIFO 1 Request */ -#define DRCMR70 __REG(0x40001118) /* Request to Channel Map Register for Camera FIFO 2 Request */ +#define DINT (0x400000f0) /* DMA Interrupt Register */ + +#define DRCMR0 (0x40000100) /* Request to Channel Map Register for DREQ 0 */ +#define DRCMR1 (0x40000104) /* Request to Channel Map Register for DREQ 1 */ +#define DRCMR2 (0x40000108) /* Request to Channel Map Register for I2S receive Request */ +#define DRCMR3 (0x4000010c) /* Request to Channel Map Register for I2S transmit Request */ +#define DRCMR4 (0x40000110) /* Request to Channel Map Register for BTUART receive Request */ +#define DRCMR5 (0x40000114) /* Request to Channel Map Register for BTUART transmit Request. */ +#define DRCMR6 (0x40000118) /* Request to Channel Map Register for FFUART receive Request */ +#define DRCMR7 (0x4000011c) /* Request to Channel Map Register for FFUART transmit Request */ +#define DRCMR8 (0x40000120) /* Request to Channel Map Register for AC97 microphone Request */ +#define DRCMR9 (0x40000124) /* Request to Channel Map Register for AC97 modem receive Request */ +#define DRCMR10 (0x40000128) /* Request to Channel Map Register for AC97 modem transmit Request */ +#define DRCMR11 (0x4000012c) /* Request to Channel Map Register for AC97 audio receive Request */ +#define DRCMR12 (0x40000130) /* Request to Channel Map Register for AC97 audio transmit Request */ +#define DRCMR13 (0x40000134) /* Request to Channel Map Register for SSP receive Request */ +#define DRCMR14 (0x40000138) /* Request to Channel Map Register for SSP transmit Request */ +#define DRCMR15 (0x4000013c) /* Reserved */ +#define DRCMR16 (0x40000140) /* Reserved */ +#define DRCMR17 (0x40000144) /* Request to Channel Map Register for ICP receive Request */ +#define DRCMR18 (0x40000148) /* Request to Channel Map Register for ICP transmit Request */ +#define DRCMR19 (0x4000014c) /* Request to Channel Map Register for STUART receive Request */ +#define DRCMR20 (0x40000150) /* Request to Channel Map Register for STUART transmit Request */ +#define DRCMR21 (0x40000154) /* Request to Channel Map Register for MMC receive Request */ +#define DRCMR22 (0x40000158) /* Request to Channel Map Register for MMC transmit Request */ +#define DRCMR23 (0x4000015c) /* Reserved */ +#define DRCMR24 (0x40000160) /* Reserved */ +#define DRCMR25 (0x40000164) /* Request to Channel Map Register for USB endpoint 1 Request */ +#define DRCMR26 (0x40000168) /* Request to Channel Map Register for USB endpoint 2 Request */ +#define DRCMR27 (0x4000016C) /* Request to Channel Map Register for USB endpoint 3 Request */ +#define DRCMR28 (0x40000170) /* Request to Channel Map Register for USB endpoint 4 Request */ +#define DRCMR29 (0x40000174) /* Reserved */ +#define DRCMR30 (0x40000178) /* Request to Channel Map Register for USB endpoint 6 Request */ +#define DRCMR31 (0x4000017C) /* Request to Channel Map Register for USB endpoint 7 Request */ +#define DRCMR32 (0x40000180) /* Request to Channel Map Register for USB endpoint 8 Request */ +#define DRCMR33 (0x40000184) /* Request to Channel Map Register for USB endpoint 9 Request */ +#define DRCMR34 (0x40000188) /* Reserved */ +#define DRCMR35 (0x4000018C) /* Request to Channel Map Register for USB endpoint 11 Request */ +#define DRCMR36 (0x40000190) /* Request to Channel Map Register for USB endpoint 12 Request */ +#define DRCMR37 (0x40000194) /* Request to Channel Map Register for USB endpoint 13 Request */ +#define DRCMR38 (0x40000198) /* Request to Channel Map Register for USB endpoint 14 Request */ +#define DRCMR39 (0x4000019C) /* Reserved */ + +#define DRCMR68 (0x40001110) /* Request to Channel Map Register for Camera FIFO 0 Request */ +#define DRCMR69 (0x40001114) /* Request to Channel Map Register for Camera FIFO 1 Request */ +#define DRCMR70 (0x40001118) /* Request to Channel Map Register for Camera FIFO 2 Request */
#define DRCMRRXSADR DRCMR2 #define DRCMRTXSADR DRCMR3 @@ -220,75 +220,75 @@ typedef void (*ExcpHndlr) (void) ; #define DRCMR_MAPVLD (1 << 7) /* Map Valid (read / write) */ #define DRCMR_CHLNUM 0x0f /* mask for Channel Number (read / write) */
-#define DDADR0 __REG(0x40000200) /* DMA Descriptor Address Register Channel 0 */ -#define DSADR0 __REG(0x40000204) /* DMA Source Address Register Channel 0 */ -#define DTADR0 __REG(0x40000208) /* DMA Target Address Register Channel 0 */ -#define DCMD0 __REG(0x4000020c) /* DMA Command Address Register Channel 0 */ -#define DDADR1 __REG(0x40000210) /* DMA Descriptor Address Register Channel 1 */ -#define DSADR1 __REG(0x40000214) /* DMA Source Address Register Channel 1 */ -#define DTADR1 __REG(0x40000218) /* DMA Target Address Register Channel 1 */ -#define DCMD1 __REG(0x4000021c) /* DMA Command Address Register Channel 1 */ -#define DDADR2 __REG(0x40000220) /* DMA Descriptor Address Register Channel 2 */ -#define DSADR2 __REG(0x40000224) /* DMA Source Address Register Channel 2 */ -#define DTADR2 __REG(0x40000228) /* DMA Target Address Register Channel 2 */ -#define DCMD2 __REG(0x4000022c) /* DMA Command Address Register Channel 2 */ -#define DDADR3 __REG(0x40000230) /* DMA Descriptor Address Register Channel 3 */ -#define DSADR3 __REG(0x40000234) /* DMA Source Address Register Channel 3 */ -#define DTADR3 __REG(0x40000238) /* DMA Target Address Register Channel 3 */ -#define DCMD3 __REG(0x4000023c) /* DMA Command Address Register Channel 3 */ -#define DDADR4 __REG(0x40000240) /* DMA Descriptor Address Register Channel 4 */ -#define DSADR4 __REG(0x40000244) /* DMA Source Address Register Channel 4 */ -#define DTADR4 __REG(0x40000248) /* DMA Target Address Register Channel 4 */ -#define DCMD4 __REG(0x4000024c) /* DMA Command Address Register Channel 4 */ -#define DDADR5 __REG(0x40000250) /* DMA Descriptor Address Register Channel 5 */ -#define DSADR5 __REG(0x40000254) /* DMA Source Address Register Channel 5 */ -#define DTADR5 __REG(0x40000258) /* DMA Target Address Register Channel 5 */ -#define DCMD5 __REG(0x4000025c) /* DMA Command Address Register Channel 5 */ -#define DDADR6 __REG(0x40000260) /* DMA Descriptor Address Register Channel 6 */ -#define DSADR6 __REG(0x40000264) /* DMA Source Address Register Channel 6 */ -#define DTADR6 __REG(0x40000268) /* DMA Target Address Register Channel 6 */ -#define DCMD6 __REG(0x4000026c) /* DMA Command Address Register Channel 6 */ -#define DDADR7 __REG(0x40000270) /* DMA Descriptor Address Register Channel 7 */ -#define DSADR7 __REG(0x40000274) /* DMA Source Address Register Channel 7 */ -#define DTADR7 __REG(0x40000278) /* DMA Target Address Register Channel 7 */ -#define DCMD7 __REG(0x4000027c) /* DMA Command Address Register Channel 7 */ -#define DDADR8 __REG(0x40000280) /* DMA Descriptor Address Register Channel 8 */ -#define DSADR8 __REG(0x40000284) /* DMA Source Address Register Channel 8 */ -#define DTADR8 __REG(0x40000288) /* DMA Target Address Register Channel 8 */ -#define DCMD8 __REG(0x4000028c) /* DMA Command Address Register Channel 8 */ -#define DDADR9 __REG(0x40000290) /* DMA Descriptor Address Register Channel 9 */ -#define DSADR9 __REG(0x40000294) /* DMA Source Address Register Channel 9 */ -#define DTADR9 __REG(0x40000298) /* DMA Target Address Register Channel 9 */ -#define DCMD9 __REG(0x4000029c) /* DMA Command Address Register Channel 9 */ -#define DDADR10 __REG(0x400002a0) /* DMA Descriptor Address Register Channel 10 */ -#define DSADR10 __REG(0x400002a4) /* DMA Source Address Register Channel 10 */ -#define DTADR10 __REG(0x400002a8) /* DMA Target Address Register Channel 10 */ -#define DCMD10 __REG(0x400002ac) /* DMA Command Address Register Channel 10 */ -#define DDADR11 __REG(0x400002b0) /* DMA Descriptor Address Register Channel 11 */ -#define DSADR11 __REG(0x400002b4) /* DMA Source Address Register Channel 11 */ -#define DTADR11 __REG(0x400002b8) /* DMA Target Address Register Channel 11 */ -#define DCMD11 __REG(0x400002bc) /* DMA Command Address Register Channel 11 */ -#define DDADR12 __REG(0x400002c0) /* DMA Descriptor Address Register Channel 12 */ -#define DSADR12 __REG(0x400002c4) /* DMA Source Address Register Channel 12 */ -#define DTADR12 __REG(0x400002c8) /* DMA Target Address Register Channel 12 */ -#define DCMD12 __REG(0x400002cc) /* DMA Command Address Register Channel 12 */ -#define DDADR13 __REG(0x400002d0) /* DMA Descriptor Address Register Channel 13 */ -#define DSADR13 __REG(0x400002d4) /* DMA Source Address Register Channel 13 */ -#define DTADR13 __REG(0x400002d8) /* DMA Target Address Register Channel 13 */ -#define DCMD13 __REG(0x400002dc) /* DMA Command Address Register Channel 13 */ -#define DDADR14 __REG(0x400002e0) /* DMA Descriptor Address Register Channel 14 */ -#define DSADR14 __REG(0x400002e4) /* DMA Source Address Register Channel 14 */ -#define DTADR14 __REG(0x400002e8) /* DMA Target Address Register Channel 14 */ -#define DCMD14 __REG(0x400002ec) /* DMA Command Address Register Channel 14 */ -#define DDADR15 __REG(0x400002f0) /* DMA Descriptor Address Register Channel 15 */ -#define DSADR15 __REG(0x400002f4) /* DMA Source Address Register Channel 15 */ -#define DTADR15 __REG(0x400002f8) /* DMA Target Address Register Channel 15 */ -#define DCMD15 __REG(0x400002fc) /* DMA Command Address Register Channel 15 */ - -#define DDADR(x) __REG2(0x40000200, (x) << 4) -#define DSADR(x) __REG2(0x40000204, (x) << 4) -#define DTADR(x) __REG2(0x40000208, (x) << 4) -#define DCMD(x) __REG2(0x4000020c, (x) << 4) +#define DDADR0 (0x40000200) /* DMA Descriptor Address Register Channel 0 */ +#define DSADR0 (0x40000204) /* DMA Source Address Register Channel 0 */ +#define DTADR0 (0x40000208) /* DMA Target Address Register Channel 0 */ +#define DCMD0 (0x4000020c) /* DMA Command Address Register Channel 0 */ +#define DDADR1 (0x40000210) /* DMA Descriptor Address Register Channel 1 */ +#define DSADR1 (0x40000214) /* DMA Source Address Register Channel 1 */ +#define DTADR1 (0x40000218) /* DMA Target Address Register Channel 1 */ +#define DCMD1 (0x4000021c) /* DMA Command Address Register Channel 1 */ +#define DDADR2 (0x40000220) /* DMA Descriptor Address Register Channel 2 */ +#define DSADR2 (0x40000224) /* DMA Source Address Register Channel 2 */ +#define DTADR2 (0x40000228) /* DMA Target Address Register Channel 2 */ +#define DCMD2 (0x4000022c) /* DMA Command Address Register Channel 2 */ +#define DDADR3 (0x40000230) /* DMA Descriptor Address Register Channel 3 */ +#define DSADR3 (0x40000234) /* DMA Source Address Register Channel 3 */ +#define DTADR3 (0x40000238) /* DMA Target Address Register Channel 3 */ +#define DCMD3 (0x4000023c) /* DMA Command Address Register Channel 3 */ +#define DDADR4 (0x40000240) /* DMA Descriptor Address Register Channel 4 */ +#define DSADR4 (0x40000244) /* DMA Source Address Register Channel 4 */ +#define DTADR4 (0x40000248) /* DMA Target Address Register Channel 4 */ +#define DCMD4 (0x4000024c) /* DMA Command Address Register Channel 4 */ +#define DDADR5 (0x40000250) /* DMA Descriptor Address Register Channel 5 */ +#define DSADR5 (0x40000254) /* DMA Source Address Register Channel 5 */ +#define DTADR5 (0x40000258) /* DMA Target Address Register Channel 5 */ +#define DCMD5 (0x4000025c) /* DMA Command Address Register Channel 5 */ +#define DDADR6 (0x40000260) /* DMA Descriptor Address Register Channel 6 */ +#define DSADR6 (0x40000264) /* DMA Source Address Register Channel 6 */ +#define DTADR6 (0x40000268) /* DMA Target Address Register Channel 6 */ +#define DCMD6 (0x4000026c) /* DMA Command Address Register Channel 6 */ +#define DDADR7 (0x40000270) /* DMA Descriptor Address Register Channel 7 */ +#define DSADR7 (0x40000274) /* DMA Source Address Register Channel 7 */ +#define DTADR7 (0x40000278) /* DMA Target Address Register Channel 7 */ +#define DCMD7 (0x4000027c) /* DMA Command Address Register Channel 7 */ +#define DDADR8 (0x40000280) /* DMA Descriptor Address Register Channel 8 */ +#define DSADR8 (0x40000284) /* DMA Source Address Register Channel 8 */ +#define DTADR8 (0x40000288) /* DMA Target Address Register Channel 8 */ +#define DCMD8 (0x4000028c) /* DMA Command Address Register Channel 8 */ +#define DDADR9 (0x40000290) /* DMA Descriptor Address Register Channel 9 */ +#define DSADR9 (0x40000294) /* DMA Source Address Register Channel 9 */ +#define DTADR9 (0x40000298) /* DMA Target Address Register Channel 9 */ +#define DCMD9 (0x4000029c) /* DMA Command Address Register Channel 9 */ +#define DDADR10 (0x400002a0) /* DMA Descriptor Address Register Channel 10 */ +#define DSADR10 (0x400002a4) /* DMA Source Address Register Channel 10 */ +#define DTADR10 (0x400002a8) /* DMA Target Address Register Channel 10 */ +#define DCMD10 (0x400002ac) /* DMA Command Address Register Channel 10 */ +#define DDADR11 (0x400002b0) /* DMA Descriptor Address Register Channel 11 */ +#define DSADR11 (0x400002b4) /* DMA Source Address Register Channel 11 */ +#define DTADR11 (0x400002b8) /* DMA Target Address Register Channel 11 */ +#define DCMD11 (0x400002bc) /* DMA Command Address Register Channel 11 */ +#define DDADR12 (0x400002c0) /* DMA Descriptor Address Register Channel 12 */ +#define DSADR12 (0x400002c4) /* DMA Source Address Register Channel 12 */ +#define DTADR12 (0x400002c8) /* DMA Target Address Register Channel 12 */ +#define DCMD12 (0x400002cc) /* DMA Command Address Register Channel 12 */ +#define DDADR13 (0x400002d0) /* DMA Descriptor Address Register Channel 13 */ +#define DSADR13 (0x400002d4) /* DMA Source Address Register Channel 13 */ +#define DTADR13 (0x400002d8) /* DMA Target Address Register Channel 13 */ +#define DCMD13 (0x400002dc) /* DMA Command Address Register Channel 13 */ +#define DDADR14 (0x400002e0) /* DMA Descriptor Address Register Channel 14 */ +#define DSADR14 (0x400002e4) /* DMA Source Address Register Channel 14 */ +#define DTADR14 (0x400002e8) /* DMA Target Address Register Channel 14 */ +#define DCMD14 (0x400002ec) /* DMA Command Address Register Channel 14 */ +#define DDADR15 (0x400002f0) /* DMA Descriptor Address Register Channel 15 */ +#define DSADR15 (0x400002f4) /* DMA Source Address Register Channel 15 */ +#define DTADR15 (0x400002f8) /* DMA Target Address Register Channel 15 */ +#define DCMD15 (0x400002fc) /* DMA Command Address Register Channel 15 */ + +#define DDADR(x) (0x40000200 | ((x) << 4)) +#define DSADR(x) (0x40000204 | ((x) << 4)) +#define DTADR(x) (0x40000208 | ((x) << 4)) +#define DCMD(x) (0x4000020c | ((x) << 4))
#define DDADR_DESCADDR 0xfffffff0 /* Address of next descriptor (mask) */ #define DDADR_STOP (1 << 0) /* Stop (read / write) */ @@ -313,56 +313,57 @@ typedef void (*ExcpHndlr) (void) ; #define DCMD_RXMCDR (DCMD_INCTRGADDR|DCMD_FLOWSRC|DCMD_BURST32|DCMD_WIDTH4) #define DCMD_TXPCDR (DCMD_INCSRCADDR|DCMD_FLOWTRG|DCMD_BURST32|DCMD_WIDTH4)
+/******************************************************************************/ /* * UARTs */ /* Full Function UART (FFUART) */ #define FFUART FFRBR -#define FFRBR __REG(0x40100000) /* Receive Buffer Register (read only) */ -#define FFTHR __REG(0x40100000) /* Transmit Holding Register (write only) */ -#define FFIER __REG(0x40100004) /* Interrupt Enable Register (read/write) */ -#define FFIIR __REG(0x40100008) /* Interrupt ID Register (read only) */ -#define FFFCR __REG(0x40100008) /* FIFO Control Register (write only) */ -#define FFLCR __REG(0x4010000C) /* Line Control Register (read/write) */ -#define FFMCR __REG(0x40100010) /* Modem Control Register (read/write) */ -#define FFLSR __REG(0x40100014) /* Line Status Register (read only) */ -#define FFMSR __REG(0x40100018) /* Modem Status Register (read only) */ -#define FFSPR __REG(0x4010001C) /* Scratch Pad Register (read/write) */ -#define FFISR __REG(0x40100020) /* Infrared Selection Register (read/write) */ -#define FFDLL __REG(0x40100000) /* Divisor Latch Low Register (DLAB = 1) (read/write) */ -#define FFDLH __REG(0x40100004) /* Divisor Latch High Register (DLAB = 1) (read/write) */ +#define FFRBR (0x40100000) /* Receive Buffer Register (read only) */ +#define FFTHR (0x40100000) /* Transmit Holding Register (write only) */ +#define FFIER (0x40100004) /* Interrupt Enable Register (read/write) */ +#define FFIIR (0x40100008) /* Interrupt ID Register (read only) */ +#define FFFCR (0x40100008) /* FIFO Control Register (write only) */ +#define FFLCR (0x4010000C) /* Line Control Register (read/write) */ +#define FFMCR (0x40100010) /* Modem Control Register (read/write) */ +#define FFLSR (0x40100014) /* Line Status Register (read only) */ +#define FFMSR (0x40100018) /* Modem Status Register (read only) */ +#define FFSPR (0x4010001C) /* Scratch Pad Register (read/write) */ +#define FFISR (0x40100020) /* Infrared Selection Register (read/write) */ +#define FFDLL (0x40100000) /* Divisor Latch Low Register (DLAB = 1) (read/write) */ +#define FFDLH (0x40100004) /* Divisor Latch High Register (DLAB = 1) (read/write) */
/* Bluetooth UART (BTUART) */ #define BTUART BTRBR -#define BTRBR __REG(0x40200000) /* Receive Buffer Register (read only) */ -#define BTTHR __REG(0x40200000) /* Transmit Holding Register (write only) */ -#define BTIER __REG(0x40200004) /* Interrupt Enable Register (read/write) */ -#define BTIIR __REG(0x40200008) /* Interrupt ID Register (read only) */ -#define BTFCR __REG(0x40200008) /* FIFO Control Register (write only) */ -#define BTLCR __REG(0x4020000C) /* Line Control Register (read/write) */ -#define BTMCR __REG(0x40200010) /* Modem Control Register (read/write) */ -#define BTLSR __REG(0x40200014) /* Line Status Register (read only) */ -#define BTMSR __REG(0x40200018) /* Modem Status Register (read only) */ -#define BTSPR __REG(0x4020001C) /* Scratch Pad Register (read/write) */ -#define BTISR __REG(0x40200020) /* Infrared Selection Register (read/write) */ -#define BTDLL __REG(0x40200000) /* Divisor Latch Low Register (DLAB = 1) (read/write) */ -#define BTDLH __REG(0x40200004) /* Divisor Latch High Register (DLAB = 1) (read/write) */ +#define BTRBR (0x40200000) /* Receive Buffer Register (read only) */ +#define BTTHR (0x40200000) /* Transmit Holding Register (write only) */ +#define BTIER (0x40200004) /* Interrupt Enable Register (read/write) */ +#define BTIIR (0x40200008) /* Interrupt ID Register (read only) */ +#define BTFCR (0x40200008) /* FIFO Control Register (write only) */ +#define BTLCR (0x4020000C) /* Line Control Register (read/write) */ +#define BTMCR (0x40200010) /* Modem Control Register (read/write) */ +#define BTLSR (0x40200014) /* Line Status Register (read only) */ +#define BTMSR (0x40200018) /* Modem Status Register (read only) */ +#define BTSPR (0x4020001C) /* Scratch Pad Register (read/write) */ +#define BTISR (0x40200020) /* Infrared Selection Register (read/write) */ +#define BTDLL (0x40200000) /* Divisor Latch Low Register (DLAB = 1) (read/write) */ +#define BTDLH (0x40200004) /* Divisor Latch High Register (DLAB = 1) (read/write) */
/* Standard UART (STUART) */ #define STUART STRBR -#define STRBR __REG(0x40700000) /* Receive Buffer Register (read only) */ -#define STTHR __REG(0x40700000) /* Transmit Holding Register (write only) */ -#define STIER __REG(0x40700004) /* Interrupt Enable Register (read/write) */ -#define STIIR __REG(0x40700008) /* Interrupt ID Register (read only) */ -#define STFCR __REG(0x40700008) /* FIFO Control Register (write only) */ -#define STLCR __REG(0x4070000C) /* Line Control Register (read/write) */ -#define STMCR __REG(0x40700010) /* Modem Control Register (read/write) */ -#define STLSR __REG(0x40700014) /* Line Status Register (read only) */ -#define STMSR __REG(0x40700018) /* Reserved */ -#define STSPR __REG(0x4070001C) /* Scratch Pad Register (read/write) */ -#define STISR __REG(0x40700020) /* Infrared Selection Register (read/write) */ -#define STDLL __REG(0x40700000) /* Divisor Latch Low Register (DLAB = 1) (read/write) */ -#define STDLH __REG(0x40700004) /* Divisor Latch High Register (DLAB = 1) (read/write) */ +#define STRBR (0x40700000) /* Receive Buffer Register (read only) */ +#define STTHR (0x40700000) /* Transmit Holding Register (write only) */ +#define STIER (0x40700004) /* Interrupt Enable Register (read/write) */ +#define STIIR (0x40700008) /* Interrupt ID Register (read only) */ +#define STFCR (0x40700008) /* FIFO Control Register (write only) */ +#define STLCR (0x4070000C) /* Line Control Register (read/write) */ +#define STMCR (0x40700010) /* Modem Control Register (read/write) */ +#define STLSR (0x40700014) /* Line Status Register (read only) */ +#define STMSR (0x40700018) /* Reserved */ +#define STSPR (0x4070001C) /* Scratch Pad Register (read/write) */ +#define STISR (0x40700020) /* Infrared Selection Register (read/write) */ +#define STDLL (0x40700000) /* Divisor Latch Low Register (DLAB = 1) (read/write) */ +#define STDLH (0x40700004) /* Divisor Latch High Register (DLAB = 1) (read/write) */
#define IER_DMAE (1 << 7) /* DMA Requests Enable */ #define IER_UUE (1 << 6) /* UART Unit Enable */ @@ -408,7 +409,7 @@ typedef void (*ExcpHndlr) (void) ; #define LSR_OE (1 << 1) /* Overrun Error */ #define LSR_DR (1 << 0) /* Data Ready */
-#define MCR_LOOP (1 << 4) */ +#define MCR_LOOP (1 << 4) /* */ #define MCR_OUT2 (1 << 3) /* force MSR_DCD in loopback mode */ #define MCR_OUT1 (1 << 2) /* force MSR_RI in loopback mode */ #define MCR_RTS (1 << 1) /* Request to Send */ @@ -423,6 +424,7 @@ typedef void (*ExcpHndlr) (void) ; #define MSR_DDSR (1 << 1) /* Delta Data Set Ready */ #define MSR_DCTS (1 << 0) /* Delta Clear To Send */
+/******************************************************************************/ /* * IrSR (Infrared Selection Register) */ @@ -456,17 +458,25 @@ typedef void (*ExcpHndlr) (void) ; /* * I2C registers */ -#define IBMR __REG(0x40301680) /* I2C Bus Monitor Register - IBMR */ -#define IDBR __REG(0x40301688) /* I2C Data Buffer Register - IDBR */ -#define ICR __REG(0x40301690) /* I2C Control Register - ICR */ -#define ISR __REG(0x40301698) /* I2C Status Register - ISR */ -#define ISAR __REG(0x403016A0) /* I2C Slave Address Register - ISAR */ - -#define PWRIBMR __REG(0x40f00180) /* Power I2C Bus Monitor Register-IBMR */ -#define PWRIDBR __REG(0x40f00188) /* Power I2C Data Buffer Register-IDBR */ -#define PWRICR __REG(0x40f00190) /* Power I2C Control Register - ICR */ -#define PWRISR __REG(0x40f00198) /* Power I2C Status Register - ISR */ -#define PWRISAR __REG(0x40f001A0) /* Power I2C Slave Address Register-ISAR */ +#define IBMR (0x40301680) /* I2C Bus Monitor Register - IBMR */ +#define IDBR (0x40301688) /* I2C Data Buffer Register - IDBR */ +#define ICR (0x40301690) /* I2C Control Register - ICR */ +#define ISR (0x40301698) /* I2C Status Register - ISR */ +#define ISAR (0x403016A0) /* I2C Slave Address Register - ISAR */ + +#ifdef CONFIG_CPU_MONAHANS +#define PWRIBMR (0x40f500C0) /* Power I2C Bus Monitor Register-IBMR */ +#define PWRIDBR (0x40f500C4) /* Power I2C Data Buffer Register-IDBR */ +#define PWRICR (0x40f500C8) /* Power I2C Control Register - ICR */ +#define PWRISR (0x40f500CC) /* Power I2C Status Register - ISR */ +#define PWRISAR (0x40f500D0) /* Power I2C Slave Address Register-ISAR */ +#else +#define PWRIBMR (0x40f00180) /* Power I2C Bus Monitor Register-IBMR */ +#define PWRIDBR (0x40f00188) /* Power I2C Data Buffer Register-IDBR */ +#define PWRICR (0x40f00190) /* Power I2C Control Register - ICR */ +#define PWRISR (0x40f00198) /* Power I2C Status Register - ISR */ +#define PWRISAR (0x40f001A0) /* Power I2C Slave Address Register-ISAR */ +#endif
/* ----- Control register bits ---------------------------------------- */
@@ -507,28 +517,28 @@ typedef void (*ExcpHndlr) (void) ; /* FIXME the audio defines collide w/ the SA1111 defines. I don't like these * short defines because there is too much chance of namespace collision */ -/*#define SACR0 __REG(0x40400000) / Global Control Register */ -/*#define SACR1 __REG(0x40400004) / Serial Audio I 2 S/MSB-Justified Control Register */ -/*#define SASR0 __REG(0x4040000C) / Serial Audio I 2 S/MSB-Justified Interface and FIFO Status Register */ -/*#define SAIMR __REG(0x40400014) / Serial Audio Interrupt Mask Register */ -/*#define SAICR __REG(0x40400018) / Serial Audio Interrupt Clear Register */ -/*#define SADIV __REG(0x40400060) / Audio Clock Divider Register. */ -/*#define SADR __REG(0x40400080) / Serial Audio Data Register (TX and RX FIFO access Register). */ +///*#define SACR0 (0x40400000) / Global Control Register */ +///*#define SACR1 (0x40400004) / Serial Audio I 2 S/MSB-Justified Control Register */ +///*#define SASR0 (0x4040000C) / Serial Audio I 2 S/MSB-Justified Interface and FIFO Status Register */ +///*#define SAIMR (0x40400014) / Serial Audio Interrupt Mask Register */ +///*#define SAICR (0x40400018) / Serial Audio Interrupt Clear Register */ +///*#define SADIV (0x40400060) / Audio Clock Divider Register. */ +///*#define SADR (0x40400080) / Serial Audio Data Register (TX and RX FIFO access Register). */
/* * AC97 Controller registers */ -#define POCR __REG(0x40500000) /* PCM Out Control Register */ +#define POCR (0x40500000) /* PCM Out Control Register */ #define POCR_FEIE (1 << 3) /* FIFO Error Interrupt Enable */
-#define PICR __REG(0x40500004) /* PCM In Control Register */ +#define PICR (0x40500004) /* PCM In Control Register */ #define PICR_FEIE (1 << 3) /* FIFO Error Interrupt Enable */
-#define MCCR __REG(0x40500008) /* Mic In Control Register */ +#define MCCR (0x40500008) /* Mic In Control Register */ #define MCCR_FEIE (1 << 3) /* FIFO Error Interrupt Enable */
-#define GCR __REG(0x4050000C) /* Global Control Register */ +#define GCR (0x4050000C) /* Global Control Register */ #define GCR_CDONE_IE (1 << 19) /* Command Done Interrupt Enable */ #define GCR_SDONE_IE (1 << 18) /* Status Done Interrupt Enable */ #define GCR_SECRDY_IEN (1 << 9) /* Secondary Ready Interrupt Enable */ @@ -540,16 +550,16 @@ typedef void (*ExcpHndlr) (void) ; #define GCR_COLD_RST (1 << 1) /* AC'97 Cold Reset (0 = active) */ #define GCR_GIE (1 << 0) /* Codec GPI Interrupt Enable */
-#define POSR __REG(0x40500010) /* PCM Out Status Register */ +#define POSR (0x40500010) /* PCM Out Status Register */ #define POSR_FIFOE (1 << 4) /* FIFO error */
-#define PISR __REG(0x40500014) /* PCM In Status Register */ +#define PISR (0x40500014) /* PCM In Status Register */ #define PISR_FIFOE (1 << 4) /* FIFO error */
-#define MCSR __REG(0x40500018) /* Mic In Status Register */ +#define MCSR (0x40500018) /* Mic In Status Register */ #define MCSR_FIFOE (1 << 4) /* FIFO error */
-#define GSR __REG(0x4050001C) /* Global Status Register */ +#define GSR (0x4050001C) /* Global Status Register */ #define GSR_CDONE (1 << 19) /* Command Done */ #define GSR_SDONE (1 << 18) /* Status Done */ #define GSR_RDCS (1 << 15) /* Read Completion Status */ @@ -567,38 +577,38 @@ typedef void (*ExcpHndlr) (void) ; #define GSR_MIINT (1 << 1) /* Modem In Interrupt */ #define GSR_GSCI (1 << 0) /* Codec GPI Status Change Interrupt */
-#define CAR __REG(0x40500020) /* CODEC Access Register */ +#define CAR (0x40500020) /* CODEC Access Register */ #define CAR_CAIP (1 << 0) /* Codec Access In Progress */
-#define PCDR __REG(0x40500040) /* PCM FIFO Data Register */ -#define MCDR __REG(0x40500060) /* Mic-in FIFO Data Register */ +#define PCDR (0x40500040) /* PCM FIFO Data Register */ +#define MCDR (0x40500060) /* Mic-in FIFO Data Register */
-#define MOCR __REG(0x40500100) /* Modem Out Control Register */ +#define MOCR (0x40500100) /* Modem Out Control Register */ #define MOCR_FEIE (1 << 3) /* FIFO Error */
-#define MICR __REG(0x40500108) /* Modem In Control Register */ +#define MICR (0x40500108) /* Modem In Control Register */ #define MICR_FEIE (1 << 3) /* FIFO Error */
-#define MOSR __REG(0x40500110) /* Modem Out Status Register */ +#define MOSR (0x40500110) /* Modem Out Status Register */ #define MOSR_FIFOE (1 << 4) /* FIFO error */
-#define MISR __REG(0x40500118) /* Modem In Status Register */ +#define MISR (0x40500118) /* Modem In Status Register */ #define MISR_FIFOE (1 << 4) /* FIFO error */
-#define MODR __REG(0x40500140) /* Modem FIFO Data Register */ +#define MODR (0x40500140) /* Modem FIFO Data Register */
-#define PAC_REG_BASE __REG(0x40500200) /* Primary Audio Codec */ -#define SAC_REG_BASE __REG(0x40500300) /* Secondary Audio Codec */ -#define PMC_REG_BASE __REG(0x40500400) /* Primary Modem Codec */ -#define SMC_REG_BASE __REG(0x40500500) /* Secondary Modem Codec */ +#define PAC_REG_BASE (0x40500200) /* Primary Audio Codec */ +#define SAC_REG_BASE (0x40500300) /* Secondary Audio Codec */ +#define PMC_REG_BASE (0x40500400) /* Primary Modem Codec */ +#define SMC_REG_BASE (0x40500500) /* Secondary Modem Codec */
/* * USB Device Controller */ -#ifdef CONFIG_PXA27X +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS)
-#define UDCCR __REG(0x40600000) /* UDC Control Register */ +#define UDCCR (0x40600000) /* UDC Control Register */ #define UDCCR_UDE (1 << 0) /* UDC enable */ #define UDCCR_UDA (1 << 1) /* UDC active */ #define UDCCR_RSM (1 << 2) /* Device resume */ @@ -623,7 +633,7 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCR_AAISN (0x07 << 5) /* Active UDC Alternate Interface Setting Number */ #define UDCCR_AAISN_S 5
-#define UDCCS0 __REG(0x40600100) /* UDC Endpoint 0 Control/Status Register */ +#define UDCCS0 (0x40600100) /* UDC Endpoint 0 Control/Status Register */ #define UDCCS0_OPR (1 << 0) /* OUT packet ready */ #define UDCCS0_IPR (1 << 1) /* IN packet ready */ #define UDCCS0_FTF (1 << 2) /* Flush Tx FIFO */ @@ -634,9 +644,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS0_SA (1 << 7) /* Setup active */
/* Bulk IN - Endpoint 1,6,11 */ -#define UDCCS1 __REG(0x40600104) /* UDC Endpoint 1 (IN) Control/Status Register */ -#define UDCCS6 __REG(0x40600028) /* UDC Endpoint 6 (IN) Control/Status Register */ -#define UDCCS11 __REG(0x4060003C) /* UDC Endpoint 11 (IN) Control/Status Register */ +#define UDCCS1 (0x40600104) /* UDC Endpoint 1 (IN) Control/Status Register */ +#define UDCCS6 (0x40600028) /* UDC Endpoint 6 (IN) Control/Status Register */ +#define UDCCS11 (0x4060003C) /* UDC Endpoint 11 (IN) Control/Status Register */
#define UDCCS_BI_TFS (1 << 0) /* Transmit FIFO service */ #define UDCCS_BI_TPC (1 << 1) /* Transmit packet complete */ @@ -647,9 +657,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_BI_TSP (1 << 7) /* Transmit short packet */
/* Bulk OUT - Endpoint 2,7,12 */ -#define UDCCS2 __REG(0x40600108) /* UDC Endpoint 2 (OUT) Control/Status Register */ -#define UDCCS7 __REG(0x4060002C) /* UDC Endpoint 7 (OUT) Control/Status Register */ -#define UDCCS12 __REG(0x40600040) /* UDC Endpoint 12 (OUT) Control/Status Register */ +#define UDCCS2 (0x40600108) /* UDC Endpoint 2 (OUT) Control/Status Register */ +#define UDCCS7 (0x4060002C) /* UDC Endpoint 7 (OUT) Control/Status Register */ +#define UDCCS12 (0x40600040) /* UDC Endpoint 12 (OUT) Control/Status Register */
#define UDCCS_BO_RFS (1 << 0) /* Receive FIFO service */ #define UDCCS_BO_RPC (1 << 1) /* Receive packet complete */ @@ -660,9 +670,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_BO_RSP (1 << 7) /* Receive short packet */
/* Isochronous IN - Endpoint 3,8,13 */ -#define UDCCS3 __REG(0x4060001C) /* UDC Endpoint 3 (IN) Control/Status Register */ -#define UDCCS8 __REG(0x40600030) /* UDC Endpoint 8 (IN) Control/Status Register */ -#define UDCCS13 __REG(0x40600044) /* UDC Endpoint 13 (IN) Control/Status Register */ +#define UDCCS3 (0x4060001C) /* UDC Endpoint 3 (IN) Control/Status Register */ +#define UDCCS8 (0x40600030) /* UDC Endpoint 8 (IN) Control/Status Register */ +#define UDCCS13 (0x40600044) /* UDC Endpoint 13 (IN) Control/Status Register */
#define UDCCS_II_TFS (1 << 0) /* Transmit FIFO service */ #define UDCCS_II_TPC (1 << 1) /* Transmit packet complete */ @@ -671,9 +681,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_II_TSP (1 << 7) /* Transmit short packet */
/* Isochronous OUT - Endpoint 4,9,14 */ -#define UDCCS4 __REG(0x40600020) /* UDC Endpoint 4 (OUT) Control/Status Register */ -#define UDCCS9 __REG(0x40600034) /* UDC Endpoint 9 (OUT) Control/Status Register */ -#define UDCCS14 __REG(0x40600048) /* UDC Endpoint 14 (OUT) Control/Status Register */ +#define UDCCS4 (0x40600020) /* UDC Endpoint 4 (OUT) Control/Status Register */ +#define UDCCS9 (0x40600034) /* UDC Endpoint 9 (OUT) Control/Status Register */ +#define UDCCS14 (0x40600048) /* UDC Endpoint 14 (OUT) Control/Status Register */
#define UDCCS_IO_RFS (1 << 0) /* Receive FIFO service */ #define UDCCS_IO_RPC (1 << 1) /* Receive packet complete */ @@ -683,9 +693,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_IO_RSP (1 << 7) /* Receive short packet */
/* Interrupt IN - Endpoint 5,10,15 */ -#define UDCCS5 __REG(0x40600024) /* UDC Endpoint 5 (Interrupt) Control/Status Register */ -#define UDCCS10 __REG(0x40600038) /* UDC Endpoint 10 (Interrupt) Control/Status Register */ -#define UDCCS15 __REG(0x4060004C) /* UDC Endpoint 15 (Interrupt) Control/Status Register */ +#define UDCCS5 (0x40600024) /* UDC Endpoint 5 (Interrupt) Control/Status Register */ +#define UDCCS10 (0x40600038) /* UDC Endpoint 10 (Interrupt) Control/Status Register */ +#define UDCCS15 (0x4060004C) /* UDC Endpoint 15 (Interrupt) Control/Status Register */
#define UDCCS_INT_TFS (1 << 0) /* Transmit FIFO service */ #define UDCCS_INT_TPC (1 << 1) /* Transmit packet complete */ @@ -695,32 +705,32 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_INT_FST (1 << 5) /* Force stall */ #define UDCCS_INT_TSP (1 << 7) /* Transmit short packet */
-#define UFNRH __REG(0x40600060) /* UDC Frame Number Register High */ -#define UFNRL __REG(0x40600014) /* UDC Frame Number Register Low */ -#define UBCR2 __REG(0x40600208) /* UDC Byte Count Reg 2 */ -#define UBCR4 __REG(0x4060006c) /* UDC Byte Count Reg 4 */ -#define UBCR7 __REG(0x40600070) /* UDC Byte Count Reg 7 */ -#define UBCR9 __REG(0x40600074) /* UDC Byte Count Reg 9 */ -#define UBCR12 __REG(0x40600078) /* UDC Byte Count Reg 12 */ -#define UBCR14 __REG(0x4060007c) /* UDC Byte Count Reg 14 */ -#define UDDR0 __REG(0x40600300) /* UDC Endpoint 0 Data Register */ -#define UDDR1 __REG(0x40600304) /* UDC Endpoint 1 Data Register */ -#define UDDR2 __REG(0x40600308) /* UDC Endpoint 2 Data Register */ -#define UDDR3 __REG(0x40600200) /* UDC Endpoint 3 Data Register */ -#define UDDR4 __REG(0x40600400) /* UDC Endpoint 4 Data Register */ -#define UDDR5 __REG(0x406000A0) /* UDC Endpoint 5 Data Register */ -#define UDDR6 __REG(0x40600600) /* UDC Endpoint 6 Data Register */ -#define UDDR7 __REG(0x40600680) /* UDC Endpoint 7 Data Register */ -#define UDDR8 __REG(0x40600700) /* UDC Endpoint 8 Data Register */ -#define UDDR9 __REG(0x40600900) /* UDC Endpoint 9 Data Register */ -#define UDDR10 __REG(0x406000C0) /* UDC Endpoint 10 Data Register */ -#define UDDR11 __REG(0x40600B00) /* UDC Endpoint 11 Data Register */ -#define UDDR12 __REG(0x40600B80) /* UDC Endpoint 12 Data Register */ -#define UDDR13 __REG(0x40600C00) /* UDC Endpoint 13 Data Register */ -#define UDDR14 __REG(0x40600E00) /* UDC Endpoint 14 Data Register */ -#define UDDR15 __REG(0x406000E0) /* UDC Endpoint 15 Data Register */ - -#define UICR0 __REG(0x40600004) /* UDC Interrupt Control Register 0 */ +#define UFNRH (0x40600060) /* UDC Frame Number Register High */ +#define UFNRL (0x40600014) /* UDC Frame Number Register Low */ +#define UBCR2 (0x40600208) /* UDC Byte Count Reg 2 */ +#define UBCR4 (0x4060006c) /* UDC Byte Count Reg 4 */ +#define UBCR7 (0x40600070) /* UDC Byte Count Reg 7 */ +#define UBCR9 (0x40600074) /* UDC Byte Count Reg 9 */ +#define UBCR12 (0x40600078) /* UDC Byte Count Reg 12 */ +#define UBCR14 (0x4060007c) /* UDC Byte Count Reg 14 */ +#define UDDR0 (0x40600300) /* UDC Endpoint 0 Data Register */ +#define UDDR1 (0x40600304) /* UDC Endpoint 1 Data Register */ +#define UDDR2 (0x40600308) /* UDC Endpoint 2 Data Register */ +#define UDDR3 (0x40600200) /* UDC Endpoint 3 Data Register */ +#define UDDR4 (0x40600400) /* UDC Endpoint 4 Data Register */ +#define UDDR5 (0x406000A0) /* UDC Endpoint 5 Data Register */ +#define UDDR6 (0x40600600) /* UDC Endpoint 6 Data Register */ +#define UDDR7 (0x40600680) /* UDC Endpoint 7 Data Register */ +#define UDDR8 (0x40600700) /* UDC Endpoint 8 Data Register */ +#define UDDR9 (0x40600900) /* UDC Endpoint 9 Data Register */ +#define UDDR10 (0x406000C0) /* UDC Endpoint 10 Data Register */ +#define UDDR11 (0x40600B00) /* UDC Endpoint 11 Data Register */ +#define UDDR12 (0x40600B80) /* UDC Endpoint 12 Data Register */ +#define UDDR13 (0x40600C00) /* UDC Endpoint 13 Data Register */ +#define UDDR14 (0x40600E00) /* UDC Endpoint 14 Data Register */ +#define UDDR15 (0x406000E0) /* UDC Endpoint 15 Data Register */ + +#define UICR0 (0x40600004) /* UDC Interrupt Control Register 0 */
#define UICR0_IM0 (1 << 0) /* Interrupt mask ep 0 */ #define UICR0_IM1 (1 << 1) /* Interrupt mask ep 1 */ @@ -731,7 +741,7 @@ typedef void (*ExcpHndlr) (void) ; #define UICR0_IM6 (1 << 6) /* Interrupt mask ep 6 */ #define UICR0_IM7 (1 << 7) /* Interrupt mask ep 7 */
-#define UICR1 __REG(0x40600008) /* UDC Interrupt Control Register 1 */ +#define UICR1 (0x40600008) /* UDC Interrupt Control Register 1 */
#define UICR1_IM8 (1 << 0) /* Interrupt mask ep 8 */ #define UICR1_IM9 (1 << 1) /* Interrupt mask ep 9 */ @@ -742,7 +752,7 @@ typedef void (*ExcpHndlr) (void) ; #define UICR1_IM14 (1 << 6) /* Interrupt mask ep 14 */ #define UICR1_IM15 (1 << 7) /* Interrupt mask ep 15 */
-#define USIR0 __REG(0x4060000C) /* UDC Status Interrupt Register 0 */ +#define USIR0 (0x4060000C) /* UDC Status Interrupt Register 0 */
#define USIR0_IR0 (1 << 0) /* Interrup request ep 0 */ #define USIR0_IR1 (1 << 2) /* Interrup request ep 1 */ @@ -753,7 +763,7 @@ typedef void (*ExcpHndlr) (void) ; #define USIR0_IR6 (1 << 6) /* Interrup request ep 6 */ #define USIR0_IR7 (1 << 7) /* Interrup request ep 7 */
-#define USIR1 __REG(0x40600010) /* UDC Status Interrupt Register 1 */ +#define USIR1 (0x40600010) /* UDC Status Interrupt Register 1 */
#define USIR1_IR8 (1 << 0) /* Interrup request ep 8 */ #define USIR1_IR9 (1 << 1) /* Interrup request ep 9 */ @@ -765,8 +775,8 @@ typedef void (*ExcpHndlr) (void) ; #define USIR1_IR15 (1 << 7) /* Interrup request ep 15 */
-#define UDCICR0 __REG(0x40600004) /* UDC Interrupt Control Register0 */ -#define UDCICR1 __REG(0x40600008) /* UDC Interrupt Control Register1 */ +#define UDCICR0 (0x40600004) /* UDC Interrupt Control Register0 */ +#define UDCICR1 (0x40600008) /* UDC Interrupt Control Register1 */ #define UDCICR_FIFOERR (1 << 1) /* FIFO Error interrupt for EP */ #define UDCICR_PKTCOMPL (1 << 0) /* Packet Complete interrupt for EP */
@@ -777,8 +787,8 @@ typedef void (*ExcpHndlr) (void) ; #define UDCICR1_IESU (1 << 28) /* IntEn - Suspend */ #define UDCICR1_IERS (1 << 27) /* IntEn - Reset */
-#define UDCISR0 __REG(0x4060000C) /* UDC Interrupt Status Register 0 */ -#define UDCISR1 __REG(0x40600010) /* UDC Interrupt Status Register 1 */ +#define UDCISR0 (0x4060000C) /* UDC Interrupt Status Register 0 */ +#define UDCISR1 (0x40600010) /* UDC Interrupt Status Register 1 */ #define UDCISR_INT(n, intr) (((intr) & 0x03) << (((n) & 0x0F) * 2)) #define UDCISR1_IRCC (1 << 31) /* IntEn - Configuration Change */ #define UDCISR1_IRSOF (1 << 30) /* IntEn - Start of Frame */ @@ -787,8 +797,8 @@ typedef void (*ExcpHndlr) (void) ; #define UDCISR1_IRRS (1 << 27) /* IntEn - Reset */
-#define UDCFNR __REG(0x40600014) /* UDC Frame Number Register */ -#define UDCOTGICR __REG(0x40600018) /* UDC On-The-Go interrupt control */ +#define UDCFNR (0x40600014) /* UDC Frame Number Register */ +#define UDCOTGICR (0x40600018) /* UDC On-The-Go interrupt control */ #define UDCOTGICR_IESF (1 << 24) /* OTG SET_FEATURE command recvd */ #define UDCOTGICR_IEXR (1 << 17) /* Extra Transciever Interrupt Rising Edge Interrupt Enable */ #define UDCOTGICR_IEXF (1 << 16) /* Extra Transciever Interrupt Falling Edge Interrupt Enable */ @@ -804,7 +814,7 @@ typedef void (*ExcpHndlr) (void) ; #define UDCOTGICR_IEIDF (1 << 0) /* OTG ID Change Falling Edge Interrupt Enable */
#define UDCCSN(x) __REG2(0x40600100, (x) << 2) -#define UDCCSR0 __REG(0x40600100) /* UDC Control/Status register - Endpoint 0 */ +#define UDCCSR0 (0x40600100) /* UDC Control/Status register - Endpoint 0 */
#define UDCCSR0_SA (1 << 7) /* Setup Active */ #define UDCCSR0_RNE (1 << 6) /* Receive FIFO Not Empty */ @@ -815,29 +825,29 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCSR0_IPR (1 << 1) /* IN Packet Ready */ #define UDCCSR0_OPC (1 << 0) /* OUT Packet Complete */
-#define UDCCSRA __REG(0x40600104) /* UDC Control/Status register - Endpoint A */ -#define UDCCSRB __REG(0x40600108) /* UDC Control/Status register - Endpoint B */ -#define UDCCSRC __REG(0x4060010C) /* UDC Control/Status register - Endpoint C */ -#define UDCCSRD __REG(0x40600110) /* UDC Control/Status register - Endpoint D */ -#define UDCCSRE __REG(0x40600114) /* UDC Control/Status register - Endpoint E */ -#define UDCCSRF __REG(0x40600118) /* UDC Control/Status register - Endpoint F */ -#define UDCCSRG __REG(0x4060011C) /* UDC Control/Status register - Endpoint G */ -#define UDCCSRH __REG(0x40600120) /* UDC Control/Status register - Endpoint H */ -#define UDCCSRI __REG(0x40600124) /* UDC Control/Status register - Endpoint I */ -#define UDCCSRJ __REG(0x40600128) /* UDC Control/Status register - Endpoint J */ -#define UDCCSRK __REG(0x4060012C) /* UDC Control/Status register - Endpoint K */ -#define UDCCSRL __REG(0x40600130) /* UDC Control/Status register - Endpoint L */ -#define UDCCSRM __REG(0x40600134) /* UDC Control/Status register - Endpoint M */ -#define UDCCSRN __REG(0x40600138) /* UDC Control/Status register - Endpoint N */ -#define UDCCSRP __REG(0x4060013C) /* UDC Control/Status register - Endpoint P */ -#define UDCCSRQ __REG(0x40600140) /* UDC Control/Status register - Endpoint Q */ -#define UDCCSRR __REG(0x40600144) /* UDC Control/Status register - Endpoint R */ -#define UDCCSRS __REG(0x40600148) /* UDC Control/Status register - Endpoint S */ -#define UDCCSRT __REG(0x4060014C) /* UDC Control/Status register - Endpoint T */ -#define UDCCSRU __REG(0x40600150) /* UDC Control/Status register - Endpoint U */ -#define UDCCSRV __REG(0x40600154) /* UDC Control/Status register - Endpoint V */ -#define UDCCSRW __REG(0x40600158) /* UDC Control/Status register - Endpoint W */ -#define UDCCSRX __REG(0x4060015C) /* UDC Control/Status register - Endpoint X */ +#define UDCCSRA (0x40600104) /* UDC Control/Status register - Endpoint A */ +#define UDCCSRB (0x40600108) /* UDC Control/Status register - Endpoint B */ +#define UDCCSRC (0x4060010C) /* UDC Control/Status register - Endpoint C */ +#define UDCCSRD (0x40600110) /* UDC Control/Status register - Endpoint D */ +#define UDCCSRE (0x40600114) /* UDC Control/Status register - Endpoint E */ +#define UDCCSRF (0x40600118) /* UDC Control/Status register - Endpoint F */ +#define UDCCSRG (0x4060011C) /* UDC Control/Status register - Endpoint G */ +#define UDCCSRH (0x40600120) /* UDC Control/Status register - Endpoint H */ +#define UDCCSRI (0x40600124) /* UDC Control/Status register - Endpoint I */ +#define UDCCSRJ (0x40600128) /* UDC Control/Status register - Endpoint J */ +#define UDCCSRK (0x4060012C) /* UDC Control/Status register - Endpoint K */ +#define UDCCSRL (0x40600130) /* UDC Control/Status register - Endpoint L */ +#define UDCCSRM (0x40600134) /* UDC Control/Status register - Endpoint M */ +#define UDCCSRN (0x40600138) /* UDC Control/Status register - Endpoint N */ +#define UDCCSRP (0x4060013C) /* UDC Control/Status register - Endpoint P */ +#define UDCCSRQ (0x40600140) /* UDC Control/Status register - Endpoint Q */ +#define UDCCSRR (0x40600144) /* UDC Control/Status register - Endpoint R */ +#define UDCCSRS (0x40600148) /* UDC Control/Status register - Endpoint S */ +#define UDCCSRT (0x4060014C) /* UDC Control/Status register - Endpoint T */ +#define UDCCSRU (0x40600150) /* UDC Control/Status register - Endpoint U */ +#define UDCCSRV (0x40600154) /* UDC Control/Status register - Endpoint V */ +#define UDCCSRW (0x40600158) /* UDC Control/Status register - Endpoint W */ +#define UDCCSRX (0x4060015C) /* UDC Control/Status register - Endpoint X */
#define UDCCSR_DPE (1 << 9) /* Data Packet Error */ #define UDCCSR_FEF (1 << 8) /* Flush Endpoint FIFO */ @@ -852,81 +862,81 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCSR_FS (1 << 0) /* FIFO needs service */
#define UDCBCN(x) __REG2(0x40600200, (x)<<2) -#define UDCBCR0 __REG(0x40600200) /* Byte Count Register - EP0 */ -#define UDCBCRA __REG(0x40600204) /* Byte Count Register - EPA */ -#define UDCBCRB __REG(0x40600208) /* Byte Count Register - EPB */ -#define UDCBCRC __REG(0x4060020C) /* Byte Count Register - EPC */ -#define UDCBCRD __REG(0x40600210) /* Byte Count Register - EPD */ -#define UDCBCRE __REG(0x40600214) /* Byte Count Register - EPE */ -#define UDCBCRF __REG(0x40600218) /* Byte Count Register - EPF */ -#define UDCBCRG __REG(0x4060021C) /* Byte Count Register - EPG */ -#define UDCBCRH __REG(0x40600220) /* Byte Count Register - EPH */ -#define UDCBCRI __REG(0x40600224) /* Byte Count Register - EPI */ -#define UDCBCRJ __REG(0x40600228) /* Byte Count Register - EPJ */ -#define UDCBCRK __REG(0x4060022C) /* Byte Count Register - EPK */ -#define UDCBCRL __REG(0x40600230) /* Byte Count Register - EPL */ -#define UDCBCRM __REG(0x40600234) /* Byte Count Register - EPM */ -#define UDCBCRN __REG(0x40600238) /* Byte Count Register - EPN */ -#define UDCBCRP __REG(0x4060023C) /* Byte Count Register - EPP */ -#define UDCBCRQ __REG(0x40600240) /* Byte Count Register - EPQ */ -#define UDCBCRR __REG(0x40600244) /* Byte Count Register - EPR */ -#define UDCBCRS __REG(0x40600248) /* Byte Count Register - EPS */ -#define UDCBCRT __REG(0x4060024C) /* Byte Count Register - EPT */ -#define UDCBCRU __REG(0x40600250) /* Byte Count Register - EPU */ -#define UDCBCRV __REG(0x40600254) /* Byte Count Register - EPV */ -#define UDCBCRW __REG(0x40600258) /* Byte Count Register - EPW */ -#define UDCBCRX __REG(0x4060025C) /* Byte Count Register - EPX */ +#define UDCBCR0 (0x40600200) /* Byte Count Register - EP0 */ +#define UDCBCRA (0x40600204) /* Byte Count Register - EPA */ +#define UDCBCRB (0x40600208) /* Byte Count Register - EPB */ +#define UDCBCRC (0x4060020C) /* Byte Count Register - EPC */ +#define UDCBCRD (0x40600210) /* Byte Count Register - EPD */ +#define UDCBCRE (0x40600214) /* Byte Count Register - EPE */ +#define UDCBCRF (0x40600218) /* Byte Count Register - EPF */ +#define UDCBCRG (0x4060021C) /* Byte Count Register - EPG */ +#define UDCBCRH (0x40600220) /* Byte Count Register - EPH */ +#define UDCBCRI (0x40600224) /* Byte Count Register - EPI */ +#define UDCBCRJ (0x40600228) /* Byte Count Register - EPJ */ +#define UDCBCRK (0x4060022C) /* Byte Count Register - EPK */ +#define UDCBCRL (0x40600230) /* Byte Count Register - EPL */ +#define UDCBCRM (0x40600234) /* Byte Count Register - EPM */ +#define UDCBCRN (0x40600238) /* Byte Count Register - EPN */ +#define UDCBCRP (0x4060023C) /* Byte Count Register - EPP */ +#define UDCBCRQ (0x40600240) /* Byte Count Register - EPQ */ +#define UDCBCRR (0x40600244) /* Byte Count Register - EPR */ +#define UDCBCRS (0x40600248) /* Byte Count Register - EPS */ +#define UDCBCRT (0x4060024C) /* Byte Count Register - EPT */ +#define UDCBCRU (0x40600250) /* Byte Count Register - EPU */ +#define UDCBCRV (0x40600254) /* Byte Count Register - EPV */ +#define UDCBCRW (0x40600258) /* Byte Count Register - EPW */ +#define UDCBCRX (0x4060025C) /* Byte Count Register - EPX */
#define UDCDN(x) __REG2(0x40600300, (x)<<2) -#define UDCDR0 __REG(0x40600300) /* Data Register - EP0 */ -#define UDCDRA __REG(0x40600304) /* Data Register - EPA */ -#define UDCDRB __REG(0x40600308) /* Data Register - EPB */ -#define UDCDRC __REG(0x4060030C) /* Data Register - EPC */ -#define UDCDRD __REG(0x40600310) /* Data Register - EPD */ -#define UDCDRE __REG(0x40600314) /* Data Register - EPE */ -#define UDCDRF __REG(0x40600318) /* Data Register - EPF */ -#define UDCDRG __REG(0x4060031C) /* Data Register - EPG */ -#define UDCDRH __REG(0x40600320) /* Data Register - EPH */ -#define UDCDRI __REG(0x40600324) /* Data Register - EPI */ -#define UDCDRJ __REG(0x40600328) /* Data Register - EPJ */ -#define UDCDRK __REG(0x4060032C) /* Data Register - EPK */ -#define UDCDRL __REG(0x40600330) /* Data Register - EPL */ -#define UDCDRM __REG(0x40600334) /* Data Register - EPM */ -#define UDCDRN __REG(0x40600338) /* Data Register - EPN */ -#define UDCDRP __REG(0x4060033C) /* Data Register - EPP */ -#define UDCDRQ __REG(0x40600340) /* Data Register - EPQ */ -#define UDCDRR __REG(0x40600344) /* Data Register - EPR */ -#define UDCDRS __REG(0x40600348) /* Data Register - EPS */ -#define UDCDRT __REG(0x4060034C) /* Data Register - EPT */ -#define UDCDRU __REG(0x40600350) /* Data Register - EPU */ -#define UDCDRV __REG(0x40600354) /* Data Register - EPV */ -#define UDCDRW __REG(0x40600358) /* Data Register - EPW */ -#define UDCDRX __REG(0x4060035C) /* Data Register - EPX */ +#define UDCDR0 (0x40600300) /* Data Register - EP0 */ +#define UDCDRA (0x40600304) /* Data Register - EPA */ +#define UDCDRB (0x40600308) /* Data Register - EPB */ +#define UDCDRC (0x4060030C) /* Data Register - EPC */ +#define UDCDRD (0x40600310) /* Data Register - EPD */ +#define UDCDRE (0x40600314) /* Data Register - EPE */ +#define UDCDRF (0x40600318) /* Data Register - EPF */ +#define UDCDRG (0x4060031C) /* Data Register - EPG */ +#define UDCDRH (0x40600320) /* Data Register - EPH */ +#define UDCDRI (0x40600324) /* Data Register - EPI */ +#define UDCDRJ (0x40600328) /* Data Register - EPJ */ +#define UDCDRK (0x4060032C) /* Data Register - EPK */ +#define UDCDRL (0x40600330) /* Data Register - EPL */ +#define UDCDRM (0x40600334) /* Data Register - EPM */ +#define UDCDRN (0x40600338) /* Data Register - EPN */ +#define UDCDRP (0x4060033C) /* Data Register - EPP */ +#define UDCDRQ (0x40600340) /* Data Register - EPQ */ +#define UDCDRR (0x40600344) /* Data Register - EPR */ +#define UDCDRS (0x40600348) /* Data Register - EPS */ +#define UDCDRT (0x4060034C) /* Data Register - EPT */ +#define UDCDRU (0x40600350) /* Data Register - EPU */ +#define UDCDRV (0x40600354) /* Data Register - EPV */ +#define UDCDRW (0x40600358) /* Data Register - EPW */ +#define UDCDRX (0x4060035C) /* Data Register - EPX */
#define UDCCN(x) __REG2(0x40600400, (x)<<2) -#define UDCCRA __REG(0x40600404) /* Configuration register EPA */ -#define UDCCRB __REG(0x40600408) /* Configuration register EPB */ -#define UDCCRC __REG(0x4060040C) /* Configuration register EPC */ -#define UDCCRD __REG(0x40600410) /* Configuration register EPD */ -#define UDCCRE __REG(0x40600414) /* Configuration register EPE */ -#define UDCCRF __REG(0x40600418) /* Configuration register EPF */ -#define UDCCRG __REG(0x4060041C) /* Configuration register EPG */ -#define UDCCRH __REG(0x40600420) /* Configuration register EPH */ -#define UDCCRI __REG(0x40600424) /* Configuration register EPI */ -#define UDCCRJ __REG(0x40600428) /* Configuration register EPJ */ -#define UDCCRK __REG(0x4060042C) /* Configuration register EPK */ -#define UDCCRL __REG(0x40600430) /* Configuration register EPL */ -#define UDCCRM __REG(0x40600434) /* Configuration register EPM */ -#define UDCCRN __REG(0x40600438) /* Configuration register EPN */ -#define UDCCRP __REG(0x4060043C) /* Configuration register EPP */ -#define UDCCRQ __REG(0x40600440) /* Configuration register EPQ */ -#define UDCCRR __REG(0x40600444) /* Configuration register EPR */ -#define UDCCRS __REG(0x40600448) /* Configuration register EPS */ -#define UDCCRT __REG(0x4060044C) /* Configuration register EPT */ -#define UDCCRU __REG(0x40600450) /* Configuration register EPU */ -#define UDCCRV __REG(0x40600454) /* Configuration register EPV */ -#define UDCCRW __REG(0x40600458) /* Configuration register EPW */ -#define UDCCRX __REG(0x4060045C) /* Configuration register EPX */ +#define UDCCRA (0x40600404) /* Configuration register EPA */ +#define UDCCRB (0x40600408) /* Configuration register EPB */ +#define UDCCRC (0x4060040C) /* Configuration register EPC */ +#define UDCCRD (0x40600410) /* Configuration register EPD */ +#define UDCCRE (0x40600414) /* Configuration register EPE */ +#define UDCCRF (0x40600418) /* Configuration register EPF */ +#define UDCCRG (0x4060041C) /* Configuration register EPG */ +#define UDCCRH (0x40600420) /* Configuration register EPH */ +#define UDCCRI (0x40600424) /* Configuration register EPI */ +#define UDCCRJ (0x40600428) /* Configuration register EPJ */ +#define UDCCRK (0x4060042C) /* Configuration register EPK */ +#define UDCCRL (0x40600430) /* Configuration register EPL */ +#define UDCCRM (0x40600434) /* Configuration register EPM */ +#define UDCCRN (0x40600438) /* Configuration register EPN */ +#define UDCCRP (0x4060043C) /* Configuration register EPP */ +#define UDCCRQ (0x40600440) /* Configuration register EPQ */ +#define UDCCRR (0x40600444) /* Configuration register EPR */ +#define UDCCRS (0x40600448) /* Configuration register EPS */ +#define UDCCRT (0x4060044C) /* Configuration register EPT */ +#define UDCCRU (0x40600450) /* Configuration register EPU */ +#define UDCCRV (0x40600454) /* Configuration register EPV */ +#define UDCCRW (0x40600458) /* Configuration register EPW */ +#define UDCCRX (0x4060045C) /* Configuration register EPX */
#define UDCCONR_CN (0x03 << 25) /* Configuration Number */ #define UDCCONR_CN_S (25) @@ -959,38 +969,39 @@ typedef void (*ExcpHndlr) (void) ;
+/******************************************************************************/ /* * USB Host Controller */ #define OHCI_REGS_BASE 0x4C000000 /* required for ohci driver */ -#define UHCREV __REG(0x4C000000) -#define UHCHCON __REG(0x4C000004) -#define UHCCOMS __REG(0x4C000008) -#define UHCINTS __REG(0x4C00000C) -#define UHCINTE __REG(0x4C000010) -#define UHCINTD __REG(0x4C000014) -#define UHCHCCA __REG(0x4C000018) -#define UHCPCED __REG(0x4C00001C) -#define UHCCHED __REG(0x4C000020) -#define UHCCCED __REG(0x4C000024) -#define UHCBHED __REG(0x4C000028) -#define UHCBCED __REG(0x4C00002C) -#define UHCDHEAD __REG(0x4C000030) -#define UHCFMI __REG(0x4C000034) -#define UHCFMR __REG(0x4C000038) -#define UHCFMN __REG(0x4C00003C) -#define UHCPERS __REG(0x4C000040) -#define UHCLST __REG(0x4C000044) -#define UHCRHDA __REG(0x4C000048) -#define UHCRHDB __REG(0x4C00004C) -#define UHCRHS __REG(0x4C000050) -#define UHCRHPS1 __REG(0x4C000054) -#define UHCRHPS2 __REG(0x4C000058) -#define UHCRHPS3 __REG(0x4C00005C) -#define UHCSTAT __REG(0x4C000060) -#define UHCHR __REG(0x4C000064) -#define UHCHIE __REG(0x4C000068) -#define UHCHIT __REG(0x4C00006C) +#define UHCREV (0x4C000000) +#define UHCHCON (0x4C000004) +#define UHCCOMS (0x4C000008) +#define UHCINTS (0x4C00000C) +#define UHCINTE (0x4C000010) +#define UHCINTD (0x4C000014) +#define UHCHCCA (0x4C000018) +#define UHCPCED (0x4C00001C) +#define UHCCHED (0x4C000020) +#define UHCCCED (0x4C000024) +#define UHCBHED (0x4C000028) +#define UHCBCED (0x4C00002C) +#define UHCDHEAD (0x4C000030) +#define UHCFMI (0x4C000034) +#define UHCFMR (0x4C000038) +#define UHCFMN (0x4C00003C) +#define UHCPERS (0x4C000040) +#define UHCLST (0x4C000044) +#define UHCRHDA (0x4C000048) +#define UHCRHDB (0x4C00004C) +#define UHCRHS (0x4C000050) +#define UHCRHPS1 (0x4C000054) +#define UHCRHPS2 (0x4C000058) +#define UHCRHPS3 (0x4C00005C) +#define UHCSTAT (0x4C000060) +#define UHCHR (0x4C000064) +#define UHCHIE (0x4C000068) +#define UHCHIT (0x4C00006C)
#define UHCHR_FSBIR (1<<0) #define UHCHR_FHR (1<<1) @@ -1011,9 +1022,7 @@ typedef void (*ExcpHndlr) (void) ; #define UHCHIE_HBAIE (1<<8) #define UHCHIE_RWIE (1<<7)
-#if defined(CONFIG_CPU_MONAHANS) || defined(CONFIG_PXA27X) -#define UP2OCR __REG(0x40600020) -#endif +#define UP2OCR (0x40600020)
#define UP2OCR_HXOE (1<<17) #define UP2OCR_HXS (1<<16) @@ -1029,36 +1038,37 @@ typedef void (*ExcpHndlr) (void) ; #define UP2OCR_CPVPE (1<<1) #define UP2OCR_CPVEN (1<<0)
-#endif +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */
+/******************************************************************************/ /* * Fast Infrared Communication Port */ -#define ICCR0 __REG(0x40800000) /* ICP Control Register 0 */ -#define ICCR1 __REG(0x40800004) /* ICP Control Register 1 */ -#define ICCR2 __REG(0x40800008) /* ICP Control Register 2 */ -#define ICDR __REG(0x4080000c) /* ICP Data Register */ -#define ICSR0 __REG(0x40800014) /* ICP Status Register 0 */ -#define ICSR1 __REG(0x40800018) /* ICP Status Register 1 */ +#define ICCR0 (0x40800000) /* ICP Control Register 0 */ +#define ICCR1 (0x40800004) /* ICP Control Register 1 */ +#define ICCR2 (0x40800008) /* ICP Control Register 2 */ +#define ICDR (0x4080000c) /* ICP Data Register */ +#define ICSR0 (0x40800014) /* ICP Status Register 0 */ +#define ICSR1 (0x40800018) /* ICP Status Register 1 */
/* * Real Time Clock */ -#define RCNR __REG(0x40900000) /* RTC Count Register */ -#define RTAR __REG(0x40900004) /* RTC Alarm Register */ -#define RTSR __REG(0x40900008) /* RTC Status Register */ -#define RTTR __REG(0x4090000C) /* RTC Timer Trim Register */ -#define RDAR1 __REG(0x40900018) /* Wristwatch Day Alarm Reg 1 */ -#define RDAR2 __REG(0x40900020) /* Wristwatch Day Alarm Reg 2 */ -#define RYAR1 __REG(0x4090001C) /* Wristwatch Year Alarm Reg 1 */ -#define RYAR2 __REG(0x40900024) /* Wristwatch Year Alarm Reg 2 */ -#define SWAR1 __REG(0x4090002C) /* Stopwatch Alarm Register 1 */ -#define SWAR2 __REG(0x40900030) /* Stopwatch Alarm Register 2 */ -#define PIAR __REG(0x40900038) /* Periodic Interrupt Alarm Register */ -#define RDCR __REG(0x40900010) /* RTC Day Count Register. */ -#define RYCR __REG(0x40900014) /* RTC Year Count Register. */ -#define SWCR __REG(0x40900028) /* Stopwatch Count Register */ -#define RTCPICR __REG(0x40900034) /* Periodic Interrupt Counter Register */ +#define RCNR (0x40900000) /* RTC Count Register */ +#define RTAR (0x40900004) /* RTC Alarm Register */ +#define RTSR (0x40900008) /* RTC Status Register */ +#define RTTR (0x4090000C) /* RTC Timer Trim Register */ +#define RDAR1 (0x40900018) /* Wristwatch Day Alarm Reg 1 */ +#define RDAR2 (0x40900020) /* Wristwatch Day Alarm Reg 2 */ +#define RYAR1 (0x4090001C) /* Wristwatch Year Alarm Reg 1 */ +#define RYAR2 (0x40900024) /* Wristwatch Year Alarm Reg 2 */ +#define SWAR1 (0x4090002C) /* Stopwatch Alarm Register 1 */ +#define SWAR2 (0x40900030) /* Stopwatch Alarm Register 2 */ +#define PIAR (0x40900038) /* Periodic Interrupt Alarm Register */ +#define RDCR (0x40900010) /* RTC Day Count Register. */ +#define RYCR (0x40900014) /* RTC Year Count Register. */ +#define SWCR (0x40900028) /* Stopwatch Count Register */ +#define RTCPICR (0x40900034) /* Periodic Interrupt Counter Register */
#define RTSR_PICE (1 << 15) /* Peridoc interrupt count enable */ #define RTSR_PIALE (1 << 14) /* Peridoc interrupt Alarm enable */ @@ -1068,48 +1078,48 @@ typedef void (*ExcpHndlr) (void) ; #define RTSR_HZ (1 << 1) /* HZ rising-edge detected */ #define RTSR_AL (1 << 0) /* RTC alarm detected */
+/******************************************************************************/ /* * OS Timer & Match Registers */ -#define OSMR0 __REG(0x40A00000) /* OS Timer Match Register 0 */ -#define OSMR1 __REG(0x40A00004) /* OS Timer Match Register 1 */ -#define OSMR2 __REG(0x40A00008) /* OS Timer Match Register 2 */ -#define OSMR3 __REG(0x40A0000C) /* OS Timer Match Register 3 */ -#define OSCR __REG(0x40A00010) /* OS Timer Counter Register */ -#define OSSR __REG(0x40A00014) /* OS Timer Status Register */ -#define OWER __REG(0x40A00018) /* OS Timer Watchdog Enable Register */ -#define OIER __REG(0x40A0001C) /* OS Timer Interrupt Enable Register */ +#define OSMR0 (0x40A00000) /* OS Timer Match Register 0 */ +#define OSMR1 (0x40A00004) /* OS Timer Match Register 1 */ +#define OSMR2 (0x40A00008) /* OS Timer Match Register 2 */ +#define OSMR3 (0x40A0000C) /* OS Timer Match Register 3 */ +#define OSCR (0x40A00010) /* OS Timer Counter Register */ +#define OSSR (0x40A00014) /* OS Timer Status Register */ +#define OWER (0x40A00018) /* OS Timer Watchdog Enable Register */ +#define OIER (0x40A0001C) /* OS Timer Interrupt Enable Register */
-#ifdef CONFIG_CPU_MONAHANS -#define OSCR4 __REG(0x40A00040) /* OS Timer Counter Register 4 */ -#define OSCR5 __REG(0x40A00044) /* OS Timer Counter Register 5 */ -#define OSCR6 __REG(0x40A00048) /* OS Timer Counter Register 6 */ -#define OSCR7 __REG(0x40A0004C) /* OS Timer Counter Register 7 */ -#define OSCR8 __REG(0x40A00050) /* OS Timer Counter Register 8 */ -#define OSCR9 __REG(0x40A00054) /* OS Timer Counter Register 9 */ -#define OSCR10 __REG(0x40A00058) /* OS Timer Counter Register 10 */ -#define OSCR11 __REG(0x40A0005C) /* OS Timer Counter Register 11 */ - -#define OSMR4 __REG(0x40A00080) /* OS Timer Match Register 4 */ -#define OSMR5 __REG(0x40A00084) /* OS Timer Match Register 5 */ -#define OSMR6 __REG(0x40A00088) /* OS Timer Match Register 6 */ -#define OSMR7 __REG(0x40A0008C) /* OS Timer Match Register 7 */ -#define OSMR8 __REG(0x40A00090) /* OS Timer Match Register 8 */ -#define OSMR9 __REG(0x40A00094) /* OS Timer Match Register 9 */ -#define OSMR10 __REG(0x40A00098) /* OS Timer Match Register 10 */ -#define OSMR11 __REG(0x40A0009C) /* OS Timer Match Register 11 */ - -#define OMCR4 __REG(0x40A000C0) /* OS Match Control Register 4 */ -#define OMCR5 __REG(0x40A000C4) /* OS Match Control Register 5 */ -#define OMCR6 __REG(0x40A000C8) /* OS Match Control Register 6 */ -#define OMCR7 __REG(0x40A000CC) /* OS Match Control Register 7 */ -#define OMCR8 __REG(0x40A000D0) /* OS Match Control Register 8 */ -#define OMCR9 __REG(0x40A000D4) /* OS Match Control Register 9 */ -#define OMCR10 __REG(0x40A000D8) /* OS Match Control Register 10 */ -#define OMCR11 __REG(0x40A000DC) /* OS Match Control Register 11 */ - -#define OSCR_CLK_FREQ 3250 /* kHz = 3.25 MHz */ -#endif /* CONFIG_CPU_MONAHANS */ +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define OSCR4 (0x40A00040) /* OS Timer Counter Register 4 */ +#define OSCR5 (0x40A00044) /* OS Timer Counter Register 5 */ +#define OSCR6 (0x40A00048) /* OS Timer Counter Register 6 */ +#define OSCR7 (0x40A0004C) /* OS Timer Counter Register 7 */ +#define OSCR8 (0x40A00050) /* OS Timer Counter Register 8 */ +#define OSCR9 (0x40A00054) /* OS Timer Counter Register 9 */ +#define OSCR10 (0x40A00058) /* OS Timer Counter Register 10 */ +#define OSCR11 (0x40A0005C) /* OS Timer Counter Register 11 */ + +#define OSMR4 (0x40A00080) /* OS Timer Match Register 4 */ +#define OSMR5 (0x40A00084) /* OS Timer Match Register 5 */ +#define OSMR6 (0x40A00088) /* OS Timer Match Register 6 */ +#define OSMR7 (0x40A0008C) /* OS Timer Match Register 7 */ +#define OSMR8 (0x40A00090) /* OS Timer Match Register 8 */ +#define OSMR9 (0x40A00094) /* OS Timer Match Register 9 */ +#define OSMR10 (0x40A00098) /* OS Timer Match Register 10 */ +#define OSMR11 (0x40A0009C) /* OS Timer Match Register 11 */ + +#define OMCR4 (0x40A000C0) /* OS Match Control Register 4 */ +#define OMCR5 (0x40A000C4) /* OS Match Control Register 5 */ +#define OMCR6 (0x40A000C8) /* OS Match Control Register 6 */ +#define OMCR7 (0x40A000CC) /* OS Match Control Register 7 */ +#define OMCR8 (0x40A000D0) /* OS Match Control Register 8 */ +#define OMCR9 (0x40A000D4) /* OS Match Control Register 9 */ +#define OMCR10 (0x40A000D8) /* OS Match Control Register 10 */ +#define OMCR11 (0x40A000DC) /* OS Match Control Register 11 */ + +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */
#define OSSR_M4 (1 << 4) /* Match status channel 4 */ #define OSSR_M3 (1 << 3) /* Match status channel 3 */ @@ -1125,321 +1135,696 @@ typedef void (*ExcpHndlr) (void) ; #define OIER_E1 (1 << 1) /* Interrupt enable channel 1 */ #define OIER_E0 (1 << 0) /* Interrupt enable channel 0 */
+#define OSCR_CLK_FREQ 3250 + +/******************************************************************************/ /* - * Pulse Width Modulator + * Core Clock */ -#define PWM_CTRL0 __REG(0x40B00000) /* PWM 0 Control Register */ -#define PWM_PWDUTY0 __REG(0x40B00004) /* PWM 0 Duty Cycle Register */ -#define PWM_PERVAL0 __REG(0x40B00008) /* PWM 0 Period Control Register */
-#define PWM_CTRL1 __REG(0x40C00000) /* PWM 1 Control Register */ -#define PWM_PWDUTY1 __REG(0x40C00004) /* PWM 1 Duty Cycle Register */ -#define PWM_PERVAL1 __REG(0x40C00008) /* PWM 1 Period Control Register */ +#if defined(CONFIG_CPU_MONAHANS) +#define ACCR (0x41340000) /* Application Subsystem Clock Configuration Register */ +#define ACSR (0x41340004) /* Application Subsystem Clock Status Register */ +#define AICSR (0x41340008) /* Application Subsystem Interrupt Control/Status Register */ +#define CKENA (0x4134000C) /* A Clock Enable Register */ +#define CKENB (0x41340010) /* B Clock Enable Register */ +#define AC97_DIV (0x41340014) /* AC97 clock divisor value register */ + +#define ACCR_SMC_MASK (0x03800000) /* Static Memory Controller Frequency Select */ +#define ACCR_SRAM_MASK (0x000c0000) /* SRAM Controller Frequency Select */ +#define ACCR_FC_MASK (0x00030000) /* Frequency Change Frequency Select */ +#define ACCR_HSIO_MASK (0x0000c000) /* High Speed IO Frequency Select */ +#define ACCR_DDR_MASK (0x00003000) /* DDR Memory Controller Frequency Select */ +#define ACCR_XN_MASK (0x00000700) /* Run Mode Frequency to Turbo Mode Frequency Multiplier */ +#define ACCR_XL_MASK (0x0000001f) /* Crystal Frequency to Memory Frequency Multiplier */ +#define ACCR_XPDIS (1 << 31) +#define ACCR_SPDIS (1 << 30) +#define ACCR_13MEND1 (1 << 27) +#define ACCR_D0CS (1 << 26) +#define ACCR_13MEND2 (1 << 21) +#define ACCR_PCCE (1 << 11) + +#define CKENA_30_MSL0 (1 << 30) /* MSL0 Interface Unit Clock Enable */ +#define CKENA_29_SSP4 (1 << 29) /* SSP3 Unit Clock Enable */ +#define CKENA_28_SSP3 (1 << 28) /* SSP2 Unit Clock Enable */ +#define CKENA_27_SSP2 (1 << 27) /* SSP1 Unit Clock Enable */ +#define CKENA_26_SSP1 (1 << 26) /* SSP0 Unit Clock Enable */ +#define CKENA_25_TSI (1 << 25) /* TSI Clock Enable */ +#define CKENA_24_AC97 (1 << 24) /* AC97 Unit Clock Enable */ +#define CKENA_23_STUART (1 << 23) /* STUART Unit Clock Enable */ +#define CKENA_22_FFUART (1 << 22) /* FFUART Unit Clock Enable */ +#define CKENA_21_BTUART (1 << 21) /* BTUART Unit Clock Enable */ +#define CKENA_20_UDC (1 << 20) /* UDC Clock Enable */ +#define CKENA_19_TPM (1 << 19) /* TPM Unit Clock Enable */ +#define CKENA_18_USIM1 (1 << 18) /* USIM1 Unit Clock Enable */ +#define CKENA_17_USIM0 (1 << 17) /* USIM0 Unit Clock Enable */ +#define CKENA_15_CIR (1 << 15) /* Consumer IR Clock Enable */ +#define CKENA_14_KEY (1 << 14) /* Keypad Controller Clock Enable */ +#define CKENA_13_MMC1 (1 << 13) /* MMC1 Clock Enable */ +#define CKENA_12_MMC0 (1 << 12) /* MMC0 Clock Enable */ +#define CKENA_11_FLASH (1 << 11) /* Boot ROM Clock Enable */ +#define CKENA_10_SRAM (1 << 10) /* SRAM Controller Clock Enable */ +#define CKENA_9_SMC (1 << 9) /* Static Memory Controller */ +#define CKENA_8_DMC (1 << 8) /* Dynamic Memory Controller */ +#define CKENA_7_GRAPHICS (1 << 7) /* 2D Graphics Clock Enable */ +#define CKENA_6_USBCLI (1 << 6) /* USB Client Unit Clock Enable */ +#define CKENA_4_NAND (1 << 4) /* NAND Flash Controller Clock Enable */ +#define CKENA_3_CAMERA (1 << 3) /* Camera Interface Clock Enable */ +#define CKENA_2_USBHOST (1 << 2) /* USB Host Unit Clock Enable */ +#define CKENA_1_LCD (1 << 1) /* LCD Unit Clock Enable */ + +#define CKENB_9_SYSBUS2 (1 << 9) /* System bus 2 */ +#define CKENB_8_1WIRE (1 << 8) /* One Wire Interface Unit Clock Enable */ +#define CKENB_7_GPIO (1 << 7) /* GPIO Clock Enable */ +#define CKENB_6_IRQ (1 << 6) /* Interrupt Controller Clock Enable */ +#define CKENB_4_I2C (1 << 4) /* I2C Unit Clock Enable */ +#define CKENB_1_PWM1 (1 << 1) /* PWM2 & PWM3 Clock Enable */ +#define CKENB_0_PWM0 (1 << 0) /* PWM0 & PWM1 Clock Enable */ + +#else /* if defined CONFIG_CPU_MONAHANS */ + +#define CCCR (0x41300000) /* Core Clock Configuration Register */ +#define CKEN (0x41300004) /* Clock Enable Register */ +#define OSCC (0x41300008) /* Oscillator Configuration Register */ +#define CCSR (0x4130000C) /* Core Clock Status Register */ + +#define CKEN23_SSP1 (1 << 23) /* SSP1 Unit Clock Enable */ +#define CKEN22_MEMC (1 << 22) /* Memory Controler */ +#define CKEN21_MSHC (1 << 21) /* Memery Stick Host Controller */ +#define CKEN20_IM (1 << 20) /* Internal Memory Clock Enable */ +#define CKEN19_KEYPAD (1 << 19) /* Keypad Interface Clock Enable */ +#define CKEN18_USIM (1 << 18) /* USIM Unit Clock Enable */ +#define CKEN17_MSL (1 << 17) /* MSL Interface Unit Clock Enable */ +#define CKEN15_PWR_I2C (1 << 15) /* PWR_I2C Unit Clock Enable */ +#define CKEN9_OST (1 << 9) /* OS Timer Unit Clock Enable */ +#define CKEN4_SSP3 (1 << 4) /* SSP3 Unit Clock Enable */ + +#define CCCR_N_MASK 0x0380 /* Run Mode Frequency to Turbo Mode Frequency Multiplier */ +#if !defined(CONFIG_PXA27X) +#define CCCR_M_MASK 0x0060 /* Memory Frequency to Run Mode Frequency Multiplier */ +#endif +#define CCCR_L_MASK 0x001f /* Crystal Frequency to Memory Frequency Multiplier */
-#define PWM_CTRL2 __REG(0x40B00010) /* PWM 2 Control Register */ -#define PWM_PWDUTY2 __REG(0x40B00014) /* PWM 2 Duty Cycle Register */ -#define PWM_PERVAL2 __REG(0x40B00018) /* PWM 2 Period Control Register */ +#define CKEN24_CAMERA (1 << 24) /* Camera Interface Clock Enable */ +#define CKEN23_SSP1 (1 << 23) /* SSP1 Unit Clock Enable */ +#define CKEN22_MEMC (1 << 22) /* Memory Controller Clock Enable */ +#define CKEN21_MEMSTK (1 << 21) /* Memory Stick Host Controller */ +#define CKEN20_IM (1 << 20) /* Internal Memory Clock Enable */ +#define CKEN19_KEYPAD (1 << 19) /* Keypad Interface Clock Enable */ +#define CKEN18_USIM (1 << 18) /* USIM Unit Clock Enable */ +#define CKEN17_MSL (1 << 17) /* MSL Unit Clock Enable */ +#define CKEN16_LCD (1 << 16) /* LCD Unit Clock Enable */ +#define CKEN15_PWRI2C (1 << 15) /* PWR I2C Unit Clock Enable */ +#define CKEN14_I2C (1 << 14) /* I2C Unit Clock Enable */ +#define CKEN13_FICP (1 << 13) /* FICP Unit Clock Enable */ +#define CKEN12_MMC (1 << 12) /* MMC Unit Clock Enable */ +#define CKEN11_USB (1 << 11) /* USB Unit Clock Enable */ +#if defined(CONFIG_PXA27X) +#define CKEN10_USBHOST (1 << 10) /* USB Host Unit Clock Enable */ +#define CKEN24_CAMERA (1 << 24) /* Camera Unit Clock Enable */ +#endif +#define CKEN8_I2S (1 << 8) /* I2S Unit Clock Enable */ +#define CKEN7_BTUART (1 << 7) /* BTUART Unit Clock Enable */ +#define CKEN6_FFUART (1 << 6) /* FFUART Unit Clock Enable */ +#define CKEN5_STUART (1 << 5) /* STUART Unit Clock Enable */ +#define CKEN3_SSP (1 << 3) /* SSP Unit Clock Enable */ +#define CKEN2_AC97 (1 << 2) /* AC97 Unit Clock Enable */ +#define CKEN1_PWM1 (1 << 1) /* PWM1 Clock Enable */ +#define CKEN0_PWM0 (1 << 0) /* PWM0 Clock Enable */
-#define PWM_CTRL3 __REG(0x40C00010) /* PWM 3 Control Register */ -#define PWM_PWDUTY3 __REG(0x40C00014) /* PWM 3 Duty Cycle Register */ -#define PWM_PERVAL3 __REG(0x40C00018) /* PWM 3 Period Control Register */ +#define OSCC_OON (1 << 1) /* 32.768kHz OON (write-once only bit) */ +#define OSCC_OOK (1 << 0) /* 32.768kHz OOK (read-only bit) */
+#if !defined(CONFIG_PXA27X) +#define CCCR_L09 (0x1F) +#define CCCR_L27 (0x1) +#define CCCR_L32 (0x2) +#define CCCR_L36 (0x3) +#define CCCR_L40 (0x4) +#define CCCR_L45 (0x5) + +#define CCCR_M1 (0x1 << 5) +#define CCCR_M2 (0x2 << 5) +#define CCCR_M4 (0x3 << 5) + +#define CCCR_N10 (0x2 << 7) +#define CCCR_N15 (0x3 << 7) +#define CCCR_N20 (0x4 << 7) +#define CCCR_N25 (0x5 << 7) +#define CCCR_N30 (0x6 << 7) +#endif + +#endif /* CONFIG_CPU_MONAHANS */ + +/******************************************************************************/ /* - * Interrupt Controller + * Pulse Width Modulator */ -#define ICIP __REG(0x40D00000) /* Interrupt Controller IRQ Pending Register */ -#define ICMR __REG(0x40D00004) /* Interrupt Controller Mask Register */ -#define ICLR __REG(0x40D00008) /* Interrupt Controller Level Register */ -#define ICFP __REG(0x40D0000C) /* Interrupt Controller FIQ Pending Register */ -#define ICPR __REG(0x40D00010) /* Interrupt Controller Pending Register */ -#define ICCR __REG(0x40D00014) /* Interrupt Controller Control Register */ +#define PWM_CTRL0 (0x40B00000) /* PWM 0 Control Register */ +#define PWM_PWDUTY0 (0x40B00004) /* PWM 0 Duty Cycle Register */ +#define PWM_PERVAL0 (0x40B00008) /* PWM 0 Period Control Register */
-#ifdef CONFIG_CPU_MONAHANS -#define ICHP __REG(0x40D00018) /* Interrupt Controller Highest Priority Register */ -/* Missing: 32 Interrupt priority registers - * These are the same as beneath for PXA27x: maybe can be merged if - * GPIO Stuff is same too. +#define PWM_CTRL1 (0x40C00000) /* PWM 1 Control Register */ +#define PWM_PWDUTY1 (0x40C00004) /* PWM 1 Duty Cycle Register */ +#define PWM_PERVAL1 (0x40C00008) /* PWM 1 Period Control Register */ + +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define PWM_CTRL2 (0x40B00010) /* PWM 2 Control Register */ +#define PWM_PWDUTY2 (0x40B00014) /* PWM 2 Duty Cycle Register */ +#define PWM_PERVAL2 (0x40B00018) /* PWM 2 Period Control Register */ + +#define PWM_CTRL3 (0x40C00010) /* PWM 3 Control Register */ +#define PWM_PWDUTY3 (0x40C00014) /* PWM 3 Duty Cycle Register */ +#define PWM_PERVAL3 (0x40C00018) /* PWM 3 Period Control Register */ +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */ + +/* + * Interrupt Controller */ -#define ICIP2 __REG(0x40D0009C) /* Interrupt Controller IRQ Pending Register 2 */ -#define ICMR2 __REG(0x40D000A0) /* Interrupt Controller Mask Register 2 */ -#define ICLR2 __REG(0x40D000A4) /* Interrupt Controller Level Register 2 */ -#define ICFP2 __REG(0x40D000A8) /* Interrupt Controller FIQ Pending Register 2 */ -#define ICPR2 __REG(0x40D000AC) /* Interrupt Controller Pending Register 2 */ -/* Missing: 2 Interrupt priority registers */ -#endif /* CONFIG_CPU_MONAHANS */ +#define ICIP (0x40D00000) /* Interrupt Controller IRQ Pending Register */ +#define ICMR (0x40D00004) /* Interrupt Controller Mask Register */ +#define ICLR (0x40D00008) /* Interrupt Controller Level Register */ +#define ICFP (0x40D0000C) /* Interrupt Controller FIQ Pending Register */ +#define ICPR (0x40D00010) /* Interrupt Controller Pending Register */ +#define ICCR (0x40D00014) /* Interrupt Controller Control Register */
+#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define ICHP (0x40D00018) /* Interrupt Controller Highest Priority Register */ +#define ICIP2 (0x40D0009C) /* Interrupt Controller IRQ Pending Register 2 */ +#define ICMR2 (0x40D000A0) /* Interrupt Controller Mask Register 2 */ +#define ICLR2 (0x40D000A4) /* Interrupt Controller Level Register 2 */ +#define ICFP2 (0x40D000A8) /* Interrupt Controller FIQ Pending Register 2 */ +#define ICPR2 (0x40D000AC) /* Interrupt Controller Pending Register 2 */ +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */ + +/******************************************************************************/ /* * General Purpose I/O */ -#define GPLR0 __REG(0x40E00000) /* GPIO Pin-Level Register GPIO<31:0> */ -#define GPLR1 __REG(0x40E00004) /* GPIO Pin-Level Register GPIO<63:32> */ -#define GPLR2 __REG(0x40E00008) /* GPIO Pin-Level Register GPIO<80:64> */ +#define GPLR0 (0x40E00000) /* GPIO Pin-Level Register GPIO<31:0> */ +#define GPLR1 (0x40E00004) /* GPIO Pin-Level Register GPIO<63:32> */ +#define GPLR2 (0x40E00008) /* GPIO Pin-Level Register GPIO<80:64> */
-#define GPDR0 __REG(0x40E0000C) /* GPIO Pin Direction Register GPIO<31:0> */ -#define GPDR1 __REG(0x40E00010) /* GPIO Pin Direction Register GPIO<63:32> */ -#define GPDR2 __REG(0x40E00014) /* GPIO Pin Direction Register GPIO<80:64> */ +#define GPDR0 (0x40E0000C) /* GPIO Pin Direction Register GPIO<31:0> */ +#define GPDR1 (0x40E00010) /* GPIO Pin Direction Register GPIO<63:32> */ +#define GPDR2 (0x40E00014) /* GPIO Pin Direction Register GPIO<80:64> */
-#define GPSR0 __REG(0x40E00018) /* GPIO Pin Output Set Register GPIO<31:0> */ -#define GPSR1 __REG(0x40E0001C) /* GPIO Pin Output Set Register GPIO<63:32> */ -#define GPSR2 __REG(0x40E00020) /* GPIO Pin Output Set Register GPIO<80:64> */ +#define GPSR0 (0x40E00018) /* GPIO Pin Output Set Register GPIO<31:0> */ +#define GPSR1 (0x40E0001C) /* GPIO Pin Output Set Register GPIO<63:32> */ +#define GPSR2 (0x40E00020) /* GPIO Pin Output Set Register GPIO<80:64> */
-#define GPCR0 __REG(0x40E00024) /* GPIO Pin Output Clear Register GPIO<31:0> */ -#define GPCR1 __REG(0x40E00028) /* GPIO Pin Output Clear Register GPIO <63:32> */ -#define GPCR2 __REG(0x40E0002C) /* GPIO Pin Output Clear Register GPIO <80:64> */ +#define GPCR0 (0x40E00024) /* GPIO Pin Output Clear Register GPIO<31:0> */ +#define GPCR1 (0x40E00028) /* GPIO Pin Output Clear Register GPIO <63:32> */ +#define GPCR2 (0x40E0002C) /* GPIO Pin Output Clear Register GPIO <80:64> */
-#define GRER0 __REG(0x40E00030) /* GPIO Rising-Edge Detect Register GPIO<31:0> */ -#define GRER1 __REG(0x40E00034) /* GPIO Rising-Edge Detect Register GPIO<63:32> */ -#define GRER2 __REG(0x40E00038) /* GPIO Rising-Edge Detect Register GPIO<80:64> */ +#define GRER0 (0x40E00030) /* GPIO Rising-Edge Detect Register GPIO<31:0> */ +#define GRER1 (0x40E00034) /* GPIO Rising-Edge Detect Register GPIO<63:32> */ +#define GRER2 (0x40E00038) /* GPIO Rising-Edge Detect Register GPIO<80:64> */
-#define GFER0 __REG(0x40E0003C) /* GPIO Falling-Edge Detect Register GPIO<31:0> */ -#define GFER1 __REG(0x40E00040) /* GPIO Falling-Edge Detect Register GPIO<63:32> */ -#define GFER2 __REG(0x40E00044) /* GPIO Falling-Edge Detect Register GPIO<80:64> */ +#define GFER0 (0x40E0003C) /* GPIO Falling-Edge Detect Register GPIO<31:0> */ +#define GFER1 (0x40E00040) /* GPIO Falling-Edge Detect Register GPIO<63:32> */ +#define GFER2 (0x40E00044) /* GPIO Falling-Edge Detect Register GPIO<80:64> */
-#define GEDR0 __REG(0x40E00048) /* GPIO Edge Detect Status Register GPIO<31:0> */ -#define GEDR1 __REG(0x40E0004C) /* GPIO Edge Detect Status Register GPIO<63:32> */ -#define GEDR2 __REG(0x40E00050) /* GPIO Edge Detect Status Register GPIO<80:64> */ +#define GEDR0 (0x40E00048) /* GPIO Edge Detect Status Register GPIO<31:0> */ +#define GEDR1 (0x40E0004C) /* GPIO Edge Detect Status Register GPIO<63:32> */ +#define GEDR2 (0x40E00050) /* GPIO Edge Detect Status Register GPIO<80:64> */ + +#define GAFR0_L (0x40E00054) /* GPIO Alternate Function Select Register GPIO<15:0> */ +#define GAFR0_U (0x40E00058) /* GPIO Alternate Function Select Register GPIO<31:16> */ +#define GAFR1_L (0x40E0005C) /* GPIO Alternate Function Select Register GPIO<47:32> */ +#define GAFR1_U (0x40E00060) /* GPIO Alternate Function Select Register GPIO<63:48> */ +#define GAFR2_L (0x40E00064) /* GPIO Alternate Function Select Register GPIO<79:64> */ +#define GAFR2_U (0x40E00068) /* GPIO Alternate Function Select Register GPIO 80 */ + +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define GPLR3 (0x40E00100) /* GPIO Pin-Level Register GPIO<127:96> */ +#define GPDR3 (0x40E0010C) /* GPIO Pin Direction Register GPIO<127:96> */ +#define GPSR3 (0x40E00118) /* GPIO Pin Output Set Register GPIO<127:96> */ +#define GPCR3 (0x40E00124) /* GPIO Pin Output Clear Register GPIO<127:96> */ +#define GRER3 (0x40E00130) /* GPIO Rising-Edge Detect Register GPIO<127:96> */ +#define GFER3 (0x40E0013C) /* GPIO Falling-Edge Detect Register GPIO<127:96> */ +#define GEDR3 (0x40E00148) /* GPIO Edge Detect Status Register GPIO<127:96> */ +#define GAFR3_L (0x40E0006C) /* GPIO Alternate Function Select Register GPIO<111:96> */ +#define GAFR3_U (0x40E00070) /* GPIO Alternate Function Select Register GPIO<127:112> */ +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */
#ifdef CONFIG_CPU_MONAHANS -#define GPLR3 __REG(0x40E00100) /* GPIO Pin-Level Register GPIO<127:96> */ -#define GPDR3 __REG(0x40E0010C) /* GPIO Pin Direction Register GPIO<127:96> */ -#define GPSR3 __REG(0x40E00118) /* GPIO Pin Output Set Register GPIO<127:96> */ -#define GPCR3 __REG(0x40E00124) /* GPIO Pin Output Clear Register GPIO<127:96> */ -#define GRER3 __REG(0x40E00130) /* GPIO Rising-Edge Detect Register GPIO<127:96> */ -#define GFER3 __REG(0x40E0013C) /* GPIO Falling-Edge Detect Register GPIO<127:96> */ -#define GEDR3 __REG(0x40E00148) /* GPIO Edge Detect Status Register GPIO<127:96> */ - -#define GSDR0 __REG(0x40E00400) /* Bit-wise Set of GPDR[31:0] */ -#define GSDR1 __REG(0x40E00404) /* Bit-wise Set of GPDR[63:32] */ -#define GSDR2 __REG(0x40E00408) /* Bit-wise Set of GPDR[95:64] */ -#define GSDR3 __REG(0x40E0040C) /* Bit-wise Set of GPDR[127:96] */ - -#define GCDR0 __REG(0x40E00420) /* Bit-wise Clear of GPDR[31:0] */ -#define GCDR1 __REG(0x40E00424) /* Bit-wise Clear of GPDR[63:32] */ -#define GCDR2 __REG(0x40E00428) /* Bit-wise Clear of GPDR[95:64] */ -#define GCDR3 __REG(0x40E0042C) /* Bit-wise Clear of GPDR[127:96] */ - -#define GSRER0 __REG(0x40E00440) /* Set Rising Edge Det. Enable [31:0] */ -#define GSRER1 __REG(0x40E00444) /* Set Rising Edge Det. Enable [63:32] */ -#define GSRER2 __REG(0x40E00448) /* Set Rising Edge Det. Enable [95:64] */ -#define GSRER3 __REG(0x40E0044C) /* Set Rising Edge Det. Enable [127:96] */ - -#define GCRER0 __REG(0x40E00460) /* Clear Rising Edge Det. Enable [31:0] */ -#define GCRER1 __REG(0x40E00464) /* Clear Rising Edge Det. Enable [63:32] */ -#define GCRER2 __REG(0x40E00468) /* Clear Rising Edge Det. Enable [95:64] */ -#define GCRER3 __REG(0x40E0046C) /* Clear Rising Edge Det. Enable[127:96] */ - -#define GSFER0 __REG(0x40E00480) /* Set Falling Edge Det. Enable [31:0] */ -#define GSFER1 __REG(0x40E00484) /* Set Falling Edge Det. Enable [63:32] */ -#define GSFER2 __REG(0x40E00488) /* Set Falling Edge Det. Enable [95:64] */ -#define GSFER3 __REG(0x40E0048C) /* Set Falling Edge Det. Enable[127:96] */ - -#define GCFER0 __REG(0x40E004A0) /* Clr Falling Edge Det. Enable [31:0] */ -#define GCFER1 __REG(0x40E004A4) /* Clr Falling Edge Det. Enable [63:32] */ -#define GCFER2 __REG(0x40E004A8) /* Clr Falling Edge Det. Enable [95:64] */ -#define GCFER3 __REG(0x40E004AC) /* Clr Falling Edge Det. Enable[127:96] */ - -#define GSDR(x) __REG2(0x40E00400, ((x) & 0x60) >> 3) -#define GCDR(x) __REG2(0x40E00420, ((x) & 0x60) >> 3) - -/* Multi-funktion Pin Registers, uncomplete, only: - * - GPIO - * - Data Flash DF_* pins defined. +#define GSDR0 (0x40E00400) /* Bit-wise Set of GPDR[31:0] */ +#define GSDR1 (0x40E00404) /* Bit-wise Set of GPDR[63:32] */ +#define GSDR2 (0x40E00408) /* Bit-wise Set of GPDR[95:64] */ +#define GSDR3 (0x40E0040C) /* Bit-wise Set of GPDR[127:96] */ + +#define GCDR0 (0x40E00420) /* Bit-wise Clear of GPDR[31:0] */ +#define GCDR1 (0x40E00424) /* Bit-wise Clear of GPDR[63:32] */ +#define GCDR2 (0x40E00428) /* Bit-wise Clear of GPDR[95:64] */ +#define GCDR3 (0x40E0042C) /* Bit-wise Clear of GPDR[127:96] */ + +#define GSRER0 (0x40E00440) /* Set Rising Edge Det. Enable [31:0] */ +#define GSRER1 (0x40E00444) /* Set Rising Edge Det. Enable [63:32] */ +#define GSRER2 (0x40E00448) /* Set Rising Edge Det. Enable [95:64] */ +#define GSRER3 (0x40E0044C) /* Set Rising Edge Det. Enable [127:96] */ + +#define GCRER0 (0x40E00460) /* Clear Rising Edge Det. Enable [31:0] */ +#define GCRER1 (0x40E00464) /* Clear Rising Edge Det. Enable [63:32] */ +#define GCRER2 (0x40E00468) /* Clear Rising Edge Det. Enable [95:64] */ +#define GCRER3 (0x40E0046C) /* Clear Rising Edge Det. Enable[127:96] */ + +#define GSFER0 (0x40E00480) /* Set Falling Edge Det. Enable [31:0] */ +#define GSFER1 (0x40E00484) /* Set Falling Edge Det. Enable [63:32] */ +#define GSFER2 (0x40E00488) /* Set Falling Edge Det. Enable [95:64] */ +#define GSFER3 (0x40E0048C) /* Set Falling Edge Det. Enable[127:96] */ + +#define GCFER0 (0x40E004A0) /* Clr Falling Edge Det. Enable [31:0] */ +#define GCFER1 (0x40E004A4) /* Clr Falling Edge Det. Enable [63:32] */ +#define GCFER2 (0x40E004A8) /* Clr Falling Edge Det. Enable [95:64] */ +#define GCFER3 (0x40E004AC) /* Clr Falling Edge Det. Enable[127:96] */ + +#define GSDR(x) (0x40E00400 | ((x) & 0x60) >> 3) +#define GCDR(x) (0x40E00420 | ((x) & 0x60) >> 3) +#endif + +#define _GPLR(x) (0x40E00000 + (((x) & 0x60) >> 3)) +#define _GPDR(x) (0x40E0000C + (((x) & 0x60) >> 3)) +#define _GPSR(x) (0x40E00018 + (((x) & 0x60) >> 3)) +#define _GPCR(x) (0x40E00024 + (((x) & 0x60) >> 3)) +#define _GRER(x) (0x40E00030 + (((x) & 0x60) >> 3)) +#define _GFER(x) (0x40E0003C + (((x) & 0x60) >> 3)) +#define _GEDR(x) (0x40E00048 + (((x) & 0x60) >> 3)) +#define _GAFR(x) (0x40E00054 + (((x) & 0x70) >> 2)) + +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define GPLR(x) (((((x) & 0x7f) < 96) ? _GPLR(x) : GPLR3)) +#define GPDR(x) (((((x) & 0x7f) < 96) ? _GPDR(x) : GPDR3)) +#define GPSR(x) (((((x) & 0x7f) < 96) ? _GPSR(x) : GPSR3)) +#define GPCR(x) (((((x) & 0x7f) < 96) ? _GPCR(x) : GPCR3)) +#define GRER(x) (((((x) & 0x7f) < 96) ? _GRER(x) : GRER3)) +#define GFER(x) (((((x) & 0x7f) < 96) ? _GFER(x) : GFER3)) +#define GEDR(x) (((((x) & 0x7f) < 96) ? _GEDR(x) : GEDR3)) +#define GAFR(x) (((((x) & 0x7f) < 96) ? _GAFR(x) : \ + ((((x) & 0x7f) < 112) ? GAFR3_L : GAFR3_U))) +#else +#define GPLR(x) _GPLR(x) +#define GPDR(x) _GPDR(x) +#define GPSR(x) _GPSR(x) +#define GPCR(x) _GPCR(x) +#define GRER(x) _GRER(x) +#define GFER(x) _GFER(x) +#define GEDR(x) _GEDR(x) +#define GAFR(x) _GAFR(x) +#endif + +#define GPIO_bit(x) (1 << ((x) & 0x1f)) + +/******************************************************************************/ +/* + * Multi-function Pin Registers: */ -#define GPIO0 __REG(0x40e10124) -#define GPIO1 __REG(0x40e10128) -#define GPIO2 __REG(0x40e1012c) -#define GPIO3 __REG(0x40e10130) -#define GPIO4 __REG(0x40e10134) -#define nXCVREN __REG(0x40e10138) - -#define DF_CLE_NOE __REG(0x40e10204) -#define DF_ALE_WE1 __REG(0x40e10208) - -#define DF_SCLK_E __REG(0x40e10210) -#define nBE0 __REG(0x40e10214) -#define nBE1 __REG(0x40e10218) -#define DF_ALE_WE2 __REG(0x40e1021c) -#define DF_INT_RnB __REG(0x40e10220) -#define DF_nCS0 __REG(0x40e10224) -#define DF_nCS1 __REG(0x40e10228) -#define DF_nWE __REG(0x40e1022c) -#define DF_nRE __REG(0x40e10230) -#define nLUA __REG(0x40e10234) -#define nLLA __REG(0x40e10238) -#define DF_ADDR0 __REG(0x40e1023c) -#define DF_ADDR1 __REG(0x40e10240) -#define DF_ADDR2 __REG(0x40e10244) -#define DF_ADDR3 __REG(0x40e10248) -#define DF_IO0 __REG(0x40e1024c) -#define DF_IO8 __REG(0x40e10250) -#define DF_IO1 __REG(0x40e10254) -#define DF_IO9 __REG(0x40e10258) -#define DF_IO2 __REG(0x40e1025c) -#define DF_IO10 __REG(0x40e10260) -#define DF_IO3 __REG(0x40e10264) -#define DF_IO11 __REG(0x40e10268) -#define DF_IO4 __REG(0x40e1026c) -#define DF_IO12 __REG(0x40e10270) -#define DF_IO5 __REG(0x40e10274) -#define DF_IO13 __REG(0x40e10278) -#define DF_IO6 __REG(0x40e1027c) -#define DF_IO14 __REG(0x40e10280) -#define DF_IO7 __REG(0x40e10284) -#define DF_IO15 __REG(0x40e10288) - -#define GPIO5 __REG(0x40e1028c) -#define GPIO6 __REG(0x40e10290) -#define GPIO7 __REG(0x40e10294) -#define GPIO8 __REG(0x40e10298) -#define GPIO9 __REG(0x40e1029c) - -#define GPIO11 __REG(0x40e102a0) -#define GPIO12 __REG(0x40e102a4) -#define GPIO13 __REG(0x40e102a8) -#define GPIO14 __REG(0x40e102ac) -#define GPIO15 __REG(0x40e102b0) -#define GPIO16 __REG(0x40e102b4) -#define GPIO17 __REG(0x40e102b8) -#define GPIO18 __REG(0x40e102bc) -#define GPIO19 __REG(0x40e102c0) -#define GPIO20 __REG(0x40e102c4) -#define GPIO21 __REG(0x40e102c8) -#define GPIO22 __REG(0x40e102cc) -#define GPIO23 __REG(0x40e102d0) -#define GPIO24 __REG(0x40e102d4) -#define GPIO25 __REG(0x40e102d8) -#define GPIO26 __REG(0x40e102dc) - -#define GPIO27 __REG(0x40e10400) -#define GPIO28 __REG(0x40e10404) -#define GPIO29 __REG(0x40e10408) -#define GPIO30 __REG(0x40e1040c) -#define GPIO31 __REG(0x40e10410) -#define GPIO32 __REG(0x40e10414) -#define GPIO33 __REG(0x40e10418) -#define GPIO34 __REG(0x40e1041c) -#define GPIO35 __REG(0x40e10420) -#define GPIO36 __REG(0x40e10424) -#define GPIO37 __REG(0x40e10428) -#define GPIO38 __REG(0x40e1042c) -#define GPIO39 __REG(0x40e10430) -#define GPIO40 __REG(0x40e10434) -#define GPIO41 __REG(0x40e10438) -#define GPIO42 __REG(0x40e1043c) -#define GPIO43 __REG(0x40e10440) -#define GPIO44 __REG(0x40e10444) -#define GPIO45 __REG(0x40e10448) -#define GPIO46 __REG(0x40e1044c) -#define GPIO47 __REG(0x40e10450) -#define GPIO48 __REG(0x40e10454) - -#define GPIO10 __REG(0x40e10458) - -#define GPIO49 __REG(0x40e1045c) -#define GPIO50 __REG(0x40e10460) -#define GPIO51 __REG(0x40e10464) -#define GPIO52 __REG(0x40e10468) -#define GPIO53 __REG(0x40e1046c) -#define GPIO54 __REG(0x40e10470) -#define GPIO55 __REG(0x40e10474) -#define GPIO56 __REG(0x40e10478) -#define GPIO57 __REG(0x40e1047c) -#define GPIO58 __REG(0x40e10480) -#define GPIO59 __REG(0x40e10484) -#define GPIO60 __REG(0x40e10488) -#define GPIO61 __REG(0x40e1048c) -#define GPIO62 __REG(0x40e10490) - -#define GPIO6_2 __REG(0x40e10494) -#define GPIO7_2 __REG(0x40e10498) -#define GPIO8_2 __REG(0x40e1049c) -#define GPIO9_2 __REG(0x40e104a0) -#define GPIO10_2 __REG(0x40e104a4) -#define GPIO11_2 __REG(0x40e104a8) -#define GPIO12_2 __REG(0x40e104ac) -#define GPIO13_2 __REG(0x40e104b0) - -#define GPIO63 __REG(0x40e104b4) -#define GPIO64 __REG(0x40e104b8) -#define GPIO65 __REG(0x40e104bc) -#define GPIO66 __REG(0x40e104c0) -#define GPIO67 __REG(0x40e104c4) -#define GPIO68 __REG(0x40e104c8) -#define GPIO69 __REG(0x40e104cc) -#define GPIO70 __REG(0x40e104d0) -#define GPIO71 __REG(0x40e104d4) -#define GPIO72 __REG(0x40e104d8) -#define GPIO73 __REG(0x40e104dc) - -#define GPIO14_2 __REG(0x40e104e0) -#define GPIO15_2 __REG(0x40e104e4) -#define GPIO16_2 __REG(0x40e104e8) -#define GPIO17_2 __REG(0x40e104ec) - -#define GPIO74 __REG(0x40e104f0) -#define GPIO75 __REG(0x40e104f4) -#define GPIO76 __REG(0x40e104f8) -#define GPIO77 __REG(0x40e104fc) -#define GPIO78 __REG(0x40e10500) -#define GPIO79 __REG(0x40e10504) -#define GPIO80 __REG(0x40e10508) -#define GPIO81 __REG(0x40e1050c) -#define GPIO82 __REG(0x40e10510) -#define GPIO83 __REG(0x40e10514) -#define GPIO84 __REG(0x40e10518) -#define GPIO85 __REG(0x40e1051c) -#define GPIO86 __REG(0x40e10520) -#define GPIO87 __REG(0x40e10524) -#define GPIO88 __REG(0x40e10528) -#define GPIO89 __REG(0x40e1052c) -#define GPIO90 __REG(0x40e10530) -#define GPIO91 __REG(0x40e10534) -#define GPIO92 __REG(0x40e10538) -#define GPIO93 __REG(0x40e1053c) -#define GPIO94 __REG(0x40e10540) -#define GPIO95 __REG(0x40e10544) -#define GPIO96 __REG(0x40e10548) -#define GPIO97 __REG(0x40e1054c) -#define GPIO98 __REG(0x40e10550) - -#define GPIO99 __REG(0x40e10600) -#define GPIO100 __REG(0x40e10604) -#define GPIO101 __REG(0x40e10608) -#define GPIO102 __REG(0x40e1060c) -#define GPIO103 __REG(0x40e10610) -#define GPIO104 __REG(0x40e10614) -#define GPIO105 __REG(0x40e10618) -#define GPIO106 __REG(0x40e1061c) -#define GPIO107 __REG(0x40e10620) -#define GPIO108 __REG(0x40e10624) -#define GPIO109 __REG(0x40e10628) -#define GPIO110 __REG(0x40e1062c) -#define GPIO111 __REG(0x40e10630) -#define GPIO112 __REG(0x40e10634) - -#define GPIO113 __REG(0x40e10638) -#define GPIO114 __REG(0x40e1063c) -#define GPIO115 __REG(0x40e10640) -#define GPIO116 __REG(0x40e10644) -#define GPIO117 __REG(0x40e10648) -#define GPIO118 __REG(0x40e1064c) -#define GPIO119 __REG(0x40e10650) -#define GPIO120 __REG(0x40e10654) -#define GPIO121 __REG(0x40e10658) -#define GPIO122 __REG(0x40e1065c) -#define GPIO123 __REG(0x40e10660) -#define GPIO124 __REG(0x40e10664) -#define GPIO125 __REG(0x40e10668) -#define GPIO126 __REG(0x40e1066c) -#define GPIO127 __REG(0x40e10670) - -#define GPIO0_2 __REG(0x40e10674) -#define GPIO1_2 __REG(0x40e10678) -#define GPIO2_2 __REG(0x40e1067c) -#define GPIO3_2 __REG(0x40e10680) -#define GPIO4_2 __REG(0x40e10684) -#define GPIO5_2 __REG(0x40e10688) +/* PXA320 */ +#if defined(CONFIG_CPU_PXA320) +#define DF_IO0 (0x40e1024c) +#define DF_IO1 (0x40e10254) +#define DF_IO2 (0x40e1025c) +#define DF_IO3 (0x40e10264) +#define DF_IO4 (0x40e1026c) +#define DF_IO5 (0x40e10274) +#define DF_IO6 (0x40e1027c) +#define DF_IO7 (0x40e10284) +#define DF_IO8 (0x40e10250) +#define DF_IO9 (0x40e10258) +#define DF_IO10 (0x40e10260) +#define DF_IO11 (0x40e10268) +#define DF_IO12 (0x40e10270) +#define DF_IO13 (0x40e10278) +#define DF_IO14 (0x40e10280) +#define DF_IO15 (0x40e10288) +#define DF_CLE_nOE (0x40e10204) +#define DF_ALE_nWE1 (0x40e10208) +#define DF_ALE_nWE2 (0x40e1021c) +#define DF_SCLK_E (0x40e10210) +#define DF_nCS0 (0x40e10224) +#define DF_nCS1 (0x40e10228) +#define nBE0 (0x40e10214) +#define nBE1 (0x40e10218) +#define nLUA (0x40e10234) +#define nLLA (0x40e10238) +#define DF_ADDR0 (0x40e1023c) +#define DF_ADDR1 (0x40e10240) +#define DF_ADDR2 (0x40e10244) +#define DF_ADDR3 (0x40e10248) +#define DF_INT_RnB (0x40e10220) +#define DF_nCS0 (0x40e10224) +#define DF_nCS1 (0x40e10228) +#define DF_nWE (0x40e1022c) +#define DF_nRE (0x40e10230) + +#define nXCVREN (0x40e10138) + +#define GPIO0 (0x40e10124) +#define GPIO1 (0x40e10128) +#define GPIO2 (0x40e1012c) +#define GPIO3 (0x40e10130) +#define GPIO4 (0x40e10134) +#define GPIO5 (0x40e1028c) +#define GPIO6 (0x40e10290) +#define GPIO7 (0x40e10294) +#define GPIO8 (0x40e10298) +#define GPIO9 (0x40e1029c) +#define GPIO10 (0x40e10458) +#define GPIO11 (0x40e102a0) +#define GPIO12 (0x40e102a4) +#define GPIO13 (0x40e102a8) +#define GPIO14 (0x40e102ac) +#define GPIO15 (0x40e102b0) +#define GPIO16 (0x40e102b4) +#define GPIO17 (0x40e102b8) +#define GPIO18 (0x40e102bc) +#define GPIO19 (0x40e102c0) +#define GPIO20 (0x40e102c4) +#define GPIO21 (0x40e102c8) +#define GPIO22 (0x40e102cc) +#define GPIO23 (0x40e102d0) +#define GPIO24 (0x40e102d4) +#define GPIO25 (0x40e102d8) +#define GPIO26 (0x40e102dc) + +#define GPIO27 (0x40e10400) +#define GPIO28 (0x40e10404) +#define GPIO29 (0x40e10408) +#define GPIO30 (0x40e1040c) +#define GPIO31 (0x40e10410) +#define GPIO32 (0x40e10414) +#define GPIO33 (0x40e10418) +#define GPIO34 (0x40e1041c) +#define GPIO35 (0x40e10420) +#define GPIO36 (0x40e10424) +#define GPIO37 (0x40e10428) +#define GPIO38 (0x40e1042c) +#define GPIO39 (0x40e10430) +#define GPIO40 (0x40e10434) +#define GPIO41 (0x40e10438) +#define GPIO42 (0x40e1043c) +#define GPIO43 (0x40e10440) +#define GPIO44 (0x40e10444) +#define GPIO45 (0x40e10448) +#define GPIO46 (0x40e1044c) +#define GPIO47 (0x40e10450) +#define GPIO48 (0x40e10454) +#define GPIO49 (0x40e1045c) +#define GPIO50 (0x40e10460) +#define GPIO51 (0x40e10464) +#define GPIO52 (0x40e10468) +#define GPIO53 (0x40e1046c) +#define GPIO54 (0x40e10470) +#define GPIO55 (0x40e10474) +#define GPIO56 (0x40e10478) +#define GPIO57 (0x40e1047c) +#define GPIO58 (0x40e10480) +#define GPIO59 (0x40e10484) +#define GPIO60 (0x40e10488) +#define GPIO61 (0x40e1048c) +#define GPIO62 (0x40e10490) + +#define GPIO6_2 (0x40e10494) +#define GPIO7_2 (0x40e10498) +#define GPIO8_2 (0x40e1049c) +#define GPIO9_2 (0x40e104a0) +#define GPIO10_2 (0x40e104a4) +#define GPIO11_2 (0x40e104a8) +#define GPIO12_2 (0x40e104ac) +#define GPIO13_2 (0x40e104b0) + +#define GPIO63 (0x40e104b4) +#define GPIO64 (0x40e104b8) +#define GPIO65 (0x40e104bc) +#define GPIO66 (0x40e104c0) +#define GPIO67 (0x40e104c4) +#define GPIO68 (0x40e104c8) +#define GPIO69 (0x40e104cc) +#define GPIO70 (0x40e104d0) +#define GPIO71 (0x40e104d4) +#define GPIO72 (0x40e104d8) +#define GPIO73 (0x40e104dc) + +#define GPIO14_2 (0x40e104e0) +#define GPIO15_2 (0x40e104e4) +#define GPIO16_2 (0x40e104e8) +#define GPIO17_2 (0x40e104ec) + +#define GPIO74 (0x40e104f0) +#define GPIO75 (0x40e104f4) +#define GPIO76 (0x40e104f8) +#define GPIO77 (0x40e104fc) +#define GPIO78 (0x40e10500) +#define GPIO79 (0x40e10504) +#define GPIO80 (0x40e10508) +#define GPIO81 (0x40e1050c) +#define GPIO82 (0x40e10510) +#define GPIO83 (0x40e10514) +#define GPIO84 (0x40e10518) +#define GPIO85 (0x40e1051c) +#define GPIO86 (0x40e10520) +#define GPIO87 (0x40e10524) +#define GPIO88 (0x40e10528) +#define GPIO89 (0x40e1052c) +#define GPIO90 (0x40e10530) +#define GPIO91 (0x40e10534) +#define GPIO92 (0x40e10538) +#define GPIO93 (0x40e1053c) +#define GPIO94 (0x40e10540) +#define GPIO95 (0x40e10544) +#define GPIO96 (0x40e10548) +#define GPIO97 (0x40e1054c) +#define GPIO98 (0x40e10550) + +#define GPIO99 (0x40e10600) +#define GPIO100 (0x40e10604) +#define GPIO101 (0x40e10608) +#define GPIO102 (0x40e1060c) +#define GPIO103 (0x40e10610) +#define GPIO104 (0x40e10614) +#define GPIO105 (0x40e10618) +#define GPIO106 (0x40e1061c) +#define GPIO107 (0x40e10620) +#define GPIO108 (0x40e10624) +#define GPIO109 (0x40e10628) +#define GPIO110 (0x40e1062c) +#define GPIO111 (0x40e10630) +#define GPIO112 (0x40e10634) + +#define GPIO113 (0x40e10638) +#define GPIO114 (0x40e1063c) +#define GPIO115 (0x40e10640) +#define GPIO116 (0x40e10644) +#define GPIO117 (0x40e10648) +#define GPIO118 (0x40e1064c) +#define GPIO119 (0x40e10650) +#define GPIO120 (0x40e10654) +#define GPIO121 (0x40e10658) +#define GPIO122 (0x40e1065c) +#define GPIO123 (0x40e10660) +#define GPIO124 (0x40e10664) +#define GPIO125 (0x40e10668) +#define GPIO126 (0x40e1066c) +#define GPIO127 (0x40e10670) + +#define GPIO0_2 (0x40e10674) +#define GPIO1_2 (0x40e10678) +#define GPIO2_2 (0x40e1067c) +#define GPIO3_2 (0x40e10680) +#define GPIO4_2 (0x40e10684) +#define GPIO5_2 (0x40e10688) + +/* PXA300 and PXA310 */ +#elif defined(CONFIG_CPU_PXA300) || defined(CONFIG_CPU_PXA310) +#define DF_IO0 (0x40e10220) +#define DF_IO1 (0x40e10228) +#define DF_IO2 (0x40e10230) +#define DF_IO3 (0x40e10238) +#define DF_IO4 (0x40e10258) +#define DF_IO5 (0x40e10260) +#define DF_IO7 (0x40e10270) +#define DF_IO6 (0x40e10268) +#define DF_IO8 (0x40e10224) +#define DF_IO9 (0x40e1022c) +#define DF_IO10 (0x40e10234) +#define DF_IO11 (0x40e1023c) +#define DF_IO12 (0x40e1025c) +#define DF_IO13 (0x40e10264) +#define DF_IO14 (0x40e1026c) +#define DF_IO15 (0x40e10274) +#define DF_CLE_NOE (0x40e10240) +#define DF_ALE_nWE (0x40e1020c) +#define DF_SCLK_E (0x40e10250) +#define nCS0 (0x40e100c4) +#define nCS1 (0x40e100c0) +#define nBE0 (0x40e10204) +#define nBE1 (0x40e10208) +#define nLUA (0x40e10244) +#define nLLA (0x40e10254) +#define DF_ADDR0 (0x40e10210) +#define DF_ADDR1 (0x40e10214) +#define DF_ADDR2 (0x40e10218) +#define DF_ADDR3 (0x40e1021c) +#define DF_INT_RnB (0x40e100c8) +#define DF_nCS0 (0x40e10248) +#define DF_nCS1 (0x40e10278) +#define DF_nWE (0x40e100cc) +#define DF_nRE (0x40e10200) + +#define GPIO0 (0x40e100b4) +#define GPIO1 (0x40e100b8) +#define GPIO2 (0x40e100bc) +#define GPIO3 (0x40e1027c) +#define GPIO4 (0x40e10280) + +#define GPIO5 (0x40e10284) +#define GPIO6 (0x40e10288) +#define GPIO7 (0x40e1028c) +#define GPIO8 (0x40e10290) +#define GPIO9 (0x40e10294) +#define GPIO10 (0x40e10298) +#define GPIO11 (0x40e1029c) +#define GPIO12 (0x40e102a0) +#define GPIO13 (0x40e102a4) +#define GPIO14 (0x40e102a8) +#define GPIO15 (0x40e102ac) +#define GPIO16 (0x40e102b0) +#define GPIO17 (0x40e102b4) +#define GPIO18 (0x40e102b8) +#define GPIO19 (0x40e102bc) +#define GPIO20 (0x40e102c0) +#define GPIO21 (0x40e102c4) +#define GPIO22 (0x40e102c8) +#define GPIO23 (0x40e102cc) +#define GPIO24 (0x40e102d0) +#define GPIO25 (0x40e102d4) +#define GPIO26 (0x40e102d8) + +#define GPIO27 (0x40e10400) +#define GPIO28 (0x40e10404) +#define GPIO29 (0x40e10408) +#define ULPI_STP (0x40e1040c) +#define ULPI_NXT (0x40e10410) +#define ULPI_DIR (0x40e10414) +#define GPIO30 (0x40e10418) +#define GPIO31 (0x40e1041c) +#define GPIO32 (0x40e10420) +#define GPIO33 (0x40e10424) +#define GPIO34 (0x40e10428) +#define GPIO35 (0x40e1042c) +#define GPIO36 (0x40e10430) +#define GPIO37 (0x40e10434) +#define GPIO38 (0x40e10438) +#define GPIO39 (0x40e1043c) +#define GPIO40 (0x40e10440) +#define GPIO41 (0x40e10444) +#define GPIO42 (0x40e10448) +#define GPIO43 (0x40e1044c) +#define GPIO44 (0x40e10450) +#define GPIO45 (0x40e10454) +#define GPIO46 (0x40e10458) +#define GPIO47 (0x40e1045c) +#define GPIO48 (0x40e10460) + +#define GPIO49 (0x40e10464) +#define GPIO50 (0x40e10468) +#define GPIO51 (0x40e1046c) +#define GPIO52 (0x40e10470) +#define GPIO53 (0x40e10474) +#define GPIO54 (0x40e10478) +#define GPIO55 (0x40e1047c) +#define GPIO56 (0x40e10480) +#define GPIO57 (0x40e10484) +#define GPIO58 (0x40e10488) +#define GPIO59 (0x40e1048c) +#define GPIO60 (0x40e10490) +#define GPIO61 (0x40e10494) +#define GPIO62 (0x40e10498) +#define GPIO63 (0x40e1049c) +#define GPIO64 (0x40e104a0) +#define GPIO65 (0x40e104a4) +#define GPIO66 (0x40e104a8) +#define GPIO67 (0x40e104ac) +#define GPIO68 (0x40e104b0) +#define GPIO69 (0x40e104b4) +#define GPIO70 (0x40e104b8) +#define GPIO71 (0x40e104bc) +#define GPIO72 (0x40e104c0) +#define GPIO73 (0x40e104c4) +#define GPIO74 (0x40e104c8) +#define GPIO75 (0x40e104cc) +#define GPIO76 (0x40e104d0) +#define GPIO77 (0x40e104d4) +#define GPIO78 (0x40e104d8) +#define GPIO79 (0x40e104dc) +#define GPIO80 (0x40e104e0) +#define GPIO81 (0x40e104e4) +#define GPIO82 (0x40e104e8) +#define GPIO83 (0x40e104ec) +#define GPIO84 (0x40e104f0) +#define GPIO85 (0x40e104f4) +#define GPIO86 (0x40e104f8) +#define GPIO87 (0x40e104fc) +#define GPIO88 (0x40e10500) +#define GPIO89 (0x40e10504) +#define GPIO90 (0x40e10508) +#define GPIO91 (0x40e1050c) +#define GPIO92 (0x40e10510) +#define GPIO93 (0x40e10514) +#define GPIO94 (0x40e10518) +#define GPIO95 (0x40e1051c) +#define GPIO96 (0x40e10520) +#define GPIO97 (0x40e10524) +#define GPIO98 (0x40e10528) + +#define GPIO99 (0x40e10600) +#define GPIO100 (0x40e10604) +#define GPIO101 (0x40e10608) +#define GPIO102 (0x40e1060c) +#define GPIO103 (0x40e10610) +#define GPIO104 (0x40e10614) +#define GPIO105 (0x40e10618) +#define GPIO106 (0x40e1061c) +#define GPIO107 (0x40e10620) +#define GPIO108 (0x40e10624) +#define GPIO109 (0x40e10628) +#define GPIO110 (0x40e1062c) +#define GPIO111 (0x40e10630) +#define GPIO112 (0x40e10634) + +#define GPIO113 (0x40e10638) +#define GPIO114 (0x40e1063c) +#define GPIO115 (0x40e10640) +#define GPIO116 (0x40e10644) +#define GPIO117 (0x40e10648) +#define GPIO118 (0x40e1064c) +#define GPIO119 (0x40e10650) +#define GPIO120 (0x40e10654) +#define GPIO121 (0x40e10658) +#define GPIO122 (0x40e1065c) +#define GPIO123 (0x40e10660) +#define GPIO124 (0x40e10664) +#define GPIO125 (0x40e10668) +#define GPIO126 (0x40e1066c) +#define GPIO127 (0x40e10670) + +#define GPIO0_2 (0x40e10674) +#define GPIO1_2 (0x40e10678) +#define GPIO2_2 (0x40e102dc) +#define GPIO3_2 (0x40e102e0) +#define GPIO4_2 (0x40e102e4) +#define GPIO5_2 (0x40e102e8) +#define GPIO6_2 (0x40e102ec) + +#ifndef CONFIG_CPU_PXA300 /* PXA310 only */ +#define GPIO7_2 (0x40e1052c) +#define GPIO8_2 (0x40e10530) +#define GPIO9_2 (0x40e10534) +#define GPIO10_2 (0x40e10538) +#endif +#endif
+#ifdef CONFIG_CPU_MONAHANS /* MFPR Bit Definitions, see 4-10, Vol. 1 */ #define PULL_SEL 0x8000 #define PULLUP_EN 0x4000 @@ -1470,62 +1855,8 @@ typedef void (*ExcpHndlr) (void) ; #define AF_SEL_6 0x6 /* Alternate function 6 */ #define AF_SEL_7 0x7 /* Alternate function 7 */
- -#else /* CONFIG_CPU_MONAHANS */ - -#define GAFR0_L __REG(0x40E00054) /* GPIO Alternate Function Select Register GPIO<15:0> */ -#define GAFR0_U __REG(0x40E00058) /* GPIO Alternate Function Select Register GPIO<31:16> */ -#define GAFR1_L __REG(0x40E0005C) /* GPIO Alternate Function Select Register GPIO<47:32> */ -#define GAFR1_U __REG(0x40E00060) /* GPIO Alternate Function Select Register GPIO<63:48> */ -#define GAFR2_L __REG(0x40E00064) /* GPIO Alternate Function Select Register GPIO<79:64> */ -#define GAFR2_U __REG(0x40E00068) /* GPIO Alternate Function Select Register GPIO 80 */ #endif /* CONFIG_CPU_MONAHANS */
-/* More handy macros. The argument is a literal GPIO number. */ - -#define GPIO_bit(x) (1 << ((x) & 0x1f)) - -#ifdef CONFIG_PXA27X - -/* Interrupt Controller */ - -#define ICIP2 __REG(0x40D0009C) /* Interrupt Controller IRQ Pending Register 2 */ -#define ICMR2 __REG(0x40D000A0) /* Interrupt Controller Mask Register 2 */ -#define ICLR2 __REG(0x40D000A4) /* Interrupt Controller Level Register 2 */ -#define ICFP2 __REG(0x40D000A8) /* Interrupt Controller FIQ Pending Register 2 */ -#define ICPR2 __REG(0x40D000AC) /* Interrupt Controller Pending Register 2 */ - -#define _GPLR(x) __REG2(0x40E00000, ((x) & 0x60) >> 3) -#define _GPDR(x) __REG2(0x40E0000C, ((x) & 0x60) >> 3) -#define _GPSR(x) __REG2(0x40E00018, ((x) & 0x60) >> 3) -#define _GPCR(x) __REG2(0x40E00024, ((x) & 0x60) >> 3) -#define _GRER(x) __REG2(0x40E00030, ((x) & 0x60) >> 3) -#define _GFER(x) __REG2(0x40E0003C, ((x) & 0x60) >> 3) -#define _GEDR(x) __REG2(0x40E00048, ((x) & 0x60) >> 3) -#define _GAFR(x) __REG2(0x40E00054, ((x) & 0x70) >> 2) - -#define GPLR(x) (*((((x) & 0x7f) < 96) ? &_GPLR(x) : &GPLR3)) -#define GPDR(x) (*((((x) & 0x7f) < 96) ? &_GPDR(x) : &GPDR3)) -#define GPSR(x) (*((((x) & 0x7f) < 96) ? &_GPSR(x) : &GPSR3)) -#define GPCR(x) (*((((x) & 0x7f) < 96) ? &_GPCR(x) : &GPCR3)) -#define GRER(x) (*((((x) & 0x7f) < 96) ? &_GRER(x) : &GRER3)) -#define GFER(x) (*((((x) & 0x7f) < 96) ? &_GFER(x) : &GFER3)) -#define GEDR(x) (*((((x) & 0x7f) < 96) ? &_GEDR(x) : &GEDR3)) -#define GAFR(x) (*((((x) & 0x7f) < 96) ? &_GAFR(x) : \ - ((((x) & 0x7f) < 112) ? &GAFR3_L : &GAFR3_U))) -#else - -#define GPLR(x) __REG2(0x40E00000, ((x) & 0x60) >> 3) -#define GPDR(x) __REG2(0x40E0000C, ((x) & 0x60) >> 3) -#define GPSR(x) __REG2(0x40E00018, ((x) & 0x60) >> 3) -#define GPCR(x) __REG2(0x40E00024, ((x) & 0x60) >> 3) -#define GRER(x) __REG2(0x40E00030, ((x) & 0x60) >> 3) -#define GFER(x) __REG2(0x40E0003C, ((x) & 0x60) >> 3) -#define GEDR(x) __REG2(0x40E00048, ((x) & 0x60) >> 3) -#define GAFR(x) __REG2(0x40E00054, ((x) & 0x70) >> 2) - -#endif - /* GPIO alternate function assignments */
#define GPIO1_RST 1 /* reset */ @@ -1732,63 +2063,63 @@ typedef void (*ExcpHndlr) (void) ; */ #ifdef CONFIG_CPU_MONAHANS
-#define ASCR __REG(0x40F40000) /* Application Subsystem Power Status/Control Register */ -#define ARSR __REG(0x40F40004) /* Application Subsystem Reset Status Register */ -#define AD3ER __REG(0x40F40008) /* Application Subsystem D3 state Wakeup Enable Register */ -#define AD3SR __REG(0x40F4000C) /* Application Subsystem D3 state Wakeup Status Register */ -#define AD2D0ER __REG(0x40F40010) /* Application Subsystem D2 to D0 state Wakeup Enable Register */ -#define AD2D0SR __REG(0x40F40014) /* Application Subsystem D2 to D0 state Wakeup Status Register */ -#define AD2D1ER __REG(0x40F40018) /* Application Subsystem D2 to D1 state Wakeup Enable Register */ -#define AD2D1SR __REG(0x40F4001C) /* Application Subsystem D2 to D1 state Wakeup Status Register */ -#define AD1D0ER __REG(0x40F40020) /* Application Subsystem D1 to D0 state Wakeup Enable Register */ -#define AD1D0SR __REG(0x40F40024) /* Application Subsystem D1 to D0 state Wakeup Status Register */ -#define ASDCNT __REG(0x40F40028) /* Application Subsystem SRAM Drowsy Count Register */ -#define AD3R __REG(0x40F40030) /* Application Subsystem D3 State Configuration Register */ -#define AD2R __REG(0x40F40034) /* Application Subsystem D2 State Configuration Register */ -#define AD1R __REG(0x40F40038) /* Application Subsystem D1 State Configuration Register */ - -#define PMCR __REG(0x40F50000) /* Power Manager Control Register */ -#define PSR __REG(0x40F50004) /* Power Manager S2 Status Register */ -#define PSPR __REG(0x40F50008) /* Power Manager Scratch Pad Register */ -#define PCFR __REG(0x40F5000C) /* Power Manager General Configuration Register */ -#define PWER __REG(0x40F50010) /* Power Manager Wake-up Enable Register */ -#define PWSR __REG(0x40F50014) /* Power Manager Wake-up Status Register */ -#define PECR __REG(0x40F50018) /* Power Manager EXT_WAKEUP[1:0] Control Register */ -#define DCDCSR __REG(0x40F50080) /* DC-DC Controller Status Register */ -#define PVCR __REG(0x40F50100) /* Power Manager Voltage Change Control Register */ -#define PCMD(x) __REG(0x40F50110 + x*4) -#define PCMD0 __REG(0x40F50110 + 0 * 4) -#define PCMD1 __REG(0x40F50110 + 1 * 4) -#define PCMD2 __REG(0x40F50110 + 2 * 4) -#define PCMD3 __REG(0x40F50110 + 3 * 4) -#define PCMD4 __REG(0x40F50110 + 4 * 4) -#define PCMD5 __REG(0x40F50110 + 5 * 4) -#define PCMD6 __REG(0x40F50110 + 6 * 4) -#define PCMD7 __REG(0x40F50110 + 7 * 4) -#define PCMD8 __REG(0x40F50110 + 8 * 4) -#define PCMD9 __REG(0x40F50110 + 9 * 4) -#define PCMD10 __REG(0x40F50110 + 10 * 4) -#define PCMD11 __REG(0x40F50110 + 11 * 4) -#define PCMD12 __REG(0x40F50110 + 12 * 4) -#define PCMD13 __REG(0x40F50110 + 13 * 4) -#define PCMD14 __REG(0x40F50110 + 14 * 4) -#define PCMD15 __REG(0x40F50110 + 15 * 4) -#define PCMD16 __REG(0x40F50110 + 16 * 4) -#define PCMD17 __REG(0x40F50110 + 17 * 4) -#define PCMD18 __REG(0x40F50110 + 18 * 4) -#define PCMD19 __REG(0x40F50110 + 19 * 4) -#define PCMD20 __REG(0x40F50110 + 20 * 4) -#define PCMD21 __REG(0x40F50110 + 21 * 4) -#define PCMD22 __REG(0x40F50110 + 22 * 4) -#define PCMD23 __REG(0x40F50110 + 23 * 4) -#define PCMD24 __REG(0x40F50110 + 24 * 4) -#define PCMD25 __REG(0x40F50110 + 25 * 4) -#define PCMD26 __REG(0x40F50110 + 26 * 4) -#define PCMD27 __REG(0x40F50110 + 27 * 4) -#define PCMD28 __REG(0x40F50110 + 28 * 4) -#define PCMD29 __REG(0x40F50110 + 29 * 4) -#define PCMD30 __REG(0x40F50110 + 30 * 4) -#define PCMD31 __REG(0x40F50110 + 31 * 4) +#define ASCR (0x40F40000) /* Application Subsystem Power Status/Control Register */ +#define ARSR (0x40F40004) /* Application Subsystem Reset Status Register */ +#define AD3ER (0x40F40008) /* Application Subsystem D3 state Wakeup Enable Register */ +#define AD3SR (0x40F4000C) /* Application Subsystem D3 state Wakeup Status Register */ +#define AD2D0ER (0x40F40010) /* Application Subsystem D2 to D0 state Wakeup Enable Register */ +#define AD2D0SR (0x40F40014) /* Application Subsystem D2 to D0 state Wakeup Status Register */ +#define AD2D1ER (0x40F40018) /* Application Subsystem D2 to D1 state Wakeup Enable Register */ +#define AD2D1SR (0x40F4001C) /* Application Subsystem D2 to D1 state Wakeup Status Register */ +#define AD1D0ER (0x40F40020) /* Application Subsystem D1 to D0 state Wakeup Enable Register */ +#define AD1D0SR (0x40F40024) /* Application Subsystem D1 to D0 state Wakeup Status Register */ +#define ASDCNT (0x40F40028) /* Application Subsystem SRAM Drowsy Count Register */ +#define AD3R (0x40F40030) /* Application Subsystem D3 State Configuration Register */ +#define AD2R (0x40F40034) /* Application Subsystem D2 State Configuration Register */ +#define AD1R (0x40F40038) /* Application Subsystem D1 State Configuration Register */ + +#define PMCR (0x40F50000) /* Power Manager Control Register */ +#define PSR (0x40F50004) /* Power Manager S2 Status Register */ +#define PSPR (0x40F50008) /* Power Manager Scratch Pad Register */ +#define PCFR (0x40F5000C) /* Power Manager General Configuration Register */ +#define PWER (0x40F50010) /* Power Manager Wake-up Enable Register */ +#define PWSR (0x40F50014) /* Power Manager Wake-up Status Register */ +#define PECR (0x40F50018) /* Power Manager EXT_WAKEUP[1:0] Control Register */ +#define DCDCSR (0x40F50080) /* DC-DC Controller Status Register */ +#define PVCR (0x40F50100) /* Power Manager Voltage Change Control Register */ +#define PCMD(x) (0x40F50110 + x*4) +#define PCMD0 (0x40F50110 + 0 * 4) +#define PCMD1 (0x40F50110 + 1 * 4) +#define PCMD2 (0x40F50110 + 2 * 4) +#define PCMD3 (0x40F50110 + 3 * 4) +#define PCMD4 (0x40F50110 + 4 * 4) +#define PCMD5 (0x40F50110 + 5 * 4) +#define PCMD6 (0x40F50110 + 6 * 4) +#define PCMD7 (0x40F50110 + 7 * 4) +#define PCMD8 (0x40F50110 + 8 * 4) +#define PCMD9 (0x40F50110 + 9 * 4) +#define PCMD10 (0x40F50110 + 10 * 4) +#define PCMD11 (0x40F50110 + 11 * 4) +#define PCMD12 (0x40F50110 + 12 * 4) +#define PCMD13 (0x40F50110 + 13 * 4) +#define PCMD14 (0x40F50110 + 14 * 4) +#define PCMD15 (0x40F50110 + 15 * 4) +#define PCMD16 (0x40F50110 + 16 * 4) +#define PCMD17 (0x40F50110 + 17 * 4) +#define PCMD18 (0x40F50110 + 18 * 4) +#define PCMD19 (0x40F50110 + 19 * 4) +#define PCMD20 (0x40F50110 + 20 * 4) +#define PCMD21 (0x40F50110 + 21 * 4) +#define PCMD22 (0x40F50110 + 22 * 4) +#define PCMD23 (0x40F50110 + 23 * 4) +#define PCMD24 (0x40F50110 + 24 * 4) +#define PCMD25 (0x40F50110 + 25 * 4) +#define PCMD26 (0x40F50110 + 26 * 4) +#define PCMD27 (0x40F50110 + 27 * 4) +#define PCMD28 (0x40F50110 + 28 * 4) +#define PCMD29 (0x40F50110 + 29 * 4) +#define PCMD30 (0x40F50110 + 30 * 4) +#define PCMD31 (0x40F50110 + 31 * 4)
#define PCMD_MBC (1<<12) #define PCMD_DCE (1<<11) @@ -1803,59 +2134,59 @@ typedef void (*ExcpHndlr) (void) ;
#else /* ifdef CONFIG_CPU_MONAHANS */
-#define PMCR __REG(0x40F00000) /* Power Manager Control Register */ -#define PSSR __REG(0x40F00004) /* Power Manager Sleep Status Register */ -#define PSPR __REG(0x40F00008) /* Power Manager Scratch Pad Register */ -#define PWER __REG(0x40F0000C) /* Power Manager Wake-up Enable Register */ -#define PRER __REG(0x40F00010) /* Power Manager GPIO Rising-Edge Detect Enable Register */ -#define PFER __REG(0x40F00014) /* Power Manager GPIO Falling-Edge Detect Enable Register */ -#define PEDR __REG(0x40F00018) /* Power Manager GPIO Edge Detect Status Register */ -#define PCFR __REG(0x40F0001C) /* Power Manager General Configuration Register */ -#define PGSR0 __REG(0x40F00020) /* Power Manager GPIO Sleep State Register for GP[31-0] */ -#define PGSR1 __REG(0x40F00024) /* Power Manager GPIO Sleep State Register for GP[63-32] */ -#define PGSR2 __REG(0x40F00028) /* Power Manager GPIO Sleep State Register for GP[84-64] */ -#define PGSR3 __REG(0x40F0002C) /* Power Manager GPIO Sleep State Register for GP[118-96] */ -#define RCSR __REG(0x40F00030) /* Reset Controller Status Register */ - -#define PSLR __REG(0x40F00034) /* Power Manager Sleep Config Register */ -#define PSTR __REG(0x40F00038) /* Power Manager Standby Config Register */ -#define PSNR __REG(0x40F0003C) /* Power Manager Sense Config Register */ -#define PVCR __REG(0x40F00040) /* Power Manager VoltageControl Register */ -#define PKWR __REG(0x40F00050) /* Power Manager KB Wake-up Enable Reg */ -#define PKSR __REG(0x40F00054) /* Power Manager KB Level-Detect Register */ -#define PCMD(x) __REG(0x40F00080 + x*4) -#define PCMD0 __REG(0x40F00080 + 0 * 4) -#define PCMD1 __REG(0x40F00080 + 1 * 4) -#define PCMD2 __REG(0x40F00080 + 2 * 4) -#define PCMD3 __REG(0x40F00080 + 3 * 4) -#define PCMD4 __REG(0x40F00080 + 4 * 4) -#define PCMD5 __REG(0x40F00080 + 5 * 4) -#define PCMD6 __REG(0x40F00080 + 6 * 4) -#define PCMD7 __REG(0x40F00080 + 7 * 4) -#define PCMD8 __REG(0x40F00080 + 8 * 4) -#define PCMD9 __REG(0x40F00080 + 9 * 4) -#define PCMD10 __REG(0x40F00080 + 10 * 4) -#define PCMD11 __REG(0x40F00080 + 11 * 4) -#define PCMD12 __REG(0x40F00080 + 12 * 4) -#define PCMD13 __REG(0x40F00080 + 13 * 4) -#define PCMD14 __REG(0x40F00080 + 14 * 4) -#define PCMD15 __REG(0x40F00080 + 15 * 4) -#define PCMD16 __REG(0x40F00080 + 16 * 4) -#define PCMD17 __REG(0x40F00080 + 17 * 4) -#define PCMD18 __REG(0x40F00080 + 18 * 4) -#define PCMD19 __REG(0x40F00080 + 19 * 4) -#define PCMD20 __REG(0x40F00080 + 20 * 4) -#define PCMD21 __REG(0x40F00080 + 21 * 4) -#define PCMD22 __REG(0x40F00080 + 22 * 4) -#define PCMD23 __REG(0x40F00080 + 23 * 4) -#define PCMD24 __REG(0x40F00080 + 24 * 4) -#define PCMD25 __REG(0x40F00080 + 25 * 4) -#define PCMD26 __REG(0x40F00080 + 26 * 4) -#define PCMD27 __REG(0x40F00080 + 27 * 4) -#define PCMD28 __REG(0x40F00080 + 28 * 4) -#define PCMD29 __REG(0x40F00080 + 29 * 4) -#define PCMD30 __REG(0x40F00080 + 30 * 4) -#define PCMD31 __REG(0x40F00080 + 31 * 4) +#define PMCR (0x40F00000) /* Power Manager Control Register */ +#define PSSR (0x40F00004) /* Power Manager Sleep Status Register */ +#define PSPR (0x40F00008) /* Power Manager Scratch Pad Register */ +#define PWER (0x40F0000C) /* Power Manager Wake-up Enable Register */ +#define PRER (0x40F00010) /* Power Manager GPIO Rising-Edge Detect Enable Register */ +#define PFER (0x40F00014) /* Power Manager GPIO Falling-Edge Detect Enable Register */ +#define PEDR (0x40F00018) /* Power Manager GPIO Edge Detect Status Register */ +#define PCFR (0x40F0001C) /* Power Manager General Configuration Register */ +#define PGSR0 (0x40F00020) /* Power Manager GPIO Sleep State Register for GP[31-0] */ +#define PGSR1 (0x40F00024) /* Power Manager GPIO Sleep State Register for GP[63-32] */ +#define PGSR2 (0x40F00028) /* Power Manager GPIO Sleep State Register for GP[84-64] */ +#define PGSR3 (0x40F0002C) /* Power Manager GPIO Sleep State Register for GP[118-96] */ +#define RCSR (0x40F00030) /* Reset Controller Status Register */ + +#define PSLR (0x40F00034) /* Power Manager Sleep Config Register */ +#define PSTR (0x40F00038) /* Power Manager Standby Config Register */ +#define PSNR (0x40F0003C) /* Power Manager Sense Config Register */ +#define PVCR (0x40F00040) /* Power Manager VoltageControl Register */ +#define PKWR (0x40F00050) /* Power Manager KB Wake-up Enable Reg */ +#define PKSR (0x40F00054) /* Power Manager KB Level-Detect Register */ +#define PCMD(x) (0x40F00080 + x*4) +#define PCMD0 (0x40F00080 + 0 * 4) +#define PCMD1 (0x40F00080 + 1 * 4) +#define PCMD2 (0x40F00080 + 2 * 4) +#define PCMD3 (0x40F00080 + 3 * 4) +#define PCMD4 (0x40F00080 + 4 * 4) +#define PCMD5 (0x40F00080 + 5 * 4) +#define PCMD6 (0x40F00080 + 6 * 4) +#define PCMD7 (0x40F00080 + 7 * 4) +#define PCMD8 (0x40F00080 + 8 * 4) +#define PCMD9 (0x40F00080 + 9 * 4) +#define PCMD10 (0x40F00080 + 10 * 4) +#define PCMD11 (0x40F00080 + 11 * 4) +#define PCMD12 (0x40F00080 + 12 * 4) +#define PCMD13 (0x40F00080 + 13 * 4) +#define PCMD14 (0x40F00080 + 14 * 4) +#define PCMD15 (0x40F00080 + 15 * 4) +#define PCMD16 (0x40F00080 + 16 * 4) +#define PCMD17 (0x40F00080 + 17 * 4) +#define PCMD18 (0x40F00080 + 18 * 4) +#define PCMD19 (0x40F00080 + 19 * 4) +#define PCMD20 (0x40F00080 + 20 * 4) +#define PCMD21 (0x40F00080 + 21 * 4) +#define PCMD22 (0x40F00080 + 22 * 4) +#define PCMD23 (0x40F00080 + 23 * 4) +#define PCMD24 (0x40F00080 + 24 * 4) +#define PCMD25 (0x40F00080 + 25 * 4) +#define PCMD26 (0x40F00080 + 26 * 4) +#define PCMD27 (0x40F00080 + 27 * 4) +#define PCMD28 (0x40F00080 + 28 * 4) +#define PCMD29 (0x40F00080 + 29 * 4) +#define PCMD30 (0x40F00080 + 30 * 4) +#define PCMD31 (0x40F00080 + 31 * 4)
#define PCMD_MBC (1<<12) #define PCMD_DCE (1<<11) @@ -1891,183 +2222,58 @@ typedef void (*ExcpHndlr) (void) ; /* * SSP Serial Port Registers */ -#define SSCR0 __REG(0x41000000) /* SSP Control Register 0 */ -#define SSCR1 __REG(0x41000004) /* SSP Control Register 1 */ -#define SSSR __REG(0x41000008) /* SSP Status Register */ -#define SSITR __REG(0x4100000C) /* SSP Interrupt Test Register */ -#define SSDR __REG(0x41000010) /* (Write / Read) SSP Data Write Register/SSP Data Read Register */ +#define SSCR0 (0x41000000) /* SSP Control Register 0 */ +#define SSCR1 (0x41000004) /* SSP Control Register 1 */ +#define SSSR (0x41000008) /* SSP Status Register */ +#define SSITR (0x4100000C) /* SSP Interrupt Test Register */ +#define SSDR (0x41000010) /* (Write / Read) SSP Data Write Register/SSP Data Read Register */
/* * MultiMediaCard (MMC) controller */ -#define MMC_STRPCL __REG(0x41100000) /* Control to start and stop MMC clock */ -#define MMC_STAT __REG(0x41100004) /* MMC Status Register (read only) */ -#define MMC_CLKRT __REG(0x41100008) /* MMC clock rate */ -#define MMC_SPI __REG(0x4110000c) /* SPI mode control bits */ -#define MMC_CMDAT __REG(0x41100010) /* Command/response/data sequence control */ -#define MMC_RESTO __REG(0x41100014) /* Expected response time out */ -#define MMC_RDTO __REG(0x41100018) /* Expected data read time out */ -#define MMC_BLKLEN __REG(0x4110001c) /* Block length of data transaction */ -#define MMC_NOB __REG(0x41100020) /* Number of blocks, for block mode */ -#define MMC_PRTBUF __REG(0x41100024) /* Partial MMC_TXFIFO FIFO written */ -#define MMC_I_MASK __REG(0x41100028) /* Interrupt Mask */ -#define MMC_I_REG __REG(0x4110002c) /* Interrupt Register (read only) */ -#define MMC_CMD __REG(0x41100030) /* Index of current command */ -#define MMC_ARGH __REG(0x41100034) /* MSW part of the current command argument */ -#define MMC_ARGL __REG(0x41100038) /* LSW part of the current command argument */ -#define MMC_RES __REG(0x4110003c) /* Response FIFO (read only) */ -#define MMC_RXFIFO __REG(0x41100040) /* Receive FIFO (read only) */ -#define MMC_TXFIFO __REG(0x41100044) /* Transmit FIFO (write only) */ - -/* - * Core Clock - */ - -#if defined(CONFIG_CPU_MONAHANS) -#define ACCR __REG(0x41340000) /* Application Subsystem Clock Configuration Register */ -#define ACSR __REG(0x41340004) /* Application Subsystem Clock Status Register */ -#define AICSR __REG(0x41340008) /* Application Subsystem Interrupt Control/Status Register */ -#define CKENA __REG(0x4134000C) /* A Clock Enable Register */ -#define CKENB __REG(0x41340010) /* B Clock Enable Register */ -#define AC97_DIV __REG(0x41340014) /* AC97 clock divisor value register */ - -#define ACCR_SMC_MASK 0x03800000 /* Static Memory Controller Frequency Select */ -#define ACCR_SRAM_MASK 0x000c0000 /* SRAM Controller Frequency Select */ -#define ACCR_FC_MASK 0x00030000 /* Frequency Change Frequency Select */ -#define ACCR_HSIO_MASK 0x0000c000 /* High Speed IO Frequency Select */ -#define ACCR_DDR_MASK 0x00003000 /* DDR Memory Controller Frequency Select */ -#define ACCR_XN_MASK 0x00000700 /* Run Mode Frequency to Turbo Mode Frequency Multiplier */ -#define ACCR_XL_MASK 0x0000001f /* Crystal Frequency to Memory Frequency Multiplier */ -#define ACCR_XPDIS (1 << 31) -#define ACCR_SPDIS (1 << 30) -#define ACCR_13MEND1 (1 << 27) -#define ACCR_D0CS (1 << 26) -#define ACCR_13MEND2 (1 << 21) -#define ACCR_PCCE (1 << 11) - -#define CKENA_30_MSL0 (1 << 30) /* MSL0 Interface Unit Clock Enable */ -#define CKENA_29_SSP4 (1 << 29) /* SSP3 Unit Clock Enable */ -#define CKENA_28_SSP3 (1 << 28) /* SSP2 Unit Clock Enable */ -#define CKENA_27_SSP2 (1 << 27) /* SSP1 Unit Clock Enable */ -#define CKENA_26_SSP1 (1 << 26) /* SSP0 Unit Clock Enable */ -#define CKENA_25_TSI (1 << 25) /* TSI Clock Enable */ -#define CKENA_24_AC97 (1 << 24) /* AC97 Unit Clock Enable */ -#define CKENA_23_STUART (1 << 23) /* STUART Unit Clock Enable */ -#define CKENA_22_FFUART (1 << 22) /* FFUART Unit Clock Enable */ -#define CKENA_21_BTUART (1 << 21) /* BTUART Unit Clock Enable */ -#define CKENA_20_UDC (1 << 20) /* UDC Clock Enable */ -#define CKENA_19_TPM (1 << 19) /* TPM Unit Clock Enable */ -#define CKENA_18_USIM1 (1 << 18) /* USIM1 Unit Clock Enable */ -#define CKENA_17_USIM0 (1 << 17) /* USIM0 Unit Clock Enable */ -#define CKENA_15_CIR (1 << 15) /* Consumer IR Clock Enable */ -#define CKENA_14_KEY (1 << 14) /* Keypad Controller Clock Enable */ -#define CKENA_13_MMC1 (1 << 13) /* MMC1 Clock Enable */ -#define CKENA_12_MMC0 (1 << 12) /* MMC0 Clock Enable */ -#define CKENA_11_FLASH (1 << 11) /* Boot ROM Clock Enable */ -#define CKENA_10_SRAM (1 << 10) /* SRAM Controller Clock Enable */ -#define CKENA_9_SMC (1 << 9) /* Static Memory Controller */ -#define CKENA_8_DMC (1 << 8) /* Dynamic Memory Controller */ -#define CKENA_7_GRAPHICS (1 << 7) /* 2D Graphics Clock Enable */ -#define CKENA_6_USBCLI (1 << 6) /* USB Client Unit Clock Enable */ -#define CKENA_4_NAND (1 << 4) /* NAND Flash Controller Clock Enable */ -#define CKENA_3_CAMERA (1 << 3) /* Camera Interface Clock Enable */ -#define CKENA_2_USBHOST (1 << 2) /* USB Host Unit Clock Enable */ -#define CKENA_1_LCD (1 << 1) /* LCD Unit Clock Enable */ - -#define CKENB_9_SYSBUS2 (1 << 9) /* System bus 2 */ -#define CKENB_8_1WIRE (1 << 8) /* One Wire Interface Unit Clock Enable */ -#define CKENB_7_GPIO (1 << 7) /* GPIO Clock Enable */ -#define CKENB_6_IRQ (1 << 6) /* Interrupt Controller Clock Enable */ -#define CKENB_4_I2C (1 << 4) /* I2C Unit Clock Enable */ -#define CKENB_1_PWM1 (1 << 1) /* PWM2 & PWM3 Clock Enable */ -#define CKENB_0_PWM0 (1 << 0) /* PWM0 & PWM1 Clock Enable */ - -#else /* if defined CONFIG_CPU_MONAHANS */ - -#define CCCR __REG(0x41300000) /* Core Clock Configuration Register */ -#define CKEN __REG(0x41300004) /* Clock Enable Register */ -#define OSCC __REG(0x41300008) /* Oscillator Configuration Register */ - -#define CCCR_N_MASK 0x0380 /* Run Mode Frequency to Turbo Mode Frequency Multiplier */ -#if !defined(CONFIG_PXA27X) -#define CCCR_M_MASK 0x0060 /* Memory Frequency to Run Mode Frequency Multiplier */ -#endif -#define CCCR_L_MASK 0x001f /* Crystal Frequency to Memory Frequency Multiplier */ - -#define CKEN24_CAMERA (1 << 24) /* Camera Interface Clock Enable */ -#define CKEN23_SSP1 (1 << 23) /* SSP1 Unit Clock Enable */ -#define CKEN22_MEMC (1 << 22) /* Memory Controller Clock Enable */ -#define CKEN21_MEMSTK (1 << 21) /* Memory Stick Host Controller */ -#define CKEN20_IM (1 << 20) /* Internal Memory Clock Enable */ -#define CKEN19_KEYPAD (1 << 19) /* Keypad Interface Clock Enable */ -#define CKEN18_USIM (1 << 18) /* USIM Unit Clock Enable */ -#define CKEN17_MSL (1 << 17) /* MSL Unit Clock Enable */ -#define CKEN16_LCD (1 << 16) /* LCD Unit Clock Enable */ -#define CKEN15_PWRI2C (1 << 15) /* PWR I2C Unit Clock Enable */ -#define CKEN14_I2C (1 << 14) /* I2C Unit Clock Enable */ -#define CKEN13_FICP (1 << 13) /* FICP Unit Clock Enable */ -#define CKEN12_MMC (1 << 12) /* MMC Unit Clock Enable */ -#define CKEN11_USB (1 << 11) /* USB Unit Clock Enable */ -#if defined(CONFIG_PXA27X) -#define CKEN10_USBHOST (1 << 10) /* USB Host Unit Clock Enable */ -#define CKEN24_CAMERA (1 << 24) /* Camera Unit Clock Enable */ -#endif -#define CKEN8_I2S (1 << 8) /* I2S Unit Clock Enable */ -#define CKEN7_BTUART (1 << 7) /* BTUART Unit Clock Enable */ -#define CKEN6_FFUART (1 << 6) /* FFUART Unit Clock Enable */ -#define CKEN5_STUART (1 << 5) /* STUART Unit Clock Enable */ -#define CKEN3_SSP (1 << 3) /* SSP Unit Clock Enable */ -#define CKEN2_AC97 (1 << 2) /* AC97 Unit Clock Enable */ -#define CKEN1_PWM1 (1 << 1) /* PWM1 Clock Enable */ -#define CKEN0_PWM0 (1 << 0) /* PWM0 Clock Enable */ +#define MMC_STRPCL (0x41100000) /* Control to start and stop MMC clock */ +#define MMC_STAT (0x41100004) /* MMC Status Register (read only) */ +#define MMC_CLKRT (0x41100008) /* MMC clock rate */ +#define MMC_SPI (0x4110000c) /* SPI mode control bits */ +#define MMC_CMDAT (0x41100010) /* Command/response/data sequence control */ +#define MMC_RESTO (0x41100014) /* Expected response time out */ +#define MMC_RDTO (0x41100018) /* Expected data read time out */ +#define MMC_BLKLEN (0x4110001c) /* Block length of data transaction */ +#define MMC_NOB (0x41100020) /* Number of blocks, for block mode */ +#define MMC_PRTBUF (0x41100024) /* Partial MMC_TXFIFO FIFO written */ +#define MMC_I_MASK (0x41100028) /* Interrupt Mask */ +#define MMC_I_REG (0x4110002c) /* Interrupt Register (read only) */ +#define MMC_CMD (0x41100030) /* Index of current command */ +#define MMC_ARGH (0x41100034) /* MSW part of the current command argument */ +#define MMC_ARGL (0x41100038) /* LSW part of the current command argument */ +#define MMC_RES (0x4110003c) /* Response FIFO (read only) */ +#define MMC_RXFIFO (0x41100040) /* Receive FIFO (read only) */ +#define MMC_TXFIFO (0x41100044) /* Transmit FIFO (write only) */
-#define OSCC_OON (1 << 1) /* 32.768kHz OON (write-once only bit) */ -#define OSCC_OOK (1 << 0) /* 32.768kHz OOK (read-only bit) */ - -#if !defined(CONFIG_PXA27X) -#define CCCR_L09 (0x1F) -#define CCCR_L27 (0x1) -#define CCCR_L32 (0x2) -#define CCCR_L36 (0x3) -#define CCCR_L40 (0x4) -#define CCCR_L45 (0x5) - -#define CCCR_M1 (0x1 << 5) -#define CCCR_M2 (0x2 << 5) -#define CCCR_M4 (0x3 << 5) - -#define CCCR_N10 (0x2 << 7) -#define CCCR_N15 (0x3 << 7) -#define CCCR_N20 (0x4 << 7) -#define CCCR_N25 (0x5 << 7) -#define CCCR_N30 (0x6 << 7) -#endif - -#endif /* CONFIG_CPU_MONAHANS */
/* * LCD */ -#define LCCR0 __REG(0x44000000) /* LCD Controller Control Register 0 */ -#define LCCR1 __REG(0x44000004) /* LCD Controller Control Register 1 */ -#define LCCR2 __REG(0x44000008) /* LCD Controller Control Register 2 */ -#define LCCR3 __REG(0x4400000C) /* LCD Controller Control Register 3 */ -#define DFBR0 __REG(0x44000020) /* DMA Channel 0 Frame Branch Register */ -#define DFBR1 __REG(0x44000024) /* DMA Channel 1 Frame Branch Register */ -#define LCSR0 __REG(0x44000038) /* LCD Controller Status Register */ -#define LCSR1 __REG(0x44000034) /* LCD Controller Status Register */ -#define LIIDR __REG(0x4400003C) /* LCD Controller Interrupt ID Register */ -#define TMEDRGBR __REG(0x44000040) /* TMED RGB Seed Register */ -#define TMEDCR __REG(0x44000044) /* TMED Control Register */ - -#define FDADR0 __REG(0x44000200) /* DMA Channel 0 Frame Descriptor Address Register */ -#define FSADR0 __REG(0x44000204) /* DMA Channel 0 Frame Source Address Register */ -#define FIDR0 __REG(0x44000208) /* DMA Channel 0 Frame ID Register */ -#define LDCMD0 __REG(0x4400020C) /* DMA Channel 0 Command Register */ -#define FDADR1 __REG(0x44000210) /* DMA Channel 1 Frame Descriptor Address Register */ -#define FSADR1 __REG(0x44000214) /* DMA Channel 1 Frame Source Address Register */ -#define FIDR1 __REG(0x44000218) /* DMA Channel 1 Frame ID Register */ -#define LDCMD1 __REG(0x4400021C) /* DMA Channel 1 Command Register */ +#define LCCR0 (0x44000000) /* LCD Controller Control Register 0 */ +#define LCCR1 (0x44000004) /* LCD Controller Control Register 1 */ +#define LCCR2 (0x44000008) /* LCD Controller Control Register 2 */ +#define LCCR3 (0x4400000C) /* LCD Controller Control Register 3 */ +#define DFBR0 (0x44000020) /* DMA Channel 0 Frame Branch Register */ +#define DFBR1 (0x44000024) /* DMA Channel 1 Frame Branch Register */ +#define LCSR0 (0x44000038) /* LCD Controller Status Register */ +#define LCSR1 (0x44000034) /* LCD Controller Status Register */ +#define LIIDR (0x4400003C) /* LCD Controller Interrupt ID Register */ +#define TMEDRGBR (0x44000040) /* TMED RGB Seed Register */ +#define TMEDCR (0x44000044) /* TMED Control Register */ + +#define FDADR0 (0x44000200) /* DMA Channel 0 Frame Descriptor Address Register */ +#define FSADR0 (0x44000204) /* DMA Channel 0 Frame Source Address Register */ +#define FIDR0 (0x44000208) /* DMA Channel 0 Frame ID Register */ +#define LDCMD0 (0x4400020C) /* DMA Channel 0 Command Register */ +#define FDADR1 (0x44000210) /* DMA Channel 1 Frame Descriptor Address Register */ +#define FSADR1 (0x44000214) /* DMA Channel 1 Frame Source Address Register */ +#define FIDR1 (0x44000218) /* DMA Channel 1 Frame ID Register */ +#define LDCMD1 (0x4400021C) /* DMA Channel 1 Command Register */
#define LCCR0_ENB (1 << 0) /* LCD Controller enable */ #define LCCR0_CMS (1 << 1) /* Color = 0, Monochrome = 1 */ @@ -2231,46 +2437,49 @@ typedef void (*ExcpHndlr) (void) ; */
#ifdef CONFIG_CPU_MONAHANS + +/* PXA3xx */ + /* Static Memory Controller Registers */ -#define MSC0 __REG_2(0x4A000008) /* Static Memory Control Register 0 */ -#define MSC1 __REG_2(0x4A00000C) /* Static Memory Control Register 1 */ -#define MECR __REG_2(0x4A000014) /* Expansion Memory (PCMCIA/Compact Flash) Bus Configuration */ -#define SXCNFG __REG_2(0x4A00001C) /* Synchronous Static Memory Control Register */ -#define MCMEM0 __REG_2(0x4A000028) /* Card interface Common Memory Space Socket 0 Timing */ -#define MCATT0 __REG_2(0x4A000030) /* Card interface Attribute Space Socket 0 Timing Configuration */ -#define MCIO0 __REG_2(0x4A000038) /* Card interface I/O Space Socket 0 Timing Configuration */ -#define MEMCLKCFG __REG_2(0x4A000068) /* SCLK speed configuration */ -#define CSADRCFG0 __REG_2(0x4A000080) /* Address Configuration for chip select 0 */ -#define CSADRCFG1 __REG_2(0x4A000084) /* Address Configuration for chip select 1 */ -#define CSADRCFG2 __REG_2(0x4A000088) /* Address Configuration for chip select 2 */ -#define CSADRCFG3 __REG_2(0x4A00008C) /* Address Configuration for chip select 3 */ -#define CSADRCFG_P __REG_2(0x4A000090) /* Address Configuration for pcmcia card interface */ -#define CSMSADRCFG __REG_2(0x4A0000A0) /* Master Address Configuration Register */ -#define CLK_RET_DEL __REG_2(0x4A0000B0) /* Delay line and mux selects for return data latching for sync. flash */ -#define ADV_RET_DEL __REG_2(0x4A0000B4) /* Delay line and mux selects for return data latching for sync. flash */ +#define MSC0 (0x4A000008) /* Static Memory Control Register 0 */ +#define MSC1 (0x4A00000C) /* Static Memory Control Register 1 */ +#define MECR (0x4A000014) /* Expansion Memory (PCMCIA/Compact Flash) Bus Configuration */ +#define SXCNFG (0x4A00001C) /* Synchronous Static Memory Control Register */ +#define MCMEM0 (0x4A000028) /* Card interface Common Memory Space Socket 0 Timing */ +#define MCATT0 (0x4A000030) /* Card interface Attribute Space Socket 0 Timing Configuration */ +#define MCIO0 (0x4A000038) /* Card interface I/O Space Socket 0 Timing Configuration */ +#define MEMCLKCFG (0x4A000068) /* SCLK speed configuration */ +#define CSADRCFG0 (0x4A000080) /* Address Configuration for chip select 0 */ +#define CSADRCFG1 (0x4A000084) /* Address Configuration for chip select 1 */ +#define CSADRCFG2 (0x4A000088) /* Address Configuration for chip select 2 */ +#define CSADRCFG3 (0x4A00008C) /* Address Configuration for chip select 3 */ +#define CSADRCFG_P (0x4A000090) /* Address Configuration for pcmcia card interface */ +#define CSMSADRCFG (0x4A0000A0) /* Master Address Configuration Register */ +#define CLK_RET_DEL (0x4A0000B0) /* Delay line and mux selects for return data latching for sync. flash */ +#define ADV_RET_DEL (0x4A0000B4) /* Delay line and mux selects for return data latching for sync. flash */
/* Dynamic Memory Controller Registers */ -#define MDCNFG __REG_2(0x48100000) /* SDRAM Configuration Register 0 */ -#define MDREFR __REG_2(0x48100004) /* SDRAM Refresh Control Register */ -#define FLYCNFG __REG_2(0x48100020) /* Fly-by DMA DVAL[1:0] polarities */ -#define MDMRS __REG_2(0x48100040) /* MRS value to be written to SDRAM */ -#define DDR_SCAL __REG_2(0x48100050) /* Software Delay Line Calibration/Configuration for external DDR memory. */ -#define DDR_HCAL __REG_2(0x48100060) /* Hardware Delay Line Calibration/Configuration for external DDR memory. */ -#define DDR_WCAL __REG_2(0x48100068) /* DDR Write Strobe Calibration Register */ -#define DMCIER __REG_2(0x48100070) /* Dynamic MC Interrupt Enable Register. */ -#define DMCISR __REG_2(0x48100078) /* Dynamic MC Interrupt Status Register. */ -#define DDR_DLS __REG_2(0x48100080) /* DDR Delay Line Value Status register for external DDR memory. */ -#define EMPI __REG_2(0x48100090) /* EMPI Control Register */ -#define RCOMP __REG_2(0x48100100) -#define PAD_MA __REG_2(0x48100110) -#define PAD_MDMSB __REG_2(0x48100114) -#define PAD_MDLSB __REG_2(0x48100118) -#define PAD_DMEM __REG_2(0x4810011c) -#define PAD_SDCLK __REG_2(0x48100120) -#define PAD_SDCS __REG_2(0x48100124) -#define PAD_SMEM __REG_2(0x48100128) -#define PAD_SCLK __REG_2(0x4810012C) -#define TAI __REG_2(0x48100F00) /* TAI Tavor Address Isolation Register */ +#define MDCNFG (0x48100000) /* SDRAM Configuration Register 0 */ +#define MDREFR (0x48100004) /* SDRAM Refresh Control Register */ +#define FLYCNFG (0x48100020) /* Fly-by DMA DVAL[1:0] polarities */ +#define MDMRS (0x48100040) /* MRS value to be written to SDRAM */ +#define DDR_SCAL (0x48100050) /* Software Delay Line Calibration/Configuration for external DDR memory. */ +#define DDR_HCAL (0x48100060) /* Hardware Delay Line Calibration/Configuration for external DDR memory. */ +#define DDR_WCAL (0x48100068) /* DDR Write Strobe Calibration Register */ +#define DMCIER (0x48100070) /* Dynamic MC Interrupt Enable Register. */ +#define DMCISR (0x48100078) /* Dynamic MC Interrupt Status Register. */ +#define DDR_DLS (0x48100080) /* DDR Delay Line Value Status register for external DDR memory. */ +#define EMPI (0x48100090) /* EMPI Control Register */ +#define RCOMP (0x48100100) +#define PAD_MA (0x48100110) +#define PAD_MDMSB (0x48100114) +#define PAD_MDLSB (0x48100118) +#define PAD_DMEM (0x4810011c) +#define PAD_SDCLK (0x48100120) +#define PAD_SDCS (0x48100124) +#define PAD_SMEM (0x48100128) +#define PAD_SCLK (0x4810012C) +#define TAI (0x48100F00) /* TAI Tavor Address Isolation Register */
/* Some frequently used bits */ #define MDCNFG_DMAP 0x80000000 /* SDRAM 1GB Memory Map Enable */ @@ -2298,19 +2507,19 @@ typedef void (*ExcpHndlr) (void) ;
/* Data Flash Controller Registers */
-#define NDCR __REG(0x43100000) /* Data Flash Control register */ -#define NDTR0CS0 __REG(0x43100004) /* Data Controller Timing Parameter 0 Register for ND_nCS0 */ -/* #define NDTR0CS1 __REG(0x43100008) /* Data Controller Timing Parameter 0 Register for ND_nCS1 */ */ -#define NDTR1CS0 __REG(0x4310000C) /* Data Controller Timing Parameter 1 Register for ND_nCS0 */ -/* #define NDTR1CS1 __REG(0x43100010) /* Data Controller Timing Parameter 1 Register for ND_nCS1 */ */ -#define NDSR __REG(0x43100014) /* Data Controller Status Register */ -#define NDPCR __REG(0x43100018) /* Data Controller Page Count Register */ -#define NDBDR0 __REG(0x4310001C) /* Data Controller Bad Block Register 0 */ -#define NDBDR1 __REG(0x43100020) /* Data Controller Bad Block Register 1 */ -#define NDDB __REG(0x43100040) /* Data Controller Data Buffer */ -#define NDCB0 __REG(0x43100048) /* Data Controller Command Buffer0 */ -#define NDCB1 __REG(0x4310004C) /* Data Controller Command Buffer1 */ -#define NDCB2 __REG(0x43100050) /* Data Controller Command Buffer2 */ +#define NDCR (0x43100000) /* Data Flash Control register */ +#define NDTR0CS0 (0x43100004) /* Data Controller Timing Parameter 0 Register for ND_nCS0 */ +/* #define NDTR0CS1 (0x43100008) /* Data Controller Timing Parameter 0 Register for ND_nCS1 */ */ +#define NDTR1CS0 (0x4310000C) /* Data Controller Timing Parameter 1 Register for ND_nCS0 */ +/* #define NDTR1CS1 (0x43100010) /* Data Controller Timing Parameter 1 Register for ND_nCS1 */ */ +#define NDSR (0x43100014) /* Data Controller Status Register */ +#define NDPCR (0x43100018) /* Data Controller Page Count Register */ +#define NDBDR0 (0x4310001C) /* Data Controller Bad Block Register 0 */ +#define NDBDR1 (0x43100020) /* Data Controller Bad Block Register 1 */ +#define NDDB (0x43100040) /* Data Controller Data Buffer */ +#define NDCB0 (0x43100048) /* Data Controller Command Buffer0 */ +#define NDCB1 (0x4310004C) /* Data Controller Command Buffer1 */ +#define NDCB2 (0x43100050) /* Data Controller Command Buffer2 */
#define NDCR_SPARE_EN (0x1<<31) #define NDCR_ECC_EN (0x1<<30) @@ -2386,7 +2595,9 @@ typedef void (*ExcpHndlr) (void) ;
-#define MEMC_BASE __REG(0x48000000) /* Base of Memory Controller */ +/* PXA2xx */ + +#define MEMC_BASE (0x48000000) /* Base of Memory Controller */ #define MDCNFG_OFFSET 0x0 #define MDREFR_OFFSET 0x4 #define MSC0_OFFSET 0x8 @@ -2405,29 +2616,29 @@ typedef void (*ExcpHndlr) (void) ; #define MCIO1_OFFSET 0x3C #define MDMRS_OFFSET 0x40
-#define MDCNFG __REG(0x48000000) /* SDRAM Configuration Register 0 */ +#define MDCNFG (0x48000000) /* SDRAM Configuration Register 0 */ #define MDCNFG_DE0 0x00000001 #define MDCNFG_DE1 0x00000002 #define MDCNFG_DE2 0x00010000 #define MDCNFG_DE3 0x00020000 #define MDCNFG_DWID0 0x00000004
-#define MDREFR __REG(0x48000004) /* SDRAM Refresh Control Register */ -#define MSC0 __REG(0x48000008) /* Static Memory Control Register 0 */ -#define MSC1 __REG(0x4800000C) /* Static Memory Control Register 1 */ -#define MSC2 __REG(0x48000010) /* Static Memory Control Register 2 */ -#define MECR __REG(0x48000014) /* Expansion Memory (PCMCIA/Compact Flash) Bus Configuration */ -#define SXLCR __REG(0x48000018) /* LCR value to be written to SDRAM-Timing Synchronous Flash */ -#define SXCNFG __REG(0x4800001C) /* Synchronous Static Memory Control Register */ -#define SXMRS __REG(0x48000024) /* MRS value to be written to Synchronous Flash or SMROM */ -#define MCMEM0 __REG(0x48000028) /* Card interface Common Memory Space Socket 0 Timing */ -#define MCMEM1 __REG(0x4800002C) /* Card interface Common Memory Space Socket 1 Timing */ -#define MCATT0 __REG(0x48000030) /* Card interface Attribute Space Socket 0 Timing Configuration */ -#define MCATT1 __REG(0x48000034) /* Card interface Attribute Space Socket 1 Timing Configuration */ -#define MCIO0 __REG(0x48000038) /* Card interface I/O Space Socket 0 Timing Configuration */ -#define MCIO1 __REG(0x4800003C) /* Card interface I/O Space Socket 1 Timing Configuration */ -#define MDMRS __REG(0x48000040) /* MRS value to be written to SDRAM */ -#define BOOT_DEF __REG(0x48000044) /* Read-Only Boot-Time Register. Contains BOOT_SEL and PKG_SEL */ +#define MDREFR (0x48000004) /* SDRAM Refresh Control Register */ +#define MSC0 (0x48000008) /* Static Memory Control Register 0 */ +#define MSC1 (0x4800000C) /* Static Memory Control Register 1 */ +#define MSC2 (0x48000010) /* Static Memory Control Register 2 */ +#define MECR (0x48000014) /* Expansion Memory (PCMCIA/Compact Flash) Bus Configuration */ +#define SXLCR (0x48000018) /* LCR value to be written to SDRAM-Timing Synchronous Flash */ +#define SXCNFG (0x4800001C) /* Synchronous Static Memory Control Register */ +#define SXMRS (0x48000024) /* MRS value to be written to Synchronous Flash or SMROM */ +#define MCMEM0 (0x48000028) /* Card interface Common Memory Space Socket 0 Timing */ +#define MCMEM1 (0x4800002C) /* Card interface Common Memory Space Socket 1 Timing */ +#define MCATT0 (0x48000030) /* Card interface Attribute Space Socket 0 Timing Configuration */ +#define MCATT1 (0x48000034) /* Card interface Attribute Space Socket 1 Timing Configuration */ +#define MCIO0 (0x48000038) /* Card interface I/O Space Socket 0 Timing Configuration */ +#define MCIO1 (0x4800003C) /* Card interface I/O Space Socket 1 Timing Configuration */ +#define MDMRS (0x48000040) /* MRS value to be written to SDRAM */ +#define BOOT_DEF (0x48000044) /* Read-Only Boot-Time Register. Contains BOOT_SEL and PKG_SEL */
#define MDREFR_ALTREFA (1 << 31) /* Exiting Alternate Bus Master Mode Refresh Control */ #define MDREFR_ALTREFB (1 << 30) /* Entering Alternate Bus Master Mode Refresh Control */ @@ -2448,7 +2659,7 @@ typedef void (*ExcpHndlr) (void) ;
-#define ARB_CNTRL __REG(0x48000048) /* Arbiter Control Register */ +#define ARB_CNTRL (0x48000048) /* Arbiter Control Register */
#define ARB_DMA_SLV_PARK (1<<31) /* Be parked with DMA slave when idle */ #define ARB_CI_PARK (1<<30) /* Be parked with Camera Interface when idle */ @@ -2460,80 +2671,41 @@ typedef void (*ExcpHndlr) (void) ; #define ARB_CORE_PARK (1<<24) /* Be parked with core when idle */ #define ARB_LOCK_FLAG (1<<23) /* Only Locking masters gain access to the bus */
-#endif /* CONFIG_CPU_MONAHANS */ - -/* Interrupt Controller */ - -#define ICIP2 __REG(0x40D0009C) /* Interrupt Controller IRQ Pending Register 2 */ -#define ICMR2 __REG(0x40D000A0) /* Interrupt Controller Mask Register 2 */ -#define ICLR2 __REG(0x40D000A4) /* Interrupt Controller Level Register 2 */ -#define ICFP2 __REG(0x40D000A8) /* Interrupt Controller FIQ Pending Register 2 */ -#define ICPR2 __REG(0x40D000AC) /* Interrupt Controller Pending Register 2 */ - -/* General Purpose I/O */ - -#define GAFR3_L __REG(0x40E0006C) /* GPIO Alternate Function Select Register GPIO<111:96> */ -#define GAFR3_U __REG(0x40E00070) /* GPIO Alternate Function Select Register GPIO<127:112> */ -#define GPLR3 __REG(0x40E00100) /* GPIO Pin-Level Register GPIO<127:96> */ -#define GPDR3 __REG(0x40E0010C) /* GPIO Pin Direction Register GPIO<127:96> */ -#define GPSR3 __REG(0x40E00118) /* GPIO Pin Output Set Register GPIO<127:96> */ -#define GPCR3 __REG(0x40E00124) /* GPIO Pin Output Clear Register GPIO <127:96> */ -#define GRER3 __REG(0x40E00130) /* GPIO Rising-Edge Detect Register GPIO<127:96> */ -#define GFER3 __REG(0x40E0013C) /* GPIO Falling-Edge Detect Register GPIO<31:0> */ -#define GEDR3 __REG(0x40E00148) /* GPIO Edge Detect Status Register GPIO<127:96> */ - -/* Core Clock */ - -#define CCSR __REG(0x4130000C) /* Core Clock Status Register */ - -#define CKEN23_SSP1 (1 << 23) /* SSP1 Unit Clock Enable */ -#define CKEN22_MEMC (1 << 22) /* Memory Controler */ -#define CKEN21_MSHC (1 << 21) /* Memery Stick Host Controller */ -#define CKEN20_IM (1 << 20) /* Internal Memory Clock Enable */ -#define CKEN19_KEYPAD (1 << 19) /* Keypad Interface Clock Enable */ -#define CKEN18_USIM (1 << 18) /* USIM Unit Clock Enable */ -#define CKEN17_MSL (1 << 17) /* MSL Interface Unit Clock Enable */ -#define CKEN15_PWR_I2C (1 << 15) /* PWR_I2C Unit Clock Enable */ -#define CKEN9_OST (1 << 9) /* OS Timer Unit Clock Enable */ -#define CKEN4_SSP3 (1 << 4) /* SSP3 Unit Clock Enable */ - -/* Memory controller */ - -#define MDREFR_K0DB4 (1 << 29) /* SDCLK[0] divide by 4 */ +#endif /* CONFIG_PXA27X */
/* LCD registers */ -#define LCCR4 __REG(0x44000010) /* LCD Controller Control Register 4 */ -#define LCCR5 __REG(0x44000014) /* LCD Controller Control Register 5 */ -#define FBR0 __REG(0x44000020) /* DMA Channel 0 Frame Branch Register */ -#define FBR1 __REG(0x44000024) /* DMA Channel 1 Frame Branch Register */ -#define FBR2 __REG(0x44000028) /* DMA Channel 2 Frame Branch Register */ -#define FBR3 __REG(0x4400002C) /* DMA Channel 3 Frame Branch Register */ -#define FBR4 __REG(0x44000030) /* DMA Channel 4 Frame Branch Register */ -#define FDADR2 __REG(0x44000220) /* DMA Channel 2 Frame Descriptor Address Register */ -#define FSADR2 __REG(0x44000224) /* DMA Channel 2 Frame Source Address Register */ -#define FIDR2 __REG(0x44000228) /* DMA Channel 2 Frame ID Register */ -#define LDCMD2 __REG(0x4400022C) /* DMA Channel 2 Command Register */ -#define FDADR3 __REG(0x44000230) /* DMA Channel 3 Frame Descriptor Address Register */ -#define FSADR3 __REG(0x44000234) /* DMA Channel 3 Frame Source Address Register */ -#define FIDR3 __REG(0x44000238) /* DMA Channel 3 Frame ID Register */ -#define LDCMD3 __REG(0x4400023C) /* DMA Channel 3 Command Register */ -#define FDADR4 __REG(0x44000240) /* DMA Channel 4 Frame Descriptor Address Register */ -#define FSADR4 __REG(0x44000244) /* DMA Channel 4 Frame Source Address Register */ -#define FIDR4 __REG(0x44000248) /* DMA Channel 4 Frame ID Register */ -#define LDCMD4 __REG(0x4400024C) /* DMA Channel 4 Command Register */ -#define FDADR5 __REG(0x44000250) /* DMA Channel 5 Frame Descriptor Address Register */ -#define FSADR5 __REG(0x44000254) /* DMA Channel 5 Frame Source Address Register */ -#define FIDR5 __REG(0x44000258) /* DMA Channel 5 Frame ID Register */ -#define LDCMD5 __REG(0x4400025C) /* DMA Channel 5 Command Register */ - -#define OVL1C1 __REG(0x44000050) /* Overlay 1 Control Register 1 */ -#define OVL1C2 __REG(0x44000060) /* Overlay 1 Control Register 2 */ -#define OVL2C1 __REG(0x44000070) /* Overlay 2 Control Register 1 */ -#define OVL2C2 __REG(0x44000080) /* Overlay 2 Control Register 2 */ -#define CCR __REG(0x44000090) /* Cursor Control Register */ - -#define FBR5 __REG(0x44000110) /* DMA Channel 5 Frame Branch Register */ -#define FBR6 __REG(0x44000114) /* DMA Channel 6 Frame Branch Register */ +#define LCCR4 (0x44000010) /* LCD Controller Control Register 4 */ +#define LCCR5 (0x44000014) /* LCD Controller Control Register 5 */ +#define FBR0 (0x44000020) /* DMA Channel 0 Frame Branch Register */ +#define FBR1 (0x44000024) /* DMA Channel 1 Frame Branch Register */ +#define FBR2 (0x44000028) /* DMA Channel 2 Frame Branch Register */ +#define FBR3 (0x4400002C) /* DMA Channel 3 Frame Branch Register */ +#define FBR4 (0x44000030) /* DMA Channel 4 Frame Branch Register */ +#define FDADR2 (0x44000220) /* DMA Channel 2 Frame Descriptor Address Register */ +#define FSADR2 (0x44000224) /* DMA Channel 2 Frame Source Address Register */ +#define FIDR2 (0x44000228) /* DMA Channel 2 Frame ID Register */ +#define LDCMD2 (0x4400022C) /* DMA Channel 2 Command Register */ +#define FDADR3 (0x44000230) /* DMA Channel 3 Frame Descriptor Address Register */ +#define FSADR3 (0x44000234) /* DMA Channel 3 Frame Source Address Register */ +#define FIDR3 (0x44000238) /* DMA Channel 3 Frame ID Register */ +#define LDCMD3 (0x4400023C) /* DMA Channel 3 Command Register */ +#define FDADR4 (0x44000240) /* DMA Channel 4 Frame Descriptor Address Register */ +#define FSADR4 (0x44000244) /* DMA Channel 4 Frame Source Address Register */ +#define FIDR4 (0x44000248) /* DMA Channel 4 Frame ID Register */ +#define LDCMD4 (0x4400024C) /* DMA Channel 4 Command Register */ +#define FDADR5 (0x44000250) /* DMA Channel 5 Frame Descriptor Address Register */ +#define FSADR5 (0x44000254) /* DMA Channel 5 Frame Source Address Register */ +#define FIDR5 (0x44000258) /* DMA Channel 5 Frame ID Register */ +#define LDCMD5 (0x4400025C) /* DMA Channel 5 Command Register */ + +#define OVL1C1 (0x44000050) /* Overlay 1 Control Register 1 */ +#define OVL1C2 (0x44000060) /* Overlay 1 Control Register 2 */ +#define OVL2C1 (0x44000070) /* Overlay 2 Control Register 1 */ +#define OVL2C2 (0x44000080) /* Overlay 2 Control Register 2 */ +#define CCR (0x44000090) /* Cursor Control Register */ + +#define FBR5 (0x44000110) /* DMA Channel 5 Frame Branch Register */ +#define FBR6 (0x44000114) /* DMA Channel 6 Frame Branch Register */
#define LCCR0_LDDALT (1<<26) /* LDD Alternate mapping bit when base pixel is RGBT16 */ #define LCCR0_OUC (1<<25) /* Overlay Underlay Control Bit */ @@ -2572,16 +2744,16 @@ typedef void (*ExcpHndlr) (void) ;
/* Keypad controller */
-#define KPC __REG(0x41500000) /* Keypad Interface Control register */ -#define KPDK __REG(0x41500008) /* Keypad Interface Direct Key register */ -#define KPREC __REG(0x41500010) /* Keypad Intefcace Rotary Encoder register */ -#define KPMK __REG(0x41500018) /* Keypad Intefcace Matrix Key register */ -#define KPAS __REG(0x41500020) /* Keypad Interface Automatic Scan register */ -#define KPASMKP0 __REG(0x41500028) /* Keypad Interface Automatic Scan Multiple Key Presser register 0 */ -#define KPASMKP1 __REG(0x41500030) /* Keypad Interface Automatic Scan Multiple Key Presser register 1 */ -#define KPASMKP2 __REG(0x41500038) /* Keypad Interface Automatic Scan Multiple Key Presser register 2 */ -#define KPASMKP3 __REG(0x41500040) /* Keypad Interface Automatic Scan Multiple Key Presser register 3 */ -#define KPKDI __REG(0x41500048) /* Keypad Interface Key Debounce Interval register */ +#define KPC (0x41500000) /* Keypad Interface Control register */ +#define KPDK (0x41500008) /* Keypad Interface Direct Key register */ +#define KPREC (0x41500010) /* Keypad Intefcace Rotary Encoder register */ +#define KPMK (0x41500018) /* Keypad Intefcace Matrix Key register */ +#define KPAS (0x41500020) /* Keypad Interface Automatic Scan register */ +#define KPASMKP0 (0x41500028) /* Keypad Interface Automatic Scan Multiple Key Presser register 0 */ +#define KPASMKP1 (0x41500030) /* Keypad Interface Automatic Scan Multiple Key Presser register 1 */ +#define KPASMKP2 (0x41500038) /* Keypad Interface Automatic Scan Multiple Key Presser register 2 */ +#define KPASMKP3 (0x41500040) /* Keypad Interface Automatic Scan Multiple Key Presser register 3 */ +#define KPKDI (0x41500048) /* Keypad Interface Key Debounce Interval register */
#define KPC_AS (0x1 << 30) /* Automatic Scan bit */ #define KPC_ASACT (0x1 << 29) /* Automatic Scan on Activity */ @@ -2623,15 +2795,15 @@ typedef void (*ExcpHndlr) (void) ; #define KPASMKPx_SO (0x1 << 31)
#define GPIO113_BIT (1 << 17)/* GPIO113 in GPSR, GPCR, bit 17 */ -#define PSLR __REG(0x40F00034) -#define PSTR __REG(0x40F00038) /* Power Manager Standby Configuration Reg */ -#define PSNR __REG(0x40F0003C) /* Power Manager Sense Configuration Reg */ -#define PVCR __REG(0x40F00040) /* Power Manager Voltage Change Control Reg */ -#define PKWR __REG(0x40F00050) /* Power Manager KB Wake-Up Enable Reg */ -#define PKSR __REG(0x40F00054) /* Power Manager KB Level-Detect Status Reg */ -#define OSMR4 __REG(0x40A00080) /* */ -#define OSCR4 __REG(0x40A00040) /* OS Timer Counter Register */ -#define OMCR4 __REG(0x40A000C0) /* */ +#define PSLR (0x40F00034) +#define PSTR (0x40F00038) /* Power Manager Standby Configuration Reg */ +#define PSNR (0x40F0003C) /* Power Manager Sense Configuration Reg */ +#define PVCR (0x40F00040) /* Power Manager Voltage Change Control Reg */ +#define PKWR (0x40F00050) /* Power Manager KB Wake-Up Enable Reg */ +#define PKSR (0x40F00054) /* Power Manager KB Level-Detect Status Reg */ +#define OSMR4 (0x40A00080) /* */ +#define OSCR4 (0x40A00040) /* OS Timer Counter Register */ +#define OMCR4 (0x40A000C0) /* */
diff --git a/board/colibri_pxa270/colibri_pxa270.c b/board/colibri_pxa270/colibri_pxa270.c index 84ec38e..8aa7067 100644 --- a/board/colibri_pxa270/colibri_pxa270.c +++ b/board/colibri_pxa270/colibri_pxa270.c @@ -22,6 +22,7 @@ #include <common.h> #include <asm/arch/hardware.h> #include <netdev.h> +#include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -65,28 +66,30 @@ int dram_init (void) #ifdef CONFIG_CMD_USB int usb_board_init(void) { - UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & - ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE); + writel((readl(UHCHR) | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE), + UHCHR);
- UHCHR |= UHCHR_FSBIR; + writel(readl(UHCHR) | UHCHR_FSBIR, UHCHR);
while (UHCHR & UHCHR_FSBIR);
- UHCHR &= ~UHCHR_SSE; - UHCHIE = (UHCHIE_UPRIE | UHCHIE_RWIE); + writel(readl(UHCHR) & ~UHCHR_SSE, UHCHR); + writel((UHCHIE_UPRIE | UHCHIE_RWIE), UHCHIE);
/* Clear any OTG Pin Hold */ - if (PSSR & PSSR_OTGPH) - PSSR |= PSSR_OTGPH; + if (readl(PSSR) & PSSR_OTGPH) + writel(readl(PSSR) | PSSR_OTGPH, PSSR);
- UHCRHDA &= ~(0x200); - UHCRHDA |= 0x100; + writel(readl(UHCRHDA) & ~(0x200), UHCRHDA); + writel(readl(UHCRHDA) | 0x100, UHCRHDA);
/* Set port power control mask bits, only 3 ports. */ - UHCRHDB |= (0x7<<17); + writel(readl(UHCRHDB) | (0x7<<17), UHCRHDB);
/* enable port 2 */ - UP2OCR |= UP2OCR_HXOE | UP2OCR_HXS | UP2OCR_DMPDE | UP2OCR_DPPDE; + writel(readl(UP2OCR) | UP2OCR_HXOE | UP2OCR_HXS | + UP2OCR_DMPDE | UP2OCR_DPPDE, UP2OCR);
return 0; } @@ -98,14 +101,14 @@ void usb_board_init_fail(void)
void usb_board_stop(void) { - UHCHR |= UHCHR_FHR; + writel(readl(UHCHR) | UHCHR_FHR, UHCHR); udelay(11); - UHCHR &= ~UHCHR_FHR; + writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR);
- UHCCOMS |= 1; + writel(readl(UHCCOMS) | 1, UHCCOMS); udelay(10);
- CKEN &= ~CKEN10_USBHOST; + writel(readl(CKEN) & ~CKEN10_USBHOST, CKEN);
return; } diff --git a/board/cradle/cradle.c b/board/cradle/cradle.c index 21eb655..c4a93f9 100644 --- a/board/cradle/cradle.c +++ b/board/cradle/cradle.c @@ -28,6 +28,7 @@ #include <asm/arch/pxa-regs.h> #include <common.h> #include <netdev.h> +#include <asm/io.h>
@@ -92,8 +93,8 @@ set_led (int led, int color) int shift = led * 2; unsigned long mask = 0x3 << shift;
- CRADLE_LED_CLR_REG = mask; /* clear bits */ - CRADLE_LED_SET_REG = (color << shift); /* set bits */ + writel(mask, GPCR2); /* clear bits */ + writel((color << shift), GPSR2); /* set bits */ udelay (5000); }
diff --git a/board/cradle/lowlevel_init.S b/board/cradle/lowlevel_init.S index 6b5cfb9..39964b6 100644 --- a/board/cradle/lowlevel_init.S +++ b/board/cradle/lowlevel_init.S @@ -34,10 +34,10 @@ DRAM_SIZE: .long CONFIG_SYS_DRAM_SIZE .endm
.macro SET_LED val - ldr r6, =CRADLE_LED_CLR_REG + ldr r6, =GPCR2 ldr r7, =0 str r7, [r6] - ldr r6, =CRADLE_LED_SET_REG + ldr r6, =GPSR2 ldr r7, =\val str r7, [r6] .endm diff --git a/board/csb226/csb226.c b/board/csb226/csb226.c index 0a6c13d..6eed9ad 100644 --- a/board/csb226/csb226.c +++ b/board/csb226/csb226.c @@ -26,6 +26,7 @@ #include <common.h> #include <netdev.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
@@ -108,23 +109,23 @@ void csb226_set_led(int led, int state) switch(led) {
case 0: if (state==1) { - GPCR0 |= CSB226_USER_LED0; + writel(readl(GPCR0) | CSB226_USER_LED0, GPCR0); } else if (state==0) { - GPSR0 |= CSB226_USER_LED0; + writel(readl(GPSR0) | CSB226_USER_LED0, GPSR0); } break;
case 1: if (state==1) { - GPCR0 |= CSB226_USER_LED1; + writel(readl(GPCR0) | CSB226_USER_LED1, GPCR0); } else if (state==0) { - GPSR0 |= CSB226_USER_LED1; + writel(readl(GPSR0) | CSB226_USER_LED1, GPSR0); } break;
case 2: if (state==1) { - GPCR0 |= CSB226_USER_LED2; + writel(readl(GPCR0) | CSB226_USER_LED2, GPCR0); } else if (state==0) { - GPSR0 |= CSB226_USER_LED2; + writel(readl(GPSR0) | CSB226_USER_LED2, GPSR0); } break; } diff --git a/board/delta/delta.c b/board/delta/delta.c index 68c39d2..df23076 100644 --- a/board/delta/delta.c +++ b/board/delta/delta.c @@ -28,6 +28,7 @@ #include <malloc.h> #include <command.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
@@ -110,7 +111,7 @@ static uchar kbd_command_prefix[] = "key_cmd"; static void get_pressed_keys(uchar *s) { unsigned long val; - val = GPLR3; + val = readl(GPLR3);
if(val & (1<<31)) *s++ = KEYBD_KP_DKIN0; @@ -124,18 +125,18 @@ static void get_pressed_keys(uchar *s)
static void keys_init() { - CKENB |= CKENB_7_GPIO; + writel(readl(CKENB) | CKENB_7_GPIO, CKENB); udelay(100);
/* Configure GPIOs */ - GPIO127 = 0xa840; /* KP_DKIN0 */ - GPIO114 = 0xa840; /* KP_DKIN1 */ - GPIO125 = 0xa840; /* KP_DKIN2 */ - GPIO118 = 0xa840; /* KP_DKIN5 */ + writel(0xa840, GPIO127); /* KP_DKIN0 */ + writel(0xa840, GPIO114); /* KP_DKIN1 */ + writel(0xa840, GPIO125); /* KP_DKIN2 */ + writel(0xa840, GPIO118); /* KP_DKIN5 */
/* Configure GPIOs as inputs */ - GPDR3 &= ~(1<<31 | 1<<18 | 1<<29 | 1<<22); - GCDR3 = (1<<31 | 1<<18 | 1<<29 | 1<<22); + writel(readl(GPDR3) & ~(1<<31 | 1<<18 | 1<<29 | 1<<22), GPDR3); + writel((1<<31 | 1<<18 | 1<<29 | 1<<22), GCDR3);
udelay(100); } @@ -283,11 +284,11 @@ int dram_init (void)
void i2c_init_board() { - CKENB |= (CKENB_4_I2C); + writel(readl(CKENB) | (CKENB_4_I2C), CKENB);
/* setup I2C GPIO's */ - GPIO32 = 0x801; /* SCL = Alt. Fkt. 1 */ - GPIO33 = 0x801; /* SDA = Alt. Fkt. 1 */ + writel(0x801, GPIO32); /* SCL = Alt. Fkt. 1 */ + writel(0x801, GPIO33); /* SDA = Alt. Fkt. 1 */ }
/* initialize the DA9030 Power Controller */ @@ -295,20 +296,20 @@ static void init_DA9030() { uchar addr = (uchar) DA9030_I2C_ADDR, val = 0;
/* Rising Edge on EXTON to reset DA9030 */ - GPIO17 = 0x8800; /* configure GPIO17, no pullup, -down */ - GPDR0 |= (1<<17); /* GPIO17 is output */ - GSDR0 = (1<<17); - GPCR0 = (1<<17); /* drive GPIO17 low */ - GPSR0 = (1<<17); /* drive GPIO17 high */ + writel(0x8800, GPIO17); /* configure GPIO17, no pullup, -down */ + writel(readl(GPDR0) | (1<<17), GPDR0); /* GPIO17 is output */ + writel((1<<17), GSDR0); + writel((1<<17), GPCR0); /* drive GPIO17 low */ + writel((1<<17), GPSR0); /* drive GPIO17 high */
#if CONFIG_SYS_DA9030_EXTON_DELAY udelay((unsigned long) CONFIG_SYS_DA9030_EXTON_DELAY); /* wait for DA9030 */ #endif - GPCR0 = (1<<17); /* drive GPIO17 low */ + writel((1<<17), GPCR0); /* drive GPIO17 low */
/* reset the watchdog and go active (0xec) */ val = (SYS_CONTROL_A_HWRES_ENABLE | diff --git a/board/delta/nand.c b/board/delta/nand.c index 85a6ba2..119a587 100644 --- a/board/delta/nand.c +++ b/board/delta/nand.c @@ -26,6 +26,7 @@
#include <nand.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
#ifdef CONFIG_SYS_DFC_DEBUG1 # define DFC_DEBUG1(fmt, args...) printf(fmt, ##args) @@ -95,7 +96,7 @@ static void dfc_write_buf(struct mtd_info *mtd, const u_char *buf, int len) if(bytes_multi) { for(i=0; i<bytes_multi; i+=4) { long_buf = (unsigned long*) &buf[i]; - NDDB = *long_buf; + writel(*long_buf, NDDB); } } if(rest) { @@ -120,7 +121,7 @@ static void dfc_read_buf(struct mtd_info *mtd, u_char* const buf, int len) if(bytes_multi) { for(i=0; i<bytes_multi; i+=4) { long_buf = (unsigned long*) &buf[i]; - *long_buf = NDDB; + *long_buf = readl(NDDB); } }
@@ -166,8 +167,8 @@ static u_char dfc_read_byte(struct mtd_info *mtd) unsigned long dummy;
if(bytes_read < 0) { - read_buf = NDDB; - dummy = NDDB; + read_buf = readl(NDDB); + dummy = readl(NDDB); bytes_read = 0; } byte = (unsigned char) (read_buf>>(8 * bytes_read++)); @@ -181,7 +182,7 @@ static u_char dfc_read_byte(struct mtd_info *mtd) /* calculate delta between OSCR values start and now */ static unsigned long get_delta(unsigned long start) { - unsigned long cur = OSCR; + unsigned long cur = readl(OSCR);
if(cur < start) /* OSCR overflowed */ return (cur + (start^0xffffffff)); @@ -192,7 +193,7 @@ static unsigned long get_delta(unsigned long start) /* delay function, this doesn't belong here */ static void wait_us(unsigned long us) { - unsigned long start = OSCR; + unsigned long start = readl(OSCR); us = DIV_ROUND_UP(us * OSCR_CLK_FREQ, 1000);
while (get_delta(start) < us) { @@ -202,14 +203,14 @@ static void wait_us(unsigned long us)
static void dfc_clear_nddb(void) { - NDCR &= ~NDCR_ND_RUN; + writel(readl(NDCR) & ~NDCR_ND_RUN, NDCR); wait_us(CONFIG_SYS_NAND_OTHER_TO); }
/* wait_event with timeout */ static unsigned long dfc_wait_event(unsigned long event) { - unsigned long ndsr, timeout, start = OSCR; + unsigned long ndsr, timeout, start = readl(OSCR);
if(!event) return 0xff000000; @@ -221,9 +222,9 @@ static unsigned long dfc_wait_event(unsigned long event) * OSCR_CLK_FREQ, 1000);
while(1) { - ndsr = NDSR; + ndsr = readl(NDSR); if(ndsr & event) { - NDSR |= event; + writel(readl(NDSR) | event, NDSR); break; } if(get_delta(start) > timeout) { @@ -243,11 +244,11 @@ static void dfc_new_cmd(void)
while(retry++ <= CONFIG_SYS_NAND_SENDCMD_RETRY) { /* Clear NDSR */ - NDSR = 0xFFF; + writel(0xfff, NDSR);
/* set NDCR[NDRUN] */ - if(!(NDCR & NDCR_ND_RUN)) - NDCR |= NDCR_ND_RUN; + if (!(readl(NDCR) & NDCR_ND_RUN)) + writel(readl(NDCR) | NDCR_ND_RUN, NDCR);
status = dfc_wait_event(NDSR_WRCMDREQ);
@@ -357,9 +358,9 @@ static void dfc_cmdfunc(struct mtd_info *mtd, unsigned command, }
write_cmd: - NDCB0 = ndcb0; - NDCB0 = ndcb1; - NDCB0 = ndcb2; + writel(ndcb0, NDCB0); + writel(ndcb1, NDCB0); + writel(ndcb2, NDCB0);
/* wait_event: */ dfc_wait_event(event); @@ -372,36 +373,36 @@ static void dfc_gpio_init(void) DFC_DEBUG2("Setting up DFC GPIO's.\n");
/* no idea what is done here, see zylonite.c */ - GPIO4 = 0x1; - - DF_ALE_WE1 = 0x00000001; - DF_ALE_WE2 = 0x00000001; - DF_nCS0 = 0x00000001; - DF_nCS1 = 0x00000001; - DF_nWE = 0x00000001; - DF_nRE = 0x00000001; - DF_IO0 = 0x00000001; - DF_IO8 = 0x00000001; - DF_IO1 = 0x00000001; - DF_IO9 = 0x00000001; - DF_IO2 = 0x00000001; - DF_IO10 = 0x00000001; - DF_IO3 = 0x00000001; - DF_IO11 = 0x00000001; - DF_IO4 = 0x00000001; - DF_IO12 = 0x00000001; - DF_IO5 = 0x00000001; - DF_IO13 = 0x00000001; - DF_IO6 = 0x00000001; - DF_IO14 = 0x00000001; - DF_IO7 = 0x00000001; - DF_IO15 = 0x00000001; - - DF_nWE = 0x1901; - DF_nRE = 0x1901; - DF_CLE_NOE = 0x1900; - DF_ALE_WE1 = 0x1901; - DF_INT_RnB = 0x1900; + writel(0x1, GPIO4); + + writel(0x00000001, DF_ALE_nWE1); + writel(0x00000001, DF_ALE_nWE2); + writel(0x00000001, DF_nCS0); + writel(0x00000001, DF_nCS1); + writel(0x00000001, DF_nWE); + writel(0x00000001, DF_nRE); + writel(0x00000001, DF_IO0); + writel(0x00000001, DF_IO8); + writel(0x00000001, DF_IO1); + writel(0x00000001, DF_IO9); + writel(0x00000001, DF_IO2); + writel(0x00000001, DF_IO10); + writel(0x00000001, DF_IO3); + writel(0x00000001, DF_IO11); + writel(0x00000001, DF_IO4); + writel(0x00000001, DF_IO12); + writel(0x00000001, DF_IO5); + writel(0x00000001, DF_IO13); + writel(0x00000001, DF_IO6); + writel(0x00000001, DF_IO14); + writel(0x00000001, DF_IO7); + writel(0x00000001, DF_IO15); + + writel(0x1901, DF_nWE); + writel(0x1901, DF_nRE); + writel(0x1900, DF_CLE_nOE); + writel(0x1901, DF_ALE_nWE1); + writel(0x1900, DF_INT_RnB); }
/* @@ -430,7 +431,7 @@ int board_nand_init(struct nand_chip *nand) dfc_gpio_init();
/* turn on the NAND Controller Clock (104 MHz @ D0) */ - CKENA |= (CKENA_4_NAND | CKENA_9_SMC); + writel(readl(CKENA) | (CKENA_4_NAND | CKENA_9_SMC), CKENA);
#undef CONFIG_SYS_TIMING_TIGHT #ifndef CONFIG_SYS_TIMING_TIGHT @@ -485,17 +486,19 @@ int board_nand_init(struct nand_chip *nand) tRP_high = 0; }
- NDTR0CS0 = (tCH << 19) | + writel((tCH << 19) | (tCS << 16) | (tWH << 11) | (tWP << 8) | (tRP_high << 6) | (tRH << 3) | - (tRP << 0); + (tRP << 0), + NDTR0CS0);
- NDTR1CS0 = (tR << 16) | + writel((tR << 16) | (tWHR << 4) | - (tAR << 0); + (tAR << 0), + NDTR1CS0);
/* If it doesn't work (unlikely) think about: * - ecc enable @@ -512,7 +515,7 @@ int board_nand_init(struct nand_chip *nand) */ /* NDCR_NCSX | /* Chip select busy don't care */ */
- NDCR = (NDCR_SPARE_EN | /* use the spare area */ + writel(NDCR_SPARE_EN | /* use the spare area */ NDCR_DWIDTH_C | /* 16bit DFC data bus width */ NDCR_DWIDTH_M | /* 16 bit Flash device data bus width */ (2 << 16) | /* read id count = 7 ???? mk@tbd */ @@ -528,7 +531,8 @@ int board_nand_init(struct nand_chip *nand) NDCR_SBERRM | /* single bit error ir masked */ NDCR_WRDREQM | /* write data request ir masked */ NDCR_RDDREQM | /* read data request ir masked */ - NDCR_WRCMDREQM); /* write command request ir masked */ + NDCR_WRCMDREQM, /* write command request ir masked */ + NDCR);
/* wait 10 us due to cmd buffer clear reset */ diff --git a/board/innokom/innokom.c b/board/innokom/innokom.c index 3412f10..2c51125 100644 --- a/board/innokom/innokom.c +++ b/board/innokom/innokom.c @@ -27,6 +27,7 @@ #include <netdev.h> #include <asm/arch/pxa-regs.h> #include <asm/mach-types.h> +#include <asm/io.h>
@@ -48,20 +49,21 @@ int i2c_init_board(void)
/* disable I2C controller first, otherwhise it thinks we want to */ /* talk to the slave port... */ - icr = ICR; ICR &= ~(ICR_SCLE | ICR_IUE); + icr = readl(ICR); + writel(readl(ICR) & ~(ICR_SCLE | ICR_IUE), ICR);
/* set gpio pin low _before_ we change direction to output */ - GPCR(70) = GPIO_bit(70); + writel(GPIO_bit(70), GPCR(70));
/* now toggle between output=low and high-impedance */ for (i = 0; i < 20; i++) { - GPDR(70) |= GPIO_bit(70); /* output */ + writel(readl(GPDR(70)) | GPIO_bit(70), GPDR(70)); /* output */ udelay(10); - GPDR(70) &= ~GPIO_bit(70); /* input */ + writel(readl(GPDR(70)) & ~GPIO_bit(70), GPDR(70)); /* input */ udelay(10); }
- ICR = icr; + writel(icr, ICR);
return 0; } @@ -76,7 +78,7 @@ int misc_init_r(void) char *str;
/* determine if the software update key is pressed during startup */ - if (GPLR0 & 0x00000800) { + if (readl(GPLR0) & 0x00000800) { printf("using bootcmd_normal (sw-update button not pressed)\n"); str = getenv("bootcmd_normal"); } else { diff --git a/board/pxa255_idp/pxa_idp.c b/board/pxa255_idp/pxa_idp.c index a54a95d..4ab8bd4 100644 --- a/board/pxa255_idp/pxa_idp.c +++ b/board/pxa255_idp/pxa_idp.c @@ -33,6 +33,7 @@ #include <common.h> #include <netdev.h> #include <command.h> +#include <asm/io.h>
@@ -56,14 +57,14 @@ int board_init (void)
/* set PWM for LCD */ /* a value that works is 60Hz, 77% duty cycle */ - CKEN |= CKEN0_PWM0; - PWM_CTRL0 = 0x3f; - PWM_PERVAL0 = 0x3ff; - PWM_PWDUTY0 = 792; + writel(readl(CKEN) | CKEN0_PWM0, CKEN); + writel(0x3f, PWM_CTRL0); + writel(0x3ff, PWM_PERVAL0); + writel(792, PWM_PWDUTY0);
/* clear reset to AC97 codec */ - CKEN |= CKEN2_AC97; - GCR = GCR_COLD_RST; + writel(readl(CKEN) | CKEN2_AC97, CKEN); + writel(GCR_COLD_RST, GCR);
/* enable LCD backlight */ /* *(volatile unsigned int *)(PXA_CS5_PHYS + 0x03C00030) = 0x7; */ @@ -102,11 +103,11 @@ int dram_init (void) void delay_c(void) { /* reset OSCR to 0 */ - OSCR = 0; - while(OSCR > 0x10000) + writel(0, OSCR); + while (readl(OSCR) > 0x10000) ;
- while(OSCR < 0xd4000) + while (readl(OSCR) < 0xd4000) ; }
@@ -114,12 +115,12 @@ void blink_c(void) { int led_bit = (1<<10);
- GPDR0 = led_bit; - GPCR0 = led_bit; + writel(led_bit, GPDR0); + writel(led_bit, GPCR0); delay_c(); - GPSR0 = led_bit; + writel(led_bit, GPSR0); delay_c(); - GPCR0 = led_bit; + writel(led_bit, GPCR0); }
int do_idpcmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) diff --git a/board/trizepsiv/conxs.c b/board/trizepsiv/conxs.c index 8c11456..7fac73d 100644 --- a/board/trizepsiv/conxs.c +++ b/board/trizepsiv/conxs.c @@ -34,6 +34,7 @@ #include <common.h> #include <asm/arch/pxa-regs.h> #include <netdev.h> +#include <asm/io.h>
@@ -57,25 +58,27 @@ extern struct serial_device serial_stuart_device;
- while (UHCHR & UHCHR_FSBIR); + while (readl(UHCHR) & UHCHR_FSBIR) + ;
- UHCRHDA &= ~(RH_A_NPS); - UHCRHDA |= RH_A_PSM; + writel(readl(UHCRHDA) & ~(RH_A_NPS), UHCRHDA); + writel(readl(UHCRHDA) | RH_A_PSM, UHCRHDA);
return 0; } @@ -87,14 +90,14 @@ void usb_board_init_fail(void)
return; } diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index 18e47e2..f792298 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -31,6 +31,8 @@ #include <common.h> #include <asm/arch/hardware.h> #include <netdev.h> +#include <serial.h> +#include <asm/io.h>
@@ -75,28 +77,31 @@ int dram_init (void)
int usb_board_init(void) { - UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & - ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE); + writel((UHCHR | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE), + UHCHR);
return 0; } @@ -108,14 +113,14 @@ void usb_board_init_fail(void)
return; } diff --git a/board/wepep250/wepep250.c b/board/wepep250/wepep250.c index fe4b6a9..6e41ea6 100644 --- a/board/wepep250/wepep250.c +++ b/board/wepep250/wepep250.c @@ -22,6 +22,7 @@
#include <common.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
@@ -33,13 +34,13 @@ int board_init (void) * Setup GPIO stuff to get serial working */ #if defined( CONFIG_FFUART ) - GPDR1 = 0x80; - GAFR1_L = 0x8010; + writel(0x80, GPDR1); + writel(0x8010, GAFR1_L); #elif defined( CONFIG_BTUART ) - GPDR1 = 0x800; - GAFR1_L = 0x900000; + writel(0x800, GPDR1); + writel(0x900000, GAFR1_L); #endif - PSSR = 0x20; + writel(0x20, PSSR);
return 0; } diff --git a/board/zipitz2/zipitz2.c b/board/zipitz2/zipitz2.c index 14d1d76..f7edc4c 100644 --- a/board/zipitz2/zipitz2.c +++ b/board/zipitz2/zipitz2.c @@ -28,6 +28,7 @@ #include <serial.h> #include <asm/arch/hardware.h> #include <spi.h> +#include <asm/io.h>
@@ -129,24 +130,24 @@ void zipitz2_spi_sda(int set) { /* GPIO 13 */ if (set) - GPSR0 = (1 << 13); + writel((1 << 13), GPSR0); else - GPCR0 = (1 << 13); + writel((1 << 13), GPCR0); }
void zipitz2_spi_scl(int set) { /* GPIO 22 */ if (set) - GPCR0 = (1 << 22); + writel((1 << 22), GPCR0); else - GPSR0 = (1 << 22); + writel((1 << 22), GPSR0); }
unsigned char zipitz2_spi_read(void) { /* GPIO 40 */ - return !!(GPLR1 & (1 << 8)); + return !!(readl(GPLR1) & (1 << 8)); }
int spi_cs_is_valid(unsigned int bus, unsigned int cs) @@ -158,13 +159,13 @@ int spi_cs_is_valid(unsigned int bus, unsigned int cs) void spi_cs_activate(struct spi_slave *slave) { /* GPIO 88 low */ - GPCR2 = (1 << 24); + writel((1 << 24), GPCR2); }
void spi_cs_deactivate(struct spi_slave *slave) { /* GPIO 88 high */ - GPSR2 = (1 << 24); + writel((1 << 24), GPSR2);
@@ -176,20 +177,20 @@ void lcd_start(void) unsigned char dummy[3] = { 0, 0, 0 };
/* PWM2 AF */ - GAFR0_L |= 0x00800000; + writel(readl(GAFR0_L) | 0x00800000, GAFR0_L); /* Enable clock to all PWM */ - CKEN |= 0x3; + writel(readl(CKEN) | 0x3, CKEN); /* Configure PWM2 */ - PWM_CTRL2 = 0x4f; - PWM_PWDUTY2 = 0x2ff; - PWM_PERVAL2 = 792; + writel(0x4f, PWM_CTRL2); + writel(0x2ff, PWM_PWDUTY2); + writel(792, PWM_PERVAL2);
/* Toggle the reset pin to reset the LCD */ - GPSR0 = (1 << 19); + writel((1 << 19), GPSR0); udelay(100000); - GPCR0 = (1 << 19); + writel((1 << 19), GPCR0); udelay(20000); - GPSR0 = (1 << 19); + writel((1 << 19), GPSR0); udelay(20000);
/* Program the LCD init sequence */ @@ -208,6 +209,6 @@ void lcd_start(void) udelay(lcd_data[i].mdelay * 1000); }
- GPSR0 = (1 << 11); + writel((1 << 11), GPSR0); } #endif diff --git a/board/zylonite/nand.c b/board/zylonite/nand.c index 7cad1ac..71d18a6 100644 --- a/board/zylonite/nand.c +++ b/board/zylonite/nand.c @@ -21,6 +21,7 @@ */
#include <common.h> +#include <asm/io.h>
#if defined(CONFIG_CMD_NAND)
@@ -95,7 +96,7 @@ static void dfc_write_buf(struct mtd_info *mtd, const u_char *buf, int len) if(bytes_multi) { for(i=0; i<bytes_multi; i+=4) { long_buf = (unsigned long*) &buf[i]; - NDDB = *long_buf; + writel(*long_buf, NDDB); } } if(rest) { @@ -125,7 +126,7 @@ static void dfc_read_buf(struct mtd_info *mtd, u_char* const buf, int len) if(bytes_multi) { for(i=0; i<bytes_multi; i+=4) { long_buf = (unsigned long*) &buf[i]; - *long_buf = NDDB; + *long_buf = readl(NDDB); } }
@@ -171,8 +172,8 @@ static u_char dfc_read_byte(struct mtd_info *mtd) unsigned long dummy;
if(bytes_read < 0) { - read_buf = NDDB; - dummy = NDDB; + read_buf = readl(NDDB); + dummy = readl(NDDB); bytes_read = 0; } byte = (unsigned char) (read_buf>>(8 * bytes_read++)); @@ -186,7 +187,7 @@ static u_char dfc_read_byte(struct mtd_info *mtd) /* calculate delta between OSCR values start and now */ static unsigned long get_delta(unsigned long start) { - unsigned long cur = OSCR; + unsigned long cur = readl(OSCR);
if(cur < start) /* OSCR overflowed */ return (cur + (start^0xffffffff)); @@ -197,7 +198,7 @@ static unsigned long get_delta(unsigned long start) /* delay function, this doesn't belong here */ static void wait_us(unsigned long us) { - unsigned long start = OSCR; + unsigned long start = readl(OSCR); us = DIV_ROUND_UP(us * OSCR_CLK_FREQ, 1000);
while (get_delta(start) < us) { @@ -207,14 +208,14 @@ static void wait_us(unsigned long us)
if(!event) return 0xff000000; @@ -226,9 +227,9 @@ static unsigned long dfc_wait_event(unsigned long event) * OSCR_CLK_FREQ, 1000);
while(1) { - ndsr = NDSR; + ndsr = readl(NDSR); if(ndsr & event) { - NDSR |= event; + writel(readl(NDSR) | event, NDSR); break; } if(get_delta(start) > timeout) { @@ -248,11 +249,11 @@ static void dfc_new_cmd(void)
while(retry++ <= CONFIG_SYS_NAND_SENDCMD_RETRY) { /* Clear NDSR */ - NDSR = 0xFFF; + writel(0xFFF, NDSR);
@@ -362,9 +363,9 @@ static void dfc_cmdfunc(struct mtd_info *mtd, unsigned command, }
/* wait_event: */ dfc_wait_event(event); @@ -377,36 +378,36 @@ static void dfc_gpio_init(void) DFC_DEBUG2("Setting up DFC GPIO's.\n");
/* @@ -435,7 +436,7 @@ int board_nand_init(struct nand_chip *nand) dfc_gpio_init();
#undef CONFIG_SYS_TIMING_TIGHT #ifndef CONFIG_SYS_TIMING_TIGHT @@ -490,17 +491,19 @@ int board_nand_init(struct nand_chip *nand) tRP_high = 0; }
/* If it doesn't work (unlikely) think about: * - ecc enable @@ -517,7 +520,7 @@ int board_nand_init(struct nand_chip *nand) */ /* NDCR_NCSX | /* Chip select busy don't care */ */
- NDCR = (NDCR_SPARE_EN | /* use the spare area */ + writel(NDCR_SPARE_EN | /* use the spare area */ NDCR_DWIDTH_C | /* 16bit DFC data bus width */ NDCR_DWIDTH_M | /* 16 bit Flash device data bus width */ (2 << 16) | /* read id count = 7 ???? mk@tbd */ @@ -533,7 +536,8 @@ int board_nand_init(struct nand_chip *nand) NDCR_SBERRM | /* single bit error ir masked */ NDCR_WRDREQM | /* write data request ir masked */ NDCR_RDDREQM | /* read data request ir masked */ - NDCR_WRCMDREQM); /* write command request ir masked */ + NDCR_WRCMDREQM, /* write command request ir masked */ + NDCR);
/* wait 10 us due to cmd buffer clear reset */ diff --git a/drivers/mmc/pxa_mmc.c b/drivers/mmc/pxa_mmc.c index 8776903..48e21ef 100644 --- a/drivers/mmc/pxa_mmc.c +++ b/drivers/mmc/pxa_mmc.c @@ -27,6 +27,7 @@ #include <asm/errno.h> #include <asm/arch/hardware.h> #include <part.h> +#include <asm/io.h>
#include "pxa_mmc.h"
@@ -59,18 +60,20 @@ mmc_cmd(ushort cmd, ushort argh, ushort argl, ushort cmdat)
debug("mmc_cmd %u 0x%04x 0x%04x 0x%04x\n", cmd, argh, argl, cmdat | wide); - MMC_STRPCL = MMC_STRPCL_STOP_CLK; - MMC_I_MASK = ~MMC_I_MASK_CLK_IS_OFF; - while (!(MMC_I_REG & MMC_I_REG_CLK_IS_OFF)) ; - MMC_CMD = cmd; - MMC_ARGH = argh; - MMC_ARGL = argl; - MMC_CMDAT = cmdat | wide; - MMC_I_MASK = ~MMC_I_MASK_END_CMD_RES; - MMC_STRPCL = MMC_STRPCL_START_CLK; - while (!(MMC_I_REG & MMC_I_REG_END_CMD_RES)) ; - - status = MMC_STAT; + writel(MMC_STRPCL_STOP_CLK, MMC_STRPCL); + writel(~MMC_I_MASK_CLK_IS_OFF, MMC_I_MASK); + while (!(readl(MMC_I_REG) & MMC_I_REG_CLK_IS_OFF)) + ; + writel(cmd, MMC_CMD); + writel(argh, MMC_ARGH); + writel(argl, MMC_ARGL); + writel(cmdat | wide, MMC_CMDAT); + writel(~MMC_I_MASK_END_CMD_RES, MMC_I_MASK); + writel(MMC_STRPCL_START_CLK, MMC_STRPCL); + while (!(readl(MMC_I_REG) & MMC_I_REG_END_CMD_RES)) + ; + + status = readl(MMC_STAT); debug("MMC status 0x%08x\n", status); if (status & MMC_STAT_TIME_OUT_RESPONSE) { return 0; @@ -80,10 +83,10 @@ mmc_cmd(ushort cmd, ushort argh, ushort argl, ushort cmdat) * Did I mention this is Sick. We always need to * discard the upper 8 bits of the first 16-bit word. */ - a = (MMC_RES & 0xffff); + a = (readl(MMC_RES) & 0xffff); for (i = 0; i < 4; i++) { - b = (MMC_RES & 0xffff); - c = (MMC_RES & 0xffff); + b = (readl(MMC_RES) & 0xffff); + c = (readl(MMC_RES) & 0xffff); resp[i] = (a << 24) | (b << 8) | (c >> 8); a = c; debug("MMC resp[%d] = %#08x\n", i, resp[i]); @@ -115,37 +118,38 @@ mmc_block_read(uchar * dst, ulong src, ulong len) /* send read command */ argh = src >> 16; argl = src & 0xffff; - MMC_STRPCL = MMC_STRPCL_STOP_CLK; - MMC_RDTO = 0xffff; - MMC_NOB = 1; - MMC_BLKLEN = len; + writel(MMC_STRPCL_STOP_CLK, MMC_STRPCL); + writel(0xffff, MMC_RDTO); + writel(1, MMC_NOB); + writel(len, MMC_BLKLEN); mmc_cmd(MMC_CMD_READ_SINGLE_BLOCK, argh, argl, MMC_CMDAT_R1 | MMC_CMDAT_READ | MMC_CMDAT_BLOCK | MMC_CMDAT_DATA_EN);
- MMC_I_MASK = ~MMC_I_MASK_RXFIFO_RD_REQ; + writel(~MMC_I_MASK_RXFIFO_RD_REQ, MMC_I_MASK); while (len) { - if (MMC_I_REG & MMC_I_REG_RXFIFO_RD_REQ) { + if (readl(MMC_I_REG) & MMC_I_REG_RXFIFO_RD_REQ) { #if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) int i; for (i = min(len, 32); i; i--) { - *dst++ = *((volatile uchar *)&MMC_RXFIFO); + *dst++ = readb(MMC_RXFIFO); len--; } #else - *dst++ = MMC_RXFIFO; + *dst++ = readb(MMC_RXFIFO); len--; #endif } - status = MMC_STAT; + status = readl(MMC_STAT); if (status & MMC_STAT_ERRORS) { printf("MMC_STAT error %lx\n", status); return -1; } } - MMC_I_MASK = ~MMC_I_MASK_DATA_TRAN_DONE; - while (!(MMC_I_REG & MMC_I_REG_DATA_TRAN_DONE)) ; - status = MMC_STAT; + writel(~MMC_I_MASK_DATA_TRAN_DONE, MMC_I_MASK); + while (!(readl(MMC_I_REG) & MMC_I_REG_DATA_TRAN_DONE)) + ; + status = readl(MMC_STAT); if (status & MMC_STAT_ERRORS) { printf("MMC_STAT error %lx\n", status); return -1; @@ -176,37 +180,39 @@ mmc_block_write(ulong dst, uchar * src, int len) /* send write command */ argh = dst >> 16; argl = dst & 0xffff; - MMC_STRPCL = MMC_STRPCL_STOP_CLK; - MMC_NOB = 1; - MMC_BLKLEN = len; + writel(MMC_STRPCL_STOP_CLK, MMC_STRPCL); + writel(1, MMC_NOB); + writel(len, MMC_BLKLEN); mmc_cmd(MMC_CMD_WRITE_SINGLE_BLOCK, argh, argl, MMC_CMDAT_R1 | MMC_CMDAT_WRITE | MMC_CMDAT_BLOCK | MMC_CMDAT_DATA_EN);
- MMC_I_MASK = ~MMC_I_MASK_TXFIFO_WR_REQ; + writel(~MMC_I_MASK_TXFIFO_WR_REQ, MMC_I_MASK); while (len) { - if (MMC_I_REG & MMC_I_REG_TXFIFO_WR_REQ) { + if (readl(MMC_I_REG) & MMC_I_REG_TXFIFO_WR_REQ) { int i, bytes = min(32, len);
for (i = 0; i < bytes; i++) { - MMC_TXFIFO = *src++; + writel(*src++, MMC_TXFIFO); } if (bytes < 32) { - MMC_PRTBUF = MMC_PRTBUF_BUF_PART_FULL; + writel(MMC_PRTBUF_BUF_PART_FULL, MMC_PRTBUF); } len -= bytes; } - status = MMC_STAT; + status = readl(MMC_STAT); if (status & MMC_STAT_ERRORS) { printf("MMC_STAT error %lx\n", status); return -1; } } - MMC_I_MASK = ~MMC_I_MASK_DATA_TRAN_DONE; - while (!(MMC_I_REG & MMC_I_REG_DATA_TRAN_DONE)) ; - MMC_I_MASK = ~MMC_I_MASK_PRG_DONE; - while (!(MMC_I_REG & MMC_I_REG_PRG_DONE)) ; - status = MMC_STAT; + writel(~MMC_I_MASK_DATA_TRAN_DONE, MMC_I_MASK); + while (!(readl(MMC_I_REG) & MMC_I_REG_DATA_TRAN_DONE)) + ; + writel(~MMC_I_MASK_PRG_DONE, MMC_I_MASK); + while (!(readl(MMC_I_REG) & MMC_I_REG_PRG_DONE)) + ; + status = readl(MMC_STAT); if (status & MMC_STAT_ERRORS) { printf("MMC_STAT error %lx\n", status); return -1; @@ -559,13 +565,13 @@ mmc_legacy_init(int verbose) set_GPIO_mode(GPIO8_MMCCS0_MD); #endif #ifdef CONFIG_CPU_MONAHANS /* pxa3xx */ - CKENA |= CKENA_12_MMC0 | CKENA_13_MMC1; + writel(readl(CKENA) | CKENA_12_MMC0 | CKENA_13_MMC1, CKENA); #else /* pxa2xx */ - CKEN |= CKEN12_MMC; /* enable MMC unit clock */ + writel(readl(CKEN) | CKEN12_MMC, CKEN); /* enable MMC unit clock */ #endif - MMC_CLKRT = MMC_CLKRT_0_3125MHZ; - MMC_RESTO = MMC_RES_TO_MAX; - MMC_SPI = MMC_SPI_DISABLE; + writel(MMC_CLKRT_0_3125MHZ, MMC_CLKRT); + writel(MMC_RES_TO_MAX, MMC_RESTO); + writel(MMC_SPI_DISABLE, MMC_SPI);
/* reset */ mmc_cmd(MMC_CMD_GO_IDLE_STATE, 0, 0, MMC_CMDAT_INIT | MMC_CMDAT_R0); @@ -624,7 +630,7 @@ mmc_legacy_init(int verbose) mmc_decode_cid(cid_resp); }
- MMC_CLKRT = 0; /* 20 MHz */ + writel(0, MMC_CLKRT); /* 20 MHz */ resp = mmc_cmd(MMC_CMD_SELECT_CARD, rca, 0, MMC_CMDAT_R1);
#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) diff --git a/drivers/serial/serial_pxa.c b/drivers/serial/serial_pxa.c index b74e439..e457980 100644 --- a/drivers/serial/serial_pxa.c +++ b/drivers/serial/serial_pxa.c @@ -32,6 +32,7 @@ #include <watchdog.h> #include <serial.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
@@ -73,60 +74,60 @@ void pxa_setbrg_dev (unsigned int uart_index) switch (uart_index) { case FFUART_INDEX: #ifdef CONFIG_CPU_MONAHANS - CKENA |= CKENA_22_FFUART; + writel(readl(CKENA) | CKENA_22_FFUART, CKENA); #else - CKEN |= CKEN6_FFUART; + writel(readl(CKEN) | CKEN6_FFUART, CKEN); #endif /* CONFIG_CPU_MONAHANS */
- FFIER = 0; /* Disable for now */ - FFFCR = 0; /* No fifos enabled */ + writel(0, FFIER); /* Disable for now */ + writel(0, FFFCR); /* No fifos enabled */
/* set baud rate */ - FFLCR = LCR_WLS0 | LCR_WLS1 | LCR_DLAB; - FFDLL = quot & 0xff; - FFDLH = quot >> 8; - FFLCR = LCR_WLS0 | LCR_WLS1; + writel(LCR_WLS0 | LCR_WLS1 | LCR_DLAB, FFLCR); + writel(quot & 0xff, FFDLL); + writel(quot >> 8, FFDLH); + writel(LCR_WLS0 | LCR_WLS1, FFLCR);
- FFIER = IER_UUE; /* Enable FFUART */ + writel(IER_UUE, FFIER); /* Enable FFUART */ break;
case BTUART_INDEX: #ifdef CONFIG_CPU_MONAHANS - CKENA |= CKENA_21_BTUART; + writel(readl(CKENA) | CKENA_21_BTUART, CKENA); #else - CKEN |= CKEN7_BTUART; + writel(readl(CKEN) | CKEN7_BTUART, CKEN); #endif /* CONFIG_CPU_MONAHANS */
- BTIER = 0; - BTFCR = 0; + writel(0, BTIER); + writel(0, BTFCR);
/* set baud rate */ - BTLCR = LCR_DLAB; - BTDLL = quot & 0xff; - BTDLH = quot >> 8; - BTLCR = LCR_WLS0 | LCR_WLS1; + writel(LCR_DLAB, BTLCR); + writel(quot & 0xff, BTDLL); + writel(quot >> 8, BTDLH); + writel(LCR_WLS0 | LCR_WLS1, BTLCR);
- BTIER = IER_UUE; /* Enable BFUART */ + writel(IER_UUE, BTIER); /* Enable BFUART */
break;
case STUART_INDEX: #ifdef CONFIG_CPU_MONAHANS - CKENA |= CKENA_23_STUART; + writel(readl(CKENA) | CKENA_23_STUART, CKENA); #else - CKEN |= CKEN5_STUART; + writel(readl(CKEN) | CKEN5_STUART, CKEN); #endif /* CONFIG_CPU_MONAHANS */
- STIER = 0; - STFCR = 0; + writel(0, STIER); + writel(0, STFCR);
/* set baud rate */ - STLCR = LCR_DLAB; - STDLL = quot & 0xff; - STDLH = quot >> 8; - STLCR = LCR_WLS0 | LCR_WLS1; + writel(LCR_DLAB, STLCR); + writel(quot & 0xff, STDLL); + writel(quot >> 8, STDLH); + writel(LCR_WLS0 | LCR_WLS1, STLCR);
- STIER = IER_UUE; /* Enable STUART */ + writel(IER_UUE, STIER); /* Enable STUART */ break;
default: @@ -156,21 +157,21 @@ void pxa_putc_dev (unsigned int uart_index,const char c) switch (uart_index) { case FFUART_INDEX: /* wait for room in the tx FIFO on FFUART */ - while ((FFLSR & LSR_TEMT) == 0) + while ((readl(FFLSR) & LSR_TEMT) == 0) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - FFTHR = c; + writel(c, FFTHR); break;
case BTUART_INDEX: - while ((BTLSR & LSR_TEMT ) == 0 ) + while ((readl(BTLSR) & LSR_TEMT) == 0) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - BTTHR = c; + writel(c, BTTHR); break;
case STUART_INDEX: - while ((STLSR & LSR_TEMT ) == 0 ) + while ((readl(STLSR) & LSR_TEMT) == 0) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - STTHR = c; + writel(c, STTHR); break; }
@@ -188,11 +189,11 @@ int pxa_tstc_dev (unsigned int uart_index) { switch (uart_index) { case FFUART_INDEX: - return FFLSR & LSR_DR; + return readl(FFLSR) & LSR_DR; case BTUART_INDEX: - return BTLSR & LSR_DR; + return readl(BTLSR) & LSR_DR; case STUART_INDEX: - return STLSR & LSR_DR; + return readl(STLSR) & LSR_DR; } return -1; } @@ -206,18 +207,21 @@ int pxa_getc_dev (unsigned int uart_index) { switch (uart_index) { case FFUART_INDEX: - while (!(FFLSR & LSR_DR)) - WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - return (char) FFRBR & 0xff; + while (!(readl(FFLSR) & LSR_DR)) + /* Reset HW Watchdog, if needed */ + WATCHDOG_RESET(); + return (char) readl(FFRBR) & 0xff;
case BTUART_INDEX: - while (!(BTLSR & LSR_DR)) - WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - return (char) BTRBR & 0xff; + while (!(readl(BTLSR) & LSR_DR)) + /* Reset HW Watchdog, if needed */ + WATCHDOG_RESET(); + return (char) readl(BTRBR) & 0xff; case STUART_INDEX: - while (!(STLSR & LSR_DR)) - WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - return (char) STRBR & 0xff; + while (!(readl(STLSR) & LSR_DR)) + /* Reset HW Watchdog, if needed */ + WATCHDOG_RESET(); + return (char) readl(STRBR) & 0xff; } return -1; } diff --git a/include/configs/cradle.h b/include/configs/cradle.h index 200b61e..998e179 100644 --- a/include/configs/cradle.h +++ b/include/configs/cradle.h @@ -339,8 +339,6 @@ #define LED_IRDA1 2 #define LED_IRDA2 4 #define LED_IRDA3 6 -#define CRADLE_LED_SET_REG GPSR2 -#define CRADLE_LED_CLR_REG GPCR2
/* SuperIO defines */ #define CRADLE_SIO_INDEX 0x2e diff --git a/include/configs/delta.h b/include/configs/delta.h index 9c46c5b..d930fb4 100644 --- a/include/configs/delta.h +++ b/include/configs/delta.h @@ -28,6 +28,7 @@ * (easy to change) */ #define CONFIG_CPU_MONAHANS 1 /* Intel Monahan CPU */ +#define CONFIG_CPU_PXA320 #define CONFIG_DELTA 1 /* Delta board */
/* #define CONFIG_LCD 1 */ diff --git a/include/configs/zylonite.h b/include/configs/zylonite.h index d0fc138..c8aa046 100644 --- a/include/configs/zylonite.h +++ b/include/configs/zylonite.h @@ -35,6 +35,7 @@ * (easy to change) */ #define CONFIG_CPU_MONAHANS 1 /* Intel Monahan CPU */ +#define CONFIG_CPU_PXA320 #define CONFIG_ZYLONITE 1 /* Zylonite board */
Dear Marek Vasut,
In message 1285226769-9619-2-git-send-email-marek.vasut@gmail.com you wrote:
Signed-off-by: Marek Vasut marek.vasut@gmail.com
- debug("FDADR0 = 0x%08x\n", (unsigned int)readl(FDADR0));
- debug("FDADR1 = 0x%08x\n", (unsigned int)readl(FDADR1));
- debug("LCCR0 = 0x%08x\n", (unsigned int)readl(LCCR0));
- debug("LCCR1 = 0x%08x\n", (unsigned int)readl(LCCR1));
- debug("LCCR2 = 0x%08x\n", (unsigned int)readl(LCCR2));
- debug("LCCR3 = 0x%08x\n", (unsigned int)readl(LCCR3));
Is there a specific reason for the "(unsigned int)" cast? Using a "0x%08lx" format would seem more logical to me?
diff --git a/arch/arm/include/asm/arch-pxa/pxa-regs.h b/arch/arm/include/asm/arch-pxa/pxa-regs.h index d442fb0..4eefff2 100644 --- a/arch/arm/include/asm/arch-pxa/pxa-regs.h +++ b/arch/arm/include/asm/arch-pxa/pxa-regs.h
+#define DCSR0 (0x40000000) /* DMA Control / Status Register for Channel 0 */ +#define DCSR1 (0x40000004) /* DMA Control / Status Register for Channel 1 */ +#define DCSR2 (0x40000008) /* DMA Control / Status Register for Channel 2 */ +#define DCSR3 (0x4000000c) /* DMA Control / Status Register for Channel 3 */ +#define DCSR4 (0x40000010) /* DMA Control / Status Register for Channel 4 */ +#define DCSR5 (0x40000014) /* DMA Control / Status Register for Channel 5 */ +#define DCSR6 (0x40000018) /* DMA Control / Status Register for Channel 6 */ +#define DCSR7 (0x4000001c) /* DMA Control / Status Register for Channel 7 */ +#define DCSR8 (0x40000020) /* DMA Control / Status Register for Channel 8 */ +#define DCSR9 (0x40000024) /* DMA Control / Status Register for Channel 9 */ +#define DCSR10 (0x40000028) /* DMA Control / Status Register for Channel 10 */ +#define DCSR11 (0x4000002c) /* DMA Control / Status Register for Channel 11 */ +#define DCSR12 (0x40000030) /* DMA Control / Status Register for Channel 12 */ +#define DCSR13 (0x40000034) /* DMA Control / Status Register for Channel 13 */ +#define DCSR14 (0x40000038) /* DMA Control / Status Register for Channel 14 */ +#define DCSR15 (0x4000003c) /* DMA Control / Status Register for Channel 15 */
No parens needed for plain numbers. Please fix globally.
Do you plan to convert this (and the others) into a proper C struct?
+///*#define SACR0 (0x40400000) / Global Control Register */ +///*#define SACR1 (0x40400004) / Serial Audio I 2 S/MSB-Justified Control Register */ +///*#define SASR0 (0x4040000C) / Serial Audio I 2 S/MSB-Justified Interface and FIFO Status Register */ +///*#define SAIMR (0x40400014) / Serial Audio Interrupt Mask Register */ +///*#define SAICR (0x40400018) / Serial Audio Interrupt Clear Register */ +///*#define SADIV (0x40400060) / Audio Clock Divider Register. */ +///*#define SADR (0x40400080) / Serial Audio Data Register (TX and RX FIFO access Register). */
C++ comments are not allowed.
Please remove dead code.
ACX517AKN LCD panel is found in Palm Tungsten|C
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxafb.c | 34 ++++++++++++++++++++++++++++++++++ 1 files changed, 34 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index d73f765..499f5cf 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -216,6 +216,40 @@ vidinfo_t panel_info = {
+#ifdef CONFIG_ACX517AKN + +# define LCD_BPP LCD_COLOR8 + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x003008f9 +# define REG_LCCR3 0x03700006 + +vidinfo_t panel_info = { + .vl_col = 320, + .vl_row = 320, + .vl_width = 320, + .vl_height = 320, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_LOW, + .vl_hsp = CONFIG_SYS_LOW, + .vl_vsp = CONFIG_SYS_LOW, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 1, + .vl_hpw = 0x04, + .vl_blw = 0x1c, + .vl_elw = 0x08, + .vl_vpw = 0x01, + .vl_bfw = 0x07, + .vl_efw = 0x08, +}; +#endif /* CONFIG_ACX517AKN */ + +/*----------------------------------------------------------------------*/ + #if LCD_BPP == LCD_COLOR8 void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue); #endif
This LCD panel is found in Palm LifeDrive handheld
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 499f5cf..d8a86a1 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -250,6 +250,40 @@ vidinfo_t panel_info = {
+#ifdef CONFIG_LQ038J7DH53 + +# define LCD_BPP LCD_COLOR8 + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x003008f9 +# define REG_LCCR3 0x03700004 + +vidinfo_t panel_info = { + .vl_col = 320, + .vl_row = 480, + .vl_width = 320, + .vl_height = 480, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_LOW, + .vl_hsp = CONFIG_SYS_LOW, + .vl_vsp = CONFIG_SYS_LOW, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 1, + .vl_hpw = 0x04, + .vl_blw = 0x20, + .vl_elw = 0x01, + .vl_vpw = 0x01, + .vl_bfw = 0x04, + .vl_efw = 0x01, +}; +#endif /* CONFIG_ACX517AKN */ + +/*----------------------------------------------------------------------*/ + #if LCD_BPP == LCD_COLOR8 void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue); #endif
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- common/serial.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/serial.c b/common/serial.c index 1345c08..3edeff9 100644 --- a/common/serial.c +++ b/common/serial.c @@ -30,7 +30,7 @@ DECLARE_GLOBAL_DATA_PTR; static struct serial_device *serial_devices = NULL; static struct serial_device *serial_current = NULL;
-#if !defined(CONFIG_LWMON) && !defined(CONFIG_PXA27X) +#if !defined(CONFIG_LWMON) && !defined(CONFIG_PXA27X) && !defined(CONFIG_PXA250) struct serial_device *__default_serial_console (void) { #if defined(CONFIG_8xx_CONS_SMC1) || defined(CONFIG_8xx_CONS_SMC2)
Dear Marek Vasut,
Please keep list sorted. Thanks.
This patch adds support for the Palm Tungsten|C PXA255 board. The support includes: - LCD - MMC - UART - NOR
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 4 + board/palmtc/Makefile | 49 +++++++++ board/palmtc/config.mk | 1 + board/palmtc/lowlevel_init.S | 39 +++++++ board/palmtc/palmtc.c | 59 ++++++++++ board/palmtc/u-boot.lds | 56 ++++++++++ boards.cfg | 1 + include/configs/palmtc.h | 245 ++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 454 insertions(+), 0 deletions(-) create mode 100644 board/palmtc/Makefile create mode 100644 board/palmtc/config.mk create mode 100644 board/palmtc/lowlevel_init.S create mode 100644 board/palmtc/palmtc.c create mode 100644 board/palmtc/u-boot.lds create mode 100644 include/configs/palmtc.h
diff --git a/MAINTAINERS b/MAINTAINERS index 0c6ce2b..5e1da95 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -793,6 +793,10 @@ Greg Ungerer greg.ungerer@opengear.com cm4116 ks8695p cm4148 ks8695p
+Marek Vasut marek.vasut@gmail.com + + palmtc xscale + Hugo Villeneuve hugo.villeneuve@lyrtech.com
SFFSDR ARM926EJS diff --git a/board/palmtc/Makefile b/board/palmtc/Makefile new file mode 100644 index 0000000..20ac4e1 --- /dev/null +++ b/board/palmtc/Makefile @@ -0,0 +1,49 @@ +# +# Palm Tungsten|C Support +# +# Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := palmtc.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/palmtc/config.mk b/board/palmtc/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/palmtc/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/palmtc/lowlevel_init.S b/board/palmtc/lowlevel_init.S new file mode 100644 index 0000000..74050dc --- /dev/null +++ b/board/palmtc/lowlevel_init.S @@ -0,0 +1,39 @@ +/* + * Palm Tungsten|C Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/palmtc/palmtc.c b/board/palmtc/palmtc.c new file mode 100644 index 0000000..04cb33e --- /dev/null +++ b/board/palmtc/palmtc.c @@ -0,0 +1,59 @@ +/* + * Palm Tungsten|C Support + * + * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <serial.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init(void) +{ + /* Arch number of Palm Tungsten|C */ + gd->bd->bi_arch_number = MACH_TYPE_PALMTC; + + /* Adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Set PWM for LCD */ + writel(0x5f, PWM_CTRL1); + writel(0x3ff, PWM_PERVAL1); + writel(892, PWM_PWDUTY1); + + return 0; +} + +struct serial_device *default_serial_console(void) +{ + return &serial_ffuart_device; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + return 0; +} diff --git a/board/palmtc/u-boot.lds b/board/palmtc/u-boot.lds new file mode 100644 index 0000000..fb4358b --- /dev/null +++ b/board/palmtc/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2000-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index 0fe1c89..ac97e1a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -60,6 +60,7 @@ delta arm pxa innokom arm pxa logodl arm pxa lubbock arm pxa +palmtc arm pxa pleb2 arm pxa xaeniax arm pxa xm250 arm pxa diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h new file mode 100644 index 0000000..f4fc9cd --- /dev/null +++ b/include/configs/palmtc.h @@ -0,0 +1,245 @@ +/* + * Palm Tungsten|C configuration file + * + * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/pxa-regs.h> + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA250 1 /* Intel PXA255 CPU */ +#define CONFIG_PALMTC 1 /* Palm Tungsten|C board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if mmc init && fatload mmc 0 0xa0000000 uboot.script ; then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x80000; " \ + "fi; " +#define CONFIG_BOOTARGS \ + "console=tty0 console=ttyS0,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + * STUART - the lower serial port on Colibri board + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#define CONFIG_CMD_MMC +#define CONFIG_LCD + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_PXA_MMC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#endif + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_ACX517AKN +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " +#else +#define CONFIG_SYS_PROMPT "=> " +#endif +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3686400 /* Timer @ 3686400 Hz */ +#define CONFIG_SYS_CPUSPEED 0x161 /* 400MHz;L=1 M=3 T=1 */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x04000000 /* 64 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x01000000 /* 16 MB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 64 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR 0x40000 + +/* + * GPIO settings + */ +#define CONFIG_SYS_GAFR0_L_VAL 0x00011004 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5000008 +#define CONFIG_SYS_GAFR1_L_VAL 0x60888050 +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa50aaa +#define CONFIG_SYS_GAFR2_L_VAL 0x0aaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x00000000 +#define CONFIG_SYS_GPCR0_VAL 0x0 +#define CONFIG_SYS_GPCR1_VAL 0x0 +#define CONFIG_SYS_GPCR2_VAL 0x0 +#define CONFIG_SYS_GPDR0_VAL 0xcfff8140 +#define CONFIG_SYS_GPDR1_VAL 0xfcbfbef3 +#define CONFIG_SYS_GPDR2_VAL 0x0001ffff +#define CONFIG_SYS_GPSR0_VAL 0x00010f8f +#define CONFIG_SYS_GPSR1_VAL 0x00bf5de5 +#define CONFIG_SYS_GPSR2_VAL 0x03fe0800 + +#define CONFIG_SYS_PSSR_VAL PSSR_RDH + +/* Clock setup: + * CKEN[1] - PWM1 ; CKEN[6] - FFUART + * CKEN[12] - MMC ; CKEN[16] - LCD + */ +#define CONFIG_SYS_CKEN 0x00011042 +#define CONFIG_SYS_CCCR 0x00000161 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x800092c2 +#define CONFIG_SYS_MSC1_VAL 0x80008000 +#define CONFIG_SYS_MSC2_VAL 0x80008000 +#define CONFIG_SYS_MDCNFG_VAL 0x00001ac9 +#define CONFIG_SYS_MDREFR_VAL 0x00118018 +#define CONFIG_SYS_MDMRS_VAL 0x00220032 +#define CONFIG_SYS_FLYCNFG_VAL 0x01fe01fe +#define CONFIG_SYS_SXCNFG_VAL 0x00000000 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00010504 +#define CONFIG_SYS_MCMEM1_VAL 0x00010504 +#define CONFIG_SYS_MCATT0_VAL 0x00010504 +#define CONFIG_SYS_MCATT1_VAL 0x00010504 +#define CONFIG_SYS_MCIO0_VAL 0x00010e04 +#define CONFIG_SYS_MCIO1_VAL 0x00010e04 + +#endif /* __CONFIG_H */
Dear Marek Vasut,
- LCD
- MMC
- UART
- NOR
- Clock Configuration
Please do not undef what is not defined.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 1 + board/palmld/Makefile | 49 ++++++++ board/palmld/config.mk | 1 + board/palmld/lowlevel_init.S | 45 +++++++ board/palmld/palmld.c | 69 +++++++++++ board/palmld/u-boot.lds | 56 +++++++++ boards.cfg | 1 + include/configs/palmld.h | 273 ++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 495 insertions(+), 0 deletions(-) create mode 100644 board/palmld/Makefile create mode 100644 board/palmld/config.mk create mode 100644 board/palmld/lowlevel_init.S create mode 100644 board/palmld/palmld.c create mode 100644 board/palmld/u-boot.lds create mode 100644 include/configs/palmld.h
diff --git a/MAINTAINERS b/MAINTAINERS index 5e1da95..c6fe1d3 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -795,6 +795,7 @@ Greg Ungerer greg.ungerer@opengear.com
+ palmld xscale palmtc xscale
Hugo Villeneuve hugo.villeneuve@lyrtech.com diff --git a/board/palmld/Makefile b/board/palmld/Makefile new file mode 100644 index 0000000..bcb014d --- /dev/null +++ b/board/palmld/Makefile @@ -0,0 +1,49 @@ +# +# Palm LifeDrive Support +# +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := palmld.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/palmld/config.mk b/board/palmld/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/palmld/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/palmld/lowlevel_init.S b/board/palmld/lowlevel_init.S new file mode 100644 index 0000000..e3382ee --- /dev/null +++ b/board/palmld/lowlevel_init.S @@ -0,0 +1,45 @@ +/* + * Palm LifeDrive Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + + /* Enable GPIO reset */ + ldr r0, =PCFR + mov r1, #0x30 + str r1, [r0] + + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/palmld/palmld.c b/board/palmld/palmld.c new file mode 100644 index 0000000..4f0087e --- /dev/null +++ b/board/palmld/palmld.c @@ -0,0 +1,69 @@ +/* + * Palm LifeDrive Support + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <serial.h> +#include <asm/arch/pxa-regs.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init(void) +{ + /* arch number of Lubbock-Board */ + gd->bd->bi_arch_number = MACH_TYPE_PALMLD; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Set PWM for LCD */ + writel(0x7, PWM_CTRL0); + writel(0x16c, PWM_PERVAL0); + writel(0x11a, PWM_PWDUTY0); + + return 0; +} + +struct serial_device *default_serial_console(void) +{ + return &serial_ffuart_device; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) +{ + info->portwidth = FLASH_CFI_16BIT; + info->chipwidth = FLASH_CFI_BY16; + info->interface = FLASH_CFI_X16; + return 1; +} diff --git a/board/palmld/u-boot.lds b/board/palmld/u-boot.lds new file mode 100644 index 0000000..fb4358b --- /dev/null +++ b/board/palmld/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2000-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index ac97e1a..4988408 100644 --- a/boards.cfg +++ b/boards.cfg @@ -60,6 +60,7 @@ delta arm pxa innokom arm pxa logodl arm pxa lubbock arm pxa +palmld arm pxa palmtc arm pxa pleb2 arm pxa xaeniax arm pxa diff --git a/include/configs/palmld.h b/include/configs/palmld.h new file mode 100644 index 0000000..affc116 --- /dev/null +++ b/include/configs/palmld.h @@ -0,0 +1,273 @@ +/* + * Palm LifeDrive configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_PALMLD 1 /* Palm LifeDrive board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if mmcinfo && fatload mmc 0 0xa0000000 uboot.script ; then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x0x60000; " \ + "fi; " +#define CONFIG_BOOTARGS "console=tty0 console=ttyS0,9600" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 9600 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_MMC +#define CONFIG_CMD_IDE +#define CONFIG_LCD + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#endif + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_LQ038J7DH53 +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " +#else +#define CONFIG_SYS_PROMPT "=> " +#endif +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x210 /* 416MHz ; N=2,L=16 */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x02000000 /* 32 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00080000 /* 512 KB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 + +#define CONFIG_FLASH_CFI_LEGACY +#define CONFIG_SYS_FLASH_LEGACY_512Kx16 + +#define CONFIG_SYS_MONITOR_BASE 0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#endif + +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SIZE 0x4000 + +/* + * IDE + */ +#ifdef CONFIG_CMD_IDE +#define CONFIG_LBA48 +#undef CONFIG_IDE_LED +#undef CONFIG_IDE_RESET + +#define __io + +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 + +#define CONFIG_SYS_ATA_BASE_ADDR 0x20000000 +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 + +#define CONFIG_SYS_ATA_DATA_OFFSET 0x10 +#define CONFIG_SYS_ATA_REG_OFFSET 0x10 +#define CONFIG_SYS_ATA_ALT_OFFSET 0x10 + +#define CONFIG_SYS_ATA_STRIDE 1 +#endif + +/* + * GPIO settings + */ +#define CONFIG_SYS_GAFR0_L_VAL 0x00000000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5180012 +#define CONFIG_SYS_GAFR1_L_VAL 0x69988056 +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa580aa +#define CONFIG_SYS_GAFR2_L_VAL 0x6aaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x01040001 +#define CONFIG_SYS_GAFR3_L_VAL 0x540a950c +#define CONFIG_SYS_GAFR3_U_VAL 0x00000009 +#define CONFIG_SYS_GPCR0_VAL 0x00000000 +#define CONFIG_SYS_GPCR1_VAL 0x00000000 +#define CONFIG_SYS_GPCR2_VAL 0x00000000 +#define CONFIG_SYS_GPCR3_VAL 0x00000000 +#define CONFIG_SYS_GPDR0_VAL 0xc26b0000 +#define CONFIG_SYS_GPDR1_VAL 0xfcdfaa93 +#define CONFIG_SYS_GPDR2_VAL 0x7bbaffff +#define CONFIG_SYS_GPDR3_VAL 0x006ff38d +#define CONFIG_SYS_GPSR0_VAL 0x0d9e45ee +#define CONFIG_SYS_GPSR1_VAL 0x03affdae +#define CONFIG_SYS_GPSR2_VAL 0x07554000 +#define CONFIG_SYS_GPSR3_VAL 0x01bc0785 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0x01ffffff +#define CONFIG_SYS_CCCR 0x02000210 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x7ff844c8 +#define CONFIG_SYS_MSC1_VAL 0x7ff86ab4 +#define CONFIG_SYS_MSC2_VAL 0x7ff87ff8 +#define CONFIG_SYS_MDCNFG_VAL 0x0B880acd +#define CONFIG_SYS_MDREFR_VAL 0x201fa031 +#define CONFIG_SYS_MDMRS_VAL 0x00320032 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x40044004 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000003 +#define CONFIG_SYS_MCMEM0_VAL 0x0001c391 +#define CONFIG_SYS_MCMEM1_VAL 0x0001c391 +#define CONFIG_SYS_MCATT0_VAL 0x0001c391 +#define CONFIG_SYS_MCATT1_VAL 0x0001c391 +#define CONFIG_SYS_MCIO0_VAL 0x00014611 +#define CONFIG_SYS_MCIO1_VAL 0x0001c391 + +#endif /* __CONFIG_H */
Dear Marek Vasut,
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 1 + MAKEALL | 3 +- Makefile | 7 ++- board/vpac270/Makefile | 7 +-- board/vpac270/lowlevel_init.S | 1 - board/vpac270/vpac270.c | 44 ++++++----------- include/configs/vpac270.h | 106 +++++++++++++++++++++++----------------- 7 files changed, 88 insertions(+), 81 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index c6fe1d3..7ba4b8b 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -797,6 +797,7 @@ Marek Vasut marek.vasut@gmail.com
palmld xscale palmtc xscale + vpac270 xscale
diff --git a/MAKEALL b/MAKEALL index 1b506d6..9dd3636 100755 --- a/MAKEALL +++ b/MAKEALL @@ -546,7 +546,8 @@ LIST_at91=" \ LIST_pxa="$(boards_by_cpu pxa) polaris \ trizepsiv \ - vpac270_nor \ + vpac270_nor_128M\ + vpac270_nor_256M\ vpac270_onenand \ "
diff --git a/Makefile b/Makefile index 84947d0..e62d0cc 100644 --- a/Makefile +++ b/Makefile @@ -2187,13 +2187,18 @@ trizepsiv_config : unconfig fi; @$(MKCONFIG) -n $@ -a trizepsiv arm pxa trizepsiv
-vpac270_nor_config \ +vpac270_nor_256M_config \ +vpac270_nor_128M_config \ vpac270_onenand_config : unconfig @mkdir -p $(obj)include @if [ "$(findstring onenand,$@)" ] ; then \ echo "#define CONFIG_ONENAND_U_BOOT" \ >>$(obj)include/config.h ; \ fi; + @if [ "$(findstring 256M,$@)" ] ; then \ + echo "#define CONFIG_256M_U_BOOT" \ + >>$(obj)include/config.h ; \ + fi; @$(MKCONFIG) -n $@ -a vpac270 arm pxa vpac270
######################################################################### diff --git a/board/vpac270/Makefile b/board/vpac270/Makefile index c6f4c7c..f5014fc 100644 --- a/board/vpac270/Makefile +++ b/board/vpac270/Makefile @@ -1,10 +1,7 @@ - # -# (C) Copyright 2000 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Voipac PXA270 Support # -# See file CREDITS for list of people who contributed to this -# project. +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com # # This program is free software; you can redistribute it and/or # modify it under the terms of the GNU General Public License as diff --git a/board/vpac270/lowlevel_init.S b/board/vpac270/lowlevel_init.S index ec0d12c..c40d12f 100644 --- a/board/vpac270/lowlevel_init.S +++ b/board/vpac270/lowlevel_init.S @@ -3,7 +3,6 @@ * * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com * - * * See file CREDITS for list of people who contributed to this * project. * diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index f792298..1557d1b 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -1,16 +1,7 @@ /* - * (C) Copyright 2004 - * Robert Whaley, Applied Data Systems, Inc. rwhaley@applieddata.net + * Voipac PXA270 Support * - * (C) Copyright 2002 - * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * See file CREDITS for list of people who contributed to this - * project. + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -36,26 +27,15 @@
-/* ------------------------------------------------------------------------- */ - /* * Miscelaneous platform dependent initialisations */ -extern struct serial_device serial_ffuart_device; -extern struct serial_device serial_btuart_device; -extern struct serial_device serial_stuart_device; - -struct serial_device *default_serial_console (void) -{ - return &serial_ffuart_device; -} - -int board_init (void) +int board_init(void) { /* memory and cpu-speed are setup before relocation */ /* so we do _nothing_ here */
- /* arch number of vpac270 */ + /* Arch number of vpac270 */ gd->bd->bi_arch_number = MACH_TYPE_VPAC270;
/* adress of boot parameters */ @@ -64,17 +44,24 @@ int board_init (void) return 0; }
-int dram_init (void) +struct serial_device *default_serial_console(void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + return &serial_ffuart_device; +}
+int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE;
+#ifdef CONFIG_256M_U_BOOT + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; +#endif return 0; }
+#ifdef CONFIG_CMD_USB int usb_board_init(void) { writel((UHCHR | UHCHR_PCPL | UHCHR_PSPL) & @@ -124,6 +111,7 @@ void usb_board_stop(void)
return; } +#endif
#ifdef CONFIG_DRIVER_DM9000 int board_eth_init(bd_t *bis) diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index d3e22d9..694a8f9 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -10,7 +10,7 @@ * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License @@ -19,8 +19,8 @@ * MA 02111-1307 USA */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_H +#define __CONFIG_H
/* * High Level Board Configuration Options @@ -28,20 +28,13 @@ #define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ #define CONFIG_VPAC270 1 /* Voipac PXA270 board */
-#undef BOARD_LATE_INIT -#undef CONFIG_SKIP_RELOCATE_UBOOT -#undef CONFIG_USE_IRQ -#undef CONFIG_SKIP_LOWLEVEL_INIT - /* * Environment settings */ -#define CONFIG_ENV_SIZE 0x4000 -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) #define CONFIG_SYS_GBL_DATA_SIZE 128
-#define CONFIG_ENV_OVERWRITE /* override default environment */ - #define CONFIG_BOOTCOMMAND \ "if mmc init && fatload mmc 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ @@ -49,6 +42,9 @@ "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ "fi; " \ + "if ide reset && fatload ide 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ "bootm 0x40000;" #define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" #define CONFIG_TIMESTAMP @@ -97,9 +93,9 @@
#define CONFIG_NET_MULTI 1 #define CONFIG_DRIVER_DM9000 1 -#define CONFIG_DM9000_BASE 0x08000300 /* CS2 */ -#define DM9000_IO (CONFIG_DM9000_BASE) -#define DM9000_DATA (CONFIG_DM9000_BASE + 4) +#define CONFIG_DM9000_BASE 0x08000300 /* CS2 */ +#define DM9000_IO (CONFIG_DM9000_BASE) +#define DM9000_DATA (CONFIG_DM9000_BASE + 4) #define CONFIG_NET_RETRY_COUNT 10
#define CONFIG_BOOTP_BOOTFILESIZE @@ -116,6 +112,7 @@ #define CONFIG_PXA_MMC #define CONFIG_SYS_MMC_BASE 0xF0000000 #define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #endif
@@ -123,8 +120,8 @@ * KGDB */ #ifdef CONFIG_CMD_KGDB -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif
/* @@ -133,16 +130,17 @@ #define CONFIG_SYS_HUSH_PARSER 1 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
-#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LONGHELP #ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "$ " #else -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "=> " #endif -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_DEVICE_NULLDEV 1
/* @@ -150,12 +148,10 @@ */ #undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ -#define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ +#define CONFIG_SYS_CPUSPEED 0x190 /* 312MHz */
/* * Stack sizes - * - * The stack sizes are set up in start.S using the settings below */ #define CONFIG_STACKSIZE (128*1024) /* regular stack */ #ifdef CONFIG_USE_IRQ @@ -166,17 +162,24 @@ /* * DRAM Map */ -#define CONFIG_NR_DRAM_BANKS 2 /* We have 2 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 2 /* 2 banks of DRAM */ #define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ + +#ifdef CONFIG_256M_U_BOOT #define PHYS_SDRAM_2 0x80000000 /* SDRAM Bank #2 */ #define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ +#endif
#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_DRAM_SIZE 0x10000000 /* 256 MB DRAM */ +#else +#define CONFIG_SYS_DRAM_SIZE 0x08000000 /* 128 MB DRAM */ +#endif
-#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
#define CONFIG_SYS_LOAD_ADDR (0x5c000000)
@@ -185,14 +188,22 @@ */ #if defined(CONFIG_CMD_FLASH) /* NOR */ #define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ + +#ifdef CONFIG_256M_U_BOOT #define PHYS_FLASH_2 0x02000000 /* Flash Bank #2 */ +#endif
#define CONFIG_SYS_FLASH_CFI #define CONFIG_FLASH_CFI_DRIVER 1
#define CONFIG_SYS_MAX_FLASH_SECT (4 + 255) +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_MAX_FLASH_BANKS 2 #define CONFIG_SYS_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2 } +#else +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#endif
#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) #define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) @@ -200,25 +211,26 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 #define CONFIG_SYS_FLASH_PROTECTION 1
-#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x4000
#elif defined(CONFIG_CMD_ONENAND) /* OneNAND */ #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_ONENAND_BASE 0x00000000 + #define CONFIG_ENV_IS_IN_ONENAND 1 +#define CONFIG_ENV_SECT_SIZE 0x20000
#else /* No flash */ #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_ENV_IS_NOWHERE #endif
-#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_BASE 0x0 #define CONFIG_SYS_MONITOR_LEN 0x40000
-#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x40000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SIZE 0x4000
/* * IDE @@ -230,15 +242,15 @@
#define __io
-#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1
-#define CONFIG_SYS_ATA_BASE_ADDR 0x0c000000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 +#define CONFIG_SYS_ATA_BASE_ADDR 0x0c000000 +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0
-#define CONFIG_SYS_ATA_DATA_OFFSET 0x120 -#define CONFIG_SYS_ATA_REG_OFFSET 0x120 -#define CONFIG_SYS_ATA_ALT_OFFSET 0x120 +#define CONFIG_SYS_ATA_DATA_OFFSET 0x120 +#define CONFIG_SYS_ATA_REG_OFFSET 0x120 +#define CONFIG_SYS_ATA_ALT_OFFSET 0x120
#define CONFIG_SYS_ATA_STRIDE 2 #endif @@ -284,7 +296,11 @@ #define CONFIG_SYS_MSC0_VAL 0x3ffc95fa #define CONFIG_SYS_MSC1_VAL 0x02ccf974 #define CONFIG_SYS_MSC2_VAL 0x00000000 +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_MDCNFG_VAL 0x8ad30ad3 +#else +#define CONFIG_SYS_MDCNFG_VAL 0x88000ad3 +#endif #define CONFIG_SYS_MDREFR_VAL 0x201fe01e #define CONFIG_SYS_MDMRS_VAL 0x00000000 #define CONFIG_SYS_FLYCNFG_VAL 0x00000000 @@ -306,13 +322,13 @@ * LCD */ #ifdef CONFIG_LCD -#define CONFIG_VOIPAC_LCD +#define CONFIG_VOIPAC_LCD #endif
/* * USB */ -#ifdef CONFIG_CMD_USB +#ifdef CONFIG_CMD_USB #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_BOARD_INIT
Dear Marek Vasut,
- vpac270 xscale
- vpac270_nor \
- vpac270_nor_128M\
- vpac270_nor_256M\ vpac270_onenand \
We do not accept such additions to MAKEALL any more. This shouldbe handled through boards.cfg; see previous discussion.
Ditto.
- (C) Copyright 2004
- Robert Whaley, Applied Data Systems, Inc. rwhaley@applieddata.net
- Voipac PXA270 Support
- (C) Copyright 2002
- Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net
- Sysgo Real-Time Solutions, GmbH <www.elinos.com>
- Marius Groeger mgroeger@sysgo.de
- project.
- Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com
I guess this file was originally copied from some other source? Why is it OK to remove the original Copyrights?
The following hardware is currently supported: - UART - USB Host - FPGA
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 1 + board/balloon3/Makefile | 49 +++++++ board/balloon3/balloon3.c | 228 ++++++++++++++++++++++++++++++++++ board/balloon3/config.mk | 1 + board/balloon3/lowlevel_init.S | 36 ++++++ board/balloon3/u-boot.lds | 55 ++++++++ boards.cfg | 1 + include/configs/balloon3.h | 269 ++++++++++++++++++++++++++++++++++++++++ 8 files changed, 640 insertions(+), 0 deletions(-) create mode 100644 board/balloon3/Makefile create mode 100644 board/balloon3/balloon3.c create mode 100644 board/balloon3/config.mk create mode 100644 board/balloon3/lowlevel_init.S create mode 100644 board/balloon3/u-boot.lds create mode 100644 include/configs/balloon3.h
diff --git a/MAINTAINERS b/MAINTAINERS index 7ba4b8b..78e62f0 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -795,6 +795,7 @@ Greg Ungerer greg.ungerer@opengear.com
+ balloon3 xscale palmld xscale palmtc xscale vpac270 xscale diff --git a/board/balloon3/Makefile b/board/balloon3/Makefile new file mode 100644 index 0000000..3928e1f --- /dev/null +++ b/board/balloon3/Makefile @@ -0,0 +1,49 @@ +# +# Balloon3 Support +# +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := balloon3.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c new file mode 100644 index 0000000..2d6eabe --- /dev/null +++ b/board/balloon3/balloon3.c @@ -0,0 +1,228 @@ +/* + * Balloon3 Support + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <serial.h> +#include <asm/io.h> +#include <spartan3.h> +#include <command.h> + +DECLARE_GLOBAL_DATA_PTR; + +void balloon3_init_fpga(void); + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init(void) +{ + /* arch number of vpac270 */ + gd->bd->bi_arch_number = MACH_TYPE_BALLOON3; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Init the FPGA */ + balloon3_init_fpga(); + + return 0; +} + +struct serial_device *default_serial_console(void) +{ + return &serial_stuart_device; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[2].start = PHYS_SDRAM_3; + + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; + + return 0; +} + +#ifdef CONFIG_CMD_USB +int usb_board_init(void) +{ + writel((readl(UHCHR) | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE), + UHCHR); + + writel(readl(UHCHR) | UHCHR_FSBIR, UHCHR); + + while (readl(UHCHR) & UHCHR_FSBIR) + ; + + writel(readl(UHCHR) & ~UHCHR_SSE, UHCHR); + writel((UHCHIE_UPRIE | UHCHIE_RWIE), UHCHIE); + + /* Clear any OTG Pin Hold */ + if (readl(PSSR) & PSSR_OTGPH) + writel(readl(PSSR) | PSSR_OTGPH, PSSR); + + writel(readl(UHCRHDA) & ~(0x200), UHCRHDA); + writel(readl(UHCRHDA) | 0x100, UHCRHDA); + + /* Set port power control mask bits, only 3 ports. */ + writel(readl(UHCRHDB) | (0x7<<17), UHCRHDB); + + /* enable port 2 */ + writel(readl(UP2OCR) | UP2OCR_HXOE | UP2OCR_HXS | + UP2OCR_DMPDE | UP2OCR_DPPDE, UP2OCR); + + return 0; +} + +void usb_board_init_fail(void) +{ + return; +} + +void usb_board_stop(void) +{ + writel(readl(UHCHR) | UHCHR_FHR, UHCHR); + udelay(11); + writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR); + + writel(readl(UHCCOMS) | 1, UHCCOMS); + udelay(10); + + writel(readl(CKEN) & ~CKEN10_USBHOST, CKEN); + + return; +} +#endif + +#if defined(CONFIG_FPGA) +/* Toggle GPIO103 and GPIO104 -- PROGB and RDnWR */ +int fpga_pgm_fn(int nassert, int nflush, int cookie) +{ + if (nassert) + writel(0x80, GPCR3); + else + writel(0x80, GPSR3); + if (nflush) + writel(0x100, GPCR3); + else + writel(0x100, GPSR3); + return nassert; +} + +/* Check GPIO83 -- INITB */ +int fpga_init_fn(int cookie) +{ + return !(readl(GPLR2) & 0x80000); +} + +/* Check GPIO84 -- BUSY */ +int fpga_busy_fn(int cookie) +{ + return !(readl(GPLR2) & 0x100000); +} + +/* Check GPIO111 -- DONE */ +int fpga_done_fn(int cookie) +{ + return readl(GPLR3) & 0x8000; +} + +/* Configure GPIO104 as GPIO and deassert it */ +int fpga_pre_config_fn(int cookie) +{ + writel(readl(GAFR3_L) & ~0x30000, GAFR3_L); + writel(0x100, GPCR3); + return 0; +} + +/* Configure GPIO104 as nSKTSEL */ +int fpga_post_config_fn(int cookie) +{ + writel(readl(GAFR3_L) | 0x10000, GAFR3_L); + return 0; +} + +/* Toggle RDnWR */ +int fpga_wr_fn(int nassert_write, int flush, int cookie) +{ + udelay(1000); + + if (nassert_write) + writel(0x100, GPCR3); + else + writel(0x100, GPSR3); + + return nassert_write; +} + +/* Write program to the FPGA */ +int fpga_wdata_fn(uchar data, int flush, int cookie) +{ + writeb(data, 0x10f00000); + return 0; +} + +/* Toggle Clock pin -- NO-OP */ +int fpga_clk_fn(int assert_clk, int flush, int cookie) +{ + return assert_clk; +} + +/* Toggle ChipSelect pin -- NO-OP */ +int fpga_cs_fn(int assert_clk, int flush, int cookie) +{ + return assert_clk; +} + +Xilinx_Spartan3_Slave_Parallel_fns balloon3_fpga_fns = { + fpga_pre_config_fn, + fpga_pgm_fn, + fpga_init_fn, + NULL, /* err */ + fpga_done_fn, + fpga_clk_fn, + fpga_cs_fn, + fpga_wr_fn, + NULL, /* rdata */ + fpga_wdata_fn, + fpga_busy_fn, + NULL, /* abort */ + fpga_post_config_fn, +}; + +Xilinx_desc fpga = XILINX_XC3S1000_DESC(slave_parallel, + (void *)&balloon3_fpga_fns, 0); + +/* Initialize the FPGA */ +void balloon3_init_fpga(void) +{ + fpga_init(); + fpga_add(fpga_xilinx, &fpga); +} +#else +void balloon3_init_fpga(void) {} +#endif /* CONFIG_FPGA */ diff --git a/board/balloon3/config.mk b/board/balloon3/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/balloon3/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/balloon3/lowlevel_init.S b/board/balloon3/lowlevel_init.S new file mode 100644 index 0000000..d7b5be6 --- /dev/null +++ b/board/balloon3/lowlevel_init.S @@ -0,0 +1,36 @@ +/* + * Balloon3 Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/balloon3/u-boot.lds b/board/balloon3/u-boot.lds new file mode 100644 index 0000000..58c371d --- /dev/null +++ b/board/balloon3/u-boot.lds @@ -0,0 +1,55 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index 4988408..fec8885 100644 --- a/boards.cfg +++ b/boards.cfg @@ -52,6 +52,7 @@ actux2 arm ixp actux3 arm ixp actux4 arm ixp ixdp425 arm ixp +balloon3 arm pxa cerf250 arm pxa colibri_pxa270 arm pxa cradle arm pxa diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h new file mode 100644 index 0000000..9066a24 --- /dev/null +++ b/include/configs/balloon3.h @@ -0,0 +1,269 @@ +/* + * Balloon3 configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_BALLOON3 1 /* Balloon3 board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ + "bootm 0x40000;" +#define CONFIG_BOOTARGS "console=tty0 console=ttyS2,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_STUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_USB +#define CONFIG_CMD_FPGA +#undef CONFIG_LCD + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " +#else +#define CONFIG_SYS_PROMPT "=> " +#endif +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x290 /* 520MHz */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 3 /* 2 banks of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_2 0xb0000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_3 0x80000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_3_SIZE 0x08000000 /* 128 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x18000000 /* 384 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR 0xa1000000 + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00800000 /* 8 MB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_ENV_IS_IN_FLASH +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x10000 + +/* + * GPIO settings + */ +#define CONFIG_SYS_GPSR0_VAL 0x307dc7fd +#define CONFIG_SYS_GPSR1_VAL 0x03cffa4e +#define CONFIG_SYS_GPSR2_VAL 0x7131c000 +#define CONFIG_SYS_GPSR3_VAL 0x01e1f3ff + +#define CONFIG_SYS_GPCR0_VAL 0x0 +#define CONFIG_SYS_GPCR1_VAL 0x0 +#define CONFIG_SYS_GPCR2_VAL 0x0 +#define CONFIG_SYS_GPCR3_VAL 0x0 + +#define CONFIG_SYS_GPDR0_VAL 0xc0f98e02 +#define CONFIG_SYS_GPDR1_VAL 0xfcffa8b7 +#define CONFIG_SYS_GPDR2_VAL 0x22e3ffff +#define CONFIG_SYS_GPDR3_VAL 0x000201fe + +#define CONFIG_SYS_GAFR0_L_VAL 0x96c00000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5e5459b +#define CONFIG_SYS_GAFR1_L_VAL 0x699b759a +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa5a5aa +#define CONFIG_SYS_GAFR2_L_VAL 0xaaaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x01f9a6aa +#define CONFIG_SYS_GAFR3_L_VAL 0x54510003 +#define CONFIG_SYS_GAFR3_U_VAL 0x00001599 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0xffffffff +#define CONFIG_SYS_CCCR 0x00000290 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x7ff07ff8 +#define CONFIG_SYS_MSC1_VAL 0x7ff07ff0 +#define CONFIG_SYS_MSC2_VAL 0x74a42491 +#define CONFIG_SYS_MDCNFG_VAL 0x89d309d3 +#define CONFIG_SYS_MDREFR_VAL 0x001d8018 +#define CONFIG_SYS_MDMRS_VAL 0x00220022 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x00000000 +#define CONFIG_SYS_MEM_BUF_IMP 0x0f + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00014307 +#define CONFIG_SYS_MCMEM1_VAL 0x00014307 +#define CONFIG_SYS_MCATT0_VAL 0x0001c787 +#define CONFIG_SYS_MCATT1_VAL 0x0001c787 +#define CONFIG_SYS_MCIO0_VAL 0x0001430f +#define CONFIG_SYS_MCIO1_VAL 0x0001430f + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_BALLOON3LCD +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * USB + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_BOARD_INIT +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x4C000000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "balloon3" +#define CONFIG_USB_STORAGE +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#endif + +/* + * FPGA + */ +#ifdef CONFIG_CMD_FPGA +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_WAIT 1000 +#define CONFIG_MAX_FPGA_DEVICES 1 +#endif + +#endif /* __CONFIG_H */
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 78e62f0..347780e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -796,9 +796,11 @@ Greg Ungerer greg.ungerer@opengear.com Marek Vasut marek.vasut@gmail.com
balloon3 xscale + colibri_pxa270 xscale palmld xscale palmtc xscale vpac270 xscale + zipitz2 xscale
From: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com
This file is not used, automatically generated u-boot.lds is used instead
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- board/vpac270/u-boot.lds | 55 ---------------------------------------------- 1 files changed, 0 insertions(+), 55 deletions(-) delete mode 100644 board/vpac270/u-boot.lds
diff --git a/board/vpac270/u-boot.lds b/board/vpac270/u-boot.lds deleted file mode 100644 index 58c371d..0000000 --- a/board/vpac270/u-boot.lds +++ /dev/null @@ -1,55 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - cpu/pxa/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(.rodata) } - - . = ALIGN(4); - .data : { *(.data) } - - . = ALIGN(4); - .got : { *(.got) } - - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - __bss_start = .; - .bss : { *(.bss) } - _end = .; -}
* CONFIG_SYS_CLKS_IN_HZ is not used anywhere, so removing it * CONFIG_SYS_HZ is set to 1000 on most architectures, so it seems to be the safe default
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- include/configs/vpac270.h | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 694a8f9..4c18d3a 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -146,8 +146,7 @@ /* * Clock Configuration */ -#undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_HZ 1000 /* Timer @ 3250000 Hz */ #define CONFIG_SYS_CPUSPEED 0x190 /* 312MHz */
Define ENV_ADDR as MONITOR_BASE + MONITOR_LEN. Fix environment sector size (NOR: 32Kb for first four sectors and 128Kb for other; OneNAND: 128Kb).
Last but not least: we have MONITOR_LEN = 0x40000 and one sector for environment (size = 0x20000), so the kernel may start from 0x00060000 only.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- include/configs/vpac270.h | 25 +++++++++++++++++-------- 1 files changed, 17 insertions(+), 8 deletions(-)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 4c18d3a..b8440a1 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -45,7 +45,7 @@ "if ide reset && fatload ide 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ "fi; " \ - "bootm 0x40000;" + "bootm 0x60000;" #define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" #define CONFIG_TIMESTAMP #define CONFIG_BOOTDELAY 2 /* Autoboot delay */ @@ -185,6 +185,12 @@ /* * NOR FLASH */ +#define CONFIG_SYS_MONITOR_BASE 0x0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 +#define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SIZE 0x4000 + #if defined(CONFIG_CMD_FLASH) /* NOR */ #define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */
@@ -211,7 +217,16 @@ #define CONFIG_SYS_FLASH_PROTECTION 1
#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SECT_SIZE 0x4000 + +/* + * The first four sectors of the NOR flash are 0x8000 bytes big, the rest of the + * flash consists of 0x20000 bytes big sectors. + */ +#if (CONFIG_ENV_ADDR <= 0x18000) +#define CONFIG_ENV_SECT_SIZE 0x8000 +#else +#define CONFIG_ENV_SECT_SIZE 0x20000 +#endif
#elif defined(CONFIG_CMD_ONENAND) /* OneNAND */ #define CONFIG_SYS_NO_FLASH @@ -225,12 +240,6 @@ #define CONFIG_SYS_ENV_IS_NOWHERE #endif
-#define CONFIG_SYS_MONITOR_BASE 0x0 -#define CONFIG_SYS_MONITOR_LEN 0x40000 - -#define CONFIG_ENV_ADDR 0x40000 -#define CONFIG_ENV_SIZE 0x4000 - /* * IDE */
pxa_mem_setup macro use r6 to store CONFIG_SYS_MDREFR_VAL during memory initialization. This reg is modified during execution of pxa_wait_ticks. Later we use r6 to setup MDREFR[APD] bit. As result MDREFR[APD] is always zero.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- arch/arm/include/asm/arch-pxa/macro.h | 20 ++++++++++++-------- 1 files changed, 12 insertions(+), 8 deletions(-)
diff --git a/arch/arm/include/asm/arch-pxa/macro.h b/arch/arm/include/asm/arch-pxa/macro.h index 035a57e..85958dd 100644 --- a/arch/arm/include/asm/arch-pxa/macro.h +++ b/arch/arm/include/asm/arch-pxa/macro.h @@ -102,7 +102,11 @@ /* * This macro sets up the Memory controller of the PXA2xx CPU * - * Clobbered regs: r3, r4, r5 + * WARNING: This macro uses internally r3 and r7 regs for MEMC_BASE + * and CONFIG_SYS_MDREFR_VAL correspondingly. Please do not + * use this regs for other purpose inside this macro. + * + * Clobbered regs: r3, r4, r5, r6, r7 */ .macro pxa_mem_setup /* This comes handy when setting MDREFR */ @@ -157,7 +161,7 @@ bic r5, r5, #0xf00 /* MDREFR user config with zeroed DRI */
ldr r4, =CONFIG_SYS_MDREFR_VAL - mov r6, r4 + mov r7, r4 lsl r4, #20 lsr r4, #20 /* Get a valid DRI field */
@@ -187,12 +191,12 @@ * 6) Initialize SDRAM */
- bic r6, #MDREFR_SLFRSH - str r6, [r3, #MDREFR_OFFSET] + bic r7, #MDREFR_SLFRSH + str r7, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET]
- orr r6, #MDREFR_E1PIN - str r6, [r3, #MDREFR_OFFSET] + orr r7, #MDREFR_E1PIN + str r7, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET]
/* @@ -250,8 +254,8 @@ */
ldr r4, [r3, #MDREFR_OFFSET] - and r6, r6, #MDREFR_APD - orr r4, r4, r6 + and r7, r7, #MDREFR_APD + orr r4, r4, r7 str r4, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET] .endm
Dear Marek Vasut,
arch/arm/cpu/pxa/pxafb.c | 200 +++++++++++++++++++++++----------------------- 1 files changed, 100 insertions(+), 100 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 0ee6a75..09ee5c6 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -56,26 +56,26 @@
/* 640x480x16 @ 61 Hz */ vidinfo_t panel_info = {
- vl_col: 640,
- vl_row: 480,
- vl_width: 640,
- vl_height: 480,
- vl_clkp: CONFIG_SYS_HIGH,
- vl_oep: CONFIG_SYS_HIGH,
- vl_hsp: CONFIG_SYS_HIGH,
- vl_vsp: CONFIG_SYS_HIGH,
- vl_dp: CONFIG_SYS_HIGH,
- vl_bpix: LCD_BPP,
- vl_lbw: 0,
- vl_splt: 0,
- vl_clor: 0,
- vl_tft: 1,
- vl_hpw: 40,
- vl_blw: 56,
- vl_elw: 56,
- vl_vpw: 20,
- vl_bfw: 8,
- vl_efw: 8,
- .vl_col = 640,
- .vl_row = 480,
- .vl_width = 640,
- .vl_height = 480,
- .vl_clkp = CONFIG_SYS_HIGH,
- .vl_oep = CONFIG_SYS_HIGH,
- .vl_hsp = CONFIG_SYS_HIGH,
- .vl_vsp = CONFIG_SYS_HIGH,
- .vl_dp = CONFIG_SYS_HIGH,
- .vl_bpix = LCD_BPP,
- .vl_lbw = 0,
- .vl_splt = 0,
- .vl_clor = 0,
- .vl_tft = 1,
- .vl_hpw = 40,
- .vl_blw = 56,
- .vl_elw = 56,
- .vl_vpw = 20,
- .vl_bfw = 8,
- .vl_efw = 8,
In addition to the indentation, you also change the initializer style. Please note this in the commit message.
