[U-Boot-Users] [Patch 01/17] U-Boot-V2: ARM: Add ARCH lowlevel Init[Try 3]
This Patch adds CONFIG_ARCH_HAS_LOWLEVEL_INIT as discussed in thread http://www.nabble.com/-Patch--U-Boot-V2%3A-Introduce-CONFIG_ARCH_HAS_INIT_LO...
Signed-off-by: Nishanth Menonx0nishan@ti.com
--- arch/arm/cpu/start-arm.S | 2 +- arch/m68k/cpu/start-mcfv4e.S | 2 +- common/Kconfig | 3 +++ 3 files changed, 5 insertions(+), 2 deletions(-)
Index: u-boot-v2.git/arch/arm/cpu/start-arm.S =================================================================== --- u-boot-v2.git.orig/arch/arm/cpu/start-arm.S 2008-05-20 17:19:44.000000000 -0500 +++ u-boot-v2.git/arch/arm/cpu/start-arm.S 2008-05-20 17:26:30.000000000 -0500 @@ -131,7 +131,7 @@ orr r0,r0,#0xd3 msr cpsr,r0
-#ifdef ARCH_HAS_INIT_LOWLEVEL +#ifdef CONFIG_ARCH_HAS_LOWLEVEL_INIT bl arch_init_lowlevel #endif /* Index: u-boot-v2.git/arch/m68k/cpu/start-mcfv4e.S =================================================================== --- u-boot-v2.git.orig/arch/m68k/cpu/start-mcfv4e.S 2008-05-20 17:19:44.000000000 -0500 +++ u-boot-v2.git/arch/m68k/cpu/start-mcfv4e.S 2008-05-20 17:26:30.000000000 -0500 @@ -406,7 +406,7 @@ * standard reset vector file, but also do some special things * required only on their specific CPU. */ -#ifdef ARCH_HAS_INIT_LOWLEVEL +#ifdef CONFIG_ARCH_HAS_LOWLEVEL_INIT bsr.l arch_init_lowlevel nop #endif Index: u-boot-v2.git/common/Kconfig =================================================================== --- u-boot-v2.git.orig/common/Kconfig 2008-05-20 17:19:44.000000000 -0500 +++ u-boot-v2.git/common/Kconfig 2008-05-20 17:26:30.000000000 -0500 @@ -77,6 +77,9 @@ on many platforms. Disabling this option allows configurations to use U-boot as a second stage boot loader.
+config ARCH_HAS_LOWLEVEL_INIT + bool + config PROMPT string prompt "U-Boot command prompt"
Menon, Nishanth
