[U-Boot] tftp "command" in default environments
since 7a83af07aef3c (TFTP: add tftpsrv command) U-Boot has a new "tftpsrv" command, which can be enabled by defining CONFIG_CMD_TFTPSRV.
Unfortunately, activating it causes some boards to stop working correctly. This is because they use the tftp "command" in their environment, but tftp is has never been a real command, just the prefix for tftpboot. tftpboot used to be the sole completion for the tftp prefix, and this is still true unless one activates tftpsrv.
A few numbers (consider a little percentage of false positives): $ git grep -w tftp | wc 788 4853 59575 $ git grep -w tftp include/configs/ board/ | wc 658 4095 51357 $ git grep -w tftp doc/ README | wc 119 685 7661
This is of course a bug in many boards (and the docs too).
It's obviously to be fixed for boards that define CONFIG_CMD_TFTPSRV: currently none, but soon I'll update dig297 in this sense.
Fixing the docs would be wise, too. I'll try to find some time to do this job.
What I'm not sure about is if the default environment for all boards should be fixed as well. This would increase the binary size and the environment size. The increase would be of a few bytes, is it correct to assume that it is negligible for all boards? OTOH it would give no visible advantage to those boards that will never want tftpsrv at all, which are probably the vast majority.
I look forward to receive comments on this last question.
Luca
Luca Ceresoli
"Luca Ceresoli" luca.ceresoli@comelit.it Comelit Group S.p.a.
Don't enable the CONFIG_CMD_TFTPSRV by default. Only boards that want to use the tftpsrv command, should define the above config. This makes it like this: if you define the CONFIG_CMD_TFTPSRV, then you need to make sure your default environment is still good, if you don't define it then you should not have a problem. Right?
See above
looks like a non issue
yep.
those configs are broken. the autocomplete support has never been something you can rely on if you add new commands. if you want correct behavior all the time, then use the full proper name (i.e. "tftpboot" not "tftp").
submit patches -mike
Dear Mike Frysinger,
This has absolutely nothing to do with autocomplete. It's just using the fact that you can abbreviate all command names as long as they remain unambiguous.
True.
that's what i was referring to -mike
Since "tftpsrv" is new, wouldn't it make sense to change it to "srvtftp" or something else that doesn't conflict with a common abbreviation?
Dear "Luca Ceresoli",
Right.
I think this is not quite correct. I don't see any broken board.
Correct. So only those board maintainers that use "tftp" as abbreviation _and_ now changing their board configuration to include the "tftpsrv" need to pay attention.
It is not a bug. It is a pretty normal situation that people use abbreviations as long as they work. When working interactively, I used to use "set" for a long, long time instead of "setenv", until it stopped working. Then I used to use "sete" (and still do this) except for boards that enable for example the "setexpr" command.
We just should try not to use such abbreviations in the environment, and/or pay special attention to check the environment when changing the board configuration to include new, additional commands.
Then make sure to check the default env.
No. Most of them will never enable the "tftpsrv" command.
participants (5)
Eric Cooper
Igor Grinberg
Luca Ceresoli
Mike Frysinger
