[U-Boot] Recommended AVR32 toolchain
Hi Andreas,
I'm trying to verify the correct build of all AVR32 boards. What is the recommended toolchain to use?
I tried the one that comes with Ubuntu:
sudo apt-get install gcc-avr binutils-avr gdb-avr avr-libc avrdude
But it does not work, I get the following build errors:
Building atngw100mkii board... avr-gcc: error: unrecognized command line option ‘-mno-init-got’ avr-gcc: error: unrecognized command line option ‘-mcpu=ap7000’ make[3]: *** [include/autoconf.mk] Error 1 make[3]: *** [include/autoconf.mk.dep] Error 1 make[2]: *** [silentoldconfig] Error 1 make: *** [sub-make] Error 2 avr-size: '/home/lab/dev/u-boot/out/all_avr32/u-boot': No such file avr-gcc: error: unrecognized command line option ‘-mno-init-got’ avr-gcc: error: unrecognized command line option ‘-mcpu=ap7000’ make[3]: *** [include/autoconf.mk] Error 1 make[3]: *** Waiting for unfinished jobs.... make[3]: *** [include/autoconf.mk.dep] Error 1 'make -f /home/lab/dev/u-boot/scripts/Makefile.autoconf obj=include include/autoconf.mk include/autoconf.mk.dep' Failed make[2]: *** [silentoldconfig] Error 1 make[1]: *** No rule to make target `include/config/auto.conf', needed by `include/config/uboot.release'. Stop. make: *** [sub-make] Error 2
Regards, Vasili
Hi Vasili,
On 20.08.14 18:10, Vasili Galka wrote:
Hi Andreas,
it depends, at least you should use a avr32-linux toolchain. The avr32-elf one builds u-boot fine but has some runtime flaws. For compile testing this would be Ok.
Ouch, that is wrong. You got the avr 8-bit variant. There is no mainline avr32 gcc support! The patches come from atmel [1] and are for an outdated gcc version unfortunately. You cold use the pre-compiled avr32 toolchain provided by kernel.org [2]. I personally have never run this toolchain but others said it works.
Best regards
Andreas Bießmann
[1] http://distribute.atmel.no/tools/opensource/ [2] https://www.kernel.org/pub/tools/crosstool/
Hi Andreas,
The toolchain from kernel.org indeed works fine.
Thank you very much for your help!
Best regards, Vasili
On Wed, Aug 20, 2014 at 11:38 PM, Andreas Bießmann andreas.devel@googlemail.com wrote:
Hi Vasili,
Hi Andreas,
Best regards
Andreas Bießmann
Andreas Bießmann
Vasili Galka
