[PATCH 0/8] Add support for Qualcomm SA8155-ADP board
This patch series adds support for Qualcomm SA8155-ADP development board. Main motivation for this series is to allow running virtualization software on this board and U-Boot is a good way to break Qualcomm's boot chain at EL2 with more convenient ways for uploading and running the code. With this patches applied it is possible to upload and run Xen on this board. KVM probably should work too.
I added myself as a maintainer for this board, but my abilities to maintain it are quite limited as I have no access to Qualcomm documentation. I used mostly Linux drivers as the source for device-specific information, like register addresses and offsets. If anyone wants to maintain this, I will gladly agree.
Volodymyr Babchuk (8): clk: qcom: clear div mask before assigning new divider dts: qcom: import device trees and bindings for SA8155P-ADP net: dw_eth_qos: add support for Qualcomm SM8150 SoC clk: qcom: add support for power domains uclass clk: qcom: add driver for SM8150 SoC pinctr: qcom: pass pin number to get_function_mux callback pinctrl: qcom: add driver for SM8150 SoC board: add support for Qualcomm SA8155P-ADP board
arch/arm/dts/pmm8155au_1.dtsi | 135 + arch/arm/dts/pmm8155au_2.dtsi | 108 + arch/arm/dts/sa8155p-adp-u-boot.dtsi | 30 + arch/arm/dts/sa8155p-adp.dts | 606 ++ arch/arm/dts/sa8155p.dtsi | 40 + arch/arm/dts/sm8150.dtsi | 5293 +++++++++++++++++ arch/arm/mach-snapdragon/Kconfig | 14 + arch/arm/mach-snapdragon/Makefile | 2 + arch/arm/mach-snapdragon/init_sa8155p.c | 30 + arch/arm/mach-snapdragon/sysmap-sm8150.c | 31 + board/qualcomm/sa8155p-adp/Kconfig | 12 + board/qualcomm/sa8155p-adp/MAINTAINERS | 6 + configs/sa8155p_adp_defconfig | 33 + doc/board/qualcomm/index.rst | 1 + doc/board/qualcomm/sa8155p-adp.rst | 94 + drivers/clk/qcom/Kconfig | 8 + drivers/clk/qcom/Makefile | 1 + drivers/clk/qcom/clock-qcom.c | 96 +- drivers/clk/qcom/clock-qcom.h | 7 + drivers/clk/qcom/clock-sm8150.c | 234 + drivers/net/dwc_eth_qos.c | 4 + drivers/net/dwc_eth_qos.h | 2 + drivers/net/dwc_eth_qos_qcom.c | 47 +- drivers/pinctrl/qcom/Kconfig | 7 + drivers/pinctrl/qcom/Makefile | 1 + drivers/pinctrl/qcom/pinctrl-apq8016.c | 3 +- drivers/pinctrl/qcom/pinctrl-apq8096.c | 3 +- drivers/pinctrl/qcom/pinctrl-ipq4019.c | 3 +- drivers/pinctrl/qcom/pinctrl-qcom.c | 4 +- drivers/pinctrl/qcom/pinctrl-qcom.h | 3 +- drivers/pinctrl/qcom/pinctrl-qcs404.c | 3 +- drivers/pinctrl/qcom/pinctrl-sdm845.c | 3 +- drivers/pinctrl/qcom/pinctrl-sm8150.c | 589 ++ include/configs/sa8155p_adp.h | 25 + .../dt-bindings/clock/qcom,dispcc-sm8150.h | 76 + include/dt-bindings/clock/qcom,gcc-sm8150.h | 252 + include/dt-bindings/clock/qcom,gpucc-sm8150.h | 33 + include/dt-bindings/clock/qcom,rpmh.h | 37 + include/dt-bindings/dma/qcom-gpi.h | 11 + include/dt-bindings/firmware/qcom,scm.h | 39 + include/dt-bindings/iio/qcom,spmi-vadc.h | 303 + .../dt-bindings/interconnect/qcom,osm-l3.h | 15 + .../dt-bindings/interconnect/qcom,sm8150.h | 159 + include/dt-bindings/phy/phy-qcom-qmp.h | 20 + include/dt-bindings/power/qcom-rpmpd.h | 412 ++ .../regulator/qcom,rpmh-regulator.h | 36 + include/dt-bindings/soc/qcom,rpmh-rsc.h | 14 + 47 files changed, 8866 insertions(+), 19 deletions(-) create mode 100644 arch/arm/dts/pmm8155au_1.dtsi create mode 100644 arch/arm/dts/pmm8155au_2.dtsi create mode 100644 arch/arm/dts/sa8155p-adp-u-boot.dtsi create mode 100644 arch/arm/dts/sa8155p-adp.dts create mode 100644 arch/arm/dts/sa8155p.dtsi create mode 100644 arch/arm/dts/sm8150.dtsi create mode 100644 arch/arm/mach-snapdragon/init_sa8155p.c create mode 100644 arch/arm/mach-snapdragon/sysmap-sm8150.c create mode 100644 board/qualcomm/sa8155p-adp/Kconfig create mode 100644 board/qualcomm/sa8155p-adp/MAINTAINERS create mode 100644 configs/sa8155p_adp_defconfig create mode 100644 doc/board/qualcomm/sa8155p-adp.rst create mode 100644 drivers/clk/qcom/clock-sm8150.c create mode 100644 drivers/pinctrl/qcom/pinctrl-sm8150.c create mode 100644 include/configs/sa8155p_adp.h create mode 100644 include/dt-bindings/clock/qcom,dispcc-sm8150.h create mode 100644 include/dt-bindings/clock/qcom,gcc-sm8150.h create mode 100644 include/dt-bindings/clock/qcom,gpucc-sm8150.h create mode 100644 include/dt-bindings/clock/qcom,rpmh.h create mode 100644 include/dt-bindings/dma/qcom-gpi.h create mode 100644 include/dt-bindings/firmware/qcom,scm.h create mode 100644 include/dt-bindings/iio/qcom,spmi-vadc.h create mode 100644 include/dt-bindings/interconnect/qcom,osm-l3.h create mode 100644 include/dt-bindings/interconnect/qcom,sm8150.h create mode 100644 include/dt-bindings/phy/phy-qcom-qmp.h create mode 100644 include/dt-bindings/power/qcom-rpmpd.h create mode 100644 include/dt-bindings/regulator/qcom,rpmh-regulator.h create mode 100644 include/dt-bindings/soc/qcom,rpmh-rsc.h
We need to do this to ensure that new divider is applied correctly. This fixes potential issue with 1Gbit ethernet on SA8155P-ADP boards.
Signed-off-by: Volodymyr Babchuk volodymyr_babchuk@epam.com ---
drivers/clk/qcom/clock-qcom.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/qcom/clock-qcom.c b/drivers/clk/qcom/clock-qcom.c index 7c683e5192..729d190c54 100644 --- a/drivers/clk/qcom/clock-qcom.c +++ b/drivers/clk/qcom/clock-qcom.c @@ -117,7 +117,8 @@ void clk_rcg_set_rate_mnd(phys_addr_t base, const struct bcr_regs *regs,
/* setup src select and divider */ cfg = readl(base + regs->cfg_rcgr); - cfg &= ~(CFG_SRC_SEL_MASK | CFG_MODE_MASK | CFG_HW_CLK_CTRL_MASK); + cfg &= ~(CFG_SRC_SEL_MASK | CFG_MODE_MASK | CFG_HW_CLK_CTRL_MASK | + CFG_SRC_DIV_MASK); cfg |= source & CFG_SRC_SEL_MASK; /* Select clock source */
if (div)
"The current behaviour does a bitwise OR of the previous and new divider values, this is wrong."
Wow, that's a subtle one!
Small nit with the wording, otherwise
Reviewed-by: Caleb Connolly caleb.connolly@linaro.org
CFG_SRC_DIV_MASK);
if (div)
Add support for Qualcomm SM8150 SoC to the EQOS driver. SM8150 has two main differences from already supported QCS404: it has another RGMII configuration registers set and it does require RGMII loopback to be disabled.
To support different variants of QCOM SoC we had to add two new fields to the eqos_priv struct: eqos_qcom_rgmii_regs and qcom_enable_loopback.
drivers/net/dwc_eth_qos.c | 4 +++ drivers/net/dwc_eth_qos.h | 2 ++ drivers/net/dwc_eth_qos_qcom.c | 47 +++++++++++++++++++++++++++------- 3 files changed, 44 insertions(+), 9 deletions(-)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 9b3bce1dc8..882b854697 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -1700,6 +1700,10 @@ static const struct udevice_id eqos_ids[] = { .compatible = "qcom,qcs404-ethqos", .data = (ulong)&eqos_qcom_config }, + { + .compatible = "qcom,sm8150-ethqos", + .data = (ulong)&eqos_qcom_config + }, #endif #if IS_ENABLED(CONFIG_DWC_ETH_QOS_STARFIVE) { diff --git a/drivers/net/dwc_eth_qos.h b/drivers/net/dwc_eth_qos.h index e3222e1e17..216e1afe53 100644 --- a/drivers/net/dwc_eth_qos.h +++ b/drivers/net/dwc_eth_qos.h @@ -255,6 +255,7 @@ struct eqos_priv { struct eqos_dma_regs *dma_regs; struct eqos_tegra186_regs *tegra186_regs; void *eqos_qcom_rgmii_regs; + struct dwmac_rgmii_regs *eqos_qcom_por; struct reset_ctl reset_ctl; struct gpio_desc phy_reset_gpio; struct clk clk_master_bus; @@ -277,6 +278,7 @@ struct eqos_priv { bool started; bool reg_access_ok; bool clk_ck_enabled; + bool qcom_enable_loopback; unsigned int tx_fifo_sz, rx_fifo_sz; u32 reset_delays[3]; }; diff --git a/drivers/net/dwc_eth_qos_qcom.c b/drivers/net/dwc_eth_qos_qcom.c index 8178138fc6..e9592ff686 100644 --- a/drivers/net/dwc_eth_qos_qcom.c +++ b/drivers/net/dwc_eth_qos_qcom.c @@ -95,6 +95,15 @@ static struct dwmac_rgmii_regs emac_v2_3_0_por = { .io_macro_config2 = 0x00002060 };
+static struct dwmac_rgmii_regs emac_v2_1_0_por = { + .io_macro_config = 0x40C01343, + .sdcc_hc_dll_config = 0x2004642C, + .sdcc_hc_ddr_config = 0x00000000, + .sdcc_hc_dll_config2 = 0x00200000, + .sdcc_usr_ctl = 0x00010800, + .io_macro_config2 = 0x00002060 +}; + static void ethqos_set_func_clk_en(struct dwmac_rgmii_regs *regs) { setbits_le32(®s->io_macro_config, RGMII_CONFIG_FUNC_CLK_EN); @@ -172,6 +181,8 @@ static int ethqos_rgmii_macro_init(struct udevice *dev, struct dwmac_rgmii_regs *regs, unsigned long speed) { + struct eqos_priv *eqos = dev_get_priv(dev); + /* Disable loopback mode */ clrbits_le32(®s->io_macro_config2, RGMII_CONFIG2_TX_TO_RX_LOOPBACK_EN); @@ -202,7 +213,9 @@ static int ethqos_rgmii_macro_init(struct udevice *dev, SDCC_DDR_CONFIG_PRG_RCLK_DLY, 57); setbits_le32(®s->sdcc_hc_ddr_config, SDCC_DDR_CONFIG_PRG_DLY_EN);
- setbits_le32(®s->io_macro_config, RGMII_CONFIG_LOOPBACK_EN); + if (eqos->qcom_enable_loopback) + setbits_le32(®s->io_macro_config, + RGMII_CONFIG_LOOPBACK_EN); break;
case SPEED_100: @@ -233,7 +246,9 @@ static int ethqos_rgmii_macro_init(struct udevice *dev, setbits_le32(®s->sdcc_hc_ddr_config, SDCC_DDR_CONFIG_EXT_PRG_RCLK_DLY_EN);
case SPEED_10: @@ -265,7 +280,9 @@ static int ethqos_rgmii_macro_init(struct udevice *dev, setbits_le32(®s->sdcc_hc_ddr_config, SDCC_DDR_CONFIG_EXT_PRG_RCLK_DLY_EN);
default: @@ -281,14 +298,15 @@ static int ethqos_configure(struct udevice *dev, unsigned long speed) { unsigned int retry = 1000; + struct eqos_priv *eqos = dev_get_priv(dev);
/* Reset to POR values and enable clk */ - writel(emac_v2_3_0_por.io_macro_config, ®s->io_macro_config); - writel(emac_v2_3_0_por.sdcc_hc_dll_config, ®s->sdcc_hc_dll_config); - writel(emac_v2_3_0_por.sdcc_hc_ddr_config, ®s->sdcc_hc_ddr_config); - writel(emac_v2_3_0_por.sdcc_hc_dll_config2, ®s->sdcc_hc_dll_config2); - writel(emac_v2_3_0_por.sdcc_usr_ctl, ®s->sdcc_usr_ctl); - writel(emac_v2_3_0_por.io_macro_config2, ®s->io_macro_config2); + writel(eqos->eqos_qcom_por->io_macro_config, ®s->io_macro_config); + writel(eqos->eqos_qcom_por->sdcc_hc_dll_config, ®s->sdcc_hc_dll_config); + writel(eqos->eqos_qcom_por->sdcc_hc_ddr_config, ®s->sdcc_hc_ddr_config); + writel(eqos->eqos_qcom_por->sdcc_hc_dll_config2, ®s->sdcc_hc_dll_config2); + writel(eqos->eqos_qcom_por->sdcc_usr_ctl, ®s->sdcc_usr_ctl); + writel(eqos->eqos_qcom_por->io_macro_config2, ®s->io_macro_config2);
ethqos_set_func_clk_en(regs);
@@ -565,6 +583,17 @@ static int eqos_probe_resources_qcom(struct udevice *dev) return -EINVAL; }
+ if (device_is_compatible(dev, "qcom,qcs404-ethqos")) { + eqos->eqos_qcom_por = &emac_v2_3_0_por; + eqos->qcom_enable_loopback = true; + } else if (device_is_compatible(dev, "qcom,sm8150-ethqos")) { + eqos->eqos_qcom_por = &emac_v2_1_0_por; + eqos->qcom_enable_loopback = false; + } else { + pr_err("Unknown QCOM ethernet device\n"); + return -EINVAL; + } + debug("%s: OK\n", __func__); return 0; }
On Thu, 29 Feb 2024 at 19:53, Volodymyr Babchuk Volodymyr_Babchuk@epam.com wrote:
We should explicitly clear the loopback bit for the else part too. I suppose it can be written cleanly as below here and other places too:
loopback = eqos->qcom_enable_loopback ? RGMII_CONFIG_LOOPBACK_EN : 0;
clrsetbits_le32(®s->io_macro_config, RGMII_CONFIG_LOOPBACK_EN, loopback);
-Sumit
break; case SPEED_100:
RGMII_CONFIG_LOOPBACK_EN); break; case SPEED_10:
RGMII_CONFIG_LOOPBACK_EN); break; default:
struct eqos_priv *eqos = dev_get_priv(dev); /* Reset to POR values and enable clk */
writel(eqos->eqos_qcom_por->io_macro_config2, ®s->io_macro_config2); ethqos_set_func_clk_en(regs);
} else {
return -EINVAL;
2.43.0
Add device tree bindings and actual device trees for SM8150 SoC and SA8155P-ADP board. Those files were imported from Linux kernel 6.8-rc5 as is. In this configuration they will not work with U-Boot for couple reasons:
- memory@ node is incomplete, as Linux expects that bootloader at the previous stage would populate the node with the actual memory configuration
- pinctrl node uses multi-tile register mapping which is not supported by the U-Boot driver
Next patches will address this issues. We are importing the existing files as is in this separate patch to ease up tracking changes from Linux.
arch/arm/dts/pmm8155au_1.dtsi | 135 + arch/arm/dts/pmm8155au_2.dtsi | 108 + arch/arm/dts/sa8155p-adp.dts | 606 ++ arch/arm/dts/sa8155p.dtsi | 40 + arch/arm/dts/sm8150.dtsi | 5293 +++++++++++++++++ .../dt-bindings/clock/qcom,dispcc-sm8150.h | 76 + include/dt-bindings/clock/qcom,gcc-sm8150.h | 252 + include/dt-bindings/clock/qcom,gpucc-sm8150.h | 33 + include/dt-bindings/clock/qcom,rpmh.h | 37 + include/dt-bindings/dma/qcom-gpi.h | 11 + include/dt-bindings/firmware/qcom,scm.h | 39 + include/dt-bindings/iio/qcom,spmi-vadc.h | 303 + .../dt-bindings/interconnect/qcom,osm-l3.h | 15 + .../dt-bindings/interconnect/qcom,sm8150.h | 159 + include/dt-bindings/phy/phy-qcom-qmp.h | 20 + include/dt-bindings/power/qcom-rpmpd.h | 412 ++ .../regulator/qcom,rpmh-regulator.h | 36 + include/dt-bindings/soc/qcom,rpmh-rsc.h | 14 + 18 files changed, 7589 insertions(+) create mode 100644 arch/arm/dts/pmm8155au_1.dtsi create mode 100644 arch/arm/dts/pmm8155au_2.dtsi create mode 100644 arch/arm/dts/sa8155p-adp.dts create mode 100644 arch/arm/dts/sa8155p.dtsi create mode 100644 arch/arm/dts/sm8150.dtsi create mode 100644 include/dt-bindings/clock/qcom,dispcc-sm8150.h create mode 100644 include/dt-bindings/clock/qcom,gcc-sm8150.h create mode 100644 include/dt-bindings/clock/qcom,gpucc-sm8150.h create mode 100644 include/dt-bindings/clock/qcom,rpmh.h create mode 100644 include/dt-bindings/dma/qcom-gpi.h create mode 100644 include/dt-bindings/firmware/qcom,scm.h create mode 100644 include/dt-bindings/iio/qcom,spmi-vadc.h create mode 100644 include/dt-bindings/interconnect/qcom,osm-l3.h create mode 100644 include/dt-bindings/interconnect/qcom,sm8150.h create mode 100644 include/dt-bindings/phy/phy-qcom-qmp.h create mode 100644 include/dt-bindings/power/qcom-rpmpd.h create mode 100644 include/dt-bindings/regulator/qcom,rpmh-regulator.h create mode 100644 include/dt-bindings/soc/qcom,rpmh-rsc.h
diff --git a/arch/arm/dts/pmm8155au_1.dtsi b/arch/arm/dts/pmm8155au_1.dtsi new file mode 100644 index 0000000000..7072e5a2e7 --- /dev/null +++ b/arch/arm/dts/pmm8155au_1.dtsi @@ -0,0 +1,135 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright (c) 2021, Linaro Limited + */ + +#include <dt-bindings/input/input.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/spmi/spmi.h> +#include <dt-bindings/iio/qcom,spmi-vadc.h> + +/ { + thermal-zones { + pmm8155au-1-thermal { + polling-delay-passive = <100>; + polling-delay = <0>; + + thermal-sensors = <&pmm8155au_1_temp>; + + trips { + trip0 { + temperature = <95000>; + hysteresis = <0>; + type = "passive"; + }; + + trip1 { + temperature = <115000>; + hysteresis = <0>; + type = "hot"; + }; + + trip2 { + temperature = <145000>; + hysteresis = <0>; + type = "critical"; + }; + }; + }; + }; +}; + +&spmi_bus { + pmic@0 { + compatible = "qcom,pmm8155au", "qcom,spmi-pmic"; + reg = <0x0 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + pon: power-on@800 { + compatible = "qcom,pm8916-pon"; + reg = <0x0800>; + pwrkey { + compatible = "qcom,pm8941-pwrkey"; + interrupts = <0x0 0x8 0x0 IRQ_TYPE_EDGE_BOTH>; + debounce = <15625>; + bias-pull-up; + linux,code = <KEY_POWER>; + + status = "disabled"; + }; + }; + + pmm8155au_1_temp: temp-alarm@2400 { + compatible = "qcom,spmi-temp-alarm"; + reg = <0x2400>; + interrupts = <0x0 0x24 0x0 IRQ_TYPE_EDGE_BOTH>; + io-channels = <&pmm8155au_1_adc ADC5_DIE_TEMP>; + io-channel-names = "thermal"; + #thermal-sensor-cells = <0>; + }; + + pmm8155au_1_adc: adc@3100 { + compatible = "qcom,spmi-adc5"; + reg = <0x3100>; + #address-cells = <1>; + #size-cells = <0>; + #io-channel-cells = <1>; + interrupts = <0x0 0x31 0x0 IRQ_TYPE_EDGE_RISING>; + + ref-gnd@0 { + reg = <ADC5_REF_GND>; + qcom,pre-scaling = <1 1>; + label = "ref_gnd"; + }; + + vref-1p25@1 { + reg = <ADC5_1P25VREF>; + qcom,pre-scaling = <1 1>; + label = "vref_1p25"; + }; + + die-temp@6 { + reg = <ADC5_DIE_TEMP>; + qcom,pre-scaling = <1 1>; + label = "die_temp"; + }; + }; + + pmm8155au_1_adc_tm: adc-tm@3500 { + compatible = "qcom,spmi-adc-tm5"; + reg = <0x3500>; + interrupts = <0x0 0x35 0x0 IRQ_TYPE_EDGE_RISING>; + #thermal-sensor-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + pmm8155au_1_rtc: rtc@6000 { + compatible = "qcom,pm8941-rtc"; + reg = <0x6000>; + reg-names = "rtc", "alarm"; + interrupts = <0x0 0x61 0x1 IRQ_TYPE_NONE>; + + status = "disabled"; + }; + + pmm8155au_1_gpios: gpio@c000 { + compatible = "qcom,pmm8155au-gpio"; + reg = <0xc000>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&pmm8155au_1_gpios 0 0 10>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + pmic@1 { + compatible = "qcom,pmm8155au", "qcom,spmi-pmic"; + reg = <0x1 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + }; +}; diff --git a/arch/arm/dts/pmm8155au_2.dtsi b/arch/arm/dts/pmm8155au_2.dtsi new file mode 100644 index 0000000000..72075964fb --- /dev/null +++ b/arch/arm/dts/pmm8155au_2.dtsi @@ -0,0 +1,108 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright (c) 2021, Linaro Limited + */ + +#include <dt-bindings/input/input.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/spmi/spmi.h> + +/ { + thermal-zones { + pmm8155au-2-thermal { + polling-delay-passive = <100>; + polling-delay = <0>; + + thermal-sensors = <&pmm8155au_2_temp>; + + trips { + trip0 { + temperature = <95000>; + hysteresis = <0>; + type = "passive"; + }; + + trip1 { + temperature = <115000>; + hysteresis = <0>; + type = "hot"; + }; + + trip2 { + temperature = <145000>; + hysteresis = <0>; + type = "critical"; + }; + }; + }; + }; +}; + +&spmi_bus { + pmic@4 { + compatible = "qcom,pmm8155au", "qcom,spmi-pmic"; + reg = <0x4 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + power-on@800 { + compatible = "qcom,pm8916-pon"; + reg = <0x0800>; + + status = "disabled"; + }; + + pmm8155au_2_temp: temp-alarm@2400 { + compatible = "qcom,spmi-temp-alarm"; + reg = <0x2400>; + interrupts = <0x4 0x24 0x0 IRQ_TYPE_EDGE_BOTH>; + io-channels = <&pmm8155au_2_adc ADC5_DIE_TEMP>; + io-channel-names = "thermal"; + #thermal-sensor-cells = <0>; + }; + + pmm8155au_2_adc: adc@3100 { + compatible = "qcom,spmi-adc5"; + reg = <0x3100>; + #address-cells = <1>; + #size-cells = <0>; + #io-channel-cells = <1>; + interrupts = <0x4 0x31 0x0 IRQ_TYPE_EDGE_RISING>; + + ref-gnd@0 { + reg = <ADC5_REF_GND>; + qcom,pre-scaling = <1 1>; + label = "ref_gnd"; + }; + + vref-1p25@1 { + reg = <ADC5_1P25VREF>; + qcom,pre-scaling = <1 1>; + label = "vref_1p25"; + }; + + die-temp@6 { + reg = <ADC5_DIE_TEMP>; + qcom,pre-scaling = <1 1>; + label = "die_temp"; + }; + }; + + pmm8155au_2_gpios: gpio@c000 { + compatible = "qcom,pmm8155au-gpio"; + reg = <0xc000>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&pmm8155au_2_gpios 0 0 10>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + pmic@5 { + compatible = "qcom,pmm8155au", "qcom,spmi-pmic"; + reg = <0x5 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + }; +}; diff --git a/arch/arm/dts/sa8155p-adp.dts b/arch/arm/dts/sa8155p-adp.dts new file mode 100644 index 0000000000..5e4287f8c8 --- /dev/null +++ b/arch/arm/dts/sa8155p-adp.dts @@ -0,0 +1,606 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright (c) 2021, Linaro Limited + */ + +/dts-v1/; + +#include <dt-bindings/regulator/qcom,rpmh-regulator.h> +#include <dt-bindings/gpio/gpio.h> +#include "sa8155p.dtsi" +#include "pmm8155au_1.dtsi" +#include "pmm8155au_2.dtsi" + +/ { + model = "Qualcomm Technologies, Inc. SA8155P ADP"; + compatible = "qcom,sa8155p-adp", "qcom,sa8155p"; + + aliases { + serial0 = &uart2; + serial1 = &uart9; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + vreg_3p3: vreg-3p3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vreg_3p3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + /* + * S4A is always on and not controllable through RPMh. + * So model it as a fixed regulator. + */ + vreg_s4a_1p8: smps4 { + compatible = "regulator-fixed"; + regulator-name = "vreg_s4a_1p8"; + + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-always-on; + regulator-boot-on; + + vin-supply = <&vreg_3p3>; + }; +}; + +&apps_rsc { + regulators-0 { + compatible = "qcom,pmm8155au-rpmh-regulators"; + qcom,pmic-id = "a"; + + vdd-s1-supply = <&vreg_3p3>; + vdd-s2-supply = <&vreg_3p3>; + vdd-s3-supply = <&vreg_3p3>; + vdd-s4-supply = <&vreg_3p3>; + vdd-s5-supply = <&vreg_3p3>; + vdd-s6-supply = <&vreg_3p3>; + vdd-s7-supply = <&vreg_3p3>; + vdd-s8-supply = <&vreg_3p3>; + vdd-s9-supply = <&vreg_3p3>; + vdd-s10-supply = <&vreg_3p3>; + + vdd-l1-l8-l11-supply = <&vreg_s6a_0p92>; + vdd-l2-l10-supply = <&vreg_3p3>; + vdd-l3-l4-l5-l18-supply = <&vreg_s6a_0p92>; + vdd-l6-l9-supply = <&vreg_s6a_0p92>; + vdd-l7-l12-l14-l15-supply = <&vreg_s5a_2p04>; + vdd-l13-l16-l17-supply = <&vreg_3p3>; + + vreg_s5a_2p04: smps5 { + regulator-name = "vreg_s5a_2p04"; + regulator-min-microvolt = <1904000>; + regulator-max-microvolt = <2000000>; + }; + + vreg_s6a_0p92: smps6 { + regulator-name = "vreg_s6a_0p92"; + regulator-min-microvolt = <920000>; + regulator-max-microvolt = <1128000>; + }; + + vreg_l1a_0p752: ldo1 { + regulator-name = "vreg_l1a_0p752"; + regulator-min-microvolt = <752000>; + regulator-max-microvolt = <752000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vdda_usb_hs_3p1: + vreg_l2a_3p072: ldo2 { + regulator-name = "vreg_l2a_3p072"; + regulator-min-microvolt = <3072000>; + regulator-max-microvolt = <3072000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l3a_0p8: ldo3 { + regulator-name = "vreg_l3a_0p8"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vdd_usb_hs_core: + vdda_usb_ss_dp_core_1: + vreg_l5a_0p88: ldo5 { + regulator-name = "vreg_l5a_0p88"; + regulator-min-microvolt = <880000>; + regulator-max-microvolt = <880000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + regulator-allow-set-load; + regulator-allowed-modes = <RPMH_REGULATOR_MODE_LPM + RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l7a_1p8: ldo7 { + regulator-name = "vreg_l7a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l10a_2p96: ldo10 { + regulator-name = "vreg_l10a_2p96"; + regulator-min-microvolt = <2504000>; + regulator-max-microvolt = <2960000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + regulator-allow-set-load; + regulator-allowed-modes = <RPMH_REGULATOR_MODE_LPM + RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l11a_0p8: ldo11 { + regulator-name = "vreg_l11a_0p8"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vdda_usb_hs_1p8: + vreg_l12a_1p8: ldo12 { + regulator-name = "vreg_l12a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l13a_2p7: ldo13 { + regulator-name = "vreg_l13a_2p7"; + regulator-min-microvolt = <2704000>; + regulator-max-microvolt = <2704000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l15a_1p7: ldo15 { + regulator-name = "vreg_l15a_1p7"; + regulator-min-microvolt = <1704000>; + regulator-max-microvolt = <1704000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l16a_2p7: ldo16 { + regulator-name = "vreg_l16a_2p7"; + regulator-min-microvolt = <2704000>; + regulator-max-microvolt = <2960000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l17a_2p96: ldo17 { + regulator-name = "vreg_l17a_2p96"; + regulator-min-microvolt = <2504000>; + regulator-max-microvolt = <2960000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + }; + + regulators-1 { + compatible = "qcom,pmm8155au-rpmh-regulators"; + qcom,pmic-id = "c"; + + vdd-s1-supply = <&vreg_3p3>; + vdd-s2-supply = <&vreg_3p3>; + vdd-s3-supply = <&vreg_3p3>; + vdd-s4-supply = <&vreg_3p3>; + vdd-s5-supply = <&vreg_3p3>; + vdd-s6-supply = <&vreg_3p3>; + vdd-s7-supply = <&vreg_3p3>; + vdd-s8-supply = <&vreg_3p3>; + vdd-s9-supply = <&vreg_3p3>; + vdd-s10-supply = <&vreg_3p3>; + + vdd-l1-l8-l11-supply = <&vreg_s4c_1p352>; + vdd-l2-l10-supply = <&vreg_3p3>; + vdd-l3-l4-l5-l18-supply = <&vreg_s4c_1p352>; + vdd-l6-l9-supply = <&vreg_s6c_1p128>; + vdd-l7-l12-l14-l15-supply = <&vreg_s5c_2p04>; + vdd-l13-l16-l17-supply = <&vreg_3p3>; + + vreg_s4c_1p352: smps4 { + regulator-name = "vreg_s4c_1p352"; + regulator-min-microvolt = <1352000>; + regulator-max-microvolt = <1352000>; + }; + + vreg_s5c_2p04: smps5 { + regulator-name = "vreg_s5c_2p04"; + regulator-min-microvolt = <1904000>; + regulator-max-microvolt = <2000000>; + }; + + vreg_s6c_1p128: smps6 { + regulator-name = "vreg_s6c_1p128"; + regulator-min-microvolt = <1128000>; + regulator-max-microvolt = <1128000>; + }; + + vreg_l1c_1p304: ldo1 { + regulator-name = "vreg_l1c_1p304"; + regulator-min-microvolt = <1304000>; + regulator-max-microvolt = <1304000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l2c_1p808: ldo2 { + regulator-name = "vreg_l2c_1p808"; + regulator-min-microvolt = <1704000>; + regulator-max-microvolt = <2928000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l5c_1p2: ldo5 { + regulator-name = "vreg_l5c_1p2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + regulator-allow-set-load; + regulator-allowed-modes = <RPMH_REGULATOR_MODE_LPM + RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l7c_1p8: ldo7 { + regulator-name = "vreg_l7c_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l8c_1p2: ldo8 { + regulator-name = "vreg_l8c_1p2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + regulator-allow-set-load; + regulator-allowed-modes = <RPMH_REGULATOR_MODE_LPM + RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l10c_3p3: ldo10 { + regulator-name = "vreg_l10c_3p3"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3312000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l11c_0p8: ldo11 { + regulator-name = "vreg_l11c_0p8"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l12c_1p808: ldo12 { + regulator-name = "vreg_l12c_1p808"; + regulator-min-microvolt = <1704000>; + regulator-max-microvolt = <2928000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l13c_2p96: ldo13 { + regulator-name = "vreg_l13c_2p96"; + regulator-min-microvolt = <2504000>; + regulator-max-microvolt = <2960000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l15c_1p9: ldo15 { + regulator-name = "vreg_l15c_1p9"; + regulator-min-microvolt = <1704000>; + regulator-max-microvolt = <2928000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l16c_3p008: ldo16 { + regulator-name = "vreg_l16c_3p008"; + regulator-min-microvolt = <3008000>; + regulator-max-microvolt = <3008000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l18c_0p88: ldo18 { + regulator-name = "vreg_l18c_0p88"; + regulator-min-microvolt = <880000>; + regulator-max-microvolt = <880000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + }; +}; + +ðernet { + status = "okay"; + + snps,reset-gpio = <&tlmm 79 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 11000 70000>; + + snps,mtl-rx-config = <&mtl_rx_setup>; + snps,mtl-tx-config = <&mtl_tx_setup>; + + pinctrl-names = "default"; + pinctrl-0 = <ðernet_defaults>; + + phy-handle = <&rgmii_phy>; + phy-mode = "rgmii"; + max-speed = <1000>; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + /* Micrel KSZ9031RNZ PHY */ + rgmii_phy: phy@7 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0x7>; + + interrupts-extended = <&tlmm 124 IRQ_TYPE_EDGE_FALLING>; + device_type = "ethernet-phy"; + }; + }; + + mtl_rx_setup: rx-queues-config { + snps,rx-queues-to-use = <1>; + snps,rx-sched-sp; + + queue0 { + snps,dcb-algorithm; + snps,map-to-dma-channel = <0x0>; + snps,route-up; + snps,priority = <0x1>; + }; + }; + + mtl_tx_setup: tx-queues-config { + snps,tx-queues-to-use = <1>; + snps,tx-sched-wrr; + + queue0 { + snps,weight = <0x10>; + snps,dcb-algorithm; + snps,priority = <0x0>; + }; + }; +}; + +&qupv3_id_1 { + status = "okay"; +}; + +&remoteproc_adsp { + status = "okay"; + firmware-name = "qcom/sa8155p/adsp.mdt"; +}; + +&remoteproc_cdsp { + status = "okay"; + firmware-name = "qcom/sa8155p/cdsp.mdt"; +}; + +&sdhc_2 { + status = "okay"; + + cd-gpios = <&tlmm 4 GPIO_ACTIVE_LOW>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&sdc2_on>; + pinctrl-1 = <&sdc2_off>; + vqmmc-supply = <&vreg_l13c_2p96>; /* IO line power */ + vmmc-supply = <&vreg_l17a_2p96>; /* Card power line */ + bus-width = <4>; + no-sdio; + no-mmc; +}; + +&uart2 { + status = "okay"; +}; + +&uart9 { + status = "okay"; +}; + +&ufs_mem_hc { + status = "okay"; + + reset-gpios = <&tlmm 175 GPIO_ACTIVE_LOW>; + + vcc-supply = <&vreg_l10a_2p96>; + vcc-max-microamp = <750000>; + vccq-supply = <&vreg_l5c_1p2>; + vccq-max-microamp = <700000>; + vccq2-supply = <&vreg_s4a_1p8>; + vccq2-max-microamp = <750000>; +}; + +&ufs_mem_phy { + status = "okay"; + + vdda-phy-supply = <&vreg_l8c_1p2>; + vdda-pll-supply = <&vreg_l5a_0p88>; +}; + +&usb_1 { + status = "okay"; +}; + +&usb_1_dwc3 { + dr_mode = "host"; + + pinctrl-names = "default"; + pinctrl-0 = <&usb2phy_ac_en1_default>; +}; + +&usb_1_hsphy { + status = "okay"; + vdda-pll-supply = <&vdd_usb_hs_core>; + vdda33-supply = <&vdda_usb_hs_3p1>; + vdda18-supply = <&vdda_usb_hs_1p8>; +}; + +&usb_1_qmpphy { + status = "disabled"; +}; + +&usb_2 { + status = "okay"; +}; + +&usb_2_dwc3 { + dr_mode = "host"; + + pinctrl-names = "default"; + pinctrl-0 = <&usb2phy_ac_en2_default>; +}; + +&usb_2_hsphy { + status = "okay"; + vdda-pll-supply = <&vdd_usb_hs_core>; + vdda33-supply = <&vdda_usb_hs_3p1>; + vdda18-supply = <&vdda_usb_hs_1p8>; +}; + +&usb_2_qmpphy { + status = "okay"; + vdda-phy-supply = <&vreg_l8c_1p2>; + vdda-pll-supply = <&vdda_usb_ss_dp_core_1>; +}; + +&pcie0 { + status = "okay"; +}; + +&pcie0_phy { + status = "okay"; + vdda-phy-supply = <&vreg_l18c_0p88>; + vdda-pll-supply = <&vreg_l8c_1p2>; +}; + +&pcie1_phy { + vdda-phy-supply = <&vreg_l18c_0p88>; + vdda-pll-supply = <&vreg_l8c_1p2>; +}; + +&tlmm { + gpio-reserved-ranges = <0 4>; + + sdc2_on: sdc2-on-state { + clk-pins { + pins = "sdc2_clk"; + bias-disable; /* No pull */ + drive-strength = <16>; /* 16 MA */ + }; + + cmd-pins { + pins = "sdc2_cmd"; + bias-pull-up; /* pull up */ + drive-strength = <16>; /* 16 MA */ + }; + + data-pins { + pins = "sdc2_data"; + bias-pull-up; /* pull up */ + drive-strength = <16>; /* 16 MA */ + }; + + sd-cd-pins { + pins = "gpio96"; + function = "gpio"; + bias-pull-up; /* pull up */ + drive-strength = <2>; /* 2 MA */ + }; + }; + + sdc2_off: sdc2-off-state { + clk-pins { + pins = "sdc2_clk"; + bias-disable; /* No pull */ + drive-strength = <2>; /* 2 MA */ + }; + + cmd-pins { + pins = "sdc2_cmd"; + bias-pull-up; /* pull up */ + drive-strength = <2>; /* 2 MA */ + }; + + data-pins { + pins = "sdc2_data"; + bias-pull-up; /* pull up */ + drive-strength = <2>; /* 2 MA */ + }; + + sd-cd-pins { + pins = "gpio96"; + function = "gpio"; + bias-pull-up; /* pull up */ + drive-strength = <2>; /* 2 MA */ + }; + }; + + usb2phy_ac_en1_default: usb2phy-ac-en1-default-state { + pins = "gpio113"; + function = "usb2phy_ac"; + bias-disable; + drive-strength = <2>; + }; + + usb2phy_ac_en2_default: usb2phy-ac-en2-default-state { + pins = "gpio123"; + function = "usb2phy_ac"; + bias-disable; + drive-strength = <2>; + }; + + ethernet_defaults: ethernet-defaults-state { + mdc-pins { + pins = "gpio7"; + function = "rgmii"; + bias-pull-up; + }; + + mdio-pins { + pins = "gpio59"; + function = "rgmii"; + bias-pull-up; + }; + + rgmii-rx-pins { + pins = "gpio117", "gpio118", "gpio119", "gpio120", "gpio115", "gpio116"; + function = "rgmii"; + bias-disable; + drive-strength = <2>; + }; + + rgmii-tx-pins { + pins = "gpio122", "gpio4", "gpio5", "gpio6", "gpio114", "gpio121"; + function = "rgmii"; + bias-pull-up; + drive-strength = <16>; + }; + + phy-intr-pins { + pins = "gpio124"; + function = "emac_phy"; + bias-disable; + drive-strength = <8>; + }; + + pps-pins { + pins = "gpio81"; + function = "emac_pps"; + bias-disable; + drive-strength = <8>; + }; + + phy-reset-pins { + pins = "gpio79"; + function = "gpio"; + bias-pull-up; + drive-strength = <16>; + }; + }; +}; diff --git a/arch/arm/dts/sa8155p.dtsi b/arch/arm/dts/sa8155p.dtsi new file mode 100644 index 0000000000..ffb7ab6952 --- /dev/null +++ b/arch/arm/dts/sa8155p.dtsi @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright (c) 2023, Linaro Limited + * + * SA8155P is an automotive variant of SM8150, with some minor changes. + * Most notably, the RPMhPD setup differs: MMCX and LCX/LMX rails are gone, + * though the cmd-db doesn't reflect that and access attemps result in a bite. + */ + +#include "sm8150.dtsi" + +&dispcc { + power-domains = <&rpmhpd SA8155P_CX>; +}; + +&mdss_dsi0 { + power-domains = <&rpmhpd SA8155P_CX>; +}; + +&mdss_dsi1 { + power-domains = <&rpmhpd SA8155P_CX>; +}; + +&mdss_mdp { + power-domains = <&rpmhpd SA8155P_CX>; +}; + +&remoteproc_slpi { + power-domains = <&rpmhpd SA8155P_CX>, + <&rpmhpd SA8155P_MX>; +}; + +&rpmhpd { + /* + * The bindings were crafted such that SA8155P PDs match their + * SM8150 counterparts to make it more maintainable and only + * necessitate adjusting entries that actually differ + */ + compatible = "qcom,sa8155p-rpmhpd"; +}; diff --git a/arch/arm/dts/sm8150.dtsi b/arch/arm/dts/sm8150.dtsi new file mode 100644 index 0000000000..761a6757dc --- /dev/null +++ b/arch/arm/dts/sm8150.dtsi @@ -0,0 +1,5293 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright (c) 2017-2019, The Linux Foundation. All rights reserved. + * Copyright (c) 2019, Linaro Limited + */ + +#include <dt-bindings/dma/qcom-gpi.h> +#include <dt-bindings/firmware/qcom,scm.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/phy/phy-qcom-qmp.h> +#include <dt-bindings/power/qcom-rpmpd.h> +#include <dt-bindings/soc/qcom,rpmh-rsc.h> +#include <dt-bindings/clock/qcom,rpmh.h> +#include <dt-bindings/clock/qcom,dispcc-sm8150.h> +#include <dt-bindings/clock/qcom,gcc-sm8150.h> +#include <dt-bindings/clock/qcom,gpucc-sm8150.h> +#include <dt-bindings/interconnect/qcom,osm-l3.h> +#include <dt-bindings/interconnect/qcom,sm8150.h> +#include <dt-bindings/thermal/thermal.h> + +/ { + interrupt-parent = <&intc>; + + #address-cells = <2>; + #size-cells = <2>; + + chosen { }; + + clocks { + xo_board: xo-board { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <38400000>; + clock-output-names = "xo_board"; + }; + + sleep_clk: sleep-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32764>; + clock-output-names = "sleep_clk"; + }; + }; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + CPU0: cpu@0 { + device_type = "cpu"; + compatible = "qcom,kryo485"; + reg = <0x0 0x0>; + clocks = <&cpufreq_hw 0>; + enable-method = "psci"; + capacity-dmips-mhz = <488>; + dynamic-power-coefficient = <232>; + next-level-cache = <&L2_0>; + qcom,freq-domain = <&cpufreq_hw 0>; + operating-points-v2 = <&cpu0_opp_table>; + interconnects = <&gem_noc MASTER_AMPSS_M0 0 &mc_virt SLAVE_EBI_CH0 0>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD0>; + power-domain-names = "psci"; + #cooling-cells = <2>; + L2_0: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + L3_0: l3-cache { + compatible = "cache"; + cache-level = <3>; + cache-unified; + }; + }; + }; + + CPU1: cpu@100 { + device_type = "cpu"; + compatible = "qcom,kryo485"; + reg = <0x0 0x100>; + clocks = <&cpufreq_hw 0>; + enable-method = "psci"; + capacity-dmips-mhz = <488>; + dynamic-power-coefficient = <232>; + next-level-cache = <&L2_100>; + qcom,freq-domain = <&cpufreq_hw 0>; + operating-points-v2 = <&cpu0_opp_table>; + interconnects = <&gem_noc MASTER_AMPSS_M0 0 &mc_virt SLAVE_EBI_CH0 0>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD1>; + power-domain-names = "psci"; + #cooling-cells = <2>; + L2_100: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU2: cpu@200 { + device_type = "cpu"; + compatible = "qcom,kryo485"; + reg = <0x0 0x200>; + clocks = <&cpufreq_hw 0>; + enable-method = "psci"; + capacity-dmips-mhz = <488>; + dynamic-power-coefficient = <232>; + next-level-cache = <&L2_200>; + qcom,freq-domain = <&cpufreq_hw 0>; + operating-points-v2 = <&cpu0_opp_table>; + interconnects = <&gem_noc MASTER_AMPSS_M0 0 &mc_virt SLAVE_EBI_CH0 0>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD2>; + power-domain-names = "psci"; + #cooling-cells = <2>; + L2_200: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU3: cpu@300 { + device_type = "cpu"; + compatible = "qcom,kryo485"; + reg = <0x0 0x300>; + clocks = <&cpufreq_hw 0>; + enable-method = "psci"; + capacity-dmips-mhz = <488>; + dynamic-power-coefficient = <232>; + next-level-cache = <&L2_300>; + qcom,freq-domain = <&cpufreq_hw 0>; + operating-points-v2 = <&cpu0_opp_table>; + interconnects = <&gem_noc MASTER_AMPSS_M0 0 &mc_virt SLAVE_EBI_CH0 0>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD3>; + power-domain-names = "psci"; + #cooling-cells = <2>; + L2_300: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU4: cpu@400 { + device_type = "cpu"; + compatible = "qcom,kryo485"; + reg = <0x0 0x400>; + clocks = <&cpufreq_hw 1>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <369>; + next-level-cache = <&L2_400>; + qcom,freq-domain = <&cpufreq_hw 1>; + operating-points-v2 = <&cpu4_opp_table>; + interconnects = <&gem_noc MASTER_AMPSS_M0 0 &mc_virt SLAVE_EBI_CH0 0>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD4>; + power-domain-names = "psci"; + #cooling-cells = <2>; + L2_400: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU5: cpu@500 { + device_type = "cpu"; + compatible = "qcom,kryo485"; + reg = <0x0 0x500>; + clocks = <&cpufreq_hw 1>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <369>; + next-level-cache = <&L2_500>; + qcom,freq-domain = <&cpufreq_hw 1>; + operating-points-v2 = <&cpu4_opp_table>; + interconnects = <&gem_noc MASTER_AMPSS_M0 0 &mc_virt SLAVE_EBI_CH0 0>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD5>; + power-domain-names = "psci"; + #cooling-cells = <2>; + L2_500: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU6: cpu@600 { + device_type = "cpu"; + compatible = "qcom,kryo485"; + reg = <0x0 0x600>; + clocks = <&cpufreq_hw 1>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <369>; + next-level-cache = <&L2_600>; + qcom,freq-domain = <&cpufreq_hw 1>; + operating-points-v2 = <&cpu4_opp_table>; + interconnects = <&gem_noc MASTER_AMPSS_M0 0 &mc_virt SLAVE_EBI_CH0 0>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD6>; + power-domain-names = "psci"; + #cooling-cells = <2>; + L2_600: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU7: cpu@700 { + device_type = "cpu"; + compatible = "qcom,kryo485"; + reg = <0x0 0x700>; + clocks = <&cpufreq_hw 2>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <421>; + next-level-cache = <&L2_700>; + qcom,freq-domain = <&cpufreq_hw 2>; + operating-points-v2 = <&cpu7_opp_table>; + interconnects = <&gem_noc MASTER_AMPSS_M0 0 &mc_virt SLAVE_EBI_CH0 0>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD7>; + power-domain-names = "psci"; + #cooling-cells = <2>; + L2_700: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + cpu-map { + cluster0 { + core0 { + cpu = <&CPU0>; + }; + + core1 { + cpu = <&CPU1>; + }; + + core2 { + cpu = <&CPU2>; + }; + + core3 { + cpu = <&CPU3>; + }; + + core4 { + cpu = <&CPU4>; + }; + + core5 { + cpu = <&CPU5>; + }; + + core6 { + cpu = <&CPU6>; + }; + + core7 { + cpu = <&CPU7>; + }; + }; + }; + + idle-states { + entry-method = "psci"; + + LITTLE_CPU_SLEEP_0: cpu-sleep-0-0 { + compatible = "arm,idle-state"; + idle-state-name = "little-rail-power-collapse"; + arm,psci-suspend-param = <0x40000004>; + entry-latency-us = <355>; + exit-latency-us = <909>; + min-residency-us = <3934>; + local-timer-stop; + }; + + BIG_CPU_SLEEP_0: cpu-sleep-1-0 { + compatible = "arm,idle-state"; + idle-state-name = "big-rail-power-collapse"; + arm,psci-suspend-param = <0x40000004>; + entry-latency-us = <241>; + exit-latency-us = <1461>; + min-residency-us = <4488>; + local-timer-stop; + }; + }; + + domain-idle-states { + CLUSTER_SLEEP_0: cluster-sleep-0 { + compatible = "domain-idle-state"; + arm,psci-suspend-param = <0x4100c244>; + entry-latency-us = <3263>; + exit-latency-us = <6562>; + min-residency-us = <9987>; + }; + }; + }; + + cpu0_opp_table: opp-table-cpu0 { + compatible = "operating-points-v2"; + opp-shared; + + cpu0_opp1: opp-300000000 { + opp-hz = /bits/ 64 <300000000>; + opp-peak-kBps = <800000 9600000>; + }; + + cpu0_opp2: opp-403200000 { + opp-hz = /bits/ 64 <403200000>; + opp-peak-kBps = <800000 9600000>; + }; + + cpu0_opp3: opp-499200000 { + opp-hz = /bits/ 64 <499200000>; + opp-peak-kBps = <800000 12902400>; + }; + + cpu0_opp4: opp-576000000 { + opp-hz = /bits/ 64 <576000000>; + opp-peak-kBps = <800000 12902400>; + }; + + cpu0_opp5: opp-672000000 { + opp-hz = /bits/ 64 <672000000>; + opp-peak-kBps = <800000 15974400>; + }; + + cpu0_opp6: opp-768000000 { + opp-hz = /bits/ 64 <768000000>; + opp-peak-kBps = <1804000 19660800>; + }; + + cpu0_opp7: opp-844800000 { + opp-hz = /bits/ 64 <844800000>; + opp-peak-kBps = <1804000 19660800>; + }; + + cpu0_opp8: opp-940800000 { + opp-hz = /bits/ 64 <940800000>; + opp-peak-kBps = <1804000 22732800>; + }; + + cpu0_opp9: opp-1036800000 { + opp-hz = /bits/ 64 <1036800000>; + opp-peak-kBps = <1804000 22732800>; + }; + + cpu0_opp10: opp-1113600000 { + opp-hz = /bits/ 64 <1113600000>; + opp-peak-kBps = <2188000 25804800>; + }; + + cpu0_opp11: opp-1209600000 { + opp-hz = /bits/ 64 <1209600000>; + opp-peak-kBps = <2188000 31948800>; + }; + + cpu0_opp12: opp-1305600000 { + opp-hz = /bits/ 64 <1305600000>; + opp-peak-kBps = <3072000 31948800>; + }; + + cpu0_opp13: opp-1382400000 { + opp-hz = /bits/ 64 <1382400000>; + opp-peak-kBps = <3072000 31948800>; + }; + + cpu0_opp14: opp-1478400000 { + opp-hz = /bits/ 64 <1478400000>; + opp-peak-kBps = <3072000 31948800>; + }; + + cpu0_opp15: opp-1555200000 { + opp-hz = /bits/ 64 <1555200000>; + opp-peak-kBps = <3072000 40550400>; + }; + + cpu0_opp16: opp-1632000000 { + opp-hz = /bits/ 64 <1632000000>; + opp-peak-kBps = <3072000 40550400>; + }; + + cpu0_opp17: opp-1708800000 { + opp-hz = /bits/ 64 <1708800000>; + opp-peak-kBps = <3072000 43008000>; + }; + + cpu0_opp18: opp-1785600000 { + opp-hz = /bits/ 64 <1785600000>; + opp-peak-kBps = <3072000 43008000>; + }; + }; + + cpu4_opp_table: opp-table-cpu4 { + compatible = "operating-points-v2"; + opp-shared; + + cpu4_opp1: opp-710400000 { + opp-hz = /bits/ 64 <710400000>; + opp-peak-kBps = <1804000 15974400>; + }; + + cpu4_opp2: opp-825600000 { + opp-hz = /bits/ 64 <825600000>; + opp-peak-kBps = <2188000 19660800>; + }; + + cpu4_opp3: opp-940800000 { + opp-hz = /bits/ 64 <940800000>; + opp-peak-kBps = <2188000 22732800>; + }; + + cpu4_opp4: opp-1056000000 { + opp-hz = /bits/ 64 <1056000000>; + opp-peak-kBps = <3072000 25804800>; + }; + + cpu4_opp5: opp-1171200000 { + opp-hz = /bits/ 64 <1171200000>; + opp-peak-kBps = <3072000 31948800>; + }; + + cpu4_opp6: opp-1286400000 { + opp-hz = /bits/ 64 <1286400000>; + opp-peak-kBps = <4068000 31948800>; + }; + + cpu4_opp7: opp-1401600000 { + opp-hz = /bits/ 64 <1401600000>; + opp-peak-kBps = <4068000 31948800>; + }; + + cpu4_opp8: opp-1497600000 { + opp-hz = /bits/ 64 <1497600000>; + opp-peak-kBps = <4068000 40550400>; + }; + + cpu4_opp9: opp-1612800000 { + opp-hz = /bits/ 64 <1612800000>; + opp-peak-kBps = <4068000 40550400>; + }; + + cpu4_opp10: opp-1708800000 { + opp-hz = /bits/ 64 <1708800000>; + opp-peak-kBps = <4068000 43008000>; + }; + + cpu4_opp11: opp-1804800000 { + opp-hz = /bits/ 64 <1804800000>; + opp-peak-kBps = <6220000 43008000>; + }; + + cpu4_opp12: opp-1920000000 { + opp-hz = /bits/ 64 <1920000000>; + opp-peak-kBps = <6220000 49152000>; + }; + + cpu4_opp13: opp-2016000000 { + opp-hz = /bits/ 64 <2016000000>; + opp-peak-kBps = <7216000 49152000>; + }; + + cpu4_opp14: opp-2131200000 { + opp-hz = /bits/ 64 <2131200000>; + opp-peak-kBps = <8368000 49152000>; + }; + + cpu4_opp15: opp-2227200000 { + opp-hz = /bits/ 64 <2227200000>; + opp-peak-kBps = <8368000 51609600>; + }; + + cpu4_opp16: opp-2323200000 { + opp-hz = /bits/ 64 <2323200000>; + opp-peak-kBps = <8368000 51609600>; + }; + + cpu4_opp17: opp-2419200000 { + opp-hz = /bits/ 64 <2419200000>; + opp-peak-kBps = <8368000 51609600>; + }; + }; + + cpu7_opp_table: opp-table-cpu7 { + compatible = "operating-points-v2"; + opp-shared; + + cpu7_opp1: opp-825600000 { + opp-hz = /bits/ 64 <825600000>; + opp-peak-kBps = <2188000 19660800>; + }; + + cpu7_opp2: opp-940800000 { + opp-hz = /bits/ 64 <940800000>; + opp-peak-kBps = <2188000 22732800>; + }; + + cpu7_opp3: opp-1056000000 { + opp-hz = /bits/ 64 <1056000000>; + opp-peak-kBps = <3072000 25804800>; + }; + + cpu7_opp4: opp-1171200000 { + opp-hz = /bits/ 64 <1171200000>; + opp-peak-kBps = <3072000 31948800>; + }; + + cpu7_opp5: opp-1286400000 { + opp-hz = /bits/ 64 <1286400000>; + opp-peak-kBps = <4068000 31948800>; + }; + + cpu7_opp6: opp-1401600000 { + opp-hz = /bits/ 64 <1401600000>; + opp-peak-kBps = <4068000 31948800>; + }; + + cpu7_opp7: opp-1497600000 { + opp-hz = /bits/ 64 <1497600000>; + opp-peak-kBps = <4068000 40550400>; + }; + + cpu7_opp8: opp-1612800000 { + opp-hz = /bits/ 64 <1612800000>; + opp-peak-kBps = <4068000 40550400>; + }; + + cpu7_opp9: opp-1708800000 { + opp-hz = /bits/ 64 <1708800000>; + opp-peak-kBps = <4068000 43008000>; + }; + + cpu7_opp10: opp-1804800000 { + opp-hz = /bits/ 64 <1804800000>; + opp-peak-kBps = <6220000 43008000>; + }; + + cpu7_opp11: opp-1920000000 { + opp-hz = /bits/ 64 <1920000000>; + opp-peak-kBps = <6220000 49152000>; + }; + + cpu7_opp12: opp-2016000000 { + opp-hz = /bits/ 64 <2016000000>; + opp-peak-kBps = <7216000 49152000>; + }; + + cpu7_opp13: opp-2131200000 { + opp-hz = /bits/ 64 <2131200000>; + opp-peak-kBps = <8368000 49152000>; + }; + + cpu7_opp14: opp-2227200000 { + opp-hz = /bits/ 64 <2227200000>; + opp-peak-kBps = <8368000 51609600>; + }; + + cpu7_opp15: opp-2323200000 { + opp-hz = /bits/ 64 <2323200000>; + opp-peak-kBps = <8368000 51609600>; + }; + + cpu7_opp16: opp-2419200000 { + opp-hz = /bits/ 64 <2419200000>; + opp-peak-kBps = <8368000 51609600>; + }; + + cpu7_opp17: opp-2534400000 { + opp-hz = /bits/ 64 <2534400000>; + opp-peak-kBps = <8368000 51609600>; + }; + + cpu7_opp18: opp-2649600000 { + opp-hz = /bits/ 64 <2649600000>; + opp-peak-kBps = <8368000 51609600>; + }; + + cpu7_opp19: opp-2745600000 { + opp-hz = /bits/ 64 <2745600000>; + opp-peak-kBps = <8368000 51609600>; + }; + + cpu7_opp20: opp-2841600000 { + opp-hz = /bits/ 64 <2841600000>; + opp-peak-kBps = <8368000 51609600>; + }; + }; + + firmware { + scm: scm { + compatible = "qcom,scm-sm8150", "qcom,scm"; + #reset-cells = <1>; + }; + }; + + memory@80000000 { + device_type = "memory"; + /* We expect the bootloader to fill in the size */ + reg = <0x0 0x80000000 0x0 0x0>; + }; + + pmu { + compatible = "arm,armv8-pmuv3"; + interrupts = <GIC_PPI 5 IRQ_TYPE_LEVEL_HIGH>; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + + CPU_PD0: power-domain-cpu0 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&LITTLE_CPU_SLEEP_0>; + }; + + CPU_PD1: power-domain-cpu1 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&LITTLE_CPU_SLEEP_0>; + }; + + CPU_PD2: power-domain-cpu2 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&LITTLE_CPU_SLEEP_0>; + }; + + CPU_PD3: power-domain-cpu3 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&LITTLE_CPU_SLEEP_0>; + }; + + CPU_PD4: power-domain-cpu4 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&BIG_CPU_SLEEP_0>; + }; + + CPU_PD5: power-domain-cpu5 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&BIG_CPU_SLEEP_0>; + }; + + CPU_PD6: power-domain-cpu6 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&BIG_CPU_SLEEP_0>; + }; + + CPU_PD7: power-domain-cpu7 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&BIG_CPU_SLEEP_0>; + }; + + CLUSTER_PD: power-domain-cpu-cluster0 { + #power-domain-cells = <0>; + domain-idle-states = <&CLUSTER_SLEEP_0>; + }; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + hyp_mem: memory@85700000 { + reg = <0x0 0x85700000 0x0 0x600000>; + no-map; + }; + + xbl_mem: memory@85d00000 { + reg = <0x0 0x85d00000 0x0 0x140000>; + no-map; + }; + + aop_mem: memory@85f00000 { + reg = <0x0 0x85f00000 0x0 0x20000>; + no-map; + }; + + aop_cmd_db: memory@85f20000 { + compatible = "qcom,cmd-db"; + reg = <0x0 0x85f20000 0x0 0x20000>; + no-map; + }; + + smem_mem: memory@86000000 { + reg = <0x0 0x86000000 0x0 0x200000>; + no-map; + }; + + tz_mem: memory@86200000 { + reg = <0x0 0x86200000 0x0 0x3900000>; + no-map; + }; + + rmtfs_mem: memory@89b00000 { + compatible = "qcom,rmtfs-mem"; + reg = <0x0 0x89b00000 0x0 0x200000>; + no-map; + + qcom,client-id = <1>; + qcom,vmid = <QCOM_SCM_VMID_MSS_MSA>; + }; + + camera_mem: memory@8b700000 { + reg = <0x0 0x8b700000 0x0 0x500000>; + no-map; + }; + + wlan_mem: memory@8bc00000 { + reg = <0x0 0x8bc00000 0x0 0x180000>; + no-map; + }; + + npu_mem: memory@8bd80000 { + reg = <0x0 0x8bd80000 0x0 0x80000>; + no-map; + }; + + adsp_mem: memory@8be00000 { + reg = <0x0 0x8be00000 0x0 0x1a00000>; + no-map; + }; + + mpss_mem: memory@8d800000 { + reg = <0x0 0x8d800000 0x0 0x9600000>; + no-map; + }; + + venus_mem: memory@96e00000 { + reg = <0x0 0x96e00000 0x0 0x500000>; + no-map; + }; + + slpi_mem: memory@97300000 { + reg = <0x0 0x97300000 0x0 0x1400000>; + no-map; + }; + + ipa_fw_mem: memory@98700000 { + reg = <0x0 0x98700000 0x0 0x10000>; + no-map; + }; + + ipa_gsi_mem: memory@98710000 { + reg = <0x0 0x98710000 0x0 0x5000>; + no-map; + }; + + gpu_mem: memory@98715000 { + reg = <0x0 0x98715000 0x0 0x2000>; + no-map; + }; + + spss_mem: memory@98800000 { + reg = <0x0 0x98800000 0x0 0x100000>; + no-map; + }; + + cdsp_mem: memory@98900000 { + reg = <0x0 0x98900000 0x0 0x1400000>; + no-map; + }; + + qseecom_mem: memory@9e400000 { + reg = <0x0 0x9e400000 0x0 0x1400000>; + no-map; + }; + }; + + smem { + compatible = "qcom,smem"; + memory-region = <&smem_mem>; + hwlocks = <&tcsr_mutex 3>; + }; + + smp2p-cdsp { + compatible = "qcom,smp2p"; + qcom,smem = <94>, <432>; + + interrupts = <GIC_SPI 576 IRQ_TYPE_EDGE_RISING>; + + mboxes = <&apss_shared 6>; + + qcom,local-pid = <0>; + qcom,remote-pid = <5>; + + cdsp_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + cdsp_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-lpass { + compatible = "qcom,smp2p"; + qcom,smem = <443>, <429>; + + interrupts = <GIC_SPI 158 IRQ_TYPE_EDGE_RISING>; + + mboxes = <&apss_shared 10>; + + qcom,local-pid = <0>; + qcom,remote-pid = <2>; + + adsp_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + adsp_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-mpss { + compatible = "qcom,smp2p"; + qcom,smem = <435>, <428>; + + interrupts = <GIC_SPI 451 IRQ_TYPE_EDGE_RISING>; + + mboxes = <&apss_shared 14>; + + qcom,local-pid = <0>; + qcom,remote-pid = <1>; + + modem_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + modem_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-slpi { + compatible = "qcom,smp2p"; + qcom,smem = <481>, <430>; + + interrupts = <GIC_SPI 172 IRQ_TYPE_EDGE_RISING>; + + mboxes = <&apss_shared 26>; + + qcom,local-pid = <0>; + qcom,remote-pid = <3>; + + slpi_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + slpi_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + soc: soc@0 { + #address-cells = <2>; + #size-cells = <2>; + ranges = <0 0 0 0 0x10 0>; + dma-ranges = <0 0 0 0 0x10 0>; + compatible = "simple-bus"; + + gcc: clock-controller@100000 { + compatible = "qcom,gcc-sm8150"; + reg = <0x0 0x00100000 0x0 0x1f0000>; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + clock-names = "bi_tcxo", + "sleep_clk"; + clocks = <&rpmhcc RPMH_CXO_CLK>, + <&sleep_clk>; + }; + + gpi_dma0: dma-controller@800000 { + compatible = "qcom,sm8150-gpi-dma", "qcom,sdm845-gpi-dma"; + reg = <0 0x00800000 0 0x60000>; + interrupts = <GIC_SPI 244 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 251 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 254 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 255 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>; + dma-channels = <13>; + dma-channel-mask = <0xfa>; + iommus = <&apps_smmu 0x00d6 0x0>; + #dma-cells = <3>; + status = "disabled"; + }; + + ethernet: ethernet@20000 { + compatible = "qcom,sm8150-ethqos"; + reg = <0x0 0x00020000 0x0 0x10000>, + <0x0 0x00036000 0x0 0x100>; + reg-names = "stmmaceth", "rgmii"; + clock-names = "stmmaceth", "pclk", "ptp_ref", "rgmii"; + clocks = <&gcc GCC_EMAC_AXI_CLK>, + <&gcc GCC_EMAC_SLV_AHB_CLK>, + <&gcc GCC_EMAC_PTP_CLK>, + <&gcc GCC_EMAC_RGMII_CLK>; + interrupts = <GIC_SPI 689 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 699 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq", "eth_lpi"; + + power-domains = <&gcc EMAC_GDSC>; + resets = <&gcc GCC_EMAC_BCR>; + + iommus = <&apps_smmu 0x3c0 0x0>; + + snps,tso; + rx-fifo-depth = <4096>; + tx-fifo-depth = <4096>; + + status = "disabled"; + }; + + qfprom: efuse@784000 { + compatible = "qcom,sm8150-qfprom", "qcom,qfprom"; + reg = <0 0x00784000 0 0x8ff>; + #address-cells = <1>; + #size-cells = <1>; + + gpu_speed_bin: gpu_speed_bin@133 { + reg = <0x133 0x1>; + bits = <5 3>; + }; + }; + + qupv3_id_0: geniqup@8c0000 { + compatible = "qcom,geni-se-qup"; + reg = <0x0 0x008c0000 0x0 0x6000>; + clock-names = "m-ahb", "s-ahb"; + clocks = <&gcc GCC_QUPV3_WRAP_0_M_AHB_CLK>, + <&gcc GCC_QUPV3_WRAP_0_S_AHB_CLK>; + iommus = <&apps_smmu 0xc3 0x0>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + status = "disabled"; + + i2c0: i2c@880000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00880000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S0_CLK>; + dmas = <&gpi_dma0 0 0 QCOM_GPI_I2C>, + <&gpi_dma0 1 0 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c0_default>; + interrupts = <GIC_SPI 601 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi0: spi@880000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00880000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S0_CLK>; + dmas = <&gpi_dma0 0 0 QCOM_GPI_SPI>, + <&gpi_dma0 1 0 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi0_default>; + interrupts = <GIC_SPI 601 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c1: i2c@884000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00884000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S1_CLK>; + dmas = <&gpi_dma0 0 1 QCOM_GPI_I2C>, + <&gpi_dma0 1 1 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c1_default>; + interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi1: spi@884000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00884000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S1_CLK>; + dmas = <&gpi_dma0 0 1 QCOM_GPI_SPI>, + <&gpi_dma0 1 1 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi1_default>; + interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c2: i2c@888000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00888000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S2_CLK>; + dmas = <&gpi_dma0 0 2 QCOM_GPI_I2C>, + <&gpi_dma0 1 2 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c2_default>; + interrupts = <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi2: spi@888000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00888000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S2_CLK>; + dmas = <&gpi_dma0 0 2 QCOM_GPI_SPI>, + <&gpi_dma0 1 2 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi2_default>; + interrupts = <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c3: i2c@88c000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x0088c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S3_CLK>; + dmas = <&gpi_dma0 0 3 QCOM_GPI_I2C>, + <&gpi_dma0 1 3 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c3_default>; + interrupts = <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi3: spi@88c000 { + compatible = "qcom,geni-spi"; + reg = <0 0x0088c000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S3_CLK>; + dmas = <&gpi_dma0 0 3 QCOM_GPI_SPI>, + <&gpi_dma0 1 3 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi3_default>; + interrupts = <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c4: i2c@890000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00890000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S4_CLK>; + dmas = <&gpi_dma0 0 4 QCOM_GPI_I2C>, + <&gpi_dma0 1 4 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c4_default>; + interrupts = <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi4: spi@890000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00890000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S4_CLK>; + dmas = <&gpi_dma0 0 4 QCOM_GPI_SPI>, + <&gpi_dma0 1 4 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi4_default>; + interrupts = <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c5: i2c@894000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00894000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S5_CLK>; + dmas = <&gpi_dma0 0 5 QCOM_GPI_I2C>, + <&gpi_dma0 1 5 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c5_default>; + interrupts = <GIC_SPI 606 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi5: spi@894000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00894000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S5_CLK>; + dmas = <&gpi_dma0 0 5 QCOM_GPI_SPI>, + <&gpi_dma0 1 5 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi5_default>; + interrupts = <GIC_SPI 606 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c6: i2c@898000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00898000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S6_CLK>; + dmas = <&gpi_dma0 0 6 QCOM_GPI_I2C>, + <&gpi_dma0 1 6 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c6_default>; + interrupts = <GIC_SPI 607 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi6: spi@898000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00898000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S6_CLK>; + dmas = <&gpi_dma0 0 6 QCOM_GPI_SPI>, + <&gpi_dma0 1 6 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi6_default>; + interrupts = <GIC_SPI 607 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c7: i2c@89c000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x0089c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S7_CLK>; + dmas = <&gpi_dma0 0 7 QCOM_GPI_I2C>, + <&gpi_dma0 1 7 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c7_default>; + interrupts = <GIC_SPI 608 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi7: spi@89c000 { + compatible = "qcom,geni-spi"; + reg = <0 0x0089c000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S7_CLK>; + dmas = <&gpi_dma0 0 7 QCOM_GPI_SPI>, + <&gpi_dma0 1 7 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi7_default>; + interrupts = <GIC_SPI 608 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + }; + + gpi_dma1: dma-controller@a00000 { + compatible = "qcom,sm8150-gpi-dma", "qcom,sdm845-gpi-dma"; + reg = <0 0x00a00000 0 0x60000>; + interrupts = <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 281 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 282 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 283 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 284 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 293 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 294 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 295 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 296 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 297 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 298 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>; + dma-channels = <13>; + dma-channel-mask = <0xfa>; + iommus = <&apps_smmu 0x0616 0x0>; + #dma-cells = <3>; + status = "disabled"; + }; + + qupv3_id_1: geniqup@ac0000 { + compatible = "qcom,geni-se-qup"; + reg = <0x0 0x00ac0000 0x0 0x6000>; + clock-names = "m-ahb", "s-ahb"; + clocks = <&gcc GCC_QUPV3_WRAP_1_M_AHB_CLK>, + <&gcc GCC_QUPV3_WRAP_1_S_AHB_CLK>; + iommus = <&apps_smmu 0x603 0x0>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + status = "disabled"; + + i2c8: i2c@a80000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a80000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S0_CLK>; + dmas = <&gpi_dma1 0 0 QCOM_GPI_I2C>, + <&gpi_dma1 1 0 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c8_default>; + interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi8: spi@a80000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a80000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S0_CLK>; + dmas = <&gpi_dma1 0 0 QCOM_GPI_SPI>, + <&gpi_dma1 1 0 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi8_default>; + interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c9: i2c@a84000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a84000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; + dmas = <&gpi_dma1 0 1 QCOM_GPI_I2C>, + <&gpi_dma1 1 1 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c9_default>; + interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi9: spi@a84000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a84000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; + dmas = <&gpi_dma1 0 1 QCOM_GPI_SPI>, + <&gpi_dma1 1 1 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi9_default>; + interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + uart9: serial@a84000 { + compatible = "qcom,geni-uart"; + reg = <0x0 0x00a84000 0x0 0x4000>; + clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; + clock-names = "se"; + pinctrl-0 = <&qup_uart9_default>; + pinctrl-names = "default"; + interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + i2c10: i2c@a88000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a88000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S2_CLK>; + dmas = <&gpi_dma1 0 2 QCOM_GPI_I2C>, + <&gpi_dma1 1 2 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c10_default>; + interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi10: spi@a88000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a88000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S2_CLK>; + dmas = <&gpi_dma1 0 2 QCOM_GPI_SPI>, + <&gpi_dma1 1 2 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi10_default>; + interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c11: i2c@a8c000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a8c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S3_CLK>; + dmas = <&gpi_dma1 0 3 QCOM_GPI_I2C>, + <&gpi_dma1 1 3 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c11_default>; + interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi11: spi@a8c000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a8c000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S3_CLK>; + dmas = <&gpi_dma1 0 3 QCOM_GPI_SPI>, + <&gpi_dma1 1 3 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi11_default>; + interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + uart2: serial@a90000 { + compatible = "qcom,geni-debug-uart"; + reg = <0x0 0x00a90000 0x0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S4_CLK>; + interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + i2c12: i2c@a90000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a90000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S4_CLK>; + dmas = <&gpi_dma1 0 4 QCOM_GPI_I2C>, + <&gpi_dma1 1 4 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c12_default>; + interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi12: spi@a90000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a90000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S4_CLK>; + dmas = <&gpi_dma1 0 4 QCOM_GPI_SPI>, + <&gpi_dma1 1 4 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi12_default>; + interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c16: i2c@94000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00094000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S5_CLK>; + dmas = <&gpi_dma2 0 5 QCOM_GPI_I2C>, + <&gpi_dma2 1 5 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c16_default>; + interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi16: spi@a94000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a94000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S5_CLK>; + dmas = <&gpi_dma2 0 5 QCOM_GPI_SPI>, + <&gpi_dma2 1 5 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi16_default>; + interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + }; + + gpi_dma2: dma-controller@c00000 { + compatible = "qcom,sm8150-gpi-dma", "qcom,sdm845-gpi-dma"; + reg = <0 0x00c00000 0 0x60000>; + interrupts = <GIC_SPI 588 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 589 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 590 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 591 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 592 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 593 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 594 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 595 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 596 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 597 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 598 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 599 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 600 IRQ_TYPE_LEVEL_HIGH>; + dma-channels = <13>; + dma-channel-mask = <0xfa>; + iommus = <&apps_smmu 0x07b6 0x0>; + #dma-cells = <3>; + status = "disabled"; + }; + + qupv3_id_2: geniqup@cc0000 { + compatible = "qcom,geni-se-qup"; + reg = <0x0 0x00cc0000 0x0 0x6000>; + + clock-names = "m-ahb", "s-ahb"; + clocks = <&gcc GCC_QUPV3_WRAP_2_M_AHB_CLK>, + <&gcc GCC_QUPV3_WRAP_2_S_AHB_CLK>; + iommus = <&apps_smmu 0x7a3 0x0>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + status = "disabled"; + + i2c17: i2c@c80000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00c80000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S0_CLK>; + dmas = <&gpi_dma2 0 0 QCOM_GPI_I2C>, + <&gpi_dma2 1 0 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c17_default>; + interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi17: spi@c80000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00c80000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S0_CLK>; + dmas = <&gpi_dma2 0 0 QCOM_GPI_SPI>, + <&gpi_dma2 1 0 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi17_default>; + interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c18: i2c@c84000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00c84000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S1_CLK>; + dmas = <&gpi_dma2 0 1 QCOM_GPI_I2C>, + <&gpi_dma2 1 1 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c18_default>; + interrupts = <GIC_SPI 583 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi18: spi@c84000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00c84000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S1_CLK>; + dmas = <&gpi_dma2 0 1 QCOM_GPI_SPI>, + <&gpi_dma2 1 1 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi18_default>; + interrupts = <GIC_SPI 583 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c19: i2c@c88000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00c88000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S2_CLK>; + dmas = <&gpi_dma2 0 2 QCOM_GPI_I2C>, + <&gpi_dma2 1 2 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c19_default>; + interrupts = <GIC_SPI 584 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi19: spi@c88000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00c88000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S2_CLK>; + dmas = <&gpi_dma2 0 2 QCOM_GPI_SPI>, + <&gpi_dma2 1 2 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi19_default>; + interrupts = <GIC_SPI 584 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c13: i2c@c8c000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00c8c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S3_CLK>; + dmas = <&gpi_dma2 0 3 QCOM_GPI_I2C>, + <&gpi_dma2 1 3 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c13_default>; + interrupts = <GIC_SPI 585 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi13: spi@c8c000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00c8c000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S3_CLK>; + dmas = <&gpi_dma2 0 3 QCOM_GPI_SPI>, + <&gpi_dma2 1 3 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi13_default>; + interrupts = <GIC_SPI 585 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c14: i2c@c90000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00c90000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S4_CLK>; + dmas = <&gpi_dma2 0 4 QCOM_GPI_I2C>, + <&gpi_dma2 1 4 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c14_default>; + interrupts = <GIC_SPI 586 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi14: spi@c90000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00c90000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S4_CLK>; + dmas = <&gpi_dma2 0 4 QCOM_GPI_SPI>, + <&gpi_dma2 1 4 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi14_default>; + interrupts = <GIC_SPI 586 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c15: i2c@c94000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00c94000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S5_CLK>; + dmas = <&gpi_dma2 0 5 QCOM_GPI_I2C>, + <&gpi_dma2 1 5 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c15_default>; + interrupts = <GIC_SPI 587 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi15: spi@c94000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00c94000 0 0x4000>; + reg-names = "se"; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP2_S5_CLK>; + dmas = <&gpi_dma2 0 5 QCOM_GPI_SPI>, + <&gpi_dma2 1 5 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi15_default>; + interrupts = <GIC_SPI 587 IRQ_TYPE_LEVEL_HIGH>; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + }; + + config_noc: interconnect@1500000 { + compatible = "qcom,sm8150-config-noc"; + reg = <0 0x01500000 0 0x7400>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + system_noc: interconnect@1620000 { + compatible = "qcom,sm8150-system-noc"; + reg = <0 0x01620000 0 0x19400>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + mc_virt: interconnect@163a000 { + compatible = "qcom,sm8150-mc-virt"; + reg = <0 0x0163a000 0 0x1000>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + aggre1_noc: interconnect@16e0000 { + compatible = "qcom,sm8150-aggre1-noc"; + reg = <0 0x016e0000 0 0xd080>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + aggre2_noc: interconnect@1700000 { + compatible = "qcom,sm8150-aggre2-noc"; + reg = <0 0x01700000 0 0x20000>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + compute_noc: interconnect@1720000 { + compatible = "qcom,sm8150-compute-noc"; + reg = <0 0x01720000 0 0x7000>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + mmss_noc: interconnect@1740000 { + compatible = "qcom,sm8150-mmss-noc"; + reg = <0 0x01740000 0 0x1c100>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + system-cache-controller@9200000 { + compatible = "qcom,sm8150-llcc"; + reg = <0 0x09200000 0 0x50000>, <0 0x09280000 0 0x50000>, + <0 0x09300000 0 0x50000>, <0 0x09380000 0 0x50000>, + <0 0x09600000 0 0x50000>; + reg-names = "llcc0_base", "llcc1_base", "llcc2_base", + "llcc3_base", "llcc_broadcast_base"; + interrupts = <GIC_SPI 582 IRQ_TYPE_LEVEL_HIGH>; + }; + + dma@10a2000 { + compatible = "qcom,sm8150-dcc", "qcom,dcc"; + reg = <0x0 0x010a2000 0x0 0x1000>, + <0x0 0x010ad000 0x0 0x3000>; + }; + + pcie0: pcie@1c00000 { + compatible = "qcom,pcie-sm8150"; + reg = <0 0x01c00000 0 0x3000>, + <0 0x60000000 0 0xf1d>, + <0 0x60000f20 0 0xa8>, + <0 0x60001000 0 0x1000>, + <0 0x60100000 0 0x100000>; + reg-names = "parf", "dbi", "elbi", "atu", "config"; + device_type = "pci"; + linux,pci-domain = <0>; + bus-range = <0x00 0xff>; + num-lanes = <1>; + + #address-cells = <3>; + #size-cells = <2>; + + ranges = <0x01000000 0x0 0x00000000 0x0 0x60200000 0x0 0x100000>, + <0x02000000 0x0 0x60300000 0x0 0x60300000 0x0 0x3d00000>; + + interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &intc 0 149 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ + <0 0 0 2 &intc 0 150 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ + <0 0 0 3 &intc 0 151 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ + <0 0 0 4 &intc 0 152 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ + + clocks = <&gcc GCC_PCIE_0_PIPE_CLK>, + <&gcc GCC_PCIE_0_AUX_CLK>, + <&gcc GCC_PCIE_0_CFG_AHB_CLK>, + <&gcc GCC_PCIE_0_MSTR_AXI_CLK>, + <&gcc GCC_PCIE_0_SLV_AXI_CLK>, + <&gcc GCC_PCIE_0_SLV_Q2A_AXI_CLK>, + <&gcc GCC_AGGRE_NOC_PCIE_TBU_CLK>; + clock-names = "pipe", + "aux", + "cfg", + "bus_master", + "bus_slave", + "slave_q2a", + "tbu"; + + iommu-map = <0x0 &apps_smmu 0x1d80 0x1>, + <0x100 &apps_smmu 0x1d81 0x1>; + + resets = <&gcc GCC_PCIE_0_BCR>; + reset-names = "pci"; + + power-domains = <&gcc PCIE_0_GDSC>; + + phys = <&pcie0_phy>; + phy-names = "pciephy"; + + perst-gpios = <&tlmm 35 GPIO_ACTIVE_HIGH>; + enable-gpio = <&tlmm 37 GPIO_ACTIVE_HIGH>; + + pinctrl-names = "default"; + pinctrl-0 = <&pcie0_default_state>; + + status = "disabled"; + }; + + pcie0_phy: phy@1c06000 { + compatible = "qcom,sm8150-qmp-gen3x1-pcie-phy"; + reg = <0 0x01c06000 0 0x1000>; + clocks = <&gcc GCC_PCIE_PHY_AUX_CLK>, + <&gcc GCC_PCIE_0_CFG_AHB_CLK>, + <&gcc GCC_PCIE_0_CLKREF_CLK>, + <&gcc GCC_PCIE0_PHY_REFGEN_CLK>, + <&gcc GCC_PCIE_0_PIPE_CLK>; + clock-names = "aux", + "cfg_ahb", + "ref", + "refgen", + "pipe"; + + clock-output-names = "pcie_0_pipe_clk"; + #clock-cells = <0>; + + #phy-cells = <0>; + + resets = <&gcc GCC_PCIE_0_PHY_BCR>; + reset-names = "phy"; + + assigned-clocks = <&gcc GCC_PCIE0_PHY_REFGEN_CLK>; + assigned-clock-rates = <100000000>; + + status = "disabled"; + }; + + pcie1: pcie@1c08000 { + compatible = "qcom,pcie-sm8150"; + reg = <0 0x01c08000 0 0x3000>, + <0 0x40000000 0 0xf1d>, + <0 0x40000f20 0 0xa8>, + <0 0x40001000 0 0x1000>, + <0 0x40100000 0 0x100000>; + reg-names = "parf", "dbi", "elbi", "atu", "config"; + device_type = "pci"; + linux,pci-domain = <1>; + bus-range = <0x00 0xff>; + num-lanes = <2>; + + #address-cells = <3>; + #size-cells = <2>; + + ranges = <0x01000000 0x0 0x00000000 0x0 0x40200000 0x0 0x100000>, + <0x02000000 0x0 0x40300000 0x0 0x40300000 0x0 0x1fd00000>; + + interrupts = <GIC_SPI 307 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &intc 0 434 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ + <0 0 0 2 &intc 0 435 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ + <0 0 0 3 &intc 0 438 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ + <0 0 0 4 &intc 0 439 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ + + clocks = <&gcc GCC_PCIE_1_PIPE_CLK>, + <&gcc GCC_PCIE_1_AUX_CLK>, + <&gcc GCC_PCIE_1_CFG_AHB_CLK>, + <&gcc GCC_PCIE_1_MSTR_AXI_CLK>, + <&gcc GCC_PCIE_1_SLV_AXI_CLK>, + <&gcc GCC_PCIE_1_SLV_Q2A_AXI_CLK>, + <&gcc GCC_AGGRE_NOC_PCIE_TBU_CLK>; + clock-names = "pipe", + "aux", + "cfg", + "bus_master", + "bus_slave", + "slave_q2a", + "tbu"; + + assigned-clocks = <&gcc GCC_PCIE_1_AUX_CLK>; + assigned-clock-rates = <19200000>; + + iommu-map = <0x0 &apps_smmu 0x1e00 0x1>, + <0x100 &apps_smmu 0x1e01 0x1>; + + resets = <&gcc GCC_PCIE_1_BCR>; + reset-names = "pci"; + + power-domains = <&gcc PCIE_1_GDSC>; + + phys = <&pcie1_phy>; + phy-names = "pciephy"; + + perst-gpios = <&tlmm 102 GPIO_ACTIVE_HIGH>; + enable-gpio = <&tlmm 104 GPIO_ACTIVE_HIGH>; + + pinctrl-names = "default"; + pinctrl-0 = <&pcie1_default_state>; + + status = "disabled"; + }; + + pcie1_phy: phy@1c0e000 { + compatible = "qcom,sm8150-qmp-gen3x2-pcie-phy"; + reg = <0 0x01c0e000 0 0x1000>; + clocks = <&gcc GCC_PCIE_PHY_AUX_CLK>, + <&gcc GCC_PCIE_1_CFG_AHB_CLK>, + <&gcc GCC_PCIE_1_CLKREF_CLK>, + <&gcc GCC_PCIE1_PHY_REFGEN_CLK>, + <&gcc GCC_PCIE_1_PIPE_CLK>; + clock-names = "aux", + "cfg_ahb", + "ref", + "refgen", + "pipe"; + + clock-output-names = "pcie_1_pipe_clk"; + #clock-cells = <0>; + + #phy-cells = <0>; + + resets = <&gcc GCC_PCIE_1_PHY_BCR>; + reset-names = "phy"; + + assigned-clocks = <&gcc GCC_PCIE1_PHY_REFGEN_CLK>; + assigned-clock-rates = <100000000>; + + status = "disabled"; + }; + + ufs_mem_hc: ufshc@1d84000 { + compatible = "qcom,sm8150-ufshc", "qcom,ufshc", + "jedec,ufs-2.0"; + reg = <0 0x01d84000 0 0x2500>, + <0 0x01d90000 0 0x8000>; + reg-names = "std", "ice"; + interrupts = <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>; + phys = <&ufs_mem_phy>; + phy-names = "ufsphy"; + lanes-per-direction = <2>; + #reset-cells = <1>; + resets = <&gcc GCC_UFS_PHY_BCR>; + reset-names = "rst"; + + iommus = <&apps_smmu 0x300 0>; + + clock-names = + "core_clk", + "bus_aggr_clk", + "iface_clk", + "core_clk_unipro", + "ref_clk", + "tx_lane0_sync_clk", + "rx_lane0_sync_clk", + "rx_lane1_sync_clk", + "ice_core_clk"; + clocks = + <&gcc GCC_UFS_PHY_AXI_CLK>, + <&gcc GCC_AGGRE_UFS_PHY_AXI_CLK>, + <&gcc GCC_UFS_PHY_AHB_CLK>, + <&gcc GCC_UFS_PHY_UNIPRO_CORE_CLK>, + <&rpmhcc RPMH_CXO_CLK>, + <&gcc GCC_UFS_PHY_TX_SYMBOL_0_CLK>, + <&gcc GCC_UFS_PHY_RX_SYMBOL_0_CLK>, + <&gcc GCC_UFS_PHY_RX_SYMBOL_1_CLK>, + <&gcc GCC_UFS_PHY_ICE_CORE_CLK>; + freq-table-hz = + <37500000 300000000>, + <0 0>, + <0 0>, + <37500000 300000000>, + <0 0>, + <0 0>, + <0 0>, + <0 0>, + <0 300000000>; + + status = "disabled"; + }; + + ufs_mem_phy: phy@1d87000 { + compatible = "qcom,sm8150-qmp-ufs-phy"; + reg = <0 0x01d87000 0 0x1000>; + + clock-names = "ref", + "ref_aux"; + clocks = <&gcc GCC_UFS_MEM_CLKREF_CLK>, + <&gcc GCC_UFS_PHY_PHY_AUX_CLK>; + + power-domains = <&gcc UFS_PHY_GDSC>; + + resets = <&ufs_mem_hc 0>; + reset-names = "ufsphy"; + + #phy-cells = <0>; + + status = "disabled"; + }; + + cryptobam: dma-controller@1dc4000 { + compatible = "qcom,bam-v1.7.4", "qcom,bam-v1.7.0"; + reg = <0 0x01dc4000 0 0x24000>; + interrupts = <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + qcom,ee = <0>; + qcom,controlled-remotely; + num-channels = <8>; + qcom,num-ees = <2>; + iommus = <&apps_smmu 0x502 0x0641>, + <&apps_smmu 0x504 0x0011>, + <&apps_smmu 0x506 0x0011>, + <&apps_smmu 0x508 0x0011>, + <&apps_smmu 0x512 0x0000>; + }; + + crypto: crypto@1dfa000 { + compatible = "qcom,sm8150-qce", "qcom,qce"; + reg = <0 0x01dfa000 0 0x6000>; + dmas = <&cryptobam 4>, <&cryptobam 5>; + dma-names = "rx", "tx"; + iommus = <&apps_smmu 0x502 0x0641>, + <&apps_smmu 0x504 0x0011>, + <&apps_smmu 0x506 0x0011>, + <&apps_smmu 0x508 0x0011>, + <&apps_smmu 0x512 0x0000>; + interconnects = <&aggre2_noc MASTER_CRYPTO_CORE_0 0 &mc_virt SLAVE_EBI_CH0 0>; + interconnect-names = "memory"; + }; + + tcsr_mutex: hwlock@1f40000 { + compatible = "qcom,tcsr-mutex"; + reg = <0x0 0x01f40000 0x0 0x20000>; + #hwlock-cells = <1>; + }; + + tcsr_regs_1: syscon@1f60000 { + compatible = "qcom,sm8150-tcsr", "syscon"; + reg = <0x0 0x01f60000 0x0 0x20000>; + }; + + remoteproc_slpi: remoteproc@2400000 { + compatible = "qcom,sm8150-slpi-pas"; + reg = <0x0 0x02400000 0x0 0x4040>; + + interrupts-extended = <&intc GIC_SPI 494 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "xo"; + + power-domains = <&rpmhpd SM8150_LCX>, + <&rpmhpd SM8150_LMX>; + power-domain-names = "lcx", "lmx"; + + memory-region = <&slpi_mem>; + + qcom,qmp = <&aoss_qmp>; + + qcom,smem-states = <&slpi_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 170 IRQ_TYPE_EDGE_RISING>; + label = "dsps"; + qcom,remote-pid = <3>; + mboxes = <&apss_shared 24>; + + fastrpc { + compatible = "qcom,fastrpc"; + qcom,glink-channels = "fastrpcglink-apps-dsp"; + label = "sdsp"; + qcom,non-secure-domain; + #address-cells = <1>; + #size-cells = <0>; + + compute-cb@1 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <1>; + iommus = <&apps_smmu 0x05a1 0x0>; + }; + + compute-cb@2 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <2>; + iommus = <&apps_smmu 0x05a2 0x0>; + }; + + compute-cb@3 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <3>; + iommus = <&apps_smmu 0x05a3 0x0>; + /* note: shared-cb = <4> in downstream */ + }; + }; + }; + }; + + gpu: gpu@2c00000 { + compatible = "qcom,adreno-640.1", "qcom,adreno"; + reg = <0 0x02c00000 0 0x40000>; + reg-names = "kgsl_3d0_reg_memory"; + + interrupts = <GIC_SPI 300 IRQ_TYPE_LEVEL_HIGH>; + + iommus = <&adreno_smmu 0 0x401>; + + operating-points-v2 = <&gpu_opp_table>; + + qcom,gmu = <&gmu>; + + nvmem-cells = <&gpu_speed_bin>; + nvmem-cell-names = "speed_bin"; + + status = "disabled"; + + zap-shader { + memory-region = <&gpu_mem>; + }; + + gpu_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-675000000 { + opp-hz = /bits/ 64 <675000000>; + opp-level = <RPMH_REGULATOR_LEVEL_NOM_L1>; + opp-supported-hw = <0x2>; + }; + + opp-585000000 { + opp-hz = /bits/ 64 <585000000>; + opp-level = <RPMH_REGULATOR_LEVEL_NOM>; + opp-supported-hw = <0x3>; + }; + + opp-499200000 { + opp-hz = /bits/ 64 <499200000>; + opp-level = <RPMH_REGULATOR_LEVEL_SVS_L2>; + opp-supported-hw = <0x3>; + }; + + opp-427000000 { + opp-hz = /bits/ 64 <427000000>; + opp-level = <RPMH_REGULATOR_LEVEL_SVS_L1>; + opp-supported-hw = <0x3>; + }; + + opp-345000000 { + opp-hz = /bits/ 64 <345000000>; + opp-level = <RPMH_REGULATOR_LEVEL_SVS>; + opp-supported-hw = <0x3>; + }; + + opp-257000000 { + opp-hz = /bits/ 64 <257000000>; + opp-level = <RPMH_REGULATOR_LEVEL_LOW_SVS>; + opp-supported-hw = <0x3>; + }; + }; + }; + + gmu: gmu@2c6a000 { + compatible = "qcom,adreno-gmu-640.1", "qcom,adreno-gmu"; + + reg = <0 0x02c6a000 0 0x30000>, + <0 0x0b290000 0 0x10000>, + <0 0x0b490000 0 0x10000>; + reg-names = "gmu", "gmu_pdc", "gmu_pdc_seq"; + + interrupts = <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hfi", "gmu"; + + clocks = <&gpucc GPU_CC_AHB_CLK>, + <&gpucc GPU_CC_CX_GMU_CLK>, + <&gpucc GPU_CC_CXO_CLK>, + <&gcc GCC_DDRSS_GPU_AXI_CLK>, + <&gcc GCC_GPU_MEMNOC_GFX_CLK>; + clock-names = "ahb", "gmu", "cxo", "axi", "memnoc"; + + power-domains = <&gpucc GPU_CX_GDSC>, + <&gpucc GPU_GX_GDSC>; + power-domain-names = "cx", "gx"; + + iommus = <&adreno_smmu 5 0x400>; + + operating-points-v2 = <&gmu_opp_table>; + + status = "disabled"; + + gmu_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-200000000 { + opp-hz = /bits/ 64 <200000000>; + opp-level = <RPMH_REGULATOR_LEVEL_MIN_SVS>; + }; + }; + }; + + gpucc: clock-controller@2c90000 { + compatible = "qcom,sm8150-gpucc"; + reg = <0 0x02c90000 0 0x9000>; + clocks = <&rpmhcc RPMH_CXO_CLK>, + <&gcc GCC_GPU_GPLL0_CLK_SRC>, + <&gcc GCC_GPU_GPLL0_DIV_CLK_SRC>; + clock-names = "bi_tcxo", + "gcc_gpu_gpll0_clk_src", + "gcc_gpu_gpll0_div_clk_src"; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + }; + + adreno_smmu: iommu@2ca0000 { + compatible = "qcom,sm8150-smmu-500", "qcom,adreno-smmu", + "qcom,smmu-500", "arm,mmu-500"; + reg = <0 0x02ca0000 0 0x10000>; + #iommu-cells = <2>; + #global-interrupts = <1>; + interrupts = <GIC_SPI 674 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 681 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 682 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 683 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 684 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 685 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 686 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 687 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 688 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gpucc GPU_CC_AHB_CLK>, + <&gcc GCC_GPU_MEMNOC_GFX_CLK>, + <&gcc GCC_GPU_SNOC_DVM_GFX_CLK>; + clock-names = "ahb", "bus", "iface"; + + power-domains = <&gpucc GPU_CX_GDSC>; + }; + + tlmm: pinctrl@3100000 { + compatible = "qcom,sm8150-pinctrl"; + reg = <0x0 0x03100000 0x0 0x300000>, + <0x0 0x03500000 0x0 0x300000>, + <0x0 0x03900000 0x0 0x300000>, + <0x0 0x03D00000 0x0 0x300000>; + reg-names = "west", "east", "north", "south"; + interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; + gpio-ranges = <&tlmm 0 0 176>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + wakeup-parent = <&pdc>; + + qup_i2c0_default: qup-i2c0-default-state { + pins = "gpio0", "gpio1"; + function = "qup0"; + drive-strength = <0x02>; + bias-disable; + }; + + qup_spi0_default: qup-spi0-default-state { + pins = "gpio0", "gpio1", "gpio2", "gpio3"; + function = "qup0"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c1_default: qup-i2c1-default-state { + pins = "gpio114", "gpio115"; + function = "qup1"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi1_default: qup-spi1-default-state { + pins = "gpio114", "gpio115", "gpio116", "gpio117"; + function = "qup1"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c2_default: qup-i2c2-default-state { + pins = "gpio126", "gpio127"; + function = "qup2"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi2_default: qup-spi2-default-state { + pins = "gpio126", "gpio127", "gpio128", "gpio129"; + function = "qup2"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c3_default: qup-i2c3-default-state { + pins = "gpio144", "gpio145"; + function = "qup3"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi3_default: qup-spi3-default-state { + pins = "gpio144", "gpio145", "gpio146", "gpio147"; + function = "qup3"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c4_default: qup-i2c4-default-state { + pins = "gpio51", "gpio52"; + function = "qup4"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi4_default: qup-spi4-default-state { + pins = "gpio51", "gpio52", "gpio53", "gpio54"; + function = "qup4"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c5_default: qup-i2c5-default-state { + pins = "gpio121", "gpio122"; + function = "qup5"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi5_default: qup-spi5-default-state { + pins = "gpio119", "gpio120", "gpio121", "gpio122"; + function = "qup5"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c6_default: qup-i2c6-default-state { + pins = "gpio6", "gpio7"; + function = "qup6"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi6_default: qup-spi6_default-state { + pins = "gpio4", "gpio5", "gpio6", "gpio7"; + function = "qup6"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c7_default: qup-i2c7-default-state { + pins = "gpio98", "gpio99"; + function = "qup7"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi7_default: qup-spi7_default-state { + pins = "gpio98", "gpio99", "gpio100", "gpio101"; + function = "qup7"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c8_default: qup-i2c8-default-state { + pins = "gpio88", "gpio89"; + function = "qup8"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi8_default: qup-spi8-default-state { + pins = "gpio88", "gpio89", "gpio90", "gpio91"; + function = "qup8"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c9_default: qup-i2c9-default-state { + pins = "gpio39", "gpio40"; + function = "qup9"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi9_default: qup-spi9-default-state { + pins = "gpio39", "gpio40", "gpio41", "gpio42"; + function = "qup9"; + drive-strength = <6>; + bias-disable; + }; + + qup_uart9_default: qup-uart9-default-state { + pins = "gpio41", "gpio42"; + function = "qup9"; + drive-strength = <2>; + bias-disable; + }; + + qup_i2c10_default: qup-i2c10-default-state { + pins = "gpio9", "gpio10"; + function = "qup10"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi10_default: qup-spi10-default-state { + pins = "gpio9", "gpio10", "gpio11", "gpio12"; + function = "qup10"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c11_default: qup-i2c11-default-state { + pins = "gpio94", "gpio95"; + function = "qup11"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi11_default: qup-spi11-default-state { + pins = "gpio92", "gpio93", "gpio94", "gpio95"; + function = "qup11"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c12_default: qup-i2c12-default-state { + pins = "gpio83", "gpio84"; + function = "qup12"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi12_default: qup-spi12-default-state { + pins = "gpio83", "gpio84", "gpio85", "gpio86"; + function = "qup12"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c13_default: qup-i2c13-default-state { + pins = "gpio43", "gpio44"; + function = "qup13"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi13_default: qup-spi13-default-state { + pins = "gpio43", "gpio44", "gpio45", "gpio46"; + function = "qup13"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c14_default: qup-i2c14-default-state { + pins = "gpio47", "gpio48"; + function = "qup14"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi14_default: qup-spi14-default-state { + pins = "gpio47", "gpio48", "gpio49", "gpio50"; + function = "qup14"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c15_default: qup-i2c15-default-state { + pins = "gpio27", "gpio28"; + function = "qup15"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi15_default: qup-spi15-default-state { + pins = "gpio27", "gpio28", "gpio29", "gpio30"; + function = "qup15"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c16_default: qup-i2c16-default-state { + pins = "gpio86", "gpio85"; + function = "qup16"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi16_default: qup-spi16-default-state { + pins = "gpio83", "gpio84", "gpio85", "gpio86"; + function = "qup16"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c17_default: qup-i2c17-default-state { + pins = "gpio55", "gpio56"; + function = "qup17"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi17_default: qup-spi17-default-state { + pins = "gpio55", "gpio56", "gpio57", "gpio58"; + function = "qup17"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c18_default: qup-i2c18-default-state { + pins = "gpio23", "gpio24"; + function = "qup18"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi18_default: qup-spi18-default-state { + pins = "gpio23", "gpio24", "gpio25", "gpio26"; + function = "qup18"; + drive-strength = <6>; + bias-disable; + }; + + qup_i2c19_default: qup-i2c19-default-state { + pins = "gpio57", "gpio58"; + function = "qup19"; + drive-strength = <2>; + bias-disable; + }; + + qup_spi19_default: qup-spi19-default-state { + pins = "gpio55", "gpio56", "gpio57", "gpio58"; + function = "qup19"; + drive-strength = <6>; + bias-disable; + }; + + pcie0_default_state: pcie0-default-state { + perst-pins { + pins = "gpio35"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + clkreq-pins { + pins = "gpio36"; + function = "pci_e0"; + drive-strength = <2>; + bias-pull-up; + }; + + wake-pins { + pins = "gpio37"; + function = "gpio"; + drive-strength = <2>; + bias-pull-up; + }; + }; + + pcie1_default_state: pcie1-default-state { + perst-pins { + pins = "gpio102"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + clkreq-pins { + pins = "gpio103"; + function = "pci_e1"; + drive-strength = <2>; + bias-pull-up; + }; + + wake-pins { + pins = "gpio104"; + function = "gpio"; + drive-strength = <2>; + bias-pull-up; + }; + }; + }; + + remoteproc_mpss: remoteproc@4080000 { + compatible = "qcom,sm8150-mpss-pas"; + reg = <0x0 0x04080000 0x0 0x4040>; + + interrupts-extended = <&intc GIC_SPI 266 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 3 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 7 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", "handover", + "stop-ack", "shutdown-ack"; + + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "xo"; + + power-domains = <&rpmhpd SM8150_CX>, + <&rpmhpd SM8150_MSS>; + power-domain-names = "cx", "mss"; + + memory-region = <&mpss_mem>; + + qcom,qmp = <&aoss_qmp>; + + qcom,smem-states = <&modem_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 449 IRQ_TYPE_EDGE_RISING>; + label = "modem"; + qcom,remote-pid = <1>; + mboxes = <&apss_shared 12>; + }; + }; + + stm@6002000 { + compatible = "arm,coresight-stm", "arm,primecell"; + reg = <0 0x06002000 0 0x1000>, + <0 0x16280000 0 0x180000>; + reg-names = "stm-base", "stm-stimulus-base"; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + stm_out: endpoint { + remote-endpoint = <&funnel0_in7>; + }; + }; + }; + }; + + funnel@6041000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x06041000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + funnel0_out: endpoint { + remote-endpoint = <&merge_funnel_in0>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@7 { + reg = <7>; + funnel0_in7: endpoint { + remote-endpoint = <&stm_out>; + }; + }; + }; + }; + + funnel@6042000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x06042000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + funnel1_out: endpoint { + remote-endpoint = <&merge_funnel_in1>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@4 { + reg = <4>; + funnel1_in4: endpoint { + remote-endpoint = <&swao_replicator_out>; + }; + }; + }; + }; + + funnel@6043000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x06043000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + funnel2_out: endpoint { + remote-endpoint = <&merge_funnel_in2>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@2 { + reg = <2>; + funnel2_in2: endpoint { + remote-endpoint = <&apss_merge_funnel_out>; + }; + }; + }; + }; + + funnel@6045000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x06045000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + merge_funnel_out: endpoint { + remote-endpoint = <&etf_in>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + merge_funnel_in0: endpoint { + remote-endpoint = <&funnel0_out>; + }; + }; + + port@1 { + reg = <1>; + merge_funnel_in1: endpoint { + remote-endpoint = <&funnel1_out>; + }; + }; + + port@2 { + reg = <2>; + merge_funnel_in2: endpoint { + remote-endpoint = <&funnel2_out>; + }; + }; + }; + }; + + replicator@6046000 { + compatible = "arm,coresight-dynamic-replicator", "arm,primecell"; + reg = <0 0x06046000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + replicator_out0: endpoint { + remote-endpoint = <&etr_in>; + }; + }; + + port@1 { + reg = <1>; + replicator_out1: endpoint { + remote-endpoint = <&replicator1_in>; + }; + }; + }; + + in-ports { + port { + replicator_in0: endpoint { + remote-endpoint = <&etf_out>; + }; + }; + }; + }; + + etf@6047000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0 0x06047000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + etf_out: endpoint { + remote-endpoint = <&replicator_in0>; + }; + }; + }; + + in-ports { + port { + etf_in: endpoint { + remote-endpoint = <&merge_funnel_out>; + }; + }; + }; + }; + + etr@6048000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0 0x06048000 0 0x1000>; + iommus = <&apps_smmu 0x05e0 0x0>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,scatter-gather; + + in-ports { + port { + etr_in: endpoint { + remote-endpoint = <&replicator_out0>; + }; + }; + }; + }; + + replicator@604a000 { + compatible = "arm,coresight-dynamic-replicator", "arm,primecell"; + reg = <0 0x0604a000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + reg = <1>; + replicator1_out: endpoint { + remote-endpoint = <&swao_funnel_in>; + }; + }; + }; + + in-ports { + + port { + replicator1_in: endpoint { + remote-endpoint = <&replicator_out1>; + }; + }; + }; + }; + + funnel@6b08000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x06b08000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + swao_funnel_out: endpoint { + remote-endpoint = <&swao_etf_in>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@6 { + reg = <6>; + swao_funnel_in: endpoint { + remote-endpoint = <&replicator1_out>; + }; + }; + }; + }; + + etf@6b09000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0 0x06b09000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + swao_etf_out: endpoint { + remote-endpoint = <&swao_replicator_in>; + }; + }; + }; + + in-ports { + port { + swao_etf_in: endpoint { + remote-endpoint = <&swao_funnel_out>; + }; + }; + }; + }; + + replicator@6b0a000 { + compatible = "arm,coresight-dynamic-replicator", "arm,primecell"; + reg = <0 0x06b0a000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + qcom,replicator-loses-context; + + out-ports { + port { + swao_replicator_out: endpoint { + remote-endpoint = <&funnel1_in4>; + }; + }; + }; + + in-ports { + port { + swao_replicator_in: endpoint { + remote-endpoint = <&swao_etf_out>; + }; + }; + }; + }; + + etm@7040000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07040000 0 0x1000>; + + cpu = <&CPU0>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + qcom,skip-power-up; + + out-ports { + port { + etm0_out: endpoint { + remote-endpoint = <&apss_funnel_in0>; + }; + }; + }; + }; + + etm@7140000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07140000 0 0x1000>; + + cpu = <&CPU1>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + qcom,skip-power-up; + + out-ports { + port { + etm1_out: endpoint { + remote-endpoint = <&apss_funnel_in1>; + }; + }; + }; + }; + + etm@7240000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07240000 0 0x1000>; + + cpu = <&CPU2>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + qcom,skip-power-up; + + out-ports { + port { + etm2_out: endpoint { + remote-endpoint = <&apss_funnel_in2>; + }; + }; + }; + }; + + etm@7340000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07340000 0 0x1000>; + + cpu = <&CPU3>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + qcom,skip-power-up; + + out-ports { + port { + etm3_out: endpoint { + remote-endpoint = <&apss_funnel_in3>; + }; + }; + }; + }; + + etm@7440000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07440000 0 0x1000>; + + cpu = <&CPU4>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + qcom,skip-power-up; + + out-ports { + port { + etm4_out: endpoint { + remote-endpoint = <&apss_funnel_in4>; + }; + }; + }; + }; + + etm@7540000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07540000 0 0x1000>; + + cpu = <&CPU5>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + qcom,skip-power-up; + + out-ports { + port { + etm5_out: endpoint { + remote-endpoint = <&apss_funnel_in5>; + }; + }; + }; + }; + + etm@7640000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07640000 0 0x1000>; + + cpu = <&CPU6>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + qcom,skip-power-up; + + out-ports { + port { + etm6_out: endpoint { + remote-endpoint = <&apss_funnel_in6>; + }; + }; + }; + }; + + etm@7740000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07740000 0 0x1000>; + + cpu = <&CPU7>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + qcom,skip-power-up; + + out-ports { + port { + etm7_out: endpoint { + remote-endpoint = <&apss_funnel_in7>; + }; + }; + }; + }; + + funnel@7800000 { /* APSS Funnel */ + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x07800000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + apss_funnel_out: endpoint { + remote-endpoint = <&apss_merge_funnel_in>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + apss_funnel_in0: endpoint { + remote-endpoint = <&etm0_out>; + }; + }; + + port@1 { + reg = <1>; + apss_funnel_in1: endpoint { + remote-endpoint = <&etm1_out>; + }; + }; + + port@2 { + reg = <2>; + apss_funnel_in2: endpoint { + remote-endpoint = <&etm2_out>; + }; + }; + + port@3 { + reg = <3>; + apss_funnel_in3: endpoint { + remote-endpoint = <&etm3_out>; + }; + }; + + port@4 { + reg = <4>; + apss_funnel_in4: endpoint { + remote-endpoint = <&etm4_out>; + }; + }; + + port@5 { + reg = <5>; + apss_funnel_in5: endpoint { + remote-endpoint = <&etm5_out>; + }; + }; + + port@6 { + reg = <6>; + apss_funnel_in6: endpoint { + remote-endpoint = <&etm6_out>; + }; + }; + + port@7 { + reg = <7>; + apss_funnel_in7: endpoint { + remote-endpoint = <&etm7_out>; + }; + }; + }; + }; + + funnel@7810000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x07810000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + apss_merge_funnel_out: endpoint { + remote-endpoint = <&funnel2_in2>; + }; + }; + }; + + in-ports { + port { + apss_merge_funnel_in: endpoint { + remote-endpoint = <&apss_funnel_out>; + }; + }; + }; + }; + + remoteproc_cdsp: remoteproc@8300000 { + compatible = "qcom,sm8150-cdsp-pas"; + reg = <0x0 0x08300000 0x0 0x4040>; + + interrupts-extended = <&intc GIC_SPI 578 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "xo"; + + power-domains = <&rpmhpd SM8150_CX>; + + memory-region = <&cdsp_mem>; + + qcom,qmp = <&aoss_qmp>; + + qcom,smem-states = <&cdsp_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 574 IRQ_TYPE_EDGE_RISING>; + label = "cdsp"; + qcom,remote-pid = <5>; + mboxes = <&apss_shared 4>; + + fastrpc { + compatible = "qcom,fastrpc"; + qcom,glink-channels = "fastrpcglink-apps-dsp"; + label = "cdsp"; + qcom,non-secure-domain; + #address-cells = <1>; + #size-cells = <0>; + + compute-cb@1 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <1>; + iommus = <&apps_smmu 0x1001 0x0460>; + }; + + compute-cb@2 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <2>; + iommus = <&apps_smmu 0x1002 0x0460>; + }; + + compute-cb@3 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <3>; + iommus = <&apps_smmu 0x1003 0x0460>; + }; + + compute-cb@4 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <4>; + iommus = <&apps_smmu 0x1004 0x0460>; + }; + + compute-cb@5 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <5>; + iommus = <&apps_smmu 0x1005 0x0460>; + }; + + compute-cb@6 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <6>; + iommus = <&apps_smmu 0x1006 0x0460>; + }; + + compute-cb@7 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <7>; + iommus = <&apps_smmu 0x1007 0x0460>; + }; + + compute-cb@8 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <8>; + iommus = <&apps_smmu 0x1008 0x0460>; + }; + + /* note: secure cb9 in downstream */ + }; + }; + }; + + usb_1_hsphy: phy@88e2000 { + compatible = "qcom,sm8150-usb-hs-phy", + "qcom,usb-snps-hs-7nm-phy"; + reg = <0 0x088e2000 0 0x400>; + status = "disabled"; + #phy-cells = <0>; + + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "ref"; + + resets = <&gcc GCC_QUSB2PHY_PRIM_BCR>; + }; + + usb_2_hsphy: phy@88e3000 { + compatible = "qcom,sm8150-usb-hs-phy", + "qcom,usb-snps-hs-7nm-phy"; + reg = <0 0x088e3000 0 0x400>; + status = "disabled"; + #phy-cells = <0>; + + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "ref"; + + resets = <&gcc GCC_QUSB2PHY_SEC_BCR>; + }; + + usb_1_qmpphy: phy@88e8000 { + compatible = "qcom,sm8150-qmp-usb3-dp-phy"; + reg = <0 0x088e8000 0 0x3000>; + + clocks = <&gcc GCC_USB3_PRIM_PHY_AUX_CLK>, + <&gcc GCC_USB3_PRIM_CLKREF_CLK>, + <&gcc GCC_USB3_PRIM_PHY_COM_AUX_CLK>, + <&gcc GCC_USB3_PRIM_PHY_PIPE_CLK>; + clock-names = "aux", + "ref", + "com_aux", + "usb3_pipe"; + + resets = <&gcc GCC_USB3_DP_PHY_PRIM_BCR>, + <&gcc GCC_USB3_PHY_PRIM_BCR>; + reset-names = "phy", "common"; + + #clock-cells = <1>; + #phy-cells = <1>; + + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + usb_1_qmpphy_out: endpoint { + }; + }; + + port@1 { + reg = <1>; + + usb_1_qmpphy_usb_ss_in: endpoint { + }; + }; + + port@2 { + reg = <2>; + + usb_1_qmpphy_dp_in: endpoint { + }; + }; + }; + }; + + usb_2_qmpphy: phy@88eb000 { + compatible = "qcom,sm8150-qmp-usb3-uni-phy"; + reg = <0 0x088eb000 0 0x1000>; + + clocks = <&gcc GCC_USB3_SEC_PHY_AUX_CLK>, + <&gcc GCC_USB3_SEC_CLKREF_CLK>, + <&gcc GCC_USB3_SEC_PHY_COM_AUX_CLK>, + <&gcc GCC_USB3_SEC_PHY_PIPE_CLK>; + clock-names = "aux", + "ref", + "com_aux", + "pipe"; + clock-output-names = "usb3_uni_phy_pipe_clk_src"; + #clock-cells = <0>; + #phy-cells = <0>; + + resets = <&gcc GCC_USB3_PHY_SEC_BCR>, + <&gcc GCC_USB3PHY_PHY_SEC_BCR>; + reset-names = "phy", + "phy_phy"; + + status = "disabled"; + }; + + sdhc_2: mmc@8804000 { + compatible = "qcom,sm8150-sdhci", "qcom,sdhci-msm-v5"; + reg = <0 0x08804000 0 0x1000>; + + interrupts = <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hc_irq", "pwr_irq"; + + clocks = <&gcc GCC_SDCC2_AHB_CLK>, + <&gcc GCC_SDCC2_APPS_CLK>, + <&rpmhcc RPMH_CXO_CLK>; + clock-names = "iface", "core", "xo"; + iommus = <&apps_smmu 0x6a0 0x0>; + qcom,dll-config = <0x0007642c>; + qcom,ddr-config = <0x80040868>; + power-domains = <&rpmhpd 0>; + operating-points-v2 = <&sdhc2_opp_table>; + + status = "disabled"; + + sdhc2_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-19200000 { + opp-hz = /bits/ 64 <19200000>; + required-opps = <&rpmhpd_opp_min_svs>; + }; + + opp-50000000 { + opp-hz = /bits/ 64 <50000000>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-202000000 { + opp-hz = /bits/ 64 <202000000>; + required-opps = <&rpmhpd_opp_svs_l1>; + }; + }; + }; + + dc_noc: interconnect@9160000 { + compatible = "qcom,sm8150-dc-noc"; + reg = <0 0x09160000 0 0x3200>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + gem_noc: interconnect@9680000 { + compatible = "qcom,sm8150-gem-noc"; + reg = <0 0x09680000 0 0x3e200>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + usb_1: usb@a6f8800 { + compatible = "qcom,sm8150-dwc3", "qcom,dwc3"; + reg = <0 0x0a6f8800 0 0x400>; + status = "disabled"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + dma-ranges; + + clocks = <&gcc GCC_CFG_NOC_USB3_PRIM_AXI_CLK>, + <&gcc GCC_USB30_PRIM_MASTER_CLK>, + <&gcc GCC_AGGRE_USB3_PRIM_AXI_CLK>, + <&gcc GCC_USB30_PRIM_SLEEP_CLK>, + <&gcc GCC_USB30_PRIM_MOCK_UTMI_CLK>, + <&gcc GCC_USB3_SEC_CLKREF_CLK>; + clock-names = "cfg_noc", + "core", + "iface", + "sleep", + "mock_utmi", + "xo"; + + assigned-clocks = <&gcc GCC_USB30_PRIM_MOCK_UTMI_CLK>, + <&gcc GCC_USB30_PRIM_MASTER_CLK>; + assigned-clock-rates = <19200000>, <200000000>; + + interrupts-extended = <&intc GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, + <&pdc 6 IRQ_TYPE_LEVEL_HIGH>, + <&pdc 8 IRQ_TYPE_EDGE_BOTH>, + <&pdc 9 IRQ_TYPE_EDGE_BOTH>; + interrupt-names = "hs_phy_irq", "ss_phy_irq", + "dm_hs_phy_irq", "dp_hs_phy_irq"; + + power-domains = <&gcc USB30_PRIM_GDSC>; + + resets = <&gcc GCC_USB30_PRIM_BCR>; + + interconnects = <&aggre1_noc MASTER_USB3 0 &mc_virt SLAVE_EBI_CH0 0>, + <&gem_noc MASTER_AMPSS_M0 0 &config_noc SLAVE_USB3 0>; + interconnect-names = "usb-ddr", "apps-usb"; + + usb_1_dwc3: usb@a600000 { + compatible = "snps,dwc3"; + reg = <0 0x0a600000 0 0xcd00>; + interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; + iommus = <&apps_smmu 0x140 0>; + snps,dis_u2_susphy_quirk; + snps,dis_enblslpm_quirk; + phys = <&usb_1_hsphy>, <&usb_1_qmpphy QMP_USB43DP_USB3_PHY>; + phy-names = "usb2-phy", "usb3-phy"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + usb_1_dwc3_hs: endpoint { + }; + }; + + port@1 { + reg = <1>; + + usb_1_dwc3_ss: endpoint { + }; + }; + }; + }; + }; + + usb_2: usb@a8f8800 { + compatible = "qcom,sm8150-dwc3", "qcom,dwc3"; + reg = <0 0x0a8f8800 0 0x400>; + status = "disabled"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + dma-ranges; + + clocks = <&gcc GCC_CFG_NOC_USB3_SEC_AXI_CLK>, + <&gcc GCC_USB30_SEC_MASTER_CLK>, + <&gcc GCC_AGGRE_USB3_SEC_AXI_CLK>, + <&gcc GCC_USB30_SEC_SLEEP_CLK>, + <&gcc GCC_USB30_SEC_MOCK_UTMI_CLK>, + <&gcc GCC_USB3_SEC_CLKREF_CLK>; + clock-names = "cfg_noc", + "core", + "iface", + "sleep", + "mock_utmi", + "xo"; + + assigned-clocks = <&gcc GCC_USB30_SEC_MOCK_UTMI_CLK>, + <&gcc GCC_USB30_SEC_MASTER_CLK>; + assigned-clock-rates = <19200000>, <200000000>; + + interrupts-extended = <&intc GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, + <&pdc 7 IRQ_TYPE_LEVEL_HIGH>, + <&pdc 10 IRQ_TYPE_EDGE_BOTH>, + <&pdc 11 IRQ_TYPE_EDGE_BOTH>; + interrupt-names = "hs_phy_irq", "ss_phy_irq", + "dm_hs_phy_irq", "dp_hs_phy_irq"; + + power-domains = <&gcc USB30_SEC_GDSC>; + + resets = <&gcc GCC_USB30_SEC_BCR>; + + interconnects = <&aggre1_noc MASTER_USB3_1 0 &mc_virt SLAVE_EBI_CH0 0>, + <&gem_noc MASTER_AMPSS_M0 0 &config_noc SLAVE_USB3_1 0>; + interconnect-names = "usb-ddr", "apps-usb"; + + usb_2_dwc3: usb@a800000 { + compatible = "snps,dwc3"; + reg = <0 0x0a800000 0 0xcd00>; + interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; + iommus = <&apps_smmu 0x160 0>; + snps,dis_u2_susphy_quirk; + snps,dis_enblslpm_quirk; + phys = <&usb_2_hsphy>, <&usb_2_qmpphy>; + phy-names = "usb2-phy", "usb3-phy"; + }; + }; + + camnoc_virt: interconnect@ac00000 { + compatible = "qcom,sm8150-camnoc-virt"; + reg = <0 0x0ac00000 0 0x1000>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + mdss: display-subsystem@ae00000 { + compatible = "qcom,sm8150-mdss"; + reg = <0 0x0ae00000 0 0x1000>; + reg-names = "mdss"; + + interconnects = <&mmss_noc MASTER_MDP_PORT0 0 &mc_virt SLAVE_EBI_CH0 0>, + <&mmss_noc MASTER_MDP_PORT1 0 &mc_virt SLAVE_EBI_CH0 0>; + interconnect-names = "mdp0-mem", "mdp1-mem"; + + power-domains = <&dispcc MDSS_GDSC>; + + clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&gcc GCC_DISP_HF_AXI_CLK>, + <&gcc GCC_DISP_SF_AXI_CLK>, + <&dispcc DISP_CC_MDSS_MDP_CLK>; + clock-names = "iface", "bus", "nrt_bus", "core"; + + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <1>; + + iommus = <&apps_smmu 0x800 0x420>; + + status = "disabled"; + + #address-cells = <2>; + #size-cells = <2>; + ranges; + + mdss_mdp: display-controller@ae01000 { + compatible = "qcom,sm8150-dpu"; + reg = <0 0x0ae01000 0 0x8f000>, + <0 0x0aeb0000 0 0x2008>; + reg-names = "mdp", "vbif"; + + clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&gcc GCC_DISP_HF_AXI_CLK>, + <&dispcc DISP_CC_MDSS_MDP_CLK>, + <&dispcc DISP_CC_MDSS_VSYNC_CLK>; + clock-names = "iface", "bus", "core", "vsync"; + + assigned-clocks = <&dispcc DISP_CC_MDSS_VSYNC_CLK>; + assigned-clock-rates = <19200000>; + + operating-points-v2 = <&mdp_opp_table>; + power-domains = <&rpmhpd SM8150_MMCX>; + + interrupt-parent = <&mdss>; + interrupts = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + dpu_intf1_out: endpoint { + remote-endpoint = <&mdss_dsi0_in>; + }; + }; + + port@1 { + reg = <1>; + dpu_intf2_out: endpoint { + remote-endpoint = <&mdss_dsi1_in>; + }; + }; + + port@2 { + reg = <2>; + dpu_intf0_out: endpoint { + remote-endpoint = <&mdss_dp_in>; + }; + }; + }; + + mdp_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-171428571 { + opp-hz = /bits/ 64 <171428571>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-300000000 { + opp-hz = /bits/ 64 <300000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-345000000 { + opp-hz = /bits/ 64 <345000000>; + required-opps = <&rpmhpd_opp_svs_l1>; + }; + + opp-460000000 { + opp-hz = /bits/ 64 <460000000>; + required-opps = <&rpmhpd_opp_nom>; + }; + }; + }; + + mdss_dp: displayport-controller@ae90000 { + compatible = "qcom,sm8150-dp", "qcom,sm8350-dp"; + reg = <0 0xae90000 0 0x200>, + <0 0xae90200 0 0x200>, + <0 0xae90400 0 0x600>, + <0 0x0ae90a00 0 0x600>, + <0 0x0ae91000 0 0x600>; + + interrupt-parent = <&mdss>; + interrupts = <12>; + clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&dispcc DISP_CC_MDSS_DP_AUX_CLK>, + <&dispcc DISP_CC_MDSS_DP_LINK_CLK>, + <&dispcc DISP_CC_MDSS_DP_LINK_INTF_CLK>, + <&dispcc DISP_CC_MDSS_DP_PIXEL_CLK>; + clock-names = "core_iface", + "core_aux", + "ctrl_link", + "ctrl_link_iface", + "stream_pixel"; + + assigned-clocks = <&dispcc DISP_CC_MDSS_DP_LINK_CLK_SRC>, + <&dispcc DISP_CC_MDSS_DP_PIXEL_CLK_SRC>; + assigned-clock-parents = <&usb_1_qmpphy QMP_USB43DP_DP_LINK_CLK>, + <&usb_1_qmpphy QMP_USB43DP_DP_VCO_DIV_CLK>; + + phys = <&usb_1_qmpphy QMP_USB43DP_DP_PHY>; + phy-names = "dp"; + + #sound-dai-cells = <0>; + + operating-points-v2 = <&dp_opp_table>; + power-domains = <&rpmhpd SM8250_MMCX>; + + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_dp_in: endpoint { + remote-endpoint = <&dpu_intf0_out>; + }; + }; + + port@1 { + reg = <1>; + + mdss_dp_out: endpoint { + }; + }; + }; + + dp_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-160000000 { + opp-hz = /bits/ 64 <160000000>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-270000000 { + opp-hz = /bits/ 64 <270000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-540000000 { + opp-hz = /bits/ 64 <540000000>; + required-opps = <&rpmhpd_opp_svs_l1>; + }; + + opp-810000000 { + opp-hz = /bits/ 64 <810000000>; + required-opps = <&rpmhpd_opp_nom>; + }; + }; + }; + + mdss_dsi0: dsi@ae94000 { + compatible = "qcom,sm8150-dsi-ctrl", "qcom,mdss-dsi-ctrl"; + reg = <0 0x0ae94000 0 0x400>; + reg-names = "dsi_ctrl"; + + interrupt-parent = <&mdss>; + interrupts = <4>; + + clocks = <&dispcc DISP_CC_MDSS_BYTE0_CLK>, + <&dispcc DISP_CC_MDSS_BYTE0_INTF_CLK>, + <&dispcc DISP_CC_MDSS_PCLK0_CLK>, + <&dispcc DISP_CC_MDSS_ESC0_CLK>, + <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&gcc GCC_DISP_HF_AXI_CLK>; + clock-names = "byte", + "byte_intf", + "pixel", + "core", + "iface", + "bus"; + + assigned-clocks = <&dispcc DISP_CC_MDSS_BYTE0_CLK_SRC>, + <&dispcc DISP_CC_MDSS_PCLK0_CLK_SRC>; + assigned-clock-parents = <&mdss_dsi0_phy 0>, + <&mdss_dsi0_phy 1>; + + operating-points-v2 = <&dsi_opp_table>; + power-domains = <&rpmhpd SM8150_MMCX>; + + phys = <&mdss_dsi0_phy>; + + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_dsi0_in: endpoint { + remote-endpoint = <&dpu_intf1_out>; + }; + }; + + port@1 { + reg = <1>; + mdss_dsi0_out: endpoint { + }; + }; + }; + + dsi_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-187500000 { + opp-hz = /bits/ 64 <187500000>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-300000000 { + opp-hz = /bits/ 64 <300000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-358000000 { + opp-hz = /bits/ 64 <358000000>; + required-opps = <&rpmhpd_opp_svs_l1>; + }; + }; + }; + + mdss_dsi0_phy: phy@ae94400 { + compatible = "qcom,dsi-phy-7nm-8150"; + reg = <0 0x0ae94400 0 0x200>, + <0 0x0ae94600 0 0x280>, + <0 0x0ae94900 0 0x260>; + reg-names = "dsi_phy", + "dsi_phy_lane", + "dsi_pll"; + + #clock-cells = <1>; + #phy-cells = <0>; + + clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&rpmhcc RPMH_CXO_CLK>; + clock-names = "iface", "ref"; + + status = "disabled"; + }; + + mdss_dsi1: dsi@ae96000 { + compatible = "qcom,sm8150-dsi-ctrl", "qcom,mdss-dsi-ctrl"; + reg = <0 0x0ae96000 0 0x400>; + reg-names = "dsi_ctrl"; + + interrupt-parent = <&mdss>; + interrupts = <5>; + + clocks = <&dispcc DISP_CC_MDSS_BYTE1_CLK>, + <&dispcc DISP_CC_MDSS_BYTE1_INTF_CLK>, + <&dispcc DISP_CC_MDSS_PCLK1_CLK>, + <&dispcc DISP_CC_MDSS_ESC1_CLK>, + <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&gcc GCC_DISP_HF_AXI_CLK>; + clock-names = "byte", + "byte_intf", + "pixel", + "core", + "iface", + "bus"; + + assigned-clocks = <&dispcc DISP_CC_MDSS_BYTE1_CLK_SRC>, + <&dispcc DISP_CC_MDSS_PCLK1_CLK_SRC>; + assigned-clock-parents = <&mdss_dsi1_phy 0>, + <&mdss_dsi1_phy 1>; + + operating-points-v2 = <&dsi_opp_table>; + power-domains = <&rpmhpd SM8150_MMCX>; + + phys = <&mdss_dsi1_phy>; + + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_dsi1_in: endpoint { + remote-endpoint = <&dpu_intf2_out>; + }; + }; + + port@1 { + reg = <1>; + mdss_dsi1_out: endpoint { + }; + }; + }; + }; + + mdss_dsi1_phy: phy@ae96400 { + compatible = "qcom,dsi-phy-7nm-8150"; + reg = <0 0x0ae96400 0 0x200>, + <0 0x0ae96600 0 0x280>, + <0 0x0ae96900 0 0x260>; + reg-names = "dsi_phy", + "dsi_phy_lane", + "dsi_pll"; + + #clock-cells = <1>; + #phy-cells = <0>; + + clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&rpmhcc RPMH_CXO_CLK>; + clock-names = "iface", "ref"; + + status = "disabled"; + }; + }; + + dispcc: clock-controller@af00000 { + compatible = "qcom,sm8150-dispcc"; + reg = <0 0x0af00000 0 0x10000>; + clocks = <&rpmhcc RPMH_CXO_CLK>, + <&mdss_dsi0_phy 0>, + <&mdss_dsi0_phy 1>, + <&mdss_dsi1_phy 0>, + <&mdss_dsi1_phy 1>, + <&usb_1_qmpphy QMP_USB43DP_DP_LINK_CLK>, + <&usb_1_qmpphy QMP_USB43DP_DP_VCO_DIV_CLK>; + clock-names = "bi_tcxo", + "dsi0_phy_pll_out_byteclk", + "dsi0_phy_pll_out_dsiclk", + "dsi1_phy_pll_out_byteclk", + "dsi1_phy_pll_out_dsiclk", + "dp_phy_pll_link_clk", + "dp_phy_pll_vco_div_clk"; + power-domains = <&rpmhpd SM8150_MMCX>; + required-opps = <&rpmhpd_opp_low_svs>; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + }; + + pdc: interrupt-controller@b220000 { + compatible = "qcom,sm8150-pdc", "qcom,pdc"; + reg = <0 0x0b220000 0 0x30000>; + qcom,pdc-ranges = <0 480 94>, <94 609 31>, + <125 63 1>; + #interrupt-cells = <2>; + interrupt-parent = <&intc>; + interrupt-controller; + }; + + aoss_qmp: power-management@c300000 { + compatible = "qcom,sm8150-aoss-qmp", "qcom,aoss-qmp"; + reg = <0x0 0x0c300000 0x0 0x400>; + interrupts = <GIC_SPI 389 IRQ_TYPE_EDGE_RISING>; + mboxes = <&apss_shared 0>; + + #clock-cells = <0>; + }; + + sram@c3f0000 { + compatible = "qcom,rpmh-stats"; + reg = <0 0x0c3f0000 0 0x400>; + }; + + tsens0: thermal-sensor@c263000 { + compatible = "qcom,sm8150-tsens", "qcom,tsens-v2"; + reg = <0 0x0c263000 0 0x1ff>, /* TM */ + <0 0x0c222000 0 0x1ff>; /* SROT */ + #qcom,sensors = <16>; + interrupts = <GIC_SPI 506 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 508 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "uplow", "critical"; + #thermal-sensor-cells = <1>; + }; + + tsens1: thermal-sensor@c265000 { + compatible = "qcom,sm8150-tsens", "qcom,tsens-v2"; + reg = <0 0x0c265000 0 0x1ff>, /* TM */ + <0 0x0c223000 0 0x1ff>; /* SROT */ + #qcom,sensors = <8>; + interrupts = <GIC_SPI 507 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 509 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "uplow", "critical"; + #thermal-sensor-cells = <1>; + }; + + spmi_bus: spmi@c440000 { + compatible = "qcom,spmi-pmic-arb"; + reg = <0x0 0x0c440000 0x0 0x0001100>, + <0x0 0x0c600000 0x0 0x2000000>, + <0x0 0x0e600000 0x0 0x0100000>, + <0x0 0x0e700000 0x0 0x00a0000>, + <0x0 0x0c40a000 0x0 0x0026000>; + reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; + interrupt-names = "periph_irq"; + interrupts = <GIC_SPI 481 IRQ_TYPE_LEVEL_HIGH>; + qcom,ee = <0>; + qcom,channel = <0>; + #address-cells = <2>; + #size-cells = <0>; + interrupt-controller; + #interrupt-cells = <4>; + }; + + apps_smmu: iommu@15000000 { + compatible = "qcom,sm8150-smmu-500", "qcom,smmu-500", "arm,mmu-500"; + reg = <0 0x15000000 0 0x100000>; + #iommu-cells = <2>; + #global-interrupts = <1>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 395 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 396 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 409 IRQ_TYPE_LEVEL_HIGH>; + }; + + remoteproc_adsp: remoteproc@17300000 { + compatible = "qcom,sm8150-adsp-pas"; + reg = <0x0 0x17300000 0x0 0x4040>; + + interrupts-extended = <&intc GIC_SPI 162 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "xo"; + + power-domains = <&rpmhpd SM8150_CX>; + + memory-region = <&adsp_mem>; + + qcom,qmp = <&aoss_qmp>; + + qcom,smem-states = <&adsp_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 156 IRQ_TYPE_EDGE_RISING>; + label = "lpass"; + qcom,remote-pid = <2>; + mboxes = <&apss_shared 8>; + + fastrpc { + compatible = "qcom,fastrpc"; + qcom,glink-channels = "fastrpcglink-apps-dsp"; + label = "adsp"; + qcom,non-secure-domain; + #address-cells = <1>; + #size-cells = <0>; + + compute-cb@3 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <3>; + iommus = <&apps_smmu 0x1b23 0x0>; + }; + + compute-cb@4 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <4>; + iommus = <&apps_smmu 0x1b24 0x0>; + }; + + compute-cb@5 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <5>; + iommus = <&apps_smmu 0x1b25 0x0>; + }; + }; + }; + }; + + intc: interrupt-controller@17a00000 { + compatible = "arm,gic-v3"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0x0 0x17a00000 0x0 0x10000>, /* GICD */ + <0x0 0x17a60000 0x0 0x100000>; /* GICR * 8 */ + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + }; + + apss_shared: mailbox@17c00000 { + compatible = "qcom,sm8150-apss-shared", + "qcom,sdm845-apss-shared"; + reg = <0x0 0x17c00000 0x0 0x1000>; + #mbox-cells = <1>; + }; + + watchdog@17c10000 { + compatible = "qcom,apss-wdt-sm8150", "qcom,kpss-wdt"; + reg = <0 0x17c10000 0 0x1000>; + clocks = <&sleep_clk>; + interrupts = <GIC_SPI 0 IRQ_TYPE_EDGE_RISING>; + }; + + timer@17c20000 { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0 0x20000000>; + compatible = "arm,armv7-timer-mem"; + reg = <0x0 0x17c20000 0x0 0x1000>; + clock-frequency = <19200000>; + + frame@17c21000 { + frame-number = <0>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17c21000 0x1000>, + <0x17c22000 0x1000>; + }; + + frame@17c23000 { + frame-number = <1>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17c23000 0x1000>; + status = "disabled"; + }; + + frame@17c25000 { + frame-number = <2>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17c25000 0x1000>; + status = "disabled"; + }; + + frame@17c27000 { + frame-number = <3>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17c26000 0x1000>; + status = "disabled"; + }; + + frame@17c29000 { + frame-number = <4>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17c29000 0x1000>; + status = "disabled"; + }; + + frame@17c2b000 { + frame-number = <5>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17c2b000 0x1000>; + status = "disabled"; + }; + + frame@17c2d000 { + frame-number = <6>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17c2d000 0x1000>; + status = "disabled"; + }; + }; + + apps_rsc: rsc@18200000 { + label = "apps_rsc"; + compatible = "qcom,rpmh-rsc"; + reg = <0x0 0x18200000 0x0 0x10000>, + <0x0 0x18210000 0x0 0x10000>, + <0x0 0x18220000 0x0 0x10000>; + reg-names = "drv-0", "drv-1", "drv-2"; + interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + qcom,tcs-offset = <0xd00>; + qcom,drv-id = <2>; + qcom,tcs-config = <ACTIVE_TCS 2>, + <SLEEP_TCS 3>, + <WAKE_TCS 3>, + <CONTROL_TCS 1>; + power-domains = <&CLUSTER_PD>; + + rpmhcc: clock-controller { + compatible = "qcom,sm8150-rpmh-clk"; + #clock-cells = <1>; + clock-names = "xo"; + clocks = <&xo_board>; + }; + + rpmhpd: power-controller { + compatible = "qcom,sm8150-rpmhpd"; + #power-domain-cells = <1>; + operating-points-v2 = <&rpmhpd_opp_table>; + + rpmhpd_opp_table: opp-table { + compatible = "operating-points-v2"; + + rpmhpd_opp_ret: opp1 { + opp-level = <RPMH_REGULATOR_LEVEL_RETENTION>; + }; + + rpmhpd_opp_min_svs: opp2 { + opp-level = <RPMH_REGULATOR_LEVEL_MIN_SVS>; + }; + + rpmhpd_opp_low_svs: opp3 { + opp-level = <RPMH_REGULATOR_LEVEL_LOW_SVS>; + }; + + rpmhpd_opp_svs: opp4 { + opp-level = <RPMH_REGULATOR_LEVEL_SVS>; + }; + + rpmhpd_opp_svs_l1: opp5 { + opp-level = <RPMH_REGULATOR_LEVEL_SVS_L1>; + }; + + rpmhpd_opp_svs_l2: opp6 { + opp-level = <224>; + }; + + rpmhpd_opp_nom: opp7 { + opp-level = <RPMH_REGULATOR_LEVEL_NOM>; + }; + + rpmhpd_opp_nom_l1: opp8 { + opp-level = <RPMH_REGULATOR_LEVEL_NOM_L1>; + }; + + rpmhpd_opp_nom_l2: opp9 { + opp-level = <RPMH_REGULATOR_LEVEL_NOM_L2>; + }; + + rpmhpd_opp_turbo: opp10 { + opp-level = <RPMH_REGULATOR_LEVEL_TURBO>; + }; + + rpmhpd_opp_turbo_l1: opp11 { + opp-level = <RPMH_REGULATOR_LEVEL_TURBO_L1>; + }; + }; + }; + + apps_bcm_voter: bcm-voter { + compatible = "qcom,bcm-voter"; + }; + }; + + osm_l3: interconnect@18321000 { + compatible = "qcom,sm8150-osm-l3", "qcom,osm-l3"; + reg = <0 0x18321000 0 0x1400>; + + clocks = <&rpmhcc RPMH_CXO_CLK>, <&gcc GPLL0>; + clock-names = "xo", "alternate"; + + #interconnect-cells = <1>; + }; + + cpufreq_hw: cpufreq@18323000 { + compatible = "qcom,sm8150-cpufreq-hw", "qcom,cpufreq-hw"; + reg = <0 0x18323000 0 0x1400>, <0 0x18325800 0 0x1400>, + <0 0x18327800 0 0x1400>; + reg-names = "freq-domain0", "freq-domain1", + "freq-domain2"; + + clocks = <&rpmhcc RPMH_CXO_CLK>, <&gcc GPLL0>; + clock-names = "xo", "alternate"; + + #freq-domain-cells = <1>; + #clock-cells = <1>; + }; + + lmh_cluster1: lmh@18350800 { + compatible = "qcom,sm8150-lmh"; + reg = <0 0x18350800 0 0x400>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + cpus = <&CPU4>; + qcom,lmh-temp-arm-millicelsius = <60000>; + qcom,lmh-temp-low-millicelsius = <84500>; + qcom,lmh-temp-high-millicelsius = <85000>; + interrupt-controller; + #interrupt-cells = <1>; + }; + + lmh_cluster0: lmh@18358800 { + compatible = "qcom,sm8150-lmh"; + reg = <0 0x18358800 0 0x400>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + cpus = <&CPU0>; + qcom,lmh-temp-arm-millicelsius = <60000>; + qcom,lmh-temp-low-millicelsius = <84500>; + qcom,lmh-temp-high-millicelsius = <85000>; + interrupt-controller; + #interrupt-cells = <1>; + }; + + wifi: wifi@18800000 { + compatible = "qcom,wcn3990-wifi"; + reg = <0 0x18800000 0 0x800000>; + reg-names = "membase"; + memory-region = <&wlan_mem>; + clock-names = "cxo_ref_clk_pin", "qdss"; + clocks = <&rpmhcc RPMH_RF_CLK2>, <&aoss_qmp>; + interrupts = <GIC_SPI 414 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 415 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>; + iommus = <&apps_smmu 0x0640 0x1>; + status = "disabled"; + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 1 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 2 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 3 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 0 IRQ_TYPE_LEVEL_LOW>; + }; + + thermal-zones { + cpu0-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 1>; + + trips { + cpu0_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu0_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu0_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu0_alert0>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu0_alert1>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu1-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 2>; + + trips { + cpu1_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu1_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu1_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu1_alert0>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu1_alert1>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu2-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 3>; + + trips { + cpu2_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu2_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu2_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu2_alert0>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu2_alert1>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu3-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 4>; + + trips { + cpu3_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu3_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu3_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu3_alert0>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu3_alert1>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu4-top-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 7>; + + trips { + cpu4_top_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu4_top_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu4_top_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu4_top_alert0>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu4_top_alert1>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu5-top-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 8>; + + trips { + cpu5_top_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu5_top_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu5_top_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu5_top_alert0>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu5_top_alert1>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu6-top-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 9>; + + trips { + cpu6_top_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu6_top_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu6_top_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu6_top_alert0>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu6_top_alert1>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu7-top-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 10>; + + trips { + cpu7_top_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu7_top_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu7_top_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu7_top_alert0>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu7_top_alert1>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu4-bottom-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 11>; + + trips { + cpu4_bottom_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu4_bottom_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu4_bottom_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu4_bottom_alert0>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu4_bottom_alert1>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu5-bottom-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 12>; + + trips { + cpu5_bottom_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu5_bottom_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu5_bottom_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu5_bottom_alert0>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu5_bottom_alert1>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu6-bottom-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 13>; + + trips { + cpu6_bottom_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu6_bottom_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu6_bottom_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu6_bottom_alert0>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu6_bottom_alert1>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu7-bottom-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 14>; + + trips { + cpu7_bottom_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu7_bottom_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu7_bottom_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu7_bottom_alert0>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu7_bottom_alert1>; + cooling-device = <&CPU4 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU5 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU6 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU7 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + aoss0-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 0>; + + trips { + aoss0_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + cluster0-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 5>; + + trips { + cluster0_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + cluster0_crit: cluster0_crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + + cluster1-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 6>; + + trips { + cluster1_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + cluster1_crit: cluster1_crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + + gpu-top-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 15>; + + trips { + gpu1_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + aoss1-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 0>; + + trips { + aoss1_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + wlan-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 1>; + + trips { + wlan_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + video-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 2>; + + trips { + video_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + mem-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 3>; + + trips { + mem_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + q6-hvx-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 4>; + + trips { + q6_hvx_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + camera-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 5>; + + trips { + camera_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + compute-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 6>; + + trips { + compute_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + modem-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 7>; + + trips { + modem_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + npu-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 8>; + + trips { + npu_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + modem-vec-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 9>; + + trips { + modem_vec_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + modem-scl-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 10>; + + trips { + modem_scl_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + gpu-bottom-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 11>; + + trips { + gpu2_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + }; +}; diff --git a/include/dt-bindings/clock/qcom,dispcc-sm8150.h b/include/dt-bindings/clock/qcom,dispcc-sm8150.h new file mode 100644 index 0000000000..767fdb27e5 --- /dev/null +++ b/include/dt-bindings/clock/qcom,dispcc-sm8150.h @@ -0,0 +1,76 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2018-2020, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_QCOM_DISP_CC_SM8250_H +#define _DT_BINDINGS_CLK_QCOM_DISP_CC_SM8250_H + +/* DISP_CC clock registers */ +#define DISP_CC_MDSS_AHB_CLK 0 +#define DISP_CC_MDSS_AHB_CLK_SRC 1 +#define DISP_CC_MDSS_BYTE0_CLK 2 +#define DISP_CC_MDSS_BYTE0_CLK_SRC 3 +#define DISP_CC_MDSS_BYTE0_DIV_CLK_SRC 4 +#define DISP_CC_MDSS_BYTE0_INTF_CLK 5 +#define DISP_CC_MDSS_BYTE1_CLK 6 +#define DISP_CC_MDSS_BYTE1_CLK_SRC 7 +#define DISP_CC_MDSS_BYTE1_DIV_CLK_SRC 8 +#define DISP_CC_MDSS_BYTE1_INTF_CLK 9 +#define DISP_CC_MDSS_DP_AUX1_CLK 10 +#define DISP_CC_MDSS_DP_AUX1_CLK_SRC 11 +#define DISP_CC_MDSS_DP_AUX_CLK 12 +#define DISP_CC_MDSS_DP_AUX_CLK_SRC 13 +#define DISP_CC_MDSS_DP_LINK1_CLK 14 +#define DISP_CC_MDSS_DP_LINK1_CLK_SRC 15 +#define DISP_CC_MDSS_DP_LINK1_DIV_CLK_SRC 16 +#define DISP_CC_MDSS_DP_LINK1_INTF_CLK 17 +#define DISP_CC_MDSS_DP_LINK_CLK 18 +#define DISP_CC_MDSS_DP_LINK_CLK_SRC 19 +#define DISP_CC_MDSS_DP_LINK_DIV_CLK_SRC 20 +#define DISP_CC_MDSS_DP_LINK_INTF_CLK 21 +#define DISP_CC_MDSS_DP_PIXEL1_CLK 22 +#define DISP_CC_MDSS_DP_PIXEL1_CLK_SRC 23 +#define DISP_CC_MDSS_DP_PIXEL2_CLK 24 +#define DISP_CC_MDSS_DP_PIXEL2_CLK_SRC 25 +#define DISP_CC_MDSS_DP_PIXEL_CLK 26 +#define DISP_CC_MDSS_DP_PIXEL_CLK_SRC 27 +#define DISP_CC_MDSS_ESC0_CLK 28 +#define DISP_CC_MDSS_ESC0_CLK_SRC 29 +#define DISP_CC_MDSS_ESC1_CLK 30 +#define DISP_CC_MDSS_ESC1_CLK_SRC 31 +#define DISP_CC_MDSS_MDP_CLK 32 +#define DISP_CC_MDSS_MDP_CLK_SRC 33 +#define DISP_CC_MDSS_MDP_LUT_CLK 34 +#define DISP_CC_MDSS_NON_GDSC_AHB_CLK 35 +#define DISP_CC_MDSS_PCLK0_CLK 36 +#define DISP_CC_MDSS_PCLK0_CLK_SRC 37 +#define DISP_CC_MDSS_PCLK1_CLK 38 +#define DISP_CC_MDSS_PCLK1_CLK_SRC 39 +#define DISP_CC_MDSS_ROT_CLK 40 +#define DISP_CC_MDSS_ROT_CLK_SRC 41 +#define DISP_CC_MDSS_RSCC_AHB_CLK 42 +#define DISP_CC_MDSS_RSCC_VSYNC_CLK 43 +#define DISP_CC_MDSS_VSYNC_CLK 44 +#define DISP_CC_MDSS_VSYNC_CLK_SRC 45 +#define DISP_CC_PLL0 46 +#define DISP_CC_PLL1 47 +#define DISP_CC_MDSS_EDP_AUX_CLK 48 +#define DISP_CC_MDSS_EDP_AUX_CLK_SRC 49 +#define DISP_CC_MDSS_EDP_GTC_CLK 50 +#define DISP_CC_MDSS_EDP_GTC_CLK_SRC 51 +#define DISP_CC_MDSS_EDP_LINK_CLK 52 +#define DISP_CC_MDSS_EDP_LINK_CLK_SRC 53 +#define DISP_CC_MDSS_EDP_LINK_INTF_CLK 54 +#define DISP_CC_MDSS_EDP_PIXEL_CLK 55 +#define DISP_CC_MDSS_EDP_PIXEL_CLK_SRC 56 +#define DISP_CC_MDSS_EDP_LINK_DIV_CLK_SRC 57 + +/* DISP_CC Reset */ +#define DISP_CC_MDSS_CORE_BCR 0 +#define DISP_CC_MDSS_RSCC_BCR 1 + +/* DISP_CC GDSCR */ +#define MDSS_GDSC 0 + +#endif diff --git a/include/dt-bindings/clock/qcom,gcc-sm8150.h b/include/dt-bindings/clock/qcom,gcc-sm8150.h new file mode 100644 index 0000000000..dfefd5e8bf --- /dev/null +++ b/include/dt-bindings/clock/qcom,gcc-sm8150.h @@ -0,0 +1,252 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2019, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_QCOM_GCC_SM8150_H +#define _DT_BINDINGS_CLK_QCOM_GCC_SM8150_H + +/* GCC clocks */ +#define GCC_AGGRE_NOC_PCIE_TBU_CLK 0 +#define GCC_AGGRE_UFS_CARD_AXI_CLK 1 +#define GCC_AGGRE_UFS_CARD_AXI_HW_CTL_CLK 2 +#define GCC_AGGRE_UFS_PHY_AXI_CLK 3 +#define GCC_AGGRE_UFS_PHY_AXI_HW_CTL_CLK 4 +#define GCC_AGGRE_USB3_PRIM_AXI_CLK 5 +#define GCC_AGGRE_USB3_SEC_AXI_CLK 6 +#define GCC_BOOT_ROM_AHB_CLK 7 +#define GCC_CAMERA_AHB_CLK 8 +#define GCC_CAMERA_HF_AXI_CLK 9 +#define GCC_CAMERA_SF_AXI_CLK 10 +#define GCC_CAMERA_XO_CLK 11 +#define GCC_CFG_NOC_USB3_PRIM_AXI_CLK 12 +#define GCC_CFG_NOC_USB3_SEC_AXI_CLK 13 +#define GCC_CPUSS_AHB_CLK 14 +#define GCC_CPUSS_AHB_CLK_SRC 15 +#define GCC_CPUSS_DVM_BUS_CLK 16 +#define GCC_CPUSS_GNOC_CLK 17 +#define GCC_CPUSS_RBCPR_CLK 18 +#define GCC_DDRSS_GPU_AXI_CLK 19 +#define GCC_DISP_AHB_CLK 20 +#define GCC_DISP_HF_AXI_CLK 21 +#define GCC_DISP_SF_AXI_CLK 22 +#define GCC_DISP_XO_CLK 23 +#define GCC_EMAC_AXI_CLK 24 +#define GCC_EMAC_PTP_CLK 25 +#define GCC_EMAC_PTP_CLK_SRC 26 +#define GCC_EMAC_RGMII_CLK 27 +#define GCC_EMAC_RGMII_CLK_SRC 28 +#define GCC_EMAC_SLV_AHB_CLK 29 +#define GCC_GP1_CLK 30 +#define GCC_GP1_CLK_SRC 31 +#define GCC_GP2_CLK 32 +#define GCC_GP2_CLK_SRC 33 +#define GCC_GP3_CLK 34 +#define GCC_GP3_CLK_SRC 35 +#define GCC_GPU_CFG_AHB_CLK 36 +#define GCC_GPU_GPLL0_CLK_SRC 37 +#define GCC_GPU_GPLL0_DIV_CLK_SRC 38 +#define GCC_GPU_IREF_CLK 39 +#define GCC_GPU_MEMNOC_GFX_CLK 40 +#define GCC_GPU_SNOC_DVM_GFX_CLK 41 +#define GCC_NPU_AT_CLK 42 +#define GCC_NPU_AXI_CLK 43 +#define GCC_NPU_CFG_AHB_CLK 44 +#define GCC_NPU_GPLL0_CLK_SRC 45 +#define GCC_NPU_GPLL0_DIV_CLK_SRC 46 +#define GCC_NPU_TRIG_CLK 47 +#define GCC_PCIE0_PHY_REFGEN_CLK 48 +#define GCC_PCIE1_PHY_REFGEN_CLK 49 +#define GCC_PCIE_0_AUX_CLK 50 +#define GCC_PCIE_0_AUX_CLK_SRC 51 +#define GCC_PCIE_0_CFG_AHB_CLK 52 +#define GCC_PCIE_0_CLKREF_CLK 53 +#define GCC_PCIE_0_MSTR_AXI_CLK 54 +#define GCC_PCIE_0_PIPE_CLK 55 +#define GCC_PCIE_0_SLV_AXI_CLK 56 +#define GCC_PCIE_0_SLV_Q2A_AXI_CLK 57 +#define GCC_PCIE_1_AUX_CLK 58 +#define GCC_PCIE_1_AUX_CLK_SRC 59 +#define GCC_PCIE_1_CFG_AHB_CLK 60 +#define GCC_PCIE_1_CLKREF_CLK 61 +#define GCC_PCIE_1_MSTR_AXI_CLK 62 +#define GCC_PCIE_1_PIPE_CLK 63 +#define GCC_PCIE_1_SLV_AXI_CLK 64 +#define GCC_PCIE_1_SLV_Q2A_AXI_CLK 65 +#define GCC_PCIE_PHY_AUX_CLK 66 +#define GCC_PCIE_PHY_REFGEN_CLK_SRC 67 +#define GCC_PDM2_CLK 68 +#define GCC_PDM2_CLK_SRC 69 +#define GCC_PDM_AHB_CLK 70 +#define GCC_PDM_XO4_CLK 71 +#define GCC_PRNG_AHB_CLK 72 +#define GCC_QMIP_CAMERA_NRT_AHB_CLK 73 +#define GCC_QMIP_CAMERA_RT_AHB_CLK 74 +#define GCC_QMIP_DISP_AHB_CLK 75 +#define GCC_QMIP_VIDEO_CVP_AHB_CLK 76 +#define GCC_QMIP_VIDEO_VCODEC_AHB_CLK 77 +#define GCC_QSPI_CNOC_PERIPH_AHB_CLK 78 +#define GCC_QSPI_CORE_CLK 79 +#define GCC_QSPI_CORE_CLK_SRC 80 +#define GCC_QUPV3_WRAP0_S0_CLK 81 +#define GCC_QUPV3_WRAP0_S0_CLK_SRC 82 +#define GCC_QUPV3_WRAP0_S1_CLK 83 +#define GCC_QUPV3_WRAP0_S1_CLK_SRC 84 +#define GCC_QUPV3_WRAP0_S2_CLK 85 +#define GCC_QUPV3_WRAP0_S2_CLK_SRC 86 +#define GCC_QUPV3_WRAP0_S3_CLK 87 +#define GCC_QUPV3_WRAP0_S3_CLK_SRC 88 +#define GCC_QUPV3_WRAP0_S4_CLK 89 +#define GCC_QUPV3_WRAP0_S4_CLK_SRC 90 +#define GCC_QUPV3_WRAP0_S5_CLK 91 +#define GCC_QUPV3_WRAP0_S5_CLK_SRC 92 +#define GCC_QUPV3_WRAP0_S6_CLK 93 +#define GCC_QUPV3_WRAP0_S6_CLK_SRC 94 +#define GCC_QUPV3_WRAP0_S7_CLK 95 +#define GCC_QUPV3_WRAP0_S7_CLK_SRC 96 +#define GCC_QUPV3_WRAP1_S0_CLK 97 +#define GCC_QUPV3_WRAP1_S0_CLK_SRC 98 +#define GCC_QUPV3_WRAP1_S1_CLK 99 +#define GCC_QUPV3_WRAP1_S1_CLK_SRC 100 +#define GCC_QUPV3_WRAP1_S2_CLK 101 +#define GCC_QUPV3_WRAP1_S2_CLK_SRC 102 +#define GCC_QUPV3_WRAP1_S3_CLK 103 +#define GCC_QUPV3_WRAP1_S3_CLK_SRC 104 +#define GCC_QUPV3_WRAP1_S4_CLK 105 +#define GCC_QUPV3_WRAP1_S4_CLK_SRC 106 +#define GCC_QUPV3_WRAP1_S5_CLK 107 +#define GCC_QUPV3_WRAP1_S5_CLK_SRC 108 +#define GCC_QUPV3_WRAP2_S0_CLK 109 +#define GCC_QUPV3_WRAP2_S0_CLK_SRC 110 +#define GCC_QUPV3_WRAP2_S1_CLK 111 +#define GCC_QUPV3_WRAP2_S1_CLK_SRC 112 +#define GCC_QUPV3_WRAP2_S2_CLK 113 +#define GCC_QUPV3_WRAP2_S2_CLK_SRC 114 +#define GCC_QUPV3_WRAP2_S3_CLK 115 +#define GCC_QUPV3_WRAP2_S3_CLK_SRC 116 +#define GCC_QUPV3_WRAP2_S4_CLK 117 +#define GCC_QUPV3_WRAP2_S4_CLK_SRC 118 +#define GCC_QUPV3_WRAP2_S5_CLK 119 +#define GCC_QUPV3_WRAP2_S5_CLK_SRC 120 +#define GCC_QUPV3_WRAP_0_M_AHB_CLK 121 +#define GCC_QUPV3_WRAP_0_S_AHB_CLK 122 +#define GCC_QUPV3_WRAP_1_M_AHB_CLK 123 +#define GCC_QUPV3_WRAP_1_S_AHB_CLK 124 +#define GCC_QUPV3_WRAP_2_M_AHB_CLK 125 +#define GCC_QUPV3_WRAP_2_S_AHB_CLK 126 +#define GCC_SDCC2_AHB_CLK 127 +#define GCC_SDCC2_APPS_CLK 128 +#define GCC_SDCC2_APPS_CLK_SRC 129 +#define GCC_SDCC4_AHB_CLK 130 +#define GCC_SDCC4_APPS_CLK 131 +#define GCC_SDCC4_APPS_CLK_SRC 132 +#define GCC_SYS_NOC_CPUSS_AHB_CLK 133 +#define GCC_TSIF_AHB_CLK 134 +#define GCC_TSIF_INACTIVITY_TIMERS_CLK 135 +#define GCC_TSIF_REF_CLK 136 +#define GCC_TSIF_REF_CLK_SRC 137 +#define GCC_UFS_CARD_AHB_CLK 138 +#define GCC_UFS_CARD_AXI_CLK 139 +#define GCC_UFS_CARD_AXI_CLK_SRC 140 +#define GCC_UFS_CARD_AXI_HW_CTL_CLK 141 +#define GCC_UFS_CARD_CLKREF_CLK 142 +#define GCC_UFS_CARD_ICE_CORE_CLK 143 +#define GCC_UFS_CARD_ICE_CORE_CLK_SRC 144 +#define GCC_UFS_CARD_ICE_CORE_HW_CTL_CLK 145 +#define GCC_UFS_CARD_PHY_AUX_CLK 146 +#define GCC_UFS_CARD_PHY_AUX_CLK_SRC 147 +#define GCC_UFS_CARD_PHY_AUX_HW_CTL_CLK 148 +#define GCC_UFS_CARD_RX_SYMBOL_0_CLK 149 +#define GCC_UFS_CARD_RX_SYMBOL_1_CLK 150 +#define GCC_UFS_CARD_TX_SYMBOL_0_CLK 151 +#define GCC_UFS_CARD_UNIPRO_CORE_CLK 152 +#define GCC_UFS_CARD_UNIPRO_CORE_CLK_SRC 153 +#define GCC_UFS_CARD_UNIPRO_CORE_HW_CTL_CLK 154 +#define GCC_UFS_MEM_CLKREF_CLK 155 +#define GCC_UFS_PHY_AHB_CLK 156 +#define GCC_UFS_PHY_AXI_CLK 157 +#define GCC_UFS_PHY_AXI_CLK_SRC 158 +#define GCC_UFS_PHY_AXI_HW_CTL_CLK 159 +#define GCC_UFS_PHY_ICE_CORE_CLK 160 +#define GCC_UFS_PHY_ICE_CORE_CLK_SRC 161 +#define GCC_UFS_PHY_ICE_CORE_HW_CTL_CLK 162 +#define GCC_UFS_PHY_PHY_AUX_CLK 163 +#define GCC_UFS_PHY_PHY_AUX_CLK_SRC 164 +#define GCC_UFS_PHY_PHY_AUX_HW_CTL_CLK 165 +#define GCC_UFS_PHY_RX_SYMBOL_0_CLK 166 +#define GCC_UFS_PHY_RX_SYMBOL_1_CLK 167 +#define GCC_UFS_PHY_TX_SYMBOL_0_CLK 168 +#define GCC_UFS_PHY_UNIPRO_CORE_CLK 169 +#define GCC_UFS_PHY_UNIPRO_CORE_CLK_SRC 170 +#define GCC_UFS_PHY_UNIPRO_CORE_HW_CTL_CLK 171 +#define GCC_USB30_PRIM_MASTER_CLK 172 +#define GCC_USB30_PRIM_MASTER_CLK_SRC 173 +#define GCC_USB30_PRIM_MOCK_UTMI_CLK 174 +#define GCC_USB30_PRIM_MOCK_UTMI_CLK_SRC 175 +#define GCC_USB30_PRIM_SLEEP_CLK 176 +#define GCC_USB30_SEC_MASTER_CLK 177 +#define GCC_USB30_SEC_MASTER_CLK_SRC 178 +#define GCC_USB30_SEC_MOCK_UTMI_CLK 179 +#define GCC_USB30_SEC_MOCK_UTMI_CLK_SRC 180 +#define GCC_USB30_SEC_SLEEP_CLK 181 +#define GCC_USB3_PRIM_CLKREF_CLK 182 +#define GCC_USB3_PRIM_PHY_AUX_CLK 183 +#define GCC_USB3_PRIM_PHY_AUX_CLK_SRC 184 +#define GCC_USB3_PRIM_PHY_COM_AUX_CLK 185 +#define GCC_USB3_PRIM_PHY_PIPE_CLK 186 +#define GCC_USB3_SEC_CLKREF_CLK 187 +#define GCC_USB3_SEC_PHY_AUX_CLK 188 +#define GCC_USB3_SEC_PHY_AUX_CLK_SRC 189 +#define GCC_USB3_SEC_PHY_COM_AUX_CLK 190 +#define GCC_USB3_SEC_PHY_PIPE_CLK 191 +#define GCC_VIDEO_AHB_CLK 192 +#define GCC_VIDEO_AXI0_CLK 193 +#define GCC_VIDEO_AXI1_CLK 194 +#define GCC_VIDEO_AXIC_CLK 195 +#define GCC_VIDEO_XO_CLK 196 +#define GPLL0 197 +#define GPLL0_OUT_EVEN 198 +#define GPLL7 199 +#define GPLL9 200 + +/* Reset clocks */ +#define GCC_EMAC_BCR 0 +#define GCC_GPU_BCR 1 +#define GCC_MMSS_BCR 2 +#define GCC_NPU_BCR 3 +#define GCC_PCIE_0_BCR 4 +#define GCC_PCIE_0_PHY_BCR 5 +#define GCC_PCIE_1_BCR 6 +#define GCC_PCIE_1_PHY_BCR 7 +#define GCC_PCIE_PHY_BCR 8 +#define GCC_PDM_BCR 9 +#define GCC_PRNG_BCR 10 +#define GCC_QSPI_BCR 11 +#define GCC_QUPV3_WRAPPER_0_BCR 12 +#define GCC_QUPV3_WRAPPER_1_BCR 13 +#define GCC_QUPV3_WRAPPER_2_BCR 14 +#define GCC_QUSB2PHY_PRIM_BCR 15 +#define GCC_QUSB2PHY_SEC_BCR 16 +#define GCC_USB3_PHY_PRIM_BCR 17 +#define GCC_USB3_DP_PHY_PRIM_BCR 18 +#define GCC_USB3_PHY_SEC_BCR 19 +#define GCC_USB3PHY_PHY_SEC_BCR 20 +#define GCC_SDCC2_BCR 21 +#define GCC_SDCC4_BCR 22 +#define GCC_TSIF_BCR 23 +#define GCC_UFS_CARD_BCR 24 +#define GCC_UFS_PHY_BCR 25 +#define GCC_USB30_PRIM_BCR 26 +#define GCC_USB30_SEC_BCR 27 +#define GCC_USB_PHY_CFG_AHB2PHY_BCR 28 + +/* GCC GDSCRs */ +#define PCIE_0_GDSC 0 +#define PCIE_1_GDSC 1 +#define UFS_CARD_GDSC 2 +#define UFS_PHY_GDSC 3 +#define USB30_PRIM_GDSC 4 +#define USB30_SEC_GDSC 5 +#define EMAC_GDSC 6 + +#endif diff --git a/include/dt-bindings/clock/qcom,gpucc-sm8150.h b/include/dt-bindings/clock/qcom,gpucc-sm8150.h new file mode 100644 index 0000000000..c5b70aad77 --- /dev/null +++ b/include/dt-bindings/clock/qcom,gpucc-sm8150.h @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017-2020, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_QCOM_GPU_CC_SM8150_H +#define _DT_BINDINGS_CLK_QCOM_GPU_CC_SM8150_H + +/* GPU_CC clock registers */ +#define GPU_CC_AHB_CLK 0 +#define GPU_CC_CRC_AHB_CLK 1 +#define GPU_CC_CX_APB_CLK 2 +#define GPU_CC_CX_GMU_CLK 3 +#define GPU_CC_CX_SNOC_DVM_CLK 4 +#define GPU_CC_CXO_AON_CLK 5 +#define GPU_CC_CXO_CLK 6 +#define GPU_CC_GMU_CLK_SRC 7 +#define GPU_CC_GX_GMU_CLK 8 +#define GPU_CC_PLL1 9 + +/* GPU_CC Resets */ +#define GPUCC_GPU_CC_CX_BCR 0 +#define GPUCC_GPU_CC_GFX3D_AON_BCR 1 +#define GPUCC_GPU_CC_GMU_BCR 2 +#define GPUCC_GPU_CC_GX_BCR 3 +#define GPUCC_GPU_CC_SPDM_BCR 4 +#define GPUCC_GPU_CC_XO_BCR 5 + +/* GPU_CC GDSCRs */ +#define GPU_CX_GDSC 0 +#define GPU_GX_GDSC 1 + +#endif diff --git a/include/dt-bindings/clock/qcom,rpmh.h b/include/dt-bindings/clock/qcom,rpmh.h new file mode 100644 index 0000000000..0a7d1be0d1 --- /dev/null +++ b/include/dt-bindings/clock/qcom,rpmh.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* Copyright (c) 2018, 2020, The Linux Foundation. All rights reserved. */ + + +#ifndef _DT_BINDINGS_CLK_MSM_RPMH_H +#define _DT_BINDINGS_CLK_MSM_RPMH_H + +/* RPMh controlled clocks */ +#define RPMH_CXO_CLK 0 +#define RPMH_CXO_CLK_A 1 +#define RPMH_LN_BB_CLK2 2 +#define RPMH_LN_BB_CLK2_A 3 +#define RPMH_LN_BB_CLK3 4 +#define RPMH_LN_BB_CLK3_A 5 +#define RPMH_RF_CLK1 6 +#define RPMH_RF_CLK1_A 7 +#define RPMH_RF_CLK2 8 +#define RPMH_RF_CLK2_A 9 +#define RPMH_RF_CLK3 10 +#define RPMH_RF_CLK3_A 11 +#define RPMH_IPA_CLK 12 +#define RPMH_LN_BB_CLK1 13 +#define RPMH_LN_BB_CLK1_A 14 +#define RPMH_CE_CLK 15 +#define RPMH_QPIC_CLK 16 +#define RPMH_DIV_CLK1 17 +#define RPMH_DIV_CLK1_A 18 +#define RPMH_RF_CLK4 19 +#define RPMH_RF_CLK4_A 20 +#define RPMH_RF_CLK5 21 +#define RPMH_RF_CLK5_A 22 +#define RPMH_PKA_CLK 23 +#define RPMH_HWKM_CLK 24 +#define RPMH_QLINK_CLK 25 +#define RPMH_QLINK_CLK_A 26 + +#endif diff --git a/include/dt-bindings/dma/qcom-gpi.h b/include/dt-bindings/dma/qcom-gpi.h new file mode 100644 index 0000000000..ebda2a37f5 --- /dev/null +++ b/include/dt-bindings/dma/qcom-gpi.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0 OR BSD-2-Clause */ +/* Copyright (c) 2020, Linaro Ltd. */ + +#ifndef __DT_BINDINGS_DMA_QCOM_GPI_H__ +#define __DT_BINDINGS_DMA_QCOM_GPI_H__ + +#define QCOM_GPI_SPI 1 +#define QCOM_GPI_UART 2 +#define QCOM_GPI_I2C 3 + +#endif /* __DT_BINDINGS_DMA_QCOM_GPI_H__ */ diff --git a/include/dt-bindings/firmware/qcom,scm.h b/include/dt-bindings/firmware/qcom,scm.h new file mode 100644 index 0000000000..6de8b08e1e --- /dev/null +++ b/include/dt-bindings/firmware/qcom,scm.h @@ -0,0 +1,39 @@ +/* SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause */ +/* + * Copyright (c) 2010-2015, 2018-2019 The Linux Foundation. All rights reserved. + * Copyright (C) 2015 Linaro Ltd. + * Copyright (c) 2023 Qualcomm Innovation Center, Inc. All rights reserved. + */ + +#ifndef _DT_BINDINGS_FIRMWARE_QCOM_SCM_H +#define _DT_BINDINGS_FIRMWARE_QCOM_SCM_H + +#define QCOM_SCM_VMID_TZ 0x1 +#define QCOM_SCM_VMID_HLOS 0x3 +#define QCOM_SCM_VMID_SSC_Q6 0x5 +#define QCOM_SCM_VMID_ADSP_Q6 0x6 +#define QCOM_SCM_VMID_CP_TOUCH 0x8 +#define QCOM_SCM_VMID_CP_BITSTREAM 0x9 +#define QCOM_SCM_VMID_CP_PIXEL 0xA +#define QCOM_SCM_VMID_CP_NON_PIXEL 0xB +#define QCOM_SCM_VMID_CP_CAMERA 0xD +#define QCOM_SCM_VMID_HLOS_FREE 0xE +#define QCOM_SCM_VMID_MSS_MSA 0xF +#define QCOM_SCM_VMID_MSS_NONMSA 0x10 +#define QCOM_SCM_VMID_CP_SEC_DISPLAY 0x11 +#define QCOM_SCM_VMID_CP_APP 0x12 +#define QCOM_SCM_VMID_LPASS 0x16 +#define QCOM_SCM_VMID_WLAN 0x18 +#define QCOM_SCM_VMID_WLAN_CE 0x19 +#define QCOM_SCM_VMID_CP_SPSS_SP 0x1A +#define QCOM_SCM_VMID_CP_CAMERA_PREVIEW 0x1D +#define QCOM_SCM_VMID_CDSP 0x1E +#define QCOM_SCM_VMID_CP_SPSS_SP_SHARED 0x22 +#define QCOM_SCM_VMID_CP_SPSS_HLOS_SHARED 0x24 +#define QCOM_SCM_VMID_ADSP_HEAP 0x25 +#define QCOM_SCM_VMID_CP_CDSP 0x2A +#define QCOM_SCM_VMID_NAV 0x2B +#define QCOM_SCM_VMID_TVM 0x2D +#define QCOM_SCM_VMID_OEMVM 0x31 + +#endif diff --git a/include/dt-bindings/iio/qcom,spmi-vadc.h b/include/dt-bindings/iio/qcom,spmi-vadc.h new file mode 100644 index 0000000000..ef07ecd4d5 --- /dev/null +++ b/include/dt-bindings/iio/qcom,spmi-vadc.h @@ -0,0 +1,303 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2012-2014,2018,2020 The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_QCOM_SPMI_VADC_H +#define _DT_BINDINGS_QCOM_SPMI_VADC_H + +/* Voltage ADC channels */ +#define VADC_USBIN 0x00 +#define VADC_DCIN 0x01 +#define VADC_VCHG_SNS 0x02 +#define VADC_SPARE1_03 0x03 +#define VADC_USB_ID_MV 0x04 +#define VADC_VCOIN 0x05 +#define VADC_VBAT_SNS 0x06 +#define VADC_VSYS 0x07 +#define VADC_DIE_TEMP 0x08 +#define VADC_REF_625MV 0x09 +#define VADC_REF_1250MV 0x0a +#define VADC_CHG_TEMP 0x0b +#define VADC_SPARE1 0x0c +#define VADC_SPARE2 0x0d +#define VADC_GND_REF 0x0e +#define VADC_VDD_VADC 0x0f + +#define VADC_P_MUX1_1_1 0x10 +#define VADC_P_MUX2_1_1 0x11 +#define VADC_P_MUX3_1_1 0x12 +#define VADC_P_MUX4_1_1 0x13 +#define VADC_P_MUX5_1_1 0x14 +#define VADC_P_MUX6_1_1 0x15 +#define VADC_P_MUX7_1_1 0x16 +#define VADC_P_MUX8_1_1 0x17 +#define VADC_P_MUX9_1_1 0x18 +#define VADC_P_MUX10_1_1 0x19 +#define VADC_P_MUX11_1_1 0x1a +#define VADC_P_MUX12_1_1 0x1b +#define VADC_P_MUX13_1_1 0x1c +#define VADC_P_MUX14_1_1 0x1d +#define VADC_P_MUX15_1_1 0x1e +#define VADC_P_MUX16_1_1 0x1f + +#define VADC_P_MUX1_1_3 0x20 +#define VADC_P_MUX2_1_3 0x21 +#define VADC_P_MUX3_1_3 0x22 +#define VADC_P_MUX4_1_3 0x23 +#define VADC_P_MUX5_1_3 0x24 +#define VADC_P_MUX6_1_3 0x25 +#define VADC_P_MUX7_1_3 0x26 +#define VADC_P_MUX8_1_3 0x27 +#define VADC_P_MUX9_1_3 0x28 +#define VADC_P_MUX10_1_3 0x29 +#define VADC_P_MUX11_1_3 0x2a +#define VADC_P_MUX12_1_3 0x2b +#define VADC_P_MUX13_1_3 0x2c +#define VADC_P_MUX14_1_3 0x2d +#define VADC_P_MUX15_1_3 0x2e +#define VADC_P_MUX16_1_3 0x2f + +#define VADC_LR_MUX1_BAT_THERM 0x30 +#define VADC_LR_MUX2_BAT_ID 0x31 +#define VADC_LR_MUX3_XO_THERM 0x32 +#define VADC_LR_MUX4_AMUX_THM1 0x33 +#define VADC_LR_MUX5_AMUX_THM2 0x34 +#define VADC_LR_MUX6_AMUX_THM3 0x35 +#define VADC_LR_MUX7_HW_ID 0x36 +#define VADC_LR_MUX8_AMUX_THM4 0x37 +#define VADC_LR_MUX9_AMUX_THM5 0x38 +#define VADC_LR_MUX10_USB_ID 0x39 +#define VADC_AMUX_PU1 0x3a +#define VADC_AMUX_PU2 0x3b +#define VADC_LR_MUX3_BUF_XO_THERM 0x3c + +#define VADC_LR_MUX1_PU1_BAT_THERM 0x70 +#define VADC_LR_MUX2_PU1_BAT_ID 0x71 +#define VADC_LR_MUX3_PU1_XO_THERM 0x72 +#define VADC_LR_MUX4_PU1_AMUX_THM1 0x73 +#define VADC_LR_MUX5_PU1_AMUX_THM2 0x74 +#define VADC_LR_MUX6_PU1_AMUX_THM3 0x75 +#define VADC_LR_MUX7_PU1_AMUX_HW_ID 0x76 +#define VADC_LR_MUX8_PU1_AMUX_THM4 0x77 +#define VADC_LR_MUX9_PU1_AMUX_THM5 0x78 +#define VADC_LR_MUX10_PU1_AMUX_USB_ID 0x79 +#define VADC_LR_MUX3_BUF_PU1_XO_THERM 0x7c + +#define VADC_LR_MUX1_PU2_BAT_THERM 0xb0 +#define VADC_LR_MUX2_PU2_BAT_ID 0xb1 +#define VADC_LR_MUX3_PU2_XO_THERM 0xb2 +#define VADC_LR_MUX4_PU2_AMUX_THM1 0xb3 +#define VADC_LR_MUX5_PU2_AMUX_THM2 0xb4 +#define VADC_LR_MUX6_PU2_AMUX_THM3 0xb5 +#define VADC_LR_MUX7_PU2_AMUX_HW_ID 0xb6 +#define VADC_LR_MUX8_PU2_AMUX_THM4 0xb7 +#define VADC_LR_MUX9_PU2_AMUX_THM5 0xb8 +#define VADC_LR_MUX10_PU2_AMUX_USB_ID 0xb9 +#define VADC_LR_MUX3_BUF_PU2_XO_THERM 0xbc + +#define VADC_LR_MUX1_PU1_PU2_BAT_THERM 0xf0 +#define VADC_LR_MUX2_PU1_PU2_BAT_ID 0xf1 +#define VADC_LR_MUX3_PU1_PU2_XO_THERM 0xf2 +#define VADC_LR_MUX4_PU1_PU2_AMUX_THM1 0xf3 +#define VADC_LR_MUX5_PU1_PU2_AMUX_THM2 0xf4 +#define VADC_LR_MUX6_PU1_PU2_AMUX_THM3 0xf5 +#define VADC_LR_MUX7_PU1_PU2_AMUX_HW_ID 0xf6 +#define VADC_LR_MUX8_PU1_PU2_AMUX_THM4 0xf7 +#define VADC_LR_MUX9_PU1_PU2_AMUX_THM5 0xf8 +#define VADC_LR_MUX10_PU1_PU2_AMUX_USB_ID 0xf9 +#define VADC_LR_MUX3_BUF_PU1_PU2_XO_THERM 0xfc + +/* ADC channels for SPMI PMIC5 */ + +#define ADC5_REF_GND 0x00 +#define ADC5_1P25VREF 0x01 +#define ADC5_VREF_VADC 0x02 +#define ADC5_VREF_VADC5_DIV_3 0x82 +#define ADC5_VPH_PWR 0x83 +#define ADC5_VBAT_SNS 0x84 +#define ADC5_VCOIN 0x85 +#define ADC5_DIE_TEMP 0x06 +#define ADC5_USB_IN_I 0x07 +#define ADC5_USB_IN_V_16 0x08 +#define ADC5_CHG_TEMP 0x09 +#define ADC5_BAT_THERM 0x0a +#define ADC5_BAT_ID 0x0b +#define ADC5_XO_THERM 0x0c +#define ADC5_AMUX_THM1 0x0d +#define ADC5_AMUX_THM2 0x0e +#define ADC5_AMUX_THM3 0x0f +#define ADC5_AMUX_THM4 0x10 +#define ADC5_AMUX_THM5 0x11 +#define ADC5_GPIO1 0x12 +#define ADC5_GPIO2 0x13 +#define ADC5_GPIO3 0x14 +#define ADC5_GPIO4 0x15 +#define ADC5_GPIO5 0x16 +#define ADC5_GPIO6 0x17 +#define ADC5_GPIO7 0x18 +#define ADC5_SBUx 0x99 +#define ADC5_MID_CHG_DIV6 0x1e +#define ADC5_OFF 0xff + +/* 30k pull-up1 */ +#define ADC5_BAT_THERM_30K_PU 0x2a +#define ADC5_BAT_ID_30K_PU 0x2b +#define ADC5_XO_THERM_30K_PU 0x2c +#define ADC5_AMUX_THM1_30K_PU 0x2d +#define ADC5_AMUX_THM2_30K_PU 0x2e +#define ADC5_AMUX_THM3_30K_PU 0x2f +#define ADC5_AMUX_THM4_30K_PU 0x30 +#define ADC5_AMUX_THM5_30K_PU 0x31 +#define ADC5_GPIO1_30K_PU 0x32 +#define ADC5_GPIO2_30K_PU 0x33 +#define ADC5_GPIO3_30K_PU 0x34 +#define ADC5_GPIO4_30K_PU 0x35 +#define ADC5_GPIO5_30K_PU 0x36 +#define ADC5_GPIO6_30K_PU 0x37 +#define ADC5_GPIO7_30K_PU 0x38 +#define ADC5_SBUx_30K_PU 0x39 + +/* 100k pull-up2 */ +#define ADC5_BAT_THERM_100K_PU 0x4a +#define ADC5_BAT_ID_100K_PU 0x4b +#define ADC5_XO_THERM_100K_PU 0x4c +#define ADC5_AMUX_THM1_100K_PU 0x4d +#define ADC5_AMUX_THM2_100K_PU 0x4e +#define ADC5_AMUX_THM3_100K_PU 0x4f +#define ADC5_AMUX_THM4_100K_PU 0x50 +#define ADC5_AMUX_THM5_100K_PU 0x51 +#define ADC5_GPIO1_100K_PU 0x52 +#define ADC5_GPIO2_100K_PU 0x53 +#define ADC5_GPIO3_100K_PU 0x54 +#define ADC5_GPIO4_100K_PU 0x55 +#define ADC5_GPIO5_100K_PU 0x56 +#define ADC5_GPIO6_100K_PU 0x57 +#define ADC5_GPIO7_100K_PU 0x58 +#define ADC5_SBUx_100K_PU 0x59 + +/* 400k pull-up3 */ +#define ADC5_BAT_THERM_400K_PU 0x6a +#define ADC5_BAT_ID_400K_PU 0x6b +#define ADC5_XO_THERM_400K_PU 0x6c +#define ADC5_AMUX_THM1_400K_PU 0x6d +#define ADC5_AMUX_THM2_400K_PU 0x6e +#define ADC5_AMUX_THM3_400K_PU 0x6f +#define ADC5_AMUX_THM4_400K_PU 0x70 +#define ADC5_AMUX_THM5_400K_PU 0x71 +#define ADC5_GPIO1_400K_PU 0x72 +#define ADC5_GPIO2_400K_PU 0x73 +#define ADC5_GPIO3_400K_PU 0x74 +#define ADC5_GPIO4_400K_PU 0x75 +#define ADC5_GPIO5_400K_PU 0x76 +#define ADC5_GPIO6_400K_PU 0x77 +#define ADC5_GPIO7_400K_PU 0x78 +#define ADC5_SBUx_400K_PU 0x79 + +/* 1/3 Divider */ +#define ADC5_GPIO1_DIV3 0x92 +#define ADC5_GPIO2_DIV3 0x93 +#define ADC5_GPIO3_DIV3 0x94 +#define ADC5_GPIO4_DIV3 0x95 +#define ADC5_GPIO5_DIV3 0x96 +#define ADC5_GPIO6_DIV3 0x97 +#define ADC5_GPIO7_DIV3 0x98 +#define ADC5_SBUx_DIV3 0x99 + +/* Current and combined current/voltage channels */ +#define ADC5_INT_EXT_ISENSE 0xa1 +#define ADC5_PARALLEL_ISENSE 0xa5 +#define ADC5_CUR_REPLICA_VDS 0xa7 +#define ADC5_CUR_SENS_BATFET_VDS_OFFSET 0xa9 +#define ADC5_CUR_SENS_REPLICA_VDS_OFFSET 0xab +#define ADC5_EXT_SENS_OFFSET 0xad + +#define ADC5_INT_EXT_ISENSE_VBAT_VDATA 0xb0 +#define ADC5_INT_EXT_ISENSE_VBAT_IDATA 0xb1 +#define ADC5_EXT_ISENSE_VBAT_VDATA 0xb2 +#define ADC5_EXT_ISENSE_VBAT_IDATA 0xb3 +#define ADC5_PARALLEL_ISENSE_VBAT_VDATA 0xb4 +#define ADC5_PARALLEL_ISENSE_VBAT_IDATA 0xb5 + +#define ADC5_MAX_CHANNEL 0xc0 + +/* ADC channels for ADC for PMIC7 */ + +#define ADC7_REF_GND 0x00 +#define ADC7_1P25VREF 0x01 +#define ADC7_VREF_VADC 0x02 +#define ADC7_DIE_TEMP 0x03 + +#define ADC7_AMUX_THM1 0x04 +#define ADC7_AMUX_THM2 0x05 +#define ADC7_AMUX_THM3 0x06 +#define ADC7_AMUX_THM4 0x07 +#define ADC7_AMUX_THM5 0x08 +#define ADC7_AMUX_THM6 0x09 +#define ADC7_GPIO1 0x0a +#define ADC7_GPIO2 0x0b +#define ADC7_GPIO3 0x0c +#define ADC7_GPIO4 0x0d + +#define ADC7_SMB_TEMP 0x06 +#define ADC7_CHG_TEMP 0x10 +#define ADC7_USB_IN_V_16 0x11 +#define ADC7_VDC_16 0x12 +#define ADC7_CC1_ID 0x13 +#define ADC7_VREF_BAT_THERM 0x15 +#define ADC7_IIN_FB 0x17 +#define ADC7_ICHG_SMB 0x18 +#define ADC7_IIN_SMB 0x19 + +/* 30k pull-up1 */ +#define ADC7_AMUX_THM1_30K_PU 0x24 +#define ADC7_AMUX_THM2_30K_PU 0x25 +#define ADC7_AMUX_THM3_30K_PU 0x26 +#define ADC7_AMUX_THM4_30K_PU 0x27 +#define ADC7_AMUX_THM5_30K_PU 0x28 +#define ADC7_AMUX_THM6_30K_PU 0x29 +#define ADC7_GPIO1_30K_PU 0x2a +#define ADC7_GPIO2_30K_PU 0x2b +#define ADC7_GPIO3_30K_PU 0x2c +#define ADC7_GPIO4_30K_PU 0x2d +#define ADC7_CC1_ID_30K_PU 0x33 + +/* 100k pull-up2 */ +#define ADC7_AMUX_THM1_100K_PU 0x44 +#define ADC7_AMUX_THM2_100K_PU 0x45 +#define ADC7_AMUX_THM3_100K_PU 0x46 +#define ADC7_AMUX_THM4_100K_PU 0x47 +#define ADC7_AMUX_THM5_100K_PU 0x48 +#define ADC7_AMUX_THM6_100K_PU 0x49 +#define ADC7_GPIO1_100K_PU 0x4a +#define ADC7_GPIO2_100K_PU 0x4b +#define ADC7_GPIO3_100K_PU 0x4c +#define ADC7_GPIO4_100K_PU 0x4d +#define ADC7_CC1_ID_100K_PU 0x53 + +/* 400k pull-up3 */ +#define ADC7_AMUX_THM1_400K_PU 0x64 +#define ADC7_AMUX_THM2_400K_PU 0x65 +#define ADC7_AMUX_THM3_400K_PU 0x66 +#define ADC7_AMUX_THM4_400K_PU 0x67 +#define ADC7_AMUX_THM5_400K_PU 0x68 +#define ADC7_AMUX_THM6_400K_PU 0x69 +#define ADC7_GPIO1_400K_PU 0x6a +#define ADC7_GPIO2_400K_PU 0x6b +#define ADC7_GPIO3_400K_PU 0x6c +#define ADC7_GPIO4_400K_PU 0x6d +#define ADC7_CC1_ID_400K_PU 0x73 + +/* 1/3 Divider */ +#define ADC7_GPIO1_DIV3 0x8a +#define ADC7_GPIO2_DIV3 0x8b +#define ADC7_GPIO3_DIV3 0x8c +#define ADC7_GPIO4_DIV3 0x8d + +#define ADC7_VPH_PWR 0x8e +#define ADC7_VBAT_SNS 0x8f + +#define ADC7_SBUx 0x94 +#define ADC7_VBAT_2S_MID 0x96 + +#endif /* _DT_BINDINGS_QCOM_SPMI_VADC_H */ diff --git a/include/dt-bindings/interconnect/qcom,osm-l3.h b/include/dt-bindings/interconnect/qcom,osm-l3.h new file mode 100644 index 0000000000..61ef649ae5 --- /dev/null +++ b/include/dt-bindings/interconnect/qcom,osm-l3.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 The Linux Foundation. All rights reserved. + */ + +#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_OSM_L3_H +#define __DT_BINDINGS_INTERCONNECT_QCOM_OSM_L3_H + +#define MASTER_OSM_L3_APPS 0 +#define SLAVE_OSM_L3 1 + +#define MASTER_EPSS_L3_APPS 0 +#define SLAVE_EPSS_L3_SHARED 1 + +#endif diff --git a/include/dt-bindings/interconnect/qcom,sm8150.h b/include/dt-bindings/interconnect/qcom,sm8150.h new file mode 100644 index 0000000000..ef292791f5 --- /dev/null +++ b/include/dt-bindings/interconnect/qcom,sm8150.h @@ -0,0 +1,159 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Qualcomm SM8150 interconnect IDs + * + * Copyright (c) 2020, The Linux Foundation. All rights reserved. + */ + +#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_SM8150_H +#define __DT_BINDINGS_INTERCONNECT_QCOM_SM8150_H + +#define MASTER_A1NOC_CFG 0 +#define MASTER_QUP_0 1 +#define MASTER_EMAC 2 +#define MASTER_UFS_MEM 3 +#define MASTER_USB3 4 +#define MASTER_USB3_1 5 +#define A1NOC_SNOC_SLV 6 +#define SLAVE_SERVICE_A1NOC 7 + +#define MASTER_A2NOC_CFG 0 +#define MASTER_QDSS_BAM 1 +#define MASTER_QSPI 2 +#define MASTER_QUP_1 3 +#define MASTER_QUP_2 4 +#define MASTER_SENSORS_AHB 5 +#define MASTER_TSIF 6 +#define MASTER_CNOC_A2NOC 7 +#define MASTER_CRYPTO_CORE_0 8 +#define MASTER_IPA 9 +#define MASTER_PCIE 10 +#define MASTER_PCIE_1 11 +#define MASTER_QDSS_ETR 12 +#define MASTER_SDCC_2 13 +#define MASTER_SDCC_4 14 +#define A2NOC_SNOC_SLV 15 +#define SLAVE_ANOC_PCIE_GEM_NOC 16 +#define SLAVE_SERVICE_A2NOC 17 + +#define MASTER_CAMNOC_HF0_UNCOMP 0 +#define MASTER_CAMNOC_HF1_UNCOMP 1 +#define MASTER_CAMNOC_SF_UNCOMP 2 +#define SLAVE_CAMNOC_UNCOMP 3 + +#define MASTER_NPU 0 +#define SLAVE_CDSP_MEM_NOC 1 + +#define MASTER_SPDM 0 +#define SNOC_CNOC_MAS 1 +#define MASTER_QDSS_DAP 2 +#define SLAVE_A1NOC_CFG 3 +#define SLAVE_A2NOC_CFG 4 +#define SLAVE_AHB2PHY_SOUTH 5 +#define SLAVE_AOP 6 +#define SLAVE_AOSS 7 +#define SLAVE_CAMERA_CFG 8 +#define SLAVE_CLK_CTL 9 +#define SLAVE_CDSP_CFG 10 +#define SLAVE_RBCPR_CX_CFG 11 +#define SLAVE_RBCPR_MMCX_CFG 12 +#define SLAVE_RBCPR_MX_CFG 13 +#define SLAVE_CRYPTO_0_CFG 14 +#define SLAVE_CNOC_DDRSS 15 +#define SLAVE_DISPLAY_CFG 16 +#define SLAVE_EMAC_CFG 17 +#define SLAVE_GLM 18 +#define SLAVE_GRAPHICS_3D_CFG 19 +#define SLAVE_IMEM_CFG 20 +#define SLAVE_IPA_CFG 21 +#define SLAVE_CNOC_MNOC_CFG 22 +#define SLAVE_NPU_CFG 23 +#define SLAVE_PCIE_0_CFG 24 +#define SLAVE_PCIE_1_CFG 25 +#define SLAVE_NORTH_PHY_CFG 26 +#define SLAVE_PIMEM_CFG 27 +#define SLAVE_PRNG 28 +#define SLAVE_QDSS_CFG 29 +#define SLAVE_QSPI 30 +#define SLAVE_QUP_2 31 +#define SLAVE_QUP_1 32 +#define SLAVE_QUP_0 33 +#define SLAVE_SDCC_2 34 +#define SLAVE_SDCC_4 35 +#define SLAVE_SNOC_CFG 36 +#define SLAVE_SPDM_WRAPPER 37 +#define SLAVE_SPSS_CFG 38 +#define SLAVE_SSC_CFG 39 +#define SLAVE_TCSR 40 +#define SLAVE_TLMM_EAST 41 +#define SLAVE_TLMM_NORTH 42 +#define SLAVE_TLMM_SOUTH 43 +#define SLAVE_TLMM_WEST 44 +#define SLAVE_TSIF 45 +#define SLAVE_UFS_CARD_CFG 46 +#define SLAVE_UFS_MEM_CFG 47 +#define SLAVE_USB3 48 +#define SLAVE_USB3_1 49 +#define SLAVE_VENUS_CFG 50 +#define SLAVE_VSENSE_CTRL_CFG 51 +#define SLAVE_CNOC_A2NOC 52 +#define SLAVE_SERVICE_CNOC 53 + +#define MASTER_CNOC_DC_NOC 0 +#define SLAVE_LLCC_CFG 1 +#define SLAVE_GEM_NOC_CFG 2 + +#define MASTER_AMPSS_M0 0 +#define MASTER_GPU_TCU 1 +#define MASTER_SYS_TCU 2 +#define MASTER_GEM_NOC_CFG 3 +#define MASTER_COMPUTE_NOC 4 +#define MASTER_GRAPHICS_3D 5 +#define MASTER_MNOC_HF_MEM_NOC 6 +#define MASTER_MNOC_SF_MEM_NOC 7 +#define MASTER_GEM_NOC_PCIE_SNOC 8 +#define MASTER_SNOC_GC_MEM_NOC 9 +#define MASTER_SNOC_SF_MEM_NOC 10 +#define MASTER_ECC 11 +#define SLAVE_MSS_PROC_MS_MPU_CFG 12 +#define SLAVE_ECC 13 +#define SLAVE_GEM_NOC_SNOC 14 +#define SLAVE_LLCC 15 +#define SLAVE_SERVICE_GEM_NOC 16 + +#define MASTER_LLCC 0 +#define SLAVE_EBI_CH0 1 + +#define MASTER_CNOC_MNOC_CFG 0 +#define MASTER_CAMNOC_HF0 1 +#define MASTER_CAMNOC_HF1 2 +#define MASTER_CAMNOC_SF 3 +#define MASTER_MDP_PORT0 4 +#define MASTER_MDP_PORT1 5 +#define MASTER_ROTATOR 6 +#define MASTER_VIDEO_P0 7 +#define MASTER_VIDEO_P1 8 +#define MASTER_VIDEO_PROC 9 +#define SLAVE_MNOC_SF_MEM_NOC 10 +#define SLAVE_MNOC_HF_MEM_NOC 11 +#define SLAVE_SERVICE_MNOC 12 + +#define MASTER_SNOC_CFG 0 +#define A1NOC_SNOC_MAS 1 +#define A2NOC_SNOC_MAS 2 +#define MASTER_GEM_NOC_SNOC 3 +#define MASTER_PIMEM 4 +#define MASTER_GIC 5 +#define SLAVE_APPSS 6 +#define SNOC_CNOC_SLV 7 +#define SLAVE_SNOC_GEM_NOC_GC 8 +#define SLAVE_SNOC_GEM_NOC_SF 9 +#define SLAVE_OCIMEM 10 +#define SLAVE_PIMEM 11 +#define SLAVE_SERVICE_SNOC 12 +#define SLAVE_PCIE_0 13 +#define SLAVE_PCIE_1 14 +#define SLAVE_QDSS_STM 15 +#define SLAVE_TCU 16 + +#endif diff --git a/include/dt-bindings/phy/phy-qcom-qmp.h b/include/dt-bindings/phy/phy-qcom-qmp.h new file mode 100644 index 0000000000..4edec4c5b2 --- /dev/null +++ b/include/dt-bindings/phy/phy-qcom-qmp.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) */ +/* + * Qualcomm QMP PHY constants + * + * Copyright (C) 2022 Linaro Limited + */ + +#ifndef _DT_BINDINGS_PHY_QMP +#define _DT_BINDINGS_PHY_QMP + +/* QMP USB4-USB3-DP clocks */ +#define QMP_USB43DP_USB3_PIPE_CLK 0 +#define QMP_USB43DP_DP_LINK_CLK 1 +#define QMP_USB43DP_DP_VCO_DIV_CLK 2 + +/* QMP USB4-USB3-DP PHYs */ +#define QMP_USB43DP_USB3_PHY 0 +#define QMP_USB43DP_DP_PHY 1 + +#endif /* _DT_BINDINGS_PHY_QMP */ diff --git a/include/dt-bindings/power/qcom-rpmpd.h b/include/dt-bindings/power/qcom-rpmpd.h new file mode 100644 index 0000000000..7f4e2983a4 --- /dev/null +++ b/include/dt-bindings/power/qcom-rpmpd.h @@ -0,0 +1,412 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* Copyright (c) 2018, The Linux Foundation. All rights reserved. */ + +#ifndef _DT_BINDINGS_POWER_QCOM_RPMPD_H +#define _DT_BINDINGS_POWER_QCOM_RPMPD_H + +/* SA8775P Power Domain Indexes */ +#define SA8775P_CX 0 +#define SA8775P_CX_AO 1 +#define SA8775P_DDR 2 +#define SA8775P_EBI 3 +#define SA8775P_GFX 4 +#define SA8775P_LCX 5 +#define SA8775P_LMX 6 +#define SA8775P_MMCX 7 +#define SA8775P_MMCX_AO 8 +#define SA8775P_MSS 9 +#define SA8775P_MX 10 +#define SA8775P_MX_AO 11 +#define SA8775P_MXC 12 +#define SA8775P_MXC_AO 13 +#define SA8775P_NSP0 14 +#define SA8775P_NSP1 15 +#define SA8775P_XO 16 + +/* SDM670 Power Domain Indexes */ +#define SDM670_MX 0 +#define SDM670_MX_AO 1 +#define SDM670_CX 2 +#define SDM670_CX_AO 3 +#define SDM670_LMX 4 +#define SDM670_LCX 5 +#define SDM670_GFX 6 +#define SDM670_MSS 7 + +/* SDM845 Power Domain Indexes */ +#define SDM845_EBI 0 +#define SDM845_MX 1 +#define SDM845_MX_AO 2 +#define SDM845_CX 3 +#define SDM845_CX_AO 4 +#define SDM845_LMX 5 +#define SDM845_LCX 6 +#define SDM845_GFX 7 +#define SDM845_MSS 8 + +/* SDX55 Power Domain Indexes */ +#define SDX55_MSS 0 +#define SDX55_MX 1 +#define SDX55_CX 2 + +/* SDX65 Power Domain Indexes */ +#define SDX65_MSS 0 +#define SDX65_MX 1 +#define SDX65_MX_AO 2 +#define SDX65_CX 3 +#define SDX65_CX_AO 4 +#define SDX65_MXC 5 + +/* SM6350 Power Domain Indexes */ +#define SM6350_CX 0 +#define SM6350_GFX 1 +#define SM6350_LCX 2 +#define SM6350_LMX 3 +#define SM6350_MSS 4 +#define SM6350_MX 5 + +/* SM6350 Power Domain Indexes */ +#define SM6375_VDDCX 0 +#define SM6375_VDDCX_AO 1 +#define SM6375_VDDCX_VFL 2 +#define SM6375_VDDMX 3 +#define SM6375_VDDMX_AO 4 +#define SM6375_VDDMX_VFL 5 +#define SM6375_VDDGX 6 +#define SM6375_VDDGX_AO 7 +#define SM6375_VDD_LPI_CX 8 +#define SM6375_VDD_LPI_MX 9 + +/* SM8150 Power Domain Indexes */ +#define SM8150_MSS 0 +#define SM8150_EBI 1 +#define SM8150_LMX 2 +#define SM8150_LCX 3 +#define SM8150_GFX 4 +#define SM8150_MX 5 +#define SM8150_MX_AO 6 +#define SM8150_CX 7 +#define SM8150_CX_AO 8 +#define SM8150_MMCX 9 +#define SM8150_MMCX_AO 10 + +/* SA8155P is a special case, kept for backwards compatibility */ +#define SA8155P_CX SM8150_CX +#define SA8155P_CX_AO SM8150_CX_AO +#define SA8155P_EBI SM8150_EBI +#define SA8155P_GFX SM8150_GFX +#define SA8155P_MSS SM8150_MSS +#define SA8155P_MX SM8150_MX +#define SA8155P_MX_AO SM8150_MX_AO + +/* SM8250 Power Domain Indexes */ +#define SM8250_CX 0 +#define SM8250_CX_AO 1 +#define SM8250_EBI 2 +#define SM8250_GFX 3 +#define SM8250_LCX 4 +#define SM8250_LMX 5 +#define SM8250_MMCX 6 +#define SM8250_MMCX_AO 7 +#define SM8250_MX 8 +#define SM8250_MX_AO 9 + +/* SM8350 Power Domain Indexes */ +#define SM8350_CX 0 +#define SM8350_CX_AO 1 +#define SM8350_EBI 2 +#define SM8350_GFX 3 +#define SM8350_LCX 4 +#define SM8350_LMX 5 +#define SM8350_MMCX 6 +#define SM8350_MMCX_AO 7 +#define SM8350_MX 8 +#define SM8350_MX_AO 9 +#define SM8350_MXC 10 +#define SM8350_MXC_AO 11 +#define SM8350_MSS 12 + +/* SM8450 Power Domain Indexes */ +#define SM8450_CX 0 +#define SM8450_CX_AO 1 +#define SM8450_EBI 2 +#define SM8450_GFX 3 +#define SM8450_LCX 4 +#define SM8450_LMX 5 +#define SM8450_MMCX 6 +#define SM8450_MMCX_AO 7 +#define SM8450_MX 8 +#define SM8450_MX_AO 9 +#define SM8450_MXC 10 +#define SM8450_MXC_AO 11 +#define SM8450_MSS 12 + +/* SM8550 Power Domain Indexes */ +#define SM8550_CX 0 +#define SM8550_CX_AO 1 +#define SM8550_EBI 2 +#define SM8550_GFX 3 +#define SM8550_LCX 4 +#define SM8550_LMX 5 +#define SM8550_MMCX 6 +#define SM8550_MMCX_AO 7 +#define SM8550_MX 8 +#define SM8550_MX_AO 9 +#define SM8550_MXC 10 +#define SM8550_MXC_AO 11 +#define SM8550_MSS 12 +#define SM8550_NSP 13 + +/* QDU1000/QRU1000 Power Domain Indexes */ +#define QDU1000_EBI 0 +#define QDU1000_MSS 1 +#define QDU1000_CX 2 +#define QDU1000_MX 3 + +/* SC7180 Power Domain Indexes */ +#define SC7180_CX 0 +#define SC7180_CX_AO 1 +#define SC7180_GFX 2 +#define SC7180_MX 3 +#define SC7180_MX_AO 4 +#define SC7180_LMX 5 +#define SC7180_LCX 6 +#define SC7180_MSS 7 + +/* SC7280 Power Domain Indexes */ +#define SC7280_CX 0 +#define SC7280_CX_AO 1 +#define SC7280_EBI 2 +#define SC7280_GFX 3 +#define SC7280_MX 4 +#define SC7280_MX_AO 5 +#define SC7280_LMX 6 +#define SC7280_LCX 7 +#define SC7280_MSS 8 + +/* SC8180X Power Domain Indexes */ +#define SC8180X_CX 0 +#define SC8180X_CX_AO 1 +#define SC8180X_EBI 2 +#define SC8180X_GFX 3 +#define SC8180X_LCX 4 +#define SC8180X_LMX 5 +#define SC8180X_MMCX 6 +#define SC8180X_MMCX_AO 7 +#define SC8180X_MSS 8 +#define SC8180X_MX 9 +#define SC8180X_MX_AO 10 + +/* SC8280XP Power Domain Indexes */ +#define SC8280XP_CX 0 +#define SC8280XP_CX_AO 1 +#define SC8280XP_DDR 2 +#define SC8280XP_EBI 3 +#define SC8280XP_GFX 4 +#define SC8280XP_LCX 5 +#define SC8280XP_LMX 6 +#define SC8280XP_MMCX 7 +#define SC8280XP_MMCX_AO 8 +#define SC8280XP_MSS 9 +#define SC8280XP_MX 10 +#define SC8280XP_MXC 12 +#define SC8280XP_MX_AO 11 +#define SC8280XP_NSP 13 +#define SC8280XP_QPHY 14 +#define SC8280XP_XO 15 + +/* SDM845 Power Domain performance levels */ +#define RPMH_REGULATOR_LEVEL_RETENTION 16 +#define RPMH_REGULATOR_LEVEL_MIN_SVS 48 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_D2 52 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_D1 56 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_D0 60 +#define RPMH_REGULATOR_LEVEL_LOW_SVS 64 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_P1 72 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_L1 80 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_L2 96 +#define RPMH_REGULATOR_LEVEL_SVS 128 +#define RPMH_REGULATOR_LEVEL_SVS_L0 144 +#define RPMH_REGULATOR_LEVEL_SVS_L1 192 +#define RPMH_REGULATOR_LEVEL_SVS_L2 224 +#define RPMH_REGULATOR_LEVEL_NOM 256 +#define RPMH_REGULATOR_LEVEL_NOM_L0 288 +#define RPMH_REGULATOR_LEVEL_NOM_L1 320 +#define RPMH_REGULATOR_LEVEL_NOM_L2 336 +#define RPMH_REGULATOR_LEVEL_TURBO 384 +#define RPMH_REGULATOR_LEVEL_TURBO_L0 400 +#define RPMH_REGULATOR_LEVEL_TURBO_L1 416 +#define RPMH_REGULATOR_LEVEL_TURBO_L2 432 +#define RPMH_REGULATOR_LEVEL_TURBO_L3 448 +#define RPMH_REGULATOR_LEVEL_SUPER_TURBO 464 +#define RPMH_REGULATOR_LEVEL_SUPER_TURBO_NO_CPR 480 + +/* MDM9607 Power Domains */ +#define MDM9607_VDDCX 0 +#define MDM9607_VDDCX_AO 1 +#define MDM9607_VDDCX_VFL 2 +#define MDM9607_VDDMX 3 +#define MDM9607_VDDMX_AO 4 +#define MDM9607_VDDMX_VFL 5 + +/* MSM8226 Power Domain Indexes */ +#define MSM8226_VDDCX 0 +#define MSM8226_VDDCX_AO 1 +#define MSM8226_VDDCX_VFC 2 + +/* MSM8939 Power Domains */ +#define MSM8939_VDDMDCX 0 +#define MSM8939_VDDMDCX_AO 1 +#define MSM8939_VDDMDCX_VFC 2 +#define MSM8939_VDDCX 3 +#define MSM8939_VDDCX_AO 4 +#define MSM8939_VDDCX_VFC 5 +#define MSM8939_VDDMX 6 +#define MSM8939_VDDMX_AO 7 + +/* MSM8916 Power Domain Indexes */ +#define MSM8916_VDDCX 0 +#define MSM8916_VDDCX_AO 1 +#define MSM8916_VDDCX_VFC 2 +#define MSM8916_VDDMX 3 +#define MSM8916_VDDMX_AO 4 + +/* MSM8909 Power Domain Indexes */ +#define MSM8909_VDDCX MSM8916_VDDCX +#define MSM8909_VDDCX_AO MSM8916_VDDCX_AO +#define MSM8909_VDDCX_VFC MSM8916_VDDCX_VFC +#define MSM8909_VDDMX MSM8916_VDDMX +#define MSM8909_VDDMX_AO MSM8916_VDDMX_AO + +/* MSM8917 Power Domain Indexes */ +#define MSM8917_VDDCX 0 +#define MSM8917_VDDCX_AO 1 +#define MSM8917_VDDCX_VFL 2 +#define MSM8917_VDDMX 3 +#define MSM8917_VDDMX_AO 4 + +/* MSM8937 Power Domain Indexes */ +#define MSM8937_VDDCX MSM8917_VDDCX +#define MSM8937_VDDCX_AO MSM8917_VDDCX_AO +#define MSM8937_VDDCX_VFL MSM8917_VDDCX_VFL +#define MSM8937_VDDMX MSM8917_VDDMX +#define MSM8937_VDDMX_AO MSM8917_VDDMX_AO + +/* QM215 Power Domain Indexes */ +#define QM215_VDDCX MSM8917_VDDCX +#define QM215_VDDCX_AO MSM8917_VDDCX_AO +#define QM215_VDDCX_VFL MSM8917_VDDCX_VFL +#define QM215_VDDMX MSM8917_VDDMX +#define QM215_VDDMX_AO MSM8917_VDDMX_AO + +/* MSM8953 Power Domain Indexes */ +#define MSM8953_VDDMD 0 +#define MSM8953_VDDMD_AO 1 +#define MSM8953_VDDCX 2 +#define MSM8953_VDDCX_AO 3 +#define MSM8953_VDDCX_VFL 4 +#define MSM8953_VDDMX 5 +#define MSM8953_VDDMX_AO 6 + +/* MSM8976 Power Domain Indexes */ +#define MSM8976_VDDCX 0 +#define MSM8976_VDDCX_AO 1 +#define MSM8976_VDDCX_VFL 2 +#define MSM8976_VDDMX 3 +#define MSM8976_VDDMX_AO 4 +#define MSM8976_VDDMX_VFL 5 + +/* MSM8994 Power Domain Indexes */ +#define MSM8994_VDDCX 0 +#define MSM8994_VDDCX_AO 1 +#define MSM8994_VDDCX_VFC 2 +#define MSM8994_VDDMX 3 +#define MSM8994_VDDMX_AO 4 +#define MSM8994_VDDGFX 5 +#define MSM8994_VDDGFX_VFC 6 + +/* MSM8996 Power Domain Indexes */ +#define MSM8996_VDDCX 0 +#define MSM8996_VDDCX_AO 1 +#define MSM8996_VDDCX_VFC 2 +#define MSM8996_VDDMX 3 +#define MSM8996_VDDMX_AO 4 +#define MSM8996_VDDSSCX 5 +#define MSM8996_VDDSSCX_VFC 6 + +/* MSM8998 Power Domain Indexes */ +#define MSM8998_VDDCX 0 +#define MSM8998_VDDCX_AO 1 +#define MSM8998_VDDCX_VFL 2 +#define MSM8998_VDDMX 3 +#define MSM8998_VDDMX_AO 4 +#define MSM8998_VDDMX_VFL 5 +#define MSM8998_SSCCX 6 +#define MSM8998_SSCCX_VFL 7 +#define MSM8998_SSCMX 8 +#define MSM8998_SSCMX_VFL 9 + +/* QCS404 Power Domains */ +#define QCS404_VDDMX 0 +#define QCS404_VDDMX_AO 1 +#define QCS404_VDDMX_VFL 2 +#define QCS404_LPICX 3 +#define QCS404_LPICX_VFL 4 +#define QCS404_LPIMX 5 +#define QCS404_LPIMX_VFL 6 + +/* SDM660 Power Domains */ +#define SDM660_VDDCX 0 +#define SDM660_VDDCX_AO 1 +#define SDM660_VDDCX_VFL 2 +#define SDM660_VDDMX 3 +#define SDM660_VDDMX_AO 4 +#define SDM660_VDDMX_VFL 5 +#define SDM660_SSCCX 6 +#define SDM660_SSCCX_VFL 7 +#define SDM660_SSCMX 8 +#define SDM660_SSCMX_VFL 9 + +/* SM6115 Power Domains */ +#define SM6115_VDDCX 0 +#define SM6115_VDDCX_AO 1 +#define SM6115_VDDCX_VFL 2 +#define SM6115_VDDMX 3 +#define SM6115_VDDMX_AO 4 +#define SM6115_VDDMX_VFL 5 +#define SM6115_VDD_LPI_CX 6 +#define SM6115_VDD_LPI_MX 7 + +/* SM6125 Power Domains */ +#define SM6125_VDDCX 0 +#define SM6125_VDDCX_AO 1 +#define SM6125_VDDCX_VFL 2 +#define SM6125_VDDMX 3 +#define SM6125_VDDMX_AO 4 +#define SM6125_VDDMX_VFL 5 + +/* QCM2290 Power Domains */ +#define QCM2290_VDDCX 0 +#define QCM2290_VDDCX_AO 1 +#define QCM2290_VDDCX_VFL 2 +#define QCM2290_VDDMX 3 +#define QCM2290_VDDMX_AO 4 +#define QCM2290_VDDMX_VFL 5 +#define QCM2290_VDD_LPI_CX 6 +#define QCM2290_VDD_LPI_MX 7 + +/* RPM SMD Power Domain performance levels */ +#define RPM_SMD_LEVEL_RETENTION 16 +#define RPM_SMD_LEVEL_RETENTION_PLUS 32 +#define RPM_SMD_LEVEL_MIN_SVS 48 +#define RPM_SMD_LEVEL_LOW_SVS 64 +#define RPM_SMD_LEVEL_SVS 128 +#define RPM_SMD_LEVEL_SVS_PLUS 192 +#define RPM_SMD_LEVEL_NOM 256 +#define RPM_SMD_LEVEL_NOM_PLUS 320 +#define RPM_SMD_LEVEL_TURBO 384 +#define RPM_SMD_LEVEL_TURBO_NO_CPR 416 +#define RPM_SMD_LEVEL_TURBO_HIGH 448 +#define RPM_SMD_LEVEL_BINNING 512 + +#endif diff --git a/include/dt-bindings/regulator/qcom,rpmh-regulator.h b/include/dt-bindings/regulator/qcom,rpmh-regulator.h new file mode 100644 index 0000000000..86713dcf9e --- /dev/null +++ b/include/dt-bindings/regulator/qcom,rpmh-regulator.h @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* Copyright (c) 2018, The Linux Foundation. All rights reserved. */ + +#ifndef __QCOM_RPMH_REGULATOR_H +#define __QCOM_RPMH_REGULATOR_H + +/* + * These mode constants may be used to specify modes for various RPMh regulator + * device tree properties (e.g. regulator-initial-mode). Each type of regulator + * supports a subset of the possible modes. + * + * %RPMH_REGULATOR_MODE_RET: Retention mode in which only an extremely small + * load current is allowed. This mode is supported + * by LDO and SMPS type regulators. + * %RPMH_REGULATOR_MODE_LPM: Low power mode in which a small load current is + * allowed. This mode corresponds to PFM for SMPS + * and BOB type regulators. This mode is supported + * by LDO, HFSMPS, BOB, and PMIC4 FTSMPS type + * regulators. + * %RPMH_REGULATOR_MODE_AUTO: Auto mode in which the regulator hardware + * automatically switches between LPM and HPM based + * upon the real-time load current. This mode is + * supported by HFSMPS, BOB, and PMIC4 FTSMPS type + * regulators. + * %RPMH_REGULATOR_MODE_HPM: High power mode in which the full rated current + * of the regulator is allowed. This mode + * corresponds to PWM for SMPS and BOB type + * regulators. This mode is supported by all types + * of regulators. + */ +#define RPMH_REGULATOR_MODE_RET 0 +#define RPMH_REGULATOR_MODE_LPM 1 +#define RPMH_REGULATOR_MODE_AUTO 2 +#define RPMH_REGULATOR_MODE_HPM 3 + +#endif diff --git a/include/dt-bindings/soc/qcom,rpmh-rsc.h b/include/dt-bindings/soc/qcom,rpmh-rsc.h new file mode 100644 index 0000000000..868f998ea9 --- /dev/null +++ b/include/dt-bindings/soc/qcom,rpmh-rsc.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2016-2018, The Linux Foundation. All rights reserved. + */ + +#ifndef __DT_QCOM_RPMH_RSC_H__ +#define __DT_QCOM_RPMH_RSC_H__ + +#define SLEEP_TCS 0 +#define WAKE_TCS 1 +#define ACTIVE_TCS 2 +#define CONTROL_TCS 3 + +#endif /* __DT_QCOM_RPMH_RSC_H__ */
On 29/02/2024 15:21, Volodymyr Babchuk wrote:
Add device tree bindings and actual device trees for SM8150 SoC and SA8155P-ADP board. Those files were imported from Linux kernel 6.8-rc5 as is. In this configuration they will not work with U-Boot for couple reasons:
Aren't you now duplicating dts/upstream/qcom?
https://lore.kernel.org/all/20240222093607.3085545-1-sumit.garg@linaro.org/
Best regards, Krzysztof
Add clock, reset and power domain driver for SM8150. Driver code is based on the similar U-Boot drivers. All constants are taken from the corresponding Linux driver.
This driver supports clock rate setting only for the debug UART and RGMII/Ethernet modules, because this is all I can test right now.
Signed-off-by: Volodymyr Babchuk volodymyr_babchuk@epam.com ---
drivers/clk/qcom/Kconfig | 8 ++ drivers/clk/qcom/Makefile | 1 + drivers/clk/qcom/clock-qcom.h | 1 + drivers/clk/qcom/clock-sm8150.c | 234 ++++++++++++++++++++++++++++++++ 4 files changed, 244 insertions(+) create mode 100644 drivers/clk/qcom/clock-sm8150.c
diff --git a/drivers/clk/qcom/Kconfig b/drivers/clk/qcom/Kconfig index 0df0d1881a..18ccf6a45e 100644 --- a/drivers/clk/qcom/Kconfig +++ b/drivers/clk/qcom/Kconfig @@ -47,6 +47,14 @@ config CLK_QCOM_SDM845 on the Snapdragon 845 SoC. This driver supports the clocks and resets exposed by the GCC hardware block.
+config CLK_QCOM_SM8150 + bool "Qualcomm SM8150 GCC" + select CLK_QCOM + help + Say Y here to enable support for the Global Clock Controller + on the Snapdragon 8150 SoC. This driver supports the clocks + and resets exposed by the GCC hardware block. + endmenu
endif diff --git a/drivers/clk/qcom/Makefile b/drivers/clk/qcom/Makefile index cb179fdac5..12c09ba19e 100644 --- a/drivers/clk/qcom/Makefile +++ b/drivers/clk/qcom/Makefile @@ -8,3 +8,4 @@ obj-$(CONFIG_CLK_QCOM_APQ8016) += clock-apq8016.o obj-$(CONFIG_CLK_QCOM_APQ8096) += clock-apq8096.o obj-$(CONFIG_CLK_QCOM_IPQ4019) += clock-ipq4019.o obj-$(CONFIG_CLK_QCOM_QCS404) += clock-qcs404.o +obj-$(CONFIG_CLK_QCOM_SM8150) += clock-sm8150.o diff --git a/drivers/clk/qcom/clock-qcom.h b/drivers/clk/qcom/clock-qcom.h index 12a1eaec2b..41107df216 100644 --- a/drivers/clk/qcom/clock-qcom.h +++ b/drivers/clk/qcom/clock-qcom.h @@ -9,6 +9,7 @@
#define CFG_CLK_SRC_CXO (0 << 8) #define CFG_CLK_SRC_GPLL0 (1 << 8) +#define CFG_CLK_SRC_GPLL7_MAIN (3 << 8) #define CFG_CLK_SRC_GPLL0_EVEN (6 << 8) #define CFG_CLK_SRC_MASK (7 << 8)
diff --git a/drivers/clk/qcom/clock-sm8150.c b/drivers/clk/qcom/clock-sm8150.c new file mode 100644 index 0000000000..e23dbccdd3 --- /dev/null +++ b/drivers/clk/qcom/clock-sm8150.c @@ -0,0 +1,234 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Clock drivers for Qualcomm SM8150 + * + * Volodymyr Babchuk volodymyr_babchuk@epam.com + * Copyright (c) 2024 EPAM Systems. + * + * Based on U-Boot driver for SDM845. Constants are taken from the Linux driver. + */ + +#include <clk-uclass.h> +#include <dm.h> +#include <linux/delay.h> +#include <errno.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <dt-bindings/clock/qcom,gcc-sm8150.h> + +#include "clock-qcom.h" + +static struct pll_vote_clk gpll7_vote_clk = { + .status = 0x1a000, + .status_bit = BIT(31), + .ena_vote = 0x52000, + .vote_bit = BIT(7), +}; + +static const struct freq_tbl ftbl_gcc_qupv3_wrap0_s0_clk_src[] = { + F(7372800, CFG_CLK_SRC_GPLL0_EVEN, 1, 384, 15625), + F(14745600, CFG_CLK_SRC_GPLL0_EVEN, 1, 768, 15625), + F(19200000, CFG_CLK_SRC_CXO, 1, 0, 0), + F(29491200, CFG_CLK_SRC_GPLL0_EVEN, 1, 1536, 15625), + F(32000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 8, 75), + F(48000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 4, 25), + F(64000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 16, 75), + F(80000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 4, 15), + F(96000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 8, 25), + F(100000000, CFG_CLK_SRC_GPLL0_EVEN, 3, 0, 0), + F(102400000, CFG_CLK_SRC_GPLL0_EVEN, 1, 128, 375), + F(112000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 28, 75), + F(117964800, CFG_CLK_SRC_GPLL0_EVEN, 1, 6144, 15625), + F(120000000, CFG_CLK_SRC_GPLL0_EVEN, 2.5, 0, 0), + F(128000000, CFG_CLK_SRC_GPLL0, 1, 16, 75), + { } +}; + +static const struct freq_tbl ftbl_gcc_emac_rgmii_clk_src[] = { + F(2500000, CFG_CLK_SRC_CXO, 1, 25, 192), + F(5000000, CFG_CLK_SRC_CXO, 1, 25, 96), + F(19200000, CFG_CLK_SRC_CXO, 1, 0, 0), + F(25000000, CFG_CLK_SRC_GPLL0_EVEN, 12, 0, 0), + F(50000000, CFG_CLK_SRC_GPLL0_EVEN, 6, 0, 0), + F(125000000, CFG_CLK_SRC_GPLL7_MAIN, 4, 0, 0), + F(250000000, CFG_CLK_SRC_GPLL7_MAIN, 2, 0, 0), + { } +}; + +static const struct bcr_regs uart2_regs = { + .cfg_rcgr = 0x1814C, + .cmd_rcgr = 0x18148, + .M = 0x18150, + .N = 0x18154, + .D = 0x18158, +}; + +static const struct bcr_regs rgmii_regs = { + .cfg_rcgr = 0x6020, + .cmd_rcgr = 0x601C, + .M = 0x6024, + .N = 0x6028, + .D = 0x602C, +}; + +static ulong sm8150_clk_set_rate(struct clk *clk, ulong rate) +{ + struct msm_clk_priv *priv = dev_get_priv(clk->dev); + const struct freq_tbl *freq; + + switch (clk->id) { + case GCC_QUPV3_WRAP1_S4_CLK: /* UART2 aka debug-uart */ + freq = qcom_find_freq(ftbl_gcc_qupv3_wrap0_s0_clk_src, rate); + clk_rcg_set_rate_mnd(priv->base, &uart2_regs, + freq->pre_div, freq->m, freq->n, freq->src, 16); + return freq->freq; + case GCC_EMAC_RGMII_CLK: + freq = qcom_find_freq(ftbl_gcc_emac_rgmii_clk_src, rate); + clk_rcg_set_rate_mnd(priv->base, &rgmii_regs, + freq->pre_div, freq->m, freq->n, freq->src, 8); + + return freq->freq; + default: + pr_err("Don't know how to set clk id %ld\n", clk->id); + return -ENODEV; + } +} + +static const struct gate_clk sm8150_clks[] = { + GATE_CLK(GCC_QUPV3_WRAP0_S0_CLK, 0x5200c, 0x00000400), + GATE_CLK(GCC_QUPV3_WRAP0_S1_CLK, 0x5200c, 0x00000800), + GATE_CLK(GCC_QUPV3_WRAP0_S2_CLK, 0x5200c, 0x00001000), + GATE_CLK(GCC_QUPV3_WRAP0_S3_CLK, 0x5200c, 0x00002000), + GATE_CLK(GCC_QUPV3_WRAP0_S4_CLK, 0x5200c, 0x00004000), + GATE_CLK(GCC_QUPV3_WRAP0_S5_CLK, 0x5200c, 0x00008000), + GATE_CLK(GCC_QUPV3_WRAP1_S0_CLK, 0x5200c, 0x00400000), + GATE_CLK(GCC_QUPV3_WRAP1_S1_CLK, 0x5200c, 0x00800000), + GATE_CLK(GCC_QUPV3_WRAP1_S3_CLK, 0x5200c, 0x02000000), + GATE_CLK(GCC_QUPV3_WRAP1_S4_CLK, 0x5200c, 0x04000000), + GATE_CLK(GCC_QUPV3_WRAP1_S5_CLK, 0x5200c, 0x08000000), + GATE_CLK(GCC_QUPV3_WRAP_0_M_AHB_CLK, 0x5200c, 0x00000040), + GATE_CLK(GCC_QUPV3_WRAP_0_S_AHB_CLK, 0x5200c, 0x00000080), + GATE_CLK(GCC_QUPV3_WRAP_1_M_AHB_CLK, 0x5200c, 0x00100000), + GATE_CLK(GCC_QUPV3_WRAP_1_S_AHB_CLK, 0x5200c, 0x00200000), + GATE_CLK(GCC_SDCC2_AHB_CLK, 0x14008, 0x00000001), + GATE_CLK(GCC_SDCC2_APPS_CLK, 0x14004, 0x00000001), + GATE_CLK(GCC_SDCC4_AHB_CLK, 0x16008, 0x00000001), + GATE_CLK(GCC_SDCC4_APPS_CLK, 0x16004, 0x00000001), + GATE_CLK(GCC_UFS_CARD_AHB_CLK, 0x75010, 0x00000001), + GATE_CLK(GCC_UFS_CARD_AXI_CLK, 0x7500c, 0x00000001), + GATE_CLK(GCC_UFS_CARD_CLKREF_CLK, 0x8c004, 0x00000001), + GATE_CLK(GCC_UFS_CARD_ICE_CORE_CLK, 0x75058, 0x00000001), + GATE_CLK(GCC_UFS_CARD_PHY_AUX_CLK, 0x7508c, 0x00000001), + GATE_CLK(GCC_UFS_CARD_RX_SYMBOL_0_CLK, 0x75018, 0x00000001), + GATE_CLK(GCC_UFS_CARD_RX_SYMBOL_1_CLK, 0x750a8, 0x00000001), + GATE_CLK(GCC_UFS_CARD_TX_SYMBOL_0_CLK, 0x75014, 0x00000001), + GATE_CLK(GCC_UFS_CARD_UNIPRO_CORE_CLK, 0x75054, 0x00000001), + GATE_CLK(GCC_UFS_MEM_CLKREF_CLK, 0x8c000, 0x00000001), + GATE_CLK(GCC_UFS_PHY_AHB_CLK, 0x77010, 0x00000001), + GATE_CLK(GCC_UFS_PHY_AXI_CLK, 0x7700c, 0x00000001), + GATE_CLK(GCC_UFS_PHY_ICE_CORE_CLK, 0x77058, 0x00000001), + GATE_CLK(GCC_UFS_PHY_PHY_AUX_CLK, 0x7708c, 0x00000001), + GATE_CLK(GCC_UFS_PHY_RX_SYMBOL_0_CLK, 0x77018, 0x00000001), + GATE_CLK(GCC_UFS_PHY_RX_SYMBOL_1_CLK, 0x770a8, 0x00000001), + GATE_CLK(GCC_UFS_PHY_TX_SYMBOL_0_CLK, 0x77014, 0x00000001), + GATE_CLK(GCC_UFS_PHY_UNIPRO_CORE_CLK, 0x77054, 0x00000001), + GATE_CLK(GCC_USB30_PRIM_MASTER_CLK, 0x0f00c, 0x00000001), + GATE_CLK(GCC_USB30_PRIM_MOCK_UTMI_CLK, 0x0f014, 0x00000001), + GATE_CLK(GCC_USB30_PRIM_SLEEP_CLK, 0x0f010, 0x00000001), + GATE_CLK(GCC_USB30_SEC_MASTER_CLK, 0x1000c, 0x00000001), + GATE_CLK(GCC_USB30_SEC_MOCK_UTMI_CLK, 0x10014, 0x00000001), + GATE_CLK(GCC_USB30_SEC_SLEEP_CLK, 0x10010, 0x00000001), + GATE_CLK(GCC_USB3_PRIM_CLKREF_CLK, 0x8c008, 0x00000001), + GATE_CLK(GCC_USB3_PRIM_PHY_AUX_CLK, 0x0f04c, 0x00000001), + GATE_CLK(GCC_USB3_PRIM_PHY_COM_AUX_CLK, 0x0f050, 0x00000001), + GATE_CLK(GCC_USB3_PRIM_PHY_PIPE_CLK, 0x0f054, 0x00000001), + GATE_CLK(GCC_USB3_SEC_CLKREF_CLK, 0x8c028, 0x00000001), + GATE_CLK(GCC_USB3_SEC_PHY_AUX_CLK, 0x1004c, 0x00000001), + GATE_CLK(GCC_USB3_SEC_PHY_PIPE_CLK, 0x10054, 0x00000001), + GATE_CLK(GCC_USB3_SEC_PHY_COM_AUX_CLK, 0x10050, 0x00000001), + GATE_CLK(GCC_EMAC_AXI_CLK, 0x06010, 0x00000001), + GATE_CLK(GCC_EMAC_SLV_AHB_CLK, 0x06014, 0x00000001), + GATE_CLK(GCC_EMAC_PTP_CLK, 0x06034, 0x00000001), + GATE_CLK(GCC_EMAC_RGMII_CLK, 0x06018, 0x00000001), +}; + +static int sm8150_clk_enable(struct clk *clk) +{ + struct msm_clk_priv *priv = dev_get_priv(clk->dev); + + clk_enable_gpll0(priv->base, &gpll7_vote_clk); + qcom_gate_clk_en(priv, clk->id); + + return 0; +} + +static const struct qcom_reset_map sm8150_gcc_resets[] = { + [GCC_EMAC_BCR] = { 0x6000 }, + [GCC_GPU_BCR] = { 0x71000 }, + [GCC_MMSS_BCR] = { 0xb000 }, + [GCC_NPU_BCR] = { 0x4d000 }, + [GCC_PCIE_0_BCR] = { 0x6b000 }, + [GCC_PCIE_0_PHY_BCR] = { 0x6c01c }, + [GCC_PCIE_1_BCR] = { 0x8d000 }, + [GCC_PCIE_1_PHY_BCR] = { 0x8e01c }, + [GCC_PCIE_PHY_BCR] = { 0x6f000 }, + [GCC_PDM_BCR] = { 0x33000 }, + [GCC_PRNG_BCR] = { 0x34000 }, + [GCC_QSPI_BCR] = { 0x24008 }, + [GCC_QUPV3_WRAPPER_0_BCR] = { 0x17000 }, + [GCC_QUPV3_WRAPPER_1_BCR] = { 0x18000 }, + [GCC_QUPV3_WRAPPER_2_BCR] = { 0x1e000 }, + [GCC_QUSB2PHY_PRIM_BCR] = { 0x12000 }, + [GCC_QUSB2PHY_SEC_BCR] = { 0x12004 }, + [GCC_USB3_PHY_PRIM_BCR] = { 0x50000 }, + [GCC_USB3_DP_PHY_PRIM_BCR] = { 0x50008 }, + [GCC_USB3_PHY_SEC_BCR] = { 0x5000c }, + [GCC_USB3PHY_PHY_SEC_BCR] = { 0x50010 }, + [GCC_SDCC2_BCR] = { 0x14000 }, + [GCC_SDCC4_BCR] = { 0x16000 }, + [GCC_TSIF_BCR] = { 0x36000 }, + [GCC_UFS_CARD_BCR] = { 0x75000 }, + [GCC_UFS_PHY_BCR] = { 0x77000 }, + [GCC_USB30_PRIM_BCR] = { 0xf000 }, + [GCC_USB30_SEC_BCR] = { 0x10000 }, + [GCC_USB_PHY_CFG_AHB2PHY_BCR] = { 0x6a000 }, +}; + +static const struct qcom_power_map sm8150_gcc_power_domains[] = { + [EMAC_GDSC] = { 0x6004 }, + [PCIE_0_GDSC] = { 0x6b004 }, + [PCIE_1_GDSC] = { 0x8d004 }, + [UFS_CARD_GDSC] = { 0x75004 }, + [UFS_PHY_GDSC] = { 0x7704 }, + [USB30_PRIM_GDSC] = { 0x6004 }, + [USB30_SEC_GDSC] = { 0x10004 }, +}; + + +static struct msm_clk_data sm8150_clk_data = { + .resets = sm8150_gcc_resets, + .num_resets = ARRAY_SIZE(sm8150_gcc_resets), + .clks = sm8150_clks, + .num_clks = ARRAY_SIZE(sm8150_clks), + .power_domains = sm8150_gcc_power_domains, + .num_power_domains = ARRAY_SIZE(sm8150_gcc_power_domains), + + .enable = sm8150_clk_enable, + .set_rate = sm8150_clk_set_rate, +}; + +static const struct udevice_id gcc_sm8150_of_match[] = { + { + .compatible = "qcom,gcc-sm8150", + .data = (ulong)&sm8150_clk_data, + }, + { } +}; + +U_BOOT_DRIVER(gcc_sm8150) = { + .name = "gcc_sm8150", + .id = UCLASS_NOP, + .of_match = gcc_sm8150_of_match, + .bind = qcom_cc_bind, + .flags = DM_FLAG_PRE_RELOC, +};
- bool "Qualcomm SM8150 GCC"
- select CLK_QCOM
- help
endmenu
Please follow the existing scheme and remove the _MAIN suffix. I'd also be fine with converting all of these definitions to follow how the Linux drivers name them.
- Clock drivers for Qualcomm SM8150
- Volodymyr Babchuk volodymyr_babchuk@epam.com
- Copyright (c) 2024 EPAM Systems.
- Based on U-Boot driver for SDM845. Constants are taken from the Linux driver.
This header is unused
- .status = 0x1a000,
- .status_bit = BIT(31),
- .ena_vote = 0x52000,
- .vote_bit = BIT(7),
- F(7372800, CFG_CLK_SRC_GPLL0_EVEN, 1, 384, 15625),
- F(14745600, CFG_CLK_SRC_GPLL0_EVEN, 1, 768, 15625),
- F(19200000, CFG_CLK_SRC_CXO, 1, 0, 0),
- F(29491200, CFG_CLK_SRC_GPLL0_EVEN, 1, 1536, 15625),
- F(32000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 8, 75),
- F(48000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 4, 25),
- F(64000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 16, 75),
- F(80000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 4, 15),
- F(96000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 8, 25),
- F(100000000, CFG_CLK_SRC_GPLL0_EVEN, 3, 0, 0),
- F(102400000, CFG_CLK_SRC_GPLL0_EVEN, 1, 128, 375),
- F(112000000, CFG_CLK_SRC_GPLL0_EVEN, 1, 28, 75),
- F(117964800, CFG_CLK_SRC_GPLL0_EVEN, 1, 6144, 15625),
- F(120000000, CFG_CLK_SRC_GPLL0_EVEN, 2.5, 0, 0),
- F(128000000, CFG_CLK_SRC_GPLL0, 1, 16, 75),
- F(2500000, CFG_CLK_SRC_CXO, 1, 25, 192),
- F(5000000, CFG_CLK_SRC_CXO, 1, 25, 96),
- F(25000000, CFG_CLK_SRC_GPLL0_EVEN, 12, 0, 0),
- F(50000000, CFG_CLK_SRC_GPLL0_EVEN, 6, 0, 0),
- F(125000000, CFG_CLK_SRC_GPLL7_MAIN, 4, 0, 0),
- F(250000000, CFG_CLK_SRC_GPLL7_MAIN, 2, 0, 0),
- .cfg_rcgr = 0x1814C,
- .cmd_rcgr = 0x18148,
- .M = 0x18150,
- .N = 0x18154,
- .D = 0x18158,
- .cfg_rcgr = 0x6020,
- .cmd_rcgr = 0x601C,
- .M = 0x6024,
- .N = 0x6028,
- .D = 0x602C,
- struct msm_clk_priv *priv = dev_get_priv(clk->dev);
- const struct freq_tbl *freq;
- switch (clk->id) {
- case GCC_QUPV3_WRAP1_S4_CLK: /* UART2 aka debug-uart */
return freq->freq;
- case GCC_EMAC_RGMII_CLK:
return freq->freq;
- default:
return -ENODEV;
I think -EINVAL would be a better fit here.
- GATE_CLK(GCC_QUPV3_WRAP0_S0_CLK, 0x5200c, 0x00000400),
- GATE_CLK(GCC_QUPV3_WRAP0_S1_CLK, 0x5200c, 0x00000800),
- GATE_CLK(GCC_QUPV3_WRAP0_S2_CLK, 0x5200c, 0x00001000),
- GATE_CLK(GCC_QUPV3_WRAP0_S3_CLK, 0x5200c, 0x00002000),
- GATE_CLK(GCC_QUPV3_WRAP0_S4_CLK, 0x5200c, 0x00004000),
- GATE_CLK(GCC_QUPV3_WRAP0_S5_CLK, 0x5200c, 0x00008000),
- GATE_CLK(GCC_QUPV3_WRAP1_S0_CLK, 0x5200c, 0x00400000),
- GATE_CLK(GCC_QUPV3_WRAP1_S1_CLK, 0x5200c, 0x00800000),
- GATE_CLK(GCC_QUPV3_WRAP1_S3_CLK, 0x5200c, 0x02000000),
- GATE_CLK(GCC_QUPV3_WRAP1_S4_CLK, 0x5200c, 0x04000000),
- GATE_CLK(GCC_QUPV3_WRAP1_S5_CLK, 0x5200c, 0x08000000),
- GATE_CLK(GCC_QUPV3_WRAP_0_M_AHB_CLK, 0x5200c, 0x00000040),
- GATE_CLK(GCC_QUPV3_WRAP_0_S_AHB_CLK, 0x5200c, 0x00000080),
- GATE_CLK(GCC_QUPV3_WRAP_1_M_AHB_CLK, 0x5200c, 0x00100000),
- GATE_CLK(GCC_QUPV3_WRAP_1_S_AHB_CLK, 0x5200c, 0x00200000),
- GATE_CLK(GCC_SDCC2_AHB_CLK, 0x14008, 0x00000001),
- GATE_CLK(GCC_SDCC2_APPS_CLK, 0x14004, 0x00000001),
- GATE_CLK(GCC_SDCC4_AHB_CLK, 0x16008, 0x00000001),
- GATE_CLK(GCC_SDCC4_APPS_CLK, 0x16004, 0x00000001),
- GATE_CLK(GCC_UFS_CARD_AHB_CLK, 0x75010, 0x00000001),
- GATE_CLK(GCC_UFS_CARD_AXI_CLK, 0x7500c, 0x00000001),
- GATE_CLK(GCC_UFS_CARD_CLKREF_CLK, 0x8c004, 0x00000001),
- GATE_CLK(GCC_UFS_CARD_ICE_CORE_CLK, 0x75058, 0x00000001),
- GATE_CLK(GCC_UFS_CARD_PHY_AUX_CLK, 0x7508c, 0x00000001),
- GATE_CLK(GCC_UFS_CARD_RX_SYMBOL_0_CLK, 0x75018, 0x00000001),
- GATE_CLK(GCC_UFS_CARD_RX_SYMBOL_1_CLK, 0x750a8, 0x00000001),
- GATE_CLK(GCC_UFS_CARD_TX_SYMBOL_0_CLK, 0x75014, 0x00000001),
- GATE_CLK(GCC_UFS_CARD_UNIPRO_CORE_CLK, 0x75054, 0x00000001),
- GATE_CLK(GCC_UFS_MEM_CLKREF_CLK, 0x8c000, 0x00000001),
- GATE_CLK(GCC_UFS_PHY_AHB_CLK, 0x77010, 0x00000001),
- GATE_CLK(GCC_UFS_PHY_AXI_CLK, 0x7700c, 0x00000001),
- GATE_CLK(GCC_UFS_PHY_ICE_CORE_CLK, 0x77058, 0x00000001),
- GATE_CLK(GCC_UFS_PHY_PHY_AUX_CLK, 0x7708c, 0x00000001),
- GATE_CLK(GCC_UFS_PHY_RX_SYMBOL_0_CLK, 0x77018, 0x00000001),
- GATE_CLK(GCC_UFS_PHY_RX_SYMBOL_1_CLK, 0x770a8, 0x00000001),
- GATE_CLK(GCC_UFS_PHY_TX_SYMBOL_0_CLK, 0x77014, 0x00000001),
- GATE_CLK(GCC_UFS_PHY_UNIPRO_CORE_CLK, 0x77054, 0x00000001),
- GATE_CLK(GCC_USB30_PRIM_MASTER_CLK, 0x0f00c, 0x00000001),
- GATE_CLK(GCC_USB30_PRIM_MOCK_UTMI_CLK, 0x0f014, 0x00000001),
- GATE_CLK(GCC_USB30_PRIM_SLEEP_CLK, 0x0f010, 0x00000001),
- GATE_CLK(GCC_USB30_SEC_MASTER_CLK, 0x1000c, 0x00000001),
- GATE_CLK(GCC_USB30_SEC_MOCK_UTMI_CLK, 0x10014, 0x00000001),
- GATE_CLK(GCC_USB30_SEC_SLEEP_CLK, 0x10010, 0x00000001),
- GATE_CLK(GCC_USB3_PRIM_CLKREF_CLK, 0x8c008, 0x00000001),
- GATE_CLK(GCC_USB3_PRIM_PHY_AUX_CLK, 0x0f04c, 0x00000001),
- GATE_CLK(GCC_USB3_PRIM_PHY_COM_AUX_CLK, 0x0f050, 0x00000001),
- GATE_CLK(GCC_USB3_PRIM_PHY_PIPE_CLK, 0x0f054, 0x00000001),
- GATE_CLK(GCC_USB3_SEC_CLKREF_CLK, 0x8c028, 0x00000001),
- GATE_CLK(GCC_USB3_SEC_PHY_AUX_CLK, 0x1004c, 0x00000001),
- GATE_CLK(GCC_USB3_SEC_PHY_PIPE_CLK, 0x10054, 0x00000001),
- GATE_CLK(GCC_USB3_SEC_PHY_COM_AUX_CLK, 0x10050, 0x00000001),
- GATE_CLK(GCC_EMAC_AXI_CLK, 0x06010, 0x00000001),
- GATE_CLK(GCC_EMAC_SLV_AHB_CLK, 0x06014, 0x00000001),
- GATE_CLK(GCC_EMAC_PTP_CLK, 0x06034, 0x00000001),
- GATE_CLK(GCC_EMAC_RGMII_CLK, 0x06018, 0x00000001),
- clk_enable_gpll0(priv->base, &gpll7_vote_clk);
This will write to the GPLL for every single clock, I think you're missing a switch case block here.
- qcom_gate_clk_en(priv, clk->id);
- [GCC_EMAC_BCR] = { 0x6000 },
- [GCC_GPU_BCR] = { 0x71000 },
- [GCC_MMSS_BCR] = { 0xb000 },
- [GCC_NPU_BCR] = { 0x4d000 },
- [GCC_PCIE_0_BCR] = { 0x6b000 },
- [GCC_PCIE_0_PHY_BCR] = { 0x6c01c },
- [GCC_PCIE_1_BCR] = { 0x8d000 },
- [GCC_PCIE_1_PHY_BCR] = { 0x8e01c },
- [GCC_PCIE_PHY_BCR] = { 0x6f000 },
- [GCC_PDM_BCR] = { 0x33000 },
- [GCC_PRNG_BCR] = { 0x34000 },
- [GCC_QSPI_BCR] = { 0x24008 },
- [GCC_QUPV3_WRAPPER_0_BCR] = { 0x17000 },
- [GCC_QUPV3_WRAPPER_1_BCR] = { 0x18000 },
- [GCC_QUPV3_WRAPPER_2_BCR] = { 0x1e000 },
- [GCC_QUSB2PHY_PRIM_BCR] = { 0x12000 },
- [GCC_QUSB2PHY_SEC_BCR] = { 0x12004 },
- [GCC_USB3_PHY_PRIM_BCR] = { 0x50000 },
- [GCC_USB3_DP_PHY_PRIM_BCR] = { 0x50008 },
- [GCC_USB3_PHY_SEC_BCR] = { 0x5000c },
- [GCC_USB3PHY_PHY_SEC_BCR] = { 0x50010 },
- [GCC_SDCC2_BCR] = { 0x14000 },
- [GCC_SDCC4_BCR] = { 0x16000 },
- [GCC_TSIF_BCR] = { 0x36000 },
- [GCC_UFS_CARD_BCR] = { 0x75000 },
- [GCC_UFS_PHY_BCR] = { 0x77000 },
- [GCC_USB30_PRIM_BCR] = { 0xf000 },
- [GCC_USB30_SEC_BCR] = { 0x10000 },
- [GCC_USB_PHY_CFG_AHB2PHY_BCR] = { 0x6a000 },
This is really nice! Certainly better than my approach [1].
Please reorder the patches so that the power domain driver is added before this so we don't break future bisects.
- [EMAC_GDSC] = { 0x6004 },
- [PCIE_0_GDSC] = { 0x6b004 },
- [PCIE_1_GDSC] = { 0x8d004 },
- [UFS_CARD_GDSC] = { 0x75004 },
- [UFS_PHY_GDSC] = { 0x7704 },
- [USB30_PRIM_GDSC] = { 0x6004 },
- [USB30_SEC_GDSC] = { 0x10004 },
- .resets = sm8150_gcc_resets,
- .num_resets = ARRAY_SIZE(sm8150_gcc_resets),
- .clks = sm8150_clks,
- .num_clks = ARRAY_SIZE(sm8150_clks),
- .power_domains = sm8150_gcc_power_domains,
- .num_power_domains = ARRAY_SIZE(sm8150_gcc_power_domains),
- .enable = sm8150_clk_enable,
- .set_rate = sm8150_clk_set_rate,
- .name = "gcc_sm8150",
- .id = UCLASS_NOP,
- .of_match = gcc_sm8150_of_match,
- .bind = qcom_cc_bind,
- .flags = DM_FLAG_PRE_RELOC,
Just in case it's useful to you, I have some work in progress patches for dumping the clock configuration, I hope to upstream these eventually but in the mean time you can find them here:
https://git.codelinaro.org/linaro/qcomlt/u-boot/-/commit/af651f236f221cc2122...
[1]: https://lore.kernel.org/u-boot/20240131-b4-qcom-livetree-v1-5-4071c0787db0@l...
Hi Caleb,
Caleb Connolly caleb.connolly@linaro.org writes:
- select CLK_QCOM
- help
endmenu
Ah, yes, planned to do this, but looks like lost it when created a final version of the patch.
This should be done in the separate patch, I think.
Yes, you are right.
power domain driver is added in the previous patch: "[PATCH 4/8] clk: qcom: add support for power domains uclass"
- .id = UCLASS_NOP,
This is what bothers me now. Looks like I jumped in the middle of your USB series and Sumit's Qulacom device tree binding series. I don't want to interfere with the ongoing work, so probably I postpone posting my v2 unless at least Sumit's series are taken into the mainline. On other hand, there are couple of patches that are not directly related to the SM8155P-ADP, like my fix to the clock driver or already mentioned "clk: qcom: add support for power domains uclass", which you can reuse. So I can post them separately or you can include them into your series if you want. What is your opinion?
Ah, my mistake!
The big conflict is really just the board support stuff and DTS. The other patches would definitely be good to have.
Could you rebase this series on top of qcom-next [1]? The big series has gone in now (and should be in U-Boot next shortly) so we shouldn't have to delay yours.
Your last patch introducing the board support will conflict, but you don't have any heavily board specific features so it should be pretty easy:
* Drop init_sm8150.c and sysmap-sm8150.c (everything they do is handled generically in board.c) * Drop your changes to mach-snapdragon/Kconfig * Delete board/qualcomm/sa8155p-adp/Kconfig * Replace CONFIG_TARGET_SA8155P_ADP=y with CONFIG_SYS_BOARD="sa8155p-adp" in your defconfig * Set CONFIG_SYS_CONFIG_NAME="sa8155p_adp" (or rename the config file to use a '-' instead).
It's now possible to use pre-processor directives from defconfigs, so you could also rework your defconfig to #include "qcom_defconfig" and that way only have to define your board specific options, but I guess there isn't much room in the hyp partition so you might not want all the bells and whistles - totally up to you.
If you could split this into series, one with your fixes and drivers, and another adding the DTS and board changes I think that would be fine.
Regarding the DT stuff, you probably drop your sm8150 DTS patch and instead select OF_UPSTREAM for ARCH_SNAPDRAGON, I'll likely send a patch for this soon.
[1]: https://source.denx.de/u-boot/custodians/u-boot-snapdragon
This patch is the preparation for SM8150 support. This new SoC depending on the particular pin can have different numbers for the same function. For example "rgmii" function for GPIO4 has id=2 while for GPIO59 it has id=1. So, to support this type of SoCs, get_function_mux() callback needs to know for which pin the function is requested.
drivers/pinctrl/qcom/pinctrl-apq8016.c | 3 ++- drivers/pinctrl/qcom/pinctrl-apq8096.c | 3 ++- drivers/pinctrl/qcom/pinctrl-ipq4019.c | 3 ++- drivers/pinctrl/qcom/pinctrl-qcom.c | 4 ++-- drivers/pinctrl/qcom/pinctrl-qcom.h | 3 ++- drivers/pinctrl/qcom/pinctrl-qcs404.c | 3 ++- drivers/pinctrl/qcom/pinctrl-sdm845.c | 3 ++- 7 files changed, 14 insertions(+), 8 deletions(-)
diff --git a/drivers/pinctrl/qcom/pinctrl-apq8016.c b/drivers/pinctrl/qcom/pinctrl-apq8016.c index 8149ffd83c..53042b6e05 100644 --- a/drivers/pinctrl/qcom/pinctrl-apq8016.c +++ b/drivers/pinctrl/qcom/pinctrl-apq8016.c @@ -49,7 +49,8 @@ static const char *apq8016_get_pin_name(struct udevice *dev, } }
-static unsigned int apq8016_get_function_mux(unsigned int selector) +static unsigned int apq8016_get_function_mux(__maybe_unused unsigned int pin, + unsigned int selector) { return msm_pinctrl_functions[selector].val; } diff --git a/drivers/pinctrl/qcom/pinctrl-apq8096.c b/drivers/pinctrl/qcom/pinctrl-apq8096.c index d64ab1ff7b..8dcd171259 100644 --- a/drivers/pinctrl/qcom/pinctrl-apq8096.c +++ b/drivers/pinctrl/qcom/pinctrl-apq8096.c @@ -44,7 +44,8 @@ static const char *apq8096_get_pin_name(struct udevice *dev, } }
-static unsigned int apq8096_get_function_mux(unsigned int selector) +static unsigned int apq8096_get_function_mux(__maybe_unused unsigned int pin, + unsigned int selector) { return msm_pinctrl_functions[selector].val; } diff --git a/drivers/pinctrl/qcom/pinctrl-ipq4019.c b/drivers/pinctrl/qcom/pinctrl-ipq4019.c index 2d99f99e1e..c2c358f556 100644 --- a/drivers/pinctrl/qcom/pinctrl-ipq4019.c +++ b/drivers/pinctrl/qcom/pinctrl-ipq4019.c @@ -40,7 +40,8 @@ static const char *ipq4019_get_pin_name(struct udevice *dev, return pin_name; }
-static unsigned int ipq4019_get_function_mux(unsigned int selector) +static unsigned int ipq4019_get_function_mux(__maybe_unused unsigned int pin, + unsigned int selector) { return msm_pinctrl_functions[selector].val; } diff --git a/drivers/pinctrl/qcom/pinctrl-qcom.c b/drivers/pinctrl/qcom/pinctrl-qcom.c index dc3d8c4d90..de0bb4de0a 100644 --- a/drivers/pinctrl/qcom/pinctrl-qcom.c +++ b/drivers/pinctrl/qcom/pinctrl-qcom.c @@ -82,10 +82,10 @@ static int msm_pinmux_set(struct udevice *dev, unsigned int pin_selector, unsigned int func_selector) { struct msm_pinctrl_priv *priv = dev_get_priv(dev); + u32 func = priv->data->get_function_mux(pin_selector, func_selector);
clrsetbits_le32(priv->base + GPIO_CONFIG_REG(priv, pin_selector), - TLMM_FUNC_SEL_MASK | TLMM_GPIO_DISABLE, - priv->data->get_function_mux(func_selector) << 2); + TLMM_FUNC_SEL_MASK | TLMM_GPIO_DISABLE, func << 2); return 0; }
diff --git a/drivers/pinctrl/qcom/pinctrl-qcom.h b/drivers/pinctrl/qcom/pinctrl-qcom.h index 07f2eae9ba..49b7bfbc00 100644 --- a/drivers/pinctrl/qcom/pinctrl-qcom.h +++ b/drivers/pinctrl/qcom/pinctrl-qcom.h @@ -18,7 +18,8 @@ struct msm_pinctrl_data { int functions_count; const char *(*get_function_name)(struct udevice *dev, unsigned int selector); - unsigned int (*get_function_mux)(unsigned int selector); + unsigned int (*get_function_mux)(unsigned int pin, + unsigned int selector); const char *(*get_pin_name)(struct udevice *dev, unsigned int selector); }; diff --git a/drivers/pinctrl/qcom/pinctrl-qcs404.c b/drivers/pinctrl/qcom/pinctrl-qcs404.c index ac00afa2a1..977f7b2ac3 100644 --- a/drivers/pinctrl/qcom/pinctrl-qcs404.c +++ b/drivers/pinctrl/qcom/pinctrl-qcs404.c @@ -56,7 +56,8 @@ static const char *qcs404_get_pin_name(struct udevice *dev, } }
-static unsigned int qcs404_get_function_mux(unsigned int selector) +static unsigned int qcs404_get_function_mux(__maybe_unused unsigned int pin, + unsigned int selector) { return msm_pinctrl_functions[selector].val; } diff --git a/drivers/pinctrl/qcom/pinctrl-sdm845.c b/drivers/pinctrl/qcom/pinctrl-sdm845.c index 9f0f4085ce..64ce1bf15e 100644 --- a/drivers/pinctrl/qcom/pinctrl-sdm845.c +++ b/drivers/pinctrl/qcom/pinctrl-sdm845.c @@ -70,7 +70,8 @@ static const char *sdm845_get_pin_name(struct udevice *dev, return pin_name; }
-static unsigned int sdm845_get_function_mux(unsigned int selector) +static unsigned int sdm845_get_function_mux(__maybe_unused unsigned int pin, + unsigned int selector) { return msm_pinctrl_functions[selector].val; }
Reviewed-by: Caleb Connolly caleb.connolly@linaro.org
return 0;TLMM_FUNC_SEL_MASK | TLMM_GPIO_DISABLE, func << 2);
- unsigned int (*get_function_mux)(unsigned int pin,
const char *(*get_pin_name)(struct udevice *dev, unsigned int selector);unsigned int selector);
Now sub-drivers for particular SoCs can register them as power domain drivers. This is needed for upcoming SM8150 support, because it needs to power up the Ethernet module.
drivers/clk/qcom/clock-qcom.c | 93 ++++++++++++++++++++++++++++++++++- drivers/clk/qcom/clock-qcom.h | 6 +++ 2 files changed, 98 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/qcom/clock-qcom.c b/drivers/clk/qcom/clock-qcom.c index 729d190c54..986b8e4da4 100644 --- a/drivers/clk/qcom/clock-qcom.c +++ b/drivers/clk/qcom/clock-qcom.c @@ -23,6 +23,7 @@ #include <linux/delay.h> #include <linux/bitops.h> #include <reset-uclass.h> +#include <power-domain-uclass.h>
@@ -30,6 +31,11 @@ #define CBCR_BRANCH_ENABLE_BIT BIT(0) #define CBCR_BRANCH_OFF_BIT BIT(31)
+#define GDSC_POWER_UP_COMPLETE BIT(16) +#define GDSC_POWER_DOWN_COMPLETE BIT(15) +#define CFG_GDSCR_OFFSET 0x4 +#define PWR_ON_MASK BIT(31) + /* Enable clock controlled by CBC soft macro */ void clk_enable_cbc(phys_addr_t cbcr) { @@ -223,7 +229,7 @@ U_BOOT_DRIVER(qcom_clk) = { int qcom_cc_bind(struct udevice *parent) { struct msm_clk_data *data = (struct msm_clk_data *)dev_get_driver_data(parent); - struct udevice *clkdev, *rstdev; + struct udevice *clkdev, *rstdev, *pwrdev; struct driver *drv; int ret;
@@ -253,6 +259,20 @@ int qcom_cc_bind(struct udevice *parent) if (ret) device_unbind(clkdev);
+ if (!data->power_domains) + return ret; + + /* Get a handle to the common power domain handler */ + drv = lists_driver_lookup_name("qcom_power"); + if (!drv) + return -ENOENT; + + /* Register the power domain controller */ + ret = device_bind_with_driver_data(parent, drv, "qcom_power", (ulong)data, + dev_ofnode(parent), &pwrdev); + if (ret) + device_unbind(pwrdev); + return ret; }
@@ -306,3 +326,74 @@ U_BOOT_DRIVER(qcom_reset) = { .ops = &qcom_reset_ops, .probe = qcom_reset_probe, }; + +static int qcom_power_set(struct power_domain *pwr, bool on) +{ + struct msm_clk_data *data = (struct msm_clk_data *)dev_get_driver_data(pwr->dev); + void __iomem *base = dev_get_priv(pwr->dev); + const struct qcom_power_map *map; + u32 value; + + if (pwr->id >= data->num_power_domains) + return -ENODEV; + + map = &data->power_domains[pwr->id]; + + if (!map->reg) + return -ENODEV; + + value = readl(base + map->reg); + + if (on) + value &= ~BIT(0); + else + value |= BIT(0); + + writel(value, base + map->reg); + + /* Wait for power on */ + while (true) { + value = readl(base + map->reg + CFG_GDSCR_OFFSET); + if (on) { + if ((value & GDSC_POWER_UP_COMPLETE) || + (value & PWR_ON_MASK)) + return 0; + } else { + if (value & GDSC_POWER_DOWN_COMPLETE || + !(value & PWR_ON_MASK)) + return 0; + } + } + + return 0; +} + +static int qcom_power_on(struct power_domain *pwr) +{ + return qcom_power_set(pwr, true); +} + +static int qcom_power_off(struct power_domain *pwr) +{ + return qcom_power_set(pwr, false); +} + +static const struct power_domain_ops qcom_power_ops = { + .on = qcom_power_on, + .off = qcom_power_off, +}; + +static int qcom_power_probe(struct udevice *dev) +{ + /* Set our priv pointer to the base address */ + dev_set_priv(dev, (void *)dev_read_addr(dev)); + + return 0; +} + +U_BOOT_DRIVER(qcom_power) = { + .name = "qcom_power", + .id = UCLASS_POWER_DOMAIN, + .ops = &qcom_power_ops, + .probe = qcom_power_probe, +}; diff --git a/drivers/clk/qcom/clock-qcom.h b/drivers/clk/qcom/clock-qcom.h index 01088c1901..12a1eaec2b 100644 --- a/drivers/clk/qcom/clock-qcom.h +++ b/drivers/clk/qcom/clock-qcom.h @@ -59,9 +59,15 @@ struct qcom_reset_map { u8 bit; };
+struct qcom_power_map { + unsigned int reg; +}; + struct clk;
struct msm_clk_data { + const struct qcom_power_map *power_domains; + unsigned long num_power_domains; const struct qcom_reset_map *resets; unsigned long num_resets; const struct gate_clk *clks;
- struct udevice *clkdev, *rstdev, *pwrdev; struct driver *drv; int ret;
Change this to:
if (ret) goto unbind_clkdev;
- if (!data->power_domains)
return ret;
Then this becomes:
if (!data->power_domains) return 0;
- /* Get a handle to the common power domain handler */
- drv = lists_driver_lookup_name("qcom_power");
- if (!drv)
return -ENOENT;
if (!drv) { ret = -ENOENT; goto unbind_rstdev; }
- /* Register the power domain controller */
- ret = device_bind_with_driver_data(parent, drv, "qcom_power", (ulong)data,
- if (ret)
pwrdev wasn't bound. Free the last *successful* allocation which was still rstdev.
if (ret) goto unbind_rstdev;
unbind_rstdev: device_unbind(rstdev); unbind_clkdev: device_unbind(clkdev);
return ret;
- return ret;
regards, dan carpenter
Please keep things sorted by bit index for bitfields and register offset for registers
return ret;
- if (!drv)
return -ENOENT;
- if (ret)
- return ret;
- struct msm_clk_data *data = (struct msm_clk_data *)dev_get_driver_data(pwr->dev);
- void __iomem *base = dev_get_priv(pwr->dev);
- const struct qcom_power_map *map;
- u32 value;
- if (pwr->id >= data->num_power_domains)
return -ENODEV;
- map = &data->power_domains[pwr->id];
- if (!map->reg)
return -ENODEV;
- value = readl(base + map->reg);
- if (on)
value &= ~BIT(0);
These magic bits should be #defined.
- else
value |= BIT(0);
- writel(value, base + map->reg);
- /* Wait for power on */
- while (true) {
Uhh.. I'm not sure a tight loop is the best idea here, especially since GDSCs are known to be grumpy and not wanna power on if they're missing a dependency. I'd say a timeout is definitely in order. 1500ms following Linux
Konrad
SA8155P Automotive Development Platform is Qualcomm SA8155-based board for developers. The nice thing that it has unlocked loaders with test keys support, which means that U-Boot for this platform can be launched at earlier stages.
This patch adds basic board support with only serial port and networking operation. I am using U-Boot to ease up Xen porting onto this board, so I am mostly interesting in booting U-Boot in EL2. But more conventional setup with Android boot image is supported as well.
arch/arm/dts/sa8155p-adp-u-boot.dtsi | 30 ++++++++ arch/arm/mach-snapdragon/Kconfig | 14 ++++ arch/arm/mach-snapdragon/Makefile | 2 + arch/arm/mach-snapdragon/init_sa8155p.c | 30 ++++++++ arch/arm/mach-snapdragon/sysmap-sm8150.c | 31 ++++++++ board/qualcomm/sa8155p-adp/Kconfig | 12 +++ board/qualcomm/sa8155p-adp/MAINTAINERS | 6 ++ configs/sa8155p_adp_defconfig | 33 +++++++++ doc/board/qualcomm/index.rst | 1 + doc/board/qualcomm/sa8155p-adp.rst | 94 ++++++++++++++++++++++++ include/configs/sa8155p_adp.h | 25 +++++++ 11 files changed, 278 insertions(+) create mode 100644 arch/arm/dts/sa8155p-adp-u-boot.dtsi create mode 100644 arch/arm/mach-snapdragon/init_sa8155p.c create mode 100644 arch/arm/mach-snapdragon/sysmap-sm8150.c create mode 100644 board/qualcomm/sa8155p-adp/Kconfig create mode 100644 board/qualcomm/sa8155p-adp/MAINTAINERS create mode 100644 configs/sa8155p_adp_defconfig create mode 100644 doc/board/qualcomm/sa8155p-adp.rst create mode 100644 include/configs/sa8155p_adp.h
diff --git a/arch/arm/dts/sa8155p-adp-u-boot.dtsi b/arch/arm/dts/sa8155p-adp-u-boot.dtsi new file mode 100644 index 0000000000..4484ea2734 --- /dev/null +++ b/arch/arm/dts/sa8155p-adp-u-boot.dtsi @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Qualcomm SA8155P-ADP device tree fixups for U-BOot + * + * Volodymyr Babchuk volodymyr_babchuk@epam.com + * Copyright (c) 2024 EPAM Systems. + */ + +/ { + /* Populate memory node with actual memory configuration */ + memory@80000000 { + reg = <0x00 0x80000000 0x00 0x39900000> , + <0x02 0x0 0x1 0x7fd00000>, + <0x00 0xC0000000 0x1 0x40000000>; + }; +}; + +ðernet { + /* Ethernet driver tries to find reset by name */ + reset-names = "emac"; +}; + +&tlmm { + /* U-Boot pinctrl driver does not understand multiple tiles */ + reg = <0x0 0x03000000 0x0 0x1000000>; + /delete-property/ reg-names; + + /* U-Boot ethernet driver wants to drive reset as GPIO */ + /delete-node/ phy-reset-pins; +}; diff --git a/arch/arm/mach-snapdragon/Kconfig b/arch/arm/mach-snapdragon/Kconfig index ad66710819..6431b6eca0 100644 --- a/arch/arm/mach-snapdragon/Kconfig +++ b/arch/arm/mach-snapdragon/Kconfig @@ -19,6 +19,12 @@ config SDM845 imply PINCTRL_QCOM_SDM845 imply BUTTON_QCOM_PMIC
+config SM8150 + bool "Qualcomm Snapdragon 855 SoC" + select LINUX_KERNEL_IMAGE_HEADER + imply CLK_QCOM_SM8150 + imply PINCTRL_QCOM_SDM8150 + config LNX_KRNL_IMG_TEXT_OFFSET_BASE default 0x80000000
@@ -90,6 +96,13 @@ config TARGET_QCS404EVB - 1GiB RAM - 8GiB eMMC, uSD slot
+config TARGET_SA8155P_ADP + bool "SA8155 Automotive Development Platform" + help + Support for Lantronix/Qualcomm SA8155P Automotive Development Platform + based on Snapdragon SA8155P + select SM8150 + endchoice
source "board/qualcomm/dragonboard410c/Kconfig" @@ -97,5 +110,6 @@ source "board/qualcomm/dragonboard820c/Kconfig" source "board/qualcomm/dragonboard845c/Kconfig" source "board/samsung/starqltechn/Kconfig" source "board/qualcomm/qcs404-evb/Kconfig" +source "board/qualcomm/sa8155p-adp/Kconfig"
endif diff --git a/arch/arm/mach-snapdragon/Makefile b/arch/arm/mach-snapdragon/Makefile index 3a3a297c17..ff2887e384 100644 --- a/arch/arm/mach-snapdragon/Makefile +++ b/arch/arm/mach-snapdragon/Makefile @@ -4,8 +4,10 @@
obj-$(CONFIG_SDM845) += sysmap-sdm845.o obj-$(CONFIG_SDM845) += init_sdm845.o +obj-$(CONFIG_SM8150) += sysmap-sm8150.o obj-$(CONFIG_TARGET_DRAGONBOARD820C) += sysmap-apq8096.o obj-$(CONFIG_TARGET_DRAGONBOARD410C) += sysmap-apq8016.o obj-y += misc.o obj-y += dram.o obj-$(CONFIG_TARGET_QCS404EVB) += sysmap-qcs404.o +obj-$(CONFIG_TARGET_SA8155P_ADP) += init_sa8155p.o diff --git a/arch/arm/mach-snapdragon/init_sa8155p.c b/arch/arm/mach-snapdragon/init_sa8155p.c new file mode 100644 index 0000000000..64dd07ae92 --- /dev/null +++ b/arch/arm/mach-snapdragon/init_sa8155p.c @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Qualcomm SM8150 initialization procedures + * + * Volodymyr Babchuk volodymyr_babchuk@epam.com + * Copyright (c) 2024 EPAM Systems. + */ + +#include <init.h> +#include <env.h> +#include <asm/system.h> +#include <dm.h> +#include <asm/arch/misc.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} + +void reset_cpu(void) +{ + psci_system_reset(); +} + +int board_init(void) +{ + return 0; +} diff --git a/arch/arm/mach-snapdragon/sysmap-sm8150.c b/arch/arm/mach-snapdragon/sysmap-sm8150.c new file mode 100644 index 0000000000..7250f5b398 --- /dev/null +++ b/arch/arm/mach-snapdragon/sysmap-sm8150.c @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Qualcomm SM8150 memory map + * + * Volodymyr Babchuk volodymyr_babchuk@epam.com + * Copyright (c) 2024 EPAM Systems. + */ + +#include <asm/armv8/mmu.h> + +static struct mm_region sm8150_mem_map[] = { + { + .virt = 0x0UL, /* Peripheral block */ + .phys = 0x0UL, /* Peripheral block */ + .size = 0x10000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + .virt = 0x80000000UL, /* DDR */ + .phys = 0x80000000UL, /* DDR */ + .size = 0x200000000UL, /* 8GiB - maximum allowed memory */ + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = sm8150_mem_map; diff --git a/board/qualcomm/sa8155p-adp/Kconfig b/board/qualcomm/sa8155p-adp/Kconfig new file mode 100644 index 0000000000..420d594e35 --- /dev/null +++ b/board/qualcomm/sa8155p-adp/Kconfig @@ -0,0 +1,12 @@ +if TARGET_SA8155P_ADP + +config SYS_BOARD + default "sa8155p_adp" + +config SYS_CONFIG_NAME + default "sa8155p_adp" + +config SYS_VENDOR + default "qualcomm" + +endif diff --git a/board/qualcomm/sa8155p-adp/MAINTAINERS b/board/qualcomm/sa8155p-adp/MAINTAINERS new file mode 100644 index 0000000000..28edd643da --- /dev/null +++ b/board/qualcomm/sa8155p-adp/MAINTAINERS @@ -0,0 +1,6 @@ +Qualcomm Robotics RB3 Development Platform (dragonboard845c) +M: Volodymyr Babchuk volodymyr_babchuk@epam.com +S: Maintained +F: board/qualcomm/sa8155p-adp/ +F: include/configs/sa8155p-adp.h +F: configs/sa8155p-adp_defconfig diff --git a/configs/sa8155p_adp_defconfig b/configs/sa8155p_adp_defconfig new file mode 100644 index 0000000000..40f275b2cb --- /dev/null +++ b/configs/sa8155p_adp_defconfig @@ -0,0 +1,33 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=19000000 +CONFIG_POSITION_INDEPENDENT=y +CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y +CONFIG_ARCH_SNAPDRAGON=y +CONFIG_TEXT_BASE=0x85710000 +CONFIG_DEFAULT_DEVICE_TREE="sa8155p-adp" +CONFIG_TARGET_SA8155P_ADP=y +CONFIG_IDENT_STRING="\nQualcomm SA8155P-ADP" +CONFIG_SYS_LOAD_ADDR=0x85710000 +CONFIG_BOOTDELAY=3 +CONFIG_SYS_CBSIZE=512 +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_HUSH_PARSER=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_MSM_GPIO=y +CONFIG_QCOM_PMIC_GPIO=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_DM_MDIO=y +CONFIG_DM_ETH_PHY=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_QCOM=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_PINCTRL_QCOM_SM8150=y +CONFIG_POWER_DOMAIN=y +CONFIG_MSM_GENI_SERIAL=y +CONFIG_SPMI_MSM=y +CONFIG_LMB_MAX_REGIONS=64 diff --git a/doc/board/qualcomm/index.rst b/doc/board/qualcomm/index.rst index 0f9c429956..05195de905 100644 --- a/doc/board/qualcomm/index.rst +++ b/doc/board/qualcomm/index.rst @@ -9,3 +9,4 @@ Qualcomm dragonboard410c sdm845 qcs404 + sa8155p-adp diff --git a/doc/board/qualcomm/sa8155p-adp.rst b/doc/board/qualcomm/sa8155p-adp.rst new file mode 100644 index 0000000000..cff68cd55f --- /dev/null +++ b/doc/board/qualcomm/sa8155p-adp.rst @@ -0,0 +1,94 @@ +.. SPDX-License-Identifier: BSD-3-Clause +.. sectionauthor:: Volodymyr Babchuk volodymyr_babchuk@epam.com + +SA8155P Automotive Development Platform +======================================= + +About +----- +This document describes the information about SA8155P Automotive +Development Platform aka SA8155P-ADP. + +Currently U-Boot can be booted either as Android boot image, or in EL2 +mode, instead of hypervisor image. In the latter case it is possible +to use U-Boot to either boot Linux with KVM support or to boot Xen +Hypervisor on this board. + +Supported HW modules +^^^^^^^^^^^^^^^^^^^^ +Port for this board is in early development state. Right now U-Boot +supports serial console and networking. No USB/fastboot or UFS support +yet. So it is not possible to save environment variables as +well. Nevertheless this is enough for development as user can download +all required images via TFTP. + +Installation +------------ +Build +^^^^^ +Setup ``CROSS_COMPILE`` for aarch64 and build U-Boot for your board:: + + $ export CROSS_COMPILE=<aarch64 toolchain prefix> + $ make sa8155p_adp_defconfig + $ make + +This will build ``u-boot.bin`` in the configured output directory. + +Boot in EL1 mode instead of Android boot image +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +Create a dummy ramdisk image::: + + $ echo "This is not a ramdisk" > ramdisk.img + +Compress u-boot binary::: + + $ gzip -c u-boot.bin > u-boot.bin.gz + +Append DTB again (binary we use already have DTB embedded in, but +Android boot image format requires another DTB at the end of the +archive)::: + + $ cat u-boot.bin.gz u-boot.dtb > u-boot.bin.gz-dtb + +Now we've got everything to build android boot image::: + + $ mkbootimg --kernel u-boot.bin.gz-dtb \ + --ramdisk ramdisk.img --pagesize 4096 \ + --base 0x80000000 -o boot.img + +Finally you can flash new boot image with fastboot::: + + $ fastboot flash boot boot.img + +Or just boot U-Boot without flashing anything::: + + $ fastboot boot boot.img + +Boot in EL2 mode instead of Qualcomm's hypervisor stub +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ +This approach ensures that U-Boot is booted in EL2 and it is possible +to run virtualization software (like Xen or KVM) on the board. You +must understand that this approach breaks Qualcomm's boot chain. You +will not be able to call all subsequent loaders, so you will not be +able to use fastboot for example. Use this approach only if you want +to experiment with virtualization on SA8155P-ADP. + +We need to create ELF file from the u-boot binary. We can't use +existing U-Boot ELF, because it does not include appended DTB +file. Easiest way to do this is to use ``create_elf.py`` from the +following repository: `qtestsign(lorc) +https://github.com/lorc/qtestsign/tree/create_elf`_: :: + + $ python ../qtestsign/create_elf.py u-boot.bin 0x85710000 u-boot.mbn + +Next, this new binary should be signed with test keys: :: + + $ ../qtestsign/qtestsign.py -v6 hyp u-boot.mbn + +Resulting ``u-boot-test-signed.mbn`` then can be written to the +board. Easiest way is to use ``edl`` tool: :: + + $ ../edl/edl w hyp_a u-boot-test-signed.mbn --memory=ufs --lun=4 + +Be sure to backup existing hyp_a loader before flashing U-Boot diff --git a/include/configs/sa8155p_adp.h b/include/configs/sa8155p_adp.h new file mode 100644 index 0000000000..e986646334 --- /dev/null +++ b/include/configs/sa8155p_adp.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: BSD-3-Clause */ +/* + * Configuration file for SA8155P Automotive development platform, + * based on Qualcomm SA8155P chip + * + * Volodymyr Babchuk volodymyr_babchuk@epam.com + * Copyright (c) 2024 EPAM Systems. + */ + +#ifndef __CONFIGS_SA8155P_ADP_H +#define __CONFIGS_SA8155P_ADP_H + +#include <linux/sizes.h> + +#define CFG_SYS_BAUDRATE_TABLE { 115200, 230400, 460800, 921600 } + +#define CFG_EXTRA_ENV_SETTINGS \ + "bootm_size=0x10000000\0" \ + "bootm_low=0xA0000000\0" \ + "bootm_mapsize=0x39900000\0" \ + "kernel_comp_add_r=0xB0000000\0" \ + "kernel_comp_size=0x01000000\0" \ + "" \ + +#endif
[...] diff --git a/doc/board/qualcomm/sa8155p-adp.rst b/doc/board/qualcomm/sa8155p-adp.rst new file mode 100644 index 0000000000..cff68cd55f --- /dev/null +++ b/doc/board/qualcomm/sa8155p-adp.rst @@ -0,0 +1,94 @@ +.. SPDX-License-Identifier: BSD-3-Clause +.. sectionauthor:: Volodymyr Babchuk volodymyr_babchuk@epam.com
- $ export CROSS_COMPILE=<aarch64 toolchain prefix>
- $ make sa8155p_adp_defconfig
- $ make
- $ echo "This is not a ramdisk" > ramdisk.img
- $ gzip -c u-boot.bin > u-boot.bin.gz
- $ cat u-boot.bin.gz u-boot.dtb > u-boot.bin.gz-dtb
- $ mkbootimg --kernel u-boot.bin.gz-dtb \
- --ramdisk ramdisk.img --pagesize 4096 \
- --base 0x80000000 -o boot.img
- $ fastboot flash boot boot.img
- $ fastboot boot boot.img
- $ python ../qtestsign/create_elf.py u-boot.bin 0x85710000 u-boot.mbn
Have you tried using CONFIG_REMAKE_ELF in U-Boot? That should effectively do the same (build a new ELF based on u-boot.bin with the appended device tree). The Qualcomm DragonBoard 410c port is using that option to solve the same problem.
But I'm glad to see that the ELF abstractions in qtestsign worked well for your purpose. :-)
Thanks, Stephan
Hi Stephan,
Stephan Gerhold stephan@gerhold.net writes:
+We need to create ELF file from the u-boot binary. We can't use +existing U-Boot ELF, because it does not include appended DTB +file. Easiest way to do this is to use ``create_elf.py`` from the +following repository: `qtestsign(lorc) +https://urldefense.com/v3/__https://github.com/lorc/qtestsign/tree/create_elf__;!!GF_29dbcQIUBPA!3iokDDZXQGZNS3GK2oGM-SU5Trj8ZSmx5FY-uvFKY0LDzDLh8LSVkBNS5r9QX-LGFKObs1tNmLdELls6iGQPZ3Aq$ [github[.]com]`_: ::
I didn't knew that there is a such option. Looks like this is exactly what I need, thank you. I'll include this in the V2.
Well, I was surprised that pyelf can parse ELF files but can't modify them. So your tool come in handy. I was going to make a PR that adds this create_elf.py script, but looks like we don't need it.
Add pinctrl and GPIO driver for SM8150. Driver code is based on the similar U-Boot drivers. All constants are taken from the corresponding Linux driver. This drivers differs from the similar U-Boot drivers, because SM8150 SoC have different function IDs for the same functions on different pins.
drivers/pinctrl/qcom/Kconfig | 7 + drivers/pinctrl/qcom/Makefile | 1 + drivers/pinctrl/qcom/pinctrl-sm8150.c | 589 ++++++++++++++++++++++++++ 3 files changed, 597 insertions(+) create mode 100644 drivers/pinctrl/qcom/pinctrl-sm8150.c
diff --git a/drivers/pinctrl/qcom/Kconfig b/drivers/pinctrl/qcom/Kconfig index 2fe6398147..290cefca47 100644 --- a/drivers/pinctrl/qcom/Kconfig +++ b/drivers/pinctrl/qcom/Kconfig @@ -41,6 +41,13 @@ config PINCTRL_QCOM_SDM845 Say Y here to enable support for pinctrl on the Snapdragon 845 SoC, as well as the associated GPIO driver.
+config PINCTRL_QCOM_SM8150 + bool "Qualcomm SM8150 GCC" + select PINCTRL_QCOM + help + Say Y here to enable support for pinctrl on the Snapdragon SM8150 SoC, + as well as the associated GPIO driver. + endmenu
endif diff --git a/drivers/pinctrl/qcom/Makefile b/drivers/pinctrl/qcom/Makefile index 6d9aca6d7b..3c7be4a685 100644 --- a/drivers/pinctrl/qcom/Makefile +++ b/drivers/pinctrl/qcom/Makefile @@ -8,3 +8,4 @@ obj-$(CONFIG_PINCTRL_QCOM_IPQ4019) += pinctrl-ipq4019.o obj-$(CONFIG_PINCTRL_QCOM_APQ8096) += pinctrl-apq8096.o obj-$(CONFIG_PINCTRL_QCOM_QCS404) += pinctrl-qcs404.o obj-$(CONFIG_PINCTRL_QCOM_SDM845) += pinctrl-sdm845.o +obj-$(CONFIG_PINCTRL_QCOM_SM8150) += pinctrl-sm8150.o diff --git a/drivers/pinctrl/qcom/pinctrl-sm8150.c b/drivers/pinctrl/qcom/pinctrl-sm8150.c new file mode 100644 index 0000000000..a6c14d7254 --- /dev/null +++ b/drivers/pinctrl/qcom/pinctrl-sm8150.c @@ -0,0 +1,589 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Qualcomm SM8150 pinctrl and GPIO driver + * + * Volodymyr Babchuk volodymyr_babchuk@epam.com + * Copyright (c) 2024 EPAM Systems. + * + * Based on similar U-Boot drivers. Constants were taken from the Linux driver + */ + +#include <dm.h> + +#include "pinctrl-qcom.h" + +#define WEST 0x00100000 +#define EAST 0x00500000 +#define NORTH 0x00900000 +#define SOUTH 0x00D00000 + +#define MAX_PIN_NAME_LEN 32 +static char pin_name[MAX_PIN_NAME_LEN] __section(".data"); + +enum sm8150_functions { + msm_mux_adsp_ext, + msm_mux_agera_pll, + msm_mux_aoss_cti, + msm_mux_atest_char, + msm_mux_atest_char0, + msm_mux_atest_char1, + msm_mux_atest_char2, + msm_mux_atest_char3, + msm_mux_atest_usb1, + msm_mux_atest_usb2, + msm_mux_atest_usb10, + msm_mux_atest_usb11, + msm_mux_atest_usb12, + msm_mux_atest_usb13, + msm_mux_atest_usb20, + msm_mux_atest_usb21, + msm_mux_atest_usb22, + msm_mux_atest_usb23, + msm_mux_audio_ref, + msm_mux_btfm_slimbus, + msm_mux_cam_mclk, + msm_mux_cci_async, + msm_mux_cci_i2c, + msm_mux_cci_timer0, + msm_mux_cci_timer1, + msm_mux_cci_timer2, + msm_mux_cci_timer3, + msm_mux_cci_timer4, + msm_mux_cri_trng, + msm_mux_cri_trng0, + msm_mux_cri_trng1, + msm_mux_dbg_out, + msm_mux_ddr_bist, + msm_mux_ddr_pxi0, + msm_mux_ddr_pxi1, + msm_mux_ddr_pxi2, + msm_mux_ddr_pxi3, + msm_mux_edp_hot, + msm_mux_edp_lcd, + msm_mux_emac_phy, + msm_mux_emac_pps, + msm_mux_gcc_gp1, + msm_mux_gcc_gp2, + msm_mux_gcc_gp3, + msm_mux_gpio, + msm_mux_jitter_bist, + msm_mux_hs1_mi2s, + msm_mux_hs2_mi2s, + msm_mux_hs3_mi2s, + msm_mux_lpass_slimbus, + msm_mux_mdp_vsync, + msm_mux_mdp_vsync0, + msm_mux_mdp_vsync1, + msm_mux_mdp_vsync2, + msm_mux_mdp_vsync3, + msm_mux_mss_lte, + msm_mux_m_voc, + msm_mux_nav_pps, + msm_mux_pa_indicator, + msm_mux_pci_e0, + msm_mux_pci_e1, + msm_mux_phase_flag, + msm_mux_pll_bist, + msm_mux_pll_bypassnl, + msm_mux_pll_reset, + msm_mux_pri_mi2s, + msm_mux_pri_mi2s_ws, + msm_mux_prng_rosc, + msm_mux_qdss, + msm_mux_qdss_cti, + msm_mux_qlink_enable, + msm_mux_qlink_request, + msm_mux_qspi0, + msm_mux_qspi1, + msm_mux_qspi2, + msm_mux_qspi3, + msm_mux_qspi_clk, + msm_mux_qspi_cs, + msm_mux_qua_mi2s, + msm_mux_qup0, + msm_mux_qup1, + msm_mux_qup2, + msm_mux_qup3, + msm_mux_qup4, + msm_mux_qup5, + msm_mux_qup6, + msm_mux_qup7, + msm_mux_qup8, + msm_mux_qup9, + msm_mux_qup10, + msm_mux_qup11, + msm_mux_qup12, + msm_mux_qup13, + msm_mux_qup14, + msm_mux_qup15, + msm_mux_qup16, + msm_mux_qup17, + msm_mux_qup18, + msm_mux_qup19, + msm_mux_qup_l4, + msm_mux_qup_l5, + msm_mux_qup_l6, + msm_mux_rgmii, + msm_mux_sdc4, + msm_mux_sd_write, + msm_mux_sec_mi2s, + msm_mux_spkr_i2s, + msm_mux_sp_cmu, + msm_mux_ter_mi2s, + msm_mux_tgu_ch0, + msm_mux_tgu_ch2, + msm_mux_tgu_ch1, + msm_mux_tgu_ch3, + msm_mux_tsense_pwm1, + msm_mux_tsense_pwm2, + msm_mux_tsif1, + msm_mux_tsif2, + msm_mux_uim1, + msm_mux_uim2, + msm_mux_uim_batt, + msm_mux_usb2phy_ac, + msm_mux_usb_phy, + msm_mux_vfr_1, + msm_mux_vsense_trigger, + msm_mux_wlan1_adc1, + msm_mux_wlan1_adc0, + msm_mux_wlan2_adc1, + msm_mux_wlan2_adc0, + msm_mux_wmss_reset, + msm_mux__, +}; + +#define MSM_PIN_FUNCTION(fname) \ + [msm_mux_##fname] = {#fname, msm_mux_##fname} + +static const struct pinctrl_function msm_pinctrl_functions[] = { + MSM_PIN_FUNCTION(adsp_ext), + MSM_PIN_FUNCTION(agera_pll), + MSM_PIN_FUNCTION(aoss_cti), + MSM_PIN_FUNCTION(ddr_pxi2), + MSM_PIN_FUNCTION(atest_char), + MSM_PIN_FUNCTION(atest_char0), + MSM_PIN_FUNCTION(atest_char1), + MSM_PIN_FUNCTION(atest_char2), + MSM_PIN_FUNCTION(atest_char3), + MSM_PIN_FUNCTION(audio_ref), + MSM_PIN_FUNCTION(atest_usb1), + MSM_PIN_FUNCTION(atest_usb2), + MSM_PIN_FUNCTION(atest_usb10), + MSM_PIN_FUNCTION(atest_usb11), + MSM_PIN_FUNCTION(atest_usb12), + MSM_PIN_FUNCTION(atest_usb13), + MSM_PIN_FUNCTION(atest_usb20), + MSM_PIN_FUNCTION(atest_usb21), + MSM_PIN_FUNCTION(atest_usb22), + MSM_PIN_FUNCTION(atest_usb23), + MSM_PIN_FUNCTION(btfm_slimbus), + MSM_PIN_FUNCTION(cam_mclk), + MSM_PIN_FUNCTION(cci_async), + MSM_PIN_FUNCTION(cci_i2c), + MSM_PIN_FUNCTION(cci_timer0), + MSM_PIN_FUNCTION(cci_timer1), + MSM_PIN_FUNCTION(cci_timer2), + MSM_PIN_FUNCTION(cci_timer3), + MSM_PIN_FUNCTION(cci_timer4), + MSM_PIN_FUNCTION(cri_trng), + MSM_PIN_FUNCTION(cri_trng0), + MSM_PIN_FUNCTION(cri_trng1), + MSM_PIN_FUNCTION(dbg_out), + MSM_PIN_FUNCTION(ddr_bist), + MSM_PIN_FUNCTION(ddr_pxi0), + MSM_PIN_FUNCTION(ddr_pxi1), + MSM_PIN_FUNCTION(ddr_pxi3), + MSM_PIN_FUNCTION(edp_hot), + MSM_PIN_FUNCTION(edp_lcd), + MSM_PIN_FUNCTION(emac_phy), + MSM_PIN_FUNCTION(emac_pps), + MSM_PIN_FUNCTION(gcc_gp1), + MSM_PIN_FUNCTION(gcc_gp2), + MSM_PIN_FUNCTION(gcc_gp3), + MSM_PIN_FUNCTION(gpio), + MSM_PIN_FUNCTION(hs1_mi2s), + MSM_PIN_FUNCTION(hs2_mi2s), + MSM_PIN_FUNCTION(hs3_mi2s), + MSM_PIN_FUNCTION(jitter_bist), + MSM_PIN_FUNCTION(lpass_slimbus), + MSM_PIN_FUNCTION(mdp_vsync), + MSM_PIN_FUNCTION(mdp_vsync0), + MSM_PIN_FUNCTION(mdp_vsync1), + MSM_PIN_FUNCTION(mdp_vsync2), + MSM_PIN_FUNCTION(mdp_vsync3), + MSM_PIN_FUNCTION(mss_lte), + MSM_PIN_FUNCTION(m_voc), + MSM_PIN_FUNCTION(nav_pps), + MSM_PIN_FUNCTION(pa_indicator), + MSM_PIN_FUNCTION(pci_e0), + MSM_PIN_FUNCTION(phase_flag), + MSM_PIN_FUNCTION(pll_bypassnl), + MSM_PIN_FUNCTION(pll_bist), + MSM_PIN_FUNCTION(pci_e1), + MSM_PIN_FUNCTION(pll_reset), + MSM_PIN_FUNCTION(pri_mi2s), + MSM_PIN_FUNCTION(pri_mi2s_ws), + MSM_PIN_FUNCTION(prng_rosc), + MSM_PIN_FUNCTION(qdss), + MSM_PIN_FUNCTION(qdss_cti), + MSM_PIN_FUNCTION(qlink_request), + MSM_PIN_FUNCTION(qlink_enable), + MSM_PIN_FUNCTION(qspi0), + MSM_PIN_FUNCTION(qspi1), + MSM_PIN_FUNCTION(qspi2), + MSM_PIN_FUNCTION(qspi3), + MSM_PIN_FUNCTION(qspi_clk), + MSM_PIN_FUNCTION(qspi_cs), + MSM_PIN_FUNCTION(qua_mi2s), + MSM_PIN_FUNCTION(qup0), + MSM_PIN_FUNCTION(qup1), + MSM_PIN_FUNCTION(qup2), + MSM_PIN_FUNCTION(qup3), + MSM_PIN_FUNCTION(qup4), + MSM_PIN_FUNCTION(qup5), + MSM_PIN_FUNCTION(qup6), + MSM_PIN_FUNCTION(qup7), + MSM_PIN_FUNCTION(qup8), + MSM_PIN_FUNCTION(qup9), + MSM_PIN_FUNCTION(qup10), + MSM_PIN_FUNCTION(qup11), + MSM_PIN_FUNCTION(qup12), + MSM_PIN_FUNCTION(qup13), + MSM_PIN_FUNCTION(qup14), + MSM_PIN_FUNCTION(qup15), + MSM_PIN_FUNCTION(qup16), + MSM_PIN_FUNCTION(qup17), + MSM_PIN_FUNCTION(qup18), + MSM_PIN_FUNCTION(qup19), + MSM_PIN_FUNCTION(qup_l4), + MSM_PIN_FUNCTION(qup_l5), + MSM_PIN_FUNCTION(qup_l6), + MSM_PIN_FUNCTION(rgmii), + MSM_PIN_FUNCTION(sdc4), + MSM_PIN_FUNCTION(sd_write), + MSM_PIN_FUNCTION(sec_mi2s), + MSM_PIN_FUNCTION(spkr_i2s), + MSM_PIN_FUNCTION(sp_cmu), + MSM_PIN_FUNCTION(ter_mi2s), + MSM_PIN_FUNCTION(tgu_ch0), + MSM_PIN_FUNCTION(tgu_ch1), + MSM_PIN_FUNCTION(tgu_ch2), + MSM_PIN_FUNCTION(tgu_ch3), + MSM_PIN_FUNCTION(tsense_pwm1), + MSM_PIN_FUNCTION(tsense_pwm2), + MSM_PIN_FUNCTION(tsif1), + MSM_PIN_FUNCTION(tsif2), + MSM_PIN_FUNCTION(uim1), + MSM_PIN_FUNCTION(uim2), + MSM_PIN_FUNCTION(uim_batt), + MSM_PIN_FUNCTION(usb2phy_ac), + MSM_PIN_FUNCTION(usb_phy), + MSM_PIN_FUNCTION(vfr_1), + MSM_PIN_FUNCTION(vsense_trigger), + MSM_PIN_FUNCTION(wlan1_adc0), + MSM_PIN_FUNCTION(wlan1_adc1), + MSM_PIN_FUNCTION(wlan2_adc0), + MSM_PIN_FUNCTION(wlan2_adc1), + MSM_PIN_FUNCTION(wmss_reset), +}; + +static const unsigned int sm8150_pin_offsets[] = { + [0] = SOUTH, [1] = SOUTH, [2] = SOUTH, [3] = SOUTH, + [4] = SOUTH, [5] = SOUTH, [6] = SOUTH, [7] = SOUTH, + [8] = NORTH, [9] = NORTH, [10] = NORTH, [11] = NORTH, + [12] = NORTH, [13] = NORTH, [14] = NORTH, [15] = NORTH, + [16] = NORTH, [17] = NORTH, [18] = NORTH, [19] = NORTH, + [20] = NORTH, [21] = EAST, [22] = EAST, [23] = EAST, + [24] = EAST, [25] = EAST, [26] = EAST, [27] = EAST, + [28] = EAST, [29] = EAST, [30] = EAST, [31] = NORTH, + [32] = NORTH, [33] = NORTH, [34] = NORTH, [35] = NORTH, + [36] = NORTH, [37] = NORTH, [38] = SOUTH, [39] = NORTH, + [40] = NORTH, [41] = NORTH, [42] = NORTH, [43] = EAST, + [44] = EAST, [45] = EAST, [46] = EAST, [47] = EAST, + [48] = EAST, [49] = EAST, [50] = EAST, [51] = SOUTH, + [52] = SOUTH, [53] = SOUTH, [54] = SOUTH, [55] = SOUTH, + [56] = SOUTH, [57] = SOUTH, [58] = SOUTH, [59] = SOUTH, + [60] = SOUTH, [61] = SOUTH, [62] = SOUTH, [63] = SOUTH, + [64] = SOUTH, [65] = SOUTH, [66] = SOUTH, [67] = SOUTH, + [68] = SOUTH, [69] = SOUTH, [70] = SOUTH, [71] = SOUTH, + [72] = SOUTH, [73] = SOUTH, [74] = SOUTH, [75] = SOUTH, + [76] = SOUTH, [77] = SOUTH, [78] = SOUTH, [79] = SOUTH, + [80] = SOUTH, [81] = SOUTH, [82] = SOUTH, [83] = NORTH, + [84] = NORTH, [85] = NORTH, [86] = NORTH, [87] = EAST, + [88] = NORTH, [89] = NORTH, [90] = NORTH, [91] = NORTH, + [92] = NORTH, [93] = NORTH, [94] = NORTH, [95] = NORTH, + [96] = NORTH, [97] = NORTH, [98] = SOUTH, [99] = SOUTH, + [100] = SOUTH, [101] = SOUTH, [102] = NORTH, [103] = NORTH, + [104] = NORTH, [105] = WEST, [106] = WEST, [107] = WEST, + [108] = WEST, [109] = WEST, [110] = WEST, [111] = WEST, + [112] = WEST, [113] = WEST, [114] = SOUTH, [115] = SOUTH, + [116] = SOUTH, [117] = SOUTH, [118] = SOUTH, [119] = SOUTH, + [120] = SOUTH, [121] = SOUTH, [122] = SOUTH, [123] = SOUTH, + [124] = SOUTH, [125] = WEST, [126] = SOUTH, [127] = SOUTH, + [128] = SOUTH, [129] = SOUTH, [130] = SOUTH, [131] = SOUTH, + [132] = SOUTH, [133] = SOUTH, [134] = SOUTH, [135] = SOUTH, + [136] = SOUTH, [137] = SOUTH, [138] = SOUTH, [139] = SOUTH, + [140] = SOUTH, [141] = SOUTH, [142] = SOUTH, [143] = SOUTH, + [144] = SOUTH, [145] = SOUTH, [146] = SOUTH, [147] = SOUTH, + [148] = SOUTH, [149] = SOUTH, [150] = SOUTH, [151] = SOUTH, + [152] = SOUTH, [153] = SOUTH, [154] = SOUTH, [155] = WEST, + [156] = WEST, [157] = WEST, [158] = WEST, [159] = WEST, + [160] = WEST, [161] = WEST, [162] = WEST, [163] = WEST, + [164] = WEST, [165] = WEST, [166] = WEST, [167] = WEST, + [168] = WEST, [169] = NORTH, [170] = NORTH, [171] = NORTH +}; + +typedef unsigned int msm_pin_function[10]; + +#define PINGROUP(id, f1, f2, f3, f4, f5, f6, f7, f8, f9) \ + [id] = { msm_mux_gpio, /* gpio mode */ \ + msm_mux_##f1, \ + msm_mux_##f2, \ + msm_mux_##f3, \ + msm_mux_##f4, \ + msm_mux_##f5, \ + msm_mux_##f6, \ + msm_mux_##f7, \ + msm_mux_##f8, \ + msm_mux_##f9 \ + } + +static const msm_pin_function sm8150_pin_functions[] = { + PINGROUP(0, qup0, _, _, _, _, _, _, _, _), + PINGROUP(1, qup0, _, _, _, _, _, _, _, _), + PINGROUP(2, qup0, _, _, _, _, _, _, _, _), + PINGROUP(3, qup0, _, _, _, _, _, _, _, _), + PINGROUP(4, qup6, rgmii, _, _, _, _, _, _, _), + PINGROUP(5, qup6, rgmii, _, _, _, _, _, _, _), + PINGROUP(6, qup6, rgmii, qup_l6, _, _, _, _, _, _), + PINGROUP(7, qup6, rgmii, qup_l5, _, _, _, _, _, _), + PINGROUP(8, mdp_vsync, _, _, _, _, _, _, _, _), + PINGROUP(9, mdp_vsync, edp_lcd, qup10, _, _, _, _, _, _), + PINGROUP(10, mdp_vsync, m_voc, edp_hot, qup10, _, _, _, _, _), + PINGROUP(11, qup10, _, _, _, _, _, _, _, _), + PINGROUP(12, qup10, _, _, _, _, _, _, _, _), + PINGROUP(13, cam_mclk, qdss, _, _, _, _, _, _, _), + PINGROUP(14, cam_mclk, qdss, _, _, _, _, _, _, _), + PINGROUP(15, cam_mclk, qdss, _, _, _, _, _, _, _), + PINGROUP(16, cam_mclk, qdss, _, _, _, _, _, _, _), + PINGROUP(17, cci_i2c, qdss, _, _, _, _, _, _, _), + PINGROUP(18, cci_i2c, phase_flag, _, qdss, _, _, _, _, _), + PINGROUP(19, cci_i2c, phase_flag, _, qdss, _, _, _, _, _), + PINGROUP(20, cci_i2c, phase_flag, _, qdss, _, _, _, _, _), + PINGROUP(21, cci_timer0, gcc_gp2, qdss, _, _, _, _, _, _), + PINGROUP(22, cci_timer1, gcc_gp3, qdss, _, _, _, _, _, _), + PINGROUP(23, cci_timer2, qup18, qdss, _, _, _, _, _, _), + PINGROUP(24, cci_timer3, cci_async, qup18, qdss, _, _, _, _, _), + PINGROUP(25, cci_timer4, cci_async, qup18, qdss, _, _, _, _, _), + PINGROUP(26, cci_async, qup18, qdss, _, _, _, _, _, _), + PINGROUP(27, qup15, _, qdss, _, _, _, _, _, _), + PINGROUP(28, qup15, qdss, _, _, _, _, _, _, _), + PINGROUP(29, qup15, qdss, _, _, _, _, _, _, _), + PINGROUP(30, qup15, qdss, _, _, _, _, _, _, _), + PINGROUP(31, cci_i2c, qdss, _, _, _, _, _, _, _), + PINGROUP(32, cci_i2c, qdss, _, _, _, _, _, _, _), + PINGROUP(33, cci_i2c, qup_l5, qdss, _, _, _, _, _, _), + PINGROUP(34, cci_i2c, qup_l6, _, _, _, _, _, _, _), + PINGROUP(35, pci_e0, _, _, _, _, _, _, _, _), + PINGROUP(36, pci_e0, _, _, _, _, _, _, _, _), + PINGROUP(37, qup_l4, agera_pll, _, _, _, _, _, _, _), + PINGROUP(38, usb_phy, _, _, _, _, _, _, _, _), + PINGROUP(39, qup9, qdss, _, _, _, _, _, _, _), + PINGROUP(40, qup9, qdss, _, _, _, _, _, _, _), + PINGROUP(41, qup9, qdss, _, _, _, _, _, _, _), + PINGROUP(42, qup9, qdss, _, _, _, _, _, _, _), + PINGROUP(43, qup13, _, _, _, _, _, _, _, _), + PINGROUP(44, qup13, _, _, _, _, _, _, _, _), + PINGROUP(45, qup13, qdss_cti, _, _, _, _, _, _, _), + PINGROUP(46, qup13, qdss_cti, _, _, _, _, _, _, _), + PINGROUP(47, qup14, qdss, _, _, _, _, _, _, _), + PINGROUP(48, qup14, qdss, _, _, _, _, _, _, _), + PINGROUP(49, qup14, _, qdss_cti, _, _, _, _, _, _), + PINGROUP(50, qup14, qdss_cti, _, _, _, _, _, _, _), + PINGROUP(51, qup4, _, _, _, _, _, _, _, _), + PINGROUP(52, qup4, _, _, _, _, _, _, _, _), + PINGROUP(53, qup4, _, _, _, _, _, _, _, _), + PINGROUP(54, qup4, _, _, _, _, _, _, _, _), + PINGROUP(55, qup17, qup19, phase_flag, _, _, _, _, _, _), + PINGROUP(56, qup17, qup19, qdss_cti, phase_flag, _, _, _, _, _), + PINGROUP(57, qup17, qup19, qdss_cti, phase_flag, _, _, _, _, _), + PINGROUP(58, qup17, qup19, qdss_cti, phase_flag, _, _, _, _, _), + PINGROUP(59, rgmii, qup_l4, phase_flag, _, atest_char, _, _, _, _), + PINGROUP(60, _, nav_pps, nav_pps, atest_usb2, _, _, _, _, _), + PINGROUP(61, qlink_request, _, _, _, _, _, _, _, _), + PINGROUP(62, qlink_enable, _, _, _, _, _, _, _, _), + PINGROUP(63, wmss_reset, atest_usb23, _, _, _, _, _, _, _), + PINGROUP(64, _, phase_flag, _, _, _, _, _, _, _), + PINGROUP(65, _, _, _, _, _, _, _, _, _), + PINGROUP(66, _, _, _, _, _, _, _, _, _), + PINGROUP(67, _, _, _, _, _, _, _, _, _), + PINGROUP(68, _, pa_indicator, phase_flag, _, _, _, _, _, _), + PINGROUP(69, mss_lte, _, _, _, _, _, _, _, _), + PINGROUP(70, mss_lte, _, _, _, _, _, _, _, _), + PINGROUP(71, _, _, _, _, _, _, _, _, _), + PINGROUP(72, _, _, _, _, _, _, _, _, _), + PINGROUP(73, _, _, _, _, _, _, _, _, _), + PINGROUP(74, _, _, _, _, _, _, _, _, _), + PINGROUP(75, _, _, _, _, _, _, _, _, _), + PINGROUP(76, _, _, _, nav_pps, nav_pps, phase_flag, _, _, _), + PINGROUP(77, _, _, _, nav_pps, nav_pps, _, _, _, _), + PINGROUP(78, _, _, _, _, _, _, _, _, _), + PINGROUP(79, _, _, phase_flag, _, _, _, _, _, _), + PINGROUP(80, _, _, phase_flag, _, _, _, _, _, _), + PINGROUP(81, _, _, _, nav_pps, nav_pps, qup_l4, mdp_vsync, emac_pps, _), + PINGROUP(82, _, _, _, nav_pps, nav_pps, qup_l5, mdp_vsync, _, _), + PINGROUP(83, qup12, qup16, _, qdss, _, _, _, _, _), + PINGROUP(84, qup12, qup16, _, _, _, _, _, _, _), + PINGROUP(85, qup12, qup16, _, _, _, _, _, _, _), + PINGROUP(86, qup12, qup16, _, _, _, _, _, _, _), + PINGROUP(87, _, _, _, _, _, _, _, _, _), + PINGROUP(88, tsif1, qup8, qspi_cs, tgu_ch3, _, _, _, _, _), + PINGROUP(89, tsif1, qup8, qspi0, mdp_vsync0, mdp_vsync1, mdp_vsync2, + mdp_vsync3, tgu_ch0, _), + PINGROUP(90, tsif1, qup8, qspi1, sdc4, phase_flag, tgu_ch1, _, _, + wlan1_adc1), + PINGROUP(91, tsif1, qup8, qspi2, sdc4, vfr_1, phase_flag, tgu_ch2, + _, _), + PINGROUP(92, tsif2, qup11, qspi_clk, sdc4, phase_flag, _, wlan2_adc1, + _, _), + PINGROUP(93, tsif2, qup11, qspi3, sdc4, phase_flag, _, wlan2_adc0, + _, _), + PINGROUP(94, tsif2, qup11, qspi_cs, sdc4, phase_flag, _, _, _, _), + PINGROUP(95, tsif2, qup11, sdc4, qup_l4, _, _, _, _, _), + PINGROUP(96, tsif2, qup_l5, phase_flag, _, _, _, _, _, _), + PINGROUP(97, sd_write, tsif1, qup_l6, _, _, _, _, _, _), + PINGROUP(98, qup7, ddr_bist, ddr_pxi3, _, _, _, _, _, _), + PINGROUP(99, qup7, ddr_bist, atest_usb13, ddr_pxi1, _, _, _, _, _), + PINGROUP(100, qup7, pll_bypassnl, atest_usb12, ddr_pxi1, _, _, _, _, _), + PINGROUP(101, qup7, pll_reset, ddr_pxi3, _, _, _, _, _, _), + PINGROUP(102, pci_e1, _, _, _, _, _, _, _, _), + PINGROUP(103, pci_e1, _, _, _, _, _, _, _, _), + PINGROUP(104, _, _, _, _, _, _, _, _, _), + PINGROUP(105, uim2, _, _, _, _, _, _, _, _), + PINGROUP(106, uim2, _, _, _, _, _, _, _, _), + PINGROUP(107, uim2, _, _, _, _, _, _, _, _), + PINGROUP(108, uim2, _, _, _, _, _, _, _, _), + PINGROUP(109, uim1, _, _, _, _, _, _, _, _), + PINGROUP(110, uim1, _, _, _, _, _, _, _, _), + PINGROUP(111, uim1, _, _, _, _, _, _, _, _), + PINGROUP(112, uim1, _, _, _, _, _, _, _, _), + PINGROUP(113, uim_batt, usb2phy_ac, aoss_cti, _, _, _, _, _, _), + PINGROUP(114, qup1, rgmii, phase_flag, _, _, _, _, _, _), + PINGROUP(115, qup1, rgmii, phase_flag, adsp_ext, _, _, _, _, _), + PINGROUP(116, qup1, rgmii, phase_flag, _, _, _, _, _, _), + PINGROUP(117, qup1, rgmii, phase_flag, _, qdss, _, _, _, _), + PINGROUP(118, rgmii, phase_flag, _, qdss, _, _, _, _, _), + PINGROUP(119, qup5, rgmii, phase_flag, _, qdss, _, _, _, _), + PINGROUP(120, qup5, rgmii, phase_flag, _, qdss, _, _, _, _), + PINGROUP(121, qup5, rgmii, phase_flag, _, qdss, _, _, _, _), + PINGROUP(122, qup5, rgmii, phase_flag, _, _, _, _, _, _), + PINGROUP(123, usb2phy_ac, qup_l6, atest_usb22, _, _, _, _, _, _), + PINGROUP(124, emac_phy, _, _, _, _, _, _, _, _), + PINGROUP(125, hs3_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(126, sec_mi2s, qup2, phase_flag, _, _, _, _, _, _), + PINGROUP(127, sec_mi2s, qup2, phase_flag, _, _, _, _, _, _), + PINGROUP(128, sec_mi2s, qup2, phase_flag, _, _, _, _, _, _), + PINGROUP(129, sec_mi2s, qup2, jitter_bist, atest_usb21, _, _, _, _, _), + PINGROUP(130, sec_mi2s, pll_bist, atest_usb20, atest_char0, + _, _, _, _, _), + PINGROUP(131, ter_mi2s, gcc_gp1, _, _, _, _, _, _, _), + PINGROUP(132, ter_mi2s, _, qdss, _, _, _, _, _, _), + PINGROUP(133, ter_mi2s, qdss, atest_char1, _, _, _, _, _, _), + PINGROUP(134, ter_mi2s, qdss, atest_char2, _, _, _, _, _, _), + PINGROUP(135, ter_mi2s, atest_char3, _, _, _, _, _, _, _), + PINGROUP(136, qua_mi2s, gcc_gp1, _, _, _, _, _, _, _), + PINGROUP(137, qua_mi2s, gcc_gp2, _, _, _, _, _, _, _), + PINGROUP(138, qua_mi2s, gcc_gp3, _, _, _, _, _, _, _), + PINGROUP(139, qua_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(140, qua_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(141, qua_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(142, qua_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(143, pri_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(144, pri_mi2s, qup3, phase_flag, _, ddr_pxi0, _, _, _, _), + PINGROUP(145, pri_mi2s_ws, qup3, phase_flag, ddr_bist, _, + vsense_trigger, atest_usb1, ddr_pxi0, _), + PINGROUP(146, pri_mi2s, qup3, ddr_bist, atest_usb11, ddr_pxi2, + _, _, _, _), + PINGROUP(147, pri_mi2s, qup3, dbg_out, atest_usb10, ddr_pxi2, + _, _, _, _), + PINGROUP(148, spkr_i2s, audio_ref, _, _, _, _, _, _, _), + PINGROUP(149, lpass_slimbus, spkr_i2s, _, _, _, _, _, _, _), + PINGROUP(150, lpass_slimbus, spkr_i2s, tsense_pwm1, tsense_pwm2, + _, _, _, _, _), + PINGROUP(151, lpass_slimbus, spkr_i2s, _, _, _, _, _, _, _), + PINGROUP(152, lpass_slimbus, spkr_i2s, _, _, _, _, _, _, _), + PINGROUP(153, btfm_slimbus, _, _, _, _, _, _, _, _), + PINGROUP(154, btfm_slimbus, _, _, _, _, _, _, _, _), + PINGROUP(155, hs1_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(156, hs1_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(157, hs1_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(158, hs1_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(159, hs1_mi2s, cri_trng0, _, _, _, _, _, _, _), + PINGROUP(160, hs2_mi2s, cri_trng1, _, _, _, _, _, _, _), + PINGROUP(161, hs2_mi2s, cri_trng, _, _, _, _, _, _, _), + PINGROUP(162, hs2_mi2s, sp_cmu, _, _, _, _, _, _, _), + PINGROUP(163, hs2_mi2s, prng_rosc, _, _, _, _, _, _, _), + PINGROUP(164, hs2_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(165, hs3_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(166, hs3_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(167, hs3_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(168, hs3_mi2s, _, _, _, _, _, _, _, _), + PINGROUP(169, _, _, _, _, _, _, _, _, _), + PINGROUP(170, _, _, _, _, _, _, _, _, _), + PINGROUP(171, _, _, _, _, _, _, _, _, _), + PINGROUP(172, _, _, _, _, _, _, _, _, _), + PINGROUP(173, _, _, _, _, _, _, _, _, _), + PINGROUP(174, _, _, _, _, _, _, _, _, _), +}; + +static const char *sm8150_get_function_name(struct udevice *dev, + unsigned int selector) +{ + return msm_pinctrl_functions[selector].name; +} + +static const char *sm8150_get_pin_name(struct udevice *dev, + unsigned int selector) +{ + snprintf(pin_name, MAX_PIN_NAME_LEN, "gpio%u", selector); + return pin_name; +} + +static unsigned int sm8150_get_function_mux(unsigned int pin, + unsigned int selector) +{ + unsigned int i; + const msm_pin_function *func = sm8150_pin_functions + pin; + + for (i = 0; i < 10; i++) + if ((*func)[i] == selector) + return i; + + pr_err("Can't find requested function for pin %u pin\n", pin); + return 0; +} + +static struct msm_pinctrl_data sm8150_data = { + .pin_data = { + .pin_offsets = sm8150_pin_offsets, + .pin_count = ARRAY_SIZE(sm8150_pin_offsets), + }, + .functions_count = ARRAY_SIZE(msm_pinctrl_functions), + .get_function_name = sm8150_get_function_name, + .get_function_mux = sm8150_get_function_mux, + .get_pin_name = sm8150_get_pin_name, +}; + +static const struct udevice_id msm_pinctrl_ids[] = { + { .compatible = "qcom,sm8150-pinctrl", .data = (ulong)&sm8150_data }, + { /* Sentinel */ } +}; + +U_BOOT_DRIVER(pinctrl_sm8150) = { + .name = "pinctrl_sm8150", + .id = UCLASS_NOP, + .of_match = msm_pinctrl_ids, + .ops = &msm_pinctrl_ops, + .bind = msm_pinctrl_bind, +};
This patch series adds support for Qualcomm SA8155-ADP development board. Main motivation for this series is to allow running virtualization software on this board and U-Boot is a good way to break Qualcomm's boot chain at EL2 with more convenient ways for uploading and running the code. With this patches applied it is possible to upload and run Xen on this board. KVM probably should work too.
This is really cool! I've experimented with this on SDM845 and SM8250 but never really did anything with it... I'd love to take a look at your Xen branch?
I added myself as a maintainer for this board, but my abilities to maintain it are quite limited as I have no access to Qualcomm documentation. I used mostly Linux drivers as the source for device-specific information, like register addresses and offsets. If anyone wants to maintain this, I will gladly agree.
Volodymyr Babchuk (8): clk: qcom: clear div mask before assigning new divider dts: qcom: import device trees and bindings for SA8155P-ADP net: dw_eth_qos: add support for Qualcomm SM8150 SoC clk: qcom: add support for power domains uclass clk: qcom: add driver for SM8150 SoC pinctr: qcom: pass pin number to get_function_mux callback pinctrl: qcom: add driver for SM8150 SoC board: add support for Qualcomm SA8155P-ADP board
arch/arm/dts/pmm8155au_1.dtsi | 135 + arch/arm/dts/pmm8155au_2.dtsi | 108 + arch/arm/dts/sa8155p-adp-u-boot.dtsi | 30 + arch/arm/dts/sa8155p-adp.dts | 606 ++ arch/arm/dts/sa8155p.dtsi | 40 + arch/arm/dts/sm8150.dtsi | 5293 +++++++++++++++++ arch/arm/mach-snapdragon/Kconfig | 14 + arch/arm/mach-snapdragon/Makefile | 2 + arch/arm/mach-snapdragon/init_sa8155p.c | 30 + arch/arm/mach-snapdragon/sysmap-sm8150.c | 31 + board/qualcomm/sa8155p-adp/Kconfig | 12 + board/qualcomm/sa8155p-adp/MAINTAINERS | 6 + configs/sa8155p_adp_defconfig | 33 + doc/board/qualcomm/index.rst | 1 + doc/board/qualcomm/sa8155p-adp.rst | 94 + drivers/clk/qcom/Kconfig | 8 + drivers/clk/qcom/Makefile | 1 + drivers/clk/qcom/clock-qcom.c | 96 +- drivers/clk/qcom/clock-qcom.h | 7 + drivers/clk/qcom/clock-sm8150.c | 234 + drivers/net/dwc_eth_qos.c | 4 + drivers/net/dwc_eth_qos.h | 2 + drivers/net/dwc_eth_qos_qcom.c | 47 +- drivers/pinctrl/qcom/Kconfig | 7 + drivers/pinctrl/qcom/Makefile | 1 + drivers/pinctrl/qcom/pinctrl-apq8016.c | 3 +- drivers/pinctrl/qcom/pinctrl-apq8096.c | 3 +- drivers/pinctrl/qcom/pinctrl-ipq4019.c | 3 +- drivers/pinctrl/qcom/pinctrl-qcom.c | 4 +- drivers/pinctrl/qcom/pinctrl-qcom.h | 3 +- drivers/pinctrl/qcom/pinctrl-qcs404.c | 3 +- drivers/pinctrl/qcom/pinctrl-sdm845.c | 3 +- drivers/pinctrl/qcom/pinctrl-sm8150.c | 589 ++ include/configs/sa8155p_adp.h | 25 + .../dt-bindings/clock/qcom,dispcc-sm8150.h | 76 + include/dt-bindings/clock/qcom,gcc-sm8150.h | 252 + include/dt-bindings/clock/qcom,gpucc-sm8150.h | 33 + include/dt-bindings/clock/qcom,rpmh.h | 37 + include/dt-bindings/dma/qcom-gpi.h | 11 + include/dt-bindings/firmware/qcom,scm.h | 39 + include/dt-bindings/iio/qcom,spmi-vadc.h | 303 + .../dt-bindings/interconnect/qcom,osm-l3.h | 15 + .../dt-bindings/interconnect/qcom,sm8150.h | 159 + include/dt-bindings/phy/phy-qcom-qmp.h | 20 + include/dt-bindings/power/qcom-rpmpd.h | 412 ++ .../regulator/qcom,rpmh-regulator.h | 36 + include/dt-bindings/soc/qcom,rpmh-rsc.h | 14 + 47 files changed, 8866 insertions(+), 19 deletions(-) create mode 100644 arch/arm/dts/pmm8155au_1.dtsi create mode 100644 arch/arm/dts/pmm8155au_2.dtsi create mode 100644 arch/arm/dts/sa8155p-adp-u-boot.dtsi create mode 100644 arch/arm/dts/sa8155p-adp.dts create mode 100644 arch/arm/dts/sa8155p.dtsi create mode 100644 arch/arm/dts/sm8150.dtsi create mode 100644 arch/arm/mach-snapdragon/init_sa8155p.c create mode 100644 arch/arm/mach-snapdragon/sysmap-sm8150.c create mode 100644 board/qualcomm/sa8155p-adp/Kconfig create mode 100644 board/qualcomm/sa8155p-adp/MAINTAINERS create mode 100644 configs/sa8155p_adp_defconfig create mode 100644 doc/board/qualcomm/sa8155p-adp.rst create mode 100644 drivers/clk/qcom/clock-sm8150.c create mode 100644 drivers/pinctrl/qcom/pinctrl-sm8150.c create mode 100644 include/configs/sa8155p_adp.h create mode 100644 include/dt-bindings/clock/qcom,dispcc-sm8150.h create mode 100644 include/dt-bindings/clock/qcom,gcc-sm8150.h create mode 100644 include/dt-bindings/clock/qcom,gpucc-sm8150.h create mode 100644 include/dt-bindings/clock/qcom,rpmh.h create mode 100644 include/dt-bindings/dma/qcom-gpi.h create mode 100644 include/dt-bindings/firmware/qcom,scm.h create mode 100644 include/dt-bindings/iio/qcom,spmi-vadc.h create mode 100644 include/dt-bindings/interconnect/qcom,osm-l3.h create mode 100644 include/dt-bindings/interconnect/qcom,sm8150.h create mode 100644 include/dt-bindings/phy/phy-qcom-qmp.h create mode 100644 include/dt-bindings/power/qcom-rpmpd.h create mode 100644 include/dt-bindings/regulator/qcom,rpmh-regulator.h create mode 100644 include/dt-bindings/soc/qcom,rpmh-rsc.h
Hi Caleb,
Honestly, there is nothing to look at right now. I just implemented early printk serial driver for the qcom, made hacks to the device tree and trying to boot Dom0. I already expecting issues with the GPU, because it has own SMMU without virtualization support and Xen already complains about it. So I had to remove it from the DTS for a time being.
Anyways, right now my Dom0 does not want to boot due to some issues with UFS. I suspect that some power domain or clock is disabled or some other bit of initialization is missing in the mainline Linux. And reason why bare Linux kernel have no issues with UFS is because aboot/xbl does proper UFS initialization, while in my case I am skipping the android bootloader completely...
I'll publish my work when I'll get Dom0 running.
On 01/03/2024 18:25, Volodymyr Babchuk wrote:
Hi Caleb,
Hmm, I see. You'll also definitely start running into issues with the DSPs and probably anything else that loads firmware. Qualcomm's hypervisor seems to be involved in booting a lot of the peripherals. The sc7180 Chromebook support is probably a good reference for how to do this in Linux as they also run in EL2.
Oh that's always fun...
For sure, I'd love to try it out!
It's really exciting to know you're working on this :D
Did you enable all the clocks/power domains/etc for the GPU SMMU? If I remember correctly it is off by default and all registers read as zeroes. The SMMU driver could easily get confused about the capabilities of the SMMU (e.g. the stage 2/virtualization support) if all the ID registers read as zeroes.
Thanks, Stephan
Hi Stephan,
Ah, this is a great idea, thanks. I tried a quick test by enabling only clocks that are provided by GCC, but looks like I need to enable GPUCC clocks as well. So I need to write a driver for GPUCC or at least figure which registers to write with a debugger. I'll try this later.
By the way, do you have any suggestion about my second issue? When Linux in the Dom0 tries to access UFS, CPU gets a secure interrupt and hangs in TZ. I had the same exactly behavior when I tried to access EMAC without enabling clocks and power domains in U-Boot. But Linux should enable all prerequisites for UFS... I suspect that there is an additional initialization needs to be done, but I didn't figured it yet.
On 04/03/2024 15:51, Volodymyr Babchuk wrote:
Hi Stephan,
Maybe it would be easiest to try enabling UFS in U-Boot first? I have it working on SDM845 and SM8250, so it should be easy enough to add SM8150 as well...
You can find the UFS and PHY patches in the branch linked below (sorry it's not very clean... Maybe easier to just add your drivers on top)
This way we can more easily dig in and see what the root cause is.
If you run into issues there let me know and I can maybe give it a try on an SM8150 HDK.
https://git.codelinaro.org/linaro/qcomlt/u-boot/-/commits/caleb/rbx-integrat...
On 3/4/24 16:51, Volodymyr Babchuk wrote:
Hi Stephan,
You'll probably also need to enable the CX GDSC (not sure about the order, probably GDSC and then clocks)
Konrad
participants (7)
Caleb Connolly
Dan Carpenter
Konrad Dybcio
Krzysztof Kozlowski
Stephan Gerhold
Sumit Garg
Volodymyr Babchuk
