[U-Boot] [PATCH] exynos: allow SPL to build in thumb mode
Building peach-pi smdk5420 and peach-pit with thumb mode for SPL ends-up in the following error:
Error: Thumb encoding does not support an immediate here -- `msr cpsr_c,#0x13|0xC0'
Use an intermediate register to be able to use thumb for exynos5 SPL.
Signed-off-by: Guillaume GARDET guillaume.gardet@free.fr
Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Minkyu Kang mk7.kang@samsung.com Cc: Tom Rini trini@konsulko.com
--- arch/arm/mach-exynos/include/mach/system.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-exynos/include/mach/system.h b/arch/arm/mach-exynos/include/mach/system.h index 4837781957..81fa9800b4 100644 --- a/arch/arm/mach-exynos/include/mach/system.h +++ b/arch/arm/mach-exynos/include/mach/system.h @@ -58,7 +58,8 @@ struct exynos5_sysreg { /* Move 0xd3 value to CPSR register to enable SVC mode */ #define svc32_mode_en() __asm__ __volatile__ \ ("@ I&F disable, Mode: 0x13 - SVC\n\t" \ - "msr cpsr_c, #0x13|0xC0\n\t" : : ) + "mov r0, #0x13|0xC0\n\t" \ + "msr cpsr_c, r0\n\t" : : )
/* Set program counter with the given value */ #define set_pc(x) __asm__ __volatile__ ("mov pc, %0\n\t" : : "r"(x))
applied to u-boot-samsung.
Thanks, Minkyu Kang.
On Wed, 2 Jan 2019 14:31:41 +0100 Guillaume GARDET guillaume.gardet@free.fr wrote:
This line needs "r0" to be also added to the clobber list. If you don't do this, then you may encounter sporadic r0 corruption problem depending on the compiler version or optimization settings.
This would be:
"msr cpsr_c, r0\n\t" : : : "r0")
See https://gcc.gnu.org/onlinedocs/gcc/Extended-Asm.html for more details.
An even better option is to just use something like this and give the compiler freedom to pick any register:
"msr cpsr_c, %0\n\t" : : "r"(0x13|0xC0))
This would be:
Thanks for the report Siarhei.
Minkyu, please merge also this patch: https://lists.denx.de/pipermail/u-boot/2019-January/353533.html
Thanks, Guillaume
-- Best regards, Siarhei Siamashka
Guillaume GARDET
Minkyu Kang
Siarhei Siamashka
