[U-Boot] Please pull u-boot-dm
Hi Tom,
Here are a few more test patches.
The following changes since commit 39af3d8a0db0aab3f78ae5576f0f5c668505a667:
sniper: Drop references to P970 (2016-02-08 10:24:19 -0500)
git://git.denx.de/u-boot-dm.git
for you to fetch changes up to c82ce04a3f38bb91465da6b2fd9d8dcb0e81f94b:
test/py: capture the entire U-Boot version at boot (2016-02-09 15:41:19 -0700)
---------------------------------------------------------------- Stephen Warren (6): gunzip: remove avail_in recalculation itest: allow map_physmem to return 0 in limited cases test/py: exit(1) if there are problems running py.test test/py: HTML awesome! test/py: fix off-by-one error in spawn matching code test/py: capture the entire U-Boot version at boot
cmd/itest.c | 2 +- lib/gunzip.c | 3 +- test/py/conftest.py | 61 +++++++++++++--------- test/py/multiplexed_log.css | 41 ++++++++------- test/py/multiplexed_log.py | 142 +++++++++++++++++++++++++++++++++++++++----------- test/py/test.py | 1 + test/py/u_boot_console_base.py | 11 ++-- test/py/u_boot_console_exec_attach.py | 12 +++-- test/py/u_boot_spawn.py | 2 +- 9 files changed, 185 insertions(+), 90 deletions(-)
On Tue, Feb 09, 2016 at 03:43:59PM -0700, Simon Glass wrote:
Hi Tom,
