[U-Boot] Dataflash timeout error when changing clock speed
I have been using uboot with an AT91SAM9G20 processor. I use AT bootstrap to setup then uboot to load the kernel and start linux. This has been working perfectly until I tried to change my crystal from the default 18.432 Mhz to a 12Mhz. I am getting the following error when trying to load the kernel from dataflash
Error Timeout dataflash.c[460] FIXME: rc=-1
To change to the new clock speed I changed AT91_MAIN_CLOCK in include/configs/at91sam9260ek.h from 18432000 to 12000000. I looked in the clock.c and the dataflash driver code and it looks like everything is calculated off the values read from registers or that define. I also tried lowering the AT91_SPI_CLK to 10,000,000 but got the same result. So I'm not sure if there is anything else I need to set when modifying the clock speed. Also it seems like it can sometimes read the dataflash to get the environment settings, but always has an error when trying to get the kernel.
Im hoping its just some related setting I need to modify and haven't found. I would appreciate any thoughts and thanks for taking a look.
Details: Processor: AT91SAM9G20 tried with Uboot 2009.11 and 2010.06
Debug output, Problem boot:
U-Boot 2009.11 (Jul 14 2010 - 13:56:12)
CPU: AT91SAM9G20 Crystal frequency: 12 MHz CPU clock : 396 MHz Master clock : 132 MHz DRAM: 64 MB NAND: 128 MiB DataFlash:AT45DB321 Nb pages: 8192 Page Size: 528 Size= 4325376 bytes Logical address: 0xD0000000 Area 0: D0000000 to D00041FF (RO) Bootstrap Area 1: D0004200 to D00083FF Environment Area 2: D0008400 to D0041FFF (RO) U-Boot Area 3: D0042000 to D0251FFF Kernel Area 4: D0252000 to D041FFFF FS In: serial Out: serial Err: serial Net: macb0 macb0: link up, 10Mbps half-duplex (lpa: 0xffff) Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at 22200000 ... Image Name: linux-2.6 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3733120 Bytes = 3.6 MB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... Bad Data CRC ERROR: can't get kernel image! U-Boot> cp.b 0xD0042000 0x22000000 0x38F6A0 Error Timeout dataflash.c[460] FIXME: rc=-1 U-Boot>
Sometimes also an error at:
macb0: link up, 10Mbps half-duplex (lpa: 0xffff) Hit any key to stop autoboot: 0 Error Timeout dataflash.c[460] FIXME: rc=-1 ## Booting kernel from Legacy Image at 22200000 ...
-- Neal Peacock Vice President of Product Development Coin Free LLC 407-657-5971
Neal Peacock
