[U-Boot] [PATCH 1/1] efi_memory: do parameter checks first
The parameter checks should be done first.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_memory.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 5c53aaafdb..c56653f497 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -407,6 +407,9 @@ efi_status_t efi_get_memory_map(unsigned long *memory_map_size,
map_size = map_entries * sizeof(struct efi_mem_desc);
+ if (provided_map_size < map_size) + return EFI_BUFFER_TOO_SMALL; + *memory_map_size = map_size;
if (descriptor_size) @@ -415,9 +418,6 @@ efi_status_t efi_get_memory_map(unsigned long *memory_map_size, if (descriptor_version) *descriptor_version = EFI_MEMORY_DESCRIPTOR_VERSION;
- if (provided_map_size < map_size) - return EFI_BUFFER_TOO_SMALL; - /* Copy list into array */ if (memory_map) { /* Return the list in ascending order */
