[U-Boot] [u-boot][RFC v1] sdp4430: Enable Falcon boot mode for mmc (RAW and FAT)
Add support to boot Linux directly from U-Boot SPL via eMMC (or RAW SD Cards) and FAT SD Cards. Jump into full U-Boot if a corresponding button is pressed.
Also define new CONFIG_BOOTCOMMAND to add ability for full U-Boot to boot Linux via eMMC (or RAW SD cards) and FAT SD Cards in case of using CONFIG_SPL_OS_BOOT feature. Set MMCDEV_DEFAULT to 1 in CONFIG_EXTRA_ENV_SETTINGS, since the target device is mmc1 (eMMC).
Also enable the spl command in the full U-Boot so the kernel parameter area snapshot can be created.
Signed-off-by: Oleksandr Tyshchenko oleksandr.tyshchenko@ti.com --- board/ti/sdp4430/sdp.c | 23 ++++++++++++++ board/ti/sdp4430/sdp4430_mux_data.h | 5 +++ include/configs/omap4_common.h | 57 +++++++++++++++++++++++++++++++++-- include/configs/omap4_sdp4430.h | 10 +++++- 4 files changed, 92 insertions(+), 3 deletions(-)
diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index 9f457e7..66ee574 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -26,6 +26,7 @@ #include <twl6030.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h> +#include <asm/gpio.h>
#include "sdp4430_mux_data.h"
@@ -69,6 +70,28 @@ int misc_init_r(void) return 0; }
+#ifdef CONFIG_SPL_OS_BOOT +/* + * SDP4430 specific implementation of spl_start_uboot() + * + * RETURN + * 0 if the button is not pressed + * 1 if the button is pressed + */ +int spl_start_uboot(void) +{ + int val = 0; + + if (!gpio_request(SPL_OS_BOOT_KEY, "U-Boot key")) { + gpio_direction_input(SPL_OS_BOOT_KEY); + val = gpio_get_value(SPL_OS_BOOT_KEY); + gpio_free(SPL_OS_BOOT_KEY); + } + + return val; +} +#endif + void set_muxconf_regs_essential(void) { do_set_mux((*ctrl)->control_padconf_core_base, diff --git a/board/ti/sdp4430/sdp4430_mux_data.h b/board/ti/sdp4430/sdp4430_mux_data.h index 0760dad..6ddd22d 100644 --- a/board/ti/sdp4430/sdp4430_mux_data.h +++ b/board/ti/sdp4430/sdp4430_mux_data.h @@ -65,6 +65,9 @@ const struct pad_conf_entry core_padconf_array_essential[] = { {USBA0_OTG_CE, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* usba0_otg_ce */ {USBA0_OTG_DP, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dp */ {USBA0_OTG_DM, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dm */ +#ifdef CONFIG_SPL_OS_BOOT +{GPMC_A22, (IEN | M3)}, /* gpio_46 */ +#endif };
const struct pad_conf_entry wkup_padconf_array_essential[] = { @@ -96,7 +99,9 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_A19, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row7 */ {GPMC_A20, (IEN | M3)}, /* gpio_44 */ {GPMC_A21, (M3)}, /* gpio_45 */ +#ifndef CONFIG_SPL_OS_BOOT {GPMC_A22, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col6 */ +#endif {GPMC_A23, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col7 */ {GPMC_A24, (PTD | M3)}, /* gpio_48 */ {GPMC_A25, (PTD | M3)}, /* gpio_49 */ diff --git a/include/configs/omap4_common.h b/include/configs/omap4_common.h index 2fa4382..da3a62f 100644 --- a/include/configs/omap4_common.h +++ b/include/configs/omap4_common.h @@ -145,6 +145,16 @@
#define CONFIG_ENV_OVERWRITE
+#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ +#define CONFIG_SILENT_CONSOLE 1 /* needed to silence "fatinfo mmc 0" */ +#define CONFIG_BOOTCOMMAND CONFIG_RAW_FAT_BOOTCOMMAND +#define MMCDEV_DEFAULT "1" +#else +#define CONFIG_BOOTCOMMAND CONFIG_COMMON_BOOTCOMMAND +#define MMCDEV_DEFAULT "0" +#endif + #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x82000000\0" \ "console=ttyO2,115200n8\0" \ @@ -156,7 +166,7 @@ "bootfile=zImage\0" \ "usbtty=cdc_acm\0" \ "vram=16M\0" \ - "mmcdev=0\0" \ + "mmcdev="MMCDEV_DEFAULT"\0" \ "mmcroot=/dev/mmcblk0p2 rw\0" \ "mmcrootfstype=ext3 rootwait\0" \ "mmcargs=setenv bootargs console=${console} " \ @@ -186,7 +196,7 @@ "echo WARNING: Could not determine device tree to use; fi; \0" \ "loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \
-#define CONFIG_BOOTCOMMAND \ +#define CONFIG_COMMON_BOOTCOMMAND \ "run findfdt; " \ "mmc dev ${mmcdev}; if mmc rescan; then " \ "echo SD/MMC found on device ${mmcdev};" \ @@ -207,6 +217,34 @@ "fi; " \ "fi"
+#define CONFIG_RAW_FAT_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "echo SD/MMC found on device ${mmcdev}; " \ + "setenv stdout nulldev; " \ + "if fatinfo mmc ${mmcdev}; then " \ + "setenv stdout serial; " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "echo Booting from mmc ${mmcdev} ...; " \ + "fatload mmc ${mmcdev} 0x81000000 uImage; " \ + "fatload mmc ${mmcdev} 0x82000000 args; " \ + "bootm 81000000 - 82000000; " \ + "fi;" \ + "else " \ + "setenv stdout serial; " \ + "mmc read 0x82000000 0x700 0x1FF; " \ + "if iminfo 0x82000000; then " \ + "run bootscript; " \ + "else " \ + "echo Booting from mmc ${mmcdev} ...; " \ + "mmc read 0x81000000 0x900 0x10000; " \ + "mmc read 0x82000000 0x80 0x80; " \ + "bootm 81000000 - 82000000; " \ + "fi; " \ + "fi; " \ + "fi" + #define CONFIG_AUTO_COMPLETE 1
/* @@ -291,6 +329,21 @@ #define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 #define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img"
+#ifdef CONFIG_SPL_OS_BOOT +/* fat */ +#define CONFIG_SPL_FAT_LOAD_KERNEL_NAME "uImage" +#define CONFIG_SPL_FAT_LOAD_ARGS_NAME "args" +#define CONFIG_SYS_SPL_ARGS_ADDR 0x82000000 + +/* raw mmc */ +#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0x900 /* address 0x120000 */ +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x80 /* address 0x10000 */ +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x80 /* 64KiB */ + +/* spl export command */ +#define CONFIG_CMD_SPL +#endif + #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBDISK_SUPPORT #define CONFIG_SPL_I2C_SUPPORT diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 9a4dea0..baa4f48 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -35,6 +35,12 @@ #define CONFIG_4430SDP 1 /* working with SDP */ #define CONFIG_MACH_TYPE MACH_TYPE_OMAP_4430SDP
+/* activate Falcon mode */ +#define CONFIG_SPL_OS_BOOT + +/* GPIO used to select between U-Boot and kernel */ +#define SPL_OS_BOOT_KEY 46 + #include <configs/omap4_common.h>
/* Battery Charger */ @@ -43,9 +49,11 @@ #endif
/* ENV related config options */ -#define CONFIG_ENV_IS_IN_MMC 1 +#define CONFIG_ENV_IS_NOWHERE 1 /* for now */ +#ifdef CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_ENV_OFFSET 0xE0000 +#endif #define CONFIG_CMD_SAVEENV
#define CONFIG_SYS_PROMPT "OMAP4430 SDP # "
My only question is:
Why are we taking env in eMMC support away by default? Is this related to using the boot partitions? If so, shouldn't we re-work this to fit that use as well (maybe use the 2nd boot partition for env?). Thanks.
