[GIT PULL] sunxi: Remaining v2021.07 merge window changes
Hi Tom,
please pull this branch, containing the late part of the 2021.07 changes.
This fixes the broken H5 Ethernet and updates the R40 and A64 DT files, so nothing really critical.
Build-tested for all 156 sunxi boards, and boot tested on a A64, R40, H5 and H616 board. USB, SD card, eMMC, HDMI and Ethernet all work there (where applicable).
Thanks, Andre
========================= The following changes since commit 4dda435131251a94b29afd52f010cf1ec5a7ceb2:
Merge tag 'mips-pull-2021-04-24' of https://source.denx.de/u-boot/custodians/u-boot-mips (2021-04-24 19:39:14 -0400)
https://source.denx.de/u-boot/custodians/u-boot-sunxi.git master
for you to fetch changes up to 647b392bf20614006917d5fcd3390347a668eee5:
sunxi: DT: A64: Update devicetree files from Linux 5.12 (2021-04-26 10:12:35 +0100)
---------------------------------------------------------------- Andre Przywara (2): net: sun8i-emac: Fix pinmux setup for Allwinner H5 sunxi: DT: A64: Update devicetree files from Linux 5.12
Ivan Uvarov (1): sunxi: DT: R40: Update device tree files from Linux 5.12
arch/arm/dts/sun50i-a64-bananapi-m64.dts | 16 +- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 2 +- arch/arm/dts/sun50i-a64-orangepi-win.dts | 10 +- arch/arm/dts/sun50i-a64-pine64-lts.dts | 15 + arch/arm/dts/sun50i-a64-pine64-plus.dts | 2 +- arch/arm/dts/sun50i-a64-pine64.dts | 8 +- arch/arm/dts/sun50i-a64-pinebook.dts | 13 +- arch/arm/dts/sun50i-a64-pinephone-1.0.dts | 7 +- arch/arm/dts/sun50i-a64-pinephone-1.1.dts | 7 +- arch/arm/dts/sun50i-a64-pinephone-1.2.dts | 16 +- arch/arm/dts/sun50i-a64-pinephone.dtsi | 90 ++++- arch/arm/dts/sun50i-a64-pinetab-early-adopter.dts | 26 ++ arch/arm/dts/sun50i-a64-pinetab.dts | 13 +- arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 11 +- arch/arm/dts/sun50i-a64-sopine.dtsi | 3 +- arch/arm/dts/sun50i-a64-teres-i.dts | 12 +- arch/arm/dts/sun50i-a64.dtsi | 40 ++- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 23 +- arch/arm/dts/sun8i-r40.dtsi | 375 +++++++++++++++++++-- arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts | 12 +- drivers/net/sun8i_emac.c | 8 +- include/dt-bindings/clock/sun8i-r40-ccu.h | 6 +- include/dt-bindings/interrupt-controller/arm-gic.h | 5 +- include/dt-bindings/thermal/thermal.h | 3 +- 24 files changed, 596 insertions(+), 127 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-pinetab-early-adopter.dts
On Mon, Apr 26, 2021 at 11:50:58AM +0100, Andre Przywara wrote:
Hi Tom,
Thanks, Andre
Andre Przywara
