Please pull u-boot-marvell/master
Hi Tom,
please pull this last minute fix:
---------------------------------------------------------------- - orion-timer: Fix problem with early static variable (Stefan) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=279&view=resu...
Thanks, Stefan
The following changes since commit 3089d12a02efd1dc5dce01e0ec0fda9142693b11:
configs: Resync with savedefconfig (2022-12-29 13:44:21 -0500)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 5387b093cb7914b3c0404da928fa4bafdffac291:
timer: orion-timer: Fix problem with early static variable (2023-01-02 09:14:16 +0100)
---------------------------------------------------------------- Stefan Roese (1): timer: orion-timer: Fix problem with early static variable
drivers/timer/orion-timer.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
Stefan Roese
