[U-Boot] [PATCH] arm64: zynqmp: Add support for zcu216
zcu104/6 defconfig was used as source. Standard features are enabled.
arch/arm/dts/Makefile | 1 + arch/arm/dts/zynqmp-zcu216-revA.dts | 592 ++++++++++++++++++++ configs/xilinx_zynqmp_zcu216_revA_defconfig | 98 ++++ 3 files changed, 691 insertions(+) create mode 100644 arch/arm/dts/zynqmp-zcu216-revA.dts create mode 100644 configs/xilinx_zynqmp_zcu216_revA_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f37d20c38f66..6a281bd9b0be 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -268,6 +268,7 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-zcu111-revA.dtb \ zynqmp-zcu1275-revA.dtb \ zynqmp-zcu1275-revB.dtb \ + zynqmp-zcu216-revA.dtb \ zynqmp-zc1232-revA.dtb \ zynqmp-zc1254-revA.dtb \ zynqmp-zc1751-xm015-dc1.dtb \ diff --git a/arch/arm/dts/zynqmp-zcu216-revA.dts b/arch/arm/dts/zynqmp-zcu216-revA.dts new file mode 100644 index 000000000000..dd9cd7b38f37 --- /dev/null +++ b/arch/arm/dts/zynqmp-zcu216-revA.dts @@ -0,0 +1,592 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * dts file for Xilinx ZynqMP ZCU216 + * + * (C) Copyright 2017 - 2019, Xilinx, Inc. + * + * Michal Simek michal.simek@xilinx.com + */ + +/dts-v1/; + +#include "zynqmp.dtsi" +#include "zynqmp-clk-ccf.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/phy/phy.h> + +/ { + model = "ZynqMP ZCU216 RevA"; + compatible = "xlnx,zynqmp-zcu216-revA", "xlnx,zynqmp-zcu216", "xlnx,zynqmp"; + + aliases { + ethernet0 = &gem3; + gpio0 = &gpio; + i2c0 = &i2c0; + i2c1 = &i2c1; + mmc0 = &sdhci1; + rtc0 = &rtc; + serial0 = &uart0; + serial1 = &dcc; + spi0 = &qspi; + usb0 = &usb0; + }; + + chosen { + bootargs = "earlycon"; + stdout-path = "serial0:115200n8"; + xlnx,eeprom = <&eeprom>; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>, <0x8 0x00000000 0x0 0x80000000>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + sw19 { + label = "sw19"; + gpios = <&gpio 22 GPIO_ACTIVE_HIGH>; + linux,code = <KEY_DOWN>; + gpio-key,wakeup; + autorepeat; + }; + }; + + leds { + compatible = "gpio-leds"; + heartbeat_led { + label = "heartbeat"; + gpios = <&gpio 23 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + ina226-vccint { + compatible = "iio-hwmon"; + io-channels = <&vccint 0>, <&vccint 1>, <&vccint 2>, <&vccint 3>; + }; + ina226-vccint-io-bram-ps { + compatible = "iio-hwmon"; + io-channels = <&vccint_io_bram_ps 0>, <&vccint_io_bram_ps 1>, <&vccint_io_bram_ps 2>, <&vccint_io_bram_ps 3>; + }; + ina226-vcc1v8 { + compatible = "iio-hwmon"; + io-channels = <&vcc1v8 0>, <&vcc1v8 1>, <&vcc1v8 2>, <&vcc1v8 3>; + }; + ina226-vcc1v2 { + compatible = "iio-hwmon"; + io-channels = <&vcc1v2 0>, <&vcc1v2 1>, <&vcc1v2 2>, <&vcc1v2 3>; + }; + ina226-vadj-fmc { + compatible = "iio-hwmon"; + io-channels = <&vadj_fmc 0>, <&vadj_fmc 1>, <&vadj_fmc 2>, <&vadj_fmc 3>; + }; + ina226-mgtavcc { + compatible = "iio-hwmon"; + io-channels = <&mgtavcc 0>, <&mgtavcc 1>, <&mgtavcc 2>, <&mgtavcc 3>; + }; + ina226-mgt1v2 { + compatible = "iio-hwmon"; + io-channels = <&mgt1v2 0>, <&mgt1v2 1>, <&mgt1v2 2>, <&mgt1v2 3>; + }; + ina226-mgt1v8 { + compatible = "iio-hwmon"; + io-channels = <&mgt1v8 0>, <&mgt1v8 1>, <&mgt1v8 2>, <&mgt1v8 3>; + }; + ina226-vccint-ams { + compatible = "iio-hwmon"; + io-channels = <&vccint_ams 0>, <&vccint_ams 1>, <&vccint_ams 2>, <&vccint_ams 3>; + }; + ina226-dac-avtt { + compatible = "iio-hwmon"; + io-channels = <&dac_avtt 0>, <&dac_avtt 1>, <&dac_avtt 2>, <&dac_avtt 3>; + }; + ina226-dac-avccaux { + compatible = "iio-hwmon"; + io-channels = <&dac_avccaux 0>, <&dac_avccaux 1>, <&dac_avccaux 2>, <&dac_avccaux 3>; + }; + ina226-adc-avcc { + compatible = "iio-hwmon"; + io-channels = <&adc_avcc 0>, <&adc_avcc 1>, <&adc_avcc 2>, <&adc_avcc 3>; + }; + ina226-adc-avccaux { + compatible = "iio-hwmon"; + io-channels = <&adc_avccaux 0>, <&adc_avccaux 1>, <&adc_avccaux 2>, <&adc_avccaux 3>; + }; + ina226-dac-avcc { + compatible = "iio-hwmon"; + io-channels = <&dac_avcc 0>, <&dac_avcc 1>, <&dac_avcc 2>, <&dac_avcc 3>; + }; +}; + +&dcc { + status = "okay"; +}; + +&fpd_dma_chan1 { + status = "okay"; +}; + +&fpd_dma_chan2 { + status = "okay"; +}; + +&fpd_dma_chan3 { + status = "okay"; +}; + +&fpd_dma_chan4 { + status = "okay"; +}; + +&fpd_dma_chan5 { + status = "okay"; +}; + +&fpd_dma_chan6 { + status = "okay"; +}; + +&fpd_dma_chan7 { + status = "okay"; +}; + +&fpd_dma_chan8 { + status = "okay"; +}; + +&gem3 { + status = "okay"; + phy-handle = <&phy0>; + phy-mode = "rgmii-id"; + phy0: ethernet-phy@c { + reg = <0xc>; + ti,rx-internal-delay = <0x8>; + ti,tx-internal-delay = <0xa>; + ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; + }; +}; + +&gpio { + status = "okay"; + gpio-line-names = "QSPI_LWR_CLK", "QSPI_LWR_DQ1", "QSPI_LWR_DQ2", "QSPI_LWR_DQ3", "QSPI_LWR_DQ0", /* 0 - 4 */ + "QSPI_LWR_CS_B", "", "QSPI_UPR_CS_B", "QSPI_UPR_DQ0", "QSPI_UPR_DQ1", /* 5 - 9 */ + "QSPI_UPR_DQ2", "QSPI_UPR_DQ3", "QSPI_UPR_CLK", "PS_GPIO2", "I2C0_SCL", /* 10 - 14 */ + "I2C0_SDA", "I2C1_SCL", "I2C1_SDA", "UART0_TXD", "UART0_RXD", /* 15 - 19 */ + "", "", "BUTTON", "LED", "", /* 20 - 24 */ + "", "PMU_INPUT", "", "", "", /* 25 - 29 */ + "", "", "PMU_GPO0", "PMU_GPO1", "PMU_GPO2", /* 30 - 34 */ + "PMU_GPO3", "PMU_GPO4", "PMU_GPO5", "PS_GPIO1", "SDIO_SEL", /* 35 - 39 */ + "SDIO_DIR_CMD", "SDIO_DIR_DAT0", "SDIO_DIR_DAT1", "", "", /* 40 - 44 */ + "SDIO_DETECT", "SDIO_DAT0", "SDIO_DAT1", "SDIO_DAT2", "SDIO_DAT3", /* 45 - 49 */ + "SDIO_CMD", "SDIO_CLK", "USB_CLK", "USB_DIR", "USB_DATA2", /* 50 - 54 */ + "USB_NXT", "USB_DATA0", "USB_DATA1", "USB_STP", "USB_DATA3", /* 55 - 59 */ + "USB_DATA4", "USB_DATA5", "USB_DATA6", "USB_DATA7", "ENET_TX_CLK", /* 60 - 64 */ + "ENET_TX_D0", "ENET_TX_D1", "ENET_TX_D2", "ENET_TX_D3", "ENET_TX_CTRL", /* 65 - 69 */ + "ENET_RX_CLK", "ENET_RX_D0", "ENET_RX_D1", "ENET_RX_D2", "ENET_RX_D3", /* 70 - 74 */ + "ENET_RX_CTRL", "ENET_MDC", "ENET_MDIO", /* 75 - 77, MIO end and EMIO start */ + "", "", /* 78 - 79 */ + "", "", "", "", "", /* 80 - 84 */ + "", "", "", "", "", /* 85 -89 */ + "", "", "", "", "", /* 90 - 94 */ + "", "", "", "", "", /* 95 - 99 */ + "", "", "", "", "", /* 100 - 104 */ + "", "", "", "", "", /* 105 - 109 */ + "", "", "", "", "", /* 110 - 114 */ + "", "", "", "", "", /* 115 - 119 */ + "", "", "", "", "", /* 120 - 124 */ + "", "", "", "", "", /* 125 - 129 */ + "", "", "", "", "", /* 130 - 134 */ + "", "", "", "", "", /* 135 - 139 */ + "", "", "", "", "", /* 140 - 144 */ + "", "", "", "", "", /* 145 - 149 */ + "", "", "", "", "", /* 150 - 154 */ + "", "", "", "", "", /* 155 - 159 */ + "", "", "", "", "", /* 160 - 164 */ + "", "", "", "", "", /* 165 - 169 */ + "", "", "", ""; /* 170 - 174 */ +}; + +&gpu { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + + tca6416_u15: gpio@20 { /* u15 */ + compatible = "ti,tca6416"; + reg = <0x20>; + gpio-controller; /* interrupt not connected */ + #gpio-cells = <2>; + gpio-line-names = "MAX6643_OT_B", "MAX6643_FANFAIL_B", "MIO26_PMU_INPUT_LS", "", /* 0 - 3 */ + "", "IIC_MUX_RESET_B", "GEM3_EXP_RESET_B", "MAX6643_FULL_SPEED", /* 4 - 7 */ + "FMCP_HSPC_PRSNT_M2C_B", "", "", "VCCINT_VRHOT_B", /* 10 - 13 */ + "", "8A34001_EXP_RST_B", "IRPS5401_ALERT_B", "INA226_PMBUS_ALERT"; /* 14 - 17 */ + }; + + i2c-mux@75 { /* u17 */ + compatible = "nxp,pca9544"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x75>; + i2c@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + /* PS_PMBUS */ + /* PMBUS_ALERT done via pca9544 */ + vccint: ina226@40 { /* u65 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-vccint"; + reg = <0x40>; + shunt-resistor = <5000>; + }; + vccint_io_bram_ps: ina226@41 { /* u57 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-vccint-io-bram-ps"; + reg = <0x41>; + shunt-resistor = <2000>; + }; + vcc1v8: ina226@42 { /* u60 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-vcc1v8"; + reg = <0x42>; + shunt-resistor = <2000>; + }; + vcc1v2: ina226@43 { /* u58 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-vcc1v2"; + reg = <0x43>; + shunt-resistor = <5000>; + }; + vadj_fmc: ina226@45 { /* u62 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-vadj-fmc"; + reg = <0x45>; + shunt-resistor = <5000>; + }; + mgtavcc: ina226@46 { /* u67 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-mgtavcc"; + reg = <0x46>; + shunt-resistor = <2000>; + }; + mgt1v2: ina226@47 { /* u63 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-mgt1v2"; + reg = <0x47>; + shunt-resistor = <5000>; + }; + mgt1v8: ina226@48 { /* u64 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-mgt1v8"; + reg = <0x48>; + shunt-resistor = <5000>; + }; + vccint_ams: ina226@49 { /* u61 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-vccint-ams"; + reg = <0x49>; + shunt-resistor = <2000>; + }; + dac_avtt: ina226@4a { /* u59 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-dac-avtt"; + reg = <0x4a>; + shunt-resistor = <5000>; + }; + dac_avccaux: ina226@4b { /* u124 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-dac-avccaux"; + reg = <0x4b>; + shunt-resistor = <5000>; + }; + adc_avcc: ina226@4c { /* u75 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-adc-avcc"; + reg = <0x4c>; + shunt-resistor = <5000>; + }; + adc_avccaux: ina226@4d { /* u71 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-adc-avccaux"; + reg = <0x4d>; + shunt-resistor = <5000>; + }; + dac_avcc: ina226@4e { /* u77 */ + compatible = "ti,ina226"; + #io-channel-cells = <1>; + label = "ina226-dac-avcc"; + reg = <0x4e>; + shunt-resistor = <5000>; + }; + }; + i2c@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + /* NC */ + }; + i2c@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + /* u104 - ir35215 0x10/0x40 */ + /* u127 - ir38164 0x1b/0x4b */ + /* u112 - ir38164 0x13/0x43 */ + /* u123 - ir38164 0x1c/0x4c */ + + irps5401_44: irps54012@44 { /* IRPS5401 - u53 */ + #clock-cells = <0>; + compatible = "infineon,irps5401"; + reg = <0x44>; /* i2c addr 0x14 */ + }; + irps5401_45: irps54012@45 { /* IRPS5401 - u55 */ + #clock-cells = <0>; + compatible = "infineon,irps5401"; + reg = <0x45>; /* i2c addr 0x15 */ + }; + /* J21 header too */ + + }; + i2c@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + /* SYSMON */ + }; + }; + /* u38 MPS430 */ +}; + +&i2c1 { + status = "okay"; + clock-frequency = <400000>; + + i2c-mux@74 { + compatible = "nxp,pca9548"; /* u20 */ + #address-cells = <1>; + #size-cells = <0>; + reg = <0x74>; + /* FIXME reset-gpios = <&tca6416_u15 SYSCTLR_IIC_MUX0_RESET_B GPIO_ACTIVE_HIGH>; */ + i2c_eeprom: i2c@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + /* + * IIC_EEPROM 1kB memory which uses 256B blocks + * where every block has different address. + * 0 - 256B address 0x54 + * 256B - 512B address 0x55 + * 512B - 768B address 0x56 + * 768B - 1024B address 0x57 + */ + eeprom: eeprom@54 { /* u21 */ + compatible = "atmel,24c08"; + reg = <0x54>; + }; + }; + i2c_si5341: i2c@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + si5341: clock-generator@36 { /* SI5341 - u43 */ + compatible = "si5341"; + reg = <0x36>; + }; + + }; + i2c_si570_user_c0: i2c@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + si570_1: clock-generator@5d { /* USER C0 SI570 - u47 */ + #clock-cells = <0>; + compatible = "silabs,si570"; + reg = <0x5d>; + temperature-stability = <50>; + factory-fout = <300000000>; + clock-frequency = <300000000>; + clock-output-names = "si570_user_c0"; + }; + }; + i2c_si570_mgt: i2c@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + si570_2: clock-generator@5d { /* USER MGT SI570 - u48 */ + #clock-cells = <0>; + compatible = "silabs,si570"; + reg = <0x5d>; + temperature-stability = <50>; + factory-fout = <156250000>; + clock-frequency = <148500000>; + clock-output-names = "si570_mgt"; + }; + }; + i2c_8a34001: i2c@4 { + #address-cells = <1>; + #size-cells = <0>; + reg = <4>; + /* U409B - 8a34001 */ + }; + i2c_clk104: i2c@5 { + #address-cells = <1>; + #size-cells = <0>; + reg = <5>; + /* CLK104_SDA */ + }; + i2c@6 { + #address-cells = <1>; + #size-cells = <0>; + reg = <6>; + /* RFMCP connector */ + }; + /* 7 NC */ + }; + + i2c-mux@75 { + compatible = "nxp,pca9548"; /* u22 */ + #address-cells = <1>; + #size-cells = <0>; + reg = <0x75>; + /* FIXME reset-gpios = <&tca6416_u15 SYSCTLR_IIC_MUX0_RESET_B GPIO_ACTIVE_HIGH>; */ + i2c@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + /* FMCP_HSPC_IIC */ + }; + i2c_si570_user_c1: i2c@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + si570_3: clock-generator@5d { /* USER C1 SI570 - u130 */ + #clock-cells = <0>; + compatible = "silabs,si570"; + reg = <0x5d>; + temperature-stability = <50>; + factory-fout = <300000000>; + clock-frequency = <300000000>; + clock-output-names = "si570_user_c1"; + }; + }; + i2c@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + /* SYSMON */ + }; + i2c@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + /* DDR4 SODIMM */ + }; + i2c@4 { + #address-cells = <1>; + #size-cells = <0>; + reg = <4>; + /* SFP3 */ + }; + i2c@5 { + #address-cells = <1>; + #size-cells = <0>; + reg = <5>; + /* SFP2 */ + }; + i2c@6 { + #address-cells = <1>; + #size-cells = <0>; + reg = <6>; + /* SFP1 */ + }; + i2c@7 { + #address-cells = <1>; + #size-cells = <0>; + reg = <7>; + /* SFP0 */ + }; + }; + /* MSP430 */ +}; + +&qspi { + status = "okay"; + is-dual = <1>; + flash@0 { + compatible = "m25p80", "jedec,spi-nor"; /* U11 and U12 MT25QU02GCBBE12 1Gb */ + #address-cells = <1>; + #size-cells = <1>; + reg = <0x0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <4>; /* FIXME also DUAL configuration possible */ + spi-max-frequency = <108000000>; /* Based on DC1 spec */ + }; +}; + +&rtc { + status = "okay"; +}; + +&sata { + status = "okay"; + /* SATA OOB timing settings */ + ceva,p0-cominit-params = /bits/ 8 <0x18 0x40 0x18 0x28>; + ceva,p0-comwake-params = /bits/ 8 <0x06 0x14 0x08 0x0E>; + ceva,p0-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; + ceva,p0-retry-params = /bits/ 16 <0x96A4 0x3FFC>; + ceva,p1-cominit-params = /bits/ 8 <0x18 0x40 0x18 0x28>; + ceva,p1-comwake-params = /bits/ 8 <0x06 0x14 0x08 0x0E>; + ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; + ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; + phy-names = "sata-phy"; + phys = <&lane3 PHY_TYPE_SATA 1 3 125000000>; +}; + +/* SD1 with level shifter */ +&sdhci1 { + status = "okay"; + disable-wp; + xlnx,mio_bank = <1>; +}; + +&serdes { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +/* ULPI SMSC USB3320 */ +&usb0 { + status = "okay"; +}; + +&dwc3_0 { + status = "okay"; + dr_mode = "host"; + snps,usb3_lpm_capable; + phy-names = "usb3-phy"; + phys = <&lane2 PHY_TYPE_USB3 0 2 26000000>; +}; diff --git a/configs/xilinx_zynqmp_zcu216_revA_defconfig b/configs/xilinx_zynqmp_zcu216_revA_defconfig new file mode 100644 index 000000000000..4854ebcf5617 --- /dev/null +++ b/configs/xilinx_zynqmp_zcu216_revA_defconfig @@ -0,0 +1,98 @@ +CONFIG_ARM=y +CONFIG_ARCH_ZYNQMP=y +CONFIG_SYS_TEXT_BASE=0x8000000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xff000000 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_ZYNQMP_USB=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_ATF=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FPGA_LOADBP=y +CONFIG_CMD_FPGA_LOADP=y +CONFIG_CMD_FPGA_LOAD_SECURE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu111-revA" +CONFIG_ENV_IS_IN_FAT=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y +CONFIG_CLK_ZYNQMP=y +CONFIG_DFU_RAM=y +CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQMPPL=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 +CONFIG_SYS_I2C_EEPROM_ADDR=0x0 +CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW=0x0 +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SF_DUAL_FLASH=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHY_MARVELL=y +CONFIG_PHY_NATSEMI=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_TI=y +CONFIG_PHY_VITESSE=y +CONFIG_PHY_FIXED=y +CONFIG_PHY_GIGE=y +CONFIG_MII=y +CONFIG_ZYNQ_GEM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DEBUG_UART_ZYNQ=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ZYNQ_SERIAL=y +CONFIG_SPI=y +CONFIG_ZYNQMP_GQSPI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_ZYNQMP=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y
Michal Simek
