[PATCH] armv8: Update erratum number to align with doc
Change the USB erratum number A-050106 to A-050204 as A-050106 is a duplicate and never be published.
Fixes 0cfa00cdb94 (“armv8: Add workaround for USB erratum A-050106”) Signed-off-by: Ran Wang ran.wang_1@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 8 ++++---- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 4 ++-- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 9d1ba4c771..b15544030c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -223,7 +223,7 @@ config ARCH_LX2162A select SYS_FSL_DDR_VER_50 select SYS_FSL_EC1 select SYS_FSL_EC2 - select SYS_FSL_ERRATUM_A050106 + select SYS_FSL_ERRATUM_A050204 select SYS_FSL_HAS_RGMII select SYS_FSL_HAS_SEC select SYS_FSL_HAS_CCN508 @@ -253,7 +253,7 @@ config ARCH_LX2160A select SYS_FSL_DDR_VER_50 select SYS_FSL_EC1 select SYS_FSL_EC2 - select SYS_FSL_ERRATUM_A050106 + select SYS_FSL_ERRATUM_A050204 select SYS_FSL_HAS_RGMII select SYS_FSL_HAS_SEC select SYS_FSL_HAS_CCN508 @@ -371,8 +371,8 @@ config SYS_FSL_ERRATUM_A009008 config SYS_FSL_ERRATUM_A009798 bool "Workaround for USB PHY erratum A009798"
-config SYS_FSL_ERRATUM_A050106 - bool "Workaround for USB PHY erratum A050106" +config SYS_FSL_ERRATUM_A050204 + bool "Workaround for USB PHY erratum A050204" help USB3.0 Receiver needs to enable fixed equalization for each of PHY instances in an SOC. This is similar diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 7553b5bce2..b7e583859a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -218,7 +218,7 @@ static void erratum_a009007(void) }
#if defined(CONFIG_FSL_LSCH3) -static void erratum_a050106(void) +static void erratum_a050204(void) { #if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) void __iomem *dcsr = (void __iomem *)DCSR_BASE; @@ -378,7 +378,7 @@ void fsl_lsch3_early_init_f(void) erratum_a009798(); erratum_a008997(); erratum_a009007(); - erratum_a050106(); + erratum_a050204(); #ifdef CONFIG_CHAIN_OF_TRUST /* In case of Secure Boot, the IBR configures the SMMU * to allow only Secure transactions.
Ran Wang
