[GIT PULL] please pull fsl-qoriq-2022-7-3
Hi Tom,
Please pull fsl-qoriq-2022-7-3 based on your next branch for 2022.10 CI: https://source.denx.de/u-boot/custodians/u-boot-fsl-qoriq/-/pipelines/12603
-------------------------------------- Several patches from Pali - fsl_elbc detection fix - sort p2020 dts node, drop duplicated node - p1_p2_rdb_pc board cleanup - simplify mpc85xx _start_cont jumping code --------------------------------------
The following changes since commit 284c1a9b4b91120385c346a1924628a695314905:
Merge tag 'u-boot-at91-2022.10-a' of https://source.denx.de/u-boot/custodians/u-boot-at91 into next (2022-06-30 15:21:52 -0400)
https://source.denx.de/u-boot/custodians/u-boot-fsl-qoriq.git tags/fsl-qoriq-2022-7-3
for you to fetch changes up to 9167a1c28c2751b97ac48da5384e540e714a752a:
powerpc: mpc85xx: Simplify jump to _start_cont in flash code (2022-07-03 15:13:51 +0800)
---------------------------------------------------------------- Pali Rohár (7): mtd: rawnand: fsl_elbc: Fix detection when nand_scan_ident() has not selected ecc.mode powerpc: dts: p2020: Sort DT nodes by their addresses powerpc: dts: p2020: Remove duplicate pic@40000 node board: freescale: p1_p2_rdb_pc: Allow to compile without BOARD_NAME board: freescale: p1_p2_rdb_pc: Allow to compile without __SW_BOOT_SD macro board: freescale: p1_p2_rdb_pc: Remove mapping for TDM-PMC card powerpc: mpc85xx: Simplify jump to _start_cont in flash code
arch/powerpc/cpu/mpc85xx/start.S | 5 ++--- arch/powerpc/dts/p2020-post.dtsi | 77 +++++++++++++++++++++++++++++++++-------------------------------------------- board/freescale/p1_p2_rdb_pc/law.c | 1 - board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 11 +++++++++-- board/freescale/p1_p2_rdb_pc/tlb.c | 3 --- drivers/mtd/nand/raw/fsl_elbc_nand.c | 6 +++++- include/configs/p1_p2_rdb_pc.h | 9 --------- scripts/config_whitelist.txt | 4 ---- 8 files changed, 49 insertions(+), 67 deletions(-)
On Tue, Jul 05, 2022 at 01:29:19AM +0000, Peng Fan (OSS) wrote:
Hi Tom,
Peng Fan (OSS)
