[PATCH] net: e1000: Fix Unchecked return value coverity
Added check for return value of e1000_read_phy_reg().
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- drivers/net/e1000.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index 694114eca7..1f0d559415 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -4738,12 +4738,16 @@ e1000_phy_init_script(struct e1000_hw *hw) uint16_t fused, fine, coarse;
/* Move to analog registers page */ - e1000_read_phy_reg(hw, - IGP01E1000_ANALOG_SPARE_FUSE_STATUS, &fused); + if (e1000_read_phy_reg(hw, + IGP01E1000_ANALOG_SPARE_FUSE_STATUS, + &fused)) + return;
if (!(fused & IGP01E1000_ANALOG_SPARE_FUSE_ENABLED)) { - e1000_read_phy_reg(hw, - IGP01E1000_ANALOG_FUSE_STATUS, &fused); + if (e1000_read_phy_reg(hw, + IGP01E1000_ANALOG_FUSE_STATUS, + &fused)) + return;
fine = fused & IGP01E1000_ANALOG_FUSE_FINE_MASK; coarse = fused
&fused))
return; if (!(fused & IGP01E1000_ANALOG_SPARE_FUSE_ENABLED)) {
&fused))
return; fine = fused & IGP01E1000_ANALOG_FUSE_FINE_MASK; coarse = fused
-- 2.17.1
What about some error messages ?
-----Original Message----- From: Ramon Fried rfried.dev@gmail.com Sent: 2021年6月10日 13:49 To: Z.Q. Hou zhiqiang.hou@nxp.com Cc: Joe Hershberger joe.hershberger@ni.com; U-Boot Mailing List u-boot@lists.denx.de Subject: Re: [PATCH] net: e1000: Fix Unchecked return value coverity
&fused))
&fused))
coarse = fused
-- 2.17.1
CID 43664 (#15 of 15): Unchecked return value (CHECKED_RETURN) 6. check_return: Calling e1000_read_phy_reg without checking return value (as is done elsewhere 44 out of 47 times).
- Zhiqiang
&fused))
&fused))
coarse = fused
-- 2.17.1
- Zhiqiang
It's not clear enough why you're leaving the function early, better add some comments in the commit message and in the code.
-----Original Message----- From: Ramon Fried [mailto:rfried.dev@gmail.com] Sent: 2021年6月12日 7:47 To: Z.Q. Hou zhiqiang.hou@nxp.com Cc: Joe Hershberger joe.hershberger@ni.com; U-Boot Mailing List u-boot@lists.denx.de Subject: Re: [PATCH] net: e1000: Fix Unchecked return value coverity
*hw)
uint16_t fused, fine, coarse; /* Move to analog registers page */
&fused))
&fused))
coarse = fused
-- 2.17.1
- Zhiqiang
If it should continue to run while it failed to read the PHY registers? Anyone can comments on this?
Thanks, Zhiqiang
Ramon Fried
Z.Q. Hou
Zhiqiang Hou
