[U-Boot] [PATCH] i.MX28: bug fixes in PMU configuration code
Fixed some typos in the i.MX28 PMU code that sets up the VDDD and VDDIO power rails. In addition the VDDD and VDDIO brownout offset values should be divided by a step size before being programmed to the corresponding registers.
Signed-off-by: Stathis Voukelatos stathis.voukelatos@linn.co.uk Cc: Stefano Babic sbabic@denx.de Cc: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/arm926ejs/mx28/spl_power_init.c | 12 ++++++------ 1 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/spl_power_init.c b/arch/arm/cpu/arm926ejs/mx28/spl_power_init.c index 4b09b0c..cc71af8 100644 --- a/arch/arm/cpu/arm926ejs/mx28/spl_power_init.c +++ b/arch/arm/cpu/arm926ejs/mx28/spl_power_init.c @@ -716,7 +716,7 @@ int mx28_get_vddio_power_source_off(void) tmp = readl(&power_regs->hw_power_vddioctrl); if (tmp & POWER_VDDIOCTRL_DISABLE_FET) { if ((tmp & POWER_VDDIOCTRL_LINREG_OFFSET_MASK) == - POWER_VDDDCTRL_LINREG_OFFSET_0STEPS) { + POWER_VDDIOCTRL_LINREG_OFFSET_0STEPS) { return 1; } } @@ -724,7 +724,7 @@ int mx28_get_vddio_power_source_off(void) if (!(readl(&power_regs->hw_power_5vctrl) & POWER_5VCTRL_ENABLE_DCDC)) { if ((tmp & POWER_VDDIOCTRL_LINREG_OFFSET_MASK) == - POWER_VDDDCTRL_LINREG_OFFSET_0STEPS) { + POWER_VDDIOCTRL_LINREG_OFFSET_0STEPS) { return 1; } } @@ -772,7 +772,7 @@ void mx28_power_set_vddio(uint32_t new_target, uint32_t new_brownout) uint32_t cur_target, diff, bo_int = 0; uint32_t powered_by_linreg = 0;
- new_brownout = new_target - new_brownout; + new_brownout = (new_target - new_brownout + 25) / 50;
cur_target = readl(&power_regs->hw_power_vddioctrl); cur_target &= POWER_VDDIOCTRL_TRG_MASK; @@ -858,8 +858,8 @@ void mx28_power_set_vddio(uint32_t new_target, uint32_t new_brownout) }
clrsetbits_le32(&power_regs->hw_power_vddioctrl, - POWER_VDDDCTRL_BO_OFFSET_MASK, - new_brownout << POWER_VDDDCTRL_BO_OFFSET_OFFSET); + POWER_VDDIOCTRL_BO_OFFSET_MASK, + new_brownout << POWER_VDDIOCTRL_BO_OFFSET_OFFSET); }
void mx28_power_set_vddd(uint32_t new_target, uint32_t new_brownout) @@ -869,7 +869,7 @@ void mx28_power_set_vddd(uint32_t new_target, uint32_t new_brownout) uint32_t cur_target, diff, bo_int = 0; uint32_t powered_by_linreg = 0;
- new_brownout = new_target - new_brownout; + new_brownout = (new_target - new_brownout + 12) / 25;
cur_target = readl(&power_regs->hw_power_vdddctrl); cur_target &= POWER_VDDDCTRL_TRG_MASK;
Dear Stathis Voukelatos,
Will test it ASAP. I should be getting new board by next week, so I'll test- drive it on that one too.
Thanks for finding those!
new_brownout = (new_target - new_brownout + 25) / 50; cur_target = readl(&power_regs->hw_power_vddioctrl); cur_target &= POWER_VDDIOCTRL_TRG_MASK;
new_brownout = (new_target - new_brownout + 12) / 25; cur_target = readl(&power_regs->hw_power_vdddctrl); cur_target &= POWER_VDDDCTRL_TRG_MASK;
Best regards, Marek Vasut
All right, yet another minus point for my responsiveness :-(
Tested-by: Marek Vasut marex@denx.de Acked-by: Marek Vasut marex@denx.de
Fabio, can you give it a quick spin on mx28evk so we can roll this late into this release maybe ?
Hi Marek,
I don't have access to my mx28evk now and will be out of the office in the following 2 weeks.
Maybe Otavio could test it on a mx28evk?
Stefano, I think this should be applied.
THanks!
There are checkpatch errors that should be fixed before applying. Stathis, can you check them and resubmit ? Thanks.
Best regards, Stefano Babic
Dear Stefano Babic,
I can eventually resubmit if Stathis grew unhappy about the slow response time :-(
participants (5)
Fabio Estevam
Stathis Voukelatos
Stefano Babic
