[U-Boot] [PULL] : Please pull u-boot-imx
Hi Albert,
still a couple of patches for the release. Please pull from u-boot-imx, thanks !
The following changes since commit a6bbee66197759f790de83181924bf1d2cf482b2:
mx6slevk: Include "mx6_common.h" (2014-01-13 11:52:28 +0100)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 3a21773129f6ef218f1978d05a1a5d5cf6801ab6:
mx6: Add initial support for the Hummingboard solo (2014-01-15 10:33:25 +0100)
---------------------------------------------------------------- Fabio Estevam (2): mx6: clock: Pass the frequency as argument of enable_fec_anatop_clock() mx6: Add initial support for the Hummingboard solo
arch/arm/cpu/armv7/mx6/clock.c | 8 +- arch/arm/include/asm/arch-mx6/clock.h | 9 +- arch/arm/include/asm/arch-mx6/imx-regs.h | 4 + board/freescale/mx6slevk/mx6slevk.c | 2 +- board/solidrun/hummingboard/Makefile | 9 + board/solidrun/hummingboard/README | 40 ++++ board/solidrun/hummingboard/hummingboard.c | 187 ++++++++++++++++ board/solidrun/hummingboard/solo.cfg | 25 +++ board/solidrun/mx6-microsom/800mhz_2x128mx16.cfg | 74 +++++++ board/solidrun/mx6-microsom/clocks.cfg | 33 +++ .../mx6-microsom/ddr-800mhz-32bit-setup.cfg | 76 +++++++ boards.cfg | 1 + include/configs/hummingboard.h | 226 ++++++++++++++++++++ 13 files changed, 691 insertions(+), 3 deletions(-) create mode 100644 board/solidrun/hummingboard/Makefile create mode 100644 board/solidrun/hummingboard/README create mode 100644 board/solidrun/hummingboard/hummingboard.c create mode 100644 board/solidrun/hummingboard/solo.cfg create mode 100644 board/solidrun/mx6-microsom/800mhz_2x128mx16.cfg create mode 100644 board/solidrun/mx6-microsom/clocks.cfg create mode 100644 board/solidrun/mx6-microsom/ddr-800mhz-32bit-setup.cfg create mode 100644 include/configs/hummingboard.h
Hi Stefano,
On Wed, 15 Jan 2014 10:43:21 +0100, Stefano Babic sbabic@denx.de wrote:
Hi Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Stefano Babic
