[U-Boot] [PATCH v2 1/2] fttmr010: move fttmr010 header to include/faraday
Move the header file and definitions of fttmr010 power control unit from a320 SoC folder to "include/faraday" folder.
This change will let other SoC which also use fttmr010 could share the same header file.
Signed-off-by: Macpaul Lin macpaul@andestech.com --- Changes for v2: - Fix patch according to the dependent patches of a320evb in u-boot-arm.git "next" branch. - V1 patches of fttmr010 as "/patch/71952/" marked as "superseded" in patchworks. - Move files into "include/faraday" instead of "drivers/timer".
arch/arm/include/asm/arch-a320/fttmr010.h | 73 ----------------------------- include/faraday/fttmr010.h | 73 +++++++++++++++++++++++++++++ 2 files changed, 73 insertions(+), 73 deletions(-) delete mode 100644 arch/arm/include/asm/arch-a320/fttmr010.h create mode 100644 include/faraday/fttmr010.h
diff --git a/arch/arm/include/asm/arch-a320/fttmr010.h b/arch/arm/include/asm/arch-a320/fttmr010.h deleted file mode 100644 index 72abcb3..0000000 --- a/arch/arm/include/asm/arch-a320/fttmr010.h +++ /dev/null @@ -1,73 +0,0 @@ -/* - * (C) Copyright 2009 Faraday Technology - * Po-Yu Chuang ratbert@faraday-tech.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. - */ - -/* - * Timer - */ -#ifndef __FTTMR010_H -#define __FTTMR010_H - -struct fttmr010 { - unsigned int timer1_counter; /* 0x00 */ - unsigned int timer1_load; /* 0x04 */ - unsigned int timer1_match1; /* 0x08 */ - unsigned int timer1_match2; /* 0x0c */ - unsigned int timer2_counter; /* 0x10 */ - unsigned int timer2_load; /* 0x14 */ - unsigned int timer2_match1; /* 0x18 */ - unsigned int timer2_match2; /* 0x1c */ - unsigned int timer3_counter; /* 0x20 */ - unsigned int timer3_load; /* 0x24 */ - unsigned int timer3_match1; /* 0x28 */ - unsigned int timer3_match2; /* 0x2c */ - unsigned int cr; /* 0x30 */ - unsigned int interrupt_state; /* 0x34 */ - unsigned int interrupt_mask; /* 0x38 */ -}; - -/* - * Timer Control Register - */ -#define FTTMR010_TM3_UPDOWN (1 << 11) -#define FTTMR010_TM2_UPDOWN (1 << 10) -#define FTTMR010_TM1_UPDOWN (1 << 9) -#define FTTMR010_TM3_OFENABLE (1 << 8) -#define FTTMR010_TM3_CLOCK (1 << 7) -#define FTTMR010_TM3_ENABLE (1 << 6) -#define FTTMR010_TM2_OFENABLE (1 << 5) -#define FTTMR010_TM2_CLOCK (1 << 4) -#define FTTMR010_TM2_ENABLE (1 << 3) -#define FTTMR010_TM1_OFENABLE (1 << 2) -#define FTTMR010_TM1_CLOCK (1 << 1) -#define FTTMR010_TM1_ENABLE (1 << 0) - -/* - * Timer Interrupt State & Mask Registers - */ -#define FTTMR010_TM3_OVERFLOW (1 << 8) -#define FTTMR010_TM3_MATCH2 (1 << 7) -#define FTTMR010_TM3_MATCH1 (1 << 6) -#define FTTMR010_TM2_OVERFLOW (1 << 5) -#define FTTMR010_TM2_MATCH2 (1 << 4) -#define FTTMR010_TM2_MATCH1 (1 << 3) -#define FTTMR010_TM1_OVERFLOW (1 << 2) -#define FTTMR010_TM1_MATCH2 (1 << 1) -#define FTTMR010_TM1_MATCH1 (1 << 0) - -#endif /* __FTTMR010_H */ diff --git a/include/faraday/fttmr010.h b/include/faraday/fttmr010.h new file mode 100644 index 0000000..72abcb3 --- /dev/null +++ b/include/faraday/fttmr010.h @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * Timer + */ +#ifndef __FTTMR010_H +#define __FTTMR010_H + +struct fttmr010 { + unsigned int timer1_counter; /* 0x00 */ + unsigned int timer1_load; /* 0x04 */ + unsigned int timer1_match1; /* 0x08 */ + unsigned int timer1_match2; /* 0x0c */ + unsigned int timer2_counter; /* 0x10 */ + unsigned int timer2_load; /* 0x14 */ + unsigned int timer2_match1; /* 0x18 */ + unsigned int timer2_match2; /* 0x1c */ + unsigned int timer3_counter; /* 0x20 */ + unsigned int timer3_load; /* 0x24 */ + unsigned int timer3_match1; /* 0x28 */ + unsigned int timer3_match2; /* 0x2c */ + unsigned int cr; /* 0x30 */ + unsigned int interrupt_state; /* 0x34 */ + unsigned int interrupt_mask; /* 0x38 */ +}; + +/* + * Timer Control Register + */ +#define FTTMR010_TM3_UPDOWN (1 << 11) +#define FTTMR010_TM2_UPDOWN (1 << 10) +#define FTTMR010_TM1_UPDOWN (1 << 9) +#define FTTMR010_TM3_OFENABLE (1 << 8) +#define FTTMR010_TM3_CLOCK (1 << 7) +#define FTTMR010_TM3_ENABLE (1 << 6) +#define FTTMR010_TM2_OFENABLE (1 << 5) +#define FTTMR010_TM2_CLOCK (1 << 4) +#define FTTMR010_TM2_ENABLE (1 << 3) +#define FTTMR010_TM1_OFENABLE (1 << 2) +#define FTTMR010_TM1_CLOCK (1 << 1) +#define FTTMR010_TM1_ENABLE (1 << 0) + +/* + * Timer Interrupt State & Mask Registers + */ +#define FTTMR010_TM3_OVERFLOW (1 << 8) +#define FTTMR010_TM3_MATCH2 (1 << 7) +#define FTTMR010_TM3_MATCH1 (1 << 6) +#define FTTMR010_TM2_OVERFLOW (1 << 5) +#define FTTMR010_TM2_MATCH2 (1 << 4) +#define FTTMR010_TM2_MATCH1 (1 << 3) +#define FTTMR010_TM1_OVERFLOW (1 << 2) +#define FTTMR010_TM1_MATCH2 (1 << 1) +#define FTTMR010_TM1_MATCH1 (1 << 0) + +#endif /* __FTTMR010_H */
Fix include path of timer fttmr010 in a320evb.
Signed-off-by: Macpaul Lin macpaul@andestech.com --- arch/arm/cpu/arm920t/a320/timer.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/arm920t/a320/timer.c b/arch/arm/cpu/arm920t/a320/timer.c index 7785036..95cb8fd 100644 --- a/arch/arm/cpu/arm920t/a320/timer.c +++ b/arch/arm/cpu/arm920t/a320/timer.c @@ -19,8 +19,8 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/fttmr010.h> #include <faraday/ftpmu010.h> +#include <faraday/fttmr010.h>
static ulong timestamp; static ulong lastdec;
Signed-off-by: Macpaul Linmacpaul@andestech.com
Applied to u-boot-arm/master, thanks.
Amicalement,
Amicalement,
Albert ARIBAUD
Macpaul Lin
