imx: move ATF to the back of the FIT to fix loading over yModem
With yModem the FIT Image is only supplied once, so we can only seek forward in the yModem supplied image and never backwards. With the recent changes to the SPL mechanism, including loading U-Boot first, FDT after, then the loadables, we must also reorder the FIT image script to make sure that the loadables are last in the FIT image.
Signed-off-by: Patrick Wildt patrick@blueri.se
diff --git a/arch/arm/mach-imx/mkimage_fit_atf.sh b/arch/arm/mach-imx/mkimage_fit_atf.sh index dd1ca5ad3fd..fe12b7bb4bd 100755 --- a/arch/arm/mach-imx/mkimage_fit_atf.sh +++ b/arch/arm/mach-imx/mkimage_fit_atf.sh @@ -62,6 +62,23 @@ cat << __HEADER_EOF compression = "none"; load = <$BL33_LOAD_ADDR>; }; +__HEADER_EOF + +cnt=1 +for dtname in $* +do + cat << __FDT_IMAGE_EOF + fdt@$cnt { + description = "$(basename $dtname .dtb)"; + data = /incbin/("$dtname"); + type = "flat_dt"; + compression = "none"; + }; +__FDT_IMAGE_EOF +cnt=$((cnt+1)) +done + +cat << __HEADER_EOF atf@1 { description = "ARM Trusted Firmware"; os = "arm-trusted-firmware"; @@ -88,20 +105,6 @@ cat << __HEADER_EOF __HEADER_EOF fi
-cnt=1 -for dtname in $* -do - cat << __FDT_IMAGE_EOF - fdt@$cnt { - description = "$(basename $dtname .dtb)"; - data = /incbin/("$dtname"); - type = "flat_dt"; - compression = "none"; - }; -__FDT_IMAGE_EOF -cnt=$((cnt+1)) -done - cat << __CONF_HEADER_EOF }; configurations {
Ping?
fdt@$cnt {
type = "flat_dt";
fdt@$cnt {
type = "flat_dt";
Thanks to this patch, I was able to push a FIT image (ATF, U-Boot, dtb) using yModem, so:
Tested-by: Sébastien Szymanski sebastien.szymanski@armadeus.com
Regards,
Patrick Wildt
Sébastien Szymanski
