[U-Boot] [PATCH v2] arm: socfpga: fix 3 boards missing env var "socfpga_legacy_reset_compat"
This fixes 3 boards that don't use CONFIG_EXTRA_ENV_SETTINGS from socfpga_common.h. They need to enable reset manager compatibility mode unless all peripheral drivers in Linux support reset handling.
Fixes: commit 4b2e32efa4e7 ("arm: socfpga: gen5: deassert peripheral reset by default") Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reported-by: Wolfgang Grandegger wg@aries-embedded.de ---
Changes in v2: - drop trailing backslash in socfpga_vining_fpga.h
include/configs/socfpga_dbm_soc1.h | 3 ++- include/configs/socfpga_stratix10_socdk.h | 3 ++- include/configs/socfpga_vining_fpga.h | 1 + 3 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/include/configs/socfpga_dbm_soc1.h b/include/configs/socfpga_dbm_soc1.h index b36d7e56fb..fc1db2442e 100644 --- a/include/configs/socfpga_dbm_soc1.h +++ b/include/configs/socfpga_dbm_soc1.h @@ -87,7 +87,8 @@ "echo Running bootscript... ; " \ "source ${kernel_addr_r} ; " \ "fi ; " \ - "fi\0" + "fi\0" \ + "socfpga_legacy_reset_compat=1\0"
/* The rest of the configuration is shared */ #include <configs/socfpga_common.h> diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index 8d2971c6e2..90ad8172e2 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -113,7 +113,8 @@ unsigned int cm_get_qspi_controller_clk_hz(void); "scriptaddr=0x02100000\0" \ "scriptfile=u-boot.scr\0" \ "fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \ - "then source ${scriptaddr}; fi\0" + "then source ${scriptaddr}; fi\0" \ + "socfpga_legacy_reset_compat=1\0"
/* * Generic Interrupt Controller Definitions diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index 29a92b9146..5416c4b170 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -145,6 +145,7 @@ "run ubi_ubi ; " \ "else echo "Unsupported boot mode: "${bootmode} ; " \ "fi\0" \ + "socfpga_legacy_reset_compat=1\0"
#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
Applied, thanks.
Simon Goldschmidt
