[U-Boot] [PATCH] ARM: fdt support: Add usbethaddr as an acceptable MAC
A board that has a USB ethernet device only may set the usbetheraddr and not the ethaddr. ethaddr will be the default MAC address that is chosen and if that is not populated then the usbethaddr is looked at. If neither are set then then device tree blob is not modified.
Signed-off-by: Dan Murphy dmurphy@ti.com --- common/fdt_support.c | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index b034c98..fef7e60 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -450,8 +450,18 @@ void fdt_fixup_ethernet(void *fdt) if (node < 0) return;
+ if (!getenv("ethaddr")) { + if (getenv("usbethaddr")) { + strcpy(mac, "usbethaddr"); + } else { + debug("No ethernet MAC Address defined\n"); + return; + } + } else { + strcpy(mac, "ethaddr"); + } + i = 0; - strcpy(mac, "ethaddr"); while ((tmp = getenv(mac)) != NULL) { sprintf(enet, "ethernet%d", i); path = fdt_getprop(fdt, node, enet, NULL);
- if (!getenv("ethaddr")) {
} else {
return;
- } else {
- i = 0;
The problem is we may well have both. I think we need to re-work the function slightly to be: while ((tmp = getenv(mac)) != NULL) { do_fdt_fixup_ethernet_x(tmp, fdt, node, enet, i) } if (getenv("usbethaddr")) do_fdt_fixup_ethernet_x("usbethaddr", fdt, ...)
Where the name of the new function, and parameter order also makes sense and is complete of course. Thanks!
Tom
} else {
return;
- } else {
- i = 0;
One issue with this approach is that we don't know which inteface in the dt is usb ethernet and which is not. So correctly assigning the MAC to the correct inteface will be tricky.
But the patch is flawed in the affect is that it does not take into account multiple usbethaddr either. I will rework it for this but I am not sure about the other.
Dan
On Wed, Oct 02, 2013 at 03:14:26PM -0500, Dan Murphy wrote:
Tom
} else {
return;
- } else {
- i = 0;
Oh, that's true... Maybe I should withdraw my objection, since we're unlikely to really see both in production cases.
But we don't support that either, did a quick grep before posting.
Tom
Tom
} else {
return;
- } else {
- i = 0;
Actually we do. If you setenv eth1addr in the enviroment it will try to set it in the dtb for the next ethernet instance.
The other option is to set the ethaddr and then have usbethaddr reference ethaddr and leave this code alone.
Dan
All
On 10/02/2013 03:21 PM, Dan Murphy wrote:
Tom
Tom
} else {
return;
- } else {
- i = 0;
Dan
Are there additional comments? I currently do not have a V2 so I am assuming I have addressed all comments.
Please let me know.
Dan
Dan Murphy
