[U-Boot] [PATCH][v3] PBL: add support for boot from SPI flash.
PBL(pre-boot loader): SPI flash used as RCW(Reset Configuration Word) and PBI(pre-boot initialization) source, CPC(CoreNet Platform Cache) used as 1M SRAM where PBL will copy whole U-BOOT image to, U-boot can boot from CPC after PBL completes RCW and PBI phases.
Signed-off-by: Chunhe Lan b25806@freescale.com Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com Signed-off-by: Shaohui Xie b21989@freescale.com --- Use CONFIG_RAMBOOT_PBL instead of CONFIG_PBL_BOOT_INDIRECT according to Kumar's comment.
arch/powerpc/cpu/mpc85xx/cpu_init.c | 19 +++++++++++++++++++ board/freescale/corenet_ds/config.mk | 6 ++++++ board/freescale/corenet_ds/tlb.c | 9 +++++++++ boards.cfg | 1 + include/configs/corenet_ds.h | 30 ++++++++++++++++++++++++++++-- 5 files changed, 63 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 4b8faa5..a58cd1a 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -139,6 +139,22 @@ static void enable_cpc(void) for (i = 0; i < CONFIG_SYS_NUM_CPC; i++, cpc++) { u32 cpccfg0 = in_be32(&cpc->cpccfg0); size += CPC_CFG0_SZ_K(cpccfg0); +#ifdef CONFIG_RAMBOOT_PBL + if (in_be32(&cpc->cpcsrcr0) & CPC_SRCR0_SRAMEN) { + /* find and disable LAW of SRAM */ + struct law_entry law = find_law(CONFIG_SYS_INIT_L3_ADDR); + + if (law.index == -1) { + printf("\nFatal error happened\n"); + return; + } + disable_law(law.index); + + clrbits_be32(&cpc->cpchdbcr0, CPC_HDBCR0_CDQ_SPEC_DIS); + out_be32(&cpc->cpccsr0, 0); + out_be32(&cpc->cpcsrcr0, 0); + } +#endif
out_be32(&cpc->cpccsr0, CPC_CSR0_CE | CPC_CSR0_PE); /* Read back to sync write */ @@ -155,6 +171,9 @@ void invalidate_cpc(void) cpc_corenet_t *cpc = (cpc_corenet_t *)CONFIG_SYS_FSL_CPC_ADDR;
for (i = 0; i < CONFIG_SYS_NUM_CPC; i++, cpc++) { + /* skip CPC when it used as all SRAM */ + if (in_be32(&cpc->cpcsrcr0) & CPC_SRCR0_SRAMEN) + continue; /* Flash invalidate the CPC and clear all the locks */ out_be32(&cpc->cpccsr0, CPC_CSR0_FI | CPC_CSR0_LFC); while (in_be32(&cpc->cpccsr0) & (CPC_CSR0_FI | CPC_CSR0_LFC)) diff --git a/board/freescale/corenet_ds/config.mk b/board/freescale/corenet_ds/config.mk index 15bbf20..918775d 100644 --- a/board/freescale/corenet_ds/config.mk +++ b/board/freescale/corenet_ds/config.mk @@ -24,4 +24,10 @@ # P4080DS board #
+ifeq ($(CONFIG_RAMBOOT_PBL), y) +RESET_VECTOR_ADDRESS = 0xfffffffc +endif + +ifndef RESET_VECTOR_ADDRESS RESET_VECTOR_ADDRESS = 0xeffffffc +endif diff --git a/board/freescale/corenet_ds/tlb.c b/board/freescale/corenet_ds/tlb.c index 1ae0416..08f91a7 100644 --- a/board/freescale/corenet_ds/tlb.c +++ b/board/freescale/corenet_ds/tlb.c @@ -51,9 +51,18 @@ struct fsl_e_tlb_entry tlb_table[] = {
/* TLB 1 */ /* *I*** - Covers boot page */ +#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L3_ADDR) + /* *I*G - L3SRAM. When L3 is used as 1M SRAM, the address of the + * SRAM is at 0xfff00000, it covered the 0xfffff000. + * */ + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), +#else SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 0, BOOKE_PAGESZ_4K, 1), +#endif
/* *I*G* - CCSRBAR */ SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, diff --git a/boards.cfg b/boards.cfg index 94b8745..2052efc 100644 --- a/boards.cfg +++ b/boards.cfg @@ -502,6 +502,7 @@ P2020RDB_NAND powerpc mpc85xx p1_p2_rdb freesca P2020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SDCARD P2020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SPIFLASH P4080DS powerpc mpc85xx corenet_ds freescale +P4080DS_RAMBOOT_PBL powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF80000 stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 454a30a..663dff2 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -28,6 +28,10 @@
#include "../board/freescale/common/ics307_clk.h"
+#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_RAMBOOT_TEXT_BASE 0xfff80000 +#endif + /* High Level Configuration Options */ #define CONFIG_BOOKE #define CONFIG_E500 /* BOOKE e500 family */ @@ -62,11 +66,17 @@ #ifdef CONFIG_SYS_NO_FLASH #define CONFIG_ENV_IS_NOWHERE #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI #endif
+#if defined(CONFIG_RAMBOOT_PBL) + #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ +#else + #define CONFIG_ENV_IS_IN_FLASH + #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#endif + #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() /* sysclk for MPC85xx */
/* @@ -96,6 +106,19 @@ #define CONFIG_PANIC_HANG /* do not reset board on panic */
/* + * Config the L3 Cache as L3 SRAM + */ +#define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_INIT_L3_ADDR_PHYS (0xf00000000ull | CONFIG_RAMBOOT_TEXT_BASE) +#else +#define CONFIG_SYS_INIT_L3_ADDR_PHYS CONFIG_SYS_INIT_L3_ADDR +#endif +#define CONFIG_SYS_L3_SIZE (1024 << 10) +#define CONFIG_SYS_INIT_L3_END (CONFIG_SYS_INIT_L3_ADDR + CONFIG_SYS_L3_SIZE) + + +/* * Base addresses -- Note these are effective addresses where the * actual resources get mapped (not physical addresses) */ @@ -188,6 +211,10 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */
+#if defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_SYS_RAMBOOT +#endif + #define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} @@ -459,7 +486,6 @@ /* * Environment */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */
Dear Shaohui Xie,
CONFIG_RAMBOOT_PBL needs to be documented in the README!
Do we really need this? Can this not be moved into the board config file, so we gan delete the config.mk ?
- /* *I*G - L3SRAM. When L3 is used as 1M SRAM, the address of the
Incorrect multiline comment style. Please fix globally.
Why is this needed? You already set SYS_TEXT_BASE to that value.
Why remove the CONFIG_ENV_IS_IN_FLASH here, but leave the CONFIG_ENV_IS_NOWHERE above?
- #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */
+#else
- #define CONFIG_ENV_IS_IN_FLASH
- #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE)
See previous comment. This should be cleaned up. For example, move this block up, and set CONFIG_SYS_NO_FLASH instead.
Drop one of the blank lines, please.
I'll post a cleanup patch that should handle this bit for us on all 85xx boards that need it.
- k
Kumar's comment.
[Xie Shaohui] OK, I'll submit a patch of README.
[Xie Shaohui] OK.
[Xie Shaohui] You are right; this is not needed after boards.cfg is used.
+#else
[Xie Shaohui] OK, I'll clean up these codes.
+#define CONFIG_SYS_L3_SIZE (1024 << 10) +#define CONFIG_SYS_INIT_L3_END (CONFIG_SYS_INIT_L3_ADDR + +CONFIG_SYS_L3_SIZE)
[Xie Shaohui] OK. Thanks.
Best Regards, Shaohui Xie
Kumar Gala
Shaohui Xie
Xie Shaohui-B21989
