[PATCH] PCI: mediatek: Release the resource when PCIe enable port fail
On the mt7623 platform, if one port enable fail and other port enable succeed. It will hang on when using pci enum because the resource was not released correctly.
Signed-off-by: Chuanjia Liu Chuanjia.Liu@mediatek.com Tested-by: Frank Wunderlich frank-w@public-files.de --- drivers/pci/pcie_mediatek.c | 19 +++++++++++++------ 1 file changed, 13 insertions(+), 6 deletions(-)
diff --git a/drivers/pci/pcie_mediatek.c b/drivers/pci/pcie_mediatek.c index ad34f7c597..55b6a40f25 100644 --- a/drivers/pci/pcie_mediatek.c +++ b/drivers/pci/pcie_mediatek.c @@ -443,29 +443,36 @@ static void mtk_pcie_enable_port(struct mtk_pcie_port *port)
err = clk_enable(&port->sys_ck); if (err) - goto exit; + goto err_sys_clk;
err = reset_assert(&port->reset); if (err) - goto exit; + goto err_reset;
err = reset_deassert(&port->reset); if (err) - goto exit; + goto err_reset;
err = generic_phy_init(&port->phy); if (err) - goto exit; + goto err_phy_init;
err = generic_phy_power_on(&port->phy); if (err) - goto exit; + goto err_phy_on;
if (!mtk_pcie_startup_port(port)) return;
pr_err("Port%d link down\n", port->slot); -exit: + + generic_phy_power_off(&port->phy); +err_phy_on: + generic_phy_exit(&port->phy); +err_phy_init: +err_reset: + clk_disable(&port->sys_ck); +err_sys_clk: mtk_pcie_port_free(port); }
thank you for fixing this issue :)
regards Frank
Gesendet: Montag, 31. August 2020 um 09:53 Uhr Von: "Chuanjia Liu" Chuanjia.Liu@mediatek.com On the mt7623 platform, if one port enable fail and other port enable succeed. It will hang on when using pci enum because the resource was not released correctly.
if fixes-Tag is needed:
Fixes: 42d37450e5 ("pci: mediatek: add PCIe controller support for MT7623")
Am 10. September 2020 20:40:10 MESZ schrieb Tom Rini trini@konsulko.com:
Thanks
Can it be applied to current release too as it is a fix (hang till watchdog reset on pci enum if no card inserted in pcie slot,but sata chip connected)? regards Frank
Thanks
Yes, OK, thanks for letting me know. I've queued this up for master when I push again. Is there anything else currently that's outstanding for MediaTek and should be in this release?
Am 10. September 2020 21:33:01 MESZ schrieb Tom Rini trini@konsulko.com:
For my boards only xhci 0.96 support is outstanding,but this is more functionality than bugfix and missing it does not break (only usb not working on bpi r2/r64). So i guess it will go in next. regards Frank
Chuanjia Liu
Frank Wunderlich
