[U-Boot] [PATCH] post: use ARRAY_SIZE
We've got a handy dandy macro already for calculating the number of elements in an array, so use it.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- post/board/lwmon/sysmon.c | 2 +- post/cpu/mpc8xx/ether.c | 4 +--- post/cpu/mpc8xx/spr.c | 3 +-- post/cpu/mpc8xx/uart.c | 4 +--- post/cpu/ppc4xx/spr.c | 3 +-- post/drivers/memory.c | 2 +- post/lib_powerpc/andi.c | 3 +-- post/lib_powerpc/cmp.c | 3 +-- post/lib_powerpc/cmpi.c | 3 +-- post/lib_powerpc/cr.c | 12 ++++-------- post/lib_powerpc/fpu/mul-subnormal-single-1.c | 2 +- post/lib_powerpc/load.c | 3 +-- post/lib_powerpc/multi.c | 2 +- post/lib_powerpc/rlwimi.c | 3 +-- post/lib_powerpc/rlwinm.c | 3 +-- post/lib_powerpc/rlwnm.c | 3 +-- post/lib_powerpc/srawi.c | 3 +-- post/lib_powerpc/store.c | 3 +-- post/lib_powerpc/three.c | 3 +-- post/lib_powerpc/threei.c | 3 +-- post/lib_powerpc/threex.c | 3 +-- post/lib_powerpc/two.c | 3 +-- post/lib_powerpc/twox.c | 3 +-- post/post.c | 2 +- post/tests.c | 2 +- 25 files changed, 28 insertions(+), 52 deletions(-)
diff --git a/post/board/lwmon/sysmon.c b/post/board/lwmon/sysmon.c index fc828b2..72224c6 100644 --- a/post/board/lwmon/sysmon.c +++ b/post/board/lwmon/sysmon.c @@ -133,7 +133,7 @@ static sysmon_table_t sysmon_table[] = {"+ 5 V standby", "V", &sysmon_pic, NULL, NULL, 100, 1000, 0, 6040, 0xFF, 0xC8, 0xDE, 0, 0xC8, 0xDE, 0, 0x7C}, }; -static int sysmon_table_size = sizeof(sysmon_table) / sizeof(sysmon_table[0]); +static int sysmon_table_size = ARRAY_SIZE(sysmon_table);
static int conversion_done = 0;
diff --git a/post/cpu/mpc8xx/ether.c b/post/cpu/mpc8xx/ether.c index 43ea817..fcbb300 100644 --- a/post/cpu/mpc8xx/ether.c +++ b/post/cpu/mpc8xx/ether.c @@ -67,8 +67,6 @@ static int ctlr_list[][2] = { {CTLR_SCC, 1} }; static int ctlr_list[][2] = { }; #endif
-#define CTRL_LIST_SIZE (sizeof(ctlr_list) / sizeof(ctlr_list[0])) - static struct { void (*init) (int index); void (*halt) (int index); @@ -618,7 +616,7 @@ int ether_post_test (int flags) ctlr_proc[CTLR_SCC].send = scc_send; ctlr_proc[CTLR_SCC].recv = scc_recv;
- for (i = 0; i < CTRL_LIST_SIZE; i++) { + for (i = 0; i < ARRAY_SIZE(ctlr_list); i++) { if (test_ctlr (ctlr_list[i][0], ctlr_list[i][1]) != 0) { res = -1; } diff --git a/post/cpu/mpc8xx/spr.c b/post/cpu/mpc8xx/spr.c index db84dbe..4c1e2af 100644 --- a/post/cpu/mpc8xx/spr.c +++ b/post/cpu/mpc8xx/spr.c @@ -108,8 +108,7 @@ static struct {826, "MD_DBRAM1", 0x00000000, 0x00000000}, };
-static int spr_test_list_size = - sizeof (spr_test_list) / sizeof (spr_test_list[0]); +static int spr_test_list_size = ARRAY_SIZE(spr_test_list);
int spr_post_test (int flags) { diff --git a/post/cpu/mpc8xx/uart.c b/post/cpu/mpc8xx/uart.c index f351ac0..7a7a62a 100644 --- a/post/cpu/mpc8xx/uart.c +++ b/post/cpu/mpc8xx/uart.c @@ -61,8 +61,6 @@ static int ctlr_list[][2] = static int ctlr_list[][2] = { }; #endif
-#define CTRL_LIST_SIZE (sizeof(ctlr_list) / sizeof(ctlr_list[0])) - static struct { void (*init) (int index); void (*halt) (int index); @@ -540,7 +538,7 @@ int uart_post_test (int flags) ctlr_proc[CTLR_SCC].putc = scc_putc; ctlr_proc[CTLR_SCC].getc = scc_getc;
- for (i = 0; i < CTRL_LIST_SIZE; i++) { + for (i = 0; i < ARRAY_SIZE(ctlr_list); i++) { if (test_ctlr (ctlr_list[i][0], ctlr_list[i][1]) != 0) { res = -1; } diff --git a/post/cpu/ppc4xx/spr.c b/post/cpu/ppc4xx/spr.c index cb18b64..3f5e965 100644 --- a/post/cpu/ppc4xx/spr.c +++ b/post/cpu/ppc4xx/spr.c @@ -156,8 +156,7 @@ static struct { {0x3f3, "DBDR", 0x00000000, 0x00000000}, };
int spr_post_test (int flags) { diff --git a/post/drivers/memory.c b/post/drivers/memory.c index 3f47449..4cca035 100644 --- a/post/drivers/memory.c +++ b/post/drivers/memory.c @@ -225,7 +225,7 @@ const unsigned long long otherpattern = 0x0123456789abcdefULL; static int memory_post_dataline(unsigned long long * pmem) { unsigned long long temp64 = 0; - int num_patterns = sizeof(pattern)/ sizeof(pattern[0]); + int num_patterns = ARRAY_SIZE(pattern); int i; unsigned int hi, lo, pathi, patlo; int ret = 0; diff --git a/post/lib_powerpc/andi.c b/post/lib_powerpc/andi.c index 52ec7c4..2791cd7 100644 --- a/post/lib_powerpc/andi.c +++ b/post/lib_powerpc/andi.c @@ -61,8 +61,7 @@ static struct cpu_post_andi_s 0x80000000 }, }; -static unsigned int cpu_post_andi_size = - sizeof (cpu_post_andi_table) / sizeof (struct cpu_post_andi_s); +static unsigned int cpu_post_andi_size = ARRAY_SIZE(cpu_post_andi_table);
int cpu_post_test_andi (void) { diff --git a/post/lib_powerpc/cmp.c b/post/lib_powerpc/cmp.c index 5f6a3b9..ae5b72b 100644 --- a/post/lib_powerpc/cmp.c +++ b/post/lib_powerpc/cmp.c @@ -95,8 +95,7 @@ static struct cpu_post_cmp_s 0x04 }, }; -static unsigned int cpu_post_cmp_size = - sizeof (cpu_post_cmp_table) / sizeof (struct cpu_post_cmp_s); +static unsigned int cpu_post_cmp_size = ARRAY_SIZE(cpu_post_cmp_table);
int cpu_post_test_cmp (void) { diff --git a/post/lib_powerpc/cmpi.c b/post/lib_powerpc/cmpi.c index 1a2fc3d..4160a2a 100644 --- a/post/lib_powerpc/cmpi.c +++ b/post/lib_powerpc/cmpi.c @@ -95,8 +95,7 @@ static struct cpu_post_cmpi_s 0x04 }, }; -static unsigned int cpu_post_cmpi_size = - sizeof (cpu_post_cmpi_table) / sizeof (struct cpu_post_cmpi_s); +static unsigned int cpu_post_cmpi_size = ARRAY_SIZE(cpu_post_cmpi_table);
int cpu_post_test_cmpi (void) { diff --git a/post/lib_powerpc/cr.c b/post/lib_powerpc/cr.c index fbee6d5..ada7c7a 100644 --- a/post/lib_powerpc/cr.c +++ b/post/lib_powerpc/cr.c @@ -59,8 +59,7 @@ static ulong cpu_post_cr_table1[] = 0xaaaaaaaa, 0x55555555, }; -static unsigned int cpu_post_cr_size1 = - sizeof (cpu_post_cr_table1) / sizeof (ulong); +static unsigned int cpu_post_cr_size1 = ARRAY_SIZE(cpu_post_cr_table1);
static struct cpu_post_cr_s2 { ulong xer; @@ -76,8 +75,7 @@ static struct cpu_post_cr_s2 { 5 }, }; -static unsigned int cpu_post_cr_size2 = - sizeof (cpu_post_cr_table2) / sizeof (struct cpu_post_cr_s2); +static unsigned int cpu_post_cr_size2 = ARRAY_SIZE(cpu_post_cr_table2);
static struct cpu_post_cr_s3 { ulong cr; @@ -99,8 +97,7 @@ static struct cpu_post_cr_s3 { 0x71234567 }, }; -static unsigned int cpu_post_cr_size3 = - sizeof (cpu_post_cr_table3) / sizeof (struct cpu_post_cr_s3); +static unsigned int cpu_post_cr_size3 = ARRAY_SIZE(cpu_post_cr_table3);
static struct cpu_post_cr_s4 { ulong cmd; @@ -240,8 +237,7 @@ static struct cpu_post_cr_s4 { 0x0000ffff }, }; -static unsigned int cpu_post_cr_size4 = - sizeof (cpu_post_cr_table4) / sizeof (struct cpu_post_cr_s4); +static unsigned int cpu_post_cr_size4 = ARRAY_SIZE(cpu_post_cr_table4);
int cpu_post_test_cr (void) { diff --git a/post/lib_powerpc/fpu/mul-subnormal-single-1.c b/post/lib_powerpc/fpu/mul-subnormal-single-1.c index 23a3f30..b3f8deb 100644 --- a/post/lib_powerpc/fpu/mul-subnormal-single-1.c +++ b/post/lib_powerpc/fpu/mul-subnormal-single-1.c @@ -86,7 +86,7 @@ int fpu_post_test_math7 (void) { unsigned int i;
- for (i = 0; i < sizeof (expected) / sizeof (expected[0]); i++) + for (i = 0; i < ARRAY_SIZE(expected); i++) { tstmul (expected[i].p1, expected[i].p2, expected[i].res); tstmul (expected[i].p2, expected[i].p1, expected[i].res); diff --git a/post/lib_powerpc/load.c b/post/lib_powerpc/load.c index 98d4373..49924f2 100644 --- a/post/lib_powerpc/load.c +++ b/post/lib_powerpc/load.c @@ -171,8 +171,7 @@ static struct cpu_post_load_s 1 }, }; -static unsigned int cpu_post_load_size = - sizeof (cpu_post_load_table) / sizeof (struct cpu_post_load_s); +static unsigned int cpu_post_load_size = ARRAY_SIZE(cpu_post_load_table);
int cpu_post_test_load (void) { diff --git a/post/lib_powerpc/multi.c b/post/lib_powerpc/multi.c index e42a7c0..5845616 100644 --- a/post/lib_powerpc/multi.c +++ b/post/lib_powerpc/multi.c @@ -57,7 +57,7 @@ int cpu_post_test_multi (void) ASM_BLR, };
- for (i = 0; i < sizeof(src) / sizeof(src[0]); i ++) + for (i = 0; i < ARRAY_SIZE(src); ++i) { src[i] = i; dst[i] = 0; diff --git a/post/lib_powerpc/rlwimi.c b/post/lib_powerpc/rlwimi.c index fd628b3..15d96ac 100644 --- a/post/lib_powerpc/rlwimi.c +++ b/post/lib_powerpc/rlwimi.c @@ -62,8 +62,7 @@ static struct cpu_post_rlwimi_s 0xffaaffff }, }; -static unsigned int cpu_post_rlwimi_size = - sizeof (cpu_post_rlwimi_table) / sizeof (struct cpu_post_rlwimi_s); +static unsigned int cpu_post_rlwimi_size = ARRAY_SIZE(cpu_post_rlwimi_table);
int cpu_post_test_rlwimi (void) { diff --git a/post/lib_powerpc/rlwinm.c b/post/lib_powerpc/rlwinm.c index 88a28c6..a04ec52 100644 --- a/post/lib_powerpc/rlwinm.c +++ b/post/lib_powerpc/rlwinm.c @@ -59,8 +59,7 @@ static struct cpu_post_rlwinm_s 0x0000ff00 }, }; -static unsigned int cpu_post_rlwinm_size = - sizeof (cpu_post_rlwinm_table) / sizeof (struct cpu_post_rlwinm_s); +static unsigned int cpu_post_rlwinm_size = ARRAY_SIZE(cpu_post_rlwinm_table);
int cpu_post_test_rlwinm (void) { diff --git a/post/lib_powerpc/rlwnm.c b/post/lib_powerpc/rlwnm.c index 60bcb6d..764fe0c 100644 --- a/post/lib_powerpc/rlwnm.c +++ b/post/lib_powerpc/rlwnm.c @@ -60,8 +60,7 @@ static struct cpu_post_rlwnm_s 0x0000ff00 }, }; -static unsigned int cpu_post_rlwnm_size = - sizeof (cpu_post_rlwnm_table) / sizeof (struct cpu_post_rlwnm_s); +static unsigned int cpu_post_rlwnm_size = ARRAY_SIZE(cpu_post_rlwnm_table);
int cpu_post_test_rlwnm (void) { diff --git a/post/lib_powerpc/srawi.c b/post/lib_powerpc/srawi.c index be153ad..90a1e4d 100644 --- a/post/lib_powerpc/srawi.c +++ b/post/lib_powerpc/srawi.c @@ -61,8 +61,7 @@ static struct cpu_post_srawi_s 0xf0000000 }, }; -static unsigned int cpu_post_srawi_size = - sizeof (cpu_post_srawi_table) / sizeof (struct cpu_post_srawi_s); +static unsigned int cpu_post_srawi_size = ARRAY_SIZE(cpu_post_srawi_table);
int cpu_post_test_srawi (void) { diff --git a/post/lib_powerpc/store.c b/post/lib_powerpc/store.c index 1956f6b..441389c 100644 --- a/post/lib_powerpc/store.c +++ b/post/lib_powerpc/store.c @@ -156,8 +156,7 @@ static struct cpu_post_store_s 0xff }, }; -static unsigned int cpu_post_store_size = - sizeof (cpu_post_store_table) / sizeof (struct cpu_post_store_s); +static unsigned int cpu_post_store_size = ARRAY_SIZE(cpu_post_store_table);
int cpu_post_test_store (void) { diff --git a/post/lib_powerpc/three.c b/post/lib_powerpc/three.c index 7f8c1e2..4391386 100644 --- a/post/lib_powerpc/three.c +++ b/post/lib_powerpc/three.c @@ -155,8 +155,7 @@ static struct cpu_post_three_s 0x40 }, }; -static unsigned int cpu_post_three_size = - sizeof (cpu_post_three_table) / sizeof (struct cpu_post_three_s); +static unsigned int cpu_post_three_size = ARRAY_SIZE(cpu_post_three_table);
int cpu_post_test_three (void) { diff --git a/post/lib_powerpc/threei.c b/post/lib_powerpc/threei.c index 31953f9..95b6322 100644 --- a/post/lib_powerpc/threei.c +++ b/post/lib_powerpc/threei.c @@ -75,8 +75,7 @@ static struct cpu_post_threei_s 0xffff8000 }, }; -static unsigned int cpu_post_threei_size = - sizeof (cpu_post_threei_table) / sizeof (struct cpu_post_threei_s); +static unsigned int cpu_post_threei_size = ARRAY_SIZE(cpu_post_threei_table);
int cpu_post_test_threei (void) { diff --git a/post/lib_powerpc/threex.c b/post/lib_powerpc/threex.c index 350a12a..7769218 100644 --- a/post/lib_powerpc/threex.c +++ b/post/lib_powerpc/threex.c @@ -125,8 +125,7 @@ static struct cpu_post_threex_s 0x1000 }, }; -static unsigned int cpu_post_threex_size = - sizeof (cpu_post_threex_table) / sizeof (struct cpu_post_threex_s); +static unsigned int cpu_post_threex_size = ARRAY_SIZE(cpu_post_threex_table);
int cpu_post_test_threex (void) { diff --git a/post/lib_powerpc/two.c b/post/lib_powerpc/two.c index 2b11147..7f08880 100644 --- a/post/lib_powerpc/two.c +++ b/post/lib_powerpc/two.c @@ -81,8 +81,7 @@ static struct cpu_post_two_s ~5 }, }; -static unsigned int cpu_post_two_size = - sizeof (cpu_post_two_table) / sizeof (struct cpu_post_two_s); +static unsigned int cpu_post_two_size = ARRAY_SIZE(cpu_post_two_table);
int cpu_post_test_two (void) { diff --git a/post/lib_powerpc/twox.c b/post/lib_powerpc/twox.c index d6714f9..88140bf 100644 --- a/post/lib_powerpc/twox.c +++ b/post/lib_powerpc/twox.c @@ -81,8 +81,7 @@ static struct cpu_post_twox_s 12 }, }; -static unsigned int cpu_post_twox_size = - sizeof (cpu_post_twox_table) / sizeof (struct cpu_post_twox_s); +static unsigned int cpu_post_twox_size = ARRAY_SIZE(cpu_post_twox_table);
int cpu_post_test_twox (void) { diff --git a/post/post.c b/post/post.c index ecea1e1..7660224 100644 --- a/post/post.c +++ b/post/post.c @@ -196,7 +196,7 @@ static void post_get_flags (int *test_flags) POST_CRITICAL }; char *var[] = { "post_poweron", "post_normal", "post_slowtest", "post_critical" }; - int varnum = sizeof (var) / sizeof (var[0]); + int varnum = ARRAY_SIZE(var); char list[128]; /* long enough for POST list */ char *name; char *s; diff --git a/post/tests.c b/post/tests.c index 5f59fbb..71437b6 100644 --- a/post/tests.c +++ b/post/tests.c @@ -305,4 +305,4 @@ struct post_test post_list[] = #endif };
-unsigned int post_list_size = sizeof (post_list) / sizeof (struct post_test); +unsigned int post_list_size = ARRAY_SIZE(post_list);
Dear Mike Frysinger,
Applied, thanks.
Mike Frysinger
