[U-Boot] Please pull ARC changes or 2018.09-rc2
Hi Tom,
The following changes since commit 5a0007d481c0fcd2d422dd48b2a129dd8e8a272a:
Prepare v2017.09-rc1 (2018-07-30 21:47:29 -0400)
git://git.denx.de/u-boot-arc.git tags/arc-updates-for-2018.09-rc2
for you to fetch changes up to 8f590063ba635264303b1713c421df331743fd46:
ARC: Enable unaligned access in hardware if compiler uses it (2018-07-31 07:49:47 +0300)
---------------------------------------------------------------- That's a set of prety minor changes and fixes for ARC.
Among them: * Improvement in CREG GPIO driver used on ARC dev boards that allow us to re-use the driver for SPI's chip select
* Enable SPI-flsh on AXS10x boards which allows to update U-Boot binary that gets loaded by boot-ROM
* Fix accommodating always utilized unaligned access by GCC for ARC starting from 8.1.0
---------------------------------------------------------------- Alexey Brodkin (3): ARC: AXS10x/HSDK: Use our own version of mkimage HSDK: Fixes and improvements in README ARC: Enable unaligned access in hardware if compiler uses it
Eugeniy Paltsev (4): GPIO: CREG: improve flexibility of hsdk-creg-gpio driver CREG GPIO: add device tree bindings AXS10x: add spi flash support ARC: AXS10x: add tool and make target to generate bsp
MAINTAINERS | 1 + arch/arc/dts/axs10x_mb.dtsi | 34 ++++++++++++++++++++ arch/arc/dts/hsdk.dts | 7 +++- arch/arc/include/asm/arcregs.h | 3 ++ arch/arc/lib/start.S | 9 ++++++ board/synopsys/axs10x/config.mk | 23 ++++++++++++++ board/synopsys/axs10x/headerize-axs.py | 176 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/synopsys/hsdk/README | 10 ++++-- board/synopsys/hsdk/config.mk | 2 +- configs/axs101_defconfig | 12 +++++++ configs/axs103_defconfig | 12 +++++++ doc/device-tree-bindings/gpio/snps,creg-gpio.txt | 43 +++++++++++++++++++++++++ drivers/gpio/hsdk-creg-gpio.c | 103 ++++++++++++++++++++++++++++++++++++++++++++++------------- include/configs/axs10x.h | 7 ++++ 14 files changed, 416 insertions(+), 26 deletions(-) create mode 100644 board/synopsys/axs10x/config.mk create mode 100644 board/synopsys/axs10x/headerize-axs.py create mode 100644 doc/device-tree-bindings/gpio/snps,creg-gpio.txt
-Alexey
On Tue, Jul 31, 2018 at 04:59:33AM +0000, Alexey Brodkin wrote:
Hi Tom,
Alexey Brodkin
