[U-Boot] [PATCH 0/5] convert CONFIG_SYS_SPI_U_BOOT_OFFS to Kconfig
The intention of this series is to bring the CONFIG_SYS_SPI_U_BOOT_OFFS option to Kconfig. For getting sure not introducing bugs and don't forget boards the requirement is a clean run of moveconfig.py without warnings.
To achieve this we need to prepare a few things: - manually edit header files which have formula within the #define - manually edit header files which are referencing to another #define - manually edit common header files which are defining the option even it is not needed on affected build-targets.
A few boards are failing in moveconfig.py because the needed tool-chain isn't found. Not a big issue since they aren't affected from the desired change.
Hannes Schmelzer (5): moveconfig: prepare moving CONFIG_SYS_SPI_U_BOOT_OFFS to Kconfig step 1 moveconfig: prepare moving CONFIG_SYS_SPI_U_BOOT_OFFS to Kconfig step 2 moveconfig: prepare moving CONFIG_SYS_SPI_U_BOOT_OFFS to Kconfig step 3 moveconfig: prepare moving CONFIG_SYS_SPI_U_BOOT_OFFS to Kconfig step 4 Convert CONFIG_SYS_SPI_U_BOOT_OFFS to Kconfig
common/spl/Kconfig | 8 ++++++++ configs/alt_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/am57xx_hs_evm_usb_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brsmarc1_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_speedy_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/dh_imx6_defconfig | 1 + configs/display5_defconfig | 1 + configs/display5_factory_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/dra7xx_hs_evm_usb_defconfig | 1 + configs/draco_defconfig | 1 + configs/ds414_defconfig | 1 + configs/etamin_defconfig | 1 + configs/gose_defconfig | 1 + configs/j721e_evm_a72_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/lager_defconfig | 1 + configs/maxbcm_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/pfla02_defconfig | 1 + configs/porter_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/silk_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/stout_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/thuban_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/x530_defconfig | 2 ++ configs/zc5202_defconfig | 1 + configs/zc5601_defconfig | 1 + configs/zynq_cc108_defconfig | 1 + configs/zynq_cse_qspi_defconfig | 1 + configs/zynq_dlc20_rev1_0_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_z_turn_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + configs/zynq_zybo_z7_defconfig | 1 + doc/README.rockchip | 2 +- include/configs/alt.h | 1 - include/configs/am335x_evm.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/at91sam9n12ek.h | 5 ----- include/configs/at91sam9x5ek.h | 4 ---- include/configs/bav335x.h | 1 - include/configs/brppt1.h | 1 - include/configs/brsmarc1.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cl-som-imx7.h | 3 --- include/configs/clearfog.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cm_t43.h | 1 - include/configs/controlcenterdc.h | 1 - include/configs/da850evm.h | 1 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/dh_imx6.h | 1 - include/configs/display5.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/ds414.h | 1 - include/configs/el6x_common.h | 1 - include/configs/gose.h | 1 - include/configs/helios4.h | 1 - include/configs/j721e_evm.h | 2 -- include/configs/koelsch.h | 1 - include/configs/lager.h | 1 - include/configs/maxbcm.h | 1 - include/configs/mt7629.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/ot1200.h | 1 - include/configs/pcm051.h | 1 - include/configs/pcm058.h | 1 - include/configs/pfla02.h | 1 - include/configs/phycore_am335x_r2.h | 1 - include/configs/porter.h | 1 - include/configs/rk3128_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rk3328_common.h | 2 -- include/configs/rk3399_common.h | 1 - include/configs/sama5d27_som1_ek.h | 4 ---- include/configs/sama5d2_xplained.h | 4 ---- include/configs/sama5d3xek.h | 4 ---- include/configs/sama5d4_xplained.h | 5 ----- include/configs/sama5d4ek.h | 4 ---- include/configs/siemens-am33x-common.h | 2 -- include/configs/silk.h | 1 - include/configs/socfpga_common.h | 7 ------- include/configs/socfpga_stratix10_socdk.h | 1 - include/configs/stout.h | 1 - include/configs/sunxi-common.h | 4 ---- include/configs/taurus.h | 1 - include/configs/theadorable.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti_armv7_keystone2.h | 1 - include/configs/topic_miami.h | 2 -- include/configs/turris_omnia.h | 1 - include/configs/x530.h | 2 -- include/configs/xilinx_zynqmp.h | 2 -- include/configs/zynq-common.h | 1 - scripts/config_whitelist.txt | 1 - 152 files changed, 97 insertions(+), 104 deletions(-)
Some boards have coded this offset with formula or bitshifts in their board-config. Manually convert these things into hex-values to be able using moveconfig.py afterwards.
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
doc/README.rockchip | 2 +- include/configs/cgtqmx6eval.h | 2 +- include/configs/cl-som-imx7.h | 2 +- include/configs/cm_fx6.h | 2 +- include/configs/cm_t43.h | 2 +- include/configs/el6x_common.h | 2 +- include/configs/ot1200.h | 2 +- include/configs/pcm058.h | 2 +- include/configs/pfla02.h | 2 +- include/configs/rk3128_common.h | 2 +- include/configs/rk3288_common.h | 2 +- include/configs/rk3328_common.h | 2 +- include/configs/rk3399_common.h | 2 +- 13 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/doc/README.rockchip b/doc/README.rockchip index 7d4dc1b..463acd9 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -560,7 +560,7 @@ header and skipping every second 2KB block. Then the U-Boot image is written at offset 128KB and the whole image is padded to 4MB which is the SPI flash size. The position of U-Boot is controlled with this setting in U-Boot:
- #define CONFIG_SYS_SPI_U_BOOT_OFFS (128 << 10) + #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
If you have a Dediprog em100pro connected then you can write the image with:
diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 07c6409..eedf0dd 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -17,7 +17,7 @@ #define CONFIG_MACH_TYPE 4122
#ifdef CONFIG_SPL -#define CONFIG_SYS_SPI_U_BOOT_OFFS (64 * 1024) +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 #include "imx6_spl.h" #endif
diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index 4c93fc6..b745f5c 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -167,7 +167,7 @@ /* SPL */ #include "imx7_spl.h" #ifdef CONFIG_SPL_BUILD -#define CONFIG_SYS_SPI_U_BOOT_OFFS (64 * 1024) +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 #endif /* CONFIG_SPL_BUILD */
#endif /* __CONFIG_H */ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 60bac9a..b2fae87 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -207,7 +207,7 @@
/* SPL */ #include "imx6_spl.h" -#define CONFIG_SYS_SPI_U_BOOT_OFFS (64 * 1024) +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000
/* Display */ #define CONFIG_IMX_HDMI diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index b2c1300..8d9bf71 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -115,7 +115,7 @@
/* SPL defines. */ #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + (128 << 20)) -#define CONFIG_SYS_SPI_U_BOOT_OFFS (256 * 1024) +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_MONITOR_LEN (512 * 1024)
/* EEPROM */ diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h index bf70ea0..bd46a34 100644 --- a/include/configs/el6x_common.h +++ b/include/configs/el6x_common.h @@ -20,7 +20,7 @@ #define CONFIG_MXC_UART
diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 7dfcccb..17ccf8b 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -59,7 +59,7 @@ /* SPL */ #ifdef CONFIG_SPL #include "imx6_spl.h" -#define CONFIG_SYS_SPI_U_BOOT_OFFS (64 * 1024) +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 #endif
#define CONFIG_FEC_MXC diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index b0415b2..98959ce 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -8,7 +8,7 @@ #define __PCM058_CONFIG_H
diff --git a/include/configs/pfla02.h b/include/configs/pfla02.h index 3a9b85a..ed7e4fb 100644 --- a/include/configs/pfla02.h +++ b/include/configs/pfla02.h @@ -8,7 +8,7 @@ #define __PCM058_CONFIG_H
diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index d12696d..edd5532 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -27,7 +27,7 @@ #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
/* RAW SD card / eMMC locations. */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS (128 << 10) +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SYS_SDRAM_BASE 0x60000000 diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 84b474a..a647619 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -30,7 +30,7 @@ #define CONFIG_IRAM_BASE 0xff700000
/* FAT sd card locations. */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index 6ed7525..bd424c0 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -25,7 +25,7 @@
/* FAT sd card locations. */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index 12ad60d..fc66797 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -39,7 +39,7 @@ #define CONFIG_ROCKCHIP_SDHCI_MAX_FREQ 200000000
some boards have common headers for several individual build-targets where CONFIG_SYS_SPI_U_BOOT_OFFS is defined even it is not needed (only needed if CONFIG_SPL_SPI_LOAD is defined also). Take this define here under '#ifdef CONFIG_SPL_SPI_LOAD' for having a clean run of moveconfig.py
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com ---
include/configs/at91sam9n12ek.h | 2 +- include/configs/at91sam9x5ek.h | 2 +- include/configs/rk3128_common.h | 2 ++ include/configs/rk3288_common.h | 2 ++ include/configs/rk3328_common.h | 2 ++ include/configs/rk3399_common.h | 2 ++ include/configs/sama5d27_som1_ek.h | 2 +- include/configs/sama5d3xek.h | 2 +- include/configs/socfpga_common.h | 4 ++-- include/configs/sunxi-common.h | 2 +- include/configs/ti814x_evm.h | 2 ++ include/configs/xilinx_zynqmp.h | 3 ++- include/configs/zynq-common.h | 2 ++ 13 files changed, 21 insertions(+), 8 deletions(-)
diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index e9b97b6..2abe979 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -153,7 +153,7 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
#elif CONFIG_SYS_USE_NANDFLASH -#elif CONFIG_SPI_BOOT +#elif CONFIG_SPI_BOOT && CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8400
#elif CONFIG_NAND_BOOT diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 9353de7..8056822 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -125,7 +125,7 @@ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
#elif CONFIG_NAND_BOOT diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index edd5532..e39009a 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -27,7 +27,9 @@ #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
/* RAW SD card / eMMC locations. */ +#ifdef CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 +#endif
#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SYS_SDRAM_BASE 0x60000000 diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index a647619..f30cc94 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -30,7 +30,9 @@ #define CONFIG_IRAM_BASE 0xff700000
/* FAT sd card locations. */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index bd424c0..a68e01e 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -25,7 +25,9 @@
/* FAT sd card locations. */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index fc66797..cda5d03 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -39,7 +39,9 @@ #define CONFIG_ROCKCHIP_SDHCI_MAX_FREQ 200000000
/* FAT sd card locations. */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h index 90846c4..7898f4d 100644 --- a/include/configs/sama5d27_som1_ek.h +++ b/include/configs/sama5d27_som1_ek.h @@ -62,7 +62,7 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif
-#ifdef CONFIG_QSPI_BOOT +#if defined(CONFIG_QSPI_BOOT) && defined(CONFIG_SPL_SPI_LOAD) #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 #endif
diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index db840e9..c5a2e54 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -84,7 +84,7 @@ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
-#elif CONFIG_SPI_BOOT +#elif CONFIG_SPI_BOOT && CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000
#elif CONFIG_NAND_BOOT diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 36b0ed5..4141c7e 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -214,9 +214,9 @@ unsigned int cm_get_qspi_controller_clk_hz(void);
/* SPL QSPI boot support */ #ifdef CONFIG_SPL_SPI_SUPPORT -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) && defined(CONFIG_SPL_SPI_LOAD) #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) && defined(CONFIG_SPL_SPI_LOAD) #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x100000 #endif #endif diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index d7133a7..c5dbf6d 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -118,7 +118,7 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 8 #endif
-#ifdef CONFIG_SPL_SPI_SUNXI +#if defined(CONFIG_SPL_SPI_SUNXI) && defined(CONFIG_SPL_SPI_LOAD) #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8000 #endif
diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 90b424f..0c11587 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -130,7 +130,9 @@ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
+#ifdef CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 +#endif #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000
/* diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index bbcb207..56500fe 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -217,9 +217,10 @@ # define CONFIG_SYS_SPI_KERNEL_OFFS 0x80000 # define CONFIG_SYS_SPI_ARGS_OFFS 0xa0000 # define CONFIG_SYS_SPI_ARGS_SIZE 0xa0000 - +#ifdef CONFIG_SPL_SPI_LOAD # define CONFIG_SYS_SPI_U_BOOT_OFFS 0x170000 #endif +#endif
/* u-boot is like dtb */ #define CONFIG_SPL_FS_LOAD_ARGS_NAME "u-boot.bin" diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index bb6a835..fd761c2 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -293,7 +293,9 @@
/* qspi mode is working fine */ #ifdef CONFIG_ZYNQ_QSPI +#ifdef CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x100000 +#endif #define CONFIG_SYS_SPI_ARGS_OFFS 0x200000 #define CONFIG_SYS_SPI_ARGS_SIZE 0x80000 #define CONFIG_SYS_SPI_KERNEL_OFFS (CONFIG_SYS_SPI_ARGS_OFFS + \
Exact two boards are referencing CONFIG_SYS_SPI_U_BOOT_OFFS to another define, we replace this manually with the value for having a clean run of moveconfig.py afterwards.
include/configs/mt7629.h | 4 +++- include/configs/ti_armv7_keystone2.h | 4 +++- 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/include/configs/mt7629.h b/include/configs/mt7629.h index 6e9b868..fc69d61 100644 --- a/include/configs/mt7629.h +++ b/include/configs/mt7629.h @@ -38,7 +38,9 @@ #define CONFIG_SPL_PAD_TO 0x10000
#define CONFIG_SPI_ADDR 0x30000000 -#define CONFIG_SYS_SPI_U_BOOT_OFFS CONFIG_SPL_PAD_TO +#ifdef CONFIG_SPL_SPI_LOAD +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 +#endif #define CONFIG_SYS_UBOOT_BASE (CONFIG_SPI_ADDR + CONFIG_SPL_PAD_TO)
/* SPL -> Uboot */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 03753c5..9144662 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -44,7 +44,9 @@ CONFIG_SYS_SPL_MALLOC_SIZE + \ SPL_MALLOC_F_SIZE + \ KEYSTONE_SPL_STACK_SIZE - 4) -#define CONFIG_SYS_SPI_U_BOOT_OFFS CONFIG_SPL_PAD_TO +#ifdef CONFIG_SPL_SPI_LOAD +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 +#endif
/* SRAM scratch space entries */ #define SRAM_SCRATCH_SPACE_ADDR CONFIG_SPL_STACK + 0x8
the x530 board needs conversion of SPL_SPI_LOAD to Kconfig first
configs/x530_defconfig | 1 + include/configs/x530.h | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 7db8de4..2bf20f4 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -21,6 +21,7 @@ CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC=y CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_MEMINFO=y # CONFIG_CMD_FLASH is not set diff --git a/include/configs/x530.h b/include/configs/x530.h index 80ae15b..0946121 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -120,7 +120,6 @@ #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
/* SPL related SPI defines */ -#define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x24000 #define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS
Reviewed-by: Chris Packham chris.packham@alliedtelesis.co.nz
/* SPL related SPI defines */ -#define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x24000 #define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_O FFS
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com Reviewed-by: Chris Packham chris.packham@alliedtelesis.co.nz
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS
common/spl/Kconfig | 8 ++++++++ configs/alt_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/am57xx_hs_evm_usb_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brsmarc1_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_speedy_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/dh_imx6_defconfig | 1 + configs/display5_defconfig | 1 + configs/display5_factory_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/dra7xx_hs_evm_usb_defconfig | 1 + configs/draco_defconfig | 1 + configs/ds414_defconfig | 1 + configs/etamin_defconfig | 1 + configs/gose_defconfig | 1 + configs/j721e_evm_a72_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/lager_defconfig | 1 + configs/maxbcm_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/pfla02_defconfig | 1 + configs/porter_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/silk_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/stout_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/thuban_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/x530_defconfig | 1 + configs/zc5202_defconfig | 1 + configs/zc5601_defconfig | 1 + configs/zynq_cc108_defconfig | 1 + configs/zynq_cse_qspi_defconfig | 1 + configs/zynq_dlc20_rev1_0_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_z_turn_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + configs/zynq_zybo_z7_defconfig | 1 + include/configs/alt.h | 1 - include/configs/am335x_evm.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/at91sam9n12ek.h | 5 ----- include/configs/at91sam9x5ek.h | 4 ---- include/configs/bav335x.h | 1 - include/configs/brppt1.h | 1 - include/configs/brsmarc1.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cl-som-imx7.h | 3 --- include/configs/clearfog.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cm_t43.h | 1 - include/configs/controlcenterdc.h | 1 - include/configs/da850evm.h | 1 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/dh_imx6.h | 1 - include/configs/display5.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/ds414.h | 1 - include/configs/el6x_common.h | 1 - include/configs/gose.h | 1 - include/configs/helios4.h | 1 - include/configs/j721e_evm.h | 2 -- include/configs/koelsch.h | 1 - include/configs/lager.h | 1 - include/configs/maxbcm.h | 1 - include/configs/mt7629.h | 3 --- include/configs/omapl138_lcdk.h | 1 - include/configs/ot1200.h | 1 - include/configs/pcm051.h | 1 - include/configs/pcm058.h | 1 - include/configs/pfla02.h | 1 - include/configs/phycore_am335x_r2.h | 1 - include/configs/porter.h | 1 - include/configs/rk3128_common.h | 3 --- include/configs/rk3288_common.h | 3 --- include/configs/rk3328_common.h | 4 ---- include/configs/rk3399_common.h | 3 --- include/configs/sama5d27_som1_ek.h | 4 ---- include/configs/sama5d2_xplained.h | 4 ---- include/configs/sama5d3xek.h | 4 ---- include/configs/sama5d4_xplained.h | 5 ----- include/configs/sama5d4ek.h | 4 ---- include/configs/siemens-am33x-common.h | 2 -- include/configs/silk.h | 1 - include/configs/socfpga_common.h | 7 ------- include/configs/socfpga_stratix10_socdk.h | 1 - include/configs/stout.h | 1 - include/configs/sunxi-common.h | 4 ---- include/configs/taurus.h | 1 - include/configs/theadorable.h | 1 - include/configs/ti814x_evm.h | 3 --- include/configs/ti_armv7_keystone2.h | 3 --- include/configs/topic_miami.h | 2 -- include/configs/turris_omnia.h | 1 - include/configs/x530.h | 1 - include/configs/xilinx_zynqmp.h | 3 --- include/configs/zynq-common.h | 3 --- scripts/config_whitelist.txt | 1 - 151 files changed, 95 insertions(+), 119 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 6304916..6b90f56 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -998,6 +998,14 @@ config SPL_SPI_LOAD Enable support for loading next stage, U-Boot or otherwise, from SPI NOR in U-Boot SPL.
+config SYS_SPI_U_BOOT_OFFS + hex "address of u-boot payload in SPI flash" + default 0x0 + depends on SPL_SPI_LOAD + help + Address within SPI-Flash from where the u-boot payload is fetched + from. + endif # SPL_SPI_FLASH_SUPPORT
config SPL_SPI_SUPPORT diff --git a/configs/alt_defconfig b/configs/alt_defconfig index a86ff90..d5934c1 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 96de6f4..248c302 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -27,6 +27,7 @@ CONFIG_SPL_DMA_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_CMD_DTIMG=y CONFIG_CMD_SPL=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index d776a0b..7b56df8 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_DTIMG=y CONFIG_CMD_BCB=y # CONFIG_CMD_FLASH is not set diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 6419c53..c8078e9 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -33,6 +33,7 @@ CONFIG_SPL_DMA_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SPL_USB_GADGET=y CONFIG_SPL_DFU=y CONFIG_SPL_YMODEM_SUPPORT=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 9d629f6..b58448f 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -38,6 +38,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 7882def..98b3446 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -37,6 +37,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index ec042d7..c20532d 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index f7beb79..18f6c38 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -24,6 +24,7 @@ CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_SPL_CRC32_SUPPORT is not set CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index d6fc7e3..0266e81 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 10b041e..3d2188a 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_SPL_CRC32_SUPPORT is not set CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index a133276..7047440 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_SPL_CRC32_SUPPORT is not set CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index 7891d62..5319ecb 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_SPL_CRC32_SUPPORT is not set CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 6f4fe45..be8c7ee 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x80 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_PROMPT="CM-FX6 # " # CONFIG_CMD_XIMG is not set diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 204e641..c121f65 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_PROMPT="CM-T43 # " CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index 93abad2..2098a7c 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -24,6 +24,7 @@ CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x30000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_GO is not set diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 7cbc9fb..5eb5d46 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -24,6 +24,7 @@ CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_CRC32_VERIFY=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 0ad4b66..cf71d0c 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_CRC32_VERIFY=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index a2d27ef..b0b5638 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -22,6 +22,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_SF=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 38d5192..4bf442e 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -23,6 +23,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x24000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index f54538a..aae1a7a 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x24000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 5654fd7..19acf16 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -22,6 +22,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 3022a187..99e5411 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -24,6 +24,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x11400 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_UNZIP=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 2275ee7..102b72d 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -33,6 +33,7 @@ CONFIG_SPL_SAVEENV=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="display5 > " diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 40df91a..64e7f84 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_SDP_SUPPORT=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 682e301..ad8868e 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 7b50d2c..7a5c3e7 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 6d6bfbc..040e6f7 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -34,6 +34,7 @@ CONFIG_SPL_DMA_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SPL_USB_GADGET=y CONFIG_SPL_DFU=y CONFIG_SPL_YMODEM_SUPPORT=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index d6b2b4a..4ba3bde 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y # CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is not set diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index 3f8c177..3f81c81 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -23,6 +23,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x24000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index cec5259..31e711d 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y # CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is not set diff --git a/configs/gose_defconfig b/configs/gose_defconfig index f591bd8..c827b53 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 917e33d..6e355f5 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_DM_RESET=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_POWER_DOMAIN=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index 60b7c40..b516f9d 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_REMOTEPROC=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 78864f2..5cdc33a 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -21,6 +21,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 48d7fdc..9ee79b4 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -21,6 +21,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 12358d1..de61d09 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -21,6 +21,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 1eef7f8..9842c91 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -21,6 +21,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 23d11df..b51b9d9 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index c056054..268959b 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 581e5bf..98d5d8c 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -21,6 +21,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_SF=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 82ee6d0..c239b0f 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -20,6 +20,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index f7e5faa..d4d6870 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y # CONFIG_CMD_FLASH is not set diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index f710d0d..8aa2644 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y # CONFIG_CMD_FLASH is not set diff --git a/configs/porter_defconfig b/configs/porter_defconfig index c42754b..1bf7684 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 5d2a28a..faf95c5 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index a34620b..201b9c9 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -27,6 +27,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index fa1d0da..452e761 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y # CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is not set diff --git a/configs/rut_defconfig b/configs/rut_defconfig index cc49c2e..ec31d52 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -28,6 +28,7 @@ CONFIG_ARCH_EARLY_INIT_R=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index d35d05f..d8f1c7e 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -29,6 +29,7 @@ CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index c38b397..a121b44 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -28,6 +28,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index a232b74..808fb26 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -29,6 +29,7 @@ CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 67a9dfe..f61d443 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -28,6 +28,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set diff --git a/configs/silk_defconfig b/configs/silk_defconfig index e38f634..b9d1971 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 3ab3cc4..89e5ff8 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -13,6 +13,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_DFU=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index a309e5b..00f2104 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -13,6 +13,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_DFU=y diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index 66f894e..1877010 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_ASKENV=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index ebaf247..de50f17 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -14,6 +14,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_DFU=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 0ac97c7..0396119 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -13,6 +13,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_DFU=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index f369301..6ea06c1 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 7feedbe..161bd6f 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -14,6 +14,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_DFU=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index dd03bc6..8ec1c05 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -13,6 +13,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_DFU=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 9e93281..15f81d1 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -13,6 +13,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_DFU=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 741525f..941bf11 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -16,6 +16,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index fbab388..ad83f50 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_BOOTDELAY=5 CONFIG_SPL_TEXT_BASE=0xFFE00000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x3C00000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SOCFPGA_STRATIX10 # " CONFIG_CMD_MEMTEST=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 9e86a23..96f806a 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -18,6 +18,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index d6d9e69..30caf9f 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x140000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 9b00387..33cecdb 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -24,6 +24,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x1a000 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 4c52610..ade82c8 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y # CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is not set diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index daab4b2..ddd43fa 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=0 CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SYS_PROMPT="zynq-uboot> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index f920142..17cc15d 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=0 CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SYS_PROMPT="zynq-uboot> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 9ba7282..3d0699d 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=0 CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_SYS_PROMPT="zynq-uboot> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 4c8ec32..4c089a0 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -28,6 +28,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x24000 CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y CONFIG_CMD_SHA1SUM=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 2bf20f4..56ea7b8 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -22,6 +22,7 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x24000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_MEMINFO=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index 1aee743..4ef00fd 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index f361ad9..ca08161 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y diff --git a/configs/zynq_cc108_defconfig b/configs/zynq_cc108_defconfig index 76a9a12..9bfe5ce 100644 --- a/configs/zynq_cc108_defconfig +++ b/configs/zynq_cc108_defconfig @@ -17,6 +17,7 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index e12306f..4972d70 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -22,6 +22,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_ARCH_EARLY_INIT_R is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/zynq_dlc20_rev1_0_defconfig b/configs/zynq_dlc20_rev1_0_defconfig index 1b4233c..b6751ad 100644 --- a/configs/zynq_dlc20_rev1_0_defconfig +++ b/configs/zynq_dlc20_rev1_0_defconfig @@ -20,6 +20,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index 3de1928..d30581b 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -15,6 +15,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y diff --git a/configs/zynq_z_turn_defconfig b/configs/zynq_z_turn_defconfig index ea24915..d133fea 100644 --- a/configs/zynq_z_turn_defconfig +++ b/configs/zynq_z_turn_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index caf97d8..6b670ae 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -19,6 +19,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index d4fcf9d..3d0cd31 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -22,6 +22,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_FPGA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 6458e62..53108ff 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -19,6 +19,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 5195ec3..30bb0ef 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -17,6 +17,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 1254b4e..9b6d754 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 078b436..2abc6db 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y diff --git a/configs/zynq_zybo_z7_defconfig b/configs/zynq_zybo_z7_defconfig index 3c97492..eda1416 100644 --- a/configs/zynq_zybo_z7_defconfig +++ b/configs/zynq_zybo_z7_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y diff --git a/include/configs/alt.h b/include/configs/alt.h index eb7eb55..bb52675 100644 --- a/include/configs/alt.h +++ b/include/configs/alt.h @@ -45,7 +45,6 @@ /* SPL support */ #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 #ifdef CONFIG_SPL_BUILD #define CONFIG_CONS_SCIF2 #define CONFIG_SH_SCIF_CLK_FREQ 65000000 diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 1885ac8..be57106 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -274,7 +274,6 @@ */ #if defined(CONFIG_SPI_BOOT) /* SPL related */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index e181b30..531f79e 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -90,6 +90,5 @@ #define CONFIG_SYS_SPI_ARGS_SIZE 0x80000
/* SPI SPL */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000
#endif /* __CONFIG_AM57XX_EVM_H */ diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 2abe979..bc79e17 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -151,11 +151,6 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - -#elif CONFIG_SYS_USE_NANDFLASH -#elif CONFIG_SPI_BOOT && CONFIG_SPL_SPI_LOAD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8400 - #elif CONFIG_NAND_BOOT #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_BASE diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 8056822..ad7d281 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -124,10 +124,6 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - -#elif CONFIG_SPI_BOOT && CONFIG_SPL_SPI_LOAD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8400 - #elif CONFIG_NAND_BOOT #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_BASE diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index bfa9fc9..db21a47 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -443,7 +443,6 @@ DEFAULT_LINUX_BOOT_ENV \ */ #if defined(CONFIG_SPI_BOOT) /* SPL related */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 5a40f3a..bc0dabb 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -181,7 +181,6 @@ NANDTGTS \
#if defined(CONFIG_SPI) /* SPI Flash */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 /* Environment */ #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ diff --git a/include/configs/brsmarc1.h b/include/configs/brsmarc1.h index c184458..c3eb5ba 100644 --- a/include/configs/brsmarc1.h +++ b/include/configs/brsmarc1.h @@ -72,7 +72,6 @@ BUR_COMMON_ENV \ #define CONFIG_INITRD_TAG
/* Environment */ #define CONFIG_SYS_REDUNDAND_ENVIRONMENT diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index eedf0dd..f109b22 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -17,7 +17,6 @@ #define CONFIG_MACH_TYPE 4122
#ifdef CONFIG_SPL -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 #include "imx6_spl.h" #endif
diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index b745f5c..82eae26 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -166,8 +166,5 @@
/* SPL */ #include "imx7_spl.h" -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 -#endif /* CONFIG_SPL_BUILD */
#endif /* __CONFIG_H */ diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 15c402b..9d20a5e 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -83,7 +83,6 @@
#if defined(CONFIG_MVEBU_SPL_BOOT_DEVICE_SPI) /* SPL related SPI defines */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 #define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS #elif defined(CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC) || defined(CONFIG_MVEBU_SPL_BOOT_DEVICE_SATA) /* SPL related MMC defines */ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index b2fae87..b957e9c 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -207,7 +207,6 @@
/* SPL */ #include "imx6_spl.h" -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000
/* Display */ #define CONFIG_IMX_HDMI diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 8d9bf71..fbd83e8 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -115,7 +115,6 @@
/* SPL defines. */ #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + (128 << 20)) -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_MONITOR_LEN (512 * 1024)
/* EEPROM */ diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 54bbfe3..f6d5328 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -97,7 +97,6 @@
#if CONFIG_SPL_BOOT_DEVICE == SPL_BOOT_SPI_NOR_FLASH /* SPL related SPI defines */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x30000 #define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS #endif
diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index b87b6b2..11e9cff 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -111,7 +111,6 @@ #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID)
#ifdef CONFIG_USE_SPIFLASH -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8000 #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 #endif
diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index a1780fa..79b9ccf 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -73,7 +73,6 @@ #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
#endif /* _CONFIG_DB_88F6720_H */ diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 5b59a92..e720b38 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -69,7 +69,6 @@
#if CONFIG_SPL_BOOT_DEVICE == SPL_BOOT_SPI_NOR_FLASH /* SPL related SPI defines */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x24000 #define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS #endif
diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index c98679e..900c962 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -85,7 +85,6 @@
diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 6ed58ce..417b5d5 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -83,7 +83,6 @@ #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
/* Enable DDR support in SPL (DDR3 training from Marvell bin_hdr) */ diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 7d2e573..bbf3283 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -23,7 +23,6 @@
/* SPL */ #include "imx6_spl.h" /* common IMX6 SPL configuration */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x11400 #define CONFIG_SPL_TARGET "u-boot-with-spl.imx"
/* Miscellaneous configurable options */ diff --git a/include/configs/display5.h b/include/configs/display5.h index 1d3334f..cb3d27d 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -45,7 +45,6 @@ #define CONFIG_SYS_SPI_ARGS_SIZE 0x10000
#include "imx6_spl.h" -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 7ec6e69..3487b8a 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -92,7 +92,6 @@ #endif
/* USB xHCI HOST */ #define CONFIG_USB_XHCI_OMAP diff --git a/include/configs/ds414.h b/include/configs/ds414.h index b175e9d..552c744 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -91,7 +91,6 @@ #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
/* DS414 bus width is 32bits */ #define CONFIG_DDR_32BIT diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h index bd46a34..fe28154 100644 --- a/include/configs/el6x_common.h +++ b/include/configs/el6x_common.h @@ -20,7 +20,6 @@ #define CONFIG_MXC_UART
diff --git a/include/configs/gose.h b/include/configs/gose.h index 0de0a36..fcb9f17 100644 --- a/include/configs/gose.h +++ b/include/configs/gose.h @@ -40,7 +40,6 @@ /* SPL support */ #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 #ifdef CONFIG_SPL_BUILD #define CONFIG_CONS_SCIF0 #define CONFIG_SH_SCIF_CLK_FREQ 65000000 diff --git a/include/configs/helios4.h b/include/configs/helios4.h index e03d840..4df3200 100644 --- a/include/configs/helios4.h +++ b/include/configs/helios4.h @@ -104,7 +104,6 @@ #define CONFIG_SPL_SPI_FLASH_SUPPORT #define CONFIG_SPL_SPI_LOAD #define CONFIG_SPL_SPI_SUPPORT -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x30000 #define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS #endif
diff --git a/include/configs/j721e_evm.h b/include/configs/j721e_evm.h index f8d4d7b..5fe77ef 100644 --- a/include/configs/j721e_evm.h +++ b/include/configs/j721e_evm.h @@ -22,7 +22,6 @@ #ifdef CONFIG_TARGET_J721E_A72_EVM #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + \ CONFIG_SYS_K3_NON_SECURE_MSRAM_SIZE) -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x280000 #else /* * Maximum size in memory allocated to the SPL BSS. Keep it as tight as @@ -45,7 +44,6 @@ /* Configure R5 SPL post-relocation malloc pool in DDR */ #define CONFIG_SYS_SPL_MALLOC_START 0x84000000 #define CONFIG_SYS_SPL_MALLOC_SIZE SZ_16M -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x80000 #endif
#ifdef CONFIG_SYS_K3_SPL_ATF diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index c42139d..140076a 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -40,7 +40,6 @@ /* SPL support */ #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 #ifdef CONFIG_SPL_BUILD #define CONFIG_CONS_SCIF0 #define CONFIG_SH_SCIF_CLK_FREQ 65000000 diff --git a/include/configs/lager.h b/include/configs/lager.h index 5acd5a2..db1dbc0 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -41,7 +41,6 @@ /* SPL support */ #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 #ifdef CONFIG_SPL_BUILD #define CONFIG_CONS_SCIF0 #define CONFIG_SH_SCIF_CLK_FREQ 65000000 diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index a017d92..9d5fbcd 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -71,7 +71,6 @@ #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
/* Enable DDR support in SPL (DDR3 training from Marvell bin_hdr) */ #define CONFIG_DDR_FIXED_SIZE (1 << 20) /* 1GiB */ diff --git a/include/configs/mt7629.h b/include/configs/mt7629.h index fc69d61..741b6fb 100644 --- a/include/configs/mt7629.h +++ b/include/configs/mt7629.h @@ -38,9 +38,6 @@ #define CONFIG_SPL_PAD_TO 0x10000
#define CONFIG_SPI_ADDR 0x30000000 -#ifdef CONFIG_SPL_SPI_LOAD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 -#endif #define CONFIG_SYS_UBOOT_BASE (CONFIG_SPI_ADDR + CONFIG_SPL_PAD_TO)
/* SPL -> Uboot */ diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index d4f404a..5c3ecdf 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -116,7 +116,6 @@ #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID)
#ifdef CONFIG_USE_SPIFLASH -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8000 #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x30000 #endif
diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 17ccf8b..4efef89 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -59,7 +59,6 @@ /* SPL */ #ifdef CONFIG_SPL #include "imx6_spl.h" -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 #endif
#define CONFIG_FEC_MXC diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index 153e567..fdbc075 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -117,7 +117,6 @@ /* CPU */
#ifdef CONFIG_SPI_BOOT -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 #endif
diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index 98959ce..d2dfe89 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -8,7 +8,6 @@ #define __PCM058_CONFIG_H
diff --git a/include/configs/pfla02.h b/include/configs/pfla02.h index ed7e4fb..8731d89 100644 --- a/include/configs/pfla02.h +++ b/include/configs/pfla02.h @@ -8,7 +8,6 @@ #define __PCM058_CONFIG_H
diff --git a/include/configs/phycore_am335x_r2.h b/include/configs/phycore_am335x_r2.h index 78d265d..ca28b6f 100644 --- a/include/configs/phycore_am335x_r2.h +++ b/include/configs/phycore_am335x_r2.h @@ -119,7 +119,6 @@ /* CPU */
#ifdef CONFIG_SPI_BOOT -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 #elif defined(CONFIG_ENV_IS_IN_NAND) #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE diff --git a/include/configs/porter.h b/include/configs/porter.h index 1db2886..db42176 100644 --- a/include/configs/porter.h +++ b/include/configs/porter.h @@ -45,7 +45,6 @@ /* SPL support */ #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 #ifdef CONFIG_SPL_BUILD #define CONFIG_CONS_SCIF0 #define CONFIG_SH_SCIF_CLK_FREQ 65000000 diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index e39009a..7dfbcb7 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -27,9 +27,6 @@ #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
/* RAW SD card / eMMC locations. */ -#ifdef CONFIG_SPL_SPI_LOAD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 -#endif
#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SYS_SDRAM_BASE 0x60000000 diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index f30cc94..45172707 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -30,9 +30,6 @@ #define CONFIG_IRAM_BASE 0xff700000
/* FAT sd card locations. */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index a68e01e..33cebb0 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -25,10 +25,6 @@
-#ifdef CONFIG_SPL_SPI_LOAD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 -#endif - /* FAT sd card locations. */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SYS_SDRAM_BASE 0 diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index cda5d03..121ede5 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -39,9 +39,6 @@ #define CONFIG_ROCKCHIP_SDHCI_MAX_FREQ 200000000
/* FAT sd card locations. */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h index 7898f4d..9b33acd 100644 --- a/include/configs/sama5d27_som1_ek.h +++ b/include/configs/sama5d27_som1_ek.h @@ -62,8 +62,4 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif
-#if defined(CONFIG_QSPI_BOOT) && defined(CONFIG_SPL_SPI_LOAD) -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 -#endif - #endif diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index 3dea359..4873395 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -69,10 +69,6 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - -#elif CONFIG_SPI_BOOT -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 - #endif
#endif diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index c5a2e54..3a712b5 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -83,10 +83,6 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - -#elif CONFIG_SPI_BOOT && CONFIG_SPL_SPI_LOAD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 - #elif CONFIG_NAND_BOOT #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_BASE diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 5e6f59f..1773412 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -47,11 +47,6 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - -#elif CONFIG_SYS_USE_NANDFLASH -#elif CONFIG_SPI_BOOT -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 - #elif CONFIG_NAND_BOOT #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_BASE diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index c1f22f7..6cf07a1 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -47,10 +47,6 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - -#elif CONFIG_SPI_BOOT -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 - #elif CONFIG_NAND_BOOT #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_BASE diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index dd63adb..ea6cc38 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -94,8 +94,6 @@ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
-#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 - #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC diff --git a/include/configs/silk.h b/include/configs/silk.h index c42b57a..a78da46 100644 --- a/include/configs/silk.h +++ b/include/configs/silk.h @@ -45,7 +45,6 @@ /* SPL support */ #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 #ifdef CONFIG_SPL_BUILD #define CONFIG_CONS_SCIF2 #define CONFIG_SH_SCIF_CLK_FREQ 65000000 diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 4141c7e..b11fe02 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -213,13 +213,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #endif
/* SPL QSPI boot support */ -#ifdef CONFIG_SPL_SPI_SUPPORT -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) && defined(CONFIG_SPL_SPI_LOAD) -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) && defined(CONFIG_SPL_SPI_LOAD) -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x100000 -#endif -#endif
/* SPL NAND boot support */ #ifdef CONFIG_SPL_NAND_SUPPORT diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index 90ad817..7b55dd1 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -201,7 +201,6 @@ unsigned int cm_get_l4_sys_free_clk_hz(void); #define CONFIG_SYS_SPL_MALLOC_SIZE (CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR \ - CONFIG_SYS_SPL_MALLOC_SIZE) -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x3C00000
/* SPL SDMMC boot support */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 diff --git a/include/configs/stout.h b/include/configs/stout.h index 4a465e0..6734595 100644 --- a/include/configs/stout.h +++ b/include/configs/stout.h @@ -49,7 +49,6 @@ /* SPL support */ #define CONFIG_SPL_STACK 0xe6340000 #define CONFIG_SPL_MAX_SIZE 0x4000 -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x140000 #ifdef CONFIG_SPL_BUILD #define CONFIG_CONS_SCIFA0 #define CONFIG_SH_SCIF_CLK_FREQ 52000000 diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index c5dbf6d..0ef289f 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -118,10 +118,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 8 #endif
-#if defined(CONFIG_SPL_SPI_SUNXI) && defined(CONFIG_SPL_SPI_LOAD) -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8000 -#endif - /* mmc config */ #ifdef CONFIG_MMC #define CONFIG_MMC_SUNXI_SLOT 0 diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 36a41ff..57c4007 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -103,7 +103,6 @@
#if defined(CONFIG_SPL_BUILD) /* SPL related */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 #endif
/* load address */ diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 3562a14..45cd7e2 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -106,7 +106,6 @@ #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
/* SPL related SPI defines */ -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x1a000 #define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS
/* Enable DDR support in SPL (DDR3 training from Marvell bin_hdr) */ diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 0c11587..b9b1308 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -130,9 +130,6 @@ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
-#ifdef CONFIG_SPL_SPI_LOAD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 -#endif #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000
/* diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 9144662..dacf7f7 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -44,9 +44,6 @@ CONFIG_SYS_SPL_MALLOC_SIZE + \ SPL_MALLOC_F_SIZE + \ KEYSTONE_SPL_STACK_SIZE - 4) -#ifdef CONFIG_SPL_SPI_LOAD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 -#endif
/* SRAM scratch space entries */ #define SRAM_SCRATCH_SPACE_ADDR CONFIG_SPL_STACK + 0x8 diff --git a/include/configs/topic_miami.h b/include/configs/topic_miami.h index a915c32..b98656d 100644 --- a/include/configs/topic_miami.h +++ b/include/configs/topic_miami.h @@ -22,8 +22,6 @@
/* SPL settings */ #undef CONFIG_SPL_ETH_SUPPORT -#undef CONFIG_SYS_SPI_U_BOOT_OFFS -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 #undef CONFIG_SPL_MAX_FOOTPRINT #define CONFIG_SPL_MAX_FOOTPRINT CONFIG_SYS_SPI_U_BOOT_OFFS #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" diff --git a/include/configs/turris_omnia.h b/include/configs/turris_omnia.h index edd776e..abe1e99 100644 --- a/include/configs/turris_omnia.h +++ b/include/configs/turris_omnia.h @@ -50,7 +50,6 @@
#ifdef CONFIG_MVEBU_SPL_BOOT_DEVICE_SPI /* SPL related SPI defines */ -# define CONFIG_SYS_SPI_U_BOOT_OFFS 0x24000 # define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS #endif
diff --git a/include/configs/x530.h b/include/configs/x530.h index 0946121..21fdd00 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -120,7 +120,6 @@ #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
#endif /* _CONFIG_X530_H */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 56500fe..a1c55a8 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -217,9 +217,6 @@ # define CONFIG_SYS_SPI_KERNEL_OFFS 0x80000 # define CONFIG_SYS_SPI_ARGS_OFFS 0xa0000 # define CONFIG_SYS_SPI_ARGS_SIZE 0xa0000 -#ifdef CONFIG_SPL_SPI_LOAD -# define CONFIG_SYS_SPI_U_BOOT_OFFS 0x170000 -#endif #endif
/* u-boot is like dtb */ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index fd761c2..ae08ebf 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -293,9 +293,6 @@
/* qspi mode is working fine */ #ifdef CONFIG_ZYNQ_QSPI -#ifdef CONFIG_SPL_SPI_LOAD -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x100000 -#endif #define CONFIG_SYS_SPI_ARGS_OFFS 0x200000 #define CONFIG_SYS_SPI_ARGS_SIZE 0x80000 #define CONFIG_SYS_SPI_KERNEL_OFFS (CONFIG_SYS_SPI_ARGS_OFFS + \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 66bf5c9..b810b31 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3942,7 +3942,6 @@ CONFIG_SYS_SPI_KERNEL_OFFS CONFIG_SYS_SPI_MXC_WAIT CONFIG_SYS_SPI_RTC_DEVID CONFIG_SYS_SPI_ST_ENABLE_WP_PIN -CONFIG_SYS_SPI_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_SIZE CONFIG_SYS_SPI_WRITE_TOUT CONFIG_SYS_SPL_ARGS_ADDR
On Thu, Aug 22, 2019 at 03:41:46PM +0200, Hannes Schmelzer wrote:
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
Chris Packham
Hannes Schmelzer
