[U-Boot] [RFC PATCH 0/2] RFC: Detect and reject new ad-hoc CONFIG options
Despite the availability of Kconfig, the number of ad-hoc CONFIG options in U-Boot is still at over 8000.
In February 2015 (commit 741e58e0) there were around 8387 ad-hoc CONFIGs. As of this patch there are about 8336, only a little fewer.
One problem is that new ones are still being added, admittedly at a slower rate. This series adds a Makefile check to detect that and produce a build error. This provides immediate feedback that new CONFIG options should go in Kconfig.
NOTE: This series needs work since there are some existing CONFIG options that are not included in the whitelist. Assuming that the approach makes sense, I will tweak my scripts to sort this out.
Simon Glass (2): Kconfig: Add a whitelist of ad-hoc CONFIG options Makefile: Give a build error if ad-hoc CONFIG options are added
Makefile | 10 +- scripts/check-config.sh | 55 + scripts/config_whitelist.txt | 9035 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 9099 insertions(+), 1 deletion(-) create mode 100755 scripts/check-config.sh create mode 100644 scripts/config_whitelist.txt
Add a list of ad-hoc CONFIG options that don't use Kconfig. This can be used to check that new ones are not being added.
scripts/config_whitelist.txt | 9035 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 9035 insertions(+) create mode 100644 scripts/config_whitelist.txt
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt new file mode 100644 index 0000000..586c86e --- /dev/null +++ b/scripts/config_whitelist.txt @@ -0,0 +1,9035 @@ +CONFIG_ +CONFIG_16BIT +CONFIG_32BIT +CONFIG_33 +CONFIG_4 +CONFIG_400MHZ_MODE +CONFIG_405 +CONFIG_405EP +CONFIG_405EX +CONFIG_405EX_CHIP21_ECID3_REV_D +CONFIG_405EX_CHIP21_PVR_REV_C +CONFIG_405EX_CHIP21_PVR_REV_D +CONFIG_405EZ +CONFIG_405GP +CONFIG_440 +CONFIG_440EP +CONFIG_440EPX +CONFIG_440GP +CONFIG_440GR +CONFIG_440GRX +CONFIG_440GX +CONFIG_440SP +CONFIG_440SPE +CONFIG_440SPE_REVA +CONFIG_440_GX +CONFIG_4430SDP +CONFIG_460EX +CONFIG_460GT +CONFIG_460SX +CONFIG_5 +CONFIG_521X +CONFIG_533MHZ_MODE +CONFIG_64BIT +CONFIG_64BIT_PHYS_ADDR +CONFIG_66 +CONFIG_8 +CONFIG_8260_CLKIN +CONFIG_8349_CLKIN +CONFIG_83XX +CONFIG_83XX_CLKIN +CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES +CONFIG_83XX_PCICLK +CONFIG_83XX_PCI_STREAMING +CONFIG_88F5182 +CONFIG_A003399_NOR_WORKAROUND +CONFIG_A008044_WORKAROUND +CONFIG_A3M071 +CONFIG_A4M072 +CONFIG_A4M2K +CONFIG_AC14XX +CONFIG_ACADIA +CONFIG_ACPI_GPE0_BASE +CONFIG_ACPI_PBLK_BASE +CONFIG_ACPI_PM1_BASE +CONFIG_ACX517AKN +CONFIG_ACX544AKN +CONFIG_ADCIOP +CONFIG_ADDMISC +CONFIG_ADDRESS +CONFIG_ADDR_AUTO_INCR_BIT +CONFIG_ADDR_MAP +CONFIG_ADDR_STREAMING +CONFIG_ADI_GPIO1 +CONFIG_ADI_GPIO2 +CONFIG_ADNPESC1 +CONFIG_ADP_AG101P +CONFIG_AEABI +CONFIG_AEMIF_CNTRL_BASE +CONFIG_AES +CONFIG_AHCI +CONFIG_ALTERA_JTAG_UART_BYPASS +CONFIG_ALTERA_SDRAM +CONFIG_ALTERA_SPI +CONFIG_ALTERA_SPI_IDLE_VAL +CONFIG_ALTERA_SYSID +CONFIG_ALTIVEC +CONFIG_ALT_LB_ADDR +CONFIG_ALT_LH_ADDR +CONFIG_ALU +CONFIG_AM335X_LCD +CONFIG_AM335X_USB0 +CONFIG_AM335X_USB0_MODE +CONFIG_AM335X_USB1 +CONFIG_AM335X_USB1_MODE +CONFIG_AM33XX +CONFIG_AM437X_USB2PHY2_HOST +CONFIG_AM43XX +CONFIG_AM57XX +CONFIG_AMBAPP_IOAREA +CONFIG_AMCC_DEF_ENV +CONFIG_AMCC_DEF_ENV_NOR_UPD +CONFIG_AMCC_DEF_ENV_POWERPC +CONFIG_AMCC_DEF_ENV_PPC +CONFIG_AMCC_DEF_ENV_PPC_OLD +CONFIG_AMCC_DEF_ENV_ROOTPATH +CONFIG_AMCORE +CONFIG_AMIGA_PARTITION +CONFIG_ANDES_PCU +CONFIG_ANDES_PCU_BASE +CONFIG_ANDROID_BOOT_IMAGE +CONFIG_AP325RXA +CONFIG_APBH_DMA +CONFIG_APBH_DMA_BURST +CONFIG_APBH_DMA_BURST8 +CONFIG_APER_0_BASE +CONFIG_APER_1_BASE +CONFIG_APER_SIZE +CONFIG_API +CONFIG_APUS_FAST_EXCEPT +CONFIG_AP_SH4A_4A +CONFIG_AP_STACK_SIZE +CONFIG_ARC +CONFIG_ARCHES +CONFIG_ARCH_AAED2000 +CONFIG_ARCH_ADI_COYOTE +CONFIG_ARCH_ADPAG101P +CONFIG_ARCH_AT91 +CONFIG_ARCH_AT91RM9200DK +CONFIG_ARCH_ATH79 +CONFIG_ARCH_AUTCPU12 +CONFIG_ARCH_BAST +CONFIG_ARCH_CATS +CONFIG_ARCH_CDB89712 +CONFIG_ARCH_CEIVA +CONFIG_ARCH_CINTEGRATOR +CONFIG_ARCH_CLEP7212 +CONFIG_ARCH_CPU_INIT +CONFIG_ARCH_CSB226 +CONFIG_ARCH_DAVINCI +CONFIG_ARCH_DMA_PIO_WORDS +CONFIG_ARCH_EARLY_INIT_R +CONFIG_ARCH_EBSA110 +CONFIG_ARCH_EBSA285 +CONFIG_ARCH_EDB7211 +CONFIG_ARCH_ENP2611 +CONFIG_ARCH_FIXUP_FDT +CONFIG_ARCH_FORTUNET +CONFIG_ARCH_GUMSTIX +CONFIG_ARCH_H1940 +CONFIG_ARCH_H5400 +CONFIG_ARCH_H7201 +CONFIG_ARCH_H7202 +CONFIG_ARCH_HAS_ILOG2_U32 +CONFIG_ARCH_HAS_ILOG2_U64 +CONFIG_ARCH_INNOKOM +CONFIG_ARCH_INTEGRATOR +CONFIG_ARCH_IQ31244 +CONFIG_ARCH_IQ80321 +CONFIG_ARCH_IQ80331 +CONFIG_ARCH_IXCDP1100 +CONFIG_ARCH_IXDP2400 +CONFIG_ARCH_IXDP2401 +CONFIG_ARCH_IXDP2800 +CONFIG_ARCH_IXDP2801 +CONFIG_ARCH_IXDP425 +CONFIG_ARCH_KIRKWOOD +CONFIG_ARCH_KS8695 +CONFIG_ARCH_L7200 +CONFIG_ARCH_LUBBOCK +CONFIG_ARCH_MAP_SYSMEM +CONFIG_ARCH_MISC_INIT +CONFIG_ARCH_MVEBU +CONFIG_ARCH_MX1ADS +CONFIG_ARCH_NETWINDER +CONFIG_ARCH_OMAP2 +CONFIG_ARCH_OMAP4 +CONFIG_ARCH_ORION5X +CONFIG_ARCH_P720T +CONFIG_ARCH_PERSONAL_SERVER +CONFIG_ARCH_PLEB +CONFIG_ARCH_PXA_CERF +CONFIG_ARCH_PXA_IDP +CONFIG_ARCH_RPC +CONFIG_ARCH_S3C2440 +CONFIG_ARCH_SHARK +CONFIG_ARCH_SMDK2410 +CONFIG_ARCH_SOCFPGA +CONFIG_ARCH_SUNXI +CONFIG_ARCH_TEGRA +CONFIG_ARCH_UNIPHIER +CONFIG_ARCH_UNIPHIER_LD11 +CONFIG_ARCH_UNIPHIER_LD20 +CONFIG_ARCH_UNIPHIER_LD4 +CONFIG_ARCH_UNIPHIER_LD6B +CONFIG_ARCH_UNIPHIER_PRO4 +CONFIG_ARCH_UNIPHIER_PRO5 +CONFIG_ARCH_UNIPHIER_PXS2 +CONFIG_ARCH_UNIPHIER_SLD3 +CONFIG_ARCH_UNIPHIER_SLD8 +CONFIG_ARCH_USE_BUILTIN_BSWAP +CONFIG_ARCH_VERSATILE_PB +CONFIG_ARCH_VIPER +CONFIG_ARCH_ZYNQ +CONFIG_ARCH_ZYNQMP +CONFIG_ARC_MMU_VER +CONFIG_ARC_SERIAL +CONFIG_ARC_UART_BASE +CONFIG_ARIA +CONFIG_ARIA_FPGA +CONFIG_ARM +CONFIG_ARM64 +CONFIG_ARM926EJS +CONFIG_ARMADA100 +CONFIG_ARMADA100_FEC +CONFIG_ARMADA100_SPI +CONFIG_ARMADA168 +CONFIG_ARMADA_38X +CONFIG_ARMADA_39X +CONFIG_ARMCORTEXA9 +CONFIG_ARMV7_BOOT_SEC_DEFAULT +CONFIG_ARMV7_LPAE +CONFIG_ARMV7_NONSEC +CONFIG_ARMV7_PSCI +CONFIG_ARMV7_PSCI_1_0 +CONFIG_ARMV7_PSCI_NR_CPUS +CONFIG_ARMV7_SECURE_BASE +CONFIG_ARMV7_SECURE_MAX_SIZE +CONFIG_ARMV7_SECURE_RESERVE_SIZE +CONFIG_ARMV7_VIRT +CONFIG_ARMV8 +CONFIG_ARMV8_MULTIENTRY +CONFIG_ARMV8_PSCI +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT +CONFIG_ARMV8_SPIN_TABLE +CONFIG_ARMV8_SWITCH_TO_EL1 +CONFIG_ARM_ARCH_CP15_ERRATA +CONFIG_ARM_ASM_UNIFIED +CONFIG_ARM_DCC +CONFIG_ARM_ERRATA_430973 +CONFIG_ARM_ERRATA_454179 +CONFIG_ARM_ERRATA_621766 +CONFIG_ARM_ERRATA_716044 +CONFIG_ARM_ERRATA_742230 +CONFIG_ARM_ERRATA_743622 +CONFIG_ARM_ERRATA_751472 +CONFIG_ARM_ERRATA_761320 +CONFIG_ARM_ERRATA_773022 +CONFIG_ARM_ERRATA_774769 +CONFIG_ARM_ERRATA_794072 +CONFIG_ARM_ERRATA_798870 +CONFIG_ARM_ERRATA_801819 +CONFIG_ARM_ERRATA_826974 +CONFIG_ARM_ERRATA_828024 +CONFIG_ARM_ERRATA_829520 +CONFIG_ARM_ERRATA_833069 +CONFIG_ARM_ERRATA_833471 +CONFIG_ARM_FREQ +CONFIG_ARM_GIC_BASE_ADDRESS +CONFIG_ARM_PL180_MMCI +CONFIG_ARM_PL180_MMCI_BASE +CONFIG_ARM_PL180_MMCI_CLOCK_FREQ +CONFIG_ARM_THUMB +CONFIG_ARP_TIMEOUT +CONFIG_AS3722_POWER +CONFIG_ASTRO5373L +CONFIG_ASTRO_COFDMDUOS2 +CONFIG_ASTRO_TWIN7S2 +CONFIG_ASTRO_V512 +CONFIG_ASTRO_V532 +CONFIG_ASTRO_V912 +CONFIG_AT32AP +CONFIG_AT32AP7000 +CONFIG_AT32UC3A0 +CONFIG_AT91C_PQFP_UHPBUG +CONFIG_AT91FAMILY +CONFIG_AT91RESET_EXTRST +CONFIG_AT91RM9200 +CONFIG_AT91RM9200EK +CONFIG_AT91SAM9260EK +CONFIG_AT91SAM9261 +CONFIG_AT91SAM9261EK +CONFIG_AT91SAM9263EK +CONFIG_AT91SAM9G10 +CONFIG_AT91SAM9G10EK +CONFIG_AT91SAM9G20 +CONFIG_AT91SAM9G20EK +CONFIG_AT91SAM9G20EK_2MMC +CONFIG_AT91SAM9G45EKES +CONFIG_AT91SAM9G45_LCD_BASE +CONFIG_AT91SAM9M10G45EK +CONFIG_AT91SAM9N12 +CONFIG_AT91SAM9RLEK +CONFIG_AT91SAM9X5 +CONFIG_AT91SAM9X5EK +CONFIG_AT91SAM9XE +CONFIG_AT91SAM9_WATCHDOG +CONFIG_AT91_CAN +CONFIG_AT91_EFLASH +CONFIG_AT91_GPIO +CONFIG_AT91_GPIO_PULLUP +CONFIG_AT91_HW_WDT_TIMEOUT +CONFIG_AT91_LED +CONFIG_AT91_LEGACY +CONFIG_AT91_WANTS_COMMON_PHY +CONFIG_ATAPI +CONFIG_ATA_ACPI +CONFIG_ATI +CONFIG_ATI_RADEON_FB +CONFIG_ATM +CONFIG_ATMEL_DATAFLASH_SPI +CONFIG_ATMEL_HLCD +CONFIG_ATMEL_LCD +CONFIG_ATMEL_LCD_BGR555 +CONFIG_ATMEL_LCD_RGB565 +CONFIG_ATMEL_LEGACY +CONFIG_ATMEL_MCI_8BIT +CONFIG_ATMEL_MCI_PORTB +CONFIG_ATMEL_NAND_HWECC +CONFIG_ATMEL_NAND_HW_PMECC +CONFIG_ATMEL_PIO4 +CONFIG_ATMEL_SDHCI +CONFIG_ATMEL_SDHCI0 +CONFIG_ATMEL_SDHCI1 +CONFIG_ATMEL_SPI +CONFIG_ATMEL_SPI0 +CONFIG_ATMEL_USART +CONFIG_ATNGW100 +CONFIG_ATNGW100MKII +CONFIG_ATSTK1000 +CONFIG_ATSTK1000_16MB_SDRAM +CONFIG_ATSTK1002 +CONFIG_AT_TRANS +CONFIG_AUTOBOOT +CONFIG_AUTOBOOT_DELAY_STR +CONFIG_AUTOBOOT_KEYED +CONFIG_AUTOBOOT_KEYED_CTRLC +CONFIG_AUTOBOOT_PROMPT +CONFIG_AUTOBOOT_STOP_STR +CONFIG_AUTOBOOT_STOP_STR_SHA256 +CONFIG_AUTOCALIB +CONFIG_AUTONEG_TIMEOUT +CONFIG_AUTO_COMPLETE +CONFIG_AUTO_ZRELADDR +CONFIG_AVR32 +CONFIG_AXP152_POWER +CONFIG_AXP209_POWER +CONFIG_AXP221_POWER +CONFIG_AXP809_POWER +CONFIG_AXP818_POWER +CONFIG_AXP_DCDC5_VOLT +CONFIG_AXP_DLDO1_VOLT +CONFIG_AXP_DLDO2_VOLT +CONFIG_AXP_DLDO3_VOLT +CONFIG_AXP_DLDO4_VOLT +CONFIG_AXP_ELDO1_VOLT +CONFIG_AXP_ELDO2_VOLT +CONFIG_AXP_ELDO3_VOLT +CONFIG_AXP_FLDO1_VOLT +CONFIG_AXP_FLDO2_VOLT +CONFIG_AXP_FLDO3_VOLT +CONFIG_AXP_GPIO +CONFIG_B2_SAMPLE +CONFIG_B4860QDS +CONFIG_BACKSIDE_L2_CACHE +CONFIG_BAMBOO +CONFIG_BAMBOO_NAND +CONFIG_BARIX_IPAM390 +CONFIG_BASE_FVP +CONFIG_BAT_CMD +CONFIG_BAT_PAIR +CONFIG_BAT_RW +CONFIG_BAUDRATE +CONFIG_BAZ +CONFIG_BCH +CONFIG_BCH_CONST_M +CONFIG_BCH_CONST_PARAMS +CONFIG_BCH_CONST_T +CONFIG_BCM2835 +CONFIG_BCM2835_GPIO +CONFIG_BCM2835_SDHCI +CONFIG_BCM2837 +CONFIG_BCM283X_MU_SERIAL +CONFIG_BCM_SF2_ETH +CONFIG_BCM_SF2_ETH_DEFAULT_PORT +CONFIG_BCM_SF2_ETH_GMAC +CONFIG_BD_NUM_CPUS +CONFIG_BF50 +CONFIG_BF506_UART0_PORTF +CONFIG_BF506_UART1_PORTG +CONFIG_BF51 +CONFIG_BF52 +CONFIG_BF527_EZKIT_REV_2_1 +CONFIG_BF54 +CONFIG_BF548_ATAPI_ALTERNATIVE_PORT +CONFIG_BF60 +CONFIG_BFIN_ATAPI_BASE_ADDR +CONFIG_BFIN_ATA_MODE +CONFIG_BFIN_BOARD_VERSION_1_0 +CONFIG_BFIN_BOOTROM_USES_EVT1 +CONFIG_BFIN_BOOT_MODE +CONFIG_BFIN_CF_IDE +CONFIG_BFIN_CPU +CONFIG_BFIN_GET_DCLK_M +CONFIG_BFIN_GPIO_TRACK +CONFIG_BFIN_HDD_IDE +CONFIG_BFIN_IDE +CONFIG_BFIN_INS_LOWOVERHEAD +CONFIG_BFIN_LINKPORT +CONFIG_BFIN_MAC +CONFIG_BFIN_MAC_PINS +CONFIG_BFIN_NFC +CONFIG_BFIN_NFC_BOOTROM_ECC +CONFIG_BFIN_NFC_CTL_VAL +CONFIG_BFIN_NFC_NO_HW_ECC +CONFIG_BFIN_SCRATCH_REG +CONFIG_BFIN_SDH +CONFIG_BFIN_SERIAL +CONFIG_BFIN_SOFT_SWITCH +CONFIG_BFIN_SPI +CONFIG_BFIN_SPI6XX +CONFIG_BFIN_SPI_GPIO_CS +CONFIG_BFIN_SPI_IDLE_VAL +CONFIG_BFIN_SPI_IMG_SIZE +CONFIG_BFIN_TRUE_IDE +CONFIG_BFIN_WATCHDOG +CONFIG_BIOSEMU +CONFIG_BITBANGMII +CONFIG_BITBANGMII_MULTI +CONFIG_BKUP_FLASH +CONFIG_BL1_OFFSET +CONFIG_BL1_SIZE +CONFIG_BL2_OFFSET +CONFIG_BL2_SIZE +CONFIG_BLACKFIN +CONFIG_BLK +CONFIG_BLOCK_CACHE +CONFIG_BMP_16BPP +CONFIG_BMP_24BMP +CONFIG_BMP_24BPP +CONFIG_BMP_32BPP +CONFIG_BOARDDIR +CONFIG_BOARDINFO +CONFIG_BOARDNAME +CONFIG_BOARDNAME_LOCAL +CONFIG_BOARD_BOOTCMD +CONFIG_BOARD_COMMON +CONFIG_BOARD_EARLY_INIT_F +CONFIG_BOARD_EARLY_INIT_R +CONFIG_BOARD_ECC_SUPPORT +CONFIG_BOARD_EMAC_COUNT +CONFIG_BOARD_H2200 +CONFIG_BOARD_IS_OPENRD_BASE +CONFIG_BOARD_IS_OPENRD_CLIENT +CONFIG_BOARD_IS_OPENRD_ULTIMATE +CONFIG_BOARD_LATE_INIT +CONFIG_BOARD_MEM_LIMIT +CONFIG_BOARD_NAME +CONFIG_BOARD_POSTCLK_INIT +CONFIG_BOARD_RESET +CONFIG_BOARD_REVISION_TAG +CONFIG_BOARD_SDRAM_SIZE +CONFIG_BOARD_SIZE_LIMIT +CONFIG_BOARD_SPECIFIC_LED +CONFIG_BOARD_TYPES +CONFIG_BOOGER +CONFIG_BOOKE +CONFIG_BOOM +CONFIG_BOOTARGS +CONFIG_BOOTARGS_AXM +CONFIG_BOOTARGS_ROOT +CONFIG_BOOTARGS_TAURUS +CONFIG_BOOTARGS_VIDEO +CONFIG_BOOTBLOCK +CONFIG_BOOTCOMMAND +CONFIG_BOOTCOUNT_ALEN +CONFIG_BOOTCOUNT_AM33XX +CONFIG_BOOTCOUNT_ENV +CONFIG_BOOTCOUNT_I2C +CONFIG_BOOTCOUNT_LIMIT +CONFIG_BOOTCOUNT_RAM +CONFIG_BOOTDELAY +CONFIG_BOOTFILE +CONFIG_BOOTMAPSZ +CONFIG_BOOTMODE +CONFIG_BOOTM_LINUX +CONFIG_BOOTM_NETBSD +CONFIG_BOOTM_OPENRTOS +CONFIG_BOOTM_OSE +CONFIG_BOOTM_PLAN9 +CONFIG_BOOTM_RTEMS +CONFIG_BOOTM_VXWORKS +CONFIG_BOOTP_ +CONFIG_BOOTP_BOOTFILE +CONFIG_BOOTP_BOOTFILESIZE +CONFIG_BOOTP_BOOTPATH +CONFIG_BOOTP_DEFAULT +CONFIG_BOOTP_DHCP_REQUEST_DELAY +CONFIG_BOOTP_DNS +CONFIG_BOOTP_DNS2 +CONFIG_BOOTP_GATEWAY +CONFIG_BOOTP_HOSTNAME +CONFIG_BOOTP_ID_CACHE_SIZE +CONFIG_BOOTP_MAY_FAIL +CONFIG_BOOTP_NISDOMAIN +CONFIG_BOOTP_NTPSERVER +CONFIG_BOOTP_PXE +CONFIG_BOOTP_PXE_CLIENTARCH +CONFIG_BOOTP_RANDOM_DELAY +CONFIG_BOOTP_SEND_HOSTNAME +CONFIG_BOOTP_SERVERIP +CONFIG_BOOTP_SUBNETMASK +CONFIG_BOOTP_TIMEOFFSET +CONFIG_BOOTP_VCI_STRING +CONFIG_BOOTP_VENDOREX +CONFIG_BOOTROM_ERR_REG +CONFIG_BOOTSCRIPT_ADDR +CONFIG_BOOTSCRIPT_COPY_RAM +CONFIG_BOOTSCRIPT_HDR_ADDR +CONFIG_BOOTSCRIPT_KEY_HASH +CONFIG_BOOTSTAGE +CONFIG_BOOTSTAGE_FDT +CONFIG_BOOTSTAGE_REPORT +CONFIG_BOOTSTAGE_STASH +CONFIG_BOOTSTAGE_STASH_ADDR +CONFIG_BOOTSTAGE_STASH_SIZE +CONFIG_BOOTSTAGE_USER_COUNT +CONFIG_BOOT_MODE_BIT +CONFIG_BOOT_OS_NET +CONFIG_BOOT_PARAMS_ADDR +CONFIG_BOOT_PCI +CONFIG_BOOT_RETRY_MIN +CONFIG_BOOT_RETRY_TIME +CONFIG_BOUNCE_BUFFER +CONFIG_BPTR_VIRT_ADDR +CONFIG_BSC9131 +CONFIG_BSC9131RDB +CONFIG_BSC9132 +CONFIG_BSC9132QDS +CONFIG_BSEIP +CONFIG_BS_ADDR_DEVICE +CONFIG_BS_ADDR_RAM +CONFIG_BS_COPY_CMD +CONFIG_BS_COPY_ENV +CONFIG_BS_HDR_ADDR_DEVICE +CONFIG_BS_HDR_ADDR_RAM +CONFIG_BS_HDR_SIZE +CONFIG_BS_SIZE +CONFIG_BTB +CONFIG_BUBINGA +CONFIG_BUFNO_AUTO_INCR_BIT +CONFIG_BUILD_ENVCRC +CONFIG_BUILD_TARGET +CONFIG_BUS_WIDTH +CONFIG_BZIP2 +CONFIG_B_SAMPLE +CONFIG_C29XPCIE +CONFIG_C2_SAMPLE +CONFIG_C3_SAMPLE +CONFIG_CACHELINE_ALIGNED_L1 +CONFIG_CACHE_MRC_BIN +CONFIG_CACHE_UNIPHIER +CONFIG_CADDY2 +CONFIG_CADENCE_QSPI +CONFIG_CALXEDA_XGMAC +CONFIG_CAM5200 +CONFIG_CANMB +CONFIG_CANYONLANDS +CONFIG_CAN_DRIVER +CONFIG_CBMEM_CONSOLE +CONFIG_CCLK_ACT_DIV +CONFIG_CCLK_DIV +CONFIG_CCLK_DIV_ +CONFIG_CCLK_HZ +CONFIG_CC_OPTIMIZE_FOR_SIZE +CONFIG_CDP_APPLIANCE_VLAN_TYPE +CONFIG_CDP_CAPABILITIES +CONFIG_CDP_DEVICE_ID +CONFIG_CDP_DEVICE_ID_PREFIX +CONFIG_CDP_PLATFORM +CONFIG_CDP_PORT_ID +CONFIG_CDP_POWER_CONSUMPTION +CONFIG_CDP_TRIGGER +CONFIG_CDP_VERSION +CONFIG_CFB_CONSOLE +CONFIG_CFB_CONSOLE_ANSI +CONFIG_CFG_DATA_SECTOR +CONFIG_CFG_FAT +CONFIG_CFG_USB +CONFIG_CFI_FLASH +CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +CONFIG_CF_ATASEL_DIS +CONFIG_CF_ATASEL_ENA +CONFIG_CF_DSPI +CONFIG_CF_QSPI +CONFIG_CF_SBF +CONFIG_CF_SPI +CONFIG_CF_V2 +CONFIG_CF_V3 +CONFIG_CF_V4 +CONFIG_CF_V4E +CONFIG_CGU_CTL_VAL +CONFIG_CGU_DIV_VAL +CONFIG_CHAIN_BOOT_CMD +CONFIG_CHAIN_OF_TRUST +CONFIG_CHARON +CONFIG_CHIP_SELECTS_PER_CTRL +CONFIG_CHIP_SELECT_QUAD_CAPABLE +CONFIG_CHROMEOS_EXTRA_ENV_SETTINGS +CONFIG_CIS8201_PHY +CONFIG_CI_UDC +CONFIG_CI_UDC_HAS_HOSTPC +CONFIG_CLK0_DIV +CONFIG_CLK0_EN +CONFIG_CLKIN_HALF +CONFIG_CLKIN_HZ +CONFIG_CLK_1000_200_200 +CONFIG_CLK_1000_330_165 +CONFIG_CLK_1000_400_200 +CONFIG_CLK_800_330_165 +CONFIG_CLK_DEBUG +CONFIG_CLK_EXYNOS +CONFIG_CLOCKS +CONFIG_CLOCKS_IN_MHZ +CONFIG_CLOCK_SYNTHESIZER +CONFIG_CM5200 +CONFIG_CM922T_XA10 +CONFIG_CMA101 +CONFIG_CMA102 +CONFIG_CMA286_21 +CONFIG_CMA286_60 +CONFIG_CMA286_60P +CONFIG_CMA286_60_OLD +CONFIG_CMA287_23 +CONFIG_CMA287_50 +CONFIG_CMA302 +CONFIG_CMDLINE +CONFIG_CMDLINE_EDITING +CONFIG_CMDLINE_PS_SUPPORT +CONFIG_CMDLINE_TAG +CONFIG_CMD_AES +CONFIG_CMD_AMBAPP +CONFIG_CMD_ASKEN +CONFIG_CMD_ASKENV +CONFIG_CMD_ATF +CONFIG_CMD_BAT +CONFIG_CMD_BDI +CONFIG_CMD_BEDBUG +CONFIG_CMD_BLOB +CONFIG_CMD_BMODE +CONFIG_CMD_BMP +CONFIG_CMD_BOOTD +CONFIG_CMD_BOOTEFI +CONFIG_CMD_BOOTI +CONFIG_CMD_BOOTLDR +CONFIG_CMD_BOOTM +CONFIG_CMD_BOOTMENU +CONFIG_CMD_BOOTZ +CONFIG_CMD_BSP +CONFIG_CMD_CACHE +CONFIG_CMD_CBFS +CONFIG_CMD_CDP +CONFIG_CMD_CHIP_CONFIG +CONFIG_CMD_CLEAR +CONFIG_CMD_CLK +CONFIG_CMD_CONSOLE +CONFIG_CMD_CPLBINFO +CONFIG_CMD_CRAMFS +CONFIG_CMD_CRC32 +CONFIG_CMD_CROS_EC +CONFIG_CMD_DATE +CONFIG_CMD_DDRPHY_DUMP +CONFIG_CMD_DEFAULTENV_VARS +CONFIG_CMD_DEKBLOB +CONFIG_CMD_DFL +CONFIG_CMD_DFU +CONFIG_CMD_DHCP +CONFIG_CMD_DIAG +CONFIG_CMD_DISPLAY +CONFIG_CMD_DNS +CONFIG_CMD_DOC +CONFIG_CMD_DS4510 +CONFIG_CMD_DS4510_INFO +CONFIG_CMD_DS4510_MEM +CONFIG_CMD_DS4510_RST +CONFIG_CMD_DTT +CONFIG_CMD_E1000 +CONFIG_CMD_ECCTEST +CONFIG_CMD_ECHO +CONFIG_CMD_EDITENV +CONFIG_CMD_EECONFIG +CONFIG_CMD_EEPROM +CONFIG_CMD_EEPROM_LAYOUT +CONFIG_CMD_ELF +CONFIG_CMD_ENTERRCM +CONFIG_CMD_ENV +CONFIG_CMD_ENV_CALLBACK +CONFIG_CMD_ENV_EXISTS +CONFIG_CMD_ENV_FLAGS +CONFIG_CMD_ERRATA +CONFIG_CMD_ESBC_VALIDATE +CONFIG_CMD_ETHSW +CONFIG_CMD_EXPORTENV +CONFIG_CMD_EXT2 +CONFIG_CMD_EXT4 +CONFIG_CMD_EXT4_WRITE +CONFIG_CMD_FASTBOOT +CONFIG_CMD_FAT +CONFIG_CMD_FDC +CONFIG_CMD_FDT_MAX_DUMP +CONFIG_CMD_FITUPD +CONFIG_CMD_FLASH +CONFIG_CMD_FPGA +CONFIG_CMD_FPGAD +CONFIG_CMD_FPGA_LOADBP +CONFIG_CMD_FPGA_LOADFS +CONFIG_CMD_FPGA_LOADMK +CONFIG_CMD_FPGA_LOADP +CONFIG_CMD_FS_GENERIC +CONFIG_CMD_FS_UUID +CONFIG_CMD_FUSE +CONFIG_CMD_GETTIME +CONFIG_CMD_GO +CONFIG_CMD_GPT +CONFIG_CMD_GREPENV +CONFIG_CMD_GSC +CONFIG_CMD_HASH +CONFIG_CMD_HD44760 +CONFIG_CMD_HD44780 +CONFIG_CMD_HDMIDETECT +CONFIG_CMD_I2C +CONFIG_CMD_IDE +CONFIG_CMD_IMI +CONFIG_CMD_IMLS +CONFIG_CMD_IMLS_NAND +CONFIG_CMD_IMMAP +CONFIG_CMD_IMPORTENV +CONFIG_CMD_IMXOTP +CONFIG_CMD_IMX_FUSE +CONFIG_CMD_INI +CONFIG_CMD_IO +CONFIG_CMD_IOLOOP +CONFIG_CMD_IOTRACE +CONFIG_CMD_IRQ +CONFIG_CMD_ITEST +CONFIG_CMD_JFFS2 +CONFIG_CMD_KGDB +CONFIG_CMD_LDRINFO +CONFIG_CMD_LED +CONFIG_CMD_LINK_LOCAL +CONFIG_CMD_LOADB +CONFIG_CMD_LOADS +CONFIG_CMD_LOADY +CONFIG_CMD_LZMADEC +CONFIG_CMD_MAX6957 +CONFIG_CMD_MD5SUM +CONFIG_CMD_MEM +CONFIG_CMD_MEMINFO +CONFIG_CMD_MEMORY +CONFIG_CMD_MEMTEST +CONFIG_CMD_MFSL +CONFIG_CMD_MII +CONFIG_CMD_MISC +CONFIG_CMD_MMC +CONFIG_CMD_MMC_SPI +CONFIG_CMD_MTDPARTS +CONFIG_CMD_MTDPARTS_SPREAD +CONFIG_CMD_NAND +CONFIG_CMD_NAND_LOCK_UNLOCK +CONFIG_CMD_NAND_TORTURE +CONFIG_CMD_NAND_TRIMFFS +CONFIG_CMD_NET +CONFIG_CMD_NFS +CONFIG_CMD_ONENAND +CONFIG_CMD_OTP +CONFIG_CMD_PART +CONFIG_CMD_PCA953X +CONFIG_CMD_PCA953X_INFO +CONFIG_CMD_PCI +CONFIG_CMD_PCI_ENUM +CONFIG_CMD_PCMCIA +CONFIG_CMD_PING +CONFIG_CMD_PINMON +CONFIG_CMD_PMIC +CONFIG_CMD_PORTIO +CONFIG_CMD_POWEROFF +CONFIG_CMD_PXE +CONFIG_CMD_QFW +CONFIG_CMD_RARP +CONFIG_CMD_READ +CONFIG_CMD_REGINFO +CONFIG_CMD_REISER +CONFIG_CMD_RUN +CONFIG_CMD_SANDBOX +CONFIG_CMD_SATA +CONFIG_CMD_SAVEENV +CONFIG_CMD_SAVES +CONFIG_CMD_SCSI +CONFIG_CMD_SDRAM +CONFIG_CMD_SETEXPR +CONFIG_CMD_SETGETDCR +CONFIG_CMD_SF +CONFIG_CMD_SF_TEST +CONFIG_CMD_SHA1SUM +CONFIG_CMD_SH_ZIMAGEBOOT +CONFIG_CMD_SNTP +CONFIG_CMD_SOFTSWITCH +CONFIG_CMD_SOURCE +CONFIG_CMD_SPI +CONFIG_CMD_SPIBOOTLDR +CONFIG_CMD_SPL +CONFIG_CMD_SPL_NAND_OFS +CONFIG_CMD_SPL_WRITE_SIZE +CONFIG_CMD_STRINGS +CONFIG_CMD_SX151X +CONFIG_CMD_TCA642X +CONFIG_CMD_TERMINAL +CONFIG_CMD_TFTP +CONFIG_CMD_TFTPPUT +CONFIG_CMD_TFTPSRV +CONFIG_CMD_THOR_DOWNLOAD +CONFIG_CMD_TIME +CONFIG_CMD_TIMER +CONFIG_CMD_TPM +CONFIG_CMD_TRACE +CONFIG_CMD_TSI148 +CONFIG_CMD_UBI +CONFIG_CMD_UBIFS +CONFIG_CMD_UNIVERSE +CONFIG_CMD_UNZIP +CONFIG_CMD_USB +CONFIG_CMD_USB_MASS_STORAGE +CONFIG_CMD_USB_STORAGE +CONFIG_CMD_UUID +CONFIG_CMD_XIMG +CONFIG_CMD_ZBOOT +CONFIG_CMD_ZFS +CONFIG_CMD_ZIP +CONFIG_CM_INIT +CONFIG_CM_MULTIPLE_SSRAM +CONFIG_CM_REMAP +CONFIG_CM_SPD_DETECT +CONFIG_CM_T335 +CONFIG_CM_T3517 +CONFIG_CM_T3X +CONFIG_CM_T43 +CONFIG_CM_T54 +CONFIG_CM_TCRAM +CONFIG_CNTL +CONFIG_COGENT +CONFIG_COLDFIRE +CONFIG_COLIBRI_IMX7_EXT_PHYCLK +CONFIG_COMMANDS +CONFIG_COMMAND_HISTORY +CONFIG_COMMON_BOOT +CONFIG_COMMON_ENV_MISC +CONFIG_COMMON_ENV_SETTINGS +CONFIG_COMMON_ENV_UBI +CONFIG_COMPACT_FLASH +CONFIG_COMPAT +CONFIG_CONSOLE +CONFIG_CONSOLE_DEV +CONFIG_CONSOLE_EXTRA_INFO +CONFIG_CONSOLE_INFO_QUIET +CONFIG_CONSOLE_MUX +CONFIG_CONSOLE_RECORD +CONFIG_CONSOLE_RECORD_IN_SIZE +CONFIG_CONSOLE_RECORD_OUT_SIZE +CONFIG_CONSOLE_ROTATION +CONFIG_CONSOLE_SCROLL_LINES +CONFIG_CONSOLE_TRUETYPE_ANKACODER +CONFIG_CONSOLE_TRUETYPE_CANTORAONE +CONFIG_CONSOLE_TRUETYPE_NIMBUS +CONFIG_CONSOLE_TRUETYPE_RUFSCRIPT +CONFIG_CONSOLE_TRUETYPE_SIZE +CONFIG_CONS_EXTC_PINSEL +CONFIG_CONS_EXTC_RATE +CONFIG_CONS_INDEX +CONFIG_CONS_NONE +CONFIG_CONS_ON_SCC +CONFIG_CONS_ON_SMC +CONFIG_CONS_SCIF0 +CONFIG_CONS_SCIF1 +CONFIG_CONS_SCIF2 +CONFIG_CONS_SCIF3 +CONFIG_CONS_SCIF4 +CONFIG_CONS_SCIF5 +CONFIG_CONS_SCIF7 +CONFIG_CONTROL +CONFIG_CONTROLCENTERD +CONFIG_CON_ROT +CONFIG_CORE1_RUN +CONFIG_CORE_COUNT +CONFIG_CORTINA_FW_ADDR +CONFIG_CORTINA_FW_LENGTH +CONFIG_CPCI405 +CONFIG_CPCI405_6U +CONFIG_CPCI405_VER2 +CONFIG_CPCI_AX2000 +CONFIG_CPLD_BR_PRELIM +CONFIG_CPLD_OR_PRELIM +CONFIG_CPM2 +CONFIG_CPU +CONFIG_CPUAT91 +CONFIG_CPU_ADDR_BITS +CONFIG_CPU_ARC750D +CONFIG_CPU_ARC770D +CONFIG_CPU_ARCEM6 +CONFIG_CPU_ARCHS34 +CONFIG_CPU_ARCHS38 +CONFIG_CPU_ARMV8 +CONFIG_CPU_BIG_ENDIAN +CONFIG_CPU_CAVIUM_OCTEON +CONFIG_CPU_FREQ_HZ +CONFIG_CPU_HAS_LLSC +CONFIG_CPU_HAS_PREFETCH +CONFIG_CPU_HAS_SMARTMIPS +CONFIG_CPU_HAS_SR_RB +CONFIG_CPU_HAS_WB +CONFIG_CPU_INTEL_TURBO_NOT_PACKAGE_SCOPED +CONFIG_CPU_LITTLE_ENDIAN +CONFIG_CPU_MICROMIPS +CONFIG_CPU_MIPS64 +CONFIG_CPU_MIPS64_R2 +CONFIG_CPU_MIPSR2 +CONFIG_CPU_MONAHANS +CONFIG_CPU_PXA25X +CONFIG_CPU_PXA26X +CONFIG_CPU_PXA27X +CONFIG_CPU_PXA300 +CONFIG_CPU_R8000 +CONFIG_CPU_SH2A +CONFIG_CPU_SH3 +CONFIG_CPU_SH4 +CONFIG_CPU_SH4A +CONFIG_CPU_SH7203 +CONFIG_CPU_SH7264 +CONFIG_CPU_SH7269 +CONFIG_CPU_SH7706 +CONFIG_CPU_SH7720 +CONFIG_CPU_SH7722 +CONFIG_CPU_SH7723 +CONFIG_CPU_SH7724 +CONFIG_CPU_SH7734 +CONFIG_CPU_SH7750 +CONFIG_CPU_SH7751 +CONFIG_CPU_SH7752 +CONFIG_CPU_SH7753 +CONFIG_CPU_SH7757 +CONFIG_CPU_SH7763 +CONFIG_CPU_SH7780 +CONFIG_CPU_SH7785 +CONFIG_CPU_SH_TYPE_R +CONFIG_CPU_TYPE_R +CONFIG_CPU_V7 +CONFIG_CPU_V7M +CONFIG_CPU_VR41XX +CONFIG_CQSPI_DECODER +CONFIG_CQSPI_REF_CLK +CONFIG_CRC32 +CONFIG_CRC32_VERIFY +CONFIG_CREATE_ARCH_SYMLINK +CONFIG_CROS_EC_KEYB +CONFIG_CS8900 +CONFIG_CS8900_BASE +CONFIG_CS8900_BUS16 +CONFIG_CS8900_BUS32 +CONFIG_CSF_SIZE +CONFIG_CTL_JTAG +CONFIG_CTL_TBE +CONFIG_CTRD1_PROBE_T1 +CONFIG_CTRD1_PROBE_T2 +CONFIG_CUSTOMER_BOARD_SUPPORT +CONFIG_CYRUS +CONFIG_C_SAMPLE +CONFIG_DA850_AM18X_EVM +CONFIG_DA850_EVM_MAX_CPU_CLK +CONFIG_DA850_LOWLEVEL +CONFIG_DA8XX_GPIO +CONFIG_DASA_SIM +CONFIG_DATA +CONFIG_DAVINCI_MMC +CONFIG_DAVINCI_MMC_SD1 +CONFIG_DAVINCI_SPI +CONFIG_DBAU1000 +CONFIG_DBAU1100 +CONFIG_DBAU1500 +CONFIG_DBAU1550 +CONFIG_DBAU1X00 +CONFIG_DBGU +CONFIG_DBG_MONITOR +CONFIG_DB_784MP_GP +CONFIG_DCACHE +CONFIG_DCACHE_OFF +CONFIG_DCACHE_RAM_BASE +CONFIG_DCACHE_RAM_MRC_VAR_SIZE +CONFIG_DCACHE_RAM_SIZE +CONFIG_DCACHE_WB +CONFIG_DCFG_ADDR +CONFIG_DCLK_DIV +CONFIG_DDR_ +CONFIG_DDR_2HCLK +CONFIG_DDR_2T_TIMING +CONFIG_DDR_32BIT +CONFIG_DDR_64BIT +CONFIG_DDR_CLK_FREQ +CONFIG_DDR_DATA_EYE +CONFIG_DDR_DEFAULT_CL +CONFIG_DDR_ECC +CONFIG_DDR_ECC_CMD +CONFIG_DDR_ECC_ENABLE +CONFIG_DDR_ECC_INIT_VIA_DMA +CONFIG_DDR_FIXED_SIZE +CONFIG_DDR_FREQ +CONFIG_DDR_HCLK +CONFIG_DDR_HYB25D512160BF +CONFIG_DDR_II +CONFIG_DDR_K4H511638C +CONFIG_DDR_LOG_LEVEL +CONFIG_DDR_MT46V16M16 +CONFIG_DDR_MT46V32M16 +CONFIG_DDR_MT47H128M8 +CONFIG_DDR_MT47H32M16 +CONFIG_DDR_MT47H64M16 +CONFIG_DDR_PLL2 +CONFIG_DDR_RFDC_FIXED +CONFIG_DDR_RQDC_FIXED +CONFIG_DDR_SPD +CONFIG_DEBUG +CONFIG_DEBUG_DEVRES +CONFIG_DEBUG_DUMP +CONFIG_DEBUG_DUMP_SYMS +CONFIG_DEBUG_EARLY_SERIAL +CONFIG_DEBUG_FS +CONFIG_DEBUG_LED +CONFIG_DEBUG_LL +CONFIG_DEBUG_LL_INCLUDE +CONFIG_DEBUG_LOCK_ALLOC +CONFIG_DEBUG_NULL_PTR +CONFIG_DEBUG_SECTION_MISMATCH +CONFIG_DEBUG_SEMIHOSTING +CONFIG_DEBUG_SERIAL +CONFIG_DEBUG_UART +CONFIG_DEBUG_UART_8250_FLOW_CONTROL +CONFIG_DEBUG_UART_8250_SHIFT +CONFIG_DEBUG_UART_8250_WORD +CONFIG_DEBUG_UART_ALTERA_JTAGUART +CONFIG_DEBUG_UART_ALTERA_UART +CONFIG_DEBUG_UART_ANNOUNCE +CONFIG_DEBUG_UART_APBUART +CONFIG_DEBUG_UART_AR933X +CONFIG_DEBUG_UART_ARM_DCC +CONFIG_DEBUG_UART_BASE +CONFIG_DEBUG_UART_BOARD_INIT +CONFIG_DEBUG_UART_CLOCK +CONFIG_DEBUG_UART_LINFLEXUART +CONFIG_DEBUG_UART_MESON +CONFIG_DEBUG_UART_NS16550 +CONFIG_DEBUG_UART_PIC32 +CONFIG_DEBUG_UART_S5P +CONFIG_DEBUG_UART_SHIFT +CONFIG_DEBUG_UART_SKIP_INIT +CONFIG_DEBUG_UART_UARTLITE +CONFIG_DEBUG_UART_ZYNQ +CONFIG_DEBUG_WRITECOUNT +CONFIG_DEB_DMA_URGENT +CONFIG_DEEP_SLEEP +CONFIG_DEFAULT +CONFIG_DEFAULT_CONSOLE +CONFIG_DEFAULT_DEVICE_TREE +CONFIG_DEFAULT_FDT_FILE +CONFIG_DEFAULT_IMMR +CONFIG_DEFAULT_KERNEL_COMMAND_LINE +CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC +CONFIG_DEFAULT_SPI_BUS +CONFIG_DEFAULT_SPI_CS +CONFIG_DEFAULT_SPI_MODE +CONFIG_DEF_HWCONFIG +CONFIG_DELAY_ENVIRONMENT +CONFIG_DENX_M28_V10 +CONFIG_DESIGNWARE_ETH +CONFIG_DESIGNWARE_SPI +CONFIG_DESIGNWARE_WATCHDOG +CONFIG_DEVCONCENTER +CONFIG_DEVELOP +CONFIG_DEVICE_TREE_LIST +CONFIG_DEVRES +CONFIG_DEV_USB_PHY_BASE +CONFIG_DFU_ALT +CONFIG_DFU_ALT_BOOT_EMMC +CONFIG_DFU_ALT_BOOT_SD +CONFIG_DFU_ALT_SYSTEM +CONFIG_DFU_ENV_SETTINGS +CONFIG_DFU_MMC +CONFIG_DFU_MTD +CONFIG_DFU_NAND +CONFIG_DFU_RAM +CONFIG_DFU_SF +CONFIG_DFU_TFTP +CONFIG_DHCP_MIN_EXT_LEN +CONFIG_DIALOG_POWER +CONFIG_DIGSY_MTC +CONFIG_DIMM_SLOTS_PER_CTLR +CONFIG_DIRECT_NOR_BOOT +CONFIG_DISABLE_CONSOLE +CONFIG_DISABLE_IGD +CONFIG_DISABLE_IMAGE_LEGACY +CONFIG_DISABLE_PISE_TEST +CONFIG_DISCONTIGMEM +CONFIG_DISCOVER_PHY +CONFIG_DISPLAY +CONFIG_DISPLAY_AER_ +CONFIG_DISPLAY_BOARDINFO +CONFIG_DISPLAY_BOARDINFO_LATE +CONFIG_DISPLAY_CPUINFO +CONFIG_DLVISION +CONFIG_DLVISION_10G +CONFIG_DM +CONFIG_DM9000_BASE +CONFIG_DM9000_BYTE_SWAPPED +CONFIG_DM9000_DEBUG +CONFIG_DM9000_NO_SROM +CONFIG_DM9000_USE_16BIT +CONFIG_DMA +CONFIG_DMA_ADDR_T_64BIT +CONFIG_DMA_COHERENT +CONFIG_DMA_COHERENT_SIZE +CONFIG_DMA_LPC32XX +CONFIG_DMA_NONCOHERENT +CONFIG_DMA_REQ_BIT +CONFIG_DMC_DDRCFG +CONFIG_DMC_DDRCTL +CONFIG_DMC_DDREMR1 +CONFIG_DMC_DDRMR +CONFIG_DMC_DDRTR0 +CONFIG_DMC_DDRTR1 +CONFIG_DMC_DDRTR2 +CONFIG_DM_DEVICE_REMOVE +CONFIG_DM_ETH +CONFIG_DM_GPIO +CONFIG_DM_I2C +CONFIG_DM_I2C_COMPAT +CONFIG_DM_KEYBOARD +CONFIG_DM_MMC +CONFIG_DM_MMC_OPS +CONFIG_DM_PCI +CONFIG_DM_PCI_COMPAT +CONFIG_DM_PMIC +CONFIG_DM_PMIC_PFUZE100 +CONFIG_DM_PWM +CONFIG_DM_REGULATOR_FIXED +CONFIG_DM_RTC +CONFIG_DM_SEQ_ALIAS +CONFIG_DM_SERIAL +CONFIG_DM_SPI +CONFIG_DM_SPI_FLASH +CONFIG_DM_STDIO +CONFIG_DM_THERMAL +CONFIG_DM_USB +CONFIG_DM_VIDEO +CONFIG_DM_WARN +CONFIG_DNET_AUTONEG_TIMEOUT +CONFIG_DNP5370_EXT_WD_DISABLE +CONFIG_DOS_PARTITION +CONFIG_DPLL_SSC_RATE_1PER +CONFIG_DP_DDR_CTRL +CONFIG_DP_DDR_DIMM_SLOTS_PER_CTLR +CONFIG_DP_DDR_NUM_CTRLS +CONFIG_DRA7XX +CONFIG_DRAM_2G +CONFIG_DRAM_CLK +CONFIG_DRAM_DQS_GATING_DELAY +CONFIG_DRAM_EMR1 +CONFIG_DRAM_MBUS_CLK +CONFIG_DRAM_ODT_CORRECTION +CONFIG_DRAM_TIMINGS_ +CONFIG_DRAM_TIMINGS_VENDOR_MAGIC +CONFIG_DRAM_TPR3 +CONFIG_DRAM_TYPE +CONFIG_DRAM_ZQ +CONFIG_DRIVER_AT91EMAC +CONFIG_DRIVER_AT91EMAC_PHYADDR +CONFIG_DRIVER_AT91EMAC_QUIET +CONFIG_DRIVER_AX88180 +CONFIG_DRIVER_AX88796L +CONFIG_DRIVER_DM9000 +CONFIG_DRIVER_EP93XX_MAC +CONFIG_DRIVER_ETHER +CONFIG_DRIVER_NAND_BFIN +CONFIG_DRIVER_NE2000 +CONFIG_DRIVER_NE2000_BASE +CONFIG_DRIVER_NE2000_CCR +CONFIG_DRIVER_NE2000_VAL +CONFIG_DRIVER_SMC911X_BASE +CONFIG_DRIVER_TI_CPSW +CONFIG_DRIVER_TI_EMAC +CONFIG_DRIVER_TI_EMAC_RMII_NO_NEGOTIATE +CONFIG_DRIVER_TI_EMAC_USE_RMII +CONFIG_DRIVER_TI_KEYSTONE_NET +CONFIG_DRIVE_MMC +CONFIG_DRIVE_SATA +CONFIG_DRIVE_TYPES +CONFIG_DRIVE_USB +CONFIG_DS4510 +CONFIG_DSP_CLUSTER_START +CONFIG_DTT +CONFIG_DTT_AD7414 +CONFIG_DTT_ADM1021 +CONFIG_DTT_DS1621 +CONFIG_DTT_DS1775 +CONFIG_DTT_DS620 +CONFIG_DTT_HYSTERESIS +CONFIG_DTT_LM63 +CONFIG_DTT_LM75 +CONFIG_DTT_LM81 +CONFIG_DTT_MAX_TEMP +CONFIG_DTT_MIN_TEMP +CONFIG_DTT_PWM_LOOKUPTABLE +CONFIG_DTT_SENSORS +CONFIG_DTT_TACH_LIMIT +CONFIG_DUOVERO +CONFIG_DV_USBPHY_CTL +CONFIG_DWC2_DFLT_SPEED_FULL +CONFIG_DWC2_DMA_BURST_SIZE +CONFIG_DWC2_DMA_ENABLE +CONFIG_DWC2_ENABLE_DYNAMIC_FIFO +CONFIG_DWC2_HOST_NPERIO_TX_FIFO_SIZE +CONFIG_DWC2_HOST_PERIO_TX_FIFO_SIZE +CONFIG_DWC2_HOST_RX_FIFO_SIZE +CONFIG_DWC2_I2C_ENABLE +CONFIG_DWC2_IC_USB_CAP +CONFIG_DWC2_MAX_CHANNELS +CONFIG_DWC2_MAX_PACKET_COUNT +CONFIG_DWC2_MAX_TRANSFER_SIZE +CONFIG_DWC2_PHY_TYPE +CONFIG_DWC2_PHY_ULPI_DDR +CONFIG_DWC2_PHY_ULPI_EXT_VBUS +CONFIG_DWC2_THR_CTL +CONFIG_DWC2_TS_DLINE +CONFIG_DWC2_TX_THR_LENGTH +CONFIG_DWC2_ULPI_FS_LS +CONFIG_DWC2_UTMI_WIDTH +CONFIG_DWCDDR21MCTL +CONFIG_DWCDDR21MCTL_BASE +CONFIG_DWC_AHSATA +CONFIG_DWC_AHSATA_BASE_ADDR +CONFIG_DWC_AHSATA_PORT_ID +CONFIG_DWMMC +CONFIG_DW_ALTDESCRIPTOR +CONFIG_DW_AXI_BURST_LEN +CONFIG_DW_GMAC_DEFAULT_DMA_PBL +CONFIG_DW_MAC_FORCE_THRESHOLD_MODE +CONFIG_DW_PORTS +CONFIG_DW_SERIAL +CONFIG_DW_UDC +CONFIG_DW_WDT_BASE +CONFIG_DW_WDT_CLOCK_KHZ +CONFIG_DYNAMIC_IO_PORT_BASE +CONFIG_DYNAMIC_MMC_DEVNO +CONFIG_E1000 +CONFIG_E1000_NO_NVM +CONFIG_E1000_SPI +CONFIG_E1000_SPI_GENERIC +CONFIG_E300 +CONFIG_E500 +CONFIG_E500MC +CONFIG_E5500 +CONFIG_E6500 +CONFIG_EARLY_POST_CROS_EC +CONFIG_EBCAW_VAL +CONFIG_EBC_PPC4 +CONFIG_EBIU_AMBCTL0_VAL +CONFIG_EBIU_AMBCTL1_VAL +CONFIG_EBIU_AMGCTL_VAL +CONFIG_EBIU_DDRCTL0_VAL +CONFIG_EBIU_DDRCTL1_VAL +CONFIG_EBIU_DDRCTL2_VAL +CONFIG_EBIU_DDRCTL3_VAL +CONFIG_EBIU_DDRQUE_VAL +CONFIG_EBIU_FCTL_VAL +CONFIG_EBIU_MBSCTL_VAL +CONFIG_EBIU_MODE_VAL +CONFIG_EBIU_RSTCTL_VAL +CONFIG_EBIU_SDBCTL_VAL +CONFIG_EBIU_SDGCTL_VAL +CONFIG_EBIU_SDRRC_VAL +CONFIG_EBSZ_VAL +CONFIG_ECC +CONFIG_ECC_INIT_VIA_DDRCONTROLLER +CONFIG_ECC_MODE_MASK +CONFIG_ECC_MODE_SHIFT +CONFIG_ECC_SRAM_ADDR_MASK +CONFIG_ECC_SRAM_ADDR_SHIFT +CONFIG_ECC_SRAM_REQ_BIT +CONFIG_ECOVEC +CONFIG_ECOVEC_ROMIMAGE_ADDR +CONFIG_EDB9301 +CONFIG_EDB9302 +CONFIG_EDB9302A +CONFIG_EDB9307 +CONFIG_EDB9307A +CONFIG_EDB9312 +CONFIG_EDB9315 +CONFIG_EDB9315A +CONFIG_EDB93XX_INDUSTRIAL +CONFIG_EDB93XX_SDCS0 +CONFIG_EDB93XX_SDCS1 +CONFIG_EDB93XX_SDCS2 +CONFIG_EDB93XX_SDCS3 +CONFIG_EEPRO100 +CONFIG_EEPRO100_SROM_WRITE +CONFIG_EEPROM_BUS_ADDRESS +CONFIG_EEPROM_CHIP_ADDRESS +CONFIG_EEPROM_LAYOUT_HELP_STRING +CONFIG_EFI +CONFIG_EFI_APP +CONFIG_EFI_LOADER +CONFIG_EFI_LOADER_BOUNCE_BUFFER +CONFIG_EFI_PARTITION +CONFIG_EFI_RAM_SIZE +CONFIG_EFI_STUB +CONFIG_EFI_STUB_32BIT +CONFIG_EFI_STUB_64BIT +CONFIG_EFLASH_PROTSECTORS +CONFIG_EHCI_DESC_BIG_ENDIAN +CONFIG_EHCI_HCD_INIT_AFTER_RESET +CONFIG_EHCI_IS_TDI +CONFIG_EHCI_MMIO_BIG_ENDIAN +CONFIG_EHCI_MXS_PORT0 +CONFIG_EHCI_MXS_PORT1 +CONFIG_ELBC_NAND_SPL_STATIC_PGSIZE +CONFIG_EMAC_MDIO_PHY_NUM +CONFIG_EMAC_NR_START +CONFIG_EMAC_PHY_MODE +CONFIG_EMIF4 +CONFIG_EMMC_BOOT +CONFIG_EMU +CONFIG_ENABLE_36BIT_PHYS +CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK +CONFIG_ENABLE_MMU +CONFIG_ENABLE_MRC_CACHE +CONFIG_ENABLE_MUST_CHECK +CONFIG_ENABLE_VBOOT +CONFIG_ENABLE_VMX +CONFIG_ENABLE_WARN_DEPRECATED +CONFIG_ENC_SILENTLINK +CONFIG_ENV_ +CONFIG_ENV_ACCESS_IGNORE_FORCE +CONFIG_ENV_ADDR +CONFIG_ENV_ADDR_FLEX +CONFIG_ENV_ADDR_REDUND +CONFIG_ENV_AES +CONFIG_ENV_BASE +CONFIG_ENV_CALLBACK_LIST_DEFAULT +CONFIG_ENV_CALLBACK_LIST_STATIC +CONFIG_ENV_COMMON_BOOT +CONFIG_ENV_EEPROM_IS_ON_I2C +CONFIG_ENV_FIT_UCBOOT +CONFIG_ENV_FLAGS_LIST_DEFAULT +CONFIG_ENV_FLAGS_LIST_STATIC +CONFIG_ENV_FLASHBOOT +CONFIG_ENV_IS_EMBEDDED +CONFIG_ENV_IS_EMBEDDED_IN_LDR +CONFIG_ENV_IS_IN_ +CONFIG_ENV_IS_IN_DATAFLASH +CONFIG_ENV_IS_IN_EEPROM +CONFIG_ENV_IS_IN_FAT +CONFIG_ENV_IS_IN_FLASH +CONFIG_ENV_IS_IN_MMC +CONFIG_ENV_IS_IN_MRAM +CONFIG_ENV_IS_IN_NAND +CONFIG_ENV_IS_IN_NVRAM +CONFIG_ENV_IS_IN_ONENAND +CONFIG_ENV_IS_IN_REMOTE +CONFIG_ENV_IS_IN_SPI_FLASH +CONFIG_ENV_IS_IN_UBI +CONFIG_ENV_IS_NOWHERE +CONFIG_ENV_MAX_ENTRIES +CONFIG_ENV_MIN_ENTRIES +CONFIG_ENV_MMC_OFFSET_REDUND +CONFIG_ENV_MMC_SIZE +CONFIG_ENV_OFFSET +CONFIG_ENV_OFFSET_OOB +CONFIG_ENV_OFFSET_REDUND +CONFIG_ENV_OFFSET_RENDUND +CONFIG_ENV_OVERWRITE +CONFIG_ENV_RANGE +CONFIG_ENV_RDADDR +CONFIG_ENV_REFLASH +CONFIG_ENV_SECT_SIZE +CONFIG_ENV_SETTINGS_BUTTONS_AND_LEDS +CONFIG_ENV_SETTINGS_NAND_V1 +CONFIG_ENV_SETTINGS_NAND_V2 +CONFIG_ENV_SETTINGS_V1 +CONFIG_ENV_SETTINGS_V2 +CONFIG_ENV_SIZE +CONFIG_ENV_SIZE_FLEX +CONFIG_ENV_SIZE_REDUND +CONFIG_ENV_SPI_BASE +CONFIG_ENV_SPI_BUS +CONFIG_ENV_SPI_CS +CONFIG_ENV_SPI_MAX_HZ +CONFIG_ENV_SPI_MODE +CONFIG_ENV_SROM_BANK +CONFIG_ENV_TOTAL_SIZE +CONFIG_ENV_UBIFS_OPTION +CONFIG_ENV_UBI_MTD +CONFIG_ENV_UBI_PART +CONFIG_ENV_UBI_VOLUME +CONFIG_ENV_UBI_VOLUME_REDUND +CONFIG_ENV_VARS_UBOOT_CONFIG +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +CONFIG_ENV_VERSION +CONFIG_EP9301 +CONFIG_EP9302 +CONFIG_EP9307 +CONFIG_EP9312 +CONFIG_EP9315 +CONFIG_EP93XX +CONFIG_EP93XX_NO_FLASH_CFG +CONFIG_EP93XX_SPI +CONFIG_EP93XX_SPI_MMC +CONFIG_EPH_POWER_EN +CONFIG_EPOLL +CONFIG_ERRNO_STR +CONFIG_ESBC_ADDR_64BIT +CONFIG_ESBC_HDR_LS +CONFIG_ESDHC_DETECT_8_BIT_QUIRK +CONFIG_ESDHC_DETECT_QUIRK +CONFIG_ESDHC_DETECT_USE_EXTERN_IRQ1 +CONFIG_ESDHC_HC_BLK_ADDR +CONFIG_ESPRESSO7420 +CONFIG_ESPT +CONFIG_ESRAM_BASE +CONFIG_ET1100_BASE +CONFIG_ETH1ADDR +CONFIG_ETH2ADDR +CONFIG_ETHADDR +CONFIG_ETHBASE +CONFIG_ETHER_INDEX +CONFIG_ETHER_LOOPBACK_TEST +CONFIG_ETHER_NONE +CONFIG_ETHER_ON_FCC +CONFIG_ETHER_ON_FCC1 +CONFIG_ETHER_ON_FCC2 +CONFIG_ETHER_ON_FCC3 +CONFIG_ETHER_ON_FEC +CONFIG_ETHER_ON_FEC1 +CONFIG_ETHER_ON_FEC2 +CONFIG_ETHER_ON_SCC +CONFIG_ETHOC +CONFIG_ETHPRIME +CONFIG_ETH_BUFSIZE +CONFIG_ETH_DESIGNWARE +CONFIG_ETH_RXSIZE +CONFIG_EXCEPTION_DEFER +CONFIG_EXPERIMENTAL +CONFIG_EXT4_WRITE +CONFIG_EXTRA_CLOCK +CONFIG_EXTRA_ENV +CONFIG_EXTRA_ENV_BOARD_SETTINGS +CONFIG_EXTRA_ENV_ITB +CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS +CONFIG_EXTRA_ENV_SETTINGS +CONFIG_EXTRA_ENV_SETTINGS_BASE +CONFIG_EXTRA_ENV_SETTINGS_COMMON +CONFIG_EXTRA_ENV_SETTINGS_DEVEL +CONFIG_EXTRA_ENV_SETTINGS_SELECT +CONFIG_EXTRA_ENV_UNLOCK +CONFIG_EXTRA_ENV_USBTTY +CONFIG_EXT_AHB2AHB_BASE +CONFIG_EXT_AHBAPBBRG_BASE +CONFIG_EXT_AHBPCIBRG_BASE +CONFIG_EXT_AHBSLAVE01_BASE +CONFIG_EXT_AHBSLAVE02_BASE +CONFIG_EXT_PHY +CONFIG_EXT_USB_HOST_BASE +CONFIG_EXYNOS4 +CONFIG_EXYNOS4210 +CONFIG_EXYNOS5 +CONFIG_EXYNOS5250 +CONFIG_EXYNOS5420 +CONFIG_EXYNOS5800 +CONFIG_EXYNOS5_DT +CONFIG_EXYNOS7420 +CONFIG_EXYNOS_ACE_SHA +CONFIG_EXYNOS_DP +CONFIG_EXYNOS_DWMMC +CONFIG_EXYNOS_FB +CONFIG_EXYNOS_MIPI_DSIM +CONFIG_EXYNOS_RELOCATE_CODE_BASE +CONFIG_EXYNOS_SPL +CONFIG_EXYNOS_TMU +CONFIG_FACTORYSET +CONFIG_FASTBOOT_BUF_ADDR +CONFIG_FASTBOOT_BUF_SIZE +CONFIG_FASTBOOT_FLASH +CONFIG_FASTBOOT_FLASH_FILLBUF_SIZE +CONFIG_FASTBOOT_FLASH_MMC_DEV +CONFIG_FASTBOOT_FLASH_NAND_DEV +CONFIG_FASTBOOT_FLASH_NAND_TRIMFFS +CONFIG_FASTBOOT_GPT_NAME +CONFIG_FAST_FLASH_BIT +CONFIG_FAT_WRITE +CONFIG_FB_ADDR +CONFIG_FB_BACKLIGHT +CONFIG_FB_DEFERRED_IO +CONFIG_FDT1_ENV_ADDR +CONFIG_FDT2_ENV_ADDR +CONFIG_FDTADDR +CONFIG_FDTFILE +CONFIG_FDT_ENV_ADDR +CONFIG_FDT_FIXUP_NOR_FLASH_SIZE +CONFIG_FDT_FIXUP_PARTITIONS +CONFIG_FDT_FIXUP_PCI_IRQ +CONFIG_FEATURE_CLEAN_UP +CONFIG_FEATURE_COMMAND_EDITING +CONFIG_FEATURE_SH_APPLETS_ALWAYS_WIN +CONFIG_FEATURE_SH_EXTRA_QUIET +CONFIG_FEATURE_SH_FANCY_PROMPT +CONFIG_FEATURE_SH_STANDALONE_SHELL +CONFIG_FEC +CONFIG_FEC1_PHY +CONFIG_FEC2_PHY +CONFIG_FEC_10MBIT +CONFIG_FEC_AN_TIMEOUT +CONFIG_FEC_ENET +CONFIG_FEC_ENET_DEV +CONFIG_FEC_FIXED_SPEED +CONFIG_FEC_MXC +CONFIG_FEC_MXC_25M_REF_CLK +CONFIG_FEC_MXC_PHYADDR +CONFIG_FEC_MXC_SWAP_PACKET +CONFIG_FEC_XCV_TYPE +CONFIG_FEROCEON +CONFIG_FEROCEON_88FR131 +CONFIG_FFUART +CONFIG_FILE +CONFIG_FILENAMES +CONFIG_FIRMWARE_OFFSET +CONFIG_FIRMWARE_SIZE +CONFIG_FIT +CONFIG_FIT_BEST_MATCH +CONFIG_FIT_DISABLE_SHA256 +CONFIG_FIT_SIGNATURE +CONFIG_FIT_SPL_PRINT +CONFIG_FIT_VERBOSE +CONFIG_FIXED_PHY +CONFIG_FIXED_PHY_ADDR +CONFIG_FIXED_SDHCI_ALIGNED_BUFFER +CONFIG_FLASHBOOTCOMMAND +CONFIG_FLASHCARD +CONFIG_FLASH_16BIT +CONFIG_FLASH_8BIT +CONFIG_FLASH_BASE +CONFIG_FLASH_BR_PRELIM +CONFIG_FLASH_CFI_DRIVER +CONFIG_FLASH_CFI_LEGACY +CONFIG_FLASH_CFI_MTD +CONFIG_FLASH_END +CONFIG_FLASH_NOT_MEM_MAPPED +CONFIG_FLASH_OR_PRELIM +CONFIG_FLASH_SECTOR_SIZE +CONFIG_FLASH_SHOW_PROGRESS +CONFIG_FLASH_SPANSION_S29WS_N +CONFIG_FLASH_VERIFY +CONFIG_FMAN_ENET +CONFIG_FM_PLAT_CLK_DIV +CONFIG_FO300 +CONFIG_FOO +CONFIG_FOOBAR +CONFIG_FORCE_DDR_DATA_BUS_WIDTH_32 +CONFIG_FORMIKE +CONFIG_FPGA +CONFIG_FPGA_ +CONFIG_FPGA_ALTERA +CONFIG_FPGA_COUNT +CONFIG_FPGA_CYCLON2 +CONFIG_FPGA_DELAY +CONFIG_FPGA_SOCFPGA +CONFIG_FPGA_SPARTAN2 +CONFIG_FPGA_SPARTAN3 +CONFIG_FPGA_STRATIX_V +CONFIG_FPGA_XILINX +CONFIG_FPGA_ZYNQPL +CONFIG_FRAMEBUFFER_SET_VESA_MODE +CONFIG_FRAMEBUFFER_VESA_MODE +CONFIG_FSLDMAFEC +CONFIG_FSL_CAAM +CONFIG_FSL_CADMUS +CONFIG_FSL_CORENET +CONFIG_FSL_CPLD +CONFIG_FSL_DCU_FB +CONFIG_FSL_DCU_SII9022A +CONFIG_FSL_DDR_BIST +CONFIG_FSL_DDR_FIRST_SLOT_QUAD_CAPABLE +CONFIG_FSL_DDR_INTERACTIVE +CONFIG_FSL_DDR_SYNC_REFRESH +CONFIG_FSL_DEBUG_SERVER +CONFIG_FSL_DEEP_SLEEP +CONFIG_FSL_DEVICE_DISABLE +CONFIG_FSL_DIU_CH7301 +CONFIG_FSL_DIU_FB +CONFIG_FSL_DMA +CONFIG_FSL_DSPI +CONFIG_FSL_DSPI1 +CONFIG_FSL_ELBC +CONFIG_FSL_ESDHC +CONFIG_FSL_ESDHC_ADAPTER_IDENT +CONFIG_FSL_ESDHC_PIN_MUX +CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK +CONFIG_FSL_ESPI +CONFIG_FSL_FIXED_MMC_LOCATION +CONFIG_FSL_FM_10GEC_REGULAR_NOTATION +CONFIG_FSL_I2C_CUSTOM_DFSR +CONFIG_FSL_I2C_CUSTOM_FDR +CONFIG_FSL_IFC +CONFIG_FSL_IIM +CONFIG_FSL_ISBC_KEY_EXT +CONFIG_FSL_LAW +CONFIG_FSL_LAYERSCAPE +CONFIG_FSL_LBC +CONFIG_FSL_LINFLEXUART +CONFIG_FSL_LPUART +CONFIG_FSL_LSCH2 +CONFIG_FSL_LSCH3 +CONFIG_FSL_LS_PPA +CONFIG_FSL_MC9SDZ60 +CONFIG_FSL_MC_ENET +CONFIG_FSL_MEMAC +CONFIG_FSL_NFC_CHIPS +CONFIG_FSL_NFC_SPARE_SIZE +CONFIG_FSL_NFC_WIDTH +CONFIG_FSL_NFC_WRITE_SIZE +CONFIG_FSL_NGPIXIS +CONFIG_FSL_PCIE_DISABLE_ASPM +CONFIG_FSL_PCIE_RESET +CONFIG_FSL_PCI_INIT +CONFIG_FSL_PIXIS +CONFIG_FSL_PMIC_BITLEN +CONFIG_FSL_PMIC_BUS +CONFIG_FSL_PMIC_CLK +CONFIG_FSL_PMIC_CS +CONFIG_FSL_PMIC_MODE +CONFIG_FSL_QIXIS +CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT +CONFIG_FSL_QIXIS_V2 +CONFIG_FSL_QSPI +CONFIG_FSL_SATA +CONFIG_FSL_SATA_ERRATUM_A001 +CONFIG_FSL_SATA_V2 +CONFIG_FSL_SDHC_V2_3 +CONFIG_FSL_SDRAM_TYPE +CONFIG_FSL_SEC_MON +CONFIG_FSL_SERDES +CONFIG_FSL_SERDES1 +CONFIG_FSL_SERDES2 +CONFIG_FSL_SGMII_RISER +CONFIG_FSL_SPI_INTERFACE +CONFIG_FSL_TBCLK_EXTRA_DIV +CONFIG_FSL_TRUST_ARCH_ +CONFIG_FSL_TZASC_400 +CONFIG_FSL_TZPC_BP147 +CONFIG_FSL_USDHC +CONFIG_FSL_VIA +CONFIG_FSMC_NAND_BASE +CONFIG_FSMTDBLK +CONFIG_FSNOTIFY +CONFIG_FSP_ADDR +CONFIG_FSP_BROKEN_HOB +CONFIG_FSP_SYS_MALLOC_F_LEN +CONFIG_FSP_TEMP_RAM_ADDR +CONFIG_FSP_USE_UPD +CONFIG_FS_EXT4 +CONFIG_FS_FAT +CONFIG_FS_FAT_MAX_CLUSTSIZE +CONFIG_FS_POSIX_ACL +CONFIG_FTAHBC020S +CONFIG_FTAHBC020S_BASE +CONFIG_FTAPBBRG020S_01_BASE +CONFIG_FTCFC010_BASE +CONFIG_FTDMAC020_BASE +CONFIG_FTGMAC100 +CONFIG_FTGMAC100_BASE +CONFIG_FTGMAC100_EGIGA +CONFIG_FTGPIO010_BASE +CONFIG_FTI2C010_BASE1 +CONFIG_FTI2C010_BASE2 +CONFIG_FTI2C010_BASE3 +CONFIG_FTI2C010_CLOCK +CONFIG_FTI2C010_TIMEOUT +CONFIG_FTIDE020S_BASE +CONFIG_FTIIC010_BASE +CONFIG_FTINTC010_BASE +CONFIG_FTLCDC100_BASE +CONFIG_FTMAC100 +CONFIG_FTMAC100_BASE +CONFIG_FTMAC110_BASE +CONFIG_FTPCI100_BASE +CONFIG_FTPCI100_IO_SIZE +CONFIG_FTPCI100_MEM_BASE +CONFIG_FTPCI100_MEM_SIZE +CONFIG_FTPMU010 +CONFIG_FTPMU010_BASE +CONFIG_FTPMU010_POWER +CONFIG_FTPWM010_BASE +CONFIG_FTRACE_MCOUNT_RECORD +CONFIG_FTRTC010_BASE +CONFIG_FTRTC010_EXTCLK +CONFIG_FTRTC010_PCLK +CONFIG_FTSDC010 +CONFIG_FTSDC010_BASE +CONFIG_FTSDC010_BASE_LIST +CONFIG_FTSDC010_NUMBER +CONFIG_FTSDC010_SDIO +CONFIG_FTSDC021_CLOCK +CONFIG_FTSDMC021 +CONFIG_FTSDMC021_BASE +CONFIG_FTSMC020 +CONFIG_FTSMC020_BASE +CONFIG_FTSSP010_01_BASE +CONFIG_FTSSP010_02_BASE +CONFIG_FTTMR010_BASE +CONFIG_FTTMR010_EXT_CLK +CONFIG_FTUART010_01_BASE +CONFIG_FTUART010_02_BASE +CONFIG_FTUART010_03_BASE +CONFIG_FTWDT010_BASE +CONFIG_FTWDT010_WATCHDOG +CONFIG_FUNC_ISRAM_ADDR +CONFIG_FWUPDATE_DEBUG +CONFIG_FZOTG266HD0A_BASE +CONFIG_GATEWAYIP +CONFIG_GCOV_KERNEL +CONFIG_GCOV_PROFILE_ALL +CONFIG_GENERATE_ACPI_TABLE +CONFIG_GENERATE_MP_TABLE +CONFIG_GENERATE_PIRQ_TABLE +CONFIG_GENERATE_SFI_TABLE +CONFIG_GENERATE_SMBIOS_TABLE +CONFIG_GENERIC_ATMEL_MCI +CONFIG_GENERIC_MMC +CONFIG_GICV2 +CONFIG_GICV3 +CONFIG_GLACIER +CONFIG_GLOBAL_DATA_NOT_REG10 +CONFIG_GLOBAL_TIMER +CONFIG_GMII +CONFIG_GOOD_SESH4 +CONFIG_GPCNTRL +CONFIG_GPCS_PHY1_ADDR +CONFIG_GPCS_PHY2_ADDR +CONFIG_GPCS_PHY3_ADDR +CONFIG_GPCS_PHY_ADDR +CONFIG_GPIO +CONFIG_GPIO_BASE +CONFIG_GPIO_ENABLE_SPI_FLASH +CONFIG_GPIO_LED +CONFIG_GPIO_LED_INVERTED_TABLE +CONFIG_GPIO_LED_STUBS +CONFIG_GREEN_LED +CONFIG_GRETH +CONFIG_GRETH_10MBIT +CONFIG_GRSIM +CONFIG_GRXC3S1500 +CONFIG_GR_EP2S60 +CONFIG_GURNARD_FPGA +CONFIG_GURNARD_SPLASH +CONFIG_GZIP +CONFIG_GZIP_COMPRESSED +CONFIG_GZIP_COMPRESS_DEF_SZ +CONFIG_G_DNL_MANUFACTURER +CONFIG_G_DNL_PRODUCT_NUM +CONFIG_G_DNL_THOR_PRODUCT_NUM +CONFIG_G_DNL_THOR_VENDOR_NUM +CONFIG_G_DNL_UMS_PRODUCT_NUM +CONFIG_G_DNL_UMS_VENDOR_NUM +CONFIG_G_DNL_VENDOR_NUM +CONFIG_H264_FREQ +CONFIG_H8300 +CONFIG_HARD_I2C +CONFIG_HARD_SPI +CONFIG_HAS +CONFIG_HASH_VERIFY +CONFIG_HAS_DATAFLASH +CONFIG_HAS_ETH0 +CONFIG_HAS_ETH1 +CONFIG_HAS_ETH2 +CONFIG_HAS_ETH3 +CONFIG_HAS_ETH4 +CONFIG_HAS_ETH5 +CONFIG_HAS_ETH7 +CONFIG_HAS_FEC +CONFIG_HAS_FSL_DR_USB +CONFIG_HAS_FSL_MPH_USB +CONFIG_HAS_FSL_XHCI_USB +CONFIG_HAS_POST +CONFIG_HAS_THUMB2 +CONFIG_HAS_VBAR +CONFIG_HAS_VR +CONFIG_HAVE_ACPI_RESUME +CONFIG_HAVE_ARCH_IOREMAP +CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS +CONFIG_HAVE_FSP +CONFIG_HAVE_OWN_RESET +CONFIG_HCLK_FREQ +CONFIG_HDBOOT +CONFIG_HDMI_ENCODER_I2C_ADDR +CONFIG_HETROGENOUS_CLUSTERS +CONFIG_HIDE_LOGO_VERSION +CONFIG_HIGH_BATS +CONFIG_HIGH_TABLE_SIZE +CONFIG_HIKEY_DWMMC +CONFIG_HIKEY_GPIO +CONFIG_HIS_DRIVER +CONFIG_HITACHI_SP19X001_Z1A +CONFIG_HITACHI_SX14 +CONFIG_HLD1045 +CONFIG_HOSTNAME +CONFIG_HOST_MAX_DEVICES +CONFIG_HOTPLUG +CONFIG_HPET_ADDRESS +CONFIG_HPS_ALTERAGRP_DBGATCLK +CONFIG_HPS_ALTERAGRP_MAINCLK +CONFIG_HPS_ALTERAGRP_MPUCLK +CONFIG_HPS_CLK_CAN0_HZ +CONFIG_HPS_CLK_CAN1_HZ +CONFIG_HPS_CLK_EMAC0_HZ +CONFIG_HPS_CLK_EMAC1_HZ +CONFIG_HPS_CLK_F2S_PER_REF_HZ +CONFIG_HPS_CLK_F2S_SDR_REF_HZ +CONFIG_HPS_CLK_GPIODB_HZ +CONFIG_HPS_CLK_L4_MP_HZ +CONFIG_HPS_CLK_L4_SP_HZ +CONFIG_HPS_CLK_MAINVCO_HZ +CONFIG_HPS_CLK_NAND_HZ +CONFIG_HPS_CLK_OSC1_HZ +CONFIG_HPS_CLK_OSC2_HZ +CONFIG_HPS_CLK_PERVCO_HZ +CONFIG_HPS_CLK_QSPI_HZ +CONFIG_HPS_CLK_SDMMC_HZ +CONFIG_HPS_CLK_SDRVCO_HZ +CONFIG_HPS_CLK_SPIM_HZ +CONFIG_HPS_CLK_USBCLK_HZ +CONFIG_HPS_DBCTRL_STAYOSC1 +CONFIG_HPS_IOCSR_SCANCHAIN0_LENGTH +CONFIG_HPS_IOCSR_SCANCHAIN1_LENGTH +CONFIG_HPS_IOCSR_SCANCHAIN2_LENGTH +CONFIG_HPS_IOCSR_SCANCHAIN3_LENGTH +CONFIG_HPS_MAINPLLGRP_CFGS2FUSER0CLK_CNT +CONFIG_HPS_MAINPLLGRP_DBGATCLK_CNT +CONFIG_HPS_MAINPLLGRP_DBGDIV_DBGATCLK +CONFIG_HPS_MAINPLLGRP_DBGDIV_DBGCLK +CONFIG_HPS_MAINPLLGRP_L4SRC_L4MP +CONFIG_HPS_MAINPLLGRP_L4SRC_L4SP +CONFIG_HPS_MAINPLLGRP_MAINCLK_CNT +CONFIG_HPS_MAINPLLGRP_MAINDIV_L3MPCLK +CONFIG_HPS_MAINPLLGRP_MAINDIV_L3SPCLK +CONFIG_HPS_MAINPLLGRP_MAINDIV_L4MPCLK +CONFIG_HPS_MAINPLLGRP_MAINDIV_L4SPCLK +CONFIG_HPS_MAINPLLGRP_MAINNANDSDMMCCLK_CNT +CONFIG_HPS_MAINPLLGRP_MAINQSPICLK_CNT +CONFIG_HPS_MAINPLLGRP_MPUCLK_CNT +CONFIG_HPS_MAINPLLGRP_TRACEDIV_TRACECLK +CONFIG_HPS_MAINPLLGRP_VCO_DENOM +CONFIG_HPS_MAINPLLGRP_VCO_NUMER +CONFIG_HPS_PERPLLGRP_DIV_CAN0CLK +CONFIG_HPS_PERPLLGRP_DIV_CAN1CLK +CONFIG_HPS_PERPLLGRP_DIV_SPIMCLK +CONFIG_HPS_PERPLLGRP_DIV_USBCLK +CONFIG_HPS_PERPLLGRP_EMAC0CLK_CNT +CONFIG_HPS_PERPLLGRP_EMAC1CLK_CNT +CONFIG_HPS_PERPLLGRP_GPIODIV_GPIODBCLK +CONFIG_HPS_PERPLLGRP_PERBASECLK_CNT +CONFIG_HPS_PERPLLGRP_PERNANDSDMMCCLK_CNT +CONFIG_HPS_PERPLLGRP_PERQSPICLK_CNT +CONFIG_HPS_PERPLLGRP_S2FUSER1CLK_CNT +CONFIG_HPS_PERPLLGRP_SRC_NAND +CONFIG_HPS_PERPLLGRP_SRC_QSPI +CONFIG_HPS_PERPLLGRP_SRC_SDMMC +CONFIG_HPS_PERPLLGRP_VCO_DENOM +CONFIG_HPS_PERPLLGRP_VCO_NUMER +CONFIG_HPS_PERPLLGRP_VCO_PSRC +CONFIG_HPS_SDRPLLGRP_DDR2XDQSCLK_CNT +CONFIG_HPS_SDRPLLGRP_DDR2XDQSCLK_PHASE +CONFIG_HPS_SDRPLLGRP_DDRDQCLK_CNT +CONFIG_HPS_SDRPLLGRP_DDRDQCLK_PHASE +CONFIG_HPS_SDRPLLGRP_DDRDQSCLK_CNT +CONFIG_HPS_SDRPLLGRP_DDRDQSCLK_PHASE +CONFIG_HPS_SDRPLLGRP_S2FUSER2CLK_CNT +CONFIG_HPS_SDRPLLGRP_S2FUSER2CLK_PHASE +CONFIG_HPS_SDRPLLGRP_VCO_DENOM +CONFIG_HPS_SDRPLLGRP_VCO_NUMER +CONFIG_HPS_SDRPLLGRP_VCO_SSRC +CONFIG_HPS_SDR_CTRLCFG_CPORTRDWR_CPORTRDWR +CONFIG_HPS_SDR_CTRLCFG_CPORTRMAP_CPORTRMAP +CONFIG_HPS_SDR_CTRLCFG_CPORTWIDTH_CPORTWIDTH +CONFIG_HPS_SDR_CTRLCFG_CPORTWMAP_CPORTWMAP +CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ADDRORDER +CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_DQSTRKEN +CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCCORREN +CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_ECCEN +CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMBL +CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_MEMTYPE +CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_NODMPINS +CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_REORDEREN +CONFIG_HPS_SDR_CTRLCFG_CTRLCFG_STARVELIMIT +CONFIG_HPS_SDR_CTRLCFG_CTRLWIDTH_CTRLWIDTH +CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_BANKBITS +CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_COLBITS +CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_CSBITS +CONFIG_HPS_SDR_CTRLCFG_DRAMADDRW_ROWBITS +CONFIG_HPS_SDR_CTRLCFG_DRAMDEVWIDTH_DEVWIDTH +CONFIG_HPS_SDR_CTRLCFG_DRAMIFWIDTH_IFWIDTH +CONFIG_HPS_SDR_CTRLCFG_DRAMINTR_INTREN +CONFIG_HPS_SDR_CTRLCFG_DRAMODT_READ +CONFIG_HPS_SDR_CTRLCFG_DRAMODT_WRITE +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_AL +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCL +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TCWL +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TFAW +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRFC +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING1_TRRD +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRCD +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TREFI +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TRP +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWR +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING2_IF_TWTR +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TCCD +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TMRD +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRAS +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRC +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING3_TRTP +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_PWRDOWNEXIT +CONFIG_HPS_SDR_CTRLCFG_DRAMTIMING4_SELFRFSHEXIT +CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_INCSYNC +CONFIG_HPS_SDR_CTRLCFG_FIFOCFG_SYNCMODE +CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST +CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST_COMMAND_PORT_USED +CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST_READ_PORT_USED +CONFIG_HPS_SDR_CTRLCFG_FPGAPORTRST_WRITE_PORT_USED +CONFIG_HPS_SDR_CTRLCFG_LOWPWREQ_SELFRFSHMASK +CONFIG_HPS_SDR_CTRLCFG_LOWPWRTIMING_AUTOPDCYCLES +CONFIG_HPS_SDR_CTRLCFG_LOWPWRTIMING_CLKDISABLECYCLES +CONFIG_HPS_SDR_CTRLCFG_MPPACING_0_THRESHOLD1_31_0 +CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD1_59_32 +CONFIG_HPS_SDR_CTRLCFG_MPPACING_1_THRESHOLD2_3_0 +CONFIG_HPS_SDR_CTRLCFG_MPPACING_2_THRESHOLD2_35_4 +CONFIG_HPS_SDR_CTRLCFG_MPPACING_3_THRESHOLD2_59_36 +CONFIG_HPS_SDR_CTRLCFG_MPPRIORITY_USERPRIORITY +CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_0_THRESHOLDRSTCYCLES_31_0 +CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_1_THRESHOLDRSTCYCLES_63_32 +CONFIG_HPS_SDR_CTRLCFG_MPTHRESHOLDRST_2_THRESHOLDRSTCYCLES_79_64 +CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_0_STATICWEIGHT_31_0 +CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_1_STATICWEIGHT_49_32 +CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_1_SUMOFWEIGHT_13_0 +CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_2_SUMOFWEIGHT_45_14 +CONFIG_HPS_SDR_CTRLCFG_MPWIEIGHT_3_SUMOFWEIGHT_63_46 +CONFIG_HPS_SDR_CTRLCFG_PHYCTRL_PHYCTRL_0 +CONFIG_HPS_SDR_CTRLCFG_PORTCFG_AUTOPCHEN +CONFIG_HPS_SDR_CTRLCFG_RFIFOCMAP_RFIFOCMAP +CONFIG_HPS_SDR_CTRLCFG_STATICCFG_MEMBL +CONFIG_HPS_SDR_CTRLCFG_STATICCFG_USEECCASDATA +CONFIG_HPS_SDR_CTRLCFG_WFIFOCMAP_WFIFOCMAP +CONFIG_HP_CLK_FREQ +CONFIG_HRCON +CONFIG_HRCON_DH +CONFIG_HRCON_FANS +CONFIG_HSMMC2_8BIT +CONFIG_HUSH_INIT_VAR +CONFIG_HUSH_PARSER +CONFIG_HVBOOT +CONFIG_HWCONFIG +CONFIG_HW_ENV_SETTINGS +CONFIG_HW_WATCHDOG +CONFIG_HW_WATCHDOG_TIMEOUT_INITCODE +CONFIG_HW_WATCHDOG_TIMEOUT_MS +CONFIG_I2C +CONFIG_I2C0_ENABLE +CONFIG_I2C1_ENABLE +CONFIG_I2C2_ENABLE +CONFIG_I2C3_ENABLE +CONFIG_I2C4_ENABLE +CONFIG_I2CFAST +CONFIG_I2C_CHIPADDRESS +CONFIG_I2C_CMD_TREE +CONFIG_I2C_EDID +CONFIG_I2C_ENV_EEPROM_BUS +CONFIG_I2C_FPGA +CONFIG_I2C_GSC +CONFIG_I2C_MAC_OFFSET +CONFIG_I2C_MBB_TIMEOUT +CONFIG_I2C_MULTI_BUS +CONFIG_I2C_MV +CONFIG_I2C_MVTWSI +CONFIG_I2C_MVTWSI_BASE +CONFIG_I2C_MVTWSI_BASE0 +CONFIG_I2C_MVTWSI_BASE1 +CONFIG_I2C_MVTWSI_BASE2 +CONFIG_I2C_MVTWSI_BASE3 +CONFIG_I2C_MVTWSI_BASE4 +CONFIG_I2C_MVTWSI_BASE5 +CONFIG_I2C_MXC +CONFIG_I2C_PMIC +CONFIG_I2C_REPEATED_START +CONFIG_I2C_RTC_ADDR +CONFIG_I2C_TIMEOUT +CONFIG_I8254_TIMER +CONFIG_I8259_PIC +CONFIG_IBM_EMAC4_V4 +CONFIG_ICACHE +CONFIG_ICACHE_OFF +CONFIG_ICON +CONFIG_ICS307_REFCLK_HZ +CONFIG_IDENT_STRING +CONFIG_IDE_8 +CONFIG_IDE_AHB +CONFIG_IDE_INIT_POSTRESET +CONFIG_IDE_LED +CONFIG_IDE_PCMCIA +CONFIG_IDE_PREINIT +CONFIG_IDE_REG_CS +CONFIG_IDE_RESET +CONFIG_IDE_RESET_ROUTINE +CONFIG_IDE_SIL680 +CONFIG_IDE_SWAP_IO +CONFIG_IDS8313 +CONFIG_IDT8T49N222A +CONFIG_ID_EEPROM +CONFIG_IFM_DEFAULT_ENV_NEW +CONFIG_IFM_DEFAULT_ENV_OLD +CONFIG_IFM_DEFAULT_ENV_SETTINGS +CONFIG_IFM_SENSOR_TYPE +CONFIG_IKCONFIG +CONFIG_IKCONFIG_PROC +CONFIG_IMA +CONFIG_IMAGE_FORMAT_LEGACY +CONFIG_IMX +CONFIG_IMX31_PHYCORE_EET +CONFIG_IMX6_PWM_PER_CLK +CONFIG_IMX_BOOTAUX +CONFIG_IMX_HDMI +CONFIG_IMX_OTP +CONFIG_IMX_RDC +CONFIG_IMX_THERMAL +CONFIG_IMX_VIDEO_SKIP +CONFIG_IMX_WATCHDOG +CONFIG_INITIAL_USB_SCAN_DELAY +CONFIG_INITRD_TAG +CONFIG_INIT_CRITICAL +CONFIG_INIT_IGNORE_ERROR +CONFIG_INIT_TLB +CONFIG_INI_ALLOW_MULTILINE +CONFIG_INI_CASE_INSENSITIVE +CONFIG_INI_MAX_LINE +CONFIG_INI_MAX_NAME +CONFIG_INI_MAX_SECTION +CONFIG_INKA4X0 +CONFIG_INTEGRITY +CONFIG_INTEL_ICH6_GPIO +CONFIG_INTEL_QUARK +CONFIG_INTERNAL_UART +CONFIG_INTERRUPTS +CONFIG_IO +CONFIG_IO64 +CONFIG_IOCON +CONFIG_IODELAY_RECALIBRATION +CONFIG_IOMUX_LPSR +CONFIG_IOMUX_SHARE_CONF_REG +CONFIG_IOS +CONFIG_IO_TRACE +CONFIG_IP86 +CONFIG_IPADDR +CONFIG_IPADDR1 +CONFIG_IPADDR2 +CONFIG_IPAM390_GPIO_BOOTMODE +CONFIG_IPAM390_GPIO_LED_GREEN +CONFIG_IPAM390_GPIO_LED_RED +CONFIG_IPEK01 +CONFIG_IPIPE +CONFIG_IPROC +CONFIG_IPUV3_CLK +CONFIG_IP_DEFRAG +CONFIG_IRAM_BASE +CONFIG_IRAM_END +CONFIG_IRAM_SIZE +CONFIG_IRAM_STACK +CONFIG_IRAM_TOP +CONFIG_IRDA_BASE +CONFIG_ISA_ARCV2 +CONFIG_ISO_PARTITION +CONFIG_ISO_STRING +CONFIG_ISP1362_USB +CONFIG_ISW_ENTRY_ADDR +CONFIG_IS_ +CONFIG_IS_BUILTIN +CONFIG_IS_ENABLED +CONFIG_IS_INVALID +CONFIG_IS_MODULE +CONFIG_IS_VALID +CONFIG_IVMS8 +CONFIG_JFFS2_CMDLINE +CONFIG_JFFS2_DEV +CONFIG_JFFS2_LZO +CONFIG_JFFS2_NAND +CONFIG_JFFS2_NAND_DEV +CONFIG_JFFS2_NAND_OFF +CONFIG_JFFS2_NAND_SIZE +CONFIG_JFFS2_PART_OFFSET +CONFIG_JFFS2_PART_SIZE +CONFIG_JFFS2_SUMMARY +CONFIG_JRSTARTR_JR0 +CONFIG_JTAG_CONSOLE +CONFIG_JTAG_CONSOLE_TIMEOUT +CONFIG_JUPITER +CONFIG_K2E_EVM +CONFIG_K2G_EVM +CONFIG_K2HK_EVM +CONFIG_K2L_EVM +CONFIG_KALLSYMS +CONFIG_KASAN +CONFIG_KATMAI +CONFIG_KCLK_DIS +CONFIG_KEEP_SERVERADDR +CONFIG_KERNEL_OFFSET +CONFIG_KEYBOARD +CONFIG_KEYSTONE_NAND_MAX_RBL_PAGE +CONFIG_KEYSTONE_NAND_MAX_RBL_SIZE +CONFIG_KEYSTONE_RBL_NAND +CONFIG_KEY_REVOCATION +CONFIG_KGDB_BAUDRATE +CONFIG_KGDB_EXTC_PINSEL +CONFIG_KGDB_EXTC_RATE +CONFIG_KGDB_INDEX +CONFIG_KGDB_ON_SCC +CONFIG_KGDB_ON_SMC +CONFIG_KGDB_SER_INDEX +CONFIG_KILAUEA +CONFIG_KIRKWOOD +CONFIG_KIRKWOOD_EGIGA_INIT +CONFIG_KIRKWOOD_GPIO +CONFIG_KIRKWOOD_PCIE_INIT +CONFIG_KIRKWOOD_RGMII_PAD_1V8 +CONFIG_KIRKWOOD_SPI +CONFIG_KIRQ_EN +CONFIG_KM8321 +CONFIG_KM8XX +CONFIG_KMCOGE5NE +CONFIG_KMETER1 +CONFIG_KMP204X +CONFIG_KMTEGR1 +CONFIG_KMVECT1 +CONFIG_KM_82XX +CONFIG_KM_BOARD_EXTRA_ENV +CONFIG_KM_BOARD_NAME +CONFIG_KM_COMMON_ETH_INIT +CONFIG_KM_CONSOLE_TTY +CONFIG_KM_CRAMFS_ADDR +CONFIG_KM_DEF_ARCH +CONFIG_KM_DEF_BOOT_ARGS_CPU +CONFIG_KM_DEF_ENV +CONFIG_KM_DEF_ENV_BOOTARGS +CONFIG_KM_DEF_ENV_BOOTPARAMS +CONFIG_KM_DEF_ENV_BOOTTARGETS +CONFIG_KM_DEF_ENV_CONSTANTS +CONFIG_KM_DEF_ENV_CPU +CONFIG_KM_DEF_ENV_FLASH_BOOT +CONFIG_KM_DEF_NETDEV +CONFIG_KM_DEV_ENV_FLASH_BOOT_UBI +CONFIG_KM_DISABLE_PCI +CONFIG_KM_DISABLE_PCIE +CONFIG_KM_ECC_MODE +CONFIG_KM_ENV_IS_IN_SPI_NOR +CONFIG_KM_FDT_ADDR +CONFIG_KM_FPGA_CONFIG +CONFIG_KM_I2C_ABORT +CONFIG_KM_IVM_BUS +CONFIG_KM_KERNEL_ADDR +CONFIG_KM_MVEXTSW_ADDR +CONFIG_KM_NEW_ENV +CONFIG_KM_PHRAM +CONFIG_KM_PIGGY4_88E6061 +CONFIG_KM_PIGGY4_88E6352 +CONFIG_KM_PNVRAM +CONFIG_KM_RESERVED_PRAM +CONFIG_KM_ROOTFSSIZE +CONFIG_KM_UBI_LINUX_MTD +CONFIG_KM_UBI_PARTITION_NAME_APP +CONFIG_KM_UBI_PARTITION_NAME_BOOT +CONFIG_KM_UBI_PART_BOOT_OPTS +CONFIG_KM_UIMAGE_NAME +CONFIG_KM_UPDATE_UBOOT +CONFIG_KONA +CONFIG_KONA_GPIO +CONFIG_KONA_RESET_S +CONFIG_KONA_SDHCI +CONFIG_KPROBES +CONFIG_KS8851_MLL +CONFIG_KS8851_MLL_BASEADDR +CONFIG_KSNAV_NETCP_PDMA_CTRL_BASE +CONFIG_KSNAV_NETCP_PDMA_RX_BASE +CONFIG_KSNAV_NETCP_PDMA_RX_CH_NUM +CONFIG_KSNAV_NETCP_PDMA_RX_FLOW_BASE +CONFIG_KSNAV_NETCP_PDMA_RX_FLOW_NUM +CONFIG_KSNAV_NETCP_PDMA_RX_FREE_QUEUE +CONFIG_KSNAV_NETCP_PDMA_RX_RCV_QUEUE +CONFIG_KSNAV_NETCP_PDMA_SCHED_BASE +CONFIG_KSNAV_NETCP_PDMA_TX_BASE +CONFIG_KSNAV_NETCP_PDMA_TX_CH_NUM +CONFIG_KSNAV_NETCP_PDMA_TX_SND_QUEUE +CONFIG_KSNAV_PKTDMA_NETCP +CONFIG_KSNAV_QM_BASE_ADDRESS +CONFIG_KSNAV_QM_CONF_BASE +CONFIG_KSNAV_QM_DESC_SETUP_BASE +CONFIG_KSNAV_QM_INTD_CONF_BASE +CONFIG_KSNAV_QM_LINK_RAM_BASE +CONFIG_KSNAV_QM_MANAGER_QUEUES_BASE +CONFIG_KSNAV_QM_MANAGER_Q_PROXY_BASE +CONFIG_KSNAV_QM_PDSP1_CMD_BASE +CONFIG_KSNAV_QM_PDSP1_CTRL_BASE +CONFIG_KSNAV_QM_PDSP1_IRAM_BASE +CONFIG_KSNAV_QM_QPOOL_NUM +CONFIG_KSNAV_QM_QUEUE_STATUS_BASE +CONFIG_KSNAV_QM_REGION_NUM +CONFIG_KSNAV_QM_STATUS_RAM_BASE +CONFIG_KSNET_CPSW_NUM_PORTS +CONFIG_KSNET_MAC_ID_BASE +CONFIG_KSNET_MDIO_PHY_CONFIG_ENABLE +CONFIG_KSNET_NETCP_BASE +CONFIG_KSNET_NETCP_V1_0 +CONFIG_KSNET_NETCP_V1_5 +CONFIG_KSNET_SERDES_LANES_PER_SGMII +CONFIG_KSNET_SERDES_SGMII2_BASE +CONFIG_KSNET_SERDES_SGMII_BASE +CONFIG_KVM_GUEST +CONFIG_KW88F6192 +CONFIG_KW88F6281 +CONFIG_KW88F6702 +CONFIG_KYOCERA_KCS057QV1AJ +CONFIG_KZM_A9_GT +CONFIG_L1_INIT_RAM +CONFIG_L2_CACHE +CONFIG_LAN91C96 +CONFIG_LAN91C96_BASE +CONFIG_LAN91C96_USE_32_BIT +CONFIG_LAST_STAGE_INIT +CONFIG_LAYERSCAPE_NS_ACCESS +CONFIG_LBA48 +CONFIG_LBD +CONFIG_LBDAF +CONFIG_LCD +CONFIG_LCD_ALIGNMENT +CONFIG_LCD_BMP_RLE8 +CONFIG_LCD_DT_SIMPLEFB +CONFIG_LCD_HEARTBEAT +CONFIG_LCD_INFO +CONFIG_LCD_INFO_BELOW_LOGO +CONFIG_LCD_IN_PSRAM +CONFIG_LCD_LOGO +CONFIG_LCD_MENU +CONFIG_LCD_MENU_BOARD +CONFIG_LCD_NOSTDOUT +CONFIG_LCD_ROTATION +CONFIG_LD9040 +CONFIG_LEGACY +CONFIG_LEGACY_BOOTCMD_ENV +CONFIG_LEON +CONFIG_LEON2 +CONFIG_LEON3 +CONFIG_LEON_RAM_SDRAM +CONFIG_LEON_RAM_SDRAM_NOSRAM +CONFIG_LEON_RAM_SELECT +CONFIG_LEON_RAM_SRAM +CONFIG_LG4573 +CONFIG_LG4573_BUS +CONFIG_LG4573_CS +CONFIG_LIBATA +CONFIG_LIB_HW_RAND +CONFIG_LIB_RAND +CONFIG_LIB_UUID +CONFIG_LINUX +CONFIG_LINUX_CMDLINE_ADDR +CONFIG_LINUX_CMDLINE_SIZE +CONFIG_LINUX_RESET_VEC +CONFIG_LITTLETON_LCD +CONFIG_LMB +CONFIG_LMS283GF05 +CONFIG_LOADADDR +CONFIG_LOADS_ECHO +CONFIG_LOCALVERSION +CONFIG_LOGBUFFER +CONFIG_LOOPW +CONFIG_LOWBOOT +CONFIG_LOWPOWER_ADDR +CONFIG_LOWPOWER_FLAG +CONFIG_LOW_MCFCLK +CONFIG_LPC32XX_ETH +CONFIG_LPC32XX_ETH_BUFS_BASE +CONFIG_LPC32XX_GPIO +CONFIG_LPC32XX_HSUART +CONFIG_LPC32XX_NAND_MLC_BUSY_DELAY +CONFIG_LPC32XX_NAND_MLC_NAND_TA +CONFIG_LPC32XX_NAND_MLC_RD_HIGH +CONFIG_LPC32XX_NAND_MLC_RD_LOW +CONFIG_LPC32XX_NAND_MLC_TCEA_DELAY +CONFIG_LPC32XX_NAND_MLC_WR_HIGH +CONFIG_LPC32XX_NAND_MLC_WR_LOW +CONFIG_LPC32XX_NAND_SLC_RDR_CLKS +CONFIG_LPC32XX_NAND_SLC_RHOLD +CONFIG_LPC32XX_NAND_SLC_RSETUP +CONFIG_LPC32XX_NAND_SLC_RWIDTH +CONFIG_LPC32XX_NAND_SLC_WDR_CLKS +CONFIG_LPC32XX_NAND_SLC_WHOLD +CONFIG_LPC32XX_NAND_SLC_WSETUP +CONFIG_LPC32XX_NAND_SLC_WWIDTH +CONFIG_LPC32XX_SDRAM_ +CONFIG_LPC32XX_SPL +CONFIG_LPC32XX_SSP +CONFIG_LPC32XX_SSP_TIMEOUT +CONFIG_LPC_BASE +CONFIG_LPC_IO_BASE +CONFIG_LPUART +CONFIG_LPUART_32B_REG +CONFIG_LQ035Q1_LCD_MODE +CONFIG_LQ035Q1_SPI_BUS +CONFIG_LQ035Q1_SPI_CS +CONFIG_LQ035Q1_USE_RGB565_8_BIT_PPI +CONFIG_LQ035Q1_USE_RGB888_8_BIT_PPI +CONFIG_LQ038J7DH53 +CONFIG_LS1012A +CONFIG_LS102XA +CONFIG_LS102XA_STREAM_ID +CONFIG_LS1043A +CONFIG_LS2080A +CONFIG_LUAN +CONFIG_LWMON5 +CONFIG_LXT971_NO_SLEEP +CONFIG_LYNXKDI +CONFIG_LZ4 +CONFIG_LZMA +CONFIG_LZO +CONFIG_M41T94_SPI_CS +CONFIG_M520 +CONFIG_M5208 +CONFIG_M52277 +CONFIG_M52277EVB +CONFIG_M5235 +CONFIG_M5249 +CONFIG_M5253 +CONFIG_M5253DEMO +CONFIG_M5253EVBE +CONFIG_M5271 +CONFIG_M5272 +CONFIG_M5275 +CONFIG_M5275EVB +CONFIG_M5282 +CONFIG_M5301 +CONFIG_M5307 +CONFIG_M5329 +CONFIG_M5373 +CONFIG_M54418 +CONFIG_M54418TWR +CONFIG_M54451 +CONFIG_M54451EVB +CONFIG_M54455 +CONFIG_M54455EVB +CONFIG_M547 +CONFIG_M548 +CONFIG_M68K +CONFIG_M88E1111_DISABLE_FIBER +CONFIG_M88E1111_PHY +CONFIG_M88E1112_PHY +CONFIG_M88E1141_PHY +CONFIG_MACB +CONFIG_MACB0_PHY +CONFIG_MACB1_PHY +CONFIG_MACB2_PHY +CONFIG_MACB3_PHY +CONFIG_MACB_SEARCH_PHY +CONFIG_MACH_A0 +CONFIG_MACH_A2F +CONFIG_MACH_ABACUS +CONFIG_MACH_ABB_GMA_1_1 +CONFIG_MACH_ABILENE +CONFIG_MACH_ABLE +CONFIG_MACH_ACER_A5 +CONFIG_MACH_ACER_A8 +CONFIG_MACH_ACER_GAUGUIN +CONFIG_MACH_ACER_MAYA +CONFIG_MACH_ACMENETUSFOXG20 +CONFIG_MACH_ACMEROVER1 +CONFIG_MACH_ACRO37XBRD +CONFIG_MACH_ACS5K +CONFIG_MACH_ACSX106 +CONFIG_MACH_ADSSPHERE +CONFIG_MACH_AEBL +CONFIG_MACH_AF4000 +CONFIG_MACH_AFEB9260 +CONFIG_MACH_AG11005 +CONFIG_MACH_AG5EVM +CONFIG_MACH_AKITA +CONFIG_MACH_AMK_A4 +CONFIG_MACH_AML_M5900 +CONFIG_MACH_AMS_DELTA +CONFIG_MACH_ANCHOVY +CONFIG_MACH_ANTARES +CONFIG_MACH_ANTERO +CONFIG_MACH_ANUBIS +CONFIG_MACH_ANW6410 +CONFIG_MACH_AP4EVB +CONFIG_MACH_APALIS_T30 +CONFIG_MACH_APP3K_ROBIN +CONFIG_MACH_AQUARIUS +CONFIG_MACH_AQUILA +CONFIG_MACH_ARCOM_VULCAN +CONFIG_MACH_ARCOM_ZEUS +CONFIG_MACH_ARK9431 +CONFIG_MACH_ARMADA_XP_DB +CONFIG_MACH_ARMADILLO460 +CONFIG_MACH_ARMADILLO5X0 +CONFIG_MACH_ARMADILLO800EVA +CONFIG_MACH_ARMCORE +CONFIG_MACH_ARMLEX4210 +CONFIG_MACH_ARMLGUEST +CONFIG_MACH_AROWANA +CONFIG_MACH_ARTHUR +CONFIG_MACH_ARUBA +CONFIG_MACH_AS1167 +CONFIG_MACH_ASL_PHOENIX +CONFIG_MACH_ASPEN +CONFIG_MACH_ASPENITE +CONFIG_MACH_AST2200 +CONFIG_MACH_AT2440EVB +CONFIG_MACH_AT572D940HFEB +CONFIG_MACH_AT91CAP7STK +CONFIG_MACH_AT91CAP7XDK +CONFIG_MACH_AT91CAP9ADK +CONFIG_MACH_AT91EB01 +CONFIG_MACH_AT91RM9200EK +CONFIG_MACH_AT91SAM9260EK +CONFIG_MACH_AT91SAM9261EK +CONFIG_MACH_AT91SAM9263DESK16L +CONFIG_MACH_AT91SAM9263EK +CONFIG_MACH_AT91SAM9263OTLITE +CONFIG_MACH_AT91SAM9G10EK +CONFIG_MACH_AT91SAM9G20EK +CONFIG_MACH_AT91SAM9G20EK_2MMC +CONFIG_MACH_AT91SAM9G45EKES +CONFIG_MACH_AT91SAM9M10G45EK +CONFIG_MACH_AT91SAM9RLEK +CONFIG_MACH_AT91SAM9X5EK +CONFIG_MACH_ATDGP318 +CONFIG_MACH_ATEB9200 +CONFIG_MACH_ATHENE +CONFIG_MACH_ATLAS5_C1 +CONFIG_MACH_AUTOBOT +CONFIG_MACH_AVENGERS_LITE +CONFIG_MACH_AVILA +CONFIG_MACH_AWM2 +CONFIG_MACH_AX502 +CONFIG_MACH_AX8008 +CONFIG_MACH_B5500 +CONFIG_MACH_BASI +CONFIG_MACH_BCM2708 +CONFIG_MACH_BCM589X +CONFIG_MACH_BCMHANA_SV +CONFIG_MACH_BCMHANA_TABLET +CONFIG_MACH_BCMRING +CONFIG_MACH_BEECT +CONFIG_MACH_BIGDISK +CONFIG_MACH_BIO3K +CONFIG_MACH_BIPNET +CONFIG_MACH_BLISS +CONFIG_MACH_BLISSC +CONFIG_MACH_BLUECHEESE +CONFIG_MACH_BLUEPOINT +CONFIG_MACH_BLUESHARK +CONFIG_MACH_BOCKW +CONFIG_MACH_BONAIRE +CONFIG_MACH_BORABORA +CONFIG_MACH_BORZOI +CONFIG_MACH_BROWNSTONE +CONFIG_MACH_BSTBRD +CONFIG_MACH_BTMAVB101 +CONFIG_MACH_BTMAWB101 +CONFIG_MACH_BUBBA3 +CONFIG_MACH_BUG +CONFIG_MACH_BUG20 +CONFIG_MACH_BURY_BL7582 +CONFIG_MACH_BURY_BPS5270 +CONFIG_MACH_BV07 +CONFIG_MACH_C2MMI +CONFIG_MACH_CALLISTO +CONFIG_MACH_CAM60 +CONFIG_MACH_CAPC7117 +CONFIG_MACH_CARDHU +CONFIG_MACH_CARMEVA +CONFIG_MACH_CAYENNE +CONFIG_MACH_CC9P9360DEV +CONFIG_MACH_CC9P9360JS +CONFIG_MACH_CCMX53 +CONFIG_MACH_CCMX53JS +CONFIG_MACH_CCWMX51MUT +CONFIG_MACH_CCWMX53 +CONFIG_MACH_CCWMX53JS +CONFIG_MACH_CENTRO +CONFIG_MACH_CETUS9263 +CONFIG_MACH_CHACHA +CONFIG_MACH_CHALTEN_XA1 +CONFIG_MACH_CHARON +CONFIG_MACH_CLOD +CONFIG_MACH_CM4745 +CONFIG_MACH_CM_A510 +CONFIG_MACH_CM_T35 +CONFIG_MACH_CM_T3517 +CONFIG_MACH_CM_T3730 +CONFIG_MACH_CM_X300 +CONFIG_MACH_CNS2133EVB +CONFIG_MACH_CNS21XX +CONFIG_MACH_CNS3420VB +CONFIG_MACH_COBRAL138 +CONFIG_MACH_COCONUT +CONFIG_MACH_COLIBRI +CONFIG_MACH_COLIBRI300 +CONFIG_MACH_COLIBRI320 +CONFIG_MACH_COLIBRI_T20 +CONFIG_MACH_COLIBRI_T30 +CONFIG_MACH_CONTROLTEK9G20 +CONFIG_MACH_CORETEC_VCX7400 +CONFIG_MACH_CORGI +CONFIG_MACH_CPUAT9G20 +CONFIG_MACH_CPX2 +CONFIG_MACH_CRANEBOARD +CONFIG_MACH_CRUX +CONFIG_MACH_CSB337 +CONFIG_MACH_CSB637 +CONFIG_MACH_CSB726 +CONFIG_MACH_CSC +CONFIG_MACH_CTBU_GEN2 +CONFIG_MACH_CTERA_PLUG_C2 +CONFIG_MACH_CURACAO +CONFIG_MACH_CV2201 +CONFIG_MACH_CV2202 +CONFIG_MACH_CV2203 +CONFIG_MACH_CWAM1808 +CONFIG_MACH_CWDM365 +CONFIG_MACH_CWME9210 +CONFIG_MACH_CWME9210JS +CONFIG_MACH_CWMX233 +CONFIG_MACH_D2NET +CONFIG_MACH_D2NET_V2 +CONFIG_MACH_D2PLUG +CONFIG_MACH_DA850_K5 +CONFIG_MACH_DAINTREE_CWAC +CONFIG_MACH_DATAWAY +CONFIG_MACH_DAVINCI_CALIMAIN +CONFIG_MACH_DAVINCI_DA830_EVM +CONFIG_MACH_DAVINCI_DA850_EVM +CONFIG_MACH_DAVINCI_DM355_EVM +CONFIG_MACH_DAVINCI_DM355_MMM +CONFIG_MACH_DAVINCI_DM365_BV +CONFIG_MACH_DAVINCI_DM365_DVR +CONFIG_MACH_DAVINCI_DM365_EVM +CONFIG_MACH_DAVINCI_DM6467TEVM +CONFIG_MACH_DAVINCI_DM6467_EVM +CONFIG_MACH_DAVINCI_EVM +CONFIG_MACH_DAVINCI_PICTO +CONFIG_MACH_DAWAD7 +CONFIG_MACH_DB78X00_BP +CONFIG_MACH_DB88F5281 +CONFIG_MACH_DB88F6281_BP +CONFIG_MACH_DDNAS +CONFIG_MACH_DDPLUG +CONFIG_MACH_DDS +CONFIG_MACH_DEEP_R_EK_1 +CONFIG_MACH_DEVIXP +CONFIG_MACH_DEVKIT8000 +CONFIG_MACH_DGM3240 +CONFIG_MACH_DIMMSAM9G20 +CONFIG_MACH_DIMM_IMX28 +CONFIG_MACH_DIMM_MX257 +CONFIG_MACH_DINGO +CONFIG_MACH_DIR665 +CONFIG_MACH_DM355_LEOPARD +CONFIG_MACH_DM365_CV100 +CONFIG_MACH_DM368_LEOPARD +CONFIG_MACH_DM3730_SOM_LV +CONFIG_MACH_DM3730_TORPEDO +CONFIG_MACH_DM6441_ESP +CONFIG_MACH_DM6446_ADBOX +CONFIG_MACH_DMA6410 +CONFIG_MACH_DMA_THUNDERBUG +CONFIG_MACH_DMW96 +CONFIG_MACH_DNS323 +CONFIG_MACH_DOCKSTAR +CONFIG_MACH_DOORBOY +CONFIG_MACH_DOUBLESHOT +CONFIG_MACH_DOVE_AVNG_V3 +CONFIG_MACH_DOVE_DB +CONFIG_MACH_DP6XX +CONFIG_MACH_DRAGONET +CONFIG_MACH_DSM320 +CONFIG_MACH_DSMG600 +CONFIG_MACH_DURIAN +CONFIG_MACH_DYNASTY +CONFIG_MACH_E10 +CONFIG_MACH_E330 +CONFIG_MACH_E350 +CONFIG_MACH_E400 +CONFIG_MACH_E740 +CONFIG_MACH_E750 +CONFIG_MACH_E800 +CONFIG_MACH_EA20 +CONFIG_MACH_EA2478DEVKIT +CONFIG_MACH_EAG_CI4000 +CONFIG_MACH_EASYCRRH +CONFIG_MACH_EC4350SDB +CONFIG_MACH_EC4350TBM +CONFIG_MACH_ECBAT91 +CONFIG_MACH_ECO920 +CONFIG_MACH_ECUV5 +CONFIG_MACH_EDB9301 +CONFIG_MACH_EDB9302 +CONFIG_MACH_EDB9302A +CONFIG_MACH_EDB9307 +CONFIG_MACH_EDB9307A +CONFIG_MACH_EDB9312 +CONFIG_MACH_EDB9315 +CONFIG_MACH_EDB9315A +CONFIG_MACH_EDISON +CONFIG_MACH_EDMINIV2 +CONFIG_MACH_EDMINI_V2 +CONFIG_MACH_EELX2 +CONFIG_MACH_EIGEN_TTR +CONFIG_MACH_ELEPHANT +CONFIG_MACH_ELKE +CONFIG_MACH_ELOG +CONFIG_MACH_EM1SY +CONFIG_MACH_EM7210 +CONFIG_MACH_EMERALD +CONFIG_MACH_EM_X270 +CONFIG_MACH_ENCORE +CONFIG_MACH_ENDIAN_MINI +CONFIG_MACH_EP80219 +CONFIG_MACH_EPC10 +CONFIG_MACH_EPIPHAN +CONFIG_MACH_ES2440 +CONFIG_MACH_ESATA_SHEEVAPLUG +CONFIG_MACH_ESL_MOBILIS_A +CONFIG_MACH_ESL_MOBILIS_B +CONFIG_MACH_ESL_WAVE_A +CONFIG_MACH_ESL_WAVE_B +CONFIG_MACH_ESPRESSO +CONFIG_MACH_ETHERPRO_ISP +CONFIG_MACH_ETNA +CONFIG_MACH_EUKREA_CPUIMX25SD +CONFIG_MACH_EUKREA_CPUIMX35SD +CONFIG_MACH_EUKREA_CPUIMX51 +CONFIG_MACH_EUKREA_CPUIMX51SD +CONFIG_MACH_EVA2000 +CONFIG_MACH_EVSY +CONFIG_MACH_EXEDA +CONFIG_MACH_EXPRESS +CONFIG_MACH_EXPRESSCT +CONFIG_MACH_EXPRESSH +CONFIG_MACH_EXPRESS_KT +CONFIG_MACH_EZX_A1200 +CONFIG_MACH_EZX_A780 +CONFIG_MACH_EZX_A910 +CONFIG_MACH_EZX_E2 +CONFIG_MACH_EZX_E6 +CONFIG_MACH_EZX_E680 +CONFIG_MACH_FA9X27 +CONFIG_MACH_FFCORE +CONFIG_MACH_FLEXIBITY +CONFIG_MACH_FLINT +CONFIG_MACH_FLYER +CONFIG_MACH_FRISMS +CONFIG_MACH_FRRHWCDMA60W +CONFIG_MACH_FSG +CONFIG_MACH_FSM9XXX_FFA +CONFIG_MACH_FSM9XXX_SURF +CONFIG_MACH_FS_S5PC100 +CONFIG_MACH_FUJI +CONFIG_MACH_FWBD_0404 +CONFIG_MACH_G3EVM +CONFIG_MACH_G4EVM +CONFIG_MACH_GATEWAY7001 +CONFIG_MACH_GENEVA_B5 +CONFIG_MACH_GESBC9312 +CONFIG_MACH_GFS_SPM +CONFIG_MACH_GINGER +CONFIG_MACH_GIRA_KNXIP_ROUTER +CONFIG_MACH_GLANTANK +CONFIG_MACH_GNET_SGCE +CONFIG_MACH_GNET_SGME +CONFIG_MACH_GNET_SLC +CONFIG_MACH_GOFLEXHOME +CONFIG_MACH_GOFLEXNET +CONFIG_MACH_GOLDENGATE +CONFIG_MACH_GONI +CONFIG_MACH_GORAMO_MLR +CONFIG_MACH_GPSDISPLAY +CONFIG_MACH_GREECO +CONFIG_MACH_GSIA18S +CONFIG_MACH_GSL_DIAMOND +CONFIG_MACH_GSNCOMM +CONFIG_MACH_GTA04 +CONFIG_MACH_GTIB +CONFIG_MACH_GTL_IT5100 +CONFIG_MACH_GTWX5715 +CONFIG_MACH_GT_I5700 +CONFIG_MACH_GUPPY +CONFIG_MACH_GURNARD +CONFIG_MACH_GURUPLUG +CONFIG_MACH_GW2361 +CONFIG_MACH_H1600 +CONFIG_MACH_H4700 +CONFIG_MACH_HABA_KNX_EXPLORER +CONFIG_MACH_HALIBUT +CONFIG_MACH_HAMMERHEAD +CONFIG_MACH_HARMONY +CONFIG_MACH_HARVEST_DESOTO +CONFIG_MACH_HAWKS +CONFIG_MACH_HDGU +CONFIG_MACH_HDMINI +CONFIG_MACH_HDNVP +CONFIG_MACH_HELIOS_V1 +CONFIG_MACH_HELIOS_V2 +CONFIG_MACH_HERALD +CONFIG_MACH_HERRING +CONFIG_MACH_HIMALAYA +CONFIG_MACH_HJSDU +CONFIG_MACH_HKDKC100 +CONFIG_MACH_HMT +CONFIG_MACH_HOLIDAY +CONFIG_MACH_HREFV60 +CONFIG_MACH_HSGX6D +CONFIG_MACH_HTCMEGA +CONFIG_MACH_HTCTORNADO +CONFIG_MACH_HTC_HD_MINI +CONFIG_MACH_HTC_SPV_M700 +CONFIG_MACH_HUASHAN +CONFIG_MACH_HUSKY +CONFIG_MACH_HWGW6410 +CONFIG_MACH_IAM28 +CONFIG_MACH_ICON +CONFIG_MACH_ICONG +CONFIG_MACH_ICONNECT +CONFIG_MACH_ICONTROL +CONFIG_MACH_ICON_G +CONFIG_MACH_ICS_IF_VOIP +CONFIG_MACH_IDEA6410 +CONFIG_MACH_IGEP0020 +CONFIG_MACH_IGEP0030 +CONFIG_MACH_IGEP0032 +CONFIG_MACH_IJ3K_2440 +CONFIG_MACH_IMATE8502 +CONFIG_MACH_IMX27IPCAM +CONFIG_MACH_IMX27LITE +CONFIG_MACH_IMX27_VISSTRIM_M10 +CONFIG_MACH_INCOME +CONFIG_MACH_INETSPACE_V2 +CONFIG_MACH_INHAND_APEIRON +CONFIG_MACH_INHAND_FURY +CONFIG_MACH_INHAND_SIREN +CONFIG_MACH_INTELMOTE2 +CONFIG_MACH_IOMEGA_IX2_200 +CONFIG_MACH_IQ80332 +CONFIG_MACH_IQ81340MC +CONFIG_MACH_IQ81340SC +CONFIG_MACH_ISC3 +CONFIG_MACH_IXDP2351 +CONFIG_MACH_IXDP28X5 +CONFIG_MACH_IXDP465 +CONFIG_MACH_IXDPG425 +CONFIG_MACH_JANUS +CONFIG_MACH_JIGEN +CONFIG_MACH_JIVE +CONFIG_MACH_JOCPU550 +CONFIG_MACH_KAEN +CONFIG_MACH_KAFA +CONFIG_MACH_KB9200 +CONFIG_MACH_KEV7A400 +CONFIG_MACH_KINGDOM +CONFIG_MACH_KIXRP435 +CONFIG_MACH_KMM2M01 +CONFIG_MACH_KMP_AM17_01 +CONFIG_MACH_KM_KIRKWOOD +CONFIG_MACH_KOI +CONFIG_MACH_KRONOS +CONFIG_MACH_KT_SBC_SAM9_1 +CONFIG_MACH_KUROBOX_PRO +CONFIG_MACH_KX33XX +CONFIG_MACH_KZM9D +CONFIG_MACH_KZM9G +CONFIG_MACH_KZM_ARM11_01 +CONFIG_MACH_LANREADYFN511 +CONFIG_MACH_LAUSANNE +CONFIG_MACH_LB88RC8480 +CONFIG_MACH_LEAD +CONFIG_MACH_LEGACY +CONFIG_MACH_LEMON +CONFIG_MACH_LIBRA +CONFIG_MACH_LIGHTNING +CONFIG_MACH_LILLY1131 +CONFIG_MACH_LINKSTATION_CHLV2 +CONFIG_MACH_LINKSTATION_LSCHL +CONFIG_MACH_LINKSTATION_LS_HGL +CONFIG_MACH_LINKSTATION_MINI +CONFIG_MACH_LINKSTATION_PRO +CONFIG_MACH_LITTLETON +CONFIG_MACH_LOFT +CONFIG_MACH_LOGICPD_PXA270 +CONFIG_MACH_LPC24XX +CONFIG_MACH_LPD7A400 +CONFIG_MACH_LPD7A404 +CONFIG_MACH_LQ2 +CONFIG_MACH_LS9G20 +CONFIG_MACH_LSWXL +CONFIG_MACH_M502 +CONFIG_MACH_MACH_SDH001 +CONFIG_MACH_MACKEREL +CONFIG_MACH_MAGICIAN +CONFIG_MACH_MAGX_ZN5 +CONFIG_MACH_MAHIMAHI +CONFIG_MACH_MAINSTONE +CONFIG_MACH_MANUAE +CONFIG_MACH_MAPLE1 +CONFIG_MACH_MARVEL +CONFIG_MACH_MARVELC +CONFIG_MACH_MARVELCT +CONFIG_MACH_MARVELL_JASPER +CONFIG_MACH_MATRIX505 +CONFIG_MACH_MATRIX518 +CONFIG_MACH_MAXIMASP +CONFIG_MACH_MB3 +CONFIG_MACH_MECHA +CONFIG_MACH_MENO_QNG +CONFIG_MACH_MESON +CONFIG_MACH_MESON_6236M +CONFIG_MACH_MESON_8626M +CONFIG_MACH_MESSINA +CONFIG_MACH_MIC256 +CONFIG_MACH_MICCPT +CONFIG_MACH_MICRO9 +CONFIG_MACH_MICRO9L +CONFIG_MACH_MICRO9M +CONFIG_MACH_MICRO9S +CONFIG_MACH_MIF10P +CONFIG_MACH_MIMAS +CONFIG_MACH_MINI210 +CONFIG_MACH_MINI2440 +CONFIG_MACH_MINI6410 +CONFIG_MACH_MINI8168 +CONFIG_MACH_MIOA502 +CONFIG_MACH_MIOA701 +CONFIG_MACH_MIONE +CONFIG_MACH_MIOS_V1 +CONFIG_MACH_MITYOMAPL138 +CONFIG_MACH_MMM +CONFIG_MACH_MONCH +CONFIG_MACH_MONE +CONFIG_MACH_MOON +CONFIG_MACH_MORA +CONFIG_MACH_MR301A +CONFIG_MACH_MSM7X25_FFA +CONFIG_MACH_MSM7X25_SURF +CONFIG_MACH_MSM7X27A_FFA +CONFIG_MACH_MSM7X27A_RUMI3 +CONFIG_MACH_MSM7X27A_SURF +CONFIG_MACH_MSM7X27_FFA +CONFIG_MACH_MSM7X27_SURF +CONFIG_MACH_MSM7X30_FFA +CONFIG_MACH_MSM7X30_FLUID +CONFIG_MACH_MSM7X30_SURF +CONFIG_MACH_MSM8960_APQ +CONFIG_MACH_MSM8960_CDP +CONFIG_MACH_MSM8960_FLUID +CONFIG_MACH_MSM8960_MDP +CONFIG_MACH_MSM8960_RUMI3 +CONFIG_MACH_MSM8960_SIM +CONFIG_MACH_MSM8X55_SVLTE_FFA +CONFIG_MACH_MSM8X55_SVLTE_SURF +CONFIG_MACH_MSM8X60_FFA +CONFIG_MACH_MSM8X60_FLUID +CONFIG_MACH_MSM8X60_QRDC +CONFIG_MACH_MSM8X60_QT +CONFIG_MACH_MSM8X60_RUMI3 +CONFIG_MACH_MSM8X60_SIM +CONFIG_MACH_MSM8X60_SURF +CONFIG_MACH_MSS2 +CONFIG_MACH_MULTHSU +CONFIG_MACH_MV2120 +CONFIG_MACH_MV88F6281GTW_GE +CONFIG_MACH_MVBLX +CONFIG_MACH_MX21ADS +CONFIG_MACH_MX23EVK +CONFIG_MACH_MX257SOL +CONFIG_MACH_MX257SX +CONFIG_MACH_MX25_3DS +CONFIG_MACH_MX25_E2S_UC +CONFIG_MACH_MX27ADS +CONFIG_MACH_MX27SU2 +CONFIG_MACH_MX27_3DS +CONFIG_MACH_MX27_WMULTRA +CONFIG_MACH_MX28EVK +CONFIG_MACH_MX31ADS +CONFIG_MACH_MX31LITE +CONFIG_MACH_MX31MOBOARD +CONFIG_MACH_MX31_3DS +CONFIG_MACH_MX35_3DS +CONFIG_MACH_MX50_ARM2 +CONFIG_MACH_MX50_RDP +CONFIG_MACH_MX51EREBUS +CONFIG_MACH_MX51_3DS +CONFIG_MACH_MX51_ASTER7 +CONFIG_MACH_MX51_BABBAGE +CONFIG_MACH_MX51_BRAVO +CONFIG_MACH_MX51_EFIKAMX +CONFIG_MACH_MX51_EFIKASB +CONFIG_MACH_MX51_GGC +CONFIG_MACH_MX51_MORAY +CONFIG_MACH_MX51_TULIP +CONFIG_MACH_MX53_ARD +CONFIG_MACH_MX53_EVK +CONFIG_MACH_MX53_LOCO +CONFIG_MACH_MX53_SMD +CONFIG_MACH_MX61_ARD +CONFIG_MACH_MXC25_TOPAZ +CONFIG_MACH_MXLADS +CONFIG_MACH_MXT_TD60 +CONFIG_MACH_MXT_TD61 +CONFIG_MACH_N2100 +CONFIG_MACH_N30 +CONFIG_MACH_N35 +CONFIG_MACH_NAJAY_A9263 +CONFIG_MACH_NANOS +CONFIG_MACH_NANOZOOM +CONFIG_MACH_NAS100D +CONFIG_MACH_NAS4220B +CONFIG_MACH_NAS6210 +CONFIG_MACH_NAVEFIHID +CONFIG_MACH_NAXY1200 +CONFIG_MACH_NAXY400 +CONFIG_MACH_NB31 +CONFIG_MACH_NCP +CONFIG_MACH_NDA_EVM +CONFIG_MACH_NEC_MP900 +CONFIG_MACH_NEO1973_GTA02 +CONFIG_MACH_NEOCORE926 +CONFIG_MACH_NERY_1000 +CONFIG_MACH_NET2BIG +CONFIG_MACH_NET2BIG_NAND_V2 +CONFIG_MACH_NET2BIG_V2 +CONFIG_MACH_NET5BIG_NAND_V2 +CONFIG_MACH_NET5BIG_V2 +CONFIG_MACH_NETSPACE_LITE_V2 +CONFIG_MACH_NETSPACE_MAX_V2 +CONFIG_MACH_NETSPACE_V2 +CONFIG_MACH_NETVIZ +CONFIG_MACH_NETWALKER +CONFIG_MACH_NEUROS_OSD2 +CONFIG_MACH_NEXCODER_2440 +CONFIG_MACH_NITROGEN_IMX51 +CONFIG_MACH_NITROGEN_IMX53 +CONFIG_MACH_NITROGEN_VM_IMX51 +CONFIG_MACH_NMH +CONFIG_MACH_NOKIA770 +CONFIG_MACH_NOKIA_N800 +CONFIG_MACH_NOKIA_N810 +CONFIG_MACH_NOKIA_N810_WIMAX +CONFIG_MACH_NOKIA_RM680 +CONFIG_MACH_NOKIA_RX51 +CONFIG_MACH_NOMADIK +CONFIG_MACH_NOTLE +CONFIG_MACH_NS2416 +CONFIG_MACH_NS2816TB +CONFIG_MACH_NS2816_NTNB +CONFIG_MACH_NS2816_NTPAD +CONFIG_MACH_NSB3AST +CONFIG_MACH_NSK330 +CONFIG_MACH_NSLU2 +CONFIG_MACH_NSSLSBOARD +CONFIG_MACH_NS_K330 +CONFIG_MACH_NUC700EVB +CONFIG_MACH_NUC710EVB +CONFIG_MACH_NUC740EVB +CONFIG_MACH_NUC745EVB +CONFIG_MACH_NUC932EVB +CONFIG_MACH_NUC950TS +CONFIG_MACH_NURI +CONFIG_MACH_NV1000 +CONFIG_MACH_NXDB500 +CONFIG_MACH_NXDKN +CONFIG_MACH_NXEB500HMI +CONFIG_MACH_OCE_NIGMA +CONFIG_MACH_OMAP2EVM +CONFIG_MACH_OMAP3505NOVA8 +CONFIG_MACH_OMAP3517EVM +CONFIG_MACH_OMAP3530_LV_SOM +CONFIG_MACH_OMAP3621_EDP1 +CONFIG_MACH_OMAP3EVM +CONFIG_MACH_OMAP3SMARTDISPLAY +CONFIG_MACH_OMAP3_BAIA +CONFIG_MACH_OMAP3_BC10 +CONFIG_MACH_OMAP3_BEAGLE +CONFIG_MACH_OMAP3_BRAILLO +CONFIG_MACH_OMAP3_IBIZA +CONFIG_MACH_OMAP3_PANDORA +CONFIG_MACH_OMAP3_RFS200 +CONFIG_MACH_OMAP3_TDM3730 +CONFIG_MACH_OMAP3_TORPEDO +CONFIG_MACH_OMAP3_WALDO1 +CONFIG_MACH_OMAP4_PANDA +CONFIG_MACH_OMAP5_SEVM +CONFIG_MACH_OMAPL138_CASE_A3 +CONFIG_MACH_OMAPL138_EUROPALC +CONFIG_MACH_OMAPL138_HAWKBOARD +CONFIG_MACH_OMAPL138_LCDK +CONFIG_MACH_OMAP_2430SDP +CONFIG_MACH_OMAP_3430SDP +CONFIG_MACH_OMAP_3630SDP +CONFIG_MACH_OMAP_4430SDP +CONFIG_MACH_OMAP_APOLLON +CONFIG_MACH_OMAP_BENDER +CONFIG_MACH_OMAP_FSAMPLE +CONFIG_MACH_OMAP_GENERIC +CONFIG_MACH_OMAP_H2 +CONFIG_MACH_OMAP_H3 +CONFIG_MACH_OMAP_H4 +CONFIG_MACH_OMAP_INNOVATOR +CONFIG_MACH_OMAP_LDP +CONFIG_MACH_OMAP_MCOP +CONFIG_MACH_OMAP_OSK +CONFIG_MACH_OMAP_PALMTE +CONFIG_MACH_OMAP_PALMTT +CONFIG_MACH_OMAP_PALMZ71 +CONFIG_MACH_OMAP_PERSEUS2 +CONFIG_MACH_OMAP_ZOOM2 +CONFIG_MACH_OMAP_ZOOM3 +CONFIG_MACH_OMN_AT91SAM9G20 +CONFIG_MACH_ONEARM +CONFIG_MACH_OPENRD_BASE +CONFIG_MACH_OPENRD_CLIENT +CONFIG_MACH_OPENRD_ULTIMATE +CONFIG_MACH_ORATISAES +CONFIG_MACH_ORATISLINK +CONFIG_MACH_ORIGEN +CONFIG_MACH_OSIRIS +CONFIG_MACH_OSLO_AMUNDSEN +CONFIG_MACH_OTOM +CONFIG_MACH_OVERO +CONFIG_MACH_OVERO_CTU_INERTIAL +CONFIG_MACH_P87_SMARTSIM +CONFIG_MACH_PALMLD +CONFIG_MACH_PALMT5 +CONFIG_MACH_PALMTC +CONFIG_MACH_PALMTE2 +CONFIG_MACH_PALMTX +CONFIG_MACH_PALMZ72 +CONFIG_MACH_PAZ00 +CONFIG_MACH_PC7302 +CONFIG_MACH_PC7308 +CONFIG_MACH_PC9260_V2 +CONFIG_MACH_PCA100 +CONFIG_MACH_PCA102 +CONFIG_MACH_PCATS_OVERLAY +CONFIG_MACH_PCM027 +CONFIG_MACH_PCM037 +CONFIG_MACH_PCM038 +CONFIG_MACH_PCM043 +CONFIG_MACH_PCM048 +CONFIG_MACH_PCM049 +CONFIG_MACH_PCONTROL_G20 +CONFIG_MACH_PEC_HC2 +CONFIG_MACH_PEC_TC +CONFIG_MACH_PEMP_OMAP3_APOLLO +CONFIG_MACH_PGS_SITARA +CONFIG_MACH_PHILHWANI +CONFIG_MACH_PHY3250 +CONFIG_MACH_PICASSO +CONFIG_MACH_PICO +CONFIG_MACH_PICOCOM3 +CONFIG_MACH_PICOCOM4 +CONFIG_MACH_PICOTUX2XX +CONFIG_MACH_PIVICC +CONFIG_MACH_PNX4008 +CONFIG_MACH_POLYSAT1 +CONFIG_MACH_POODLE +CONFIG_MACH_PORTUXG20 +CONFIG_MACH_POV15HD +CONFIG_MACH_PREMIERWAVE_EN +CONFIG_MACH_PRIMA2_EVB +CONFIG_MACH_PTX7510 +CONFIG_MACH_PTX7545 +CONFIG_MACH_PUNICA +CONFIG_MACH_PUPITRE +CONFIG_MACH_PVM2030 +CONFIG_MACH_PWB3090 +CONFIG_MACH_PXWNAS_500_1000 +CONFIG_MACH_PYRAMID +CONFIG_MACH_QBC9263 +CONFIG_MACH_QIL_A9260 +CONFIG_MACH_QONG +CONFIG_MACH_QSD8X50A_ST1_5 +CONFIG_MACH_QSD8X50_SURF +CONFIG_MACH_QSD8X72_FFA +CONFIG_MACH_QSD8X72_SURF +CONFIG_MACH_QT2410 +CONFIG_MACH_QUAD_SALSA +CONFIG_MACH_QUICKSTEP +CONFIG_MACH_R1801E +CONFIG_MACH_RASCAL +CONFIG_MACH_RAUMFELD_CONNECTOR +CONFIG_MACH_RAUMFELD_RC +CONFIG_MACH_RAUMFELD_SPEAKER +CONFIG_MACH_RD78X00_MASA +CONFIG_MACH_RD88F5181L_FXO +CONFIG_MACH_RD88F5181L_GE +CONFIG_MACH_RD88F5182 +CONFIG_MACH_RD88F6183AP_GE +CONFIG_MACH_RD88F6192_NAS +CONFIG_MACH_RD88F6281 +CONFIG_MACH_RDSTOR +CONFIG_MACH_RE2REV20 +CONFIG_MACH_RE2REV21 +CONFIG_MACH_REAL6410 +CONFIG_MACH_REALVIEW_EB +CONFIG_MACH_REALVIEW_PB1176 +CONFIG_MACH_REALVIEW_PB11MP +CONFIG_MACH_REALVIEW_PBA8 +CONFIG_MACH_REALVIEW_PBX +CONFIG_MACH_REMUS +CONFIG_MACH_REXMAS +CONFIG_MACH_RFL109145_SSRV +CONFIG_MACH_RHINO +CONFIG_MACH_RIB +CONFIG_MACH_RIDER +CONFIG_MACH_RIOT_BEI2 +CONFIG_MACH_RIOT_X37 +CONFIG_MACH_ROADRUNNER +CONFIG_MACH_ROCKHOPPER +CONFIG_MACH_ROVERPCS8 +CONFIG_MACH_ROVERX7 +CONFIG_MACH_ROVER_G8 +CONFIG_MACH_RPC353 +CONFIG_MACH_RUBY +CONFIG_MACH_RUBYS +CONFIG_MACH_RUMP +CONFIG_MACH_RUT100 +CONFIG_MACH_RV082 +CONFIG_MACH_RX1950 +CONFIG_MACH_RX3715 +CONFIG_MACH_S3C2413 +CONFIG_MACH_S5500 +CONFIG_MACH_S5PC110_CRESPO +CONFIG_MACH_SAAR +CONFIG_MACH_SAARB +CONFIG_MACH_SAARB_MG1 +CONFIG_MACH_SAGA +CONFIG_MACH_SALUDA +CONFIG_MACH_SAM9REPEATER +CONFIG_MACH_SAM9_L9260 +CONFIG_MACH_SANTIAGO +CONFIG_MACH_SAPPHIRE +CONFIG_MACH_SBC3530 +CONFIG_MACH_SBC6000X +CONFIG_MACH_SBCA11 +CONFIG_MACH_SC575IPC +CONFIG_MACH_SC575PLC +CONFIG_MACH_SCB9328 +CONFIG_MACH_SCIPHONE_G2 +CONFIG_MACH_SDI_ESS_9263 +CONFIG_MACH_SDVR +CONFIG_MACH_SEABOARD +CONFIG_MACH_SERRANO +CONFIG_MACH_SFFSDR +CONFIG_MACH_SGH_I740 +CONFIG_MACH_SHARESPACE +CONFIG_MACH_SHEEVAPLUG +CONFIG_MACH_SHENZHOU +CONFIG_MACH_SHEPHERD +CONFIG_MACH_SHOOTER +CONFIG_MACH_SHOOTER_CT +CONFIG_MACH_SHOOTER_U +CONFIG_MACH_SHORTLOIN +CONFIG_MACH_SIEMENS_L0 +CONFIG_MACH_SIMPLENET +CONFIG_MACH_SIMTEC_KIRKMOD +CONFIG_MACH_SIM_ONE +CONFIG_MACH_SKY25 +CONFIG_MACH_SKY6410 +CONFIG_MACH_SM1K +CONFIG_MACH_SMARTQ5 +CONFIG_MACH_SMARTQ7 +CONFIG_MACH_SMARTQV3 +CONFIG_MACH_SMARTQV5 +CONFIG_MACH_SMARTQV7 +CONFIG_MACH_SMDK2412 +CONFIG_MACH_SMDK2413 +CONFIG_MACH_SMDK2416 +CONFIG_MACH_SMDK2443 +CONFIG_MACH_SMDK6410 +CONFIG_MACH_SMDK6440 +CONFIG_MACH_SMDK6442 +CONFIG_MACH_SMDK6450 +CONFIG_MACH_SMDKC100 +CONFIG_MACH_SMDKC110 +CONFIG_MACH_SMDKC210 +CONFIG_MACH_SMDKV210 +CONFIG_MACH_SMDKV310 +CONFIG_MACH_SNAPPER_9260 +CONFIG_MACH_SNAPPER_CL15 +CONFIG_MACH_SOFTWINNER +CONFIG_MACH_SOLI_01 +CONFIG_MACH_SPADE +CONFIG_MACH_SPADE_LTE +CONFIG_MACH_SPDM +CONFIG_MACH_SPEAR1310 +CONFIG_MACH_SPEAR1340 +CONFIG_MACH_SPEAR300 +CONFIG_MACH_SPEAR310 +CONFIG_MACH_SPEAR320 +CONFIG_MACH_SPEAR600 +CONFIG_MACH_SPEAR900 +CONFIG_MACH_SPECIFIC +CONFIG_MACH_SPICA +CONFIG_MACH_SPITZ +CONFIG_MACH_SPLENDOR +CONFIG_MACH_SPX_SAKURA +CONFIG_MACH_SPYPLUG +CONFIG_MACH_SSC +CONFIG_MACH_STAMP9G20 +CONFIG_MACH_STAMP9G45 +CONFIG_MACH_STARGATE2 +CONFIG_MACH_STEELYARD +CONFIG_MACH_STELLA +CONFIG_MACH_STMP378X +CONFIG_MACH_STMP37XX +CONFIG_MACH_STRASBOURG +CONFIG_MACH_STRASBOURG_A2 +CONFIG_MACH_STRETCHS7000 +CONFIG_MACH_SUN4I +CONFIG_MACH_SUN50I +CONFIG_MACH_SUN5I +CONFIG_MACH_SUN6I +CONFIG_MACH_SUN7I +CONFIG_MACH_SUN8I +CONFIG_MACH_SUN8I_A23 +CONFIG_MACH_SUN8I_A33 +CONFIG_MACH_SUN8I_A83T +CONFIG_MACH_SUN8I_H3 +CONFIG_MACH_SUN9I +CONFIG_MACH_SUNFIRE +CONFIG_MACH_SUNFLOWER +CONFIG_MACH_SVCID +CONFIG_MACH_SVP5500 +CONFIG_MACH_SVP8500V1 +CONFIG_MACH_SVP8500V2 +CONFIG_MACH_SWARCOEXTMODEM +CONFIG_MACH_SWEDA_TMS2 +CONFIG_MACH_SX1 +CONFIG_MACH_SYNERGY +CONFIG_MACH_SYNOLOGY_6282 +CONFIG_MACH_T20 +CONFIG_MACH_T5325 +CONFIG_MACH_T5388P +CONFIG_MACH_T55 +CONFIG_MACH_TAG +CONFIG_MACH_TAGW +CONFIG_MACH_TANNA +CONFIG_MACH_TAVOREVB +CONFIG_MACH_TAVOREVB3 +CONFIG_MACH_TCC8000_SDK +CONFIG_MACH_TCT_HAMMER +CONFIG_MACH_TD3_REV1 +CONFIG_MACH_TEENOTE +CONFIG_MACH_TEGRA_DAYTONA +CONFIG_MACH_TEGRA_E1165 +CONFIG_MACH_TEGRA_SWORDFISH +CONFIG_MACH_TEGRA_VOGUE +CONFIG_MACH_TEM3X30 +CONFIG_MACH_TENDERLOIN +CONFIG_MACH_TERASTATION_PRO2 +CONFIG_MACH_TERASTATION_WXL +CONFIG_MACH_TERA_PRO2_RACK +CONFIG_MACH_TETON_BGA +CONFIG_MACH_THALES_ADC +CONFIG_MACH_THALES_CBC +CONFIG_MACH_THEBE +CONFIG_MACH_TI8148EVM +CONFIG_MACH_TI8168EVM +CONFIG_MACH_TIMU +CONFIG_MACH_TIN307 +CONFIG_MACH_TIN510 +CONFIG_MACH_TINY_GURNARD +CONFIG_MACH_TITAN +CONFIG_MACH_TJINC1000 +CONFIG_MACH_TM_EFDC +CONFIG_MACH_TN200 +CONFIG_MACH_TNETV107X +CONFIG_MACH_TNY_T3530 +CONFIG_MACH_TONGA2_TFTTIMER +CONFIG_MACH_TOP9000 +CONFIG_MACH_TOP9000_BSL +CONFIG_MACH_TOP9000_EVAL +CONFIG_MACH_TOP9000_SU +CONFIG_MACH_TOP9000_TCU +CONFIG_MACH_TORBRECK +CONFIG_MACH_TORNADO3240 +CONFIG_MACH_TOSA +CONFIG_MACH_TOUCHBOOK +CONFIG_MACH_TPT_2_0 +CONFIG_MACH_TQ6410 +CONFIG_MACH_TQMA35 +CONFIG_MACH_TQMA9263 +CONFIG_MACH_TRANSCEDE +CONFIG_MACH_TREO680 +CONFIG_MACH_TRICORDER +CONFIG_MACH_TRIDENT +CONFIG_MACH_TRIMSLICE +CONFIG_MACH_TRIPEL +CONFIG_MACH_TRITIP +CONFIG_MACH_TRIZEPS4 +CONFIG_MACH_TRIZEPS4WL +CONFIG_MACH_TROUT +CONFIG_MACH_TS209 +CONFIG_MACH_TS219 +CONFIG_MACH_TS3 +CONFIG_MACH_TS409 +CONFIG_MACH_TS41X +CONFIG_MACH_TS42XX +CONFIG_MACH_TS47XX +CONFIG_MACH_TS4800 +CONFIG_MACH_TS48XX +CONFIG_MACH_TS72XX +CONFIG_MACH_TS75XX +CONFIG_MACH_TS78XX +CONFIG_MACH_TSOPLOADER +CONFIG_MACH_TSUNAGI +CONFIG_MACH_TTC_DKB +CONFIG_MACH_TUBE +CONFIG_MACH_TULIP +CONFIG_MACH_TUNA +CONFIG_MACH_TUXRAIL +CONFIG_MACH_TX28 +CONFIG_MACH_TX53 +CONFIG_MACH_TYPE +CONFIG_MACH_TYPE_COMPAT_REV +CONFIG_MACH_U300 +CONFIG_MACH_U5500 +CONFIG_MACH_UBISYS_P9D_EVP +CONFIG_MACH_UEMD +CONFIG_MACH_UNINO1 +CONFIG_MACH_UNISDEV +CONFIG_MACH_UNISENSE_MMM +CONFIG_MACH_UNIT2S +CONFIG_MACH_UNIVERSAL_C210 +CONFIG_MACH_USB_A9260 +CONFIG_MACH_USB_A9263 +CONFIG_MACH_USDLOADER +CONFIG_MACH_UTM300 +CONFIG_MACH_VALDEZ +CONFIG_MACH_VANGOGH +CONFIG_MACH_VC0718 +CONFIG_MACH_VENTANA +CONFIG_MACH_VERDI +CONFIG_MACH_VERDI_LTE +CONFIG_MACH_VERIDIS_A300 +CONFIG_MACH_VERSATILE_AB +CONFIG_MACH_VEXPRESS +CONFIG_MACH_VIGOR +CONFIG_MACH_VIPRINET +CONFIG_MACH_VIT_IBOX +CONFIG_MACH_VIVO +CONFIG_MACH_VIVOW_CT +CONFIG_MACH_VMX25 +CONFIG_MACH_VMX51 +CONFIG_MACH_VMX53 +CONFIG_MACH_VOICEBLUE +CONFIG_MACH_VPAC270 +CONFIG_MACH_VPR200 +CONFIG_MACH_VR1000 +CONFIG_MACH_VSTMS +CONFIG_MACH_VVBOX_SDLITE2 +CONFIG_MACH_VVBOX_SDORIG2 +CONFIG_MACH_VVBOX_SDPRO4 +CONFIG_MACH_W21 +CONFIG_MACH_W90N960EVB +CONFIG_MACH_W90P910EVB +CONFIG_MACH_W90P950EVB +CONFIG_MACH_WARIO +CONFIG_MACH_WASABI +CONFIG_MACH_WATSON_EFM_PLUGIN +CONFIG_MACH_WB40N +CONFIG_MACH_WBD111 +CONFIG_MACH_WBD222 +CONFIG_MACH_WG302V2 +CONFIG_MACH_WHISTLER +CONFIG_MACH_WLAN_COMPUTER +CONFIG_MACH_WLF_CRAGG_6410 +CONFIG_MACH_WM8505_7IN_NETBOOK +CONFIG_MACH_WM8650REFBOARD +CONFIG_MACH_WN802T +CONFIG_MACH_WNR854T +CONFIG_MACH_WRT350N_V2 +CONFIG_MACH_WTPLUG +CONFIG_MACH_XARINA +CONFIG_MACH_XCEP +CONFIG_MACH_XILINX +CONFIG_MACH_XILINX_EP107 +CONFIG_MACH_XSBASE255 +CONFIG_MACH_YANOMAMI +CONFIG_MACH_YL9200 +CONFIG_MACH_Z3_814X_MOD +CONFIG_MACH_Z3_816X_MOD +CONFIG_MACH_ZIPIT2 +CONFIG_MACH_ZMX25 +CONFIG_MACH_ZYLONITE +CONFIG_MACH_ZYLONITE2 +CONFIG_MACPWR +CONFIG_MACRESET_TIMEOUT +CONFIG_MAC_ADDR_IN_SPIFLASH +CONFIG_MAC_OFFSET +CONFIG_MAC_PARTITION +CONFIG_MAKALU +CONFIG_MALLOC_F_ADDR +CONFIG_MALTA +CONFIG_MARCO_MEMSET +CONFIG_MARUBUN_PCCARD +CONFIG_MARVELL +CONFIG_MARVELL_GPIO +CONFIG_MARVELL_MFP +CONFIG_MASK_AER_AO +CONFIG_MAX_CPUS +CONFIG_MAX_DSP_CPUS +CONFIG_MAX_FPGA_DEVICES +CONFIG_MAX_I2C_NUM +CONFIG_MAX_MEM_MAPPED +CONFIG_MAX_PIRQ_LINKS +CONFIG_MAX_PKT +CONFIG_MAX_RAM_BANK_SIZE +CONFIG_MBA6 +CONFIG_MC13783_SPI_BUS +CONFIG_MC13783_SPI_CS +CONFIG_MCAST_TFTP +CONFIG_MCF52 +CONFIG_MCF5249 +CONFIG_MCF5253 +CONFIG_MCF5301 +CONFIG_MCF532 +CONFIG_MCF5441 +CONFIG_MCF5445 +CONFIG_MCF547 +CONFIG_MCFFEC +CONFIG_MCFPIT +CONFIG_MCFRTC +CONFIG_MCFTMR +CONFIG_MCFUART +CONFIG_MCLK_DIS +CONFIG_MD5 +CONFIG_MD5SUM_VERIFY +CONFIG_MDIO_TIMEOUT +CONFIG_MECP5123 +CONFIG_MEMSIZE +CONFIG_MEMSIZE_IN_BYTES +CONFIG_MEMSIZE_MASK +CONFIG_MEM_ADD_WDTH +CONFIG_MEM_HOLE_16M +CONFIG_MEM_INIT_VALUE +CONFIG_MEM_REMAP +CONFIG_MEM_SIZE +CONFIG_MENU +CONFIG_MENUKEY +CONFIG_MENUPROMPT +CONFIG_MENU_SHOW +CONFIG_MFG_ENV_SETTINGS +CONFIG_MGCOGE3NE +CONFIG_MIGO_R +CONFIG_MII +CONFIG_MIIM_ADDRESS +CONFIG_MII_DEFAULT_TSEC +CONFIG_MII_INIT +CONFIG_MII_SUPPRESS_PREAMBLE +CONFIG_MIP405 +CONFIG_MIPS +CONFIG_MIPS_BOOT_ENV_LEGACY +CONFIG_MIPS_HUGE_TLB_SUPPORT +CONFIG_MIPS_L1_CACHE_SHIFT +CONFIG_MIPS_MT_FPAFF +CONFIG_MIRQ_EN +CONFIG_MISC_COMMON +CONFIG_MISC_INIT_F +CONFIG_MISC_INIT_R +CONFIG_MIU_1BIT_INTERLEAVED +CONFIG_MIU_2BIT_21_7_INTERLEAVED +CONFIG_MIU_2BIT_INTERLEAVED +CONFIG_MIU_LINEAR +CONFIG_MK_ +CONFIG_MMC +CONFIG_MMCBOOTCOMMAND +CONFIG_MMCROOT +CONFIG_MMC_DEFAULT_DEV +CONFIG_MMC_RPMB_TRACE +CONFIG_MMC_SDHCI_IO_ACCESSORS +CONFIG_MMC_SDMA +CONFIG_MMC_SPI +CONFIG_MMC_SPI_BUS +CONFIG_MMC_SPI_CRC_ON +CONFIG_MMC_SPI_CS +CONFIG_MMC_SPI_CS_EPGIO +CONFIG_MMC_SPI_MODE +CONFIG_MMC_SPI_NPOWER_EGPIO +CONFIG_MMC_SPI_POWER_EGPIO +CONFIG_MMC_SPI_SPEED +CONFIG_MMC_SUNXI +CONFIG_MMC_SUNXI_SLOT +CONFIG_MMC_SUNXI_SLOT_EXTRA +CONFIG_MMC_TRACE +CONFIG_MMC_UNIPHIER +CONFIG_MMU +CONFIG_MODVERSIONS +CONFIG_MONITOR_IS_IN_RAM +CONFIG_MOTIONPRO +CONFIG_MP +CONFIG_MPC5 +CONFIG_MPC512 +CONFIG_MPC5121ADS +CONFIG_MPC5121ADS_REV2 +CONFIG_MPC512X +CONFIG_MPC5200 +CONFIG_MPC5200_DDR +CONFIG_MPC52XX_SPI +CONFIG_MPC555 +CONFIG_MPC8 +CONFIG_MPC823 +CONFIG_MPC8247 +CONFIG_MPC8255 +CONFIG_MPC8260 +CONFIG_MPC8272_FAMILY +CONFIG_MPC83 +CONFIG_MPC830 +CONFIG_MPC8308 +CONFIG_MPC8308RDB +CONFIG_MPC8308_P1M +CONFIG_MPC8309 +CONFIG_MPC831 +CONFIG_MPC8313 +CONFIG_MPC8313ERDB +CONFIG_MPC8315 +CONFIG_MPC8315ERDB +CONFIG_MPC832 +CONFIG_MPC832XEMDS +CONFIG_MPC834 +CONFIG_MPC8349 +CONFIG_MPC8349ADS +CONFIG_MPC8349EMDS +CONFIG_MPC8349ITX +CONFIG_MPC8349ITXGP +CONFIG_MPC8360 +CONFIG_MPC837 +CONFIG_MPC837XEMDS +CONFIG_MPC837XERDB +CONFIG_MPC83XX_GPIO +CONFIG_MPC83XX_GPIO_0_INIT_DIRECTION +CONFIG_MPC83XX_GPIO_0_INIT_OPEN_DRAIN +CONFIG_MPC83XX_GPIO_0_INIT_VALUE +CONFIG_MPC83XX_GPIO_1_INIT_DIRECTION +CONFIG_MPC83XX_GPIO_1_INIT_OPEN_DRAIN +CONFIG_MPC83XX_GPIO_1_INIT_VALUE +CONFIG_MPC83XX_PCI2 +CONFIG_MPC85 +CONFIG_MPC850 +CONFIG_MPC8536 +CONFIG_MPC8536DS +CONFIG_MPC8540 +CONFIG_MPC8540ADS +CONFIG_MPC8541 +CONFIG_MPC8541CDS +CONFIG_MPC8544 +CONFIG_MPC8544DS +CONFIG_MPC8548 +CONFIG_MPC8548CDS +CONFIG_MPC855 +CONFIG_MPC8555 +CONFIG_MPC8555CDS +CONFIG_MPC8560 +CONFIG_MPC8560ADS +CONFIG_MPC8568 +CONFIG_MPC8568MDS +CONFIG_MPC8569 +CONFIG_MPC8569MDS +CONFIG_MPC857 +CONFIG_MPC8572 +CONFIG_MPC8572DS +CONFIG_MPC85XX +CONFIG_MPC85XX_FEC +CONFIG_MPC85XX_FEC_NAME +CONFIG_MPC85XX_GPIO +CONFIG_MPC85XX_PCI2 +CONFIG_MPC86 +CONFIG_MPC860 +CONFIG_MPC860T +CONFIG_MPC8610 +CONFIG_MPC8610HPCD +CONFIG_MPC862 +CONFIG_MPC8641 +CONFIG_MPC8641HPCN +CONFIG_MPC866 +CONFIG_MPC866_FAMILY +CONFIG_MPC885 +CONFIG_MPC885_FAMILY +CONFIG_MPC8XXX_SPI +CONFIG_MPC8XX_LCD +CONFIG_MPLL_FREQ +CONFIG_MPR2 +CONFIG_MPX5200 +CONFIG_MP_CLK_FREQ +CONFIG_MS7720SE +CONFIG_MS7722SE +CONFIG_MS7750SE +CONFIG_MSHC_FREQ +CONFIG_MTD +CONFIG_MTDMAP +CONFIG_MTDPARTS +CONFIG_MTD_CONCAT +CONFIG_MTD_DEBUG +CONFIG_MTD_DEBUG_VERBOSE +CONFIG_MTD_DEVICE +CONFIG_MTD_ECC_SOFT +CONFIG_MTD_NAND_DENALI_SCRATCH_REG_ADDR +CONFIG_MTD_NAND_ECC_SMC +CONFIG_MTD_NAND_MUSEUM_IDS +CONFIG_MTD_NAND_VERIFY_WRITE +CONFIG_MTD_ONENAND_VERIFY_WRITE +CONFIG_MTD_PARTITION +CONFIG_MTD_PARTITIONS +CONFIG_MTD_REDBOOT_DIRECTORY_BLOCK +CONFIG_MTD_REDBOOT_PARTS +CONFIG_MTD_UBI_BEB_LIMIT +CONFIG_MTD_UBI_BEB_RESERVE +CONFIG_MTD_UBI_BLOCK +CONFIG_MTD_UBI_DEBUG +CONFIG_MTD_UBI_DEBUG_MSG +CONFIG_MTD_UBI_DEBUG_MSG_BLD +CONFIG_MTD_UBI_DEBUG_MSG_EBA +CONFIG_MTD_UBI_DEBUG_MSG_IO +CONFIG_MTD_UBI_DEBUG_MSG_WL +CONFIG_MTD_UBI_DEBUG_PARANOID +CONFIG_MTD_UBI_FASTMAP +CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT +CONFIG_MTD_UBI_FM_DEBUG +CONFIG_MTD_UBI_GLUEBI +CONFIG_MTD_UBI_MODULE +CONFIG_MTD_UBI_WL_THRESHOLD +CONFIG_MULTI_CS +CONFIG_MUNICES +CONFIG_MUSB_HOST +CONFIG_MV88E61XX_CPU_PORT +CONFIG_MV88E61XX_PHY_PORTS +CONFIG_MV88E61XX_SWITCH +CONFIG_MV88E6352_SWITCH +CONFIG_MVEBU_MMC +CONFIG_MVGBE +CONFIG_MVGBE_PORTS +CONFIG_MVMFP_V2 +CONFIG_MVNETA +CONFIG_MVS +CONFIG_MVSATA_IDE +CONFIG_MVSATA_IDE_USE_PORT0 +CONFIG_MVSATA_IDE_USE_PORT1 +CONFIG_MV_ETH_RXQ +CONFIG_MV_I2C_NUM +CONFIG_MV_I2C_REG +CONFIG_MV_SDHCI +CONFIG_MX23 +CONFIG_MX25 +CONFIG_MX25_CLK32 +CONFIG_MX25_HCLK_FREQ +CONFIG_MX27 +CONFIG_MX27_CLK32 +CONFIG_MX27_TIMER_HIGH_PRECISION +CONFIG_MX28 +CONFIG_MX28_FEC_MAC_IN_OCOTP +CONFIG_MX31 +CONFIG_MX31_CLK32 +CONFIG_MX31_HCLK_FREQ +CONFIG_MX31_TIMER_HIGH_PRECISION +CONFIG_MX35 +CONFIG_MX35_CLK32 +CONFIG_MX35_HCLK_FREQ +CONFIG_MX51 +CONFIG_MX51_PLL_ERRATA +CONFIG_MX53 +CONFIG_MX6 +CONFIG_MX6DL +CONFIG_MX6DL_LPDDR2 +CONFIG_MX6DQ_LPDDR2 +CONFIG_MX6Q +CONFIG_MX6QDL +CONFIG_MX6S +CONFIG_MX6SL +CONFIG_MX6SX +CONFIG_MX6SX_SABRESD_REVA +CONFIG_MX6UL +CONFIG_MX6UL_14X14_EVK_EMMC_REWORK +CONFIG_MX7 +CONFIG_MX7D +CONFIG_MXC_EPDC +CONFIG_MXC_GPIO +CONFIG_MXC_GPT_HCLK +CONFIG_MXC_MCI_REGS_BASE +CONFIG_MXC_MMC +CONFIG_MXC_NAND_HWECC +CONFIG_MXC_NAND_IP_REGS_BASE +CONFIG_MXC_NAND_REGS_BASE +CONFIG_MXC_OCOTP +CONFIG_MXC_SPI +CONFIG_MXC_UART +CONFIG_MXC_UART_BASE +CONFIG_MXC_USB_FLAGS +CONFIG_MXC_USB_OTG_HACTIVE +CONFIG_MXC_USB_PORT +CONFIG_MXC_USB_PORTSC +CONFIG_MXS +CONFIG_MXS_GPIO +CONFIG_MXS_MMC +CONFIG_MXS_OCOTP +CONFIG_MXS_SPI +CONFIG_MX_CYCLIC +CONFIG_MY_OPTION +CONFIG_NAND +CONFIG_NANDFLASH_SIZE +CONFIG_NAND_ +CONFIG_NAND_6BYTES_OOB_FREE_10BYTES_ECC +CONFIG_NAND_ACTL +CONFIG_NAND_ARASAN +CONFIG_NAND_ATMEL +CONFIG_NAND_BOOT +CONFIG_NAND_CS_INIT +CONFIG_NAND_DATA_REG +CONFIG_NAND_DAVINCI +CONFIG_NAND_DENALI +CONFIG_NAND_DENALI_ECC_SIZE +CONFIG_NAND_ECC_BCH +CONFIG_NAND_ENV_DST +CONFIG_NAND_FSL_ELBC +CONFIG_NAND_FSL_IFC +CONFIG_NAND_FSL_NFC +CONFIG_NAND_FSMC +CONFIG_NAND_KIRKWOOD +CONFIG_NAND_KMETER1 +CONFIG_NAND_LPC32XX_MLC +CONFIG_NAND_LPC32XX_SLC +CONFIG_NAND_MODE_REG +CONFIG_NAND_MPC5121_NFC +CONFIG_NAND_MXC +CONFIG_NAND_MXC_V1_1 +CONFIG_NAND_MXS +CONFIG_NAND_NDFC +CONFIG_NAND_OMAP_ECCSCHEME +CONFIG_NAND_OMAP_ELM +CONFIG_NAND_OMAP_GPMC +CONFIG_NAND_OMAP_GPMC_PREFETCH +CONFIG_NAND_OMAP_GPMC_WSCFG +CONFIG_NAND_PLAT +CONFIG_NAND_S3C2410 +CONFIG_NAND_SECBOOT +CONFIG_NAND_SPL +CONFIG_NAND_SUNXI +CONFIG_NAND_U_BOOT +CONFIG_NAND_VF610_NFC +CONFIG_NATSEMI +CONFIG_NB +CONFIG_NCEL2C100_BASE +CONFIG_NCEMIC100_BASE +CONFIG_NDS32 +CONFIG_NDS_DLM1_BASE +CONFIG_NDS_DLM2_BASE +CONFIG_NEC_NL6448AC33 +CONFIG_NEC_NL6448BC20 +CONFIG_NEC_NL6448BC33_54 +CONFIG_NEEDS_MANUAL_RELOC +CONFIG_NEO +CONFIG_NET +CONFIG_NET2BIG_V2 +CONFIG_NETCONSOLE +CONFIG_NETCONSOLE_BUFFER_SIZE +CONFIG_NETDEV +CONFIG_NETMASK +CONFIG_NETSPACE_MINI_V2 +CONFIG_NET_MAXDEFRAG +CONFIG_NET_MULTI +CONFIG_NET_RANDOM_ETHADDR +CONFIG_NET_RETRY_COUNT +CONFIG_NET_TFTP_VARS +CONFIG_NEVER_ASSERT_ODT_TO_CPU +CONFIG_NFC_FREQ +CONFIG_NFSBOOT +CONFIG_NFSBOOTCOMMAND +CONFIG_NFS_READ_SIZE +CONFIG_NFS_TIMEOUT +CONFIG_NOBQFMAN +CONFIG_NON_SECURE +CONFIG_NORBOOT +CONFIG_NOR_BOOT +CONFIG_NOT_SELECTED +CONFIG_NO_ETH +CONFIG_NO_RELOCATION +CONFIG_NO_SERIAL_EEPROM +CONFIG_NO_WAIT +CONFIG_NR_CPUS +CONFIG_NR_DRAM_BANKS +CONFIG_NR_DRAM_BANKS_MAX +CONFIG_NR_DRAM_POPULATED +CONFIG_NS16550_MIN_FUNCTIONS +CONFIG_NS8382X +CONFIG_NS87308 +CONFIG_NUM_DDR_CONTROLLERS +CONFIG_NUM_DSP_CPUS +CONFIG_NUM_PAMU +CONFIG_OCLK_DIV +CONFIG_ODROID_REV_AIN +CONFIG_OFF_PADCONF +CONFIG_OF_ +CONFIG_OF_BOARD_SETUP +CONFIG_OF_BOOT_CPU +CONFIG_OF_CONTROL +CONFIG_OF_EMBED +CONFIG_OF_HOSTFILE +CONFIG_OF_IDE_FIXUP +CONFIG_OF_ISA_BUS +CONFIG_OF_LIBFDT +CONFIG_OF_PLATDATA +CONFIG_OF_SEPARATE +CONFIG_OF_SPI +CONFIG_OF_SPI_FLASH +CONFIG_OF_STDOUT_PATH +CONFIG_OF_SUPPORT_OLD_DEVICE_TREES +CONFIG_OF_SYSTEM_SETUP +CONFIG_OLD_SUNXI_KERNEL_COMPAT +CONFIG_OMAP +CONFIG_OMAP3430 +CONFIG_OMAP34XX +CONFIG_OMAP3_AM3517CRANE +CONFIG_OMAP3_DEVKIT8000 +CONFIG_OMAP3_EVM +CONFIG_OMAP3_GPIO_2 +CONFIG_OMAP3_GPIO_3 +CONFIG_OMAP3_GPIO_4 +CONFIG_OMAP3_GPIO_5 +CONFIG_OMAP3_GPIO_6 +CONFIG_OMAP3_LOGIC_USE_NEW_PRODUCT_ID +CONFIG_OMAP3_MCX +CONFIG_OMAP3_MICRON_DDR +CONFIG_OMAP3_RX51 +CONFIG_OMAP3_SPI +CONFIG_OMAP3_SPI_D0_D1_SWAPPED +CONFIG_OMAP3_ZOOM1 +CONFIG_OMAP4430 +CONFIG_OMAP44XX +CONFIG_OMAP54X +CONFIG_OMAP54XX +CONFIG_OMAP_COMMON +CONFIG_OMAP_EHCI_PHY1_RESET_GPIO +CONFIG_OMAP_EHCI_PHY2_RESET_GPIO +CONFIG_OMAP_EHCI_PHY3_RESET_GPIO +CONFIG_OMAP_GPIO +CONFIG_OMAP_HSMMC +CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC +CONFIG_OMAP_USB2PHY2_HOST +CONFIG_OMAP_USB3PHY1_HOST +CONFIG_OMAP_USB_PHY +CONFIG_OMAP_VC_I2C_HS_MCODE +CONFIG_OMAP_WATCHDOG +CONFIG_OPTREX_BW +CONFIG_ORIGEN +CONFIG_ORION5X +CONFIG_OS1_ENV_ADDR +CONFIG_OS2_ENV_ADDR +CONFIG_OS_ENV_ADDR +CONFIG_OTHBOOTARGS +CONFIG_OVERWRITE_ETHADDR_ONCE +CONFIG_P1010 +CONFIG_P1010RDB_PB +CONFIG_P1020 +CONFIG_P1021 +CONFIG_P1022 +CONFIG_P1022DS +CONFIG_P1023 +CONFIG_P1024 +CONFIG_P1025 +CONFIG_P1025RDB +CONFIG_P2020 +CONFIG_P2020RDB +CONFIG_P2041RDB +CONFIG_P3041DS +CONFIG_P4080DS +CONFIG_P5020DS +CONFIG_P5040DS +CONFIG_PAGE_CNT_MASK +CONFIG_PAGE_CNT_SHIFT +CONFIG_PALMAS_AUDPWR +CONFIG_PALMAS_POWER +CONFIG_PALMAS_SMPS7_FPWM +CONFIG_PALMAS_USB_SS_PWR +CONFIG_PANIC_HANG +CONFIG_PARAVIRT +CONFIG_PARTITIONS +CONFIG_PARTITION_TYPE_GUID +CONFIG_PARTITION_UUIDS +CONFIG_PATA_BFIN +CONFIG_PATI +CONFIG_PB1000 +CONFIG_PB1100 +CONFIG_PB1500 +CONFIG_PB1X00 +CONFIG_PCA953X +CONFIG_PCA9551_I2C_ADDR +CONFIG_PCA9564_BASE +CONFIG_PCA9564_I2C +CONFIG_PCA9698 +CONFIG_PCI +CONFIG_PCI1 +CONFIG_PCI2 +CONFIG_PCIAUTO_SKIP_HOST_BRIDGE +CONFIG_PCIE +CONFIG_PCIE1 +CONFIG_PCIE2 +CONFIG_PCIE3 +CONFIG_PCIE4 +CONFIG_PCIE_ECAM_BASE +CONFIG_PCIE_ECAM_SIZE +CONFIG_PCIE_IMX +CONFIG_PCIE_IMX_PERST_GPIO +CONFIG_PCIE_IMX_POWER_GPIO +CONFIG_PCIE_LAYERSCAPE +CONFIG_PCISLAVE +CONFIG_PCIX_CHECK +CONFIG_PCI_33M +CONFIG_PCI_4 +CONFIG_PCI_66M +CONFIG_PCI_BOOTDELAY +CONFIG_PCI_CLK_FREQ +CONFIG_PCI_CONFIG_HOST_BRIDGE +CONFIG_PCI_DISABLE_PCIE +CONFIG_PCI_EHCI_DEVICE +CONFIG_PCI_EHCI_DEVNO +CONFIG_PCI_ENUM_ONLY +CONFIG_PCI_FIXUP_DEV +CONFIG_PCI_GT64120 +CONFIG_PCI_HOST +CONFIG_PCI_INDIRECT_BRIDGE +CONFIG_PCI_IO_BUS +CONFIG_PCI_IO_PHYS +CONFIG_PCI_IO_SIZE +CONFIG_PCI_MEMORY_BUS +CONFIG_PCI_MEMORY_PHYS +CONFIG_PCI_MEMORY_SIZE +CONFIG_PCI_MEM_BUS +CONFIG_PCI_MEM_PHYS +CONFIG_PCI_MEM_SIZE +CONFIG_PCI_MSC01 +CONFIG_PCI_MVEBU +CONFIG_PCI_NOSCAN +CONFIG_PCI_OHCI +CONFIG_PCI_OHCI_DEVNO +CONFIG_PCI_PNP +CONFIG_PCI_PREF_BUS +CONFIG_PCI_PREF_PHYS +CONFIG_PCI_PREF_SIZE +CONFIG_PCI_SCAN_SHOW +CONFIG_PCI_SKIP_HOST_BRIDGE +CONFIG_PCI_SYS_BUS +CONFIG_PCI_SYS_MEM_BUS +CONFIG_PCI_SYS_MEM_PHYS +CONFIG_PCI_SYS_MEM_SIZE +CONFIG_PCI_SYS_PHYS +CONFIG_PCI_SYS_SIZE +CONFIG_PCI_TEGRA +CONFIG_PCMCIA +CONFIG_PCMCIA_SLOT_A +CONFIG_PCMCIA_SLOT_B +CONFIG_PCNET +CONFIG_PCNET_79C973 +CONFIG_PCNET_79C975 +CONFIG_PDM360NG +CONFIG_PDSP188 +CONFIG_PEN_ADDR_BIG_ENDIAN +CONFIG_PERIF1_FREQ +CONFIG_PERIF2_FREQ +CONFIG_PERIF3_FREQ +CONFIG_PERIF4_FREQ +CONFIG_PHY +CONFIG_PHY1_ADDR +CONFIG_PHY2_ADDR +CONFIG_PHY3_ADDR +CONFIG_PHYCORE_MPC5200B_TINY +CONFIG_PHYLIB +CONFIG_PHYLIB_10G +CONFIG_PHYSMEM +CONFIG_PHYS_64BIT +CONFIG_PHYS_TO_BUS +CONFIG_PHY_ADDR +CONFIG_PHY_AQUANTIA +CONFIG_PHY_ATHEROS +CONFIG_PHY_BASE_ADR +CONFIG_PHY_BCM5421S +CONFIG_PHY_BROADCOM +CONFIG_PHY_CLK_FREQ +CONFIG_PHY_CLOCK_FREQ +CONFIG_PHY_CMD_DELAY +CONFIG_PHY_CORTINA +CONFIG_PHY_DAVICOM +CONFIG_PHY_DYNAMIC_ANEG +CONFIG_PHY_ET1011C +CONFIG_PHY_ET1011C_TX_CLK_FIX +CONFIG_PHY_GIGE +CONFIG_PHY_ID +CONFIG_PHY_INTERFACE_MODE +CONFIG_PHY_IRAM_BASE +CONFIG_PHY_KSZ9031 +CONFIG_PHY_LXT +CONFIG_PHY_M88E1111 +CONFIG_PHY_MARVELL +CONFIG_PHY_MAX_ADDR +CONFIG_PHY_MICREL +CONFIG_PHY_MICREL_KSZ9021 +CONFIG_PHY_MICREL_KSZ9031 +CONFIG_PHY_MODE_NEED_CHANGE +CONFIG_PHY_NATSEMI +CONFIG_PHY_REALTEK +CONFIG_PHY_RESET +CONFIG_PHY_RESET_DELAY +CONFIG_PHY_SMSC +CONFIG_PHY_TERANETICS +CONFIG_PHY_TI +CONFIG_PHY_TYPE +CONFIG_PHY_VITESSE +CONFIG_PHY_XILINX +CONFIG_PICOSAM +CONFIG_PIGGY_MAC_ADRESS_OFFSET +CONFIG_PINCTRL_EXYNOS +CONFIG_PINCTRL_FULL +CONFIG_PIP405 +CONFIG_PIXIS_BRDCFG0_SPI +CONFIG_PIXIS_BRDCFG0_USB2 +CONFIG_PIXIS_BRDCFG1_AUDCLK_11 +CONFIG_PIXIS_BRDCFG1_AUDCLK_12 +CONFIG_PIXIS_BRDCFG1_AUDCLK_MASK +CONFIG_PIXIS_BRDCFG1_SSI_TDM_MASK +CONFIG_PIXIS_BRDCFG1_SSI_TDM_SSI +CONFIG_PIXIS_BRDCFG1_TDM +CONFIG_PIXIS_SGMII_CMD +CONFIG_PL01 +CONFIG_PL010_SERIAL +CONFIG_PL011_CLOCK +CONFIG_PL011_SERIAL +CONFIG_PL011_SERIAL_RLCR +CONFIG_PL01X_SERIAL +CONFIG_PLATFORM_ENV_SETTINGS +CONFIG_PLATINUM_BOARD +CONFIG_PLATINUM_CPU +CONFIG_PLATINUM_PICON +CONFIG_PLATINUM_PROJECT +CONFIG_PLATINUM_TITANIUM +CONFIG_PLL +CONFIG_PLL1_CLK_FREQ +CONFIG_PLL1_DIV2_CLK_FREQ +CONFIG_PLL_BYPASS +CONFIG_PLL_CTL_VAL +CONFIG_PLL_DIV_VAL +CONFIG_PLL_LOCKCNT_VAL +CONFIG_PLU405 +CONFIG_PM +CONFIG_PM9261 +CONFIG_PM9263 +CONFIG_PM9G45 +CONFIG_PMC405DE +CONFIG_PMC_BR_PRELIM +CONFIG_PMC_OR_PRELIM +CONFIG_PMECC_CAP +CONFIG_PMECC_INDEX_TABLE_OFFSET +CONFIG_PMECC_SECTOR_SIZE +CONFIG_PME_PLAT_CLK_DIV +CONFIG_PMIC +CONFIG_PMIC_S5M8767 +CONFIG_PMU +CONFIG_PMW_BASE +CONFIG_PM_SLEEP +CONFIG_PORTMUX_GPIO +CONFIG_PORTMUX_PIO +CONFIG_PORT_ADDR +CONFIG_PORT_AP +CONFIG_PORT_BEM +CONFIG_PORT_BME +CONFIG_PORT_BS +CONFIG_PORT_BU +CONFIG_PORT_BW +CONFIG_PORT_CR +CONFIG_PORT_CSN +CONFIG_PORT_OEN +CONFIG_PORT_PEN +CONFIG_PORT_RE +CONFIG_PORT_SOR +CONFIG_PORT_TH +CONFIG_PORT_TWE +CONFIG_PORT_WBF +CONFIG_PORT_WBN +CONFIG_POST +CONFIG_POSTBOOTMENU +CONFIG_POST_ALT_LIST +CONFIG_POST_BSPEC1 +CONFIG_POST_BSPEC1_GPIO_LEDS +CONFIG_POST_BSPEC2 +CONFIG_POST_BSPEC2_GPIO_BUTTONS +CONFIG_POST_BSPEC2_GPIO_NAMES +CONFIG_POST_BSPEC3 +CONFIG_POST_BSPEC4 +CONFIG_POST_BSPEC5 +CONFIG_POST_EXTERNAL_WORD_FUNCS +CONFIG_POST_KEY_MAGIC +CONFIG_POST_SKIP_ENV_FLAGS +CONFIG_POST_STD_LIST +CONFIG_POST_UART +CONFIG_POST_WATCHDOG +CONFIG_POWER +CONFIG_POWER_BATTERY +CONFIG_POWER_BATTERY_TRATS +CONFIG_POWER_BATTERY_TRATS2 +CONFIG_POWER_FG +CONFIG_POWER_FG_MAX17042 +CONFIG_POWER_FG_MAX77693 +CONFIG_POWER_FSL +CONFIG_POWER_FSL_MC13892 +CONFIG_POWER_FSL_MC34704 +CONFIG_POWER_HI6553 +CONFIG_POWER_I2C +CONFIG_POWER_LTC3676 +CONFIG_POWER_LTC3676_I2C_ADDR +CONFIG_POWER_MAX77686 +CONFIG_POWER_MAX77696 +CONFIG_POWER_MAX77696_I2C_ADDR +CONFIG_POWER_MAX8997 +CONFIG_POWER_MAX8998 +CONFIG_POWER_MUIC +CONFIG_POWER_MUIC_MAX77693 +CONFIG_POWER_MUIC_MAX8997 +CONFIG_POWER_PFUZE100 +CONFIG_POWER_PFUZE100_I2C_ADDR +CONFIG_POWER_PFUZE3000 +CONFIG_POWER_PFUZE3000_I2C_ADDR +CONFIG_POWER_PMIC_MAX77693 +CONFIG_POWER_SPI +CONFIG_POWER_TPS62362 +CONFIG_POWER_TPS65090_EC +CONFIG_POWER_TPS65217 +CONFIG_POWER_TPS65218 +CONFIG_POWER_TPS65910 +CONFIG_PPC +CONFIG_PPC4 +CONFIG_PPC4XX_RAPIDIO_DEBUG +CONFIG_PPC4XX_RAPIDIO_IN_BAR_USE_OCM +CONFIG_PPC4XX_RAPIDIO_LOOPBACK +CONFIG_PPC4XX_RAPIDIO_PROMISCUOUS_MODE +CONFIG_PPC4XX_RAPIDIO_USE_HB_PLB +CONFIG_PPC64BRIDGE +CONFIG_PPC_B4420 +CONFIG_PPC_B4860 +CONFIG_PPC_C29X +CONFIG_PPC_CLUSTER_START +CONFIG_PPC_P2041 +CONFIG_PPC_P3041 +CONFIG_PPC_P4080 +CONFIG_PPC_P5020 +CONFIG_PPC_P5040 +CONFIG_PPC_SPINTABLE_COMPATIBLE +CONFIG_PPC_T1024 +CONFIG_PPC_T1040 +CONFIG_PPC_T2081 +CONFIG_PPC_T4240 +CONFIG_PQ_MDS_PIB +CONFIG_PQ_MDS_PIB_ATM +CONFIG_PRAM +CONFIG_PREBOOT +CONFIG_PRE_CONSOLE_BUFFER +CONFIG_PRE_CON_BUF_ADDR +CONFIG_PRE_CON_BUF_SZ +CONFIG_PRIMEVIEW_V16C6448AC +CONFIG_PRINTK +CONFIG_PROC_FS +CONFIG_PROFILE_ALL_BRANCHES +CONFIG_PROFILING +CONFIG_PROG_FDT +CONFIG_PROG_FDT1 +CONFIG_PROG_FDT2 +CONFIG_PROG_OS +CONFIG_PROG_OS1 +CONFIG_PROG_OS2 +CONFIG_PROG_SDRAM_TLB +CONFIG_PROG_UBOOT +CONFIG_PROG_UBOOT1 +CONFIG_PROG_UBOOT2 +CONFIG_PROOF_POINTS +CONFIG_PRPMC_PCI_ALIAS +CONFIG_PS2KBD +CONFIG_PS2MULT +CONFIG_PS2MULT_DELAY +CONFIG_PS2SERIAL +CONFIG_PSC3_USB +CONFIG_PSC_CONSOLE +CONFIG_PSC_CONSOLE2 +CONFIG_PSRAM_SCFG +CONFIG_PUB_ROM_DATA_SIZE +CONFIG_PWM +CONFIG_PWM_IMX +CONFIG_PWRSEQ +CONFIG_PXA_LCD +CONFIG_PXA_MMC_GENERIC +CONFIG_PXA_PWR_I2C +CONFIG_PXA_SERIAL +CONFIG_PXA_STD_I2C +CONFIG_PXA_VGA +CONFIG_PXA_VIDEO +CONFIG_P_CLK_FREQ +CONFIG_QBMAN_CLK_DIV +CONFIG_QE +CONFIG_QEMU +CONFIG_QEMU_E500 +CONFIG_QEMU_MIPS +CONFIG_QFW +CONFIG_QIXIS_I2C_ACCESS +CONFIG_QSPI_BOOT +CONFIG_QSPI_QUAD_SUPPORT +CONFIG_QSPI_SEL_GPIO +CONFIG_QUOTA +CONFIG_R0P7734 +CONFIG_R2DPLUS +CONFIG_R7780MP +CONFIG_R8A66597_BASE_ADDR +CONFIG_R8A66597_ENDIAN +CONFIG_R8A66597_LDRV +CONFIG_R8A66597_XTAL +CONFIG_R8A7740 +CONFIG_R8A7790 +CONFIG_R8A7791 +CONFIG_R8A7793 +CONFIG_R8A7794 +CONFIG_RAINIER +CONFIG_RAM +CONFIG_RAMBOOT +CONFIG_RAMBOOTCOMMAND +CONFIG_RAMBOOTCOMMAND_TFTP +CONFIG_RAMBOOT_NAND +CONFIG_RAMBOOT_PBL +CONFIG_RAMBOOT_SDCARD +CONFIG_RAMBOOT_SPIFLASH +CONFIG_RAMBOOT_TEXT_BASE +CONFIG_RAMDISKFILE +CONFIG_RAMDISK_ADDR +CONFIG_RAMDISK_BOOT +CONFIG_RAM_BOOT +CONFIG_RAM_BOOT_PHYS +CONFIG_RANDOM_UUID +CONFIG_RAPIDIO +CONFIG_RBTREE +CONFIG_RCBA_BASE +CONFIG_RD_LVL +CONFIG_REALMODE_DEBUG +CONFIG_RED_LED +CONFIG_REFCLK_FREQ +CONFIG_REG +CONFIG_REGEX +CONFIG_REG_0 +CONFIG_REG_1_BASE +CONFIG_REG_2 +CONFIG_REG_3 +CONFIG_REG_8 +CONFIG_REG_APER_SIZE +CONFIG_RELOC_GOT_SKIP_NULL +CONFIG_REMAKE_ELF +CONFIG_REMOTEPROC +CONFIG_REQ +CONFIG_REQUIRE_SERIAL_CONSOLE +CONFIG_RESERVED_01_BASE +CONFIG_RESERVED_02_BASE +CONFIG_RESERVED_03_BASE +CONFIG_RESERVED_04_BASE +CONFIG_RESET +CONFIG_RESET_PHY_R +CONFIG_RESET_SEG_START +CONFIG_RESET_TO_RETRY +CONFIG_RESET_VECTOR_ADDRESS +CONFIG_RESTORE_FLASH +CONFIG_RES_BLOCK_SIZE +CONFIG_REV1 +CONFIG_REVISION_TAG +CONFIG_RGMII +CONFIG_RIO +CONFIG_RMII +CONFIG_RMOBILE +CONFIG_RMOBILE_BOARD_STRING +CONFIG_RMOBILE_EXTRAM_BOOT +CONFIG_RMSTP0_ENA +CONFIG_RMSTP10_ENA +CONFIG_RMSTP11_ENA +CONFIG_RMSTP1_ENA +CONFIG_RMSTP2_ENA +CONFIG_RMSTP3_ENA +CONFIG_RMSTP4_ENA +CONFIG_RMSTP5_ENA +CONFIG_RMSTP6_ENA +CONFIG_RMSTP7_ENA +CONFIG_RMSTP8_ENA +CONFIG_RMSTP9_ENA +CONFIG_ROCKCHIP_CHIP_TAG +CONFIG_ROCKCHIP_FAST_SPL +CONFIG_ROCKCHIP_MAX_INIT_SIZE +CONFIG_ROCKCHIP_RK3036 +CONFIG_ROCKCHIP_SDHCI_MAX_FREQ +CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +CONFIG_ROCKCHIP_USB2_PHY +CONFIG_ROM_SIZE +CONFIG_ROM_STUBS +CONFIG_ROM_UNIFIED_SECTIONS +CONFIG_ROOTFS_OFFSET +CONFIG_ROOTPATH +CONFIG_RSA_FREESCALE_EXP +CONFIG_RSK7203 +CONFIG_RSK7264 +CONFIG_RSK7269 +CONFIG_RTC_BFIN +CONFIG_RTC_DS1307 +CONFIG_RTC_DS1337 +CONFIG_RTC_DS1338 +CONFIG_RTC_DS1339 +CONFIG_RTC_DS1374 +CONFIG_RTC_DS1388 +CONFIG_RTC_DS1556 +CONFIG_RTC_DS164 +CONFIG_RTC_DS174 +CONFIG_RTC_DS3231 +CONFIG_RTC_FTRTC010 +CONFIG_RTC_IMXDI +CONFIG_RTC_INTERNAL +CONFIG_RTC_ISL1208 +CONFIG_RTC_M41T11 +CONFIG_RTC_M41T60 +CONFIG_RTC_M41T62 +CONFIG_RTC_M48T35A +CONFIG_RTC_MAX6900 +CONFIG_RTC_MC13XXX +CONFIG_RTC_MC146818 +CONFIG_RTC_MCFRRTC +CONFIG_RTC_MCP79411 +CONFIG_RTC_MPC5200 +CONFIG_RTC_MPC8 +CONFIG_RTC_MV +CONFIG_RTC_MXS +CONFIG_RTC_PCF8563 +CONFIG_RTC_PT7C4338 +CONFIG_RTC_RTC4543 +CONFIG_RTC_RV3029 +CONFIG_RTC_RX8025 +CONFIG_RTC_S3C24X0 +CONFIG_RTC_X1205 +CONFIG_RTL8211X_PHY_FORCE_MASTER +CONFIG_RUN_FROM_DDR0 +CONFIG_RUN_FROM_DDR1 +CONFIG_RUN_FROM_IRAM_ONLY +CONFIG_RX_DESCR_NUM +CONFIG_R_I2C_ENABLE +CONFIG_S32V234 +CONFIG_S3C2400 +CONFIG_S3C2410 +CONFIG_S3C2410_NAND_BBT +CONFIG_S3C2410_NAND_HWECC +CONFIG_S3C2440 +CONFIG_S3C24X0 +CONFIG_S3C24X0_SERIAL +CONFIG_S3C24XX_CUSTOM_NAND_TIMING +CONFIG_S3C24XX_TACLS +CONFIG_S3C24XX_TWRPH0 +CONFIG_S3C24XX_TWRPH1 +CONFIG_S5P +CONFIG_S5PC100 +CONFIG_S5PC110 +CONFIG_S5P_PA_SYSRAM +CONFIG_S5P_SDHCI +CONFIG_S6E63D6 +CONFIG_S6E8AX0 +CONFIG_SA1100_ADSBITSY +CONFIG_SA1100_ASSABET +CONFIG_SA1100_BADGE4 +CONFIG_SA1100_BRUTUS +CONFIG_SA1100_CERF +CONFIG_SA1100_COLLIE +CONFIG_SA1100_CONSUS +CONFIG_SA1100_FLEXANET +CONFIG_SA1100_GRAPHICSCLIENT +CONFIG_SA1100_GRAPHICSMASTER +CONFIG_SA1100_H3100 +CONFIG_SA1100_H3600 +CONFIG_SA1100_HACKKIT +CONFIG_SA1100_JORNADA720 +CONFIG_SA1100_LART +CONFIG_SA1100_NANOENGINE +CONFIG_SA1100_PFS168 +CONFIG_SA1100_PLEB +CONFIG_SA1100_PT_SYSTEM3 +CONFIG_SA1100_SHANNON +CONFIG_SA1100_SIMPAD +CONFIG_SA1100_XP860 +CONFIG_SAMA5D2 +CONFIG_SAMA5D3_LCD_BASE +CONFIG_SAMA5D4 +CONFIG_SAMSUNG +CONFIG_SAMSUNG_ONENAND +CONFIG_SANDBOX +CONFIG_SANDBOX_ARCH +CONFIG_SANDBOX_BIG_ENDIAN +CONFIG_SANDBOX_BITS_PER_LONG +CONFIG_SANDBOX_GPIO_COUNT +CONFIG_SANDBOX_SDL +CONFIG_SANDBOX_SPI +CONFIG_SANDBOX_SPI_MAX_BUS +CONFIG_SANDBOX_SPI_MAX_CS +CONFIG_SAR2_REG +CONFIG_SAR_REG +CONFIG_SATA1 +CONFIG_SATA2 +CONFIG_SATAPWR +CONFIG_SATA_CEVA +CONFIG_SATA_DWC +CONFIG_SATA_MV +CONFIG_SATA_SIL +CONFIG_SATA_SIL3114 +CONFIG_SATA_ULI5288 +CONFIG_SBC8349 +CONFIG_SBC8548 +CONFIG_SBC8641D +CONFIG_SCC1_ENET +CONFIG_SCC2_ENET +CONFIG_SCF0403_LCD +CONFIG_SCIF +CONFIG_SCIF_A +CONFIG_SCIF_CONSOLE +CONFIG_SCIF_EXT_CLOCK +CONFIG_SCIF_USE_EXT_CLK +CONFIG_SCLK0_DIV +CONFIG_SCLK1_DIV +CONFIG_SCLK_DIV +CONFIG_SCLK_HZ +CONFIG_SCSI +CONFIG_SCSI_AHCI +CONFIG_SCSI_AHCI_PLAT +CONFIG_SCSI_DEV_ID +CONFIG_SCSI_DEV_LIST +CONFIG_SCSI_SYM53C8XX +CONFIG_SC_TIMER_CLK +CONFIG_SDCARD +CONFIG_SDHCI +CONFIG_SDHCI_CMD_DEFAULT_TIMEOUT +CONFIG_SDHCI_CMD_MAX_TIMEOUT +CONFIG_SDMMC_BASE +CONFIG_SDRAM_BANK0 +CONFIG_SDRAM_BANK1 +CONFIG_SDRAM_ECC +CONFIG_SDRAM_OFFSET_FOR_RT +CONFIG_SDRAM_PPC4 +CONFIG_SDRC +CONFIG_SDR_MT48LC16M16A2 +CONFIG_SD_BOOT +CONFIG_SD_BOOT_QSPI +CONFIG_SEABIOS +CONFIG_SECBOOT +CONFIG_SECURE_BL1_ONLY +CONFIG_SECURE_BOOT +CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ +CONFIG_SECURITY +CONFIG_SEC_DEQ_TIMEOUT +CONFIG_SEC_FW_SIZE +CONFIG_SELECTED +CONFIG_SEMIHOSTING +CONFIG_SERIAL0 +CONFIG_SERIAL1 +CONFIG_SERIAL2 +CONFIG_SERIAL3 +CONFIG_SERIAL_BOOT +CONFIG_SERIAL_FLASH +CONFIG_SERIAL_HW_FLOW_CONTROL +CONFIG_SERIAL_MULTI +CONFIG_SERIAL_SOFTWARE_FIFO +CONFIG_SERIAL_TAG +CONFIG_SERIES +CONFIG_SERIRQ_CONTINUOUS_MODE +CONFIG_SERVERIP +CONFIG_SETUP_INITRD_TAG +CONFIG_SETUP_MEMORY_TAGS +CONFIG_SET_BIST +CONFIG_SET_BOOTARGS +CONFIG_SET_DFU_ALT_BUF_LEN +CONFIG_SET_DFU_ALT_INFO +CONFIG_SFIO +CONFIG_SF_DATAFLASH +CONFIG_SF_DEFAULT_BUS +CONFIG_SF_DEFAULT_CS +CONFIG_SF_DEFAULT_HZ +CONFIG_SF_DEFAULT_MODE +CONFIG_SF_DEFAULT_SPEED +CONFIG_SF_DUAL_FLASH +CONFIG_SGI_IP28 +CONFIG_SH4_PCI +CONFIG_SH73A0 +CONFIG_SH7751_PCI +CONFIG_SH7752EVB +CONFIG_SH7753EVB +CONFIG_SH7757LCR +CONFIG_SH7757LCR_DDR_ECC +CONFIG_SH7763RDP +CONFIG_SH7780_PCI +CONFIG_SH7780_PCI_BAR +CONFIG_SH7780_PCI_LAR +CONFIG_SH7780_PCI_LSR +CONFIG_SH7785LCR +CONFIG_SHA1 +CONFIG_SHA1SUM_VERIFY +CONFIG_SHA256 +CONFIG_SHARP_16 +CONFIG_SHARP_LM8V31 +CONFIG_SHARP_LQ035Q7DH06 +CONFIG_SHARP_LQ057Q3DC02 +CONFIG_SHARP_LQ065T9DR51U +CONFIG_SHARP_LQ084V1DG21 +CONFIG_SHARP_LQ104V7DS01 +CONFIG_SHARP_LQ64D341 +CONFIG_SHA_HW_ACCEL +CONFIG_SHA_PROG_HW_ACCEL +CONFIG_SHC_ICT +CONFIG_SHC_NETBOOT +CONFIG_SHC_SDBOOT +CONFIG_SHEEVA_88SV131 +CONFIG_SHEEVA_88SV331 +CONFIG_SHELL +CONFIG_SHMIN +CONFIG_SHOW_ACTIVITY +CONFIG_SHOW_BOOT_PROGRESS +CONFIG_SH_32BIT +CONFIG_SH_CMT_CLK_FREQ +CONFIG_SH_DSP +CONFIG_SH_ETHER +CONFIG_SH_ETHER_ALIGNE_SIZE +CONFIG_SH_ETHER_BASE_ADDR +CONFIG_SH_ETHER_CACHE_INVALIDATE +CONFIG_SH_ETHER_CACHE_WRITEBACK +CONFIG_SH_ETHER_PHY_ADDR +CONFIG_SH_ETHER_PHY_MODE +CONFIG_SH_ETHER_SH7734_MII +CONFIG_SH_ETHER_USE_GETHER +CONFIG_SH_ETHER_USE_PORT +CONFIG_SH_GPIO_PFC +CONFIG_SH_I2C_8BIT +CONFIG_SH_I2C_BASE0 +CONFIG_SH_I2C_BASE1 +CONFIG_SH_I2C_CLOCK +CONFIG_SH_I2C_DATA_HIGH +CONFIG_SH_I2C_DATA_LOW +CONFIG_SH_MMCIF +CONFIG_SH_MMCIF_ADDR +CONFIG_SH_MMCIF_CLK +CONFIG_SH_QSPI +CONFIG_SH_SCIF_CLK_FREQ +CONFIG_SH_SDHI +CONFIG_SH_SDHI_FREQ +CONFIG_SH_SDRAM_OFFSET +CONFIG_SH_SH7734_I2C +CONFIG_SH_SPI +CONFIG_SH_SPI_BASE +CONFIG_SH_TMU_CLK_FREQ +CONFIG_SIEMENS_DRACO +CONFIG_SIEMENS_MACH_TYPE +CONFIG_SIEMENS_PXM2 +CONFIG_SIEMENS_RUT +CONFIG_SILENT_CONSOLE +CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC +CONFIG_SILENT_CONSOLE_UPDATE_ON_SET +CONFIG_SILENT_U_BOOT_ONLY +CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION +CONFIG_SKIP_LOWLEVEL_INIT +CONFIG_SKIP_LOWLEVEL_INIT_ONLY +CONFIG_SKIP_TRUNOFF_WATCHDOG +CONFIG_SLIC +CONFIG_SLTTMR +CONFIG_SMBIOS_MANUFACTURER +CONFIG_SMBIOS_PRODUCT_NAME +CONFIG_SMC91111 +CONFIG_SMC91111_BASE +CONFIG_SMC91111_EXT_PHY +CONFIG_SMC911X +CONFIG_SMC911X_16_BIT +CONFIG_SMC911X_32_BIT +CONFIG_SMC911X_BASE +CONFIG_SMC911X_NO_EEPROM +CONFIG_SMC_91111_EXT_PHY +CONFIG_SMC_AUTONEG_TIMEOUT +CONFIG_SMC_B0CTL_VAL +CONFIG_SMC_B0ETIM_VAL +CONFIG_SMC_B0TIM_VAL +CONFIG_SMC_B1CTL_VAL +CONFIG_SMC_B1ETIM_VAL +CONFIG_SMC_B1TIM_VAL +CONFIG_SMC_B2CTL_VAL +CONFIG_SMC_B2ETIM_VAL +CONFIG_SMC_B2TIM_VAL +CONFIG_SMC_B3CTL_VAL +CONFIG_SMC_B3ETIM_VAL +CONFIG_SMC_B3TIM_VAL +CONFIG_SMC_GCTL_VAL +CONFIG_SMC_USE_32_BIT +CONFIG_SMC_USE_IOFUNCS +CONFIG_SMDK2410 +CONFIG_SMDK5420 +CONFIG_SMDKC100 +CONFIG_SMDKV310 +CONFIG_SMM_TSEG_SIZE +CONFIG_SMP +CONFIG_SMP_PEN_ADDR +CONFIG_SMSC_LPC47M +CONFIG_SMSC_SIO1007 +CONFIG_SMSTP0_ENA +CONFIG_SMSTP10_ENA +CONFIG_SMSTP11_ENA +CONFIG_SMSTP1_ENA +CONFIG_SMSTP2_ENA +CONFIG_SMSTP3_ENA +CONFIG_SMSTP4_ENA +CONFIG_SMSTP5_ENA +CONFIG_SMSTP6_ENA +CONFIG_SMSTP7_ENA +CONFIG_SMSTP8_ENA +CONFIG_SMSTP9_ENA +CONFIG_SOCFPGA_DWMMC +CONFIG_SOCFPGA_DWMMC_BUS_HZ +CONFIG_SOCFPGA_DWMMC_BUS_WIDTH +CONFIG_SOCFPGA_DWMMC_DRVSEL +CONFIG_SOCFPGA_DWMMC_FIFO_DEPTH +CONFIG_SOCFPGA_DWMMC_SMPSEL +CONFIG_SOCFPGA_VIRTUAL_TARGET +CONFIG_SOCRATES +CONFIG_SOC_AU1000 +CONFIG_SOC_AU1100 +CONFIG_SOC_AU1500 +CONFIG_SOC_AU1550 +CONFIG_SOC_AU1X00 +CONFIG_SOC_DA850 +CONFIG_SOC_DA8XX +CONFIG_SOC_DM355 +CONFIG_SOC_DM365 +CONFIG_SOC_DM644X +CONFIG_SOC_DM646X +CONFIG_SOC_K2E +CONFIG_SOC_K2G +CONFIG_SOC_K2HK +CONFIG_SOC_K2L +CONFIG_SOC_KEYSTONE +CONFIG_SOC_OMAP3430 +CONFIG_SOFT_I2C_GPIO_SCL +CONFIG_SOFT_I2C_GPIO_SDA +CONFIG_SOFT_I2C_I2C10_SCL +CONFIG_SOFT_I2C_I2C10_SDA +CONFIG_SOFT_I2C_I2C5_SCL +CONFIG_SOFT_I2C_I2C5_SDA +CONFIG_SOFT_I2C_I2C9_SCL +CONFIG_SOFT_I2C_I2C9_SDA +CONFIG_SOFT_I2C_MULTI_BUS +CONFIG_SOFT_I2C_READ_REPEATED_START +CONFIG_SOFT_SPI +CONFIG_SOFT_TWS +CONFIG_SOUND_MAX98095 +CONFIG_SOURCE +CONFIG_SPARSE_RCU_POINTER +CONFIG_SPDDRAM_SILENT +CONFIG_SPD_EEPROM +CONFIG_SPEAR300 +CONFIG_SPEAR310 +CONFIG_SPEAR320 +CONFIG_SPEAR3XX +CONFIG_SPEAR600 +CONFIG_SPEAR_BOOTSTRAPCFG +CONFIG_SPEAR_BOOTSTRAPMASK +CONFIG_SPEAR_BOOTSTRAPSHFT +CONFIG_SPEAR_EMI +CONFIG_SPEAR_EMIBASE +CONFIG_SPEAR_ETHBASE +CONFIG_SPEAR_GPIO +CONFIG_SPEAR_HZ +CONFIG_SPEAR_HZ_CLOCK +CONFIG_SPEAR_MISCBASE +CONFIG_SPEAR_MPMCBASE +CONFIG_SPEAR_MPMCREGS +CONFIG_SPEAR_NORNAND16BOOT +CONFIG_SPEAR_NORNAND8BOOT +CONFIG_SPEAR_NORNANDBOOT +CONFIG_SPEAR_ONLYSNORBOOT +CONFIG_SPEAR_RASBASE +CONFIG_SPEAR_SYSCNTLBASE +CONFIG_SPEAR_TIMERBASE +CONFIG_SPEAR_UART48M +CONFIG_SPEAR_UARTCLKMSK +CONFIG_SPEAR_USBBOOT +CONFIG_SPEAR_USBTTY +CONFIG_SPI +CONFIG_SPIFLASH +CONFIG_SPI_ADDR +CONFIG_SPI_BAUD_INITBLOCK +CONFIG_SPI_BOOT +CONFIG_SPI_BOOTING +CONFIG_SPI_CS_IS_VALID +CONFIG_SPI_DATAFLASH_WRITE_VERIFY +CONFIG_SPI_DMA_BASE +CONFIG_SPI_FLASH +CONFIG_SPI_FLASH_ALL +CONFIG_SPI_FLASH_ATMEL +CONFIG_SPI_FLASH_BAR +CONFIG_SPI_FLASH_DATAFLASH +CONFIG_SPI_FLASH_EON +CONFIG_SPI_FLASH_GIGADEVICE +CONFIG_SPI_FLASH_ISSI +CONFIG_SPI_FLASH_MACRONIX +CONFIG_SPI_FLASH_MTD +CONFIG_SPI_FLASH_QUAD +CONFIG_SPI_FLASH_SIZE +CONFIG_SPI_FLASH_SPANSION +CONFIG_SPI_FLASH_SST +CONFIG_SPI_FLASH_STMICRO +CONFIG_SPI_FLASH_USE_4K_SECTORS +CONFIG_SPI_FLASH_WINBOND +CONFIG_SPI_HALF_DUPLEX +CONFIG_SPI_IDLE_VAL +CONFIG_SPI_LENGTH +CONFIG_SPI_N25Q256A_RESET +CONFIG_SPL +CONFIG_SPLASHIMAGE_GUARD +CONFIG_SPLASH_SCREEN +CONFIG_SPLASH_SCREEN_ALIGN +CONFIG_SPLASH_SOURCE +CONFIG_SPLL_FREQ +CONFIG_SPL_ +CONFIG_SPL_ABORT_ON_RAW_IMAGE +CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC +CONFIG_SPL_ATMEL_SIZE +CONFIG_SPL_BOARD_INIT +CONFIG_SPL_BOARD_LOAD_IMAGE +CONFIG_SPL_BOOTROM_SAVE +CONFIG_SPL_BOOT_DEVICE +CONFIG_SPL_BSS_MAX_SIZE +CONFIG_SPL_BSS_START_ADDR +CONFIG_SPL_BUILD +CONFIG_SPL_CMT +CONFIG_SPL_CMT_DEBUG +CONFIG_SPL_COMMON_INIT_DDR +CONFIG_SPL_CONSOLE +CONFIG_SPL_CRC32_SUPPORT +CONFIG_SPL_DISPLAY_PRINT +CONFIG_SPL_DM +CONFIG_SPL_ENV_SUPPORT +CONFIG_SPL_ETH_DEVICE +CONFIG_SPL_ETH_SUPPORT +CONFIG_SPL_EXT_SUPPORT +CONFIG_SPL_FAT_SUPPORT +CONFIG_SPL_FIT_IMAGE_POST_PROCESS +CONFIG_SPL_FLUSH_IMAGE +CONFIG_SPL_FOO +CONFIG_SPL_FRAMEWORK +CONFIG_SPL_FSL_PBL +CONFIG_SPL_FS_LOAD_ARGS_NAME +CONFIG_SPL_FS_LOAD_KERNEL_NAME +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME +CONFIG_SPL_GD_ADDR +CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER +CONFIG_SPL_I2C_SUPPORT +CONFIG_SPL_INIT_MINIMAL +CONFIG_SPL_JR0_LIODN_NS +CONFIG_SPL_JR0_LIODN_S +CONFIG_SPL_LDSCRIPT +CONFIG_SPL_LED +CONFIG_SPL_LIBCOMMON_SUPPORT +CONFIG_SPL_LIBGENERIC_SUPPORT +CONFIG_SPL_LOAD_FIT +CONFIG_SPL_LOAD_FIT_ADDRESS +CONFIG_SPL_MAX_FOOTPRINT +CONFIG_SPL_MAX_PEB_SIZE +CONFIG_SPL_MAX_SIZE +CONFIG_SPL_MD5_SUPPORT +CONFIG_SPL_MMC_BOOT +CONFIG_SPL_MMC_LOAD +CONFIG_SPL_MMC_MINIMAL +CONFIG_SPL_MMC_SUPPORT +CONFIG_SPL_MPC83XX_WAIT_FOR_NAND +CONFIG_SPL_MXS_PSWITCH_WAIT +CONFIG_SPL_NAND_AM33XX_BCH +CONFIG_SPL_NAND_BASE +CONFIG_SPL_NAND_BOOT +CONFIG_SPL_NAND_DRIVERS +CONFIG_SPL_NAND_ECC +CONFIG_SPL_NAND_INIT +CONFIG_SPL_NAND_LOAD +CONFIG_SPL_NAND_MINIMAL +CONFIG_SPL_NAND_MXS +CONFIG_SPL_NAND_RAW_ONLY +CONFIG_SPL_NAND_SIMPLE +CONFIG_SPL_NAND_SOFTECC +CONFIG_SPL_NAND_SUPPORT +CONFIG_SPL_NAND_WORKSPACE +CONFIG_SPL_NET_SUPPORT +CONFIG_SPL_NET_VCI_STRING +CONFIG_SPL_NOR_SUPPORT +CONFIG_SPL_NO_CPU_SUPPORT_CODE +CONFIG_SPL_OF_CONTROL +CONFIG_SPL_OF_LIBFDT +CONFIG_SPL_OF_PLATDATA +CONFIG_SPL_OMAP3_ID_NAND +CONFIG_SPL_ONENAND_SUPPORT +CONFIG_SPL_OS_BOOT +CONFIG_SPL_PAD_TO +CONFIG_SPL_PANIC_ON_RAW_IMAGE +CONFIG_SPL_PBL_PAD +CONFIG_SPL_PINCTRL_FULL +CONFIG_SPL_PMIC_CHILDREN +CONFIG_SPL_PPAACT_ADDR +CONFIG_SPL_RAM_DEVICE +CONFIG_SPL_RELOC_MALLOC_ADDR +CONFIG_SPL_RELOC_MALLOC_SIZE +CONFIG_SPL_RELOC_STACK +CONFIG_SPL_RELOC_STACK_SIZE +CONFIG_SPL_RELOC_TEXT_BASE +CONFIG_SPL_SATA_BOOT_DEVICE +CONFIG_SPL_SATA_SUPPORT +CONFIG_SPL_SERIAL_PRESENT +CONFIG_SPL_SERIAL_SUPPORT +CONFIG_SPL_SHA1_SUPPORT +CONFIG_SPL_SHA256_SUPPORT +CONFIG_SPL_SIMPLE_BUS +CONFIG_SPL_SIZE +CONFIG_SPL_SKIP_RELOCATE +CONFIG_SPL_SPAACT_ADDR +CONFIG_SPL_SPI_BOOT +CONFIG_SPL_SPI_BUS +CONFIG_SPL_SPI_CS +CONFIG_SPL_SPI_FLASH_MINIMAL +CONFIG_SPL_SPI_LOAD +CONFIG_SPL_SPI_SUNXI +CONFIG_SPL_SPI_SUPPORT +CONFIG_SPL_STACK +CONFIG_SPL_STACK_ADDR +CONFIG_SPL_STACK_R +CONFIG_SPL_STACK_R_ADDR +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN +CONFIG_SPL_STACK_SIZE +CONFIG_SPL_START_S_PATH +CONFIG_SPL_SYS_MALLOC_SIMPLE +CONFIG_SPL_TARGET +CONFIG_SPL_TEXT_BASE +CONFIG_SPL_UBI +CONFIG_SPL_UBI_INFO_ADDR +CONFIG_SPL_UBI_LEB_START +CONFIG_SPL_UBI_LOAD_ARGS_ID +CONFIG_SPL_UBI_LOAD_KERNEL_ID +CONFIG_SPL_UBI_LOAD_MONITOR_ID +CONFIG_SPL_UBI_MAX_PEBS +CONFIG_SPL_UBI_MAX_PEB_SIZE +CONFIG_SPL_UBI_MAX_VOL_LEBS +CONFIG_SPL_UBI_PEB_OFFSET +CONFIG_SPL_UBI_VID_OFFSET +CONFIG_SPL_UBI_VOL_IDS +CONFIG_SPL_UBOOT_KEY_HASH +CONFIG_SPL_USBETH_SUPPORT +CONFIG_SPL_USB_HOST_SUPPORT +CONFIG_SPL_USB_SUPPORT +CONFIG_SPL_XXX_SUPPORT +CONFIG_SPL_YMODEM_SUPPORT +CONFIG_SRAM_BASE +CONFIG_SRAM_SIZE +CONFIG_SRIO1 +CONFIG_SRIO2 +CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET +CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 +CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 +CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS +CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE +CONFIG_SRIO_PCIE_BOOT_MASTER +CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK +CONFIG_SRIO_PCIE_BOOT_SLAVE +CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS +CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS +CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE +CONFIG_SSD_BR_PRELIM +CONFIG_SSD_OR_PRELIM +CONFIG_SSE2 +CONFIG_SSI1_FREQ +CONFIG_SSI2_FREQ +CONFIG_SSP1_BASE +CONFIG_SSP2_BASE +CONFIG_SSP3_BASE +CONFIG_STACKBASE +CONFIG_STACKSIZE +CONFIG_STACKSIZE_FIQ +CONFIG_STACKSIZE_IRQ +CONFIG_STAMP_CF +CONFIG_STANDALONE_LOAD_ADDR +CONFIG_STATIC_BOARD_REV +CONFIG_STATIC_RELA +CONFIG_STATUS_LED +CONFIG_STD_DEVICES_SETTINGS +CONFIG_STK52XX +CONFIG_STK52XX_REV100 +CONFIG_STM32F4DISCOVERY +CONFIG_STM32X7_SERIAL +CONFIG_STM32_FLASH +CONFIG_STM32_GPIO +CONFIG_STM32_HSE_HZ +CONFIG_STM32_HZ +CONFIG_STM32_SERIAL +CONFIG_STORAGE_EMMC +CONFIG_STRESS +CONFIG_STRIDER +CONFIG_STRIDER_CON +CONFIG_STRIDER_CON_DP +CONFIG_STRIDER_CPU +CONFIG_STRIDER_CPU_DP +CONFIG_STRIDER_FANS +CONFIG_STUART +CONFIG_STV0991_HZ +CONFIG_STV0991_HZ_CLOCK +CONFIG_ST_SMI +CONFIG_SUN4 +CONFIG_SUNXI +CONFIG_SUNXI_AHCI +CONFIG_SUNXI_EMAC +CONFIG_SUNXI_GEN_SUN4I +CONFIG_SUNXI_GEN_SUN6I +CONFIG_SUNXI_GMAC +CONFIG_SUNXI_GPIO +CONFIG_SUNXI_MAX_FB_SIZE +CONFIG_SUNXI_USB_PHYS +CONFIG_SUPERH_ON_CHIP_R8A66597 +CONFIG_SUPPORT_EMMC_BOOT +CONFIG_SUPPORT_EMMC_RPMB +CONFIG_SUPPORT_RAW_INITRD +CONFIG_SUPPORT_VFAT +CONFIG_SX151X_GPIO_COUNT_8 +CONFIG_SX151X_SPI_BUS +CONFIG_SXNI855T +CONFIG_SY8106A_POWER +CONFIG_SYSCOUNTER_TIMER +CONFIG_SYSFLAGS_ADDR +CONFIG_SYSFS +CONFIG_SYSMGR_ISWGRP_HANDOFF +CONFIG_SYSRESET +CONFIG_SYSTEMACE +CONFIG_SYS_ +CONFIG_SYS_4 +CONFIG_SYS_405_UART_ERRATA_59 +CONFIG_SYS_460GT_SRIO_ERRATA_1 +CONFIG_SYS_64BIT +CONFIG_SYS_64BIT_LBA +CONFIG_SYS_64BIT_VSPRINTF +CONFIG_SYS_66MHZ +CONFIG_SYS_8 +CONFIG_SYS_8313ERDB_BROKEN_PMC +CONFIG_SYS_83XX_DDR_USES_CS0 +CONFIG_SYS_8XX_XIN +CONFIG_SYS_ACE_BASE +CONFIG_SYS_ACE_BASE_PHYS_H +CONFIG_SYS_ACE_BASE_PHYS_L +CONFIG_SYS_ACR_APARK +CONFIG_SYS_ACR_PARKM +CONFIG_SYS_ACR_PIPE_DEP +CONFIG_SYS_ACR_RPTCNT +CONFIG_SYS_ADDRESS_MAP_A +CONFIG_SYS_ADV7611_I2C +CONFIG_SYS_AHB_BASE +CONFIG_SYS_ALE_MASK +CONFIG_SYS_ALLOC_DPRAM +CONFIG_SYS_ALT_BOOT +CONFIG_SYS_ALT_FLASH +CONFIG_SYS_ALT_MEMTEST +CONFIG_SYS_AMASK0 +CONFIG_SYS_AMASK0_FINAL +CONFIG_SYS_AMASK1 +CONFIG_SYS_AMASK1_FINAL +CONFIG_SYS_AMASK2 +CONFIG_SYS_AMASK2_FINAL +CONFIG_SYS_AMASK3 +CONFIG_SYS_AMASK3_FINAL +CONFIG_SYS_AMASK4 +CONFIG_SYS_AMASK5 +CONFIG_SYS_AMASK6 +CONFIG_SYS_AMASK7 +CONFIG_SYS_APP1_BASE +CONFIG_SYS_APP1_SIZE +CONFIG_SYS_APP2_BASE +CONFIG_SYS_APP2_SIZE +CONFIG_SYS_ARCH +CONFIG_SYS_ARCH_TIMER +CONFIG_SYS_ARIA_FPGA_BASE +CONFIG_SYS_ARIA_FPGA_SIZE +CONFIG_SYS_ARIA_SRAM_BASE +CONFIG_SYS_ARIA_SRAM_SIZE +CONFIG_SYS_ARM_ARCH +CONFIG_SYS_ARM_CACHE_WRITETHROUGH +CONFIG_SYS_AT91_CPU_NAME +CONFIG_SYS_AT91_MAIN_CLOCK +CONFIG_SYS_AT91_PLLA +CONFIG_SYS_AT91_PLLB +CONFIG_SYS_AT91_SLOW_CLOCK +CONFIG_SYS_ATA_ALT_OFFSET +CONFIG_SYS_ATA_BASE_ADDR +CONFIG_SYS_ATA_CS_ON_I2C2 +CONFIG_SYS_ATA_CS_ON_TIMER01 +CONFIG_SYS_ATA_DATA_OFFSET +CONFIG_SYS_ATA_IDE0_OFFSET +CONFIG_SYS_ATA_IDE1_OFFSET +CONFIG_SYS_ATA_PORT_ADDR +CONFIG_SYS_ATA_REG_OFFSET +CONFIG_SYS_ATA_STRIDE +CONFIG_SYS_ATI_REV_A11 +CONFIG_SYS_ATI_REV_A12 +CONFIG_SYS_ATI_REV_A13 +CONFIG_SYS_ATI_REV_ID_MASK +CONFIG_SYS_ATMEL_BASE +CONFIG_SYS_ATMEL_BOOT +CONFIG_SYS_ATMEL_CPU_NAME +CONFIG_SYS_ATMEL_REGION +CONFIG_SYS_ATMEL_SECT +CONFIG_SYS_ATMEL_SECTSZ +CONFIG_SYS_ATMEL_TOTALSECT +CONFIG_SYS_AUTOLOAD +CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION +CONFIG_SYS_AUXCORE_BOOTDATA +CONFIG_SYS_BARGSIZE +CONFIG_SYS_BASE_BAUD +CONFIG_SYS_BAUDRATE_TABLE +CONFIG_SYS_BCR +CONFIG_SYS_BCR_60 +CONFIG_SYS_BCR_SINGLE +CONFIG_SYS_BCSR +CONFIG_SYS_BCSR3_PCIE +CONFIG_SYS_BCSR5_PCI66EN +CONFIG_SYS_BCSR_ADDR +CONFIG_SYS_BCSR_BASE +CONFIG_SYS_BCSR_BASE_PHYS +CONFIG_SYS_BCSR_SIZE +CONFIG_SYS_BD_INFO_ADDR +CONFIG_SYS_BD_REV +CONFIG_SYS_BFTIC3_BASE +CONFIG_SYS_BFTIC3_SIZE +CONFIG_SYS_BIG_ENDIAN +CONFIG_SYS_BITBANG_PHY_PORT +CONFIG_SYS_BITBANG_PHY_PORTS +CONFIG_SYS_BLACK_IN_WRITE +CONFIG_SYS_BMAN_CENA_BASE +CONFIG_SYS_BMAN_CENA_SIZE +CONFIG_SYS_BMAN_CINH_BASE +CONFIG_SYS_BMAN_CINH_SIZE +CONFIG_SYS_BMAN_MEM_BASE +CONFIG_SYS_BMAN_MEM_PHYS +CONFIG_SYS_BMAN_MEM_SIZE +CONFIG_SYS_BMAN_NUM_PORTALS +CONFIG_SYS_BMAN_SP_CENA_SIZE +CONFIG_SYS_BMAN_SP_CINH_SIZE +CONFIG_SYS_BMAN_SWP_ISDR_REG +CONFIG_SYS_BOARD +CONFIG_SYS_BOARD_NAME +CONFIG_SYS_BOARD_VERSION +CONFIG_SYS_BOOK3E_HV +CONFIG_SYS_BOOTADDR +CONFIG_SYS_BOOTCOUNT_ADDR +CONFIG_SYS_BOOTCOUNT_BE +CONFIG_SYS_BOOTCOUNT_LE +CONFIG_SYS_BOOTCOUNT_SINGLEWORD +CONFIG_SYS_BOOTCS_CFG +CONFIG_SYS_BOOTCS_SIZE +CONFIG_SYS_BOOTCS_START +CONFIG_SYS_BOOTFILE +CONFIG_SYS_BOOTFILE_PREFIX +CONFIG_SYS_BOOTLOC +CONFIG_SYS_BOOTMAPSZ +CONFIG_SYS_BOOTM_LEN +CONFIG_SYS_BOOTPARAMS_LEN +CONFIG_SYS_BOOTSEQ +CONFIG_SYS_BOOTSZ +CONFIG_SYS_BOOT_BASE_ADDR +CONFIG_SYS_BOOT_BLOCK +CONFIG_SYS_BOOT_EEPROM_PAGE_WRITE_BITS +CONFIG_SYS_BOOT_GET_CMDLINE +CONFIG_SYS_BOOT_GET_KBD +CONFIG_SYS_BOOT_RAMDISK_HIGH +CONFIG_SYS_BOOT_SPINOR +CONFIG_SYS_BR0_64M +CONFIG_SYS_BR0_8M +CONFIG_SYS_BR0_PRELIM +CONFIG_SYS_BR10_PRELIM +CONFIG_SYS_BR11_PRELIM +CONFIG_SYS_BR1_PRELIM +CONFIG_SYS_BR2_PRELIM +CONFIG_SYS_BR3_CAN +CONFIG_SYS_BR3_PRELIM +CONFIG_SYS_BR4_PRELIM +CONFIG_SYS_BR5_ISP1362 +CONFIG_SYS_BR5_PRELIM +CONFIG_SYS_BR6_64M +CONFIG_SYS_BR6_8M +CONFIG_SYS_BR6_PRELIM +CONFIG_SYS_BR7_PRELIM +CONFIG_SYS_BR8_PRELIM +CONFIG_SYS_BR9_PRELIM +CONFIG_SYS_BRGCLK_PRESCALE +CONFIG_SYS_BRIGHTNESS +CONFIG_SYS_BUSCLK +CONFIG_SYS_CACHELINE_SHIFT +CONFIG_SYS_CACHELINE_SIZE +CONFIG_SYS_CACHE_ACR0 +CONFIG_SYS_CACHE_ACR1 +CONFIG_SYS_CACHE_ACR2 +CONFIG_SYS_CACHE_ACR3 +CONFIG_SYS_CACHE_ACR4 +CONFIG_SYS_CACHE_ACR5 +CONFIG_SYS_CACHE_ACR6 +CONFIG_SYS_CACHE_ACR7 +CONFIG_SYS_CACHE_DCACR +CONFIG_SYS_CACHE_ICACR +CONFIG_SYS_CACHE_SIZE_AUTO +CONFIG_SYS_CACHE_STASHING +CONFIG_SYS_CADMUS_BASE_REG +CONFIG_SYS_CAN_BASE +CONFIG_SYS_CAN_OR_AM +CONFIG_SYS_CAR_ADDR +CONFIG_SYS_CAR_SIZE +CONFIG_SYS_CBSIZE +CONFIG_SYS_CCBPLL +CONFIG_SYS_CCCR +CONFIG_SYS_CCI400_ADDR +CONFIG_SYS_CCSRBAR +CONFIG_SYS_CCSRBAR_DEFAULT +CONFIG_SYS_CCSRBAR_PHYS +CONFIG_SYS_CCSRBAR_PHYS_HIGH +CONFIG_SYS_CCSRBAR_PHYS_LOW +CONFIG_SYS_CCSR_DEFAULT_DBATL +CONFIG_SYS_CCSR_DEFAULT_DBATU +CONFIG_SYS_CCSR_DEFAULT_IBATL +CONFIG_SYS_CCSR_DEFAULT_IBATU +CONFIG_SYS_CCSR_DO_NOT_RELOCATE +CONFIG_SYS_CFI_FLASH_CONFIG_REGS +CONFIG_SYS_CFI_FLASH_STATUS_POLL +CONFIG_SYS_CF_BASE +CONFIG_SYS_CF_INTC_REG1 +CONFIG_SYS_CF_SIZE +CONFIG_SYS_CH7301_I2C +CONFIG_SYS_CKEN +CONFIG_SYS_CLE_MASK +CONFIG_SYS_CLK +CONFIG_SYS_CLKDIV_CPU +CONFIG_SYS_CLKDIV_HSB +CONFIG_SYS_CLKDIV_PBA +CONFIG_SYS_CLKDIV_PBB +CONFIG_SYS_CLKTL_CBCDR +CONFIG_SYS_CLK_DIV +CONFIG_SYS_CLK_FREQ +CONFIG_SYS_CLK_FREQ_C100 +CONFIG_SYS_CLK_FREQ_C110 +CONFIG_SYS_CMD_CONFIGURE +CONFIG_SYS_CMD_EL +CONFIG_SYS_CMD_IAS +CONFIG_SYS_CMD_INT +CONFIG_SYS_CMD_SUSPEND +CONFIG_SYS_CMXFCR_MASK1 +CONFIG_SYS_CMXFCR_MASK2 +CONFIG_SYS_CMXFCR_MASK3 +CONFIG_SYS_CMXFCR_VALUE1 +CONFIG_SYS_CMXFCR_VALUE2 +CONFIG_SYS_CMXFCR_VALUE3 +CONFIG_SYS_CMXSCR_VALUE +CONFIG_SYS_CONFIG_NAME +CONFIG_SYS_CONSOLE_BG_COL +CONFIG_SYS_CONSOLE_ENV_OVERWRITE +CONFIG_SYS_CONSOLE_FG_COL +CONFIG_SYS_CONSOLE_INFO_QUIET +CONFIG_SYS_CONSOLE_IS_IN_ENV +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +CONFIG_SYS_COREBOOT +CONFIG_SYS_COREPLL +CONFIG_SYS_CORE_SRAM +CONFIG_SYS_CORE_SRAM_SIZE +CONFIG_SYS_CORTEX_R4 +CONFIG_SYS_CORTINA_FW_IN_MMC +CONFIG_SYS_CORTINA_FW_IN_NAND +CONFIG_SYS_CORTINA_FW_IN_NOR +CONFIG_SYS_CORTINA_FW_IN_REMOTE +CONFIG_SYS_CORTINA_FW_IN_SPIFLASH +CONFIG_SYS_CPC_REINIT_F +CONFIG_SYS_CPLD +CONFIG_SYS_CPLD_ADDR +CONFIG_SYS_CPLD_AMASK +CONFIG_SYS_CPLD_BASE +CONFIG_SYS_CPLD_BASE_PHYS +CONFIG_SYS_CPLD_CSOR +CONFIG_SYS_CPLD_CSPR +CONFIG_SYS_CPLD_CSPR_EXT +CONFIG_SYS_CPLD_DATA +CONFIG_SYS_CPLD_FTIM0 +CONFIG_SYS_CPLD_FTIM1 +CONFIG_SYS_CPLD_FTIM2 +CONFIG_SYS_CPLD_FTIM3 +CONFIG_SYS_CPLD_SIZE +CONFIG_SYS_CPMFCR_RAMTYPE +CONFIG_SYS_CPM_BOOTCOUNT_ADDR +CONFIG_SYS_CPM_INTERRUPT +CONFIG_SYS_CPM_POST_WORD_ADDR +CONFIG_SYS_CPRI +CONFIG_SYS_CPRI_CLK +CONFIG_SYS_CPU +CONFIG_SYS_CPUBOOT +CONFIG_SYS_CPUSPEED +CONFIG_SYS_CPU_CLK +CONFIG_SYS_CPU_PCI_IO_START +CONFIG_SYS_CPU_PCI_MEMIO_START +CONFIG_SYS_CPU_PCI_MEM_START +CONFIG_SYS_CS0_BASE +CONFIG_SYS_CS0_CFG +CONFIG_SYS_CS0_CTRL +CONFIG_SYS_CS0_FTIM0 +CONFIG_SYS_CS0_FTIM1 +CONFIG_SYS_CS0_FTIM2 +CONFIG_SYS_CS0_FTIM3 +CONFIG_SYS_CS0_MASK +CONFIG_SYS_CS0_SIZE +CONFIG_SYS_CS0_START +CONFIG_SYS_CS1_BASE +CONFIG_SYS_CS1_CFG +CONFIG_SYS_CS1_CTRL +CONFIG_SYS_CS1_FLASH_BASE +CONFIG_SYS_CS1_FTIM0 +CONFIG_SYS_CS1_FTIM1 +CONFIG_SYS_CS1_FTIM2 +CONFIG_SYS_CS1_FTIM3 +CONFIG_SYS_CS1_MASK +CONFIG_SYS_CS1_SIZE +CONFIG_SYS_CS1_START +CONFIG_SYS_CS2_BASE +CONFIG_SYS_CS2_CFG +CONFIG_SYS_CS2_CTRL +CONFIG_SYS_CS2_FLASH_BASE +CONFIG_SYS_CS2_FTIM0 +CONFIG_SYS_CS2_FTIM1 +CONFIG_SYS_CS2_FTIM2 +CONFIG_SYS_CS2_FTIM3 +CONFIG_SYS_CS2_MASK +CONFIG_SYS_CS2_SIZE +CONFIG_SYS_CS2_START +CONFIG_SYS_CS3_BASE +CONFIG_SYS_CS3_CFG +CONFIG_SYS_CS3_CTRL +CONFIG_SYS_CS3_FLASH_BASE +CONFIG_SYS_CS3_FTIM0 +CONFIG_SYS_CS3_FTIM1 +CONFIG_SYS_CS3_FTIM2 +CONFIG_SYS_CS3_FTIM3 +CONFIG_SYS_CS3_MASK +CONFIG_SYS_CS3_SIZE +CONFIG_SYS_CS3_START +CONFIG_SYS_CS4_BASE +CONFIG_SYS_CS4_CFG +CONFIG_SYS_CS4_CTRL +CONFIG_SYS_CS4_FLASH_BASE +CONFIG_SYS_CS4_FTIM0 +CONFIG_SYS_CS4_FTIM1 +CONFIG_SYS_CS4_FTIM2 +CONFIG_SYS_CS4_FTIM3 +CONFIG_SYS_CS4_MASK +CONFIG_SYS_CS4_SIZE +CONFIG_SYS_CS4_START +CONFIG_SYS_CS5_BASE +CONFIG_SYS_CS5_CFG +CONFIG_SYS_CS5_CTRL +CONFIG_SYS_CS5_FLASH_BASE +CONFIG_SYS_CS5_FTIM0 +CONFIG_SYS_CS5_FTIM1 +CONFIG_SYS_CS5_FTIM2 +CONFIG_SYS_CS5_FTIM3 +CONFIG_SYS_CS5_MASK +CONFIG_SYS_CS5_SIZE +CONFIG_SYS_CS5_START +CONFIG_SYS_CS6_BASE +CONFIG_SYS_CS6_CFG +CONFIG_SYS_CS6_CTRL +CONFIG_SYS_CS6_FTIM0 +CONFIG_SYS_CS6_FTIM1 +CONFIG_SYS_CS6_FTIM2 +CONFIG_SYS_CS6_FTIM3 +CONFIG_SYS_CS6_MASK +CONFIG_SYS_CS6_SIZE +CONFIG_SYS_CS6_START +CONFIG_SYS_CS7_BASE +CONFIG_SYS_CS7_CFG +CONFIG_SYS_CS7_CTRL +CONFIG_SYS_CS7_FTIM0 +CONFIG_SYS_CS7_FTIM1 +CONFIG_SYS_CS7_FTIM2 +CONFIG_SYS_CS7_FTIM3 +CONFIG_SYS_CS7_MASK +CONFIG_SYS_CS7_SIZE +CONFIG_SYS_CS7_START +CONFIG_SYS_CSOR0 +CONFIG_SYS_CSOR0_EXT +CONFIG_SYS_CSOR1 +CONFIG_SYS_CSOR1_EXT +CONFIG_SYS_CSOR2 +CONFIG_SYS_CSOR2_EXT +CONFIG_SYS_CSOR3 +CONFIG_SYS_CSOR3_EXT +CONFIG_SYS_CSOR4 +CONFIG_SYS_CSOR4_EXT +CONFIG_SYS_CSOR5 +CONFIG_SYS_CSOR5_EXT +CONFIG_SYS_CSOR6 +CONFIG_SYS_CSOR6_EXT +CONFIG_SYS_CSOR7 +CONFIG_SYS_CSOR7_EXT +CONFIG_SYS_CSPR0 +CONFIG_SYS_CSPR0_EXT +CONFIG_SYS_CSPR0_FINAL +CONFIG_SYS_CSPR1 +CONFIG_SYS_CSPR1_EXT +CONFIG_SYS_CSPR1_FINAL +CONFIG_SYS_CSPR2 +CONFIG_SYS_CSPR2_EXT +CONFIG_SYS_CSPR2_FINAL +CONFIG_SYS_CSPR3 +CONFIG_SYS_CSPR3_EXT +CONFIG_SYS_CSPR3_FINAL +CONFIG_SYS_CSPR4 +CONFIG_SYS_CSPR4_EXT +CONFIG_SYS_CSPR5 +CONFIG_SYS_CSPR5_EXT +CONFIG_SYS_CSPR6 +CONFIG_SYS_CSPR6_EXT +CONFIG_SYS_CSPR7 +CONFIG_SYS_CSPR7_EXT +CONFIG_SYS_CS_ALETIMING +CONFIG_SYS_CS_BURST +CONFIG_SYS_CS_DEADCYCLE +CONFIG_SYS_CS_HOLDCYCLE +CONFIG_SYS_DA850_CS2CFG +CONFIG_SYS_DA850_CS3CFG +CONFIG_SYS_DA850_DDR2_DDRPHYCR +CONFIG_SYS_DA850_DDR2_PBBPR +CONFIG_SYS_DA850_DDR2_SDBCR +CONFIG_SYS_DA850_DDR2_SDBCR2 +CONFIG_SYS_DA850_DDR2_SDRCR +CONFIG_SYS_DA850_DDR2_SDTIMR +CONFIG_SYS_DA850_DDR2_SDTIMR2 +CONFIG_SYS_DA850_DDR_INIT +CONFIG_SYS_DA850_PLL0_PLLDIV1 +CONFIG_SYS_DA850_PLL0_PLLDIV2 +CONFIG_SYS_DA850_PLL0_PLLDIV3 +CONFIG_SYS_DA850_PLL0_PLLDIV4 +CONFIG_SYS_DA850_PLL0_PLLDIV5 +CONFIG_SYS_DA850_PLL0_PLLDIV6 +CONFIG_SYS_DA850_PLL0_PLLDIV7 +CONFIG_SYS_DA850_PLL0_PLLM +CONFIG_SYS_DA850_PLL0_POSTDIV +CONFIG_SYS_DA850_PLL0_PREDIV +CONFIG_SYS_DA850_PLL1_PLLDIV1 +CONFIG_SYS_DA850_PLL1_PLLDIV2 +CONFIG_SYS_DA850_PLL1_PLLDIV3 +CONFIG_SYS_DA850_PLL1_PLLM +CONFIG_SYS_DA850_PLL1_POSTDIV +CONFIG_SYS_DA850_PLL_INIT +CONFIG_SYS_DA850_SYSCFG_SUSPSRC +CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 +CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 +CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS2 +CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 +CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT +CONFIG_SYS_DAVINCI_I2C_SLAVE +CONFIG_SYS_DAVINCI_I2C_SLAVE1 +CONFIG_SYS_DAVINCI_I2C_SLAVE2 +CONFIG_SYS_DAVINCI_I2C_SPEED +CONFIG_SYS_DAVINCI_I2C_SPEED1 +CONFIG_SYS_DAVINCI_I2C_SPEED2 +CONFIG_SYS_DBAT +CONFIG_SYS_DBAT0L +CONFIG_SYS_DBAT0U +CONFIG_SYS_DBAT1L +CONFIG_SYS_DBAT1U +CONFIG_SYS_DBAT2L +CONFIG_SYS_DBAT2U +CONFIG_SYS_DBAT3L +CONFIG_SYS_DBAT3U +CONFIG_SYS_DBAT4L +CONFIG_SYS_DBAT4U +CONFIG_SYS_DBAT5L +CONFIG_SYS_DBAT5U +CONFIG_SYS_DBAT6L +CONFIG_SYS_DBAT6L_EARLY +CONFIG_SYS_DBAT6U +CONFIG_SYS_DBAT6U_EARLY +CONFIG_SYS_DBAT7L +CONFIG_SYS_DBAT7U +CONFIG_SYS_DCACHE_INV +CONFIG_SYS_DCACHE_LINESZ +CONFIG_SYS_DCACHE_LINE_SIZE +CONFIG_SYS_DCACHE_OFF +CONFIG_SYS_DCACHE_SACR_VALUE +CONFIG_SYS_DCACHE_SIZE +CONFIG_SYS_DCSRBAR +CONFIG_SYS_DCSRBAR_PHYS +CONFIG_SYS_DCSR_COP_CCP_ADDR +CONFIG_SYS_DCSR_DCFG_ADDR +CONFIG_SYS_DCSR_DCFG_OFFSET +CONFIG_SYS_DCU_ADDR +CONFIG_SYS_DDR1_CS0_BNDS +CONFIG_SYS_DDR2_CFG_1A +CONFIG_SYS_DDR2_CFG_1B +CONFIG_SYS_DDR2_CFG_2 +CONFIG_SYS_DDR2_CLK_CTRL +CONFIG_SYS_DDR2_CS0_BNDS +CONFIG_SYS_DDR2_CS0_CONFIG +CONFIG_SYS_DDR2_CS1_BNDS +CONFIG_SYS_DDR2_CS1_CONFIG +CONFIG_SYS_DDR2_CS2_BNDS +CONFIG_SYS_DDR2_CS2_CONFIG +CONFIG_SYS_DDR2_CS3_BNDS +CONFIG_SYS_DDR2_CS3_CONFIG +CONFIG_SYS_DDR2_DATA_INIT +CONFIG_SYS_DDR2_EXT_REFRESH +CONFIG_SYS_DDR2_INTERVAL +CONFIG_SYS_DDR2_MODE_1 +CONFIG_SYS_DDR2_MODE_2 +CONFIG_SYS_DDR2_MODE_CTL +CONFIG_SYS_DDR2_TIMING_0 +CONFIG_SYS_DDR2_TIMING_1 +CONFIG_SYS_DDR2_TIMING_2 +CONFIG_SYS_DDRCDR +CONFIG_SYS_DDRCDR_VALUE +CONFIG_SYS_DDRCMD_EM2 +CONFIG_SYS_DDRCMD_EM3 +CONFIG_SYS_DDRCMD_EN_DLL +CONFIG_SYS_DDRCMD_NOP +CONFIG_SYS_DDRCMD_OCD_DEFAULT +CONFIG_SYS_DDRCMD_OCD_EXIT +CONFIG_SYS_DDRCMD_PCHG_ALL +CONFIG_SYS_DDRCMD_RES_DLL +CONFIG_SYS_DDRCMD_RFSH +CONFIG_SYS_DDRD +CONFIG_SYS_DDRDEBUG +CONFIG_SYS_DDRTC +CONFIG_SYS_DDRUA +CONFIG_SYS_DDR_BASE +CONFIG_SYS_DDR_BLOCK1_SIZE +CONFIG_SYS_DDR_BLOCK2_BASE +CONFIG_SYS_DDR_CACHED_ADDR +CONFIG_SYS_DDR_CDR_1 +CONFIG_SYS_DDR_CDR_2 +CONFIG_SYS_DDR_CFG_1A +CONFIG_SYS_DDR_CFG_1B +CONFIG_SYS_DDR_CFG_2 +CONFIG_SYS_DDR_CLKSEL +CONFIG_SYS_DDR_CLK_CNTL +CONFIG_SYS_DDR_CLK_CONTROL +CONFIG_SYS_DDR_CLK_CTRL +CONFIG_SYS_DDR_CLK_CTRL_1000 +CONFIG_SYS_DDR_CLK_CTRL_1200 +CONFIG_SYS_DDR_CLK_CTRL_1333 +CONFIG_SYS_DDR_CLK_CTRL_667 +CONFIG_SYS_DDR_CLK_CTRL_800 +CONFIG_SYS_DDR_CLK_CTRL_900 +CONFIG_SYS_DDR_CONFIG +CONFIG_SYS_DDR_CONFIG_2 +CONFIG_SYS_DDR_CONFIG_256 +CONFIG_SYS_DDR_CONTROL +CONFIG_SYS_DDR_CONTROL2 +CONFIG_SYS_DDR_CONTROL_1333 +CONFIG_SYS_DDR_CONTROL_2 +CONFIG_SYS_DDR_CONTROL_2_1333 +CONFIG_SYS_DDR_CONTROL_2_800 +CONFIG_SYS_DDR_CONTROL_800 +CONFIG_SYS_DDR_CPO +CONFIG_SYS_DDR_CS0_BNDS +CONFIG_SYS_DDR_CS0_CONFIG +CONFIG_SYS_DDR_CS0_CONFIG_1333 +CONFIG_SYS_DDR_CS0_CONFIG_2 +CONFIG_SYS_DDR_CS0_CONFIG_800 +CONFIG_SYS_DDR_CS1_BNDS +CONFIG_SYS_DDR_CS1_CONFIG +CONFIG_SYS_DDR_CS1_CONFIG_2 +CONFIG_SYS_DDR_CS2_BNDS +CONFIG_SYS_DDR_CS2_CONFIG +CONFIG_SYS_DDR_CS3_BNDS +CONFIG_SYS_DDR_CS3_CONFIG +CONFIG_SYS_DDR_DATA_INIT +CONFIG_SYS_DDR_ERR_DIS +CONFIG_SYS_DDR_ERR_INT_EN +CONFIG_SYS_DDR_INIT_ADDR +CONFIG_SYS_DDR_INIT_EXT_ADDR +CONFIG_SYS_DDR_INTERVAL +CONFIG_SYS_DDR_INTERVAL_1000 +CONFIG_SYS_DDR_INTERVAL_1200 +CONFIG_SYS_DDR_INTERVAL_1333 +CONFIG_SYS_DDR_INTERVAL_667 +CONFIG_SYS_DDR_INTERVAL_800 +CONFIG_SYS_DDR_INTERVAL_900 +CONFIG_SYS_DDR_MODE +CONFIG_SYS_DDR_MODE2 +CONFIG_SYS_DDR_MODE_1 +CONFIG_SYS_DDR_MODE_1_1000 +CONFIG_SYS_DDR_MODE_1_1200 +CONFIG_SYS_DDR_MODE_1_1333 +CONFIG_SYS_DDR_MODE_1_667 +CONFIG_SYS_DDR_MODE_1_800 +CONFIG_SYS_DDR_MODE_1_900 +CONFIG_SYS_DDR_MODE_2 +CONFIG_SYS_DDR_MODE_2_1000 +CONFIG_SYS_DDR_MODE_2_1200 +CONFIG_SYS_DDR_MODE_2_1333 +CONFIG_SYS_DDR_MODE_2_667 +CONFIG_SYS_DDR_MODE_2_800 +CONFIG_SYS_DDR_MODE_2_900 +CONFIG_SYS_DDR_MODE_CONTROL +CONFIG_SYS_DDR_MODE_CTL +CONFIG_SYS_DDR_MODE_WEAK +CONFIG_SYS_DDR_OCD_CTRL +CONFIG_SYS_DDR_OCD_STATUS +CONFIG_SYS_DDR_RAW_TIMING +CONFIG_SYS_DDR_RCW_1 +CONFIG_SYS_DDR_RCW_2 +CONFIG_SYS_DDR_SBE +CONFIG_SYS_DDR_SDRAM_BASE +CONFIG_SYS_DDR_SDRAM_BASE2 +CONFIG_SYS_DDR_SDRAM_CFG +CONFIG_SYS_DDR_SDRAM_CFG2 +CONFIG_SYS_DDR_SDRAM_CFG_2 +CONFIG_SYS_DDR_SDRAM_CLK_CNTL +CONFIG_SYS_DDR_SDRAM_INTERVAL +CONFIG_SYS_DDR_SDRAM_MODE +CONFIG_SYS_DDR_SDRAM_MODE_2 +CONFIG_SYS_DDR_SIZE +CONFIG_SYS_DDR_SR_CNTR +CONFIG_SYS_DDR_TIMING_0 +CONFIG_SYS_DDR_TIMING_0_1000 +CONFIG_SYS_DDR_TIMING_0_1200 +CONFIG_SYS_DDR_TIMING_0_1333 +CONFIG_SYS_DDR_TIMING_0_667 +CONFIG_SYS_DDR_TIMING_0_800 +CONFIG_SYS_DDR_TIMING_0_900 +CONFIG_SYS_DDR_TIMING_1 +CONFIG_SYS_DDR_TIMING_1_1000 +CONFIG_SYS_DDR_TIMING_1_1200 +CONFIG_SYS_DDR_TIMING_1_1333 +CONFIG_SYS_DDR_TIMING_1_667 +CONFIG_SYS_DDR_TIMING_1_800 +CONFIG_SYS_DDR_TIMING_1_900 +CONFIG_SYS_DDR_TIMING_2 +CONFIG_SYS_DDR_TIMING_2_1000 +CONFIG_SYS_DDR_TIMING_2_1200 +CONFIG_SYS_DDR_TIMING_2_1333 +CONFIG_SYS_DDR_TIMING_2_667 +CONFIG_SYS_DDR_TIMING_2_800 +CONFIG_SYS_DDR_TIMING_2_900 +CONFIG_SYS_DDR_TIMING_3 +CONFIG_SYS_DDR_TIMING_3_1000 +CONFIG_SYS_DDR_TIMING_3_1200 +CONFIG_SYS_DDR_TIMING_3_1333 +CONFIG_SYS_DDR_TIMING_3_667 +CONFIG_SYS_DDR_TIMING_3_800 +CONFIG_SYS_DDR_TIMING_3_900 +CONFIG_SYS_DDR_TIMING_4 +CONFIG_SYS_DDR_TIMING_4_1333 +CONFIG_SYS_DDR_TIMING_4_800 +CONFIG_SYS_DDR_TIMING_5 +CONFIG_SYS_DDR_TIMING_5_1333 +CONFIG_SYS_DDR_TIMING_5_800 +CONFIG_SYS_DDR_WRITE_DATA_DELAY +CONFIG_SYS_DDR_WRLVL_CNTL +CONFIG_SYS_DDR_WRLVL_CONTROL +CONFIG_SYS_DDR_WRLVL_CONTROL_1333 +CONFIG_SYS_DDR_WRLVL_CONTROL_667 +CONFIG_SYS_DDR_WRLVL_CONTROL_800 +CONFIG_SYS_DDR_ZQ_CNTL +CONFIG_SYS_DDR_ZQ_CONTROL +CONFIG_SYS_DEBUG +CONFIG_SYS_DEBUG_SERVER_DRAM_BLOCK_MIN_SIZE +CONFIG_SYS_DEBUG_SERVER_FW_ADDR +CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR +CONFIG_SYS_DEBUG_SERVER_TIMEOUT +CONFIG_SYS_DECREMENT_PATTERNS +CONFIG_SYS_DEFAULT_IMMR +CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +CONFIG_SYS_DEFAULT_MBAR +CONFIG_SYS_DEFAULT_VIDEO_MODE +CONFIG_SYS_DEF_EEPROM_ADDR +CONFIG_SYS_DELAYED_ICACHE +CONFIG_SYS_DER +CONFIG_SYS_DEVICE_NULLDEV +CONFIG_SYS_DFU_DATA_BUF_SIZE +CONFIG_SYS_DFU_MAX_FILE_SIZE +CONFIG_SYS_DIAG_ADDR +CONFIG_SYS_DIALOG_PMIC_I2C_ADDR +CONFIG_SYS_DIMM_SLOTS_PER_CTLR +CONFIG_SYS_DIRECT_FLASH_NFS +CONFIG_SYS_DIRECT_FLASH_TFTP +CONFIG_SYS_DISCOVER_PHY +CONFIG_SYS_DISPLAY_BASE +CONFIG_SYS_DISP_CHR_RAM +CONFIG_SYS_DIU_ADDR +CONFIG_SYS_DM36 +CONFIG_SYS_DMA_USE_INTSRAM +CONFIG_SYS_DOC_SHORT_TIMEOUT +CONFIG_SYS_DOC_SUPPORT_2000 +CONFIG_SYS_DOC_SUPPORT_MILLENNIUM +CONFIG_SYS_DP501_BASE +CONFIG_SYS_DP501_DIFFERENTIAL +CONFIG_SYS_DP501_I2C +CONFIG_SYS_DP501_VCAPCTRL0 +CONFIG_SYS_DPAA_DCE +CONFIG_SYS_DPAA_FMAN +CONFIG_SYS_DPAA_PME +CONFIG_SYS_DPAA_QBMAN +CONFIG_SYS_DPAA_RMAN +CONFIG_SYS_DP_DDR_BASE +CONFIG_SYS_DP_DDR_BASE_PHY +CONFIG_SYS_DRAMSZ +CONFIG_SYS_DRAMSZ1 +CONFIG_SYS_DRAM_BASE +CONFIG_SYS_DRAM_SIZE +CONFIG_SYS_DRAM_TEST +CONFIG_SYS_DS1339_TCR_VAL +CONFIG_SYS_DS1388_TCR_VAL +CONFIG_SYS_DSPIC_TEST_ADDR +CONFIG_SYS_DSPIC_TEST_MASK +CONFIG_SYS_DSPI_CS0 +CONFIG_SYS_DSPI_CS2 +CONFIG_SYS_DSPI_CTAR0 +CONFIG_SYS_DSPI_CTAR1 +CONFIG_SYS_DSPI_CTAR2 +CONFIG_SYS_DSPI_CTAR3 +CONFIG_SYS_DSPI_CTAR4 +CONFIG_SYS_DSPI_CTAR5 +CONFIG_SYS_DSPI_CTAR6 +CONFIG_SYS_DSPI_CTAR7 +CONFIG_SYS_DTT_ADM1021 +CONFIG_SYS_DTT_BUS_NUM +CONFIG_SYS_DTT_HYSTERESIS +CONFIG_SYS_DTT_LOW_TEMP +CONFIG_SYS_DTT_MAX_TEMP +CONFIG_SYS_DTT_MIN_TEMP +CONFIG_SYS_DUART_RST +CONFIG_SYS_DV_CLKMODE +CONFIG_SYS_DV_NOR_BOOT_CFG +CONFIG_SYS_EBC_CFG +CONFIG_SYS_EBC_PB0AP +CONFIG_SYS_EBC_PB0CR +CONFIG_SYS_EBC_PB1AP +CONFIG_SYS_EBC_PB1CR +CONFIG_SYS_EBC_PB2AP +CONFIG_SYS_EBC_PB2CR +CONFIG_SYS_EBC_PB3AP +CONFIG_SYS_EBC_PB3CR +CONFIG_SYS_EBC_PB4AP +CONFIG_SYS_EBC_PB4CR +CONFIG_SYS_EBC_PB5AP +CONFIG_SYS_EBC_PB5CR +CONFIG_SYS_EBC_PB6AP +CONFIG_SYS_EBC_PB6CR +CONFIG_SYS_EBC_PB7AP +CONFIG_SYS_EBC_PB7CR +CONFIG_SYS_EBI_CFGR_VAL +CONFIG_SYS_EBI_CSA_VAL +CONFIG_SYS_EEPROM_BASE +CONFIG_SYS_EEPROM_BUS_NUM +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS +CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE +CONFIG_SYS_EEPROM_SIZE +CONFIG_SYS_EEPROM_WP +CONFIG_SYS_EEPROM_WREN +CONFIG_SYS_EHCI_USB1_ADDR +CONFIG_SYS_ELBC_BASE +CONFIG_SYS_ELBC_BASE_PHYS +CONFIG_SYS_ELO3_DMA3 +CONFIG_SYS_ELPIDA_INIT_DEV_OP +CONFIG_SYS_ELPIDA_OCD_EXIT +CONFIG_SYS_ELPIDA_RES_DLL +CONFIG_SYS_EMAC_TI_CLKDIV +CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +CONFIG_SYS_ENABLE_PADS_ALL +CONFIG_SYS_ENET_BD_BASE +CONFIG_SYS_ENV_ADDR +CONFIG_SYS_ENV_OFFSET +CONFIG_SYS_ENV_SECT_SIZE +CONFIG_SYS_EPLD_BASE +CONFIG_SYS_ETHOC_BASE +CONFIG_SYS_ETHOC_BUFFER_ADDR +CONFIG_SYS_ETH_IOBASE +CONFIG_SYS_ETVPE_CLK +CONFIG_SYS_EXCEPTION_VECTORS_HIGH +CONFIG_SYS_EXTBDINFO +CONFIG_SYS_EXTRA_ENV_RELOC +CONFIG_SYS_EXTRA_OPTIONS +CONFIG_SYS_EXT_SERIAL_CLOCK +CONFIG_SYS_FAST_CLK +CONFIG_SYS_FAULT_ECCONFIG_SYS_NO_FLASHHO_LINK_DOWN +CONFIG_SYS_FAULT_ECHO_LINK_DOWN +CONFIG_SYS_FAULT_MII_ADDR +CONFIG_SYS_FCC_PSMR +CONFIG_SYS_FCPU133MHZ +CONFIG_SYS_FCPU266MHZ +CONFIG_SYS_FCPU333MHZ +CONFIG_SYS_FDC_DRIVE_NUMBER +CONFIG_SYS_FDC_HW_INIT +CONFIG_SYS_FDT_ADDR +CONFIG_SYS_FDT_BASE +CONFIG_SYS_FDT_LOAD_ADDR +CONFIG_SYS_FDT_PAD +CONFIG_SYS_FDT_SIZE +CONFIG_SYS_FEC0_IOBASE +CONFIG_SYS_FEC0_MIIBASE +CONFIG_SYS_FEC0_PHYADDR +CONFIG_SYS_FEC0_PINMUX +CONFIG_SYS_FEC1_IOBASE +CONFIG_SYS_FEC1_MIIBASE +CONFIG_SYS_FEC1_PHYADDR +CONFIG_SYS_FEC1_PINMUX +CONFIG_SYS_FECI2C +CONFIG_SYS_FEC_BUF_USE_SRAM +CONFIG_SYS_FEC_FULL_MII +CONFIG_SYS_FEC_NO_SHARED_PHY +CONFIG_SYS_FIFO_BASE +CONFIG_SYS_FIXED_PHY_ADDR +CONFIG_SYS_FIXED_PHY_PORT +CONFIG_SYS_FIXED_PHY_PORTS +CONFIG_SYS_FLASH +CONFIG_SYS_FLASH0 +CONFIG_SYS_FLASH0_BASE +CONFIG_SYS_FLASH1 +CONFIG_SYS_FLASH1_BASE +CONFIG_SYS_FLASH1_BASE_PHYS +CONFIG_SYS_FLASH1_BASE_PHYS_EARLY +CONFIG_SYS_FLASH2_BASE +CONFIG_SYS_FLASHBANK +CONFIG_SYS_FLASHBOOT +CONFIG_SYS_FLASHMAP +CONFIG_SYS_FLASHWP +CONFIG_SYS_FLASH_2ND_16BIT_DEV +CONFIG_SYS_FLASH_2ND_ADDR +CONFIG_SYS_FLASH_ADDR0 +CONFIG_SYS_FLASH_ADDR1 +CONFIG_SYS_FLASH_ADDR_BASE +CONFIG_SYS_FLASH_AMD_CHECK_DQ7 +CONFIG_SYS_FLASH_AUTOPROTECT_LIST +CONFIG_SYS_FLASH_BANKS_LIST +CONFIG_SYS_FLASH_BANKS_SIZES +CONFIG_SYS_FLASH_BANK_SIZE +CONFIG_SYS_FLASH_BASE +CONFIG_SYS_FLASH_BASE0 +CONFIG_SYS_FLASH_BASE1 +CONFIG_SYS_FLASH_BASE2 +CONFIG_SYS_FLASH_BASE_1 +CONFIG_SYS_FLASH_BASE_2 +CONFIG_SYS_FLASH_BASE_CS1 +CONFIG_SYS_FLASH_BASE_PHYS +CONFIG_SYS_FLASH_BASE_PHYS_EARLY +CONFIG_SYS_FLASH_BASE_PHYS_H +CONFIG_SYS_FLASH_BASE_PHYS_L +CONFIG_SYS_FLASH_BASE_PHYS_LOW +CONFIG_SYS_FLASH_BR_PRELIM +CONFIG_SYS_FLASH_CFI +CONFIG_SYS_FLASH_CFI_AMD_RESET +CONFIG_SYS_FLASH_CFI_BROKEN_TABLE +CONFIG_SYS_FLASH_CFI_BYPASS_READ +CONFIG_SYS_FLASH_CFI_NONBLOCK +CONFIG_SYS_FLASH_CFI_WIDTH +CONFIG_SYS_FLASH_CHECKSUM +CONFIG_SYS_FLASH_CHECK_BLANK_BEFORE_ERASE +CONFIG_SYS_FLASH_EMPTY_INFO +CONFIG_SYS_FLASH_ERASE_TOUT +CONFIG_SYS_FLASH_LEGACY_256K +CONFIG_SYS_FLASH_LEGACY_512K +CONFIG_SYS_FLASH_LOCK_TOUT +CONFIG_SYS_FLASH_OR_PRELIM +CONFIG_SYS_FLASH_PARMSECT_SZ +CONFIG_SYS_FLASH_PROTECTION +CONFIG_SYS_FLASH_QUIET_TEST +CONFIG_SYS_FLASH_READ0 +CONFIG_SYS_FLASH_READ1 +CONFIG_SYS_FLASH_READ2 +CONFIG_SYS_FLASH_SECT_SIZE +CONFIG_SYS_FLASH_SECT_SZ +CONFIG_SYS_FLASH_SIZE +CONFIG_SYS_FLASH_SIZE_1 +CONFIG_SYS_FLASH_SIZE_2 +CONFIG_SYS_FLASH_UNLOCK_TOUT +CONFIG_SYS_FLASH_USE_BUFFER_WRITE +CONFIG_SYS_FLASH_VERIFY_AFTER_WRITE +CONFIG_SYS_FLASH_WORD_SIZE +CONFIG_SYS_FLASH_WRITE_TOUT +CONFIG_SYS_FLYCNFG_VAL +CONFIG_SYS_FM1_10GEC1_PHY_ADDR +CONFIG_SYS_FM1_10GEC2_PHY_ADDR +CONFIG_SYS_FM1_CLK +CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR +CONFIG_SYS_FM1_DTSEC1_PHY_ADDR +CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR +CONFIG_SYS_FM1_DTSEC2_PHY_ADDR +CONFIG_SYS_FM1_DTSEC2_RISER_PHY_ADDR +CONFIG_SYS_FM1_DTSEC3_PHY_ADDR +CONFIG_SYS_FM1_DTSEC3_RISER_PHY_ADDR +CONFIG_SYS_FM1_DTSEC4_PHY_ADDR +CONFIG_SYS_FM1_DTSEC4_RISER_PHY_ADDR +CONFIG_SYS_FM1_DTSEC5_PHY_ADDR +CONFIG_SYS_FM1_DTSEC_MDIO_ADDR +CONFIG_SYS_FM1_ONBOARD_PHY1_ADDR +CONFIG_SYS_FM1_ONBOARD_PHY2_ADDR +CONFIG_SYS_FM1_QSGMII11_PHY_ADDR +CONFIG_SYS_FM1_QSGMII21_PHY_ADDR +CONFIG_SYS_FM1_TGEC_MDIO_ADDR +CONFIG_SYS_FM2_10GEC1_PHY_ADDR +CONFIG_SYS_FM2_CLK +CONFIG_SYS_FM2_DTSEC1_PHY_ADDR +CONFIG_SYS_FM2_DTSEC2_PHY_ADDR +CONFIG_SYS_FM2_DTSEC3_PHY_ADDR +CONFIG_SYS_FM2_DTSEC4_PHY_ADDR +CONFIG_SYS_FM2_DTSEC_MDIO_ADDR +CONFIG_SYS_FM2_TGEC_MDIO_ADDR +CONFIG_SYS_FMAN_FW_ADDR +CONFIG_SYS_FMAN_V3 +CONFIG_SYS_FM_MURAM_SIZE +CONFIG_SYS_FORM_3U_CPCI +CONFIG_SYS_FORM_3U_VPX +CONFIG_SYS_FORM_6U_CPCI +CONFIG_SYS_FORM_6U_VPX +CONFIG_SYS_FORM_AMC +CONFIG_SYS_FORM_ATCA_AMC +CONFIG_SYS_FORM_ATCA_PMC +CONFIG_SYS_FORM_CUSTOM +CONFIG_SYS_FORM_PCI +CONFIG_SYS_FORM_PCI_EXPRESS +CONFIG_SYS_FORM_PMC +CONFIG_SYS_FORM_PMC_XMC +CONFIG_SYS_FORM_VME +CONFIG_SYS_FORM_XMC +CONFIG_SYS_FPGA0_BASE +CONFIG_SYS_FPGA0_SIZE +CONFIG_SYS_FPGA1_BASE +CONFIG_SYS_FPGA2_BASE +CONFIG_SYS_FPGA3_BASE +CONFIG_SYS_FPGAREG_DATE +CONFIG_SYS_FPGAREG_DIPSW +CONFIG_SYS_FPGAREG_FREQ +CONFIG_SYS_FPGAREG_RESET +CONFIG_SYS_FPGAREG_RESET_CODE +CONFIG_SYS_FPGA_ +CONFIG_SYS_FPGA_AMASK +CONFIG_SYS_FPGA_BASE +CONFIG_SYS_FPGA_BASE0 +CONFIG_SYS_FPGA_BASE1 +CONFIG_SYS_FPGA_BASE_0 +CONFIG_SYS_FPGA_BASE_1 +CONFIG_SYS_FPGA_BASE_ADDR +CONFIG_SYS_FPGA_BASE_PHYS +CONFIG_SYS_FPGA_CHECK_BUSY +CONFIG_SYS_FPGA_CHECK_CTRLC +CONFIG_SYS_FPGA_CHECK_ERROR +CONFIG_SYS_FPGA_CHIPSIDE_LOOPBACK +CONFIG_SYS_FPGA_CLK +CONFIG_SYS_FPGA_COMMON +CONFIG_SYS_FPGA_COUNT +CONFIG_SYS_FPGA_CSOR +CONFIG_SYS_FPGA_CSPR +CONFIG_SYS_FPGA_CSPR_EXT +CONFIG_SYS_FPGA_CTRL +CONFIG_SYS_FPGA_CTRL_CF_RESET +CONFIG_SYS_FPGA_CTRL_PS2_RESET +CONFIG_SYS_FPGA_CTRL_WDI +CONFIG_SYS_FPGA_DATA +CONFIG_SYS_FPGA_DONE +CONFIG_SYS_FPGA_DPRAM_RST +CONFIG_SYS_FPGA_DPRAM_RW_TYPE +CONFIG_SYS_FPGA_DPRAM_R_INT_LINE +CONFIG_SYS_FPGA_DPRAM_W_INT_LINE +CONFIG_SYS_FPGA_FIFO_BASE +CONFIG_SYS_FPGA_FTIM0 +CONFIG_SYS_FPGA_FTIM1 +CONFIG_SYS_FPGA_FTIM2 +CONFIG_SYS_FPGA_FTIM3 +CONFIG_SYS_FPGA_INIT +CONFIG_SYS_FPGA_IS_PROTO +CONFIG_SYS_FPGA_LINESIDE_LOOPBACK +CONFIG_SYS_FPGA_MAGIC +CONFIG_SYS_FPGA_MAGIC_MASK +CONFIG_SYS_FPGA_MAX_SIZE +CONFIG_SYS_FPGA_MODE +CONFIG_SYS_FPGA_MODE_CF_RESET +CONFIG_SYS_FPGA_MODE_DUART_RESET +CONFIG_SYS_FPGA_MODE_ENABLE_OUTPUT +CONFIG_SYS_FPGA_MODE_TS_CLEAR +CONFIG_SYS_FPGA_MODE_TS_IRQ_CLEAR +CONFIG_SYS_FPGA_MODE_TS_IRQ_ENABLE +CONFIG_SYS_FPGA_NO_RFL_HI +CONFIG_SYS_FPGA_PHY0_INT +CONFIG_SYS_FPGA_PHY1_INT +CONFIG_SYS_FPGA_PRG +CONFIG_SYS_FPGA_PROG +CONFIG_SYS_FPGA_PROG_FEEDBACK +CONFIG_SYS_FPGA_PROG_TIME +CONFIG_SYS_FPGA_PTR +CONFIG_SYS_FPGA_REG_BASE +CONFIG_SYS_FPGA_REG_BASE_ADDR +CONFIG_SYS_FPGA_SIZE +CONFIG_SYS_FPGA_SLIC0_CS +CONFIG_SYS_FPGA_SLIC0_ENABLE +CONFIG_SYS_FPGA_SLIC0_INT +CONFIG_SYS_FPGA_SLIC0_R_DPRAM_INT +CONFIG_SYS_FPGA_SLIC0_W_DPRAM_INT +CONFIG_SYS_FPGA_SLIC1_CS +CONFIG_SYS_FPGA_SLIC1_ENABLE +CONFIG_SYS_FPGA_SLIC1_INT +CONFIG_SYS_FPGA_SLIC1_R_DPRAM_INT +CONFIG_SYS_FPGA_SLIC1_W_DPRAM_INT +CONFIG_SYS_FPGA_SPARTAN2 +CONFIG_SYS_FPGA_STATUS +CONFIG_SYS_FPGA_STATUS_DIP0 +CONFIG_SYS_FPGA_STATUS_DIP1 +CONFIG_SYS_FPGA_STATUS_DIP2 +CONFIG_SYS_FPGA_STATUS_FLASH +CONFIG_SYS_FPGA_STATUS_TS_IRQ +CONFIG_SYS_FPGA_TS +CONFIG_SYS_FPGA_TS_CAP0 +CONFIG_SYS_FPGA_TS_CAP0_LOW +CONFIG_SYS_FPGA_TS_CAP1 +CONFIG_SYS_FPGA_TS_CAP1_LOW +CONFIG_SYS_FPGA_TS_CAP2 +CONFIG_SYS_FPGA_TS_CAP2_LOW +CONFIG_SYS_FPGA_TS_CAP3 +CONFIG_SYS_FPGA_TS_CAP3_LOW +CONFIG_SYS_FPGA_TS_LOW +CONFIG_SYS_FPGA_UART0_FO +CONFIG_SYS_FPGA_UART1_FO +CONFIG_SYS_FPGA_USER_LED0 +CONFIG_SYS_FPGA_USER_LED1 +CONFIG_SYS_FPGA_VER_MASK +CONFIG_SYS_FPGA_WAIT +CONFIG_SYS_FPGA_WAIT_BUSY +CONFIG_SYS_FPGA_WAIT_CONFIG +CONFIG_SYS_FPGA_WAIT_INIT +CONFIG_SYS_FSL_A004447_SVR_REV +CONFIG_SYS_FSL_AIOP1_BASE +CONFIG_SYS_FSL_AIOP1_SIZE +CONFIG_SYS_FSL_B4860QDS_XFI_ERR +CONFIG_SYS_FSL_BMAN_ADDR +CONFIG_SYS_FSL_BMAN_OFFSET +CONFIG_SYS_FSL_BOOTROM_BASE +CONFIG_SYS_FSL_BOOTROM_SIZE +CONFIG_SYS_FSL_CCSR_BASE +CONFIG_SYS_FSL_CCSR_GUR_BE +CONFIG_SYS_FSL_CCSR_GUR_LE +CONFIG_SYS_FSL_CCSR_SCFG_BE +CONFIG_SYS_FSL_CCSR_SCFG_LE +CONFIG_SYS_FSL_CCSR_SIZE +CONFIG_SYS_FSL_CH3_CLK_CTRL_ADDR +CONFIG_SYS_FSL_CH3_CLK_GRPA_ADDR +CONFIG_SYS_FSL_CH3_CLK_GRPB_ADDR +CONFIG_SYS_FSL_CLK +CONFIG_SYS_FSL_CLK_ADDR +CONFIG_SYS_FSL_CLUSTER_1_L2 +CONFIG_SYS_FSL_CLUSTER_1_L2_OFFSET +CONFIG_SYS_FSL_CLUSTER_CLOCKS +CONFIG_SYS_FSL_CORENET_CCM_ADDR +CONFIG_SYS_FSL_CORENET_CCM_OFFSET +CONFIG_SYS_FSL_CORENET_CLK_ADDR +CONFIG_SYS_FSL_CORENET_CLK_OFFSET +CONFIG_SYS_FSL_CORENET_PMAN +CONFIG_SYS_FSL_CORENET_PMAN1_OFFSET +CONFIG_SYS_FSL_CORENET_PMAN2_OFFSET +CONFIG_SYS_FSL_CORENET_PMAN3_OFFSET +CONFIG_SYS_FSL_CORENET_PME_ADDR +CONFIG_SYS_FSL_CORENET_PME_OFFSET +CONFIG_SYS_FSL_CORENET_RCPM_ADDR +CONFIG_SYS_FSL_CORENET_RCPM_OFFSET +CONFIG_SYS_FSL_CORENET_RMAN_ADDR +CONFIG_SYS_FSL_CORENET_RMAN_OFFSET +CONFIG_SYS_FSL_CORENET_SERDES2_ADDR +CONFIG_SYS_FSL_CORENET_SERDES2_OFFSET +CONFIG_SYS_FSL_CORENET_SERDES3_ADDR +CONFIG_SYS_FSL_CORENET_SERDES3_OFFSET +CONFIG_SYS_FSL_CORENET_SERDES4_ADDR +CONFIG_SYS_FSL_CORENET_SERDES4_OFFSET +CONFIG_SYS_FSL_CORENET_SERDES_ADDR +CONFIG_SYS_FSL_CORENET_SERDES_OFFSET +CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY +CONFIG_SYS_FSL_CORES_PER_CLUSTER +CONFIG_SYS_FSL_CPC +CONFIG_SYS_FSL_CPC_ADDR +CONFIG_SYS_FSL_CPC_OFFSET +CONFIG_SYS_FSL_CSU_ADDR +CONFIG_SYS_FSL_DCFG_ADDR +CONFIG_SYS_FSL_DCSR_BASE +CONFIG_SYS_FSL_DCSR_DDR2_ADDR +CONFIG_SYS_FSL_DCSR_DDR3_ADDR +CONFIG_SYS_FSL_DCSR_DDR4_ADDR +CONFIG_SYS_FSL_DCSR_DDR_ADDR +CONFIG_SYS_FSL_DCSR_SIZE +CONFIG_SYS_FSL_DCU_BE +CONFIG_SYS_FSL_DCU_LE +CONFIG_SYS_FSL_DDR +CONFIG_SYS_FSL_DDR1 +CONFIG_SYS_FSL_DDR2 +CONFIG_SYS_FSL_DDR2_ADDR +CONFIG_SYS_FSL_DDR3 +CONFIG_SYS_FSL_DDR3L +CONFIG_SYS_FSL_DDR3_ADDR +CONFIG_SYS_FSL_DDR4 +CONFIG_SYS_FSL_DDRC_ARM_GEN3 +CONFIG_SYS_FSL_DDRC_GEN1 +CONFIG_SYS_FSL_DDRC_GEN2 +CONFIG_SYS_FSL_DDRC_GEN3 +CONFIG_SYS_FSL_DDRC_GEN4 +CONFIG_SYS_FSL_DDR_86XX +CONFIG_SYS_FSL_DDR_ADDR +CONFIG_SYS_FSL_DDR_BE +CONFIG_SYS_FSL_DDR_EMU +CONFIG_SYS_FSL_DDR_INTLV_256B +CONFIG_SYS_FSL_DDR_LE +CONFIG_SYS_FSL_DDR_MAIN_NUM_CTRLS +CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY +CONFIG_SYS_FSL_DDR_VER +CONFIG_SYS_FSL_DRAM_BASE1 +CONFIG_SYS_FSL_DRAM_BASE2 +CONFIG_SYS_FSL_DRAM_BASE3 +CONFIG_SYS_FSL_DRAM_SIZE1 +CONFIG_SYS_FSL_DRAM_SIZE2 +CONFIG_SYS_FSL_DRAM_SIZE3 +CONFIG_SYS_FSL_DSPI_BE +CONFIG_SYS_FSL_DSP_CCSRBAR +CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT +CONFIG_SYS_FSL_DSP_CCSRBAR_PHYS +CONFIG_SYS_FSL_DSP_CCSR_DDR_ADDR +CONFIG_SYS_FSL_DSP_CCSR_DDR_OFFSET +CONFIG_SYS_FSL_DSP_DDR_ADDR +CONFIG_SYS_FSL_DSP_M2_RAM_ADDR +CONFIG_SYS_FSL_DSP_M3_RAM_ADDR +CONFIG_SYS_FSL_ERRATUM_A004468 +CONFIG_SYS_FSL_ERRATUM_A004477 +CONFIG_SYS_FSL_ERRATUM_A004508 +CONFIG_SYS_FSL_ERRATUM_A004510 +CONFIG_SYS_FSL_ERRATUM_A004510_SVR_REV +CONFIG_SYS_FSL_ERRATUM_A004510_SVR_REV2 +CONFIG_SYS_FSL_ERRATUM_A004580 +CONFIG_SYS_FSL_ERRATUM_A004699 +CONFIG_SYS_FSL_ERRATUM_A004849 +CONFIG_SYS_FSL_ERRATUM_A005125 +CONFIG_SYS_FSL_ERRATUM_A005434 +CONFIG_SYS_FSL_ERRATUM_A005812 +CONFIG_SYS_FSL_ERRATUM_A005871 +CONFIG_SYS_FSL_ERRATUM_A006261 +CONFIG_SYS_FSL_ERRATUM_A006379 +CONFIG_SYS_FSL_ERRATUM_A006384 +CONFIG_SYS_FSL_ERRATUM_A006475 +CONFIG_SYS_FSL_ERRATUM_A006593 +CONFIG_SYS_FSL_ERRATUM_A007075 +CONFIG_SYS_FSL_ERRATUM_A007186 +CONFIG_SYS_FSL_ERRATUM_A007212 +CONFIG_SYS_FSL_ERRATUM_A007798 +CONFIG_SYS_FSL_ERRATUM_A008044 +CONFIG_SYS_FSL_ERRATUM_A008336 +CONFIG_SYS_FSL_ERRATUM_A008378 +CONFIG_SYS_FSL_ERRATUM_A008407 +CONFIG_SYS_FSL_ERRATUM_A008511 +CONFIG_SYS_FSL_ERRATUM_A008514 +CONFIG_SYS_FSL_ERRATUM_A008585 +CONFIG_SYS_FSL_ERRATUM_A008751 +CONFIG_SYS_FSL_ERRATUM_A008850 +CONFIG_SYS_FSL_ERRATUM_A009635 +CONFIG_SYS_FSL_ERRATUM_A009660 +CONFIG_SYS_FSL_ERRATUM_A009663 +CONFIG_SYS_FSL_ERRATUM_A009801 +CONFIG_SYS_FSL_ERRATUM_A009803 +CONFIG_SYS_FSL_ERRATUM_A009929 +CONFIG_SYS_FSL_ERRATUM_A009942 +CONFIG_SYS_FSL_ERRATUM_A010165 +CONFIG_SYS_FSL_ERRATUM_A_004934 +CONFIG_SYS_FSL_ERRATUM_CPC_A002 +CONFIG_SYS_FSL_ERRATUM_CPC_A003 +CONFIG_SYS_FSL_ERRATUM_CPU_A003999 +CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134 +CONFIG_SYS_FSL_ERRATUM_DDR_115 +CONFIG_SYS_FSL_ERRATUM_DDR_A003 +CONFIG_SYS_FSL_ERRATUM_DDR_A003474 +CONFIG_SYS_FSL_ERRATUM_DDR_MSYNC_IN +CONFIG_SYS_FSL_ERRATUM_ELBC_A001 +CONFIG_SYS_FSL_ERRATUM_ESDHC111 +CONFIG_SYS_FSL_ERRATUM_ESDHC13 +CONFIG_SYS_FSL_ERRATUM_ESDHC135 +CONFIG_SYS_FSL_ERRATUM_ESDHC_A001 +CONFIG_SYS_FSL_ERRATUM_I2C_A004447 +CONFIG_SYS_FSL_ERRATUM_IFC_A002769 +CONFIG_SYS_FSL_ERRATUM_IFC_A003399 +CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011 +CONFIG_SYS_FSL_ERRATUM_NMG_DDR120 +CONFIG_SYS_FSL_ERRATUM_NMG_ETSEC129 +CONFIG_SYS_FSL_ERRATUM_NMG_LBC103 +CONFIG_SYS_FSL_ERRATUM_P1010_A003549 +CONFIG_SYS_FSL_ERRATUM_SEC_A003571 +CONFIG_SYS_FSL_ERRATUM_SRIO_A004034 +CONFIG_SYS_FSL_ERRATUM_USB14 +CONFIG_SYS_FSL_ESDHC_ADDR +CONFIG_SYS_FSL_ESDHC_BE +CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT +CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT +CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE +CONFIG_SYS_FSL_ESDHC_LE +CONFIG_SYS_FSL_ESDHC_NUM +CONFIG_SYS_FSL_ESDHC_P1010_BROKEN_SDCLK +CONFIG_SYS_FSL_ESDHC_USE_PIO +CONFIG_SYS_FSL_FM +CONFIG_SYS_FSL_FM1_ADDR +CONFIG_SYS_FSL_FM1_DTSEC1_ADDR +CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET +CONFIG_SYS_FSL_FM1_OFFSET +CONFIG_SYS_FSL_FM1_RX0_10G_OFFSET +CONFIG_SYS_FSL_FM1_RX0_1G_OFFSET +CONFIG_SYS_FSL_FM1_RX1_10G_OFFSET +CONFIG_SYS_FSL_FM1_RX1_1G_OFFSET +CONFIG_SYS_FSL_FM1_RX2_1G_OFFSET +CONFIG_SYS_FSL_FM1_RX3_1G_OFFSET +CONFIG_SYS_FSL_FM1_RX4_1G_OFFSET +CONFIG_SYS_FSL_FM1_RX5_1G_OFFSET +CONFIG_SYS_FSL_FM2_ADDR +CONFIG_SYS_FSL_FM2_OFFSET +CONFIG_SYS_FSL_FM2_RX0_10G_OFFSET +CONFIG_SYS_FSL_FM2_RX0_1G_OFFSET +CONFIG_SYS_FSL_FM2_RX1_10G_OFFSET +CONFIG_SYS_FSL_FM2_RX1_1G_OFFSET +CONFIG_SYS_FSL_FM2_RX2_1G_OFFSET +CONFIG_SYS_FSL_FM2_RX3_1G_OFFSET +CONFIG_SYS_FSL_FM2_RX4_1G_OFFSET +CONFIG_SYS_FSL_FM2_RX5_1G_OFFSET +CONFIG_SYS_FSL_FMAN_ADDR +CONFIG_SYS_FSL_GUTS_ADDR +CONFIG_SYS_FSL_HAS_DP_DDR +CONFIG_SYS_FSL_I2C +CONFIG_SYS_FSL_I2C2_OFFSET +CONFIG_SYS_FSL_I2C2_SLAVE +CONFIG_SYS_FSL_I2C2_SPEED +CONFIG_SYS_FSL_I2C3_OFFSET +CONFIG_SYS_FSL_I2C3_SLAVE +CONFIG_SYS_FSL_I2C3_SPEED +CONFIG_SYS_FSL_I2C4_OFFSET +CONFIG_SYS_FSL_I2C4_SLAVE +CONFIG_SYS_FSL_I2C4_SPEED +CONFIG_SYS_FSL_I2C_OFFSET +CONFIG_SYS_FSL_I2C_SLAVE +CONFIG_SYS_FSL_I2C_SPEED +CONFIG_SYS_FSL_IFC_BANK_COUNT +CONFIG_SYS_FSL_IFC_BASE +CONFIG_SYS_FSL_IFC_BASE1 +CONFIG_SYS_FSL_IFC_BASE2 +CONFIG_SYS_FSL_IFC_BE +CONFIG_SYS_FSL_IFC_LE +CONFIG_SYS_FSL_IFC_SIZE +CONFIG_SYS_FSL_IFC_SIZE1 +CONFIG_SYS_FSL_IFC_SIZE1_1 +CONFIG_SYS_FSL_IFC_SIZE2 +CONFIG_SYS_FSL_ISBC_VER +CONFIG_SYS_FSL_JR0_ADDR +CONFIG_SYS_FSL_JR0_OFFSET +CONFIG_SYS_FSL_LS1_CLK_ADDR +CONFIG_SYS_FSL_LSCH3_SERDES_ADDR +CONFIG_SYS_FSL_MAX_NUM_OF_SEC +CONFIG_SYS_FSL_MC9SDZ60_I2C_ADDR +CONFIG_SYS_FSL_MC_BASE +CONFIG_SYS_FSL_MC_SIZE +CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +CONFIG_SYS_FSL_NI_BASE +CONFIG_SYS_FSL_NI_SIZE +CONFIG_SYS_FSL_NO_SERDES +CONFIG_SYS_FSL_NUM_CC_PLL +CONFIG_SYS_FSL_NUM_CC_PLLS +CONFIG_SYS_FSL_NUM_LAWS +CONFIG_SYS_FSL_OCRAM_BASE +CONFIG_SYS_FSL_OCRAM_SIZE +CONFIG_SYS_FSL_OTHER_DDR_NUM_CTRLS +CONFIG_SYS_FSL_PAMU_OFFSET +CONFIG_SYS_FSL_PBL_PBI +CONFIG_SYS_FSL_PBL_RCW +CONFIG_SYS_FSL_PCIE_COMPAT +CONFIG_SYS_FSL_PCI_VER_3_X +CONFIG_SYS_FSL_PEBUF_BASE +CONFIG_SYS_FSL_PEBUF_SIZE +CONFIG_SYS_FSL_PEX_LUT_BE +CONFIG_SYS_FSL_PEX_LUT_LE +CONFIG_SYS_FSL_PMIC_I2C_ADDR +CONFIG_SYS_FSL_PMU_ADDR +CONFIG_SYS_FSL_PMU_CLTBENR +CONFIG_SYS_FSL_QBMAN_BASE +CONFIG_SYS_FSL_QBMAN_SIZE +CONFIG_SYS_FSL_QBMAN_SIZE_1 +CONFIG_SYS_FSL_QMAN_ADDR +CONFIG_SYS_FSL_QMAN_OFFSET +CONFIG_SYS_FSL_QMAN_V3 +CONFIG_SYS_FSL_QORIQ_CHASSIS1 +CONFIG_SYS_FSL_QORIQ_CHASSIS2 +CONFIG_SYS_FSL_QSPI_AHB +CONFIG_SYS_FSL_QSPI_BASE +CONFIG_SYS_FSL_QSPI_BASE1 +CONFIG_SYS_FSL_QSPI_BASE2 +CONFIG_SYS_FSL_QSPI_BE +CONFIG_SYS_FSL_QSPI_LE +CONFIG_SYS_FSL_QSPI_SIZE +CONFIG_SYS_FSL_QSPI_SIZE1 +CONFIG_SYS_FSL_QSPI_SIZE2 +CONFIG_SYS_FSL_RAID_ENGINE +CONFIG_SYS_FSL_RAID_ENGINE_ADDR +CONFIG_SYS_FSL_RAID_ENGINE_OFFSET +CONFIG_SYS_FSL_RCPM_ADDR +CONFIG_SYS_FSL_RMU +CONFIG_SYS_FSL_RST_ADDR +CONFIG_SYS_FSL_SCFG_ADDR +CONFIG_SYS_FSL_SCFG_IODSECR1_ADDR +CONFIG_SYS_FSL_SCFG_IODSECR1_OFFSET +CONFIG_SYS_FSL_SCFG_OFFSET +CONFIG_SYS_FSL_SCFG_PIXCLKCR_OFFSET +CONFIG_SYS_FSL_SCFG_PIXCLK_ADDR +CONFIG_SYS_FSL_SEC_ADDR +CONFIG_SYS_FSL_SEC_BE +CONFIG_SYS_FSL_SEC_COMPAT +CONFIG_SYS_FSL_SEC_IDX_OFFSET +CONFIG_SYS_FSL_SEC_LE +CONFIG_SYS_FSL_SEC_MON_BE +CONFIG_SYS_FSL_SEC_MON_LE +CONFIG_SYS_FSL_SEC_OFFSET +CONFIG_SYS_FSL_SERDES +CONFIG_SYS_FSL_SERDES_ADDR +CONFIG_SYS_FSL_SFP_BE +CONFIG_SYS_FSL_SFP_LE +CONFIG_SYS_FSL_SFP_VER_3_0 +CONFIG_SYS_FSL_SFP_VER_3_2 +CONFIG_SYS_FSL_SFP_VER_3_4 +CONFIG_SYS_FSL_SINGLE_SOURCE_CLK +CONFIG_SYS_FSL_SNVS_LE +CONFIG_SYS_FSL_SP_ADDR +CONFIG_SYS_FSL_SP_LOOPBACK_DUART +CONFIG_SYS_FSL_SP_VSG_GIC_ADDR +CONFIG_SYS_FSL_SP_VSG_GIC_VIGR1 +CONFIG_SYS_FSL_SP_VSG_GIC_VIGR2 +CONFIG_SYS_FSL_SRDS_1 +CONFIG_SYS_FSL_SRDS_2 +CONFIG_SYS_FSL_SRDS_3 +CONFIG_SYS_FSL_SRDS_4 +CONFIG_SYS_FSL_SRDS_NUM_PLLS +CONFIG_SYS_FSL_SRIO_ADDR +CONFIG_SYS_FSL_SRIO_IB_WIN_NUM +CONFIG_SYS_FSL_SRIO_LIODN +CONFIG_SYS_FSL_SRIO_MAX_PORTS +CONFIG_SYS_FSL_SRIO_MSG_UNIT_NUM +CONFIG_SYS_FSL_SRIO_OB_WIN_NUM +CONFIG_SYS_FSL_SRIO_OFFSET +CONFIG_SYS_FSL_SRK_LE +CONFIG_SYS_FSL_TBCLK_DIV +CONFIG_SYS_FSL_THREADS_PER_CORE +CONFIG_SYS_FSL_TIMER_ADDR +CONFIG_SYS_FSL_USB1_ADDR +CONFIG_SYS_FSL_USB1_PHY_ENABLE +CONFIG_SYS_FSL_USB2_ADDR +CONFIG_SYS_FSL_USB2_PHY_ENABLE +CONFIG_SYS_FSL_USB_CTRL_PHY_EN +CONFIG_SYS_FSL_USB_DRVVBUS_CR_EN +CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE +CONFIG_SYS_FSL_USB_ENABLE_OVERRIDE +CONFIG_SYS_FSL_USB_HS_DISCNCT_INC +CONFIG_SYS_FSL_USB_INTERNAL_SOC_CLK_EN +CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +CONFIG_SYS_FSL_USB_PLLPRG1_PHY_DIV +CONFIG_SYS_FSL_USB_PLLPRG2_FRAC_LPF_EN +CONFIG_SYS_FSL_USB_PLLPRG2_MFI +CONFIG_SYS_FSL_USB_PLLPRG2_MFI_INTERNAL_CLK +CONFIG_SYS_FSL_USB_PLLPRG2_PHY1_CLK_EN +CONFIG_SYS_FSL_USB_PLLPRG2_PHY2_CLK_EN +CONFIG_SYS_FSL_USB_PLLPRG2_PLL_EN +CONFIG_SYS_FSL_USB_PLLPRG2_REF_DIV +CONFIG_SYS_FSL_USB_PLLPRG2_REF_DIV_INTERNAL_CLK +CONFIG_SYS_FSL_USB_PWRFLT_CR_EN +CONFIG_SYS_FSL_USB_RX_AUTO_CAL_RD_WR_SEL +CONFIG_SYS_FSL_USB_SQUELCH_PROG_MASK +CONFIG_SYS_FSL_USB_SQUELCH_PROG_RD_0 +CONFIG_SYS_FSL_USB_SQUELCH_PROG_RD_3 +CONFIG_SYS_FSL_USB_SQUELCH_PROG_WR_0 +CONFIG_SYS_FSL_USB_SQUELCH_PROG_WR_3 +CONFIG_SYS_FSL_USB_SYS_CLK_VALID +CONFIG_SYS_FSL_USB_XCVRPRG_HS_DCNT_PROG_EN +CONFIG_SYS_FSL_USB_XCVRPRG_HS_DCNT_PROG_MASK +CONFIG_SYS_FSL_USDHC_NUM +CONFIG_SYS_FSL_WDOG_BE +CONFIG_SYS_FSL_WRIOP1_ADDR +CONFIG_SYS_FSL_WRIOP1_BASE +CONFIG_SYS_FSL_WRIOP1_MDIO1 +CONFIG_SYS_FSL_WRIOP1_MDIO2 +CONFIG_SYS_FSL_WRIOP1_SIZE +CONFIG_SYS_FSL_XHCI_USB1_ADDR +CONFIG_SYS_FSL_XHCI_USB2_ADDR +CONFIG_SYS_FSL_XHCI_USB3_ADDR +CONFIG_SYS_FSMC_BASE +CONFIG_SYS_FSMC_NAND_16BIT +CONFIG_SYS_FSMC_NAND_8BIT +CONFIG_SYS_FSMC_NAND_SP +CONFIG_SYS_FTAHBC020S_SLAVE_BSR_6 +CONFIG_SYS_FTAHBC020S_SLAVE_BSR_BASE +CONFIG_SYS_FTPMU010_PDLLCR0_HCLKOUTDIS +CONFIG_SYS_FTPMU010_SDRAMHTC +CONFIG_SYS_FTSDMC021_BANK0_BASE +CONFIG_SYS_FTSDMC021_BANK0_BSR +CONFIG_SYS_FTSDMC021_BANK1_BASE +CONFIG_SYS_FTSDMC021_BANK1_BSR +CONFIG_SYS_FTSDMC021_CR1 +CONFIG_SYS_FTSDMC021_CR2 +CONFIG_SYS_FTSDMC021_TP1 +CONFIG_SYS_FTSDMC021_TP2 +CONFIG_SYS_FTSMC020_CONFIGS +CONFIG_SYS_FULL_VA +CONFIG_SYS_GAFR0_L_VAL +CONFIG_SYS_GAFR0_U_VAL +CONFIG_SYS_GAFR1_L_VAL +CONFIG_SYS_GAFR1_U_VAL +CONFIG_SYS_GAFR2_L_VAL +CONFIG_SYS_GAFR2_U_VAL +CONFIG_SYS_GAFR3_L_VAL +CONFIG_SYS_GAFR3_U_VAL +CONFIG_SYS_GBIT_MII1_BUSNAME +CONFIG_SYS_GBIT_MII_BUSNAME +CONFIG_SYS_GBL_DATA_ADDR +CONFIG_SYS_GBL_DATA_OFFSET +CONFIG_SYS_GBL_DATA_SIZE +CONFIG_SYS_GENERIC_BOARD +CONFIG_SYS_GENERIC_GLOBAL_DATA +CONFIG_SYS_GIC400_ADDR +CONFIG_SYS_GLOBAL_SDRAM_LIMIT +CONFIG_SYS_GP1DIR +CONFIG_SYS_GP1ODR +CONFIG_SYS_GP2DIR +CONFIG_SYS_GP2ODR +CONFIG_SYS_GPCR0_VAL +CONFIG_SYS_GPCR1_VAL +CONFIG_SYS_GPCR2_VAL +CONFIG_SYS_GPCR3_VAL +CONFIG_SYS_GPDR0_VAL +CONFIG_SYS_GPDR1_VAL +CONFIG_SYS_GPDR2_VAL +CONFIG_SYS_GPDR3_VAL +CONFIG_SYS_GPIO0_ISR1H +CONFIG_SYS_GPIO0_ISR1L +CONFIG_SYS_GPIO0_ISR2H +CONFIG_SYS_GPIO0_ISR2L +CONFIG_SYS_GPIO0_ODR +CONFIG_SYS_GPIO0_OR +CONFIG_SYS_GPIO0_OSRH +CONFIG_SYS_GPIO0_OSRL +CONFIG_SYS_GPIO0_TCR +CONFIG_SYS_GPIO0_TSRH +CONFIG_SYS_GPIO0_TSRL +CONFIG_SYS_GPIO1_DAT +CONFIG_SYS_GPIO1_DIR +CONFIG_SYS_GPIO1_EN +CONFIG_SYS_GPIO1_FUNC +CONFIG_SYS_GPIO1_ISR1H +CONFIG_SYS_GPIO1_ISR1L +CONFIG_SYS_GPIO1_LED +CONFIG_SYS_GPIO1_OSRH +CONFIG_SYS_GPIO1_OSRL +CONFIG_SYS_GPIO1_OUT +CONFIG_SYS_GPIO1_PRELIM +CONFIG_SYS_GPIO1_TCR +CONFIG_SYS_GPIO1_TSRH +CONFIG_SYS_GPIO1_TSRL +CONFIG_SYS_GPIO2_DAT +CONFIG_SYS_GPIO2_DIR +CONFIG_SYS_GPIO2_PRELIM +CONFIG_SYS_GPIO_0_ADDR +CONFIG_SYS_GPIO_BASE +CONFIG_SYS_GPIO_BOARD_RESET +CONFIG_SYS_GPIO_CAN_ENABLE +CONFIG_SYS_GPIO_CRAM_ADV +CONFIG_SYS_GPIO_CRAM_CLK +CONFIG_SYS_GPIO_CRAM_CRE +CONFIG_SYS_GPIO_CRAM_WAIT +CONFIG_SYS_GPIO_DATADIR +CONFIG_SYS_GPIO_DATAVALUE +CONFIG_SYS_GPIO_DSPIC_READY +CONFIG_SYS_GPIO_EEPROM_EXT_WP +CONFIG_SYS_GPIO_EEPROM_INT_WP +CONFIG_SYS_GPIO_EEPROM_WP +CONFIG_SYS_GPIO_EN +CONFIG_SYS_GPIO_ENABLE +CONFIG_SYS_GPIO_EREADY +CONFIG_SYS_GPIO_FLASH_WP +CONFIG_SYS_GPIO_FUNC +CONFIG_SYS_GPIO_HIGHSIDE +CONFIG_SYS_GPIO_HWREV_MASK +CONFIG_SYS_GPIO_HWREV_SHIFT +CONFIG_SYS_GPIO_I2C_SCL +CONFIG_SYS_GPIO_I2C_SDA +CONFIG_SYS_GPIO_LEDA_N +CONFIG_SYS_GPIO_LEDB_N +CONFIG_SYS_GPIO_LEDRUN_N +CONFIG_SYS_GPIO_LIME_RST +CONFIG_SYS_GPIO_LIME_S +CONFIG_SYS_GPIO_LSB_ENABLE +CONFIG_SYS_GPIO_M66EN +CONFIG_SYS_GPIO_MONARCH_N +CONFIG_SYS_GPIO_ODR +CONFIG_SYS_GPIO_OPENDRAIN +CONFIG_SYS_GPIO_OR +CONFIG_SYS_GPIO_OUT +CONFIG_SYS_GPIO_PCIE_CLKREQ +CONFIG_SYS_GPIO_PCIE_PRESENT0 +CONFIG_SYS_GPIO_PCIE_PRESENT1 +CONFIG_SYS_GPIO_PCIE_PRESENT2 +CONFIG_SYS_GPIO_PCIE_RST +CONFIG_SYS_GPIO_PCIE_WAKE +CONFIG_SYS_GPIO_PERM_VOLT_FEED +CONFIG_SYS_GPIO_PHY0_RST +CONFIG_SYS_GPIO_PHY1_RST +CONFIG_SYS_GPIO_PHY_RST +CONFIG_SYS_GPIO_RS232_FORCEOFF +CONFIG_SYS_GPIO_SELFRST_N +CONFIG_SYS_GPIO_STARTUP_FINISHED +CONFIG_SYS_GPIO_STARTUP_FINISHED_N +CONFIG_SYS_GPIO_SYSMON_STATUS +CONFIG_SYS_GPIO_TCR +CONFIG_SYS_GPIO_WATCHDOG +CONFIG_SYS_GPIO_WIDTH +CONFIG_SYS_GPR1 +CONFIG_SYS_GPSR0_VAL +CONFIG_SYS_GPSR1_VAL +CONFIG_SYS_GPSR2_VAL +CONFIG_SYS_GPSR3_VAL +CONFIG_SYS_GPS_PORT_CONFIG +CONFIG_SYS_GPS_PORT_CONFIG_1 +CONFIG_SYS_GPS_PORT_CONFIG_2 +CONFIG_SYS_GRLIB_APBUART_INDEX +CONFIG_SYS_GRLIB_ESA_MCTRL1 +CONFIG_SYS_GRLIB_ESA_MCTRL1_CFG1 +CONFIG_SYS_GRLIB_ESA_MCTRL1_CFG2 +CONFIG_SYS_GRLIB_ESA_MCTRL1_CFG3 +CONFIG_SYS_GRLIB_ESA_MCTRL2 +CONFIG_SYS_GRLIB_ESA_MCTRL2_CFG1 +CONFIG_SYS_GRLIB_ESA_MCTRL2_CFG2 +CONFIG_SYS_GRLIB_ESA_MCTRL2_CFG3 +CONFIG_SYS_GRLIB_GAISLER_DDR2SPA1 +CONFIG_SYS_GRLIB_GAISLER_DDR2SPA1_CFG1 +CONFIG_SYS_GRLIB_GAISLER_DDR2SPA1_CFG3 +CONFIG_SYS_GRLIB_GAISLER_DDR2SPA1_CFG4 +CONFIG_SYS_GRLIB_GAISLER_DDR2SPA2 +CONFIG_SYS_GRLIB_GAISLER_DDR2SPA2_CFG1 +CONFIG_SYS_GRLIB_GAISLER_DDR2SPA2_CFG3 +CONFIG_SYS_GRLIB_GAISLER_DDR2SPA2_CFG4 +CONFIG_SYS_GRLIB_GAISLER_DDRSPA1 +CONFIG_SYS_GRLIB_GAISLER_DDRSPA1_CTRL +CONFIG_SYS_GRLIB_GAISLER_DDRSPA2 +CONFIG_SYS_GRLIB_GAISLER_DDRSPA2_CTRL +CONFIG_SYS_GRLIB_GAISLER_FTMCTRL1 +CONFIG_SYS_GRLIB_GAISLER_FTMCTRL1_CFG1 +CONFIG_SYS_GRLIB_GAISLER_FTMCTRL1_CFG2 +CONFIG_SYS_GRLIB_GAISLER_FTMCTRL1_CFG3 +CONFIG_SYS_GRLIB_GAISLER_FTMCTRL2 +CONFIG_SYS_GRLIB_GAISLER_FTMCTRL2_CFG1 +CONFIG_SYS_GRLIB_GAISLER_FTMCTRL2_CFG2 +CONFIG_SYS_GRLIB_GAISLER_FTMCTRL2_CFG3 +CONFIG_SYS_GRLIB_GAISLER_SDCTRL1 +CONFIG_SYS_GRLIB_GAISLER_SDCTRL1_CTRL +CONFIG_SYS_GRLIB_GAISLER_SDCTRL2 +CONFIG_SYS_GRLIB_GAISLER_SDCTRL2_CTRL +CONFIG_SYS_GRLIB_GPTIMER_INDEX +CONFIG_SYS_GRLIB_GRETH_INDEX +CONFIG_SYS_GRLIB_GRETH_PHYADDR +CONFIG_SYS_GRLIB_GRUSB_INDEX +CONFIG_SYS_GRLIB_MEMCFG1 +CONFIG_SYS_GRLIB_MEMCFG2 +CONFIG_SYS_GRLIB_MEMCFG3 +CONFIG_SYS_GRLIB_SDRAM +CONFIG_SYS_GRLIB_SINGLE_BUS +CONFIG_SYS_HALT_BEFOR_RAM_JUMP +CONFIG_SYS_HAS_NO_CACHE +CONFIG_SYS_HAS_SERDES +CONFIG_SYS_HELP_CMD_WIDTH +CONFIG_SYS_HID0_FINAL +CONFIG_SYS_HID0_INIT +CONFIG_SYS_HID2 +CONFIG_SYS_HIGH +CONFIG_SYS_HMI_BASE +CONFIG_SYS_HOSTMODE +CONFIG_SYS_HOSTNAME +CONFIG_SYS_HRCW_HIGH +CONFIG_SYS_HRCW_HIGH_BASE +CONFIG_SYS_HRCW_LOW +CONFIG_SYS_HRCW_MASTER +CONFIG_SYS_HRCW_SLAVE1 +CONFIG_SYS_HRCW_SLAVE2 +CONFIG_SYS_HRCW_SLAVE3 +CONFIG_SYS_HRCW_SLAVE4 +CONFIG_SYS_HRCW_SLAVE5 +CONFIG_SYS_HRCW_SLAVE6 +CONFIG_SYS_HRCW_SLAVE7 +CONFIG_SYS_HSDRAMC +CONFIG_SYS_HWINFO_MAGIC +CONFIG_SYS_HWINFO_OFFSET +CONFIG_SYS_HWINFO_SIZE +CONFIG_SYS_HZ +CONFIG_SYS_HZ_CLOCK +CONFIG_SYS_I2 +CONFIG_SYS_I2C +CONFIG_SYS_I2C2_FSL_OFFSET +CONFIG_SYS_I2C2_OFFSET +CONFIG_SYS_I2C2_PINMUX_CLR +CONFIG_SYS_I2C2_PINMUX_REG +CONFIG_SYS_I2C2_PINMUX_SET +CONFIG_SYS_I2C_0 +CONFIG_SYS_I2C_2 +CONFIG_SYS_I2C_5 +CONFIG_SYS_I2C_8574A_ADDR1 +CONFIG_SYS_I2C_8574A_ADDR2 +CONFIG_SYS_I2C_8574_ADDR1 +CONFIG_SYS_I2C_8574_ADDR2 +CONFIG_SYS_I2C_ADI +CONFIG_SYS_I2C_BASE +CONFIG_SYS_I2C_BASE0 +CONFIG_SYS_I2C_BASE1 +CONFIG_SYS_I2C_BASE2 +CONFIG_SYS_I2C_BASE3 +CONFIG_SYS_I2C_BASE4 +CONFIG_SYS_I2C_BASE5 +CONFIG_SYS_I2C_BOARD_LATE_INIT +CONFIG_SYS_I2C_BOOT_EEPROM_ADDR +CONFIG_SYS_I2C_BUSES +CONFIG_SYS_I2C_BUS_MAX +CONFIG_SYS_I2C_CLK_OFFSET +CONFIG_SYS_I2C_DAVINCI +CONFIG_SYS_I2C_DIRECT_BUS +CONFIG_SYS_I2C_DPMEM_OFFSET +CONFIG_SYS_I2C_DS1621_ADDR +CONFIG_SYS_I2C_DS4510_ADDR +CONFIG_SYS_I2C_DSPIC_2_ADDR +CONFIG_SYS_I2C_DSPIC_ADDR +CONFIG_SYS_I2C_DSPIC_IO_ADDR +CONFIG_SYS_I2C_DSPIC_KEYB_ADDR +CONFIG_SYS_I2C_DTT_ADDR +CONFIG_SYS_I2C_DVI_ADDR +CONFIG_SYS_I2C_DVI_BUS_NUM +CONFIG_SYS_I2C_DW_ENABLE_STATUS_UNSUPPORTED +CONFIG_SYS_I2C_EARLY_INIT +CONFIG_SYS_I2C_EEPROM +CONFIG_SYS_I2C_EEPROM_ADDR +CONFIG_SYS_I2C_EEPROM_ADDR_LEN +CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW +CONFIG_SYS_I2C_EEPROM_BUS +CONFIG_SYS_I2C_EEPROM_BUS_NUM +CONFIG_SYS_I2C_EEPROM_CCID +CONFIG_SYS_I2C_EEPROM_CPU_ADDR +CONFIG_SYS_I2C_EEPROM_MAC_OFFSET +CONFIG_SYS_I2C_EEPROM_MB_ADDR +CONFIG_SYS_I2C_EEPROM_NXID +CONFIG_SYS_I2C_EEPROM_NXID_MAC +CONFIG_SYS_I2C_EEPROM_PAGE_WRITE_BITS +CONFIG_SYS_I2C_EEPROM_PAGE_WRITE_DELAY_MS +CONFIG_SYS_I2C_EXPANDER_ADDR +CONFIG_SYS_I2C_FACT_ADDR +CONFIG_SYS_I2C_FPGA_ADDR +CONFIG_SYS_I2C_FRAM +CONFIG_SYS_I2C_FSL +CONFIG_SYS_I2C_G762_ADDR +CONFIG_SYS_I2C_GENERIC_MAC +CONFIG_SYS_I2C_HWMON_ADDR +CONFIG_SYS_I2C_IDT6V49205B +CONFIG_SYS_I2C_IFDR_DIV +CONFIG_SYS_I2C_IHS +CONFIG_SYS_I2C_IHS_CH0 +CONFIG_SYS_I2C_IHS_CH0_1 +CONFIG_SYS_I2C_IHS_CH1 +CONFIG_SYS_I2C_IHS_CH1_1 +CONFIG_SYS_I2C_IHS_CH2 +CONFIG_SYS_I2C_IHS_CH2_1 +CONFIG_SYS_I2C_IHS_CH3 +CONFIG_SYS_I2C_IHS_CH3_1 +CONFIG_SYS_I2C_IHS_DUAL +CONFIG_SYS_I2C_IHS_SLAVE_0 +CONFIG_SYS_I2C_IHS_SLAVE_0_1 +CONFIG_SYS_I2C_IHS_SLAVE_1 +CONFIG_SYS_I2C_IHS_SLAVE_1_1 +CONFIG_SYS_I2C_IHS_SLAVE_2 +CONFIG_SYS_I2C_IHS_SLAVE_2_1 +CONFIG_SYS_I2C_IHS_SLAVE_3 +CONFIG_SYS_I2C_IHS_SLAVE_3_1 +CONFIG_SYS_I2C_IHS_SPEED_0 +CONFIG_SYS_I2C_IHS_SPEED_0_1 +CONFIG_SYS_I2C_IHS_SPEED_1 +CONFIG_SYS_I2C_IHS_SPEED_1_1 +CONFIG_SYS_I2C_IHS_SPEED_2 +CONFIG_SYS_I2C_IHS_SPEED_2_1 +CONFIG_SYS_I2C_IHS_SPEED_3 +CONFIG_SYS_I2C_IHS_SPEED_3_1 +CONFIG_SYS_I2C_INIT_BOARD +CONFIG_SYS_I2C_INIT_MPC5XXX +CONFIG_SYS_I2C_IO +CONFIG_SYS_I2C_KEYBD_ADDR +CONFIG_SYS_I2C_KONA +CONFIG_SYS_I2C_LDI_ADDR +CONFIG_SYS_I2C_LM75_ADDR +CONFIG_SYS_I2C_LM90_ADDR +CONFIG_SYS_I2C_LPC32XX +CONFIG_SYS_I2C_LPC32XX_SLAVE +CONFIG_SYS_I2C_LPC32XX_SPEED +CONFIG_SYS_I2C_MAC1_BUS +CONFIG_SYS_I2C_MAC1_CHIP_ADDR +CONFIG_SYS_I2C_MAC1_DATA_ADDR +CONFIG_SYS_I2C_MAC2_BUS +CONFIG_SYS_I2C_MAC2_CHIP_ADDR +CONFIG_SYS_I2C_MAC2_DATA_ADDR +CONFIG_SYS_I2C_MAC_OFFSET +CONFIG_SYS_I2C_MAX1237_ADDR +CONFIG_SYS_I2C_MAX_HOPS +CONFIG_SYS_I2C_MODULE +CONFIG_SYS_I2C_MULTI_NOPROBES +CONFIG_SYS_I2C_MVTWSI +CONFIG_SYS_I2C_MXC +CONFIG_SYS_I2C_MXC_I2C1 +CONFIG_SYS_I2C_MXC_I2C2 +CONFIG_SYS_I2C_MXC_I2C3 +CONFIG_SYS_I2C_MXC_I2C4 +CONFIG_SYS_I2C_MXS +CONFIG_SYS_I2C_NCT72_ADDR +CONFIG_SYS_I2C_NOPROBES +CONFIG_SYS_I2C_OFFSET +CONFIG_SYS_I2C_OMAP24XX +CONFIG_SYS_I2C_OMAP34XX +CONFIG_SYS_I2C_PCA953X_ADDR +CONFIG_SYS_I2C_PCA953X_ADDR0 +CONFIG_SYS_I2C_PCA953X_ADDR1 +CONFIG_SYS_I2C_PCA953X_ADDR2 +CONFIG_SYS_I2C_PCA953X_ADDR3 +CONFIG_SYS_I2C_PCA953X_WIDTH +CONFIG_SYS_I2C_PCA9553_ADDR +CONFIG_SYS_I2C_PCA9555_ADDR +CONFIG_SYS_I2C_PCA9557_ADDR +CONFIG_SYS_I2C_PCF8574A_ADDR +CONFIG_SYS_I2C_PEX8518_ADDR +CONFIG_SYS_I2C_PINMUX_CLR +CONFIG_SYS_I2C_PINMUX_REG +CONFIG_SYS_I2C_PINMUX_SET +CONFIG_SYS_I2C_POWERIC_ADDR +CONFIG_SYS_I2C_PPC4XX +CONFIG_SYS_I2C_PPC4XX_CH0 +CONFIG_SYS_I2C_PPC4XX_CH1 +CONFIG_SYS_I2C_PPC4XX_SLAVE_0 +CONFIG_SYS_I2C_PPC4XX_SLAVE_1 +CONFIG_SYS_I2C_PPC4XX_SPEED_0 +CONFIG_SYS_I2C_PPC4XX_SPEED_1 +CONFIG_SYS_I2C_PXA +CONFIG_SYS_I2C_QIXIS_ADDR +CONFIG_SYS_I2C_RCAR +CONFIG_SYS_I2C_RTC_ADDR +CONFIG_SYS_I2C_S3C24X0 +CONFIG_SYS_I2C_S3C24X0_SLAVE +CONFIG_SYS_I2C_S3C24X0_SPEED +CONFIG_SYS_I2C_SH +CONFIG_SYS_I2C_SH_BASE0 +CONFIG_SYS_I2C_SH_BASE1 +CONFIG_SYS_I2C_SH_BASE2 +CONFIG_SYS_I2C_SH_BASE3 +CONFIG_SYS_I2C_SH_BASE4 +CONFIG_SYS_I2C_SH_BASE5 +CONFIG_SYS_I2C_SH_NUM_CONTROLLERS +CONFIG_SYS_I2C_SH_SPEED0 +CONFIG_SYS_I2C_SH_SPEED1 +CONFIG_SYS_I2C_SH_SPEED2 +CONFIG_SYS_I2C_SH_SPEED3 +CONFIG_SYS_I2C_SH_SPEED4 +CONFIG_SYS_I2C_SH_SPEED5 +CONFIG_SYS_I2C_SLAVE +CONFIG_SYS_I2C_SLAVE1 +CONFIG_SYS_I2C_SLAVE2 +CONFIG_SYS_I2C_SLAVE3 +CONFIG_SYS_I2C_SOFT +CONFIG_SYS_I2C_SOFT_SLAVE +CONFIG_SYS_I2C_SOFT_SLAVE_10 +CONFIG_SYS_I2C_SOFT_SLAVE_11 +CONFIG_SYS_I2C_SOFT_SLAVE_12 +CONFIG_SYS_I2C_SOFT_SLAVE_2 +CONFIG_SYS_I2C_SOFT_SLAVE_3 +CONFIG_SYS_I2C_SOFT_SLAVE_4 +CONFIG_SYS_I2C_SOFT_SLAVE_5 +CONFIG_SYS_I2C_SOFT_SLAVE_6 +CONFIG_SYS_I2C_SOFT_SLAVE_7 +CONFIG_SYS_I2C_SOFT_SLAVE_8 +CONFIG_SYS_I2C_SOFT_SLAVE_9 +CONFIG_SYS_I2C_SOFT_SPEED +CONFIG_SYS_I2C_SOFT_SPEED_10 +CONFIG_SYS_I2C_SOFT_SPEED_11 +CONFIG_SYS_I2C_SOFT_SPEED_12 +CONFIG_SYS_I2C_SOFT_SPEED_2 +CONFIG_SYS_I2C_SOFT_SPEED_3 +CONFIG_SYS_I2C_SOFT_SPEED_4 +CONFIG_SYS_I2C_SOFT_SPEED_5 +CONFIG_SYS_I2C_SOFT_SPEED_6 +CONFIG_SYS_I2C_SOFT_SPEED_7 +CONFIG_SYS_I2C_SOFT_SPEED_8 +CONFIG_SYS_I2C_SOFT_SPEED_9 +CONFIG_SYS_I2C_SPEED +CONFIG_SYS_I2C_SPEED1 +CONFIG_SYS_I2C_SPEED2 +CONFIG_SYS_I2C_SPEED3 +CONFIG_SYS_I2C_TCA642X_ADDR +CONFIG_SYS_I2C_TCA642X_BUS_NUM +CONFIG_SYS_I2C_TEGRA +CONFIG_SYS_I2C_UCODE_PATCH +CONFIG_SYS_I2C_W83782G_ADDR +CONFIG_SYS_I2C_ZYNQ +CONFIG_SYS_I2C_ZYNQ_SLAVE +CONFIG_SYS_I2C_ZYNQ_SPEED +CONFIG_SYS_I2ODMA_BASE +CONFIG_SYS_I2ODMA_PHYS_ADDR +CONFIG_SYS_IBAT +CONFIG_SYS_IBAT0L +CONFIG_SYS_IBAT0U +CONFIG_SYS_IBAT1L +CONFIG_SYS_IBAT1U +CONFIG_SYS_IBAT2L +CONFIG_SYS_IBAT2U +CONFIG_SYS_IBAT3L +CONFIG_SYS_IBAT3U +CONFIG_SYS_IBAT4L +CONFIG_SYS_IBAT4U +CONFIG_SYS_IBAT5L +CONFIG_SYS_IBAT5U +CONFIG_SYS_IBAT6L +CONFIG_SYS_IBAT6L_EARLY +CONFIG_SYS_IBAT6U +CONFIG_SYS_IBAT6U_EARLY +CONFIG_SYS_IBAT7L +CONFIG_SYS_IBAT7U +CONFIG_SYS_ICACHE_INV +CONFIG_SYS_ICACHE_LINESZ +CONFIG_SYS_ICACHE_LINE_SIZE +CONFIG_SYS_ICACHE_OFF +CONFIG_SYS_ICACHE_SACR_VALUE +CONFIG_SYS_ICACHE_SIZE +CONFIG_SYS_ICS8N3QV01_I2C +CONFIG_SYS_ICTRL +CONFIG_SYS_IDE_MAXBUS +CONFIG_SYS_IDE_MAXDEVICE +CONFIG_SYS_IDWP +CONFIG_SYS_ID_EEPROM +CONFIG_SYS_IFC_ADDR +CONFIG_SYS_IFC_CCR +CONFIG_SYS_IMMR +CONFIG_SYS_INIT_DATA_SIZE +CONFIG_SYS_INIT_DBCR +CONFIG_SYS_INIT_DCACHE_CS +CONFIG_SYS_INIT_DCACHE_PB +CONFIG_SYS_INIT_EXTRA_SIZE +CONFIG_SYS_INIT_L2CSR0 +CONFIG_SYS_INIT_L2_ADDR +CONFIG_SYS_INIT_L2_ADDR_PHYS +CONFIG_SYS_INIT_L2_END +CONFIG_SYS_INIT_L3_ADDR +CONFIG_SYS_INIT_L3_ADDR_PHYS +CONFIG_SYS_INIT_L3_END +CONFIG_SYS_INIT_L3_VADDR +CONFIG_SYS_INIT_RAM1_ADDR +CONFIG_SYS_INIT_RAM1_CTRL +CONFIG_SYS_INIT_RAM1_END +CONFIG_SYS_INIT_RAM_ADDR +CONFIG_SYS_INIT_RAM_ADDR_PHYS +CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH +CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW +CONFIG_SYS_INIT_RAM_CTRL +CONFIG_SYS_INIT_RAM_DCACHE +CONFIG_SYS_INIT_RAM_LOCK +CONFIG_SYS_INIT_RAM_PATTERN +CONFIG_SYS_INIT_RAM_SIZE +CONFIG_SYS_INIT_SP_ADDR +CONFIG_SYS_INIT_SP_OFFSET +CONFIG_SYS_INPUT_CLKSRC +CONFIG_SYS_INTA_FAKE +CONFIG_SYS_INTEL_BOOT +CONFIG_SYS_INTERLAKEN +CONFIG_SYS_INTRAM_BASE +CONFIG_SYS_INTRAM_SIZE +CONFIG_SYS_INTR_BASE +CONFIG_SYS_INTSRAM +CONFIG_SYS_INTSRAMSZ +CONFIG_SYS_INT_FLASH_BASE +CONFIG_SYS_INT_FLASH_ENABLE +CONFIG_SYS_IOCTRL_MUX_DDR +CONFIG_SYS_IOPORT +CONFIG_SYS_IO_BASE +CONFIG_SYS_IPBCLK_EQUALS_XLBCLK +CONFIG_SYS_IPBSPEED_133 +CONFIG_SYS_IR_REG_BASE_ADDR +CONFIG_SYS_ISA_BASE +CONFIG_SYS_ISA_IO +CONFIG_SYS_ISA_IO_BASE_ADDRESS +CONFIG_SYS_ISA_IO_OFFSET +CONFIG_SYS_ISA_IO_STRIDE +CONFIG_SYS_ISA_MEM +CONFIG_SYS_ISB +CONFIG_SYS_ISRAM_BASE +CONFIG_SYS_IVM_EEPROM_ADR +CONFIG_SYS_IVM_EEPROM_MAX_LEN +CONFIG_SYS_IVM_EEPROM_PAGE_LEN +CONFIG_SYS_JFFS2_FIRST_BANK +CONFIG_SYS_JFFS2_FIRST_SECTOR +CONFIG_SYS_JFFS2_MEM_NAND +CONFIG_SYS_JFFS2_NUM_BANKS +CONFIG_SYS_JFFS2_SORT_FRAGMENTS +CONFIG_SYS_JFFS_CUSTOM_PART +CONFIG_SYS_JFFS_SINGLE_PART +CONFIG_SYS_KBYTES_SDRAM +CONFIG_SYS_KEY_REG_BASE_ADDR +CONFIG_SYS_KMBEC_FPGA_BASE +CONFIG_SYS_KMBEC_FPGA_SIZE +CONFIG_SYS_KWD_CONFIG +CONFIG_SYS_KW_SPI_MPP +CONFIG_SYS_L2 +CONFIG_SYS_L2CACHE_OFF +CONFIG_SYS_L2_PL310 +CONFIG_SYS_L2_SIZE +CONFIG_SYS_L3_SIZE +CONFIG_SYS_LADOPT +CONFIG_SYS_LARGE_FLASH +CONFIG_SYS_LATCH0_BOOT +CONFIG_SYS_LATCH0_RESET +CONFIG_SYS_LATCH1_BOOT +CONFIG_SYS_LATCH1_RESET +CONFIG_SYS_LATCH_ADDR +CONFIG_SYS_LATCH_BASE +CONFIG_SYS_LBAPP1_BASE +CONFIG_SYS_LBAPP1_BASE_PHYS +CONFIG_SYS_LBAPP1_BR_PRELIM +CONFIG_SYS_LBAPP1_OR_PRELIM +CONFIG_SYS_LBAPP2_BASE +CONFIG_SYS_LBAPP2_BASE_PHYS +CONFIG_SYS_LBAPP2_BR_PRELIM +CONFIG_SYS_LBAPP2_OR_PRELIM +CONFIG_SYS_LBC0_BASE +CONFIG_SYS_LBC0_BASE_PHYS +CONFIG_SYS_LBC1_BASE +CONFIG_SYS_LBC1_BASE_PHYS +CONFIG_SYS_LBCR_ADDR +CONFIG_SYS_LBC_ADDR +CONFIG_SYS_LBC_BASE +CONFIG_SYS_LBC_BASE_PHYS_LOW +CONFIG_SYS_LBC_CACHE_BASE +CONFIG_SYS_LBC_FLASH_BASE +CONFIG_SYS_LBC_LBCR +CONFIG_SYS_LBC_LCRR +CONFIG_SYS_LBC_LSDMR_1 +CONFIG_SYS_LBC_LSDMR_2 +CONFIG_SYS_LBC_LSDMR_3 +CONFIG_SYS_LBC_LSDMR_4 +CONFIG_SYS_LBC_LSDMR_5 +CONFIG_SYS_LBC_LSDMR_ARFRSH +CONFIG_SYS_LBC_LSDMR_COMMON +CONFIG_SYS_LBC_LSDMR_MRW +CONFIG_SYS_LBC_LSDMR_PCHALL +CONFIG_SYS_LBC_LSDMR_RFEN +CONFIG_SYS_LBC_LSRT +CONFIG_SYS_LBC_MRTPR +CONFIG_SYS_LBC_NONCACHE_BASE +CONFIG_SYS_LBC_SDRAM_BASE +CONFIG_SYS_LBC_SDRAM_BASE_PHYS +CONFIG_SYS_LBC_SDRAM_SIZE +CONFIG_SYS_LBLAWAR0_PRELIM +CONFIG_SYS_LBLAWAR1_PRELIM +CONFIG_SYS_LBLAWAR2_PRELIM +CONFIG_SYS_LBLAWAR3_PRELIM +CONFIG_SYS_LBLAWAR4_PRELIM +CONFIG_SYS_LBLAWAR5_PRELIM +CONFIG_SYS_LBLAWAR6_PRELIM +CONFIG_SYS_LBLAWAR7_PRELIM +CONFIG_SYS_LBLAWBAR0_PRELIM +CONFIG_SYS_LBLAWBAR1_PRELIM +CONFIG_SYS_LBLAWBAR2_PRELIM +CONFIG_SYS_LBLAWBAR3_PRELIM +CONFIG_SYS_LBLAWBAR4_PRELIM +CONFIG_SYS_LBLAWBAR5_PRELIM +CONFIG_SYS_LBLAWBAR6_PRELIM +CONFIG_SYS_LBLAWBAR7_PRELIM +CONFIG_SYS_LB_SDRAM +CONFIG_SYS_LCD0_RST +CONFIG_SYS_LCD1_RST +CONFIG_SYS_LCD_BASE +CONFIG_SYS_LCD_ENDIAN +CONFIG_SYS_LCRR_CLKDIV +CONFIG_SYS_LCRR_DBYP +CONFIG_SYS_LCRR_EADC +CONFIG_SYS_LDB_CLOCK +CONFIG_SYS_LDSCRIPT +CONFIG_SYS_LED_ADDR +CONFIG_SYS_LED_BASE +CONFIG_SYS_LED_DISP_BASE +CONFIG_SYS_LIME_BASE +CONFIG_SYS_LIME_BASE_0 +CONFIG_SYS_LIME_BASE_1 +CONFIG_SYS_LIME_BASE_2 +CONFIG_SYS_LIME_BASE_3 +CONFIG_SYS_LIME_CLOCK_100MHZ +CONFIG_SYS_LIME_CLOCK_133MHZ +CONFIG_SYS_LIME_MMR +CONFIG_SYS_LIME_SDRAM_CLOCK +CONFIG_SYS_LIME_SIZE +CONFIG_SYS_LINUX_LOWMEM_MAX_SIZE +CONFIG_SYS_LITTLE_ENDIAN +CONFIG_SYS_LOADS_BAUD_CHANGE +CONFIG_SYS_LOAD_ADDR +CONFIG_SYS_LOAD_ADDR2 +CONFIG_SYS_LOCAL_CONF_REGS +CONFIG_SYS_LONGHELP +CONFIG_SYS_LOW +CONFIG_SYS_LOWBOOT +CONFIG_SYS_LOWBOOT16 +CONFIG_SYS_LOWBOOT32 +CONFIG_SYS_LOWMEM_BASE +CONFIG_SYS_LOW_RES_TIMER +CONFIG_SYS_LPAE_SDRAM_BASE +CONFIG_SYS_LPC32XX_UART +CONFIG_SYS_LS1_DDR_BLOCK1_SIZE +CONFIG_SYS_LS2_DDR_BLOCK1_SIZE +CONFIG_SYS_LS_MC_AIOP_IMG_MAX_LENGTH +CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS +CONFIG_SYS_LS_MC_DPC_ADDR +CONFIG_SYS_LS_MC_DPC_IN_DDR +CONFIG_SYS_LS_MC_DPC_IN_NOR +CONFIG_SYS_LS_MC_DPC_MAX_LENGTH +CONFIG_SYS_LS_MC_DPL_ADDR +CONFIG_SYS_LS_MC_DPL_IN_DDR +CONFIG_SYS_LS_MC_DPL_IN_NOR +CONFIG_SYS_LS_MC_DPL_MAX_LENGTH +CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET +CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE +CONFIG_SYS_LS_MC_DRAM_DPC_OFFSET +CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET +CONFIG_SYS_LS_MC_FW_ADDR +CONFIG_SYS_LS_MC_FW_IN_ +CONFIG_SYS_LS_MC_FW_IN_DDR +CONFIG_SYS_LS_MC_FW_IN_NOR +CONFIG_SYS_LS_MC_FW_LENGTH +CONFIG_SYS_LS_PPA_FW_ADDR +CONFIG_SYS_LS_PPA_FW_IN_ +CONFIG_SYS_LS_PPA_FW_IN_XIP +CONFIG_SYS_M41T11_BASE_YEAR +CONFIG_SYS_M41T11_EXT_CENTURY_DATA +CONFIG_SYS_MACB0_BASE +CONFIG_SYS_MACB1_BASE +CONFIG_SYS_MACB2_BASE +CONFIG_SYS_MACB3_BASE +CONFIG_SYS_MAIN_PWR_ON +CONFIG_SYS_MALLOC_BASE +CONFIG_SYS_MALLOC_CLEAR_ON_INIT +CONFIG_SYS_MALLOC_END +CONFIG_SYS_MALLOC_F +CONFIG_SYS_MALLOC_F_LEN +CONFIG_SYS_MALLOC_LEN +CONFIG_SYS_MALLOC_SIMPLE +CONFIG_SYS_MAMR +CONFIG_SYS_MAMR_10COL +CONFIG_SYS_MAMR_8COL +CONFIG_SYS_MAMR_9COL +CONFIG_SYS_MAMR_PTA +CONFIG_SYS_MAPLE +CONFIG_SYS_MAPLE_MEM_PHYS +CONFIG_SYS_MAPPED_RAM_BASE +CONFIG_SYS_MARUBUN_IO +CONFIG_SYS_MARUBUN_MRSHPC +CONFIG_SYS_MARUBUN_MW1 +CONFIG_SYS_MARUBUN_MW2 +CONFIG_SYS_MASK +CONFIG_SYS_MASTER_CLOCK +CONFIG_SYS_MATRIX_EBI0CSA_VAL +CONFIG_SYS_MATRIX_EBICSA_VAL +CONFIG_SYS_MATRIX_MCFG_REMAP +CONFIG_SYS_MAXARGS +CONFIG_SYS_MAXIDLE +CONFIG_SYS_MAX_DATAFLASH_BANKS +CONFIG_SYS_MAX_DDR_BAT_SIZE +CONFIG_SYS_MAX_DOC_DEVICE +CONFIG_SYS_MAX_FLASH_BANKS +CONFIG_SYS_MAX_FLASH_BANKS_DETECT +CONFIG_SYS_MAX_FLASH_SECT +CONFIG_SYS_MAX_I2C_BUS +CONFIG_SYS_MAX_MTD_BANKS +CONFIG_SYS_MAX_NAND_CHIPS +CONFIG_SYS_MAX_NAND_DEVICE +CONFIG_SYS_MAX_PCI_EPS +CONFIG_SYS_MAX_RAM_SIZE +CONFIG_SYS_MB862 +CONFIG_SYS_MBAR +CONFIG_SYS_MBAR2 +CONFIG_SYS_MBIO_BASE +CONFIG_SYS_MBYTES_RAM +CONFIG_SYS_MBYTES_SDRAM +CONFIG_SYS_MCATT0_VAL +CONFIG_SYS_MCATT1_VAL +CONFIG_SYS_MCFRRTC_BASE +CONFIG_SYS_MCFRTC_BASE +CONFIG_SYS_MCF_SYNCR +CONFIG_SYS_MCIO0_VAL +CONFIG_SYS_MCIO1_VAL +CONFIG_SYS_MCKR +CONFIG_SYS_MCKR1_VAL +CONFIG_SYS_MCKR2_VAL +CONFIG_SYS_MCKR_CSS +CONFIG_SYS_MCKR_VAL +CONFIG_SYS_MCLINK_MAX +CONFIG_SYS_MCMEM0_VAL +CONFIG_SYS_MCMEM1_VAL +CONFIG_SYS_MC_RSV_MEM_ALIGN +CONFIG_SYS_MDC1_PIN +CONFIG_SYS_MDCNFG_VAL +CONFIG_SYS_MDC_PIN +CONFIG_SYS_MDDRCGRP_HIPRIO_CFG +CONFIG_SYS_MDDRCGRP_LUT0_AL +CONFIG_SYS_MDDRCGRP_LUT0_AU +CONFIG_SYS_MDDRCGRP_LUT0_ML +CONFIG_SYS_MDDRCGRP_LUT0_MU +CONFIG_SYS_MDDRCGRP_LUT1_AL +CONFIG_SYS_MDDRCGRP_LUT1_AU +CONFIG_SYS_MDDRCGRP_LUT1_ML +CONFIG_SYS_MDDRCGRP_LUT1_MU +CONFIG_SYS_MDDRCGRP_LUT2_AL +CONFIG_SYS_MDDRCGRP_LUT2_AU +CONFIG_SYS_MDDRCGRP_LUT2_ML +CONFIG_SYS_MDDRCGRP_LUT2_MU +CONFIG_SYS_MDDRCGRP_LUT3_AL +CONFIG_SYS_MDDRCGRP_LUT3_AU +CONFIG_SYS_MDDRCGRP_LUT3_ML +CONFIG_SYS_MDDRCGRP_LUT3_MU +CONFIG_SYS_MDDRCGRP_LUT4_AL +CONFIG_SYS_MDDRCGRP_LUT4_AU +CONFIG_SYS_MDDRCGRP_LUT4_ML +CONFIG_SYS_MDDRCGRP_LUT4_MU +CONFIG_SYS_MDDRCGRP_PM_CFG1 +CONFIG_SYS_MDDRCGRP_PM_CFG2 +CONFIG_SYS_MDDRC_SYS_CFG +CONFIG_SYS_MDDRC_SYS_CFG_ALT1 +CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA +CONFIG_SYS_MDDRC_SYS_CFG_EN +CONFIG_SYS_MDDRC_TIME_CFG0 +CONFIG_SYS_MDDRC_TIME_CFG0_ALT1 +CONFIG_SYS_MDDRC_TIME_CFG1 +CONFIG_SYS_MDDRC_TIME_CFG1_ALT1 +CONFIG_SYS_MDDRC_TIME_CFG1_ELPIDA +CONFIG_SYS_MDDRC_TIME_CFG2 +CONFIG_SYS_MDDRC_TIME_CFG2_ALT1 +CONFIG_SYS_MDDRC_TIME_CFG2_ELPIDA +CONFIG_SYS_MDIO1_OFFSET +CONFIG_SYS_MDIO1_PIN +CONFIG_SYS_MDIO_BASE_ADDR +CONFIG_SYS_MDIO_PIN +CONFIG_SYS_MDMRS_VAL +CONFIG_SYS_MDREFR_VAL +CONFIG_SYS_MEASURE_CPUCLK +CONFIG_SYS_MECR_VAL +CONFIG_SYS_MEMAC_LITTLE_ENDIAN +CONFIG_SYS_MEMDEBUG +CONFIG_SYS_MEMORY_BASE +CONFIG_SYS_MEMORY_SIZE +CONFIG_SYS_MEMORY_TOP +CONFIG_SYS_MEMTEST_END +CONFIG_SYS_MEMTEST_SCRATCH +CONFIG_SYS_MEMTEST_START +CONFIG_SYS_MEM_MAP +CONFIG_SYS_MEM_RESERVE_SECURE +CONFIG_SYS_MEM_SIZE +CONFIG_SYS_MEM_TOP_HIDE +CONFIG_SYS_MFD +CONFIG_SYS_MHZ +CONFIG_SYS_MICRON_BMODE +CONFIG_SYS_MICRON_BMODE_PARAM +CONFIG_SYS_MICRON_BMODE_RSTDLL +CONFIG_SYS_MICRON_EMODE +CONFIG_SYS_MICRON_EMODE2 +CONFIG_SYS_MICRON_EMODE3 +CONFIG_SYS_MICRON_EMODE_PARAM +CONFIG_SYS_MICRON_EMR +CONFIG_SYS_MICRON_EMR2 +CONFIG_SYS_MICRON_EMR3 +CONFIG_SYS_MICRON_EMR_OCD +CONFIG_SYS_MICRON_INIT_DEV_OP +CONFIG_SYS_MII_MODE +CONFIG_SYS_MIPS_CACHE_INIT_RAM_LOAD +CONFIG_SYS_MIPS_CACHE_MODE +CONFIG_SYS_MIPS_TIMER_FREQ +CONFIG_SYS_MMCSD_FS_BOOT_PARTITION +CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR +CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS +CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR +CONFIG_SYS_MMC_BASE +CONFIG_SYS_MMC_CD_PIN +CONFIG_SYS_MMC_CLK_OD +CONFIG_SYS_MMC_ENV_DEV +CONFIG_SYS_MMC_ENV_PART +CONFIG_SYS_MMC_IMG_LOAD_PART +CONFIG_SYS_MMC_MAX_BLK_COUNT +CONFIG_SYS_MMC_MAX_DEVICE +CONFIG_SYS_MMC_U_BOOT_DST +CONFIG_SYS_MMC_U_BOOT_OFFS +CONFIG_SYS_MMC_U_BOOT_SIZE +CONFIG_SYS_MMC_U_BOOT_START +CONFIG_SYS_MMDC_CORE_ADDR_PARTITION +CONFIG_SYS_MMDC_CORE_CONTROL_1 +CONFIG_SYS_MMDC_CORE_CONTROL_2 +CONFIG_SYS_MMDC_CORE_MISC +CONFIG_SYS_MMDC_CORE_ODT_TIMING +CONFIG_SYS_MMDC_CORE_OUT_OF_RESET_DELAY +CONFIG_SYS_MMDC_CORE_PWR_DOWN_CTRL +CONFIG_SYS_MMDC_CORE_PWR_SAV_CTRL_STAT +CONFIG_SYS_MMDC_CORE_RDWR_CMD_DELAY +CONFIG_SYS_MMDC_CORE_REFRESH_CTL +CONFIG_SYS_MMDC_CORE_TIMING_CFG_0 +CONFIG_SYS_MMDC_CORE_TIMING_CFG_1 +CONFIG_SYS_MMDC_CORE_TIMING_CFG_2 +CONFIG_SYS_MMDC_PHY_MEASURE_UNIT +CONFIG_SYS_MMDC_PHY_ODT_CTRL +CONFIG_SYS_MMDC_PHY_RD_DLY_LINES_CFG +CONFIG_SYS_MMDC_PHY_ZQ_HW_CTRL +CONFIG_SYS_MM_TOP_HIDE +CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO +CONFIG_SYS_MONAHANS_TURBO_RUN_MODE_RATIO +CONFIG_SYS_MONITOR_ +CONFIG_SYS_MONITOR_BASE +CONFIG_SYS_MONITOR_BASE_EARLY +CONFIG_SYS_MONITOR_LEN +CONFIG_SYS_MONITOR_SEC +CONFIG_SYS_MOR_VAL +CONFIG_SYS_MPC512 +CONFIG_SYS_MPC512X_CLKIN +CONFIG_SYS_MPC5XXX_CLKIN +CONFIG_SYS_MPC8 +CONFIG_SYS_MPC83 +CONFIG_SYS_MPC85 +CONFIG_SYS_MPC85XX_NO_RESETVEC +CONFIG_SYS_MPC86 +CONFIG_SYS_MPC92469AC +CONFIG_SYS_MPEG_BASE +CONFIG_SYS_MPEG_SIZE +CONFIG_SYS_MPTPR +CONFIG_SYS_MPTPR_1BK_2K +CONFIG_SYS_MPTPR_1BK_4K +CONFIG_SYS_MPTPR_1BK_8K +CONFIG_SYS_MPTPR_2BK_2K +CONFIG_SYS_MPTPR_2BK_4K +CONFIG_SYS_MPTPR_2BK_8K +CONFIG_SYS_MPUCLK +CONFIG_SYS_MRAM_BASE +CONFIG_SYS_MRAM_SIZE +CONFIG_SYS_MRS_OFFS +CONFIG_SYS_MSC0_VAL +CONFIG_SYS_MSC1_VAL +CONFIG_SYS_MSC2_VAL +CONFIG_SYS_MTDPARTS_RUNTIME +CONFIG_SYS_MVEBU_PLL_CLOCK +CONFIG_SYS_MVFS +CONFIG_SYS_MX5_CLK32 +CONFIG_SYS_MX5_HCLK +CONFIG_SYS_MX6_CLK32 +CONFIG_SYS_MX6_HCLK +CONFIG_SYS_MX7_CLK32 +CONFIG_SYS_MX7_HCLK +CONFIG_SYS_MXC_I2C1_SLAVE +CONFIG_SYS_MXC_I2C1_SPEED +CONFIG_SYS_MXC_I2C2_SLAVE +CONFIG_SYS_MXC_I2C2_SPEED +CONFIG_SYS_MXC_I2C3_SLAVE +CONFIG_SYS_MXC_I2C3_SPEED +CONFIG_SYS_MXC_I2C4_SLAVE +CONFIG_SYS_MXC_I2C4_SPEED +CONFIG_SYS_MXS_VDD5V_ONLY +CONFIG_SYS_NAND2_ADDR +CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST +CONFIG_SYS_NAND_4_ADDR_CYCLE +CONFIG_SYS_NAND_5_ADDR_CYCLE +CONFIG_SYS_NAND_ACTL_ALE +CONFIG_SYS_NAND_ACTL_CLE +CONFIG_SYS_NAND_ACTL_DELAY +CONFIG_SYS_NAND_ACTL_NCE +CONFIG_SYS_NAND_ADDR +CONFIG_SYS_NAND_ALE +CONFIG_SYS_NAND_AMASK +CONFIG_SYS_NAND_BAD_BLOCK_POS +CONFIG_SYS_NAND_BASE +CONFIG_SYS_NAND_BASE2 +CONFIG_SYS_NAND_BASE_LIST +CONFIG_SYS_NAND_BASE_PHYS +CONFIG_SYS_NAND_BCR +CONFIG_SYS_NAND_BLOCK_SIZE +CONFIG_SYS_NAND_BOOT +CONFIG_SYS_NAND_BR_PRELIM +CONFIG_SYS_NAND_BUSWIDTH_16 +CONFIG_SYS_NAND_BUSWIDTH_16BIT +CONFIG_SYS_NAND_BUSWIDTH_16_BIT +CONFIG_SYS_NAND_CE +CONFIG_SYS_NAND_CLE +CONFIG_SYS_NAND_CS +CONFIG_SYS_NAND_CSOR +CONFIG_SYS_NAND_CSPR +CONFIG_SYS_NAND_CSPR_EXT +CONFIG_SYS_NAND_DATA_BASE +CONFIG_SYS_NAND_DBW_16 +CONFIG_SYS_NAND_DBW_8 +CONFIG_SYS_NAND_DDR_LAW +CONFIG_SYS_NAND_DENALI_64BIT +CONFIG_SYS_NAND_ECCBYTES +CONFIG_SYS_NAND_ECCPOS +CONFIG_SYS_NAND_ECCSIZE +CONFIG_SYS_NAND_ECCSTEPS +CONFIG_SYS_NAND_ECCTOTAL +CONFIG_SYS_NAND_ECC_BASE +CONFIG_SYS_NAND_ENABLE_PIN +CONFIG_SYS_NAND_ENABLE_PIN_SPL +CONFIG_SYS_NAND_FTIM0 +CONFIG_SYS_NAND_FTIM1 +CONFIG_SYS_NAND_FTIM2 +CONFIG_SYS_NAND_FTIM3 +CONFIG_SYS_NAND_HW_ECC +CONFIG_SYS_NAND_HW_ECC_OOBFIRST +CONFIG_SYS_NAND_LARGEPAGE +CONFIG_SYS_NAND_LBLAWAR_PRELIM +CONFIG_SYS_NAND_LBLAWBAR_PRELIM +CONFIG_SYS_NAND_MASK_ALE +CONFIG_SYS_NAND_MASK_CLE +CONFIG_SYS_NAND_MAX_CHIPS +CONFIG_SYS_NAND_MAX_DEVICE +CONFIG_SYS_NAND_MAX_ECCPOS +CONFIG_SYS_NAND_MAX_OOBFREE +CONFIG_SYS_NAND_MX7_GPMI_62_ECC_BYTES +CONFIG_SYS_NAND_NO_SUBPAGE +CONFIG_SYS_NAND_NO_SUBPAGE_WRITE +CONFIG_SYS_NAND_ONFI_DETECTION +CONFIG_SYS_NAND_OOBSIZE +CONFIG_SYS_NAND_OR_PRELIM +CONFIG_SYS_NAND_PAGE_2K +CONFIG_SYS_NAND_PAGE_4K +CONFIG_SYS_NAND_PAGE_COUNT +CONFIG_SYS_NAND_PAGE_SIZE +CONFIG_SYS_NAND_QUIET +CONFIG_SYS_NAND_RDY +CONFIG_SYS_NAND_READY_PIN +CONFIG_SYS_NAND_REGS_BASE +CONFIG_SYS_NAND_SELECT_DEVICE +CONFIG_SYS_NAND_SELF_INIT +CONFIG_SYS_NAND_SIZE +CONFIG_SYS_NAND_SKIP_BAD_DOT_I +CONFIG_SYS_NAND_SPL_KERNEL_OFFS +CONFIG_SYS_NAND_SPL_SIZE +CONFIG_SYS_NAND_USE_FLASH_BBT +CONFIG_SYS_NAND_U_BOOT_DST +CONFIG_SYS_NAND_U_BOOT_OFFS +CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND +CONFIG_SYS_NAND_U_BOOT_RELOC +CONFIG_SYS_NAND_U_BOOT_RELOC_SP +CONFIG_SYS_NAND_U_BOOT_SIZE +CONFIG_SYS_NAND_U_BOOT_START +CONFIG_SYS_NAND_WINDOW_SIZE +CONFIG_SYS_NDFC_EBC0_CFG +CONFIG_SYS_NETA_INTERFACE_TYPE +CONFIG_SYS_NONCACHED_MEMORY +CONFIG_SYS_NOR0_CSPR +CONFIG_SYS_NOR0_CSPR_EARLY +CONFIG_SYS_NOR0_CSPR_EXT +CONFIG_SYS_NOR1SZ +CONFIG_SYS_NOR1_CSPR +CONFIG_SYS_NOR1_CSPR_EARLY +CONFIG_SYS_NOR1_CSPR_EXT +CONFIG_SYS_NOR_AMASK +CONFIG_SYS_NOR_AMASK_EARLY +CONFIG_SYS_NOR_BR_PRELIM +CONFIG_SYS_NOR_CS +CONFIG_SYS_NOR_CSOR +CONFIG_SYS_NOR_CSPR +CONFIG_SYS_NOR_CSPR_EXT +CONFIG_SYS_NOR_FTIM0 +CONFIG_SYS_NOR_FTIM1 +CONFIG_SYS_NOR_FTIM2 +CONFIG_SYS_NOR_FTIM3 +CONFIG_SYS_NOR_OR_PRELIM +CONFIG_SYS_NO_DCACHE +CONFIG_SYS_NO_FLASH +CONFIG_SYS_NROF_PAGES_NAND_SPL +CONFIG_SYS_NROF_UBL_HEADER +CONFIG_SYS_NR_PIOS +CONFIG_SYS_NR_VM_REGIONS +CONFIG_SYS_NS16550 +CONFIG_SYS_NS16550_CLK +CONFIG_SYS_NS16550_CLK_DIV +CONFIG_SYS_NS16550_COM1 +CONFIG_SYS_NS16550_COM2 +CONFIG_SYS_NS16550_COM3 +CONFIG_SYS_NS16550_COM4 +CONFIG_SYS_NS16550_COM5 +CONFIG_SYS_NS16550_COM6 +CONFIG_SYS_NS16550_IER +CONFIG_SYS_NS16550_MEM32 +CONFIG_SYS_NS16550_PORT_MAPPED +CONFIG_SYS_NS16550_REG_SIZE +CONFIG_SYS_NS16550_SERIAL +CONFIG_SYS_NS87308_CS0_BASE +CONFIG_SYS_NS87308_CS0_CONF +CONFIG_SYS_NS87308_CS1_BASE +CONFIG_SYS_NS87308_CS1_CONF +CONFIG_SYS_NS87308_CS2_BASE +CONFIG_SYS_NS87308_CS2_CONF +CONFIG_SYS_NS87308_FDC +CONFIG_SYS_NS87308_FDC_BASE +CONFIG_SYS_NS87308_GPIO +CONFIG_SYS_NS87308_GPIO_BASE +CONFIG_SYS_NS87308_KBC1 +CONFIG_SYS_NS87308_KBC1_BASE +CONFIG_SYS_NS87308_KBC2 +CONFIG_SYS_NS87308_LPT_BASE +CONFIG_SYS_NS87308_MOUSE +CONFIG_SYS_NS87308_PARP +CONFIG_SYS_NS87308_PMC1 +CONFIG_SYS_NS87308_PMC2 +CONFIG_SYS_NS87308_PMC3 +CONFIG_SYS_NS87308_POWRMAN +CONFIG_SYS_NS87308_PS2MOD +CONFIG_SYS_NS87308_PWMAN_BASE +CONFIG_SYS_NS87308_RARP +CONFIG_SYS_NS87308_RTC_APC +CONFIG_SYS_NS87308_RTC_BASE +CONFIG_SYS_NS87308_UART1 +CONFIG_SYS_NS87308_UART1_BASE +CONFIG_SYS_NS87308_UART2 +CONFIG_SYS_NS87308_UART2_BASE +CONFIG_SYS_NUM_ADDR_MAP +CONFIG_SYS_NUM_CPC +CONFIG_SYS_NUM_DDR_CTLRS +CONFIG_SYS_NUM_FM1_10GEC +CONFIG_SYS_NUM_FM1_DTSEC +CONFIG_SYS_NUM_FM2_10GEC +CONFIG_SYS_NUM_FM2_DTSEC +CONFIG_SYS_NUM_FMAN +CONFIG_SYS_NUM_I2C_ADAPTERS +CONFIG_SYS_NUM_I2C_BUSES +CONFIG_SYS_NUM_IRQS +CONFIG_SYS_NUM_TLBCAMS +CONFIG_SYS_NVRAM_ACCESS_ROUTINE +CONFIG_SYS_NVRAM_BASE +CONFIG_SYS_NVRAM_BASE_ADDR +CONFIG_SYS_NVRAM_SIZE +CONFIG_SYS_OBIR +CONFIG_SYS_OCM_BASE +CONFIG_SYS_OCM_DATA_ADDR +CONFIG_SYS_OCM_DATA_SIZE +CONFIG_SYS_OCM_SIZE +CONFIG_SYS_OCM_STATUS_ADDR +CONFIG_SYS_OCM_STATUS_FAIL +CONFIG_SYS_OCM_STATUS_MASK +CONFIG_SYS_OCM_STATUS_OK +CONFIG_SYS_OHCI_BE_CONTROLLER +CONFIG_SYS_OHCI_SWAP_REG_ACCESS +CONFIG_SYS_OHCI_USE_NPS +CONFIG_SYS_OMAP24_I2C_SLAVE +CONFIG_SYS_OMAP24_I2C_SLAVE1 +CONFIG_SYS_OMAP24_I2C_SLAVE2 +CONFIG_SYS_OMAP24_I2C_SLAVE3 +CONFIG_SYS_OMAP24_I2C_SLAVE4 +CONFIG_SYS_OMAP24_I2C_SPEED +CONFIG_SYS_OMAP24_I2C_SPEED1 +CONFIG_SYS_OMAP24_I2C_SPEED2 +CONFIG_SYS_OMAP24_I2C_SPEED3 +CONFIG_SYS_OMAP24_I2C_SPEED4 +CONFIG_SYS_OMAP24_I2C_SPEED_PSOC +CONFIG_SYS_OMAP_ABE_SYSCK +CONFIG_SYS_ONENAND_BASE +CONFIG_SYS_ONENAND_BLOCK_SIZE +CONFIG_SYS_ONENAND_PAGE_SIZE +CONFIG_SYS_OPENRISC_TMR_HZ +CONFIG_SYS_OPER_FLASH +CONFIG_SYS_OR0_64M +CONFIG_SYS_OR0_8M +CONFIG_SYS_OR0_PRELIM +CONFIG_SYS_OR0_REMAP +CONFIG_SYS_OR1 +CONFIG_SYS_OR10_PRELIM +CONFIG_SYS_OR11_PRELIM +CONFIG_SYS_OR1_PRELIM +CONFIG_SYS_OR1_REMAP +CONFIG_SYS_OR2_PRELIM +CONFIG_SYS_OR3_CAN +CONFIG_SYS_OR3_PRELIM +CONFIG_SYS_OR4_PRELIM +CONFIG_SYS_OR5_ISP1362 +CONFIG_SYS_OR5_PRELIM +CONFIG_SYS_OR5_REMAP +CONFIG_SYS_OR6_64M +CONFIG_SYS_OR6_8M +CONFIG_SYS_OR6_PRELIM +CONFIG_SYS_OR7_PRELIM +CONFIG_SYS_OR8_PRELIM +CONFIG_SYS_OR9_PRELIM +CONFIG_SYS_OR_TIMING_FLASH +CONFIG_SYS_OR_TIMING_FLASH_AT_50MHZ +CONFIG_SYS_OR_TIMING_MRAM +CONFIG_SYS_OR_TIMING_SDRAM +CONFIG_SYS_OSC0_HZ +CONFIG_SYS_OSC1_HZ +CONFIG_SYS_OSCIN_FREQ +CONFIG_SYS_OSC_CLK +CONFIG_SYS_OSD_DH +CONFIG_SYS_OSD_SCREENS +CONFIG_SYS_OSPR_OFFSET +CONFIG_SYS_OS_BASE +CONFIG_SYS_P4080_ERRATUM_CPU22 +CONFIG_SYS_P4080_ERRATUM_PCIE_A003 +CONFIG_SYS_P4080_ERRATUM_SERDES8 +CONFIG_SYS_P4080_ERRATUM_SERDES9 +CONFIG_SYS_P4080_ERRATUM_SERDES_A001 +CONFIG_SYS_P4080_ERRATUM_SERDES_A005 +CONFIG_SYS_PACNT +CONFIG_SYS_PADAT +CONFIG_SYS_PADDR +CONFIG_SYS_PAGE_SIZE +CONFIG_SYS_PAMU_ADDR +CONFIG_SYS_PASPAR +CONFIG_SYS_PAXE_BASE +CONFIG_SYS_PAXE_SIZE +CONFIG_SYS_PBCNT +CONFIG_SYS_PBDAT +CONFIG_SYS_PBDDR +CONFIG_SYS_PBI_FLASH_BASE +CONFIG_SYS_PBI_FLASH_WINDOW +CONFIG_SYS_PBSIZE +CONFIG_SYS_PB_LED +CONFIG_SYS_PCA953X_BRD_CFG0 +CONFIG_SYS_PCA953X_BRD_CFG1 +CONFIG_SYS_PCA953X_BRD_CFG2 +CONFIG_SYS_PCA953X_C0_FLASH_PASS_CS +CONFIG_SYS_PCA953X_C0_SER0_EN +CONFIG_SYS_PCA953X_C0_SER0_MODE +CONFIG_SYS_PCA953X_C0_SER1_EN +CONFIG_SYS_PCA953X_C0_SER1_MODE +CONFIG_SYS_PCA953X_C0_VCORE_VID2 +CONFIG_SYS_PCA953X_C0_VCORE_VID3 +CONFIG_SYS_PCA953X_EREADY +CONFIG_SYS_PCA953X_FLASH_PASS_CS +CONFIG_SYS_PCA953X_GPIO_VPX0 +CONFIG_SYS_PCA953X_GPIO_VPX1 +CONFIG_SYS_PCA953X_GPIO_VPX2 +CONFIG_SYS_PCA953X_GPIO_VPX3 +CONFIG_SYS_PCA953X_MC_GPIO0 +CONFIG_SYS_PCA953X_MC_GPIO1 +CONFIG_SYS_PCA953X_MC_GPIO2 +CONFIG_SYS_PCA953X_MC_GPIO3 +CONFIG_SYS_PCA953X_MC_GPIO4 +CONFIG_SYS_PCA953X_MC_GPIO5 +CONFIG_SYS_PCA953X_MC_GPIO6 +CONFIG_SYS_PCA953X_MC_GPIO7 +CONFIG_SYS_PCA953X_MONARCH +CONFIG_SYS_PCA953X_NVM_WP +CONFIG_SYS_PCA953X_P0_GA0 +CONFIG_SYS_PCA953X_P0_GA1 +CONFIG_SYS_PCA953X_P0_GA2 +CONFIG_SYS_PCA953X_P0_GA3 +CONFIG_SYS_PCA953X_P0_GA4 +CONFIG_SYS_PCA953X_P0_GAP +CONFIG_SYS_PCA953X_P14_IO0 +CONFIG_SYS_PCA953X_P14_IO1 +CONFIG_SYS_PCA953X_P14_IO2 +CONFIG_SYS_PCA953X_P14_IO3 +CONFIG_SYS_PCA953X_P14_IO4 +CONFIG_SYS_PCA953X_P14_IO5 +CONFIG_SYS_PCA953X_P14_IO6 +CONFIG_SYS_PCA953X_P14_IO7 +CONFIG_SYS_PCA953X_P1_SYSEN +CONFIG_SYS_PCA953X_PLUG_GPIO0 +CONFIG_SYS_PCA953X_PMC0_EREADY +CONFIG_SYS_PCA953X_PMC0_MONARCH +CONFIG_SYS_PCA953X_PMC_EREADY +CONFIG_SYS_PCA953X_PMC_MONARCH +CONFIG_SYS_PCA953X_PMC_PRESENT +CONFIG_SYS_PCA953X_VPX_FRU_WRCTL +CONFIG_SYS_PCA953X_VPX_GPIO0 +CONFIG_SYS_PCA953X_VPX_GPIO1 +CONFIG_SYS_PCA953X_VPX_GPIO2 +CONFIG_SYS_PCA953X_VPX_GPIO3 +CONFIG_SYS_PCA953X_XMC0_BIST +CONFIG_SYS_PCA953X_XMC0_MVMR0 +CONFIG_SYS_PCA953X_XMC0_ROOT0 +CONFIG_SYS_PCA953X_XMC0_WAKE +CONFIG_SYS_PCA953X_XMC_BIST +CONFIG_SYS_PCA953X_XMC_GA0 +CONFIG_SYS_PCA953X_XMC_GA1 +CONFIG_SYS_PCA953X_XMC_GA2 +CONFIG_SYS_PCA953X_XMC_PRESENT +CONFIG_SYS_PCA953X_XMC_ROOT0 +CONFIG_SYS_PCA953X_XMC_WAKE +CONFIG_SYS_PCCNT +CONFIG_SYS_PCDAT +CONFIG_SYS_PCDDR +CONFIG_SYS_PCI +CONFIG_SYS_PCI0_IO_SPACE +CONFIG_SYS_PCI1_ADDR +CONFIG_SYS_PCI1_IO_BASE +CONFIG_SYS_PCI1_IO_BUS +CONFIG_SYS_PCI1_IO_PHYS +CONFIG_SYS_PCI1_IO_SIZE +CONFIG_SYS_PCI1_IO_VIRT +CONFIG_SYS_PCI1_MEM_BASE +CONFIG_SYS_PCI1_MEM_BUS +CONFIG_SYS_PCI1_MEM_PHYS +CONFIG_SYS_PCI1_MEM_SIZE +CONFIG_SYS_PCI1_MEM_VIRT +CONFIG_SYS_PCI1_MMIO_BASE +CONFIG_SYS_PCI1_MMIO_PHYS +CONFIG_SYS_PCI1_MMIO_SIZE +CONFIG_SYS_PCI2_ADDR +CONFIG_SYS_PCI2_IO_BASE +CONFIG_SYS_PCI2_IO_BUS +CONFIG_SYS_PCI2_IO_PHYS +CONFIG_SYS_PCI2_IO_SIZE +CONFIG_SYS_PCI2_IO_VIRT +CONFIG_SYS_PCI2_MEM_BASE +CONFIG_SYS_PCI2_MEM_BUS +CONFIG_SYS_PCI2_MEM_PHYS +CONFIG_SYS_PCI2_MEM_SIZE +CONFIG_SYS_PCI2_MEM_VIRT +CONFIG_SYS_PCI2_MMIO_BASE +CONFIG_SYS_PCI2_MMIO_PHYS +CONFIG_SYS_PCI2_MMIO_SIZE +CONFIG_SYS_PCI64_MEMORY_BUS +CONFIG_SYS_PCI9054_IOBASE +CONFIG_SYS_PCICLK_EQUALS_IPBCLK_DIV2 +CONFIG_SYS_PCIE +CONFIG_SYS_PCIE0_CFGBASE +CONFIG_SYS_PCIE0_CFGMASK +CONFIG_SYS_PCIE0_MEMBASE +CONFIG_SYS_PCIE0_REGBASE +CONFIG_SYS_PCIE0_UTLBASE +CONFIG_SYS_PCIE0_XCFGBASE +CONFIG_SYS_PCIE1_ADDR +CONFIG_SYS_PCIE1_BASE +CONFIG_SYS_PCIE1_CFGBASE +CONFIG_SYS_PCIE1_CFGMASK +CONFIG_SYS_PCIE1_CFG_BASE +CONFIG_SYS_PCIE1_CFG_SIZE +CONFIG_SYS_PCIE1_IO_BASE +CONFIG_SYS_PCIE1_IO_BUS +CONFIG_SYS_PCIE1_IO_PHYS +CONFIG_SYS_PCIE1_IO_PHYS_LOW +CONFIG_SYS_PCIE1_IO_SIZE +CONFIG_SYS_PCIE1_IO_VIRT +CONFIG_SYS_PCIE1_MEMBASE +CONFIG_SYS_PCIE1_MEM_BASE +CONFIG_SYS_PCIE1_MEM_BUS +CONFIG_SYS_PCIE1_MEM_PHYS +CONFIG_SYS_PCIE1_MEM_PHYS_HIGH +CONFIG_SYS_PCIE1_MEM_PHYS_LOW +CONFIG_SYS_PCIE1_MEM_SIZE +CONFIG_SYS_PCIE1_MEM_VIRT +CONFIG_SYS_PCIE1_NAME +CONFIG_SYS_PCIE1_PHYS_ADDR +CONFIG_SYS_PCIE1_PHYS_BASE +CONFIG_SYS_PCIE1_PHYS_SIZE +CONFIG_SYS_PCIE1_REGBASE +CONFIG_SYS_PCIE1_UTLBASE +CONFIG_SYS_PCIE1_VIRT_ADDR +CONFIG_SYS_PCIE1_XCFGBASE +CONFIG_SYS_PCIE2_ADDR +CONFIG_SYS_PCIE2_BASE +CONFIG_SYS_PCIE2_CFGBASE +CONFIG_SYS_PCIE2_CFG_BASE +CONFIG_SYS_PCIE2_CFG_SIZE +CONFIG_SYS_PCIE2_IO_BASE +CONFIG_SYS_PCIE2_IO_BUS +CONFIG_SYS_PCIE2_IO_PHYS +CONFIG_SYS_PCIE2_IO_PHYS_LOW +CONFIG_SYS_PCIE2_IO_SIZE +CONFIG_SYS_PCIE2_IO_VIRT +CONFIG_SYS_PCIE2_MEM_BASE +CONFIG_SYS_PCIE2_MEM_BUS +CONFIG_SYS_PCIE2_MEM_PHYS +CONFIG_SYS_PCIE2_MEM_PHYS_HIGH +CONFIG_SYS_PCIE2_MEM_PHYS_LOW +CONFIG_SYS_PCIE2_MEM_SIZE +CONFIG_SYS_PCIE2_MEM_VIRT +CONFIG_SYS_PCIE2_NAME +CONFIG_SYS_PCIE2_PHYS_ADDR +CONFIG_SYS_PCIE2_PHYS_BASE +CONFIG_SYS_PCIE2_PHYS_SIZE +CONFIG_SYS_PCIE2_REGBASE +CONFIG_SYS_PCIE2_VIRT_ADDR +CONFIG_SYS_PCIE2_XCFGBASE +CONFIG_SYS_PCIE3_ADDR +CONFIG_SYS_PCIE3_IO_BUS +CONFIG_SYS_PCIE3_IO_PHYS +CONFIG_SYS_PCIE3_IO_SIZE +CONFIG_SYS_PCIE3_IO_VIRT +CONFIG_SYS_PCIE3_MEM_BUS +CONFIG_SYS_PCIE3_MEM_BUS2 +CONFIG_SYS_PCIE3_MEM_PHYS +CONFIG_SYS_PCIE3_MEM_PHYS2 +CONFIG_SYS_PCIE3_MEM_SIZE +CONFIG_SYS_PCIE3_MEM_SIZE2 +CONFIG_SYS_PCIE3_MEM_VIRT +CONFIG_SYS_PCIE3_MEM_VIRT2 +CONFIG_SYS_PCIE3_NAME +CONFIG_SYS_PCIE3_PHYS_ADDR +CONFIG_SYS_PCIE3_PHYS_SIZE +CONFIG_SYS_PCIE4_ADDR +CONFIG_SYS_PCIE4_IO_BUS +CONFIG_SYS_PCIE4_IO_PHYS +CONFIG_SYS_PCIE4_IO_SIZE +CONFIG_SYS_PCIE4_IO_VIRT +CONFIG_SYS_PCIE4_MEM_BUS +CONFIG_SYS_PCIE4_MEM_PHYS +CONFIG_SYS_PCIE4_MEM_SIZE +CONFIG_SYS_PCIE4_MEM_VIRT +CONFIG_SYS_PCIE4_NAME +CONFIG_SYS_PCIE4_PHYS_ADDR +CONFIG_SYS_PCIE4_PHYS_SIZE +CONFIG_SYS_PCIE_ADDR_HIGH +CONFIG_SYS_PCIE_BASE +CONFIG_SYS_PCIE_CFG0_PHYS_OFF +CONFIG_SYS_PCIE_CFG0_SIZE +CONFIG_SYS_PCIE_CFG1_PHYS_OFF +CONFIG_SYS_PCIE_CFG1_SIZE +CONFIG_SYS_PCIE_INBOUND_BASE +CONFIG_SYS_PCIE_IO_BUS +CONFIG_SYS_PCIE_IO_PHYS_OFF +CONFIG_SYS_PCIE_IO_SIZE +CONFIG_SYS_PCIE_MEMBASE +CONFIG_SYS_PCIE_MEMSIZE +CONFIG_SYS_PCIE_MEM_BUS +CONFIG_SYS_PCIE_MEM_PHYS_OFF +CONFIG_SYS_PCIE_MEM_SIZE +CONFIG_SYS_PCIE_MMAP_SIZE +CONFIG_SYS_PCIE_NR_PORTS +CONFIG_SYS_PCIE_PHYS +CONFIG_SYS_PCIE_VIRT +CONFIG_SYS_PCIMSK0_MASK +CONFIG_SYS_PCIMSK1_MASK +CONFIG_SYS_PCISPEED_66 +CONFIG_SYS_PCI_64BIT +CONFIG_SYS_PCI_BAR0 +CONFIG_SYS_PCI_BAR1 +CONFIG_SYS_PCI_BAR2 +CONFIG_SYS_PCI_BAR3 +CONFIG_SYS_PCI_BAR4 +CONFIG_SYS_PCI_BAR5 +CONFIG_SYS_PCI_BASE +CONFIG_SYS_PCI_BOARD_FIXUP_IRQ +CONFIG_SYS_PCI_CACHE_LINE_SIZE +CONFIG_SYS_PCI_CFG_BASE +CONFIG_SYS_PCI_CFG_BUS +CONFIG_SYS_PCI_CFG_PHYS +CONFIG_SYS_PCI_CFG_SIZE +CONFIG_SYS_PCI_CLASSCODE +CONFIG_SYS_PCI_CLASSCODE_MONARCH +CONFIG_SYS_PCI_CLASSCODE_NONMONARCH +CONFIG_SYS_PCI_CON_DEVICE +CONFIG_SYS_PCI_EP_MEMORY_BASE +CONFIG_SYS_PCI_FORCE_PCI_CONV +CONFIG_SYS_PCI_IO_BASE +CONFIG_SYS_PCI_IO_BUS +CONFIG_SYS_PCI_IO_PHYS +CONFIG_SYS_PCI_IO_SIZE +CONFIG_SYS_PCI_MAP_END +CONFIG_SYS_PCI_MAP_START +CONFIG_SYS_PCI_MASTER_INIT +CONFIG_SYS_PCI_MEMBASE +CONFIG_SYS_PCI_MEMBASE1 +CONFIG_SYS_PCI_MEMBASE2 +CONFIG_SYS_PCI_MEMBASE3 +CONFIG_SYS_PCI_MEMORY_BUS +CONFIG_SYS_PCI_MEMORY_PHYS +CONFIG_SYS_PCI_MEMORY_SIZE +CONFIG_SYS_PCI_MEMSIZE +CONFIG_SYS_PCI_MEM_BASE +CONFIG_SYS_PCI_MEM_BUS +CONFIG_SYS_PCI_MEM_PHYS +CONFIG_SYS_PCI_MEM_SIZE +CONFIG_SYS_PCI_MMIO_BASE +CONFIG_SYS_PCI_MMIO_PHYS +CONFIG_SYS_PCI_MMIO_SIZE +CONFIG_SYS_PCI_MSTR0_LOCAL +CONFIG_SYS_PCI_MSTR1_LOCAL +CONFIG_SYS_PCI_MSTR_IO_BUS +CONFIG_SYS_PCI_MSTR_IO_LOCAL +CONFIG_SYS_PCI_MSTR_IO_SIZE +CONFIG_SYS_PCI_MSTR_MEMIO_BUS +CONFIG_SYS_PCI_MSTR_MEMIO_LOCAL +CONFIG_SYS_PCI_MSTR_MEMIO_SIZE +CONFIG_SYS_PCI_MSTR_MEM_BUS +CONFIG_SYS_PCI_MSTR_MEM_LOCAL +CONFIG_SYS_PCI_MSTR_MEM_SIZE +CONFIG_SYS_PCI_NR_INBOUND_WIN +CONFIG_SYS_PCI_PHYS +CONFIG_SYS_PCI_PTM1LA +CONFIG_SYS_PCI_PTM1MS +CONFIG_SYS_PCI_PTM1PCI +CONFIG_SYS_PCI_PTM2LA +CONFIG_SYS_PCI_PTM2MS +CONFIG_SYS_PCI_PTM2PCI +CONFIG_SYS_PCI_SLV_MEM_BUS +CONFIG_SYS_PCI_SLV_MEM_LOCAL +CONFIG_SYS_PCI_SLV_MEM_SIZE +CONFIG_SYS_PCI_SUBSYS_DEVICEID +CONFIG_SYS_PCI_SUBSYS_DEVICEID2 +CONFIG_SYS_PCI_SUBSYS_ID +CONFIG_SYS_PCI_SUBSYS_ID_MONARCH +CONFIG_SYS_PCI_SUBSYS_ID_NONMONARCH +CONFIG_SYS_PCI_SUBSYS_VENDORID +CONFIG_SYS_PCI_SYS_MEM_BUS +CONFIG_SYS_PCI_SYS_MEM_PHYS +CONFIG_SYS_PCI_SYS_MEM_SIZE +CONFIG_SYS_PCI_TARGBASE +CONFIG_SYS_PCI_TARGET_INIT +CONFIG_SYS_PCI_TBATR0 +CONFIG_SYS_PCI_TBATR1 +CONFIG_SYS_PCI_TBATR2 +CONFIG_SYS_PCI_TBATR3 +CONFIG_SYS_PCI_TBATR4 +CONFIG_SYS_PCI_TBATR5 +CONFIG_SYS_PCI_VIRT +CONFIG_SYS_PCMCIA_ATTRB_ADDR +CONFIG_SYS_PCMCIA_ATTRB_SIZE +CONFIG_SYS_PCMCIA_ATTR_BASE +CONFIG_SYS_PCMCIA_CIS_WIN +CONFIG_SYS_PCMCIA_CIS_WIN_SIZE +CONFIG_SYS_PCMCIA_DMA_ADDR +CONFIG_SYS_PCMCIA_DMA_SIZE +CONFIG_SYS_PCMCIA_IO_ADDR +CONFIG_SYS_PCMCIA_IO_BASE +CONFIG_SYS_PCMCIA_IO_SIZE +CONFIG_SYS_PCMCIA_IO_WIN +CONFIG_SYS_PCMCIA_IO_WIN_SIZE +CONFIG_SYS_PCMCIA_MEM_ADDR +CONFIG_SYS_PCMCIA_MEM_SIZE +CONFIG_SYS_PCMCIA_PBR0 +CONFIG_SYS_PCMCIA_PBR1 +CONFIG_SYS_PCMCIA_PBR2 +CONFIG_SYS_PCMCIA_PBR3 +CONFIG_SYS_PCMCIA_PBR4 +CONFIG_SYS_PCMCIA_PBR5 +CONFIG_SYS_PCMCIA_PBR6 +CONFIG_SYS_PCMCIA_PBR7 +CONFIG_SYS_PCMCIA_POR0 +CONFIG_SYS_PCMCIA_POR1 +CONFIG_SYS_PCMCIA_POR2 +CONFIG_SYS_PCMCIA_POR3 +CONFIG_SYS_PCMCIA_POR4 +CONFIG_SYS_PCMCIA_POR5 +CONFIG_SYS_PCMCIA_POR6 +CONFIG_SYS_PCMCIA_POR7 +CONFIG_SYS_PCMCIA_TIMING +CONFIG_SYS_PDCNT +CONFIG_SYS_PDM360NG_COPROC_BAUDRATE +CONFIG_SYS_PDM360NG_COPROC_READ_DELAY +CONFIG_SYS_PEHLPAR +CONFIG_SYS_PEPAR +CONFIG_SYS_PERIPHERAL_BASE +CONFIG_SYS_PFC0 +CONFIG_SYS_PFPAR +CONFIG_SYS_PHYS_ADDR_HIGH +CONFIG_SYS_PHY_UBOOT_BASE +CONFIG_SYS_PIB_BASE +CONFIG_SYS_PIB_WINDOW_SIZE +CONFIG_SYS_PICMR0_MASK_ATTRIB +CONFIG_SYS_PIOC_ASR_VAL +CONFIG_SYS_PIOC_BSR_VAL +CONFIG_SYS_PIOC_PDR_VAL +CONFIG_SYS_PIOC_PDR_VAL1 +CONFIG_SYS_PIOC_PPUDR_VAL +CONFIG_SYS_PIOD_PDR_VAL1 +CONFIG_SYS_PIOD_PPUDR_VAL +CONFIG_SYS_PIO_MODE +CONFIG_SYS_PISCR +CONFIG_SYS_PIT_BASE +CONFIG_SYS_PIT_PRESCALE +CONFIG_SYS_PIXISOPT +CONFIG_SYS_PIXIS_VBOOT_ENABLE +CONFIG_SYS_PIXIS_VBOOT_MASK +CONFIG_SYS_PIXIS_VCFGEN0_ENABLE +CONFIG_SYS_PJPAR +CONFIG_SYS_PL310_BASE +CONFIG_SYS_PLATFORM_SRAM_BASE +CONFIG_SYS_PLATFORM_SRAM_BASE_PHYS +CONFIG_SYS_PLATFORM_SRAM_SIZE +CONFIG_SYS_PLL0_DIV +CONFIG_SYS_PLL0_MUL +CONFIG_SYS_PLL0_OPT +CONFIG_SYS_PLL0_SUPPRESS_CYCLES +CONFIG_SYS_PLLAR_VAL +CONFIG_SYS_PLLBR_VAL +CONFIG_SYS_PLLCR +CONFIG_SYS_PLL_BYPASS +CONFIG_SYS_PLL_FDR +CONFIG_SYS_PLL_ODR +CONFIG_SYS_PLL_RECONFIG +CONFIG_SYS_PLL_SETTLING_TIME +CONFIG_SYS_PLPRCR +CONFIG_SYS_PLUG_BASE +CONFIG_SYS_PMAN +CONFIG_SYS_PMC_BASE +CONFIG_SYS_PMC_BASE_PHYS +CONFIG_SYS_PME_CLK +CONFIG_SYS_POCMR0_MASK_ATTRIB +CONFIG_SYS_POCMR1_MASK_ATTRIB +CONFIG_SYS_POCMR2_MASK_ATTRIB +CONFIG_SYS_PORTDIV +CONFIG_SYS_PORTTC +CONFIG_SYS_POST_BSPEC1 +CONFIG_SYS_POST_BSPEC2 +CONFIG_SYS_POST_BSPEC3 +CONFIG_SYS_POST_BSPEC4 +CONFIG_SYS_POST_BSPEC5 +CONFIG_SYS_POST_CACHE +CONFIG_SYS_POST_CACHE_ADDR +CONFIG_SYS_POST_CODEC +CONFIG_SYS_POST_COPROC +CONFIG_SYS_POST_CPU +CONFIG_SYS_POST_DSP +CONFIG_SYS_POST_ECC +CONFIG_SYS_POST_ETHER +CONFIG_SYS_POST_ETHER_EXT_LOOPBACK +CONFIG_SYS_POST_ETH_LOOPS +CONFIG_SYS_POST_FLASH +CONFIG_SYS_POST_FLASH_END +CONFIG_SYS_POST_FLASH_NUM +CONFIG_SYS_POST_FLASH_START +CONFIG_SYS_POST_FPU +CONFIG_SYS_POST_FPU_ON +CONFIG_SYS_POST_HOTKEYS_GPIO +CONFIG_SYS_POST_I2C +CONFIG_SYS_POST_I2C_ADDRS +CONFIG_SYS_POST_I2C_IGNORES +CONFIG_SYS_POST_MEMORY +CONFIG_SYS_POST_MEMORY_ON +CONFIG_SYS_POST_MEM_REGIONS +CONFIG_SYS_POST_OCM +CONFIG_SYS_POST_PREREL +CONFIG_SYS_POST_RTC +CONFIG_SYS_POST_SPI +CONFIG_SYS_POST_SPR +CONFIG_SYS_POST_SYSMON +CONFIG_SYS_POST_UART +CONFIG_SYS_POST_UART_TABLE +CONFIG_SYS_POST_USB +CONFIG_SYS_POST_WATCHDOG +CONFIG_SYS_POST_WORD_ADDR +CONFIG_SYS_POWER_MANAGER +CONFIG_SYS_PPC4XX_USB_ADDR +CONFIG_SYS_PPC64 +CONFIG_SYS_PPC_DDR_WIMGE +CONFIG_SYS_PPC_E500_DEBUG_TLB +CONFIG_SYS_PQSPAR +CONFIG_SYS_PRELIM_OR_AM +CONFIG_SYS_PROMPT +CONFIG_SYS_PROMPT_HUSH_PS2 +CONFIG_SYS_PROM_OFFSET +CONFIG_SYS_PROM_SIZE +CONFIG_SYS_PSC1 +CONFIG_SYS_PSC3 +CONFIG_SYS_PSC4 +CONFIG_SYS_PSC6 +CONFIG_SYS_PSDMR +CONFIG_SYS_PSDPAR +CONFIG_SYS_PSRT +CONFIG_SYS_PSSR_VAL +CONFIG_SYS_PTA_PER_CLK +CONFIG_SYS_PTCPAR +CONFIG_SYS_PTDPAR +CONFIG_SYS_PTL2_BITS +CONFIG_SYS_PTV +CONFIG_SYS_PUAPAR +CONFIG_SYS_QE_FMAN_FW_IN_MMC +CONFIG_SYS_QE_FMAN_FW_IN_NAND +CONFIG_SYS_QE_FMAN_FW_IN_NOR +CONFIG_SYS_QE_FMAN_FW_IN_REMOTE +CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH +CONFIG_SYS_QE_FMAN_FW_LENGTH +CONFIG_SYS_QE_FW_ADDR +CONFIG_SYS_QE_FW_IN_ +CONFIG_SYS_QE_FW_IN_SPIFLASH +CONFIG_SYS_QMAN_CENA_BASE +CONFIG_SYS_QMAN_CENA_SIZE +CONFIG_SYS_QMAN_CINH_BASE +CONFIG_SYS_QMAN_CINH_SIZE +CONFIG_SYS_QMAN_MEM_BASE +CONFIG_SYS_QMAN_MEM_PHYS +CONFIG_SYS_QMAN_MEM_SIZE +CONFIG_SYS_QMAN_NUM_PORTALS +CONFIG_SYS_QMAN_SP_CENA_SIZE +CONFIG_SYS_QMAN_SP_CINH_SIZE +CONFIG_SYS_QMAN_SWP_ISDR_REG +CONFIG_SYS_QRIO_BASE +CONFIG_SYS_QRIO_BASE_PHYS +CONFIG_SYS_QRIO_BR_PRELIM +CONFIG_SYS_QRIO_OR_PRELIM +CONFIG_SYS_R7780MP_OLD_FLASH +CONFIG_SYS_RAMBOOT +CONFIG_SYS_RAM_BASE +CONFIG_SYS_RAM_CS +CONFIG_SYS_RAM_END +CONFIG_SYS_RAM_FREQ_DIV +CONFIG_SYS_RAM_SIZE +CONFIG_SYS_RCAR_I2C0_BASE +CONFIG_SYS_RCAR_I2C0_SPEED +CONFIG_SYS_RCAR_I2C1_BASE +CONFIG_SYS_RCAR_I2C1_SPEED +CONFIG_SYS_RCAR_I2C2_BASE +CONFIG_SYS_RCAR_I2C2_SPEED +CONFIG_SYS_RCAR_I2C3_BASE +CONFIG_SYS_RCAR_I2C3_SPEED +CONFIG_SYS_RCCR +CONFIG_SYS_RCWH_PCIHOST +CONFIG_SYS_READ_SPD +CONFIG_SYS_REDUNDAND_ENVIRONMENT +CONFIG_SYS_REFCLKSEL +CONFIG_SYS_RELOC_MONITOR_BASE +CONFIG_SYS_RELOC_MONITOR_MAX_END +CONFIG_SYS_REMAP_OR_AM +CONFIG_SYS_RESET_ADDR +CONFIG_SYS_RESET_ADDRESS +CONFIG_SYS_RESET_BASE +CONFIG_SYS_RESET_SCTRL +CONFIG_SYS_RESET_SOURCE +CONFIG_SYS_RFD +CONFIG_SYS_RGMII1_PHY_ADDR +CONFIG_SYS_RGMII2_PHY_ADDR +CONFIG_SYS_RIO_MEM_BASE +CONFIG_SYS_RIO_MEM_BUS +CONFIG_SYS_RIO_MEM_PHYS +CONFIG_SYS_RIO_MEM_SIZE +CONFIG_SYS_RIO_MEM_VIRT +CONFIG_SYS_RMDS +CONFIG_SYS_RMR +CONFIG_SYS_ROM_BASE +CONFIG_SYS_ROOTPATH +CONFIG_SYS_RSTC_RMR_VAL +CONFIG_SYS_RTCSC +CONFIG_SYS_RTC_BUS_NUM +CONFIG_SYS_RTC_CNT +CONFIG_SYS_RTC_DS1337 +CONFIG_SYS_RTC_DS1337_NOOSC +CONFIG_SYS_RTC_DS1388 +CONFIG_SYS_RTC_OSCILLATOR +CONFIG_SYS_RTC_PL031_BASE +CONFIG_SYS_RTC_REG_BASE_ADDR +CONFIG_SYS_RTC_SETUP +CONFIG_SYS_RV3029_TCR +CONFIG_SYS_RX_ETH_BUFFER +CONFIG_SYS_S3C2410_NAND_HWECC +CONFIG_SYS_SATA +CONFIG_SYS_SATA1 +CONFIG_SYS_SATA1_FLAGS +CONFIG_SYS_SATA1_OFFSET +CONFIG_SYS_SATA2 +CONFIG_SYS_SATA2_FLAGS +CONFIG_SYS_SATA2_OFFSET +CONFIG_SYS_SATA_ENV_DEV +CONFIG_SYS_SATA_FAT_BOOT_PARTITION +CONFIG_SYS_SATA_MAX_DEVICE +CONFIG_SYS_SBFHDR_DATA_OFFSET +CONFIG_SYS_SBFHDR_SIZE +CONFIG_SYS_SCCR +CONFIG_SYS_SCCR_ENCCM +CONFIG_SYS_SCCR_PCICM +CONFIG_SYS_SCCR_PCIEXP1CM +CONFIG_SYS_SCCR_PCIEXP2CM +CONFIG_SYS_SCCR_SATACM +CONFIG_SYS_SCCR_TSEC1CM +CONFIG_SYS_SCCR_TSEC1ON +CONFIG_SYS_SCCR_TSEC2CM +CONFIG_SYS_SCCR_TSEC2ON +CONFIG_SYS_SCCR_TSECCM +CONFIG_SYS_SCCR_USBDRCM +CONFIG_SYS_SCCR_USBMPHCM +CONFIG_SYS_SCC_TOUT_LOOP +CONFIG_SYS_SCR +CONFIG_SYS_SCRATCH_VA +CONFIG_SYS_SCSI_MAXDEVICE +CONFIG_SYS_SCSI_MAX_DEVICE +CONFIG_SYS_SCSI_MAX_LUN +CONFIG_SYS_SCSI_MAX_SCSI_ID +CONFIG_SYS_SCSI_SPIN_UP_TIME +CONFIG_SYS_SCSI_SYM53C8XX_CCF +CONFIG_SYS_SDHC_CLK +CONFIG_SYS_SDHC_CLK_2_PLL +CONFIG_SYS_SDIO0 +CONFIG_SYS_SDIO0_MAX_CLK +CONFIG_SYS_SDIO1 +CONFIG_SYS_SDIO1_MAX_CLK +CONFIG_SYS_SDIO2 +CONFIG_SYS_SDIO2_MAX_CLK +CONFIG_SYS_SDIO3 +CONFIG_SYS_SDIO3_MAX_CLK +CONFIG_SYS_SDIO_BASE0 +CONFIG_SYS_SDIO_BASE1 +CONFIG_SYS_SDIO_BASE2 +CONFIG_SYS_SDIO_BASE3 +CONFIG_SYS_SDMR +CONFIG_SYS_SDRAM +CONFIG_SYS_SDRAM0_CFG0 +CONFIG_SYS_SDRAM0_CLKTR +CONFIG_SYS_SDRAM0_CODT +CONFIG_SYS_SDRAM0_DLCR +CONFIG_SYS_SDRAM0_INITPLR0 +CONFIG_SYS_SDRAM0_INITPLR1 +CONFIG_SYS_SDRAM0_INITPLR10 +CONFIG_SYS_SDRAM0_INITPLR11 +CONFIG_SYS_SDRAM0_INITPLR12 +CONFIG_SYS_SDRAM0_INITPLR13 +CONFIG_SYS_SDRAM0_INITPLR14 +CONFIG_SYS_SDRAM0_INITPLR15 +CONFIG_SYS_SDRAM0_INITPLR2 +CONFIG_SYS_SDRAM0_INITPLR3 +CONFIG_SYS_SDRAM0_INITPLR4 +CONFIG_SYS_SDRAM0_INITPLR5 +CONFIG_SYS_SDRAM0_INITPLR6 +CONFIG_SYS_SDRAM0_INITPLR7 +CONFIG_SYS_SDRAM0_INITPLR8 +CONFIG_SYS_SDRAM0_INITPLR9 +CONFIG_SYS_SDRAM0_MB0CF +CONFIG_SYS_SDRAM0_MB0CF_BASE +CONFIG_SYS_SDRAM0_MB1CF +CONFIG_SYS_SDRAM0_MB1CF_BASE +CONFIG_SYS_SDRAM0_MB2CF +CONFIG_SYS_SDRAM0_MB3CF +CONFIG_SYS_SDRAM0_MCOPT1 +CONFIG_SYS_SDRAM0_MCOPT2 +CONFIG_SYS_SDRAM0_MEMODE +CONFIG_SYS_SDRAM0_MMODE +CONFIG_SYS_SDRAM0_MODT0 +CONFIG_SYS_SDRAM0_MODT1 +CONFIG_SYS_SDRAM0_MODT2 +CONFIG_SYS_SDRAM0_MODT3 +CONFIG_SYS_SDRAM0_RDCC +CONFIG_SYS_SDRAM0_RFDC +CONFIG_SYS_SDRAM0_RQDC +CONFIG_SYS_SDRAM0_RTR +CONFIG_SYS_SDRAM0_SDTR1 +CONFIG_SYS_SDRAM0_SDTR2 +CONFIG_SYS_SDRAM0_SDTR3 +CONFIG_SYS_SDRAM0_TR0 +CONFIG_SYS_SDRAM0_WDDCTR +CONFIG_SYS_SDRAM0_WRDTR +CONFIG_SYS_SDRAM1 +CONFIG_SYS_SDRAM_ +CONFIG_SYS_SDRAM_BANKS +CONFIG_SYS_SDRAM_BASE +CONFIG_SYS_SDRAM_BASE0 +CONFIG_SYS_SDRAM_BASE1 +CONFIG_SYS_SDRAM_BASE2 +CONFIG_SYS_SDRAM_CASL +CONFIG_SYS_SDRAM_CFG +CONFIG_SYS_SDRAM_CFG1 +CONFIG_SYS_SDRAM_CFG2 +CONFIG_SYS_SDRAM_CL +CONFIG_SYS_SDRAM_CONF1HB +CONFIG_SYS_SDRAM_CONF1LL +CONFIG_SYS_SDRAM_CONFPATHB +CONFIG_SYS_SDRAM_CS1 +CONFIG_SYS_SDRAM_CTP +CONFIG_SYS_SDRAM_CTRL +CONFIG_SYS_SDRAM_DRVSTRENGTH +CONFIG_SYS_SDRAM_DRV_STRENGTH +CONFIG_SYS_SDRAM_EMOD +CONFIG_SYS_SDRAM_END +CONFIG_SYS_SDRAM_LDF +CONFIG_SYS_SDRAM_LIST +CONFIG_SYS_SDRAM_LOWER +CONFIG_SYS_SDRAM_MODE +CONFIG_SYS_SDRAM_PLBADDUHB +CONFIG_SYS_SDRAM_PLBADDULL +CONFIG_SYS_SDRAM_PTA +CONFIG_SYS_SDRAM_R0BAS +CONFIG_SYS_SDRAM_R1BAS +CONFIG_SYS_SDRAM_R2BAS +CONFIG_SYS_SDRAM_R3BAS +CONFIG_SYS_SDRAM_RCD +CONFIG_SYS_SDRAM_RFTA +CONFIG_SYS_SDRAM_SIZE +CONFIG_SYS_SDRAM_SIZE0 +CONFIG_SYS_SDRAM_SIZE1 +CONFIG_SYS_SDRAM_SIZE_LAW +CONFIG_SYS_SDRAM_SIZE_MB +CONFIG_SYS_SDRAM_TABLE +CONFIG_SYS_SDRAM_UPPER +CONFIG_SYS_SDRAM_VAL +CONFIG_SYS_SDRAM_VAL1 +CONFIG_SYS_SDRAM_VAL10 +CONFIG_SYS_SDRAM_VAL11 +CONFIG_SYS_SDRAM_VAL12 +CONFIG_SYS_SDRAM_VAL2 +CONFIG_SYS_SDRAM_VAL3 +CONFIG_SYS_SDRAM_VAL4 +CONFIG_SYS_SDRAM_VAL5 +CONFIG_SYS_SDRAM_VAL6 +CONFIG_SYS_SDRAM_VAL7 +CONFIG_SYS_SDRAM_VAL8 +CONFIG_SYS_SDRAM_VAL9 +CONFIG_SYS_SDRC_CR_VAL +CONFIG_SYS_SDRC_MDR_VAL +CONFIG_SYS_SDRC_MR_VAL +CONFIG_SYS_SDRC_MR_VAL1 +CONFIG_SYS_SDRC_MR_VAL2 +CONFIG_SYS_SDRC_MR_VAL3 +CONFIG_SYS_SDRC_MR_VAL4 +CONFIG_SYS_SDRC_MR_VAL5 +CONFIG_SYS_SDRC_TR_VAL +CONFIG_SYS_SDRC_TR_VAL1 +CONFIG_SYS_SDRC_TR_VAL2 +CONFIG_SYS_SDSR +CONFIG_SYS_SD_VOLTAGE +CONFIG_SYS_SEC_MON_ADDR +CONFIG_SYS_SEC_MON_OFFSET +CONFIG_SYS_SELF_RST +CONFIG_SYS_SERIAL0 +CONFIG_SYS_SERIAL1 +CONFIG_SYS_SERIAL2 +CONFIG_SYS_SERIAL3 +CONFIG_SYS_SERIAL4 +CONFIG_SYS_SERIAL5 +CONFIG_SYS_SERROM_ADDR +CONFIG_SYS_SFP_ADDR +CONFIG_SYS_SFP_OFFSET +CONFIG_SYS_SGMII1_PHY_ADDR +CONFIG_SYS_SGMII2_PHY_ADDR +CONFIG_SYS_SGMII3_PHY_ADDR +CONFIG_SYS_SGMII_LINERATE_MHZ +CONFIG_SYS_SGMII_RATESCALE +CONFIG_SYS_SGMII_REFCLK_MHZ +CONFIG_SYS_SH_SDHI0_BASE +CONFIG_SYS_SH_SDHI1_BASE +CONFIG_SYS_SH_SDHI2_BASE +CONFIG_SYS_SH_SDHI3_BASE +CONFIG_SYS_SH_SDHI_NR_CHANNEL +CONFIG_SYS_SICRH +CONFIG_SYS_SICRL +CONFIG_SYS_SIL1178_I2C +CONFIG_SYS_SIMULATE_SPD_EEPROM +CONFIG_SYS_SIUMCR +CONFIG_SYS_SIUMCR_HIGH +CONFIG_SYS_SIUMCR_LOW +CONFIG_SYS_SJA1000_BASE +CONFIG_SYS_SMALL_FLASH +CONFIG_SYS_SMC0_CYCLE0_VAL +CONFIG_SYS_SMC0_MODE0_VAL +CONFIG_SYS_SMC0_PULSE0_VAL +CONFIG_SYS_SMC0_SETUP0_VAL +CONFIG_SYS_SMC_CSR0_VAL +CONFIG_SYS_SMC_DPMEM_OFFSET +CONFIG_SYS_SMC_RXBUFLEN +CONFIG_SYS_SMC_UCODE_PATCH +CONFIG_SYS_SMI_BASE +CONFIG_SYS_SOC +CONFIG_SYS_SPANSION_BASE +CONFIG_SYS_SPANSION_BOOT +CONFIG_SYS_SPARC_NWINDOWS +CONFIG_SYS_SPC1920_PLD_BASE +CONFIG_SYS_SPC1920_SMC1_CLK4 +CONFIG_SYS_SPCR_OPT +CONFIG_SYS_SPCR_TSEC1EP +CONFIG_SYS_SPCR_TSEC2EP +CONFIG_SYS_SPCR_TSECEP +CONFIG_SYS_SPD_BUS_NUM +CONFIG_SYS_SPD_MAX_DIMMS +CONFIG_SYS_SPI0 +CONFIG_SYS_SPI0_NUM_CS +CONFIG_SYS_SPI1 +CONFIG_SYS_SPI1_BASE +CONFIG_SYS_SPI1_NUM_CS +CONFIG_SYS_SPI2 +CONFIG_SYS_SPI2_BASE +CONFIG_SYS_SPI2_NUM_CS +CONFIG_SYS_SPI_ARGS_OFFS +CONFIG_SYS_SPI_ARGS_SIZE +CONFIG_SYS_SPI_BASE +CONFIG_SYS_SPI_CLK +CONFIG_SYS_SPI_CS_ACT +CONFIG_SYS_SPI_CS_BASE +CONFIG_SYS_SPI_CS_USED +CONFIG_SYS_SPI_DPMEM_OFFSET +CONFIG_SYS_SPI_FLASH_U_BOOT_DST +CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS +CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE +CONFIG_SYS_SPI_FLASH_U_BOOT_START +CONFIG_SYS_SPI_INIT_OFFSET +CONFIG_SYS_SPI_KERNEL_OFFS +CONFIG_SYS_SPI_MXC_WAIT +CONFIG_SYS_SPI_RTC_DEVID +CONFIG_SYS_SPI_ST_ENABLE_WP_PIN +CONFIG_SYS_SPI_UCODE_PATCH +CONFIG_SYS_SPI_U_BOOT_OFFS +CONFIG_SYS_SPI_U_BOOT_SIZE +CONFIG_SYS_SPI_WRITE_TOUT +CONFIG_SYS_SPL_ARGS_ADDR +CONFIG_SYS_SPL_LEN +CONFIG_SYS_SPL_MALLOC_SIZE +CONFIG_SYS_SPL_MALLOC_START +CONFIG_SYS_SPL_MAX_LEN +CONFIG_SYS_SPR +CONFIG_SYS_SRAM_BASE +CONFIG_SYS_SRAM_END +CONFIG_SYS_SRAM_SIZE +CONFIG_SYS_SRAM_START +CONFIG_SYS_SRGPL0_CFG_BAR +CONFIG_SYS_SRGPL0_MNT_BAR +CONFIG_SYS_SRGPL0_MSG_BAR +CONFIG_SYS_SRGPL0_REG_BAR +CONFIG_SYS_SRIO +CONFIG_SYS_SRIO1_MEM_BASE +CONFIG_SYS_SRIO1_MEM_BUS +CONFIG_SYS_SRIO1_MEM_PHYS +CONFIG_SYS_SRIO1_MEM_PHYS_HIGH +CONFIG_SYS_SRIO1_MEM_PHYS_LOW +CONFIG_SYS_SRIO1_MEM_SIZE +CONFIG_SYS_SRIO1_MEM_VIRT +CONFIG_SYS_SRIO2_MEM_PHYS +CONFIG_SYS_SRIO2_MEM_SIZE +CONFIG_SYS_SRIO2_MEM_VIRT +CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR +CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS +CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR +CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS +CONFIG_SYS_SSD_BASE +CONFIG_SYS_SSD_BASE_PHYS +CONFIG_SYS_SSP_PORT +CONFIG_SYS_SST_SECT +CONFIG_SYS_SST_SECTSZ +CONFIG_SYS_STACKSIZE +CONFIG_SYS_STACK_LENGTH +CONFIG_SYS_STACK_SIZE +CONFIG_SYS_STATUS_C +CONFIG_SYS_STATUS_OK +CONFIG_SYS_STDIO_DEREGISTER +CONFIG_SYS_STMICRO_BOOT +CONFIG_SYS_SUPPORT_64BIT_DATA +CONFIG_SYS_SXCNFG_VAL +CONFIG_SYS_SYPCR +CONFIG_SYS_SYSCLK +CONFIG_SYS_SYSTEMACE_BASE +CONFIG_SYS_SYSTEMACE_WIDTH +CONFIG_SYS_TBIPA_VALUE +CONFIG_SYS_TBSCR +CONFIG_SYS_TCLK +CONFIG_SYS_TEMP_STACK_OCM +CONFIG_SYS_TEXT_ADDR +CONFIG_SYS_TEXT_BASE +CONFIG_SYS_TEXT_BASE_NOR +CONFIG_SYS_TEXT_BASE_SPL +CONFIG_SYS_TFP410_ADDR +CONFIG_SYS_TFP410_BUS +CONFIG_SYS_THUMB_BUILD +CONFIG_SYS_TIMERBASE +CONFIG_SYS_TIMER_BASE +CONFIG_SYS_TIMER_COUNTER +CONFIG_SYS_TIMER_COUNTS_DOWN +CONFIG_SYS_TIMER_PRESCALER +CONFIG_SYS_TIMER_RATE +CONFIG_SYS_TLB_FOR_BOOT_FLASH +CONFIG_SYS_TMCNTSC +CONFIG_SYS_TMPVIRT +CONFIG_SYS_TMRINTR_MASK +CONFIG_SYS_TMRINTR_NO +CONFIG_SYS_TMRINTR_PEND +CONFIG_SYS_TMRINTR_PRI +CONFIG_SYS_TMRPND_REG +CONFIG_SYS_TMR_BASE +CONFIG_SYS_TMU_CLK_DIV +CONFIG_SYS_TSEC1 +CONFIG_SYS_TSEC1_OFFSET +CONFIG_SYS_TSEC2 +CONFIG_SYS_TSEC2_OFFSET +CONFIG_SYS_TSEC3_OFFSET +CONFIG_SYS_TX_ETH_BUFFER +CONFIG_SYS_UART1_ALT1_GPIO +CONFIG_SYS_UART1_PRI_GPIO +CONFIG_SYS_UART2_ALT1_GPIO +CONFIG_SYS_UART2_ALT3_GPIO +CONFIG_SYS_UART2_PRI_GPIO +CONFIG_SYS_UART_BASE +CONFIG_SYS_UART_BAUD +CONFIG_SYS_UART_FREQ +CONFIG_SYS_UART_PORT +CONFIG_SYS_UBOOT_BASE +CONFIG_SYS_UBOOT_END +CONFIG_SYS_UBOOT_START +CONFIG_SYS_UCC_RGMII_MODE +CONFIG_SYS_UCC_RMII_MODE +CONFIG_SYS_UDELAY_BASE +CONFIG_SYS_UEC +CONFIG_SYS_UEC1_ETH_TYPE +CONFIG_SYS_UEC1_INTERFACE_SPEED +CONFIG_SYS_UEC1_INTERFACE_TYPE +CONFIG_SYS_UEC1_PHY_ADDR +CONFIG_SYS_UEC1_RX_CLK +CONFIG_SYS_UEC1_TX_CLK +CONFIG_SYS_UEC1_UCC_NUM +CONFIG_SYS_UEC2_ETH_TYPE +CONFIG_SYS_UEC2_INTERFACE_SPEED +CONFIG_SYS_UEC2_INTERFACE_TYPE +CONFIG_SYS_UEC2_PHY_ADDR +CONFIG_SYS_UEC2_RX_CLK +CONFIG_SYS_UEC2_TX_CLK +CONFIG_SYS_UEC2_UCC_NUM +CONFIG_SYS_UEC3_ETH_TYPE +CONFIG_SYS_UEC3_INTERFACE_SPEED +CONFIG_SYS_UEC3_INTERFACE_TYPE +CONFIG_SYS_UEC3_PHY_ADDR +CONFIG_SYS_UEC3_RX_CLK +CONFIG_SYS_UEC3_TX_CLK +CONFIG_SYS_UEC3_UCC_NUM +CONFIG_SYS_UEC4_ETH_TYPE +CONFIG_SYS_UEC4_INTERFACE_SPEED +CONFIG_SYS_UEC4_INTERFACE_TYPE +CONFIG_SYS_UEC4_PHY_ADDR +CONFIG_SYS_UEC4_RX_CLK +CONFIG_SYS_UEC4_TX_CLK +CONFIG_SYS_UEC4_UCC_NUM +CONFIG_SYS_UEC5_ETH_TYPE +CONFIG_SYS_UEC5_INTERFACE_SPEED +CONFIG_SYS_UEC5_INTERFACE_TYPE +CONFIG_SYS_UEC5_PHY_ADDR +CONFIG_SYS_UEC5_RX_CLK +CONFIG_SYS_UEC5_TX_CLK +CONFIG_SYS_UEC5_UCC_NUM +CONFIG_SYS_UEC6_ETH_TYPE +CONFIG_SYS_UEC6_INTERFACE_SPEED +CONFIG_SYS_UEC6_INTERFACE_TYPE +CONFIG_SYS_UEC6_PHY_ADDR +CONFIG_SYS_UEC6_RX_CLK +CONFIG_SYS_UEC6_TX_CLK +CONFIG_SYS_UEC6_UCC_NUM +CONFIG_SYS_UEC8_ETH_TYPE +CONFIG_SYS_UEC8_INTERFACE_SPEED +CONFIG_SYS_UEC8_INTERFACE_TYPE +CONFIG_SYS_UEC8_PHY_ADDR +CONFIG_SYS_UEC8_RX_CLK +CONFIG_SYS_UEC8_TX_CLK +CONFIG_SYS_UEC8_UCC_NUM +CONFIG_SYS_UHC0_EHCI_BASE +CONFIG_SYS_UHC1_EHCI_BASE +CONFIG_SYS_ULB_CLK +CONFIG_SYS_UMCR +CONFIG_SYS_UNIFY_CACHE +CONFIG_SYS_UNSPEC_PHYID +CONFIG_SYS_UNSPEC_STRID +CONFIG_SYS_UPDATE_FLASH_SIZE +CONFIG_SYS_USB2D0_BASE +CONFIG_SYS_USBD_BASE +CONFIG_SYS_USB_BRGCLK +CONFIG_SYS_USB_BRG_CLK +CONFIG_SYS_USB_DEVICE +CONFIG_SYS_USB_EHCI_CPU_INIT +CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS +CONFIG_SYS_USB_EHCI_REGS_BASE +CONFIG_SYS_USB_EVENT_POLL +CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE +CONFIG_SYS_USB_EXTC_CLK +CONFIG_SYS_USB_FAT_BOOT_PARTITION +CONFIG_SYS_USB_HOST +CONFIG_SYS_USB_OHCI_BOARD_INIT +CONFIG_SYS_USB_OHCI_CPU_INIT +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS +CONFIG_SYS_USB_OHCI_REGS_BASE +CONFIG_SYS_USB_OHCI_SLOT_NAME +CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS +CONFIG_SYS_USER_SWITCHES_BASE +CONFIG_SYS_USE_BOOT_NORFLASH +CONFIG_SYS_USE_DATAFLASH +CONFIG_SYS_USE_DATAFLASH_CS0 +CONFIG_SYS_USE_DATAFLASH_CS1 +CONFIG_SYS_USE_DATAFLASH_CS3 +CONFIG_SYS_USE_DSPLINK +CONFIG_SYS_USE_FLASH +CONFIG_SYS_USE_MAIN_OSCILLATOR +CONFIG_SYS_USE_MMC +CONFIG_SYS_USE_MPC834XSYS_USB_PHY +CONFIG_SYS_USE_NAND +CONFIG_SYS_USE_NANDFLASH +CONFIG_SYS_USE_NOR +CONFIG_SYS_USE_NORFLASH +CONFIG_SYS_USE_OSCCLK +CONFIG_SYS_USE_PPCENV +CONFIG_SYS_USE_SERIALFLASH +CONFIG_SYS_USE_SPIFLASH +CONFIG_SYS_USE_UBI +CONFIG_SYS_USR_EXCEP +CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS +CONFIG_SYS_U_BOOT_OFFS +CONFIG_SYS_VA_BITS +CONFIG_SYS_VCXK_ +CONFIG_SYS_VCXK_ACKNOWLEDGE_DDR +CONFIG_SYS_VCXK_ACKNOWLEDGE_PIN +CONFIG_SYS_VCXK_ACKNOWLEDGE_PORT +CONFIG_SYS_VCXK_AUTODETECT +CONFIG_SYS_VCXK_BASE +CONFIG_SYS_VCXK_DEFAULT_LINEALIGN +CONFIG_SYS_VCXK_DOUBLEBUFFERED +CONFIG_SYS_VCXK_ENABLE_DDR +CONFIG_SYS_VCXK_ENABLE_PIN +CONFIG_SYS_VCXK_ENABLE_PORT +CONFIG_SYS_VCXK_INVERT_DDR +CONFIG_SYS_VCXK_INVERT_PIN +CONFIG_SYS_VCXK_INVERT_PORT +CONFIG_SYS_VCXK_REQUEST_DDR +CONFIG_SYS_VCXK_REQUEST_PIN +CONFIG_SYS_VCXK_REQUEST_PORT +CONFIG_SYS_VCXK_RESET_DDR +CONFIG_SYS_VCXK_RESET_PIN +CONFIG_SYS_VCXK_RESET_PORT +CONFIG_SYS_VENDOR +CONFIG_SYS_VGA_RAM_EN +CONFIG_SYS_VID +CONFIG_SYS_VIDEO_LOGO_MAX_SIZE +CONFIG_SYS_VPC3_BASE +CONFIG_SYS_VPC3_SIZE +CONFIG_SYS_VSC7385_BASE +CONFIG_SYS_VSC7385_BASE_PHYS +CONFIG_SYS_VSC7385_BR_PRELIM +CONFIG_SYS_VSC7385_OR_PRELIM +CONFIG_SYS_VSC7385_SIZE +CONFIG_SYS_VSC8601_SKEWFIX +CONFIG_SYS_VXWORKS_MAC_PTR +CONFIG_SYS_WATCHDOG_FLAGS_ADDR +CONFIG_SYS_WATCHDOG_FREQ +CONFIG_SYS_WATCHDOG_MAGIC +CONFIG_SYS_WATCHDOG_MAGIC_MASK +CONFIG_SYS_WATCHDOG_TIME_ADDR +CONFIG_SYS_WATCHDOG_VALUE +CONFIG_SYS_WDTC_WDMR_VAL +CONFIG_SYS_WDTTIMERBASE +CONFIG_SYS_WDT_PERIOD_HIGH +CONFIG_SYS_WDT_PERIOD_LOW +CONFIG_SYS_WHITE_ON_BLACK +CONFIG_SYS_WINDOW1_BASE +CONFIG_SYS_WRITE_SWAPPED_DATA +CONFIG_SYS_X86_START16 +CONFIG_SYS_XHCI_USB1_ADDR +CONFIG_SYS_XHCI_USB2_ADDR +CONFIG_SYS_XHCI_USB3_ADDR +CONFIG_SYS_XILINX_SPI_LIST +CONFIG_SYS_XIMG_LEN +CONFIG_SYS_XLB_PIPELINING +CONFIG_SYS_XSVF_DEFAULT_ADDR +CONFIG_SYS_XWAY_EBU_BOOTCFG +CONFIG_SYS_XXX +CONFIG_SYS_ZYNQ_QSPI_WAIT +CONFIG_SYS_ZYNQ_SPI_WAIT +CONFIG_T1023RDB +CONFIG_T1024RDB +CONFIG_T104 +CONFIG_T1040D4RDB +CONFIG_T1040QDS +CONFIG_T1040RDB +CONFIG_T1042D4RDB +CONFIG_T1042RDB +CONFIG_T1042RDB_PI +CONFIG_T104XD4RDB +CONFIG_T2080QDS +CONFIG_T2080RDB +CONFIG_T2081QDS +CONFIG_T4240QDS +CONFIG_T4240RDB +CONFIG_TAM3517_SETTINGS +CONFIG_TAM3517_SW3_SETTINGS +CONFIG_TARGET_EFI +CONFIG_TARGET_ETAMIN +CONFIG_TARGET_JETSON_TK1 +CONFIG_TARGET_MX6UL_9X9_EVK +CONFIG_TARGET_OMAP3_CAIRO +CONFIG_TARGET_VEXPRESS64_BASE_FVP +CONFIG_TARGET_VEXPRESS64_BASE_FVP_DRAM +CONFIG_TARGET_VEXPRESS64_JUNO +CONFIG_TARGET_ZC5202 +CONFIG_TCA642X +CONFIG_TEGRA +CONFIG_TEGRA124 +CONFIG_TEGRA186 +CONFIG_TEGRA20 +CONFIG_TEGRA210 +CONFIG_TEGRA_BOARD_STRING +CONFIG_TEGRA_CLOCK_SCALING +CONFIG_TEGRA_ENABLE_UARTA +CONFIG_TEGRA_ENABLE_UARTB +CONFIG_TEGRA_ENABLE_UARTC +CONFIG_TEGRA_ENABLE_UARTD +CONFIG_TEGRA_ENABLE_UARTE +CONFIG_TEGRA_GPU +CONFIG_TEGRA_KEYBOARD +CONFIG_TEGRA_LP0 +CONFIG_TEGRA_MMC +CONFIG_TEGRA_NAND +CONFIG_TEGRA_PMU +CONFIG_TEGRA_SLINK_CTRLS +CONFIG_TEGRA_SPI +CONFIG_TEGRA_SUPPORT_NON_SECURE +CONFIG_TEGRA_UARTA_GPU +CONFIG_TEGRA_UARTA_SDIO1 +CONFIG_TEGRA_UARTA_UAA_UAB +CONFIG_TEGRA_VDD_CORE_TPS62361B_SET3 +CONFIG_TEGRA_VDD_CORE_TPS62366A_SET1 +CONFIG_TESTPIN_MASK +CONFIG_TESTPIN_REG +CONFIG_TEST_LIST_SORT +CONFIG_TFP410_I2C_ADDR +CONFIG_TFTP_BLOCKSIZE +CONFIG_TFTP_FILE_NAME_MAX_LEN +CONFIG_TFTP_PORT +CONFIG_TFTP_TSIZE +CONFIG_THOR_RESET_OFF +CONFIG_THUMB2_KERNEL +CONFIG_THUNDERX +CONFIG_TI814X +CONFIG_TI816X +CONFIG_TI816X_DDR_PLL_796 +CONFIG_TI816X_EVM_DDR2 +CONFIG_TI816X_EVM_DDR3 +CONFIG_TI816X_USE_EMIF0 +CONFIG_TI816X_USE_EMIF1 +CONFIG_TI81XX +CONFIG_TIMER +CONFIG_TIMER_CLK_FREQ +CONFIG_TIMER_EARLY +CONFIG_TIMESTAMP +CONFIG_TIZEN +CONFIG_TI_EDMA3 +CONFIG_TI_KEYSTONE_SERDES +CONFIG_TI_KSNAV +CONFIG_TI_QSPI +CONFIG_TI_SECURE_DEVICE +CONFIG_TI_SPI_MMAP +CONFIG_TMU_CMD_DTT +CONFIG_TMU_TIMER +CONFIG_TOTAL5200 +CONFIG_TPL +CONFIG_TPL_BUILD +CONFIG_TPL_PAD_TO +CONFIG_TPM +CONFIG_TPM_ATMEL_TWI +CONFIG_TPM_AUTH_SESSIONS +CONFIG_TPM_ST33ZP24 +CONFIG_TPM_ST33ZP24_I2C +CONFIG_TPM_ST33ZP24_SPI +CONFIG_TPM_TIS_BASE_ADDRESS +CONFIG_TPM_TIS_I2C_BURST_LIMITATION +CONFIG_TPM_TIS_I2C_BURST_LIMITATION_LEN +CONFIG_TPM_TIS_INFINEON +CONFIG_TPM_TIS_LPC +CONFIG_TPS6586X_POWER +CONFIG_TQM5200 +CONFIG_TQM5200S +CONFIG_TQM5200_B +CONFIG_TQM5200_REV100 +CONFIG_TQM8 +CONFIG_TQM823L +CONFIG_TQM823M +CONFIG_TQM834X +CONFIG_TQM850L +CONFIG_TQM850M +CONFIG_TQM855L +CONFIG_TQM855M +CONFIG_TQM860L +CONFIG_TQM860M +CONFIG_TQM862L +CONFIG_TQM862M +CONFIG_TQM866M +CONFIG_TQM885D +CONFIG_TRACE +CONFIG_TRACE_BUFFER_SIZE +CONFIG_TRACE_EARLY +CONFIG_TRACE_EARLY_ADDR +CONFIG_TRACE_EARLY_SIZE +CONFIG_TRAILBLAZER +CONFIG_TRATS +CONFIG_TRDX_PID_COLIBRI_VF50 +CONFIG_TRDX_PID_COLIBRI_VF50IT +CONFIG_TRDX_PID_COLIBRI_VF61 +CONFIG_TRDX_PID_COLIBRI_VF61IT +CONFIG_TRDX_VID +CONFIG_TSEC +CONFIG_TSEC1 +CONFIG_TSEC1_NAME +CONFIG_TSEC2 +CONFIG_TSEC2_NAME +CONFIG_TSEC3 +CONFIG_TSEC3_NAME +CONFIG_TSEC4 +CONFIG_TSEC4_NAME +CONFIG_TSECV2 +CONFIG_TSECV2_1 +CONFIG_TSEC_ENET +CONFIG_TSEC_TBI +CONFIG_TSEC_TBICR_SETTINGS +CONFIG_TSI108_ETH_NUM_PORTS +CONFIG_TSIM +CONFIG_TULIP +CONFIG_TULIP_FIX_DAVICOM +CONFIG_TULIP_SELECT_MEDIA +CONFIG_TULIP_USE_IO +CONFIG_TWL4030_INPUT +CONFIG_TWL4030_KEYPAD +CONFIG_TWL4030_LED +CONFIG_TWL4030_POWER +CONFIG_TWL4030_PWM +CONFIG_TWL4030_USB +CONFIG_TWL6030_INPUT +CONFIG_TWL6030_POWER +CONFIG_TWR +CONFIG_TWR_P1025 +CONFIG_TX_DESCR_NUM +CONFIG_TZSW_RESERVED_DRAM_SIZE +CONFIG_T_SH7706LSR +CONFIG_UART_BASE +CONFIG_UART_BR_PRELIM +CONFIG_UART_CONSOLE +CONFIG_UART_CONSOLE_IS_JTAG +CONFIG_UART_MEM +CONFIG_UART_OR_PRELIM +CONFIG_UBIBLOCK +CONFIG_UBIFS_SILENCE_MSG +CONFIG_UBIFS_VOLUME +CONFIG_UBI_PART +CONFIG_UBI_SILENCE_MSG +CONFIG_UBI_SIZE +CONFIG_UBOOT1_ENV_ADDR +CONFIG_UBOOT2_ENV_ADDR +CONFIG_UBOOTPATH +CONFIG_UBOOT_ENABLE_PADS_ALL +CONFIG_UBOOT_ENV_ADDR +CONFIG_UBOOT_SECTOR_COUNT +CONFIG_UBOOT_SECTOR_START +CONFIG_UCP1020 +CONFIG_UCP1020_REV_1_3 +CONFIG_UDP_CHECKSUM +CONFIG_UEC_ETH +CONFIG_UEC_ETH1 +CONFIG_UEC_ETH2 +CONFIG_UEC_ETH3 +CONFIG_UEC_ETH4 +CONFIG_UEC_ETH5 +CONFIG_UEC_ETH6 +CONFIG_UEC_ETH7 +CONFIG_UEC_ETH8 +CONFIG_UID16 +CONFIG_ULI526X +CONFIG_ULPI_REF_CLK +CONFIG_UMSDEVS +CONFIG_UNIPHIER_ETH +CONFIG_UNIPHIER_SERIAL +CONFIG_UPDATEB +CONFIG_UPDATE_LOAD_ADDR +CONFIG_UPDATE_TFTP +CONFIG_UPDATE_TFTP_CNT_MAX +CONFIG_UPDATE_TFTP_MSEC_MAX +CONFIG_USART1 +CONFIG_USART3 +CONFIG_USART_BASE +CONFIG_USART_ID +CONFIG_USB +CONFIG_USBBOOTCOMMAND +CONFIG_USBDEBUG +CONFIG_USBD_CONFIGURATION_STR +CONFIG_USBD_CTRL_INTERFACE_STR +CONFIG_USBD_DATA_INTERFACE_STR +CONFIG_USBD_HS +CONFIG_USBD_MANUFACTURER +CONFIG_USBD_PRODUCTID +CONFIG_USBD_PRODUCTID_CDCACM +CONFIG_USBD_PRODUCTID_GSERIAL +CONFIG_USBD_PRODUCT_NAME +CONFIG_USBD_SERIAL_BULK_HS_PKTSIZE +CONFIG_USBD_SERIAL_BULK_PKTSIZE +CONFIG_USBD_SERIAL_INT_ENDPOINT +CONFIG_USBD_SERIAL_INT_PKTSIZE +CONFIG_USBD_SERIAL_IN_ENDPOINT +CONFIG_USBD_SERIAL_IN_PKTSIZE +CONFIG_USBD_SERIAL_OUT_ENDPOINT +CONFIG_USBD_SERIAL_OUT_PKTSIZE +CONFIG_USBD_VENDORID +CONFIG_USBID_ADDR +CONFIG_USBNET_DEV_ADDR +CONFIG_USBNET_HOST_ADDR +CONFIG_USBNET_MANUFACTURER +CONFIG_USB_AM35X +CONFIG_USB_ATMEL +CONFIG_USB_ATMEL_CLK_SEL_PLLB +CONFIG_USB_ATMEL_CLK_SEL_UPLL +CONFIG_USB_BIN_FIXUP +CONFIG_USB_BLACKFIN +CONFIG_USB_BLACKFIN_CLKIN +CONFIG_USB_BOOTING +CONFIG_USB_CABLE_CHECK +CONFIG_USB_CLOCK +CONFIG_USB_CONFIG +CONFIG_USB_DEVICE +CONFIG_USB_DEV_BASE +CONFIG_USB_DEV_PULLUP_GPIO +CONFIG_USB_DWC2 +CONFIG_USB_DWC2_REG_ADDR +CONFIG_USB_DWC3 +CONFIG_USB_DWC3_GADGET +CONFIG_USB_DWC3_HOST +CONFIG_USB_DWC3_OMAP +CONFIG_USB_DWC3_PHY_OMAP +CONFIG_USB_EHCI +CONFIG_USB_EHCI_ARMADA100 +CONFIG_USB_EHCI_ATMEL +CONFIG_USB_EHCI_BASE +CONFIG_USB_EHCI_BASE_LIST +CONFIG_USB_EHCI_EXYNOS +CONFIG_USB_EHCI_FARADAY +CONFIG_USB_EHCI_FSL +CONFIG_USB_EHCI_HCD +CONFIG_USB_EHCI_KIRKWOOD +CONFIG_USB_EHCI_MARVELL +CONFIG_USB_EHCI_MX5 +CONFIG_USB_EHCI_MX6 +CONFIG_USB_EHCI_MX7 +CONFIG_USB_EHCI_MXC +CONFIG_USB_EHCI_MXS +CONFIG_USB_EHCI_OMAP +CONFIG_USB_EHCI_PCI +CONFIG_USB_EHCI_PPC4XX +CONFIG_USB_EHCI_RMOBILE +CONFIG_USB_EHCI_SPEAR +CONFIG_USB_EHCI_SUNXI +CONFIG_USB_EHCI_TEGRA +CONFIG_USB_EHCI_TXFIFO_THRESH +CONFIG_USB_EHCI_VCT +CONFIG_USB_EHCI_VF +CONFIG_USB_EHCI_ZYNQ +CONFIG_USB_ETHER +CONFIG_USB_ETHER_ +CONFIG_USB_ETHER_ASIX +CONFIG_USB_ETHER_ASIX88179 +CONFIG_USB_ETHER_DM9601 +CONFIG_USB_ETHER_MCS7830 +CONFIG_USB_ETHER_RNDIS +CONFIG_USB_ETHER_RTL8152 +CONFIG_USB_ETHER_SMSC95XX +CONFIG_USB_ETH_CDC +CONFIG_USB_ETH_QMULT +CONFIG_USB_ETH_RNDIS +CONFIG_USB_ETH_SUBSET +CONFIG_USB_EXT2_BOOT +CONFIG_USB_FAT_BOOT +CONFIG_USB_FREQ +CONFIG_USB_FUNCTION_DFU +CONFIG_USB_FUNCTION_FASTBOOT +CONFIG_USB_FUNCTION_MASS_STORAGE +CONFIG_USB_FUNCTION_THOR +CONFIG_USB_GADGET +CONFIG_USB_GADGET_AMD5536UDC +CONFIG_USB_GADGET_AT91 +CONFIG_USB_GADGET_ATMEL_USBA +CONFIG_USB_GADGET_AU1X00 +CONFIG_USB_GADGET_BCM_UDC_OTG_PHY +CONFIG_USB_GADGET_DOWNLOAD +CONFIG_USB_GADGET_DUALSPEED +CONFIG_USB_GADGET_DUMMY_HCD +CONFIG_USB_GADGET_DWC2_OTG +CONFIG_USB_GADGET_DWC2_OTG_PHY +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8 +CONFIG_USB_GADGET_FOTG210 +CONFIG_USB_GADGET_FSL_USB2 +CONFIG_USB_GADGET_GOKU +CONFIG_USB_GADGET_IMX +CONFIG_USB_GADGET_M66592 +CONFIG_USB_GADGET_MASS_STORAGE +CONFIG_USB_GADGET_MPC8272 +CONFIG_USB_GADGET_MQ11XX +CONFIG_USB_GADGET_MUSBHSFC +CONFIG_USB_GADGET_N9604 +CONFIG_USB_GADGET_NET2280 +CONFIG_USB_GADGET_OMAP +CONFIG_USB_GADGET_PXA27X +CONFIG_USB_GADGET_PXA2XX +CONFIG_USB_GADGET_S3C2410 +CONFIG_USB_GADGET_SA1100 +CONFIG_USB_GADGET_SUPERH +CONFIG_USB_GADGET_SX2 +CONFIG_USB_GADGET_VBUS_DRAW +CONFIG_USB_HOST_ETHER +CONFIG_USB_HOST_XHCI_BASE +CONFIG_USB_INVENTRA_DMA +CONFIG_USB_ISP1301_I2C_ADDR +CONFIG_USB_KEYBOARD +CONFIG_USB_MAX_CONTROLLER_COUNT +CONFIG_USB_MUSB_AM35X +CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT +CONFIG_USB_MUSB_DSPS +CONFIG_USB_MUSB_GADGET +CONFIG_USB_MUSB_HCD +CONFIG_USB_MUSB_HOST +CONFIG_USB_MUSB_OMAP2PLUS +CONFIG_USB_MUSB_PIO_ONLY +CONFIG_USB_MUSB_SUNXI +CONFIG_USB_MUSB_TIMEOUT +CONFIG_USB_MUSB_TUSB6010 +CONFIG_USB_MUSB_UDC +CONFIG_USB_MUSB_UDD +CONFIG_USB_OHCI +CONFIG_USB_OHCI_EP93XX +CONFIG_USB_OHCI_LPC32XX +CONFIG_USB_OHCI_NEW +CONFIG_USB_OHCI_S3C24XX +CONFIG_USB_OHCI_SUNXI +CONFIG_USB_OMAP3 +CONFIG_USB_OTG +CONFIG_USB_OTG_BLACKLIST_HUB +CONFIG_USB_PHY_CFG_BASE +CONFIG_USB_PHY_TYPE +CONFIG_USB_PXA25X_SMALL +CONFIG_USB_R8A66597_HCD +CONFIG_USB_SERIALNO +CONFIG_USB_SS_BASE +CONFIG_USB_STORAGE +CONFIG_USB_TI_CPPI_DMA +CONFIG_USB_TTY +CONFIG_USB_TUSB_OMAP_DMA +CONFIG_USB_UHCI +CONFIG_USB_ULPI +CONFIG_USB_ULPI_TIMEOUT +CONFIG_USB_ULPI_VIEWPORT +CONFIG_USB_ULPI_VIEWPORT_OMAP +CONFIG_USB_XHCI_DWC3 +CONFIG_USB_XHCI_EXYNOS +CONFIG_USB_XHCI_FSL +CONFIG_USB_XHCI_HCD +CONFIG_USB_XHCI_KEYSTONE +CONFIG_USB_XHCI_OMAP +CONFIG_USB_XHCI_PCI +CONFIG_USB_XHCI_UNIPHIER +CONFIG_USB_XHCI_ZYNQMP +CONFIG_USER_LOWLEVEL_INIT +CONFIG_USE_ARCH_MEMCPY +CONFIG_USE_ARCH_MEMSET +CONFIG_USE_FDT +CONFIG_USE_INTERRUPT +CONFIG_USE_IRQ +CONFIG_USE_NAND +CONFIG_USE_NETDEV +CONFIG_USE_NOR +CONFIG_USE_ONENAND_BOARD_INIT +CONFIG_USE_SPIFLASH +CONFIG_USE_STDINT +CONFIG_USE_TINY_PRINTF +CONFIG_USE_TTY +CONFIG_UTBIPAR_INIT_TBIPA +CONFIG_UT_DM +CONFIG_UT_ENV +CONFIG_UT_TIME +CONFIG_U_BOOT_HDR_ADDR +CONFIG_U_BOOT_HDR_SIZE +CONFIG_U_QE +CONFIG_V38B +CONFIG_VAL +CONFIG_VAR_SIZE_SPL +CONFIG_VCMA9 +CONFIG_VCO_HZ +CONFIG_VCO_MULT +CONFIG_VCT_NOR +CONFIG_VCT_ONENAND +CONFIG_VCT_PLATINUM +CONFIG_VCT_PLATINUMAVC +CONFIG_VCT_PREMIUM +CONFIG_VCT_SMALL_IMAGE +CONFIG_VE8313 +CONFIG_VERSION_VARIABLE +CONFIG_VERY_BIG_RAM +CONFIG_VEXPRESS_EXTENDED_MEMORY_MAP +CONFIG_VEXPRESS_ORIGINAL_MEMORY_MAP +CONFIG_VF610 +CONFIG_VGA_AS_SINGLE_DEVICE +CONFIG_VGA_BIOS_ADDR +CONFIG_VID +CONFIG_VIDCONSOLE_AS_LCD +CONFIG_VIDEO +CONFIG_VIDEO_BCM2835 +CONFIG_VIDEO_BMP_GZIP +CONFIG_VIDEO_BMP_LOGO +CONFIG_VIDEO_BMP_RLE8 +CONFIG_VIDEO_BPP16 +CONFIG_VIDEO_BPP32 +CONFIG_VIDEO_BPP8 +CONFIG_VIDEO_COMPOSITE +CONFIG_VIDEO_CORALP +CONFIG_VIDEO_CT69000 +CONFIG_VIDEO_DA8XX +CONFIG_VIDEO_DT_SIMPLEFB +CONFIG_VIDEO_FONT_4X6 +CONFIG_VIDEO_HDMI +CONFIG_VIDEO_HW_CURSOR +CONFIG_VIDEO_IPUV3 +CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW +CONFIG_VIDEO_LCD_I2C_BUS +CONFIG_VIDEO_LCD_IF_LVDS +CONFIG_VIDEO_LCD_IF_PARALLEL +CONFIG_VIDEO_LCD_MODE +CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804 +CONFIG_VIDEO_LCD_PANEL_I2C +CONFIG_VIDEO_LCD_PANEL_I2C_SCL +CONFIG_VIDEO_LCD_PANEL_I2C_SDA +CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828 +CONFIG_VIDEO_LCD_SSD2828 +CONFIG_VIDEO_LCD_SSD2828_TX_CLK +CONFIG_VIDEO_LOGO +CONFIG_VIDEO_MB862 +CONFIG_VIDEO_MX3 +CONFIG_VIDEO_MXS +CONFIG_VIDEO_MXS_MODE_SYSTEM +CONFIG_VIDEO_OMAP3 +CONFIG_VIDEO_ONBOARD +CONFIG_VIDEO_SED13806 +CONFIG_VIDEO_SED13806_16BPP +CONFIG_VIDEO_SED13806_8BPP +CONFIG_VIDEO_SM501 +CONFIG_VIDEO_SM501_16BPP +CONFIG_VIDEO_SM501_32BPP +CONFIG_VIDEO_SM501_8BPP +CONFIG_VIDEO_SM501_PCI +CONFIG_VIDEO_SMI_LYNXEM +CONFIG_VIDEO_STD_TIMINGS +CONFIG_VIDEO_SUNXI +CONFIG_VIDEO_SW_CURSOR +CONFIG_VIDEO_TEGRA20 +CONFIG_VIDEO_VCXK +CONFIG_VIDEO_VGA +CONFIG_VIDEO_VGA_VIA_LCD +CONFIG_VIDEO_VGA_VIA_LCD_FORCE_SYNC_ACTIVE_HIGH +CONFIG_VID_FLS_ENV +CONFIG_VM86 +CONFIG_VME8349 +CONFIG_VOIPAC_LCD +CONFIG_VOL_MONITOR_INA220 +CONFIG_VOL_MONITOR_IR36021_READ +CONFIG_VOL_MONITOR_IR36021_SET +CONFIG_VOM405 +CONFIG_VR_CTL_CLKBUF +CONFIG_VR_CTL_FREQ +CONFIG_VR_CTL_VAL +CONFIG_VR_CTL_VLEV +CONFIG_VSC7385_ENET +CONFIG_VSC7385_IMAGE +CONFIG_VSC7385_IMAGE_SIZE +CONFIG_VSC9953 +CONFIG_VSC_CROSSBAR +CONFIG_VYBRID_GPIO +CONFIG_WALNUT +CONFIG_WATCHDOG +CONFIG_WATCHDOG_BASEADDR +CONFIG_WATCHDOG_IRQ +CONFIG_WATCHDOG_NOWAYOUT +CONFIG_WATCHDOG_PRESC +CONFIG_WATCHDOG_RC +CONFIG_WATCHDOG_TIMEOUT +CONFIG_WATCHDOG_TIMEOUT_MSECS +CONFIG_WDOG_GPIO_PIN +CONFIG_WDT_BASE +CONFIG_WD_MAX_RATE +CONFIG_WD_PERIOD +CONFIG_WINBOND_83C553 +CONFIG_WRU4 +CONFIG_X600 +CONFIG_X86 +CONFIG_X86EMU_DEBUG +CONFIG_X86EMU_RAW_IO +CONFIG_X86_64 +CONFIG_X86_BSWAP +CONFIG_X86_MRC_ADDR +CONFIG_X86_REFCODE_ADDR +CONFIG_X86_REFCODE_RUN_ADDR +CONFIG_X86_RESET_VECTOR +CONFIG_XGI_XG22_BASE +CONFIG_XILINX_405 +CONFIG_XILINX_440 +CONFIG_XILINX_GPIO +CONFIG_XILINX_LL_TEMAC +CONFIG_XILINX_LL_TEMAC_CLK +CONFIG_XILINX_MICROBLAZE0_USE_MSR_INSTR +CONFIG_XILINX_PPC440_GENERIC +CONFIG_XILINX_SPI_IDLE_VAL +CONFIG_XILINX_TB_WATCHDOG +CONFIG_XPEDITE1000 +CONFIG_XPEDITE5140 +CONFIG_XPEDITE5200 +CONFIG_XPEDITE5370 +CONFIG_XPEDITE550X +CONFIG_XR16L2751 +CONFIG_XSENGINE +CONFIG_XTFPGA +CONFIG_XTFPGA_LX60 +CONFIG_XWAY_SWAP_BYTES +CONFIG_XXX +CONFIG_YAFFS2 +CONFIG_YAFFSFS_PROVIDE_VALUES +CONFIG_YAFFS_AUTO_UNICODE +CONFIG_YAFFS_CASE_INSENSITIVE +CONFIG_YAFFS_DEFINES_TYPES +CONFIG_YAFFS_DIRECT +CONFIG_YAFFS_PROVIDE_DEFS +CONFIG_YAFFS_UNICODE +CONFIG_YAFFS_UTIL +CONFIG_YAFFS_WINCE +CONFIG_YELLOWSTONE +CONFIG_YELLOW_LED +CONFIG_ZBOOT_32 +CONFIG_ZLIB +CONFIG_ZLT +CONFIG_ZM7300 +CONFIG_ZYNQMP_EEPROM +CONFIG_ZYNQMP_XHCI_LIST +CONFIG_ZYNQ_EEPROM +CONFIG_ZYNQ_EEPROM_BUS +CONFIG_ZYNQ_GEM_EEPROM_ADDR +CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET +CONFIG_ZYNQ_HISPD_BROKEN +CONFIG_ZYNQ_I2C0 +CONFIG_ZYNQ_I2C1 +CONFIG_ZYNQ_PS_CLK_FREQ +CONFIG_ZYNQ_QSPI +CONFIG_ZYNQ_SDHCI +CONFIG_ZYNQ_SDHCI0 +CONFIG_ZYNQ_SDHCI1 +CONFIG_ZYNQ_SDHCI_MAX_FREQ +CONFIG_ZYNQ_SDHCI_MIN_FREQ +CONFIG_ZYNQ_SERIAL +CONFIG_ZYNQ_SPI
On 08/24/2016 08:44 AM, Simon Glass wrote:
Add a list of ad-hoc CONFIG options that don't use Kconfig. This can be used to check that new ones are not being added.
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt
+CONFIG_
Does that indicate a bug in the regex in the whitelist generation script?
New CONFIG options should be added via Kconfig. To help prevent new ad-hoc CONFIGs from being added, give a build error when these are detected.
Makefile | 10 ++++++++- scripts/check-config.sh | 55 +++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 64 insertions(+), 1 deletion(-) create mode 100755 scripts/check-config.sh
diff --git a/Makefile b/Makefile index c66bd2f..080b913 100644 --- a/Makefile +++ b/Makefile @@ -740,7 +740,8 @@ DO_STATIC_RELA = endif
# Always append ALL so that arch config.mk's can add custom ones -ALL-y += u-boot.srec u-boot.bin u-boot.sym System.map u-boot.cfg binary_size_check +ALL-y += u-boot.srec u-boot.bin u-boot.sym System.map u-boot.cfg \ + binary_size_check no_new_adhoc_configs_check
ALL-$(CONFIG_ONENAND_U_BOOT) += u-boot-onenand.bin ifeq ($(CONFIG_SPL_FSL_PBL),y) @@ -938,6 +939,13 @@ u-boot.dis: u-boot u-boot.cfg: include/config.h FORCE $(call if_changed,cpp_cfg)
+# Check that this build does not use CONFIG options that we don't know about +# unless they are in Kconfig. All the existing CONFIG options are whitelisted, +# so new ones should not be added. +no_new_adhoc_configs_check: u-boot.cfg FORCE + $(srctree)/scripts/check-config.sh $< \ + $(srctree)/scripts/config_whitelist.txt ${srctree} + ifdef CONFIG_TPL SPL_PAYLOAD := tpl/u-boot-with-tpl.bin else diff --git a/scripts/check-config.sh b/scripts/check-config.sh new file mode 100755 index 0000000..1d87686 --- /dev/null +++ b/scripts/check-config.sh @@ -0,0 +1,55 @@ +#!/bin/sh +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# Check that the u-boot.cfg file provided does not introduce any new +# ad-hoc CONFIG options +# +# You can generate the list of current ad-hoc CONFIG options (those which are +# not in Kconfig) with this command: +# +# export LC_ALL=C LC_COLLATE=C +# git grep CONFIG_ |tr ' \t' '\n\n' |sed -n 's/^(CONFIG_[A-Z0-9_]*).*/\1/p' \ +# |sort |uniq >scripts/config_whitelist.txt; +# unset LC_ALL LC_COLLATE + +# Usage +# check-config.sh <path to u-boot.cfg> <path to whitelist file> <source dir> +# +# For example: +# scripts/check-config.sh b/chromebook_link/u-boot.cfg kconfig_whitelist.txt . + +path="$1" +whitelist="$2" +srctree="$3" + +# Temporary files +configs="${path}.configs" +suspects="${path}.suspects" +ok="${path}.ok" +new_adhoc="${path}.adhoc" + +export LC_ALL=C +export LC_COLLATE=C + +cat ${path} |sed -n 's/^#define (CONFIG_[A-Z0-9_]*).*/\1/p' |sort |uniq \ + >${configs} + +comm -23 ${configs} ${whitelist} > ${suspects} + +cat `find ${srctree} -name Kconfig` |sed -n \ + -e 's/^config ([A-Z0-9_]*).*$/CONFIG_\1/p' \ + -e 's/^menuconfig ([A-Z0-9_]*).*$/CONFIG_\1/p' |sort |uniq > ${ok} +comm -23 ${suspects} ${ok} >${new_adhoc} +if [ -s ${new_adhoc} ]; then + echo "Error: You must add new CONFIG options using Kconfig" + echo "The following new ad-hoc CONFIG options were detected:" + cat ${new_adhoc} + echo + echo "Please add these via Kconfig instead. Find a suitable Kconfig" + echo "file and add a 'config' or 'menuconfig' option." + # Don't delete the temporary files in case they are useful + exit 1 +else + rm ${suspects} ${ok} ${new_adhoc} +fi
Acked-by: Stephen Warren swarren@nvidia.com Tested-by: Stephen Warren swarren@nvidia.com
I worried about the increased build time due to find/grep on all Kconfig files, but at least with a hot disk cache it seems to make no noticeable difference:-)
FWIW, CONFIG_SPL_GPIO_SUPPORT is missing in the whitelist, which affects the Jetson TK1 build (and likely all/most other Tegra boards).
Ah, that's why "CONFIG_" is in the current whitelist; there are Makefiles that reference CONFIG_$(SPL)_SOMETHING. Handling that automatically might be a little involved for a one-off thing; I guess you'd need to manually fix up the whitelist for this?
Hi Stephen,
I'm not sure yet. There are a large number of failures so for the real patch I'll have to figure out something. I was hoping that a bit more sed stuff will solve it, but we'll see.
Hi Stephen,
That has been moved to Kconfig (this patch sits on top of that series).
Hi Stephen,
Yes it was pretty slow at first, but I fiddled with it to sort that.
The current approach is based on files that are already generated by the build. There is a very small overhead but it is small enough that I cannot reliably measure it.
Stephen Warren
