[U-Boot] [PATCH] board/BuR/brsmarc1: initial commit
This commit adds support for the B&R brsmarc1 SoM.
The SoM is based on TI's AM335x SoC. Mainly vxWorks 6.9.4.x is running on the board, doing some PLC stuff on various carrier boards.
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
arch/arm/dts/Makefile | 1 + arch/arm/dts/am335x-brsmarc1.dts | 408 +++++++++++++++++++++++++++++++++++++ arch/arm/mach-omap2/Kconfig | 1 + arch/arm/mach-omap2/am33xx/Kconfig | 3 + board/BuR/brsmarc1/Kconfig | 15 ++ board/BuR/brsmarc1/MAINTAINERS | 6 + board/BuR/brsmarc1/Makefile | 13 ++ board/BuR/brsmarc1/board.c | 168 +++++++++++++++ board/BuR/brsmarc1/config.mk | 34 ++++ board/BuR/brsmarc1/mux.c | 266 ++++++++++++++++++++++++ configs/brsmarc1_defconfig | 107 ++++++++++ include/configs/brsmarc1.h | 87 ++++++++ 12 files changed, 1109 insertions(+) create mode 100644 arch/arm/dts/am335x-brsmarc1.dts create mode 100644 board/BuR/brsmarc1/Kconfig create mode 100644 board/BuR/brsmarc1/MAINTAINERS create mode 100644 board/BuR/brsmarc1/Makefile create mode 100644 board/BuR/brsmarc1/board.c create mode 100644 board/BuR/brsmarc1/config.mk create mode 100644 board/BuR/brsmarc1/mux.c create mode 100644 configs/brsmarc1_defconfig create mode 100644 include/configs/brsmarc1.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index dfa5b02..8ac057a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -250,6 +250,7 @@ dtb-$(CONFIG_AM33XX) += \ am335x-brppt1-nand.dtb \ am335x-brppt1-spi.dtb \ am335x-brxre1.dtb \ + am335x-brsmarc1.dtb \ am335x-draco.dtb \ am335x-evm.dtb \ am335x-evmsk.dtb \ diff --git a/arch/arm/dts/am335x-brsmarc1.dts b/arch/arm/dts/am335x-brsmarc1.dts new file mode 100644 index 0000000..e5e2761 --- /dev/null +++ b/arch/arm/dts/am335x-brsmarc1.dts @@ -0,0 +1,408 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2017 B&R Industrial Automation GmbH + * http://www.br-automation.com + * + */ +/dts-v1/; + +#include "am33xx.dtsi" + +/ { + model = "BRSMARC1 SoM"; + compatible = "ti,am33xx"; + + fset: factory-settings { + bl-version = " "; + order-no = " "; + cpu-order-no = " "; + hw-revision = " "; + serial-no = <0>; + device-id = <0x0>; + parent-id = <0x0>; + hw-variant = <0x0>; + hw-platform = <0x7>; + fram-offset = <0x100>; + fram-size = <0x1F00>; + cache-disable = <0x0>; + cpu-clock = <0x0>; + }; + + chosen { + bootargs = "console=ttyO0,115200 earlyprintk"; + stdout-path = &uart0; + }; + + aliases { + fset = &fset; + mmc = &mmc2; + spi0 = &spi0; + spi1 = &spi1; + touch0 = &burtouch0; + screen0 = &lcdscreen0; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x10000000>; /* 256 MB */ + }; + + vmmcsd_fixed: fixedregulator@0 { + compatible = "regulator-fixed"; + regulator-name = "vmmcsd_fixed"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + lcdscreen0: lcdscreen@0 { + /*backlight = <&tps_bl>; */ + compatible = "ti,tilcdc,panel"; + status = "okay"; + + panel-info { + ac-bias = <255>; + ac-bias-intrpt = <0>; + dma-burst-sz = <16>; + bpp = <32>; + fdd = <0x80>; + sync-edge = <0>; + sync-ctrl = <1>; + raster-order = <0>; + fifo-th = <0>; + rotation = <0>; + pupdelay = <0>; + pondelay = <0>; + pwrpin = <0x000000B1>; + brightdrv = <0>; + brightfdim = <100>; + brightdef = <50>; + }; + + display-timings { + default { + clock-frequency = <0>; + hactive = <0>; + vactive = <0>; + hfront-porch = <0>; + hback-porch = <0>; + hsync-len = <0>; + vfront-porch = <0>; + vback-porch = <0>; + vsync-len = <0>; + hsync-active = <0>; + vsync-active = <0>; + pupdelay = <10>; + pondelay = <10>; + }; + }; + }; + + board_thermal: board-thermal { + polling-delay-passive = <1000>; /* milliseconds */ + polling-delay = <2500>; /* milliseconds */ + + thermal-sensors = <&cputemp>; + + trips { + crit_trip: crit-trip { + temperature = <95000>; /* millicelsius */ + hysteresis = <5000>; /* millicelsius */ + type = "critical"; + }; + }; + cooling-maps { + map0 { + trip = <&crit_trip>; + cooling-device = <&resetc>; + }; + }; + }; +}; + +&uart0 { /* console uart */ + u-boot,dm-spl; + status = "okay"; +}; + +&uart2 { /* X2X - P2P */ + status = "okay"; +}; + +&uart3 { /* RS485 */ + status = "okay"; +}; + +&uart4 { /* RS232 */ + status = "okay"; +}; + +&i2c0 { + u-boot,dm-spl; + status = "okay"; + clock-frequency = <100000>; + + tps: tps@24 { /* PMIC controller */ + u-boot,dm-spl; + reg = <0x24>; + compatible = "ti,tps65217"; + }; + + cputemp: pct2075_0@48 { /* cpu temperature */ + compatible = "nxp,pct2075"; + reg = <0x48>; + }; + + extrtc: rx8571@51 { /* realtime clock */ + compatible = "epson,rx8571"; + reg = <0x51>; + }; + + resetc: rststm@60 { /* reset controller */ + compatible = "bur,rststm"; + reg = <0x60>; + + cooling-min-state = <0>; + cooling-max-state = <1>; /* reset gets fired */ + #cooling-cells = <2>; /* min followed by max */ + }; +}; + +&i2c1 { + u-boot,dm-spl; + status = "okay"; +}; + +&spi0 { + u-boot,dm-spl; + status = "okay"; + + cs-gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>, + <&gpio0 6 GPIO_ACTIVE_HIGH>, + <0>, + <0>; + + spi-max-frequency = <24000000>; + + spi_flash: spiflash@0 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; + compatible = "spidev", "spi-flash"; + spi-max-frequency = <24000000>; + reg = <0>; + }; +}; + +&spi1 { + u-boot,dm-spl; + status = "okay"; + cs-gpios = <&gpio3 17 GPIO_ACTIVE_HIGH>, + <&gpio0 19 GPIO_ACTIVE_HIGH>, + <0>, + <0>; + + spi-max-frequency = <24000000>; +}; + +&edma { + status = "okay"; +}; + +&cppi41dma { + status = "okay"; +}; + +&usb { + status = "okay"; +}; + +&usb_ctrl_mod { + status = "okay"; +}; + +&usb0_phy { + status = "okay"; +}; + +&usb1_phy { + status = "okay"; +}; + +&usb0 { + status = "okay"; + dr_mode = "host"; +}; + +&usb1 { + status = "okay"; + dr_mode = "host"; +}; + +&davinci_mdio { + status = "okay"; +}; + +&mac { + status = "okay"; +}; + +&phy_sel { + rmii-clock-ext; +}; + +&cpsw_emac0 { + phy_id = <&davinci_mdio>, <1>; + phy-mode = "rmii"; + ti,ledcr = <0x0480>; +}; + +&cpsw_emac1 { + phy_id = <&davinci_mdio>, <3>; + phy-mode = "rmii"; + ti,ledcr = <0x0480>; +}; + +&mmc1 { + vmmc-supply = <&vmmcsd_fixed>; + bus-width = <0x4>; + ti,non-removable; + ti,needs-special-hs-handling; + ti,vcc-aux-disable-is-sleep; + status = "okay"; +}; + +&mmc2 { + vmmc-supply = <&vmmcsd_fixed>; + bus-width = <0x8>; + ti,non-removable; + ti,needs-special-hs-handling; + ti,vcc-aux-disable-is-sleep; + status = "okay"; +}; + +&lcdc { + status = "okay"; + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&elm { + status = "okay"; +}; + +&sham { + status = "okay"; +}; + +&aes { + status = "okay"; +}; + +&gpio0 { + u-boot,dm-spl; + ti,no-reset-on-init; +}; + +&gpio1 { + u-boot,dm-spl; + ti,no-reset-on-init; +}; + +&gpio2 { + u-boot,dm-spl; + ti,no-reset-on-init; +}; + +&gpio3 { + u-boot,dm-spl; + ti,no-reset-on-init; +}; + +&timer1 { /* today unused */ + status = "okay"; + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&timer2 { /* used for vxworks primary timer device */ + status = "okay"; + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&timer3 { /* used sysdelay and hal tsc counter*/ + status = "okay"; + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&timer4 { /* used for PWM beeper */ + status = "okay"; + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&timer5 { /* used for PWM backlight */ + status = "okay"; + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&timer6 { /* used for cpsw end device */ + status = "okay"; + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&timer7 { /* used for cpsw end device */ + status = "okay"; + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&wdt2 { + status = "okay"; + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&epwmss0 { + status = "okay"; +}; + +&tscadc { + status = "okay"; + + tsc { + burtouch0: burtouch@0 { + status = "okay"; + compatible = "bur,DdVxSfTouchXXX"; + bur,hwtree = "IF7"; + bur,KX0 = <0x0>; + bur,KX1 = <0x0>; + bur,KX2 = <0x0>; + bur,KY0 = <0x0>; + bur,KY1 = <0x0>; + bur,KY2 = <0x0>; + }; + }; +}; + +&dcan0 { + status = "okay"; +}; + +&dcan1 { + status = "okay"; +}; + +&sham { + status = "disabled"; +}; + +&aes { + status = "disabled"; +}; + +&rng { + status = "disabled"; +}; diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index d29f1ca..bb27b34 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -176,6 +176,7 @@ source "arch/arm/mach-omap2/omap5/Kconfig" source "arch/arm/mach-omap2/am33xx/Kconfig"
source "board/BuR/brxre1/Kconfig" +source "board/BuR/brsmarc1/Kconfig" source "board/BuR/brppt1/Kconfig" source "board/siemens/draco/Kconfig" source "board/siemens/pxm2/Kconfig" diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 500df1a..3ec154e 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -121,6 +121,9 @@ config TARGET_BRXRE1 bool "Support BRXRE1" select BOARD_LATE_INIT
+config TARGET_BRSMARC1 + bool "Support BRSMARC1" + select BOARD_LATE_INIT config TARGET_BRPPT1 bool "Support BRPPT1" select BOARD_LATE_INIT diff --git a/board/BuR/brsmarc1/Kconfig b/board/BuR/brsmarc1/Kconfig new file mode 100644 index 0000000..6d3d7a2 --- /dev/null +++ b/board/BuR/brsmarc1/Kconfig @@ -0,0 +1,15 @@ +if TARGET_BRSMARC1 + +config SYS_BOARD + default "brsmarc1" + +config SYS_VENDOR + default "BuR" + +config SYS_SOC + default "am33xx" + +config SYS_CONFIG_NAME + default "brsmarc1" + +endif diff --git a/board/BuR/brsmarc1/MAINTAINERS b/board/BuR/brsmarc1/MAINTAINERS new file mode 100644 index 0000000..c6dfc20 --- /dev/null +++ b/board/BuR/brsmarc1/MAINTAINERS @@ -0,0 +1,6 @@ +BRSMARC1 BOARD +M: Hannes Schmelzer hannes.schmelzer@br-automation.com +S: Maintained +F: board/BuR/brsmarc1/ +F: include/configs/brsmarc1.h +F: configs/brsmarc1_defconfig diff --git a/board/BuR/brsmarc1/Makefile b/board/BuR/brsmarc1/Makefile new file mode 100644 index 0000000..6ef6cef --- /dev/null +++ b/board/BuR/brsmarc1/Makefile @@ -0,0 +1,13 @@ +# +# Makefile +# +# Copyright (C) 2017 Hannes Schmelzer oe5hpm@oevsv.at - +# B&R Industrial Automation GmbH - http://www.br-automation.com/ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_SPL_BUILD) += mux.o +obj-y += ../common/br_resetc.o +obj-y += ../common/common.o +obj-y += board.o diff --git a/board/BuR/brsmarc1/board.c b/board/BuR/brsmarc1/board.c new file mode 100644 index 0000000..4c70346 --- /dev/null +++ b/board/BuR/brsmarc1/board.c @@ -0,0 +1,168 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * board.c + * + * Board functions for B&R BRSMARC1 Board + * + * Copyright (C) 2017 Hannes Schmelzer oe5hpm@oevsv.at + * B&R Industrial Automation GmbH - http://www.br-automation.com + * + */ +#include <common.h> +#include <errno.h> +#include <spl.h> +#include <asm/arch/cpu.h> +#include <asm/arch/hardware.h> +#include <asm/arch/omap.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mem.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include <asm/emif.h> +#include <power/tps65217.h> +#include "../common/bur_common.h" +#include "../common/br_resetc.h" + +/* -------------------------------------------------------------------------*/ +/* -- defines for used GPIO Hardware -- */ +#define PER_RESET (2 * 32 + 0) + +DECLARE_GLOBAL_DATA_PTR; + +#if defined(CONFIG_SPL_BUILD) +static const struct ddr_data ddr3_data = { + .datardsratio0 = MT41K256M16HA125E_RD_DQS, + .datawdsratio0 = MT41K256M16HA125E_WR_DQS, + .datafwsratio0 = MT41K256M16HA125E_PHY_FIFO_WE, + .datawrsratio0 = MT41K256M16HA125E_PHY_WR_DATA, +}; + +static const struct cmd_control ddr3_cmd_ctrl_data = { + .cmd0csratio = MT41K256M16HA125E_RATIO, + .cmd0iclkout = MT41K256M16HA125E_INVERT_CLKOUT, + + .cmd1csratio = MT41K256M16HA125E_RATIO, + .cmd1iclkout = MT41K256M16HA125E_INVERT_CLKOUT, + + .cmd2csratio = MT41K256M16HA125E_RATIO, + .cmd2iclkout = MT41K256M16HA125E_INVERT_CLKOUT, +}; + +static struct emif_regs ddr3_emif_reg_data = { + .sdram_config = MT41K256M16HA125E_EMIF_SDCFG, + .ref_ctrl = MT41K256M16HA125E_EMIF_SDREF, + .sdram_tim1 = MT41K256M16HA125E_EMIF_TIM1, + .sdram_tim2 = MT41K256M16HA125E_EMIF_TIM2, + .sdram_tim3 = MT41K256M16HA125E_EMIF_TIM3, + .zq_config = MT41K256M16HA125E_ZQ_CFG, + .emif_ddr_phy_ctlr_1 = MT41K256M16HA125E_EMIF_READ_LATENCY, +}; + +static const struct ctrl_ioregs ddr3_ioregs = { + .cm0ioctl = MT41K256M16HA125E_IOCTRL_VALUE, + .cm1ioctl = MT41K256M16HA125E_IOCTRL_VALUE, + .cm2ioctl = MT41K256M16HA125E_IOCTRL_VALUE, + .dt0ioctl = MT41K256M16HA125E_IOCTRL_VALUE, + .dt1ioctl = MT41K256M16HA125E_IOCTRL_VALUE, +}; + +#define OSC (V_OSCK / 1000000) +const struct dpll_params dpll_ddr3 = { 400, OSC - 1, 1, -1, -1, -1, -1}; + +void am33xx_spl_board_init(void) +{ + struct cm_perpll *const cmper = (struct cm_perpll *)CM_PER; + struct cm_wkuppll *const cmwkup = (struct cm_wkuppll *)CM_WKUP; + + int rc; + /* + * enable additional clocks of modules which are accessed later from + * VxWorks OS + */ + u32 *const clk_domains[] = { 0 }; + u32 *const clk_modules_specific[] = { + &cmwkup->wkup_adctscctrl, + &cmper->spi1clkctrl, + &cmper->dcan0clkctrl, + &cmper->dcan1clkctrl, + &cmper->timer4clkctrl, + &cmper->timer5clkctrl, + &cmper->lcdclkctrl, + &cmper->lcdcclkstctrl, + 0 + }; + do_enable_clocks(clk_domains, clk_modules_specific, 1); + + /* setup I2C */ + enable_i2c_pin_mux(); + + /* peripheral reset */ + rc = gpio_request(PER_RESET, "PER_RESET"); + if (rc != 0) + printf("cannot request PER_RESET GPIO!\n"); + + rc = gpio_direction_output(PER_RESET, 0); + if (rc != 0) + printf("cannot set PER_RESET GPIO!\n"); + + /* setup pmic */ + pmicsetup(0, 0); +} + +const struct dpll_params *get_dpll_ddr_params(void) +{ + return &dpll_ddr3; +} + +void sdram_init(void) +{ + config_ddr(400, &ddr3_ioregs, + &ddr3_data, + &ddr3_cmd_ctrl_data, + &ddr3_emif_reg_data, 0); +} +#endif /* CONFIG_SPL_BUILD */ +#if !defined(CONFIG_SPL_BUILD) + +/* decision if backlight is switched on or not on powerup */ +int board_backlightstate(void) +{ + u8 bklmask, rstcause; + int rc = 0; + + rc |= br_resetc_regget(RSTCTRL_SCRATCHREG1, &bklmask); + rc |= br_resetc_regget(RSTCTRL_ERSTCAUSE, &rstcause); + + if (rc != 0) { + printf("%s: read rstctrl failed!\n", __func__); + return 1; + } + + if ((rstcause & bklmask) != 0) + return 0; + + return 1; +} + +/* Basic board specific setup. run quite after relocation */ +int board_init(void) +{ + if (power_tps65217_init(0)) + printf("WARN: cannot setup PMIC 0x24 @ bus #0, not found!.\n"); + + return 0; +} + +#if defined(CONFIG_BOARD_LATE_INIT) + +int board_late_init(void) +{ + br_resetc_bmode(); + + return 0; +} + +#endif /* CONFIG_BOARD_LATE_INIT */ +#endif /* !CONFIG_SPL_BUILD */ diff --git a/board/BuR/brsmarc1/config.mk b/board/BuR/brsmarc1/config.mk new file mode 100644 index 0000000..b8aa3d2 --- /dev/null +++ b/board/BuR/brsmarc1/config.mk @@ -0,0 +1,34 @@ +# +# Copyright (C) 2018 Hannes Schmelzer oe5hpm@oevsv.at - +# B&R Industrial Automation GmbH - http://www.br-automation.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +hw-platform-y :=$(shell echo $(CONFIG_DEFAULT_DEVICE_TREE) | sed -e 's/am335x-//') + +payload_off :=$(shell printf "%d" $(CONFIG_SYS_SPI_U_BOOT_OFFS)) + +quiet_cmd_prodbin = PRODBIN $@ $(payload_off) +cmd_prodbin = \ + dd if=/dev/zero ibs=1M count=2 2>/dev/null | tr "\000" "\377" >$@ && \ + dd conv=notrunc bs=1 if=MLO.byteswap of=$@ seek=0 2>/dev/null && \ + dd bs=1 if=u-boot-dtb.img of=$@ seek=$(payload_off) 2>/dev/null + +quiet_cmd_prodzip = SAPZIP $@ +cmd_prodzip = \ + test -d misc && rm -r misc; \ + mkdir misc && \ + cp MLO.byteswap misc/ && \ + cp spl/u-boot-spl.bin misc/ && \ + cp u-boot-dtb.img misc/ && \ + zip -9 -r $@ misc/* >/dev/null $< + +ALL-y += $(hw-platform-y)_prog.bin +ALL-y += $(hw-platform-y)_prod.zip + +$(hw-platform-y)_prog.bin: u-boot-dtb.img spl/u-boot-spl.bin + $(call if_changed,prodbin) + +$(hw-platform-y)_prod.zip: $(hw-platform-y)_prog.bin + $(call if_changed,prodzip) \ No newline at end of file diff --git a/board/BuR/brsmarc1/mux.c b/board/BuR/brsmarc1/mux.c new file mode 100644 index 0000000..33c214d --- /dev/null +++ b/board/BuR/brsmarc1/mux.c @@ -0,0 +1,266 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * mux.c + * + * Pinmux Setting for B&R BRSMARC1 Board (HW-Rev. 1) + * + * Copyright (C) 2017 Hannes Schmelzer hannes.schmelzer@br-automation.com + * B&R Industrial Automation GmbH - http://www.br-automation.com + * + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h> +#include <asm/arch/mux.h> +#include <asm/io.h> +#include <i2c.h> + +static struct module_pin_mux spi0_pin_mux[] = { + /* SPI0_SCLK */ + {OFFSET(spi0_sclk), MODE(0) | PULLUDEN | RXACTIVE}, + /* SPI0_D0 */ + {OFFSET(spi0_d0), MODE(0) | PULLUDEN | RXACTIVE}, + /* SPI0_D1 */ + {OFFSET(spi0_d1), MODE(0) | PULLUDEN | RXACTIVE}, + /* SPI0_CS0 */ + {OFFSET(spi0_cs0), MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE}, + /* SPI0_CS1 */ + {OFFSET(spi0_cs1), MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE}, + {-1}, +}; + +static struct module_pin_mux spi1_pin_mux[] = { + /* SPI1_SCLK */ + {OFFSET(mcasp0_aclkx), MODE(3) | PULLUDEN | RXACTIVE}, + /* SPI1_D0 */ + {OFFSET(mcasp0_fsx), MODE(3) | PULLUDEN | RXACTIVE}, + /* SPI1_D1 */ + {OFFSET(mcasp0_axr0), MODE(3) | PULLUDEN | RXACTIVE}, + /* SPI1_CS0 */ + {OFFSET(mcasp0_ahclkr), MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE}, + /* SPI1_CS1 */ + {OFFSET(xdma_event_intr0), MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE}, + {-1}, +}; + +static struct module_pin_mux dcan0_pin_mux[] = { + /* DCAN0 TX */ + {OFFSET(uart1_ctsn), MODE(2) | PULLUDEN | PULLUP_EN}, + /* DCAN0 RX */ + {OFFSET(uart1_rtsn), MODE(2) | RXACTIVE}, + {-1}, +}; + +static struct module_pin_mux dcan1_pin_mux[] = { + /* DCAN1 TX */ + {OFFSET(uart0_ctsn), MODE(2) | PULLUDEN | PULLUP_EN}, + /* DCAN1 RX */ + {OFFSET(uart0_rtsn), MODE(2) | RXACTIVE}, + {-1}, +}; + +static struct module_pin_mux gpios[] = { + /* GPIO0_7 - LVDS_EN */ + {OFFSET(ecap0_in_pwm0_out), (MODE(7) | PULLUDDIS | PULLDOWN_EN)}, + /* GPIO0_20 - BKLT_PWM (timer7) */ + {OFFSET(xdma_event_intr1), (MODE(4) | PULLUDDIS | PULLDOWN_EN)}, + /* GPIO2_4 - DISON */ + {OFFSET(gpmc_wen), (MODE(7) | PULLUDDIS | PULLDOWN_EN)}, + /* GPIO1_24 - RGB_EN */ + {OFFSET(gpmc_a8), (MODE(7) | PULLUDDIS | PULLDOWN_EN)}, + /* GPIO1_28 - nPD */ + {OFFSET(gpmc_be1n), (MODE(7) | PULLUDEN | PULLUP_EN)}, + /* GPIO2_5 - Watchdog */ + {OFFSET(gpmc_be0n_cle), (MODE(7) | PULLUDDIS | PULLDOWN_EN)}, + /* GPIO2_0 - ResetOut */ + {OFFSET(gpmc_csn3), (MODE(7) | PULLUDEN | PULLUP_EN)}, + /* GPIO2_2 - BKLT_EN */ + {OFFSET(gpmc_advn_ale), (MODE(7) | PULLUDDIS | PULLDOWN_EN)}, + /* GPIO1_17 - GPIO0 */ + {OFFSET(gpmc_a1), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO1_18 - GPIO1 */ + {OFFSET(gpmc_a2), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO1_19 - GPIO2 */ + {OFFSET(gpmc_a3), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO1_22 - GPIO3 */ + {OFFSET(gpmc_a6), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO1_23 - GPIO4 */ + {OFFSET(gpmc_a7), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO1_25 - GPIO5 */ + {OFFSET(gpmc_a9), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO3_7 - GPIO6 */ + {OFFSET(emu0), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO3_8 - GPIO7 */ + {OFFSET(emu1), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO3_18 - GPIO8 */ + {OFFSET(mcasp0_aclkr), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO3_19 - GPIO9 */ + {OFFSET(mcasp0_fsr), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO3_20 - GPIO10 */ + {OFFSET(mcasp0_axr1), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO3_21 - GPIO11 */ + {OFFSET(mcasp0_ahclkx), (MODE(7) | PULLUDDIS | RXACTIVE)}, + /* GPIO2_28 - DRAM-strapping */ + {OFFSET(mmc0_dat1), (MODE(7) | PULLUDEN | PULLUP_EN)}, + /* GPIO2_4 - not routed (Pin U6) */ + {OFFSET(gpmc_wen), (MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + /* GPIO2_5 - not routed (Pin T6) */ + {OFFSET(gpmc_be0n_cle), (MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + /* GPIO2_28 - not routed (Pin G15) */ + {OFFSET(mmc0_dat1), (MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + /* GPIO3_18 - not routed (Pin B12) */ + {OFFSET(mcasp0_aclkr), (MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + {-1}, +}; + +static struct module_pin_mux uart0_pin_mux[] = { + /* UART0_RXD */ + {OFFSET(uart0_rxd), (MODE(0) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + /* UART0_TXD */ + {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, + {-1}, +}; + +static struct module_pin_mux uart234_pin_mux[] = { + /* UART2_RXD */ + {OFFSET(mii1_txclk), (MODE(1) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + /* UART2_TXD */ + {OFFSET(mii1_rxclk), (MODE(1) | PULLUDEN)}, + + /* UART3_RXD */ + {OFFSET(mii1_rxd3), (MODE(1) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + /* UART3_TXD */ + {OFFSET(mmc0_dat0), (MODE(3) | PULLUDEN)}, + /* UART3_RTS */ + {OFFSET(mmc0_cmd), (MODE(2) | PULLUDEN)}, + /* UART3_CTS */ + {OFFSET(mmc0_clk), (MODE(2) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + + /* UART4_RXD */ + {OFFSET(mii1_txd3), (MODE(3) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + /* UART4_TXD */ + {OFFSET(mii1_txd2), (MODE(3) | PULLUDEN)}, + /* UART4_RTS */ + {OFFSET(mmc0_dat2), (MODE(3) | PULLUDEN)}, + /* UART4_CTS */ + {OFFSET(mmc0_dat3), (MODE(3) | PULLUDEN | PULLUP_EN | RXACTIVE)}, + + {-1}, +}; + +static struct module_pin_mux i2c_pin_mux[] = { + /* I2C0_DATA */ + {OFFSET(i2c0_sda), (MODE(0) | RXACTIVE | PULLUDEN | SLEWCTRL)}, + /* I2C0_SCLK */ + {OFFSET(i2c0_scl), (MODE(0) | RXACTIVE | PULLUDEN | SLEWCTRL)}, + /* I2C1_DATA */ + {OFFSET(uart1_rxd), (MODE(3) | RXACTIVE | PULLUDEN | SLEWCTRL)}, + /* I2C1_SCLK */ + {OFFSET(uart1_txd), (MODE(3) | RXACTIVE | PULLUDEN | SLEWCTRL)}, + {-1}, +}; + +static struct module_pin_mux eth_pin_mux[] = { + /* ETH1 */ + {OFFSET(rmii1_refclk), MODE(0) | RXACTIVE}, /* ETH1_REFCLK */ + {OFFSET(mii1_crs), MODE(1) | RXACTIVE}, /* RMII1_CRSDV */ + {OFFSET(mii1_rxerr), MODE(1) | RXACTIVE}, /* RMII1_RXER */ + {OFFSET(mii1_txen), MODE(1)}, /* RMII1_TXEN */ + {OFFSET(mii1_rxd0), MODE(1) | RXACTIVE}, /* RMII1_RXD0 */ + {OFFSET(mii1_rxd1), MODE(1) | RXACTIVE}, /* RMII1_RXD1 */ + {OFFSET(mii1_txd0), MODE(1)}, /* RMII1_TXD0 */ + {OFFSET(mii1_txd1), MODE(1)}, /* RMII1_TXD1 */ + + /* ETH2 */ + {OFFSET(mii1_col), MODE(1) | RXACTIVE}, /* ETH2_REFCLK */ + {OFFSET(gpmc_wait0), MODE(3) | RXACTIVE}, /* RMII2_CRSDV */ + {OFFSET(gpmc_wpn), MODE(3) | RXACTIVE}, /* RMII2_RXER */ + {OFFSET(gpmc_a0), MODE(3)}, /* RMII2_TXEN */ + {OFFSET(gpmc_a11), MODE(3) | RXACTIVE}, /* RMII2_RXD0 */ + {OFFSET(gpmc_a10), MODE(3) | RXACTIVE}, /* RMII2_RXD1 */ + {OFFSET(gpmc_a5), MODE(3)}, /* RMII2_TXD0 */ + {OFFSET(gpmc_a4), MODE(3)}, /* RMII2_TXD1 */ + + /* gpio2_19, gpio 3_4, not connected on board */ + {OFFSET(mii1_rxd2), MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE}, + {OFFSET(mii1_rxdv), MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE}, + + /* ETH Management */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + + {-1}, +}; + +static struct module_pin_mux mmc1_pin_mux[] = { + {OFFSET(gpmc_ad7), (MODE(1) | RXACTIVE | PULLUP_EN)}, /* MMC1_DAT7 */ + {OFFSET(gpmc_ad6), (MODE(1) | RXACTIVE | PULLUP_EN)}, /* MMC1_DAT6 */ + {OFFSET(gpmc_ad5), (MODE(1) | RXACTIVE | PULLUP_EN)}, /* MMC1_DAT5 */ + {OFFSET(gpmc_ad4), (MODE(1) | RXACTIVE | PULLUP_EN)}, /* MMC1_DAT4 */ + {OFFSET(gpmc_ad3), (MODE(1) | RXACTIVE | PULLUP_EN)}, /* MMC1_DAT3 */ + {OFFSET(gpmc_ad2), (MODE(1) | RXACTIVE | PULLUP_EN)}, /* MMC1_DAT2 */ + {OFFSET(gpmc_ad1), (MODE(1) | RXACTIVE | PULLUP_EN)}, /* MMC1_DAT1 */ + {OFFSET(gpmc_ad0), (MODE(1) | RXACTIVE | PULLUP_EN)}, /* MMC1_DAT0 */ + {OFFSET(gpmc_csn1), (MODE(2) | RXACTIVE | PULLUP_EN)}, /* MMC1_CLK */ + {OFFSET(gpmc_csn2), (MODE(2) | RXACTIVE | PULLUP_EN)}, /* MMC1_CMD */ + {-1}, +}; + +static struct module_pin_mux lcd_pin_mux[] = { + {OFFSET(lcd_data0), (MODE(0) | PULLUDDIS)}, /* LCD-Data(0) */ + {OFFSET(lcd_data1), (MODE(0) | PULLUDDIS)}, /* LCD-Data(1) */ + {OFFSET(lcd_data2), (MODE(0) | PULLUDDIS)}, /* LCD-Data(2) */ + {OFFSET(lcd_data3), (MODE(0) | PULLUDDIS)}, /* LCD-Data(3) */ + {OFFSET(lcd_data4), (MODE(0) | PULLUDDIS)}, /* LCD-Data(4) */ + {OFFSET(lcd_data5), (MODE(0) | PULLUDDIS)}, /* LCD-Data(5) */ + {OFFSET(lcd_data6), (MODE(0) | PULLUDDIS)}, /* LCD-Data(6) */ + {OFFSET(lcd_data7), (MODE(0) | PULLUDDIS)}, /* LCD-Data(7) */ + {OFFSET(lcd_data8), (MODE(0) | PULLUDDIS)}, /* LCD-Data(8) */ + {OFFSET(lcd_data9), (MODE(0) | PULLUDDIS)}, /* LCD-Data(9) */ + {OFFSET(lcd_data10), (MODE(0) | PULLUDDIS)}, /* LCD-Data(10) */ + {OFFSET(lcd_data11), (MODE(0) | PULLUDDIS)}, /* LCD-Data(11) */ + {OFFSET(lcd_data12), (MODE(0) | PULLUDDIS)}, /* LCD-Data(12) */ + {OFFSET(lcd_data13), (MODE(0) | PULLUDDIS)}, /* LCD-Data(13) */ + {OFFSET(lcd_data14), (MODE(0) | PULLUDDIS)}, /* LCD-Data(14) */ + {OFFSET(lcd_data15), (MODE(0) | PULLUDDIS)}, /* LCD-Data(15) */ + + {OFFSET(gpmc_ad8), (MODE(1) | PULLUDDIS)}, /* LCD-Data(16) */ + {OFFSET(gpmc_ad9), (MODE(1) | PULLUDDIS)}, /* LCD-Data(17) */ + {OFFSET(gpmc_ad10), (MODE(1) | PULLUDDIS)}, /* LCD-Data(18) */ + {OFFSET(gpmc_ad11), (MODE(1) | PULLUDDIS)}, /* LCD-Data(19) */ + {OFFSET(gpmc_ad12), (MODE(1) | PULLUDDIS)}, /* LCD-Data(20) */ + {OFFSET(gpmc_ad13), (MODE(1) | PULLUDDIS)}, /* LCD-Data(21) */ + {OFFSET(gpmc_ad14), (MODE(1) | PULLUDDIS)}, /* LCD-Data(22) */ + {OFFSET(gpmc_ad15), (MODE(1) | PULLUDDIS)}, /* LCD-Data(23) */ + + {OFFSET(lcd_vsync), (MODE(0) | PULLUDDIS)}, /* LCD-VSync */ + {OFFSET(lcd_hsync), (MODE(0) | PULLUDDIS)}, /* LCD-HSync */ + {OFFSET(lcd_ac_bias_en), (MODE(0) | PULLUDDIS)},/* LCD-DE */ + {OFFSET(lcd_pclk), (MODE(0) | PULLUDDIS)}, /* LCD-CLK */ + + {-1}, +}; + +void enable_uart0_pin_mux(void) +{ + configure_module_pin_mux(uart0_pin_mux); +} + +void enable_i2c_pin_mux(void) +{ + configure_module_pin_mux(i2c_pin_mux); +} + +void enable_board_pin_mux(void) +{ + configure_module_pin_mux(eth_pin_mux); + configure_module_pin_mux(spi0_pin_mux); + configure_module_pin_mux(spi1_pin_mux); + configure_module_pin_mux(dcan0_pin_mux); + configure_module_pin_mux(dcan1_pin_mux); + configure_module_pin_mux(uart234_pin_mux); + configure_module_pin_mux(mmc1_pin_mux); + configure_module_pin_mux(lcd_pin_mux); + configure_module_pin_mux(gpios); +} diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig new file mode 100644 index 0000000..6b21f0c --- /dev/null +++ b/configs/brsmarc1_defconfig @@ -0,0 +1,107 @@ +CONFIG_ARM=y +CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_AM33XX=y +CONFIG_SYS_MPUCLK=600 +CONFIG_TARGET_BRSMARC1=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_TPL_SYS_MALLOC_F_LEN=0x0 +# CONFIG_EXPERT is not set +# CONFIG_FIT is not set +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=0 +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run b_default" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_MISC_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SEPARATE_BSS=y +# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_SPL_NAND_SUPPORT is not set +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_ITEST is not set +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="am335x-brsmarc1" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_OF_TRANSLATE is not set +# CONFIG_SPL_BLK is not set +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_OMAP_HS=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHY_NATSEMI=y +CONFIG_DM_ETH=y +CONFIG_DRIVER_TI_CPSW=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_OMAP3_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_MUSB_HOST=y +CONFIG_USB_MUSB_GADGET=y +CONFIG_USB_MUSB_TI=y +CONFIG_USB_MUSB_DSPS=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +# CONFIG_OMAP_WATCHDOG is not set +CONFIG_SPL_TINY_MEMSET=y +CONFIG_SHA1=y +CONFIG_SHA256=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/brsmarc1.h b/include/configs/brsmarc1.h new file mode 100644 index 0000000..77f8755 --- /dev/null +++ b/include/configs/brsmarc1.h @@ -0,0 +1,87 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * brsmarc1.h + * + * specific parts for B&R BRSMARC1 Motherboard + * + * Copyright (C) 2017 Hannes Schmelzer oe5hpm@oevsv.at - + * B&R Industrial Automation GmbH - http://www.br-automation.com + * + */ + +#ifndef __CONFIG_BRSMARC1_H__ +#define __CONFIG_BRSMARC1_H__ + +#include <configs/bur_cfg_common.h> +#include <configs/bur_am335x_common.h> +/* ------------------------------------------------------------------------- */ +#define CONFIG_BOARD_TYPES + +/* memory */ +#define CONFIG_SYS_MALLOC_LEN (5 * 1024 * 1024) +#define CONFIG_SYS_BOOTM_LEN (32 * 1024 * 1024) + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK) + +#define CONFIG_MACH_TYPE 3589 + +#ifndef CONFIG_SPL_BUILD + +/* Default environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \ +BUR_COMMON_ENV \ +"autoload=0\0" \ +"scradr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ +"cfgscr=mw ${dtbaddr} 0;" \ +" sf probe && sf read ${scradr} 0xC0000 0x10000 && source ${scradr};" \ +" fdt addr ${dtbaddr} || cp ${fdtcontroladdr} ${dtbaddr} 4000\0" \ +"dtbaddr=0x84000000\0" \ +"loadaddr=0x82000000\0" \ +"b_break=0\0" \ +"b_tgts_std=mmc0 mmc1 def net usb0\0" \ +"b_tgts_rcy=def net usb0\0" \ +"b_tgts_pme=net usb0 mmc0 mmc1\0" \ +"b_deftgts=if test ${b_mode} = 12; then setenv b_tgts ${b_tgts_pme};" \ +" elif test ${b_mode} = 0; then setenv b_tgts ${b_tgts_rcy};" \ +" else setenv b_tgts ${b_tgts_std}; fi\0" \ +"b_mmc0=load mmc 1 ${scradr} bootscr.img && source ${scradr}\0" \ +"b_mmc1=load mmc 1 ${loadaddr} arimg.ugz && run startsys\0" \ +"b_def=sf read ${loadaddr} 100000 700000; run startsys\0" \ +"b_net=tftp ${scradr} netscript.img && source ${scradr}\0" \ +"b_usb0=usb start && load usb 0 ${scradr} bootscr.img && source ${scradr}\0" \ +"b_default=run b_deftgts; for target in ${b_tgts};"\ +" do run b_${target}; if test ${b_break} = 1; then; exit; fi; done\0" \ +"vxargs=setenv bootargs cpsw(0,0)host:vxWorks h=${serverip}" \ +" e=${ipaddr}:${netmask} g=${gatewayip} u=vxWorksFTP pw=vxWorks\0" \ +"vxfdt=fdt addr ${dtbaddr}; fdt resize 0x8000;" \ +" fdt boardsetup\0" \ +"startsys=run vxargs && mw 0x80001100 0 && run vxfdt &&" \ +" bootm ${loadaddr} - ${dtbaddr}\0" +#endif /* !CONFIG_SPL_BUILD*/ + +/* undefine command which we not need here */ +#undef CONFIG_BOOTM_NETBSD +#undef CONFIG_BOOTM_PLAN9 +#undef CONFIG_BOOTM_RTEMS + +/* Support both device trees and ATAGs. */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +/* SPI Flash */ +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 + +/* Environment */ +#define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE +#define CONFIG_ENV_OFFSET 0x20000 +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ + CONFIG_ENV_SECT_SIZE) + +#define CONFIG_CONS_INDEX 1 +#endif /* __CONFIG_BRSMARC1_H__ */
A few small things. Makefile / config.mk need the SDPX tag as the top line. Next:
You missed adding a newline after the new TARGET.
Thanks!
Hannes Schmelzer
