[U-Boot] [PATCH 4/4 v2] vexpress64: support the Juno Development Platform
The Juno Development Platform is a physical Versatile Express device with some differences from the emulated semihosting models. The main difference is that the system is split in a SoC and an FPGA where the SoC hosts the serial ports at totally different adresses.
Signed-off-by: Linus Walleij linus.walleij@linaro.org --- ChangeLog v1->v2: - Remove a dangling C99 comment. --- arch/arm/Kconfig | 4 ++++ board/armltd/vexpress64/Kconfig | 13 +++++++++++++ board/armltd/vexpress64/MAINTAINERS | 5 +++++ configs/vexpress_aemv8a_juno_defconfig | 5 +++++ include/configs/vexpress_aemv8a.h | 19 ++++++++++++++++++- 5 files changed, 45 insertions(+), 1 deletion(-) create mode 100644 configs/vexpress_aemv8a_juno_defconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d5399f162d57..986b4c5d81db 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -736,6 +736,10 @@ config TARGET_VEXPRESS64_BASE_FVP select ARM64 select SEMIHOSTING
+config TARGET_VEXPRESS64_JUNO + bool "Support Versatile Express Juno Development Platform" + select ARM64 + config TARGET_LS2085A_EMU bool "Support ls2085a_emu" select ARM64 diff --git a/board/armltd/vexpress64/Kconfig b/board/armltd/vexpress64/Kconfig index 80eaa3d3ab08..7d5e7bee8b9a 100644 --- a/board/armltd/vexpress64/Kconfig +++ b/board/armltd/vexpress64/Kconfig @@ -23,3 +23,16 @@ config SYS_CONFIG_NAME default "vexpress_aemv8a"
endif + +if TARGET_VEXPRESS64_JUNO + +config SYS_BOARD + default "vexpress64" + +config SYS_VENDOR + default "armltd" + +config SYS_CONFIG_NAME + default "vexpress_aemv8a" + +endif diff --git a/board/armltd/vexpress64/MAINTAINERS b/board/armltd/vexpress64/MAINTAINERS index 66c8dffa1634..0ba044d7ff87 100644 --- a/board/armltd/vexpress64/MAINTAINERS +++ b/board/armltd/vexpress64/MAINTAINERS @@ -9,3 +9,8 @@ VEXPRESS_AEMV8A_SEMI BOARD M: Linus Walleij linus.walleij@linaro.org S: Maintained F: configs/vexpress_aemv8a_semi_defconfig + +JUNO DEVELOPMENT PLATFORM BOARD +M: Linus Walleij linus.walleij@linaro.org +S: Maintained +F: configs/vexpress_aemv8a_juno_defconfig diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig new file mode 100644 index 000000000000..d28a4286e5af --- /dev/null +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -0,0 +1,5 @@ +# ARM Ltd. Juno Board Reference Design +CONFIG_ARM=y +CONFIG_TARGET_VEXPRESS64_JUNO=y +CONFIG_DEFAULT_DEVICE_TREE="vexpress64" +CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index 85894bedf8bd..7fb28a54ba17 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -21,7 +21,8 @@
#define CONFIG_REMAKE_ELF
-#ifndef CONFIG_TARGET_VEXPRESS64_BASE_FVP +#if !defined(CONFIG_TARGET_VEXPRESS64_BASE_FVP) && \ + !defined(CONFIG_TARGET_VEXPRESS64_JUNO) /* Base FVP and Juno not using GICv3 yet */ #define CONFIG_GICV3 #endif @@ -44,6 +45,9 @@ /* ATF loads u-boot here for BASE_FVP model */ #define CONFIG_SYS_TEXT_BASE 0x88000000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x03f00000) +#elif CONFIG_TARGET_VEXPRESS64_JUNO +#define CONFIG_SYS_TEXT_BASE 0xe0000000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fff0) #else #define CONFIG_SYS_TEXT_BASE 0x80000000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fff0) @@ -88,10 +92,15 @@ #define V2M_KMI0 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(6)) #define V2M_KMI1 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(7))
+#ifdef CONFIG_TARGET_VEXPRESS64_JUNO +#define V2M_UART0 0x7ff80000 +#define V2M_UART1 0x7ff70000 +#else /* Not Juno */ #define V2M_UART0 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(9)) #define V2M_UART1 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(10)) #define V2M_UART2 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(11)) #define V2M_UART3 (V2M_PA_CS3 + V2M_PERIPH_OFFSET(12)) +#endif
#define V2M_WDT (V2M_PA_CS3 + V2M_PERIPH_OFFSET(15))
@@ -122,6 +131,9 @@ #ifdef CONFIG_TARGET_VEXPRESS64_BASE_FVP #define GICD_BASE (0x2f000000) #define GICC_BASE (0x2c000000) +#elif CONFIG_TARGET_VEXPRESS64_JUNO +#define GICD_BASE (0x2C010000) +#define GICC_BASE (0x2C02f000) #else #define GICD_BASE (0x2C001000) #define GICC_BASE (0x2C002000) @@ -140,7 +152,11 @@
/* PL011 Serial Configuration */ #define CONFIG_PL011_SERIAL +#ifdef CONFIG_TARGET_VEXPRESS64_JUNO +#define CONFIG_PL011_CLOCK 7273800 +#else #define CONFIG_PL011_CLOCK 24000000 +#endif #define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0, \ (void *)CONFIG_SYS_SERIAL1} #define CONFIG_CONS_INDEX 0 @@ -161,6 +177,7 @@ #define CONFIG_CMD_ENV #define CONFIG_CMD_FLASH #define CONFIG_CMD_IMI +#define CONFIG_CMD_LOADB #define CONFIG_CMD_MEMORY #define CONFIG_CMD_MII #define CONFIG_CMD_NET
Linus Walleij
