[U-Boot] [PATCH] mx7_common: initialize generic timer on all CPU's
Use CONFIG_TIMER_CLK_FREQ to let the non-secure init code initialize the generic timer on all CPU's. This allows to make use of the timer freuquency register also on other CPU than the start CPU which is important for KVM.
Signed-off-by: Stefan Agner stefan.agner@toradex.com ---
include/configs/mx7_common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 9f80f9f..7295fa6 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -21,6 +21,7 @@ #define CONFIG_MXC_GPT_HCLK #define CONFIG_SYSCOUNTER_TIMER #define CONFIG_SC_TIMER_CLK 8000000 /* 8Mhz */ +#define CONFIG_TIMER_CLK_FREQ CONFIG_SC_TIMER_CLK #define CONFIG_SYS_FSL_CLK
#define CONFIG_SYS_BOOTM_LEN 0x1000000
Hi Stefan
From: Stefan Agner [mailto:stefan@agner.ch] Sent: Dienstag, 26. Juli 2016 07:58
[Krummenacher Max] Could you elaborate on the 'other CPUs'? The SMP companions Cortex A7 or the Cortex M4. And what exactly is KVM here?
2.9.0
Thanks & Regards, Max Krummenacher
Hi Max,
On 2016-07-26 02:31, Max Krummenacher wrote:
Hi Stefan
This is only for the primary A-Class CPU complex. The generic timer is only available there.
Kernel-based Virtual Machine, the Linux integrated hypervisor. The Cortex-A7 support ARM's virtualization extensions which allow to make use of KVM...
-- Stefan
2.9.0
On 26/07/2016 19:35, Stefan Agner wrote:
Hi Max,
Hi Stefan
Best regards, Stefano Babic
Max Krummenacher
Stefan Agner
Stefano Babic
